03-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS9820 SeriesReference GuidesCommand ReferencesH3C S9820-64H Switch Command References-Release 66xx-6W10403-Layer 2—LAN Switching Command Reference
16-Service loopback group commands
16-Service loopback group commands 50.65 KB
display service-loopback group
Use display service-loopback group to display service loopback group information.
display service-loopback group [ group-id ]
group-id: Specifies a service loopback group ID. The value range for the group-id argument is 1 to 1024. If you do not specify a service loopback group, this command displays information about all service loopback groups.
# Display information about service loopback group 5.
<Sysname> display service-loopback group 5
Group ID: 5                Service type: Tunnel
  Member                            Status
  HundredGigE1/0/1                  Selected
  HundredGigE1/0/2                  Unselected
Group ID
Service loopback group ID.
Service type
Service type of the service loopback group:
·     Multicast-tunnel—Supports multicast tunnel services.
·     Tunnel—Supports unicast tunnel services.
·     Multiport—Supports multiport ARP services.
·     VSI-gateway—Supports VSI gateway services.
·     Telemetry-stream—Supports Telemetry streaming services.
Member
Member ports of the service loopback group.
Status
Member port state:
·     Unselected—The port is in Unselected state. An unselected port cannot forward traffic of the service type.
·     Selected—The port is in Selected state. A selected port can forward traffic of the service type.
port service-loopback group
Use port service-loopback group to assign a port to a service loopback group.
Use undo port service-loopback group to remove a port from a service loopback group.
port service-loopback group group-id
A port does not belong to a service loopback group.
When you assign a port to a service loopback group, the system removes the configuration on the port. Make sure you are fully aware of the impact of this command before using it on a live network.
To avoid IRF split, do not assign a port to a service loopback group if that port is the only IRF physical interface of an IRF port.
Before assigning a port to a service loopback group, make sure the port supports the service type of the group.
A port can belong to only one service loopback group. You can assign a maximum of 32 ports to a service loopback group.
For correct traffic processing, make sure a service loopback group has a minimum of one member port when it is being used by a feature.
# Assign HundredGigE 1/0/1 to service loopback group 5.
[Sysname-HundredGigE1/0/1] port service-loopback group 5
Use service-loopback group to create a service loopback group and specify its service type.
Use undo service-loopback group to delete a service loopback group.
service-loopback group group-id type { { multicast-tunnel | tunnel } * | multiport | telemetry-stream | vsi-gateway }
undo service-loopback group group-id
No service loopback groups exist.
type: Specifies the service type of the service loopback group.
multicast-tunnel: Specifies multicast tunnel services.
tunnel: Specifies unicast tunnel services.
multiport: Specifies multiport ARP services.
telemetry-stream: Specifies Telemetry streaming services.
vsi-gateway: Specifies VSI gateway services.
Service loopback groups must work with other features, such as GRE. A service loopback group can be used by multiple features.
You must create a service loopback group before you can use it with a feature.
You can configure only one service loopback group for a service type. You cannot change the service type of a service loopback group.
To ensure correct traffic processing, do not delete a service loopback group that is being used by a feature.
# Create service loopback group 5 and specify unicast tunnel services for the group.
[Sysname] service-loopback group 5 type tunnel
  • Become a Partner
  • Partner Resources
