- 03-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Bulk interface commands
- 03-Ethernet interface commands
- 04-Ethernet link aggregation commands
- 05-DRNI commands
- 06-Port isolation commands
- 07-VLAN commands
- 08-MVRP commands
- 09-Loopback, null, and inloopback interface commands
- 10-QinQ commands
- 11-VLAN mapping commands
- 12-Loop detection commands
- 13-Spanning tree commands
- 14-LLDP commands
- 15-L2PT commands
- 16-Service loopback group commands
- 17-Cut-through Layer 2 forwarding commands
05-DRNI commands | 276.25 KB |
display drni consistency-check status
drni auto-recovery reload-delay
drni consistency-check disable
drni mad exclude logical-interfaces
reset drni troubleshooting history
DRNI commands
Use display drni consistency to display information about the configuration consistency check done by DRNI.
display drni consistency { type1 | type2 } { global | interface interface-type interface-number }
type1: Specifies type 1 configuration consistency check.
type2: Specifies type 1 configuration consistency check.
global: Specifies global information.
interface interface-type interface-number: Specifies a DR interface by its type and number.
This command does not display consistent type 1 and type 2 settings.
The device does not check the invalid VLANs for inconsistency during global or interface-specific type 2 configuration consistency check.
This command displays the following fields only when VLAN or VLAN interface inconsistencies are detected during global type 2 configuration consistency check:
· Vlan-int(shutdown).
· Vlan-int(IPv4).
· Vlan-int(IPv6).
· Vlan-int(VRRPv4).
# (Release 6607.) Display global information about type 1 configuration consistency check.
<Sysname> display drni consistency type1 global
VLAN consistency check: Success
Local IPP link type: Access
Peer IPP link type: Access
Local IPP PVID: 1
Peer IPP PVID: 1
STP consistency check: Success
Local global STP protocol state: Enabled
Peer global STP protocol state: Enabled
Local STP mode: MSTP
Peer STP mode: MSTP
Local MST region name: text
Peer MST region name: text
Local MSTP revision level: 0
Peer MSTP revision level: 0
MSTP VLAN-to-instance mappings: Consistent
STP-enabled VLANs: Consistent
# (Release 6607.) Display global information about type 2 configuration consistency check.
<Sysname> display drni consistency type2 global
Local VLAN interfaces:
2-10, 15, 20-30, 40, 50
Peer VLAN interfaces:
Passing PVID and VLANs (tagged) on local IPP:
1
Passing PVID and VLANs (tagged) on peer IPP:
1
Invalid VLANs on local IPP:
None
# (Release 6607.) Display information about type 1 configuration consistency check on DR interface Bridge-Aggregation 1.
<Sysname> display drni consistency type1 interface bridge-aggregation 1
LAGG consistency check: Success
Local aggregation mode: Dynamic
Peer aggregation mode: Dynamic
VLAN consistency check :Success
Local link type: Trunk
Peer link type: Trunk
Local PVID: 10
Peer PVID: 10
Local STP protocol state: Enabled
Peer STP protocol state: Enabled
# (Release 6607.) Display information about type 2 configuration consistency check on DR interface Bridge-Aggregation 1.
<Sysname> display drni consistency type2 interface bridge-aggregation 1
Passing VLANs (tagged) on local DR interface:
None
Passing VLANs (tagged) on peer DR interface:
None
Passing VLANs (untagged) on local DR interface:
1
Passing VLANs (untagged) on peer DR interface:
1
Invalid VLANs on local DR interface:
None
Feature consistency check |
Result of configuration consistency check for a feature: · Success. · Failure. |
Local VLAN interfaces Peer VLAN interfaces |
VLAN interfaces on the local or peer device. These fields display VLAN interfaces that meet the following conditions: · The interface is up. · The IPP has been assigned to the corresponding VLANs. |
Passing PVID and VLANs (tagged) on local IPP |
VLANs of which the local IPP forwards tagged traffic or PVID of which the local IPP forwards traffic. This field does not include VLANs that are permitted on the local IPP but have not been created yet. |
Passing PVID and VLANs (tagged) on peer IPP |
VLANs of which the peer IPP forwards tagged traffic or PVID of which the peer IPP forwards traffic. This field does not include VLANs that are permitted on the peer IPP but have not been created yet. |
Invalid VLANs on local IPP |
VLANs of which the local IPP cannot forward traffic because of incomplete or inconsistent VLAN settings: · VLANs to which the local IPP is assigned as an untagged member (PVID not included). · VLANs that contain the local IPP but do not contain the peer IPP. If no invalid VLANs exist, this field displays None. |
Passing VLANs (tagged) on local DR interface Passing VLANs (tagged) on peer DR interface |
VLANs of which the local or peer DR interface forwards tagged traffic. These fields do not include VLANs that are permitted on the DR interfaces but have not been created yet. |
Passing VLANs (untagged) on local DR interface Passing VLANs (untagged) on peer DR interface |
VLANs of which the local or peer DR interface forwards untagged traffic. These fields do not include VLANs that are permitted on the DR interfaces but have not been created yet. |
Invalid VLANs on local DR interface |
VLANs of which the local DR interface cannot forward traffic because of incomplete or inconsistent VLAN settings. A VLAN is in this list if it meets one of the following conditions: · The VLAN is permitted on the local DR interface, but it is not in the passing PVID and VLANs (tagged) list on the local or peer IPP. · The VLAN is in the passing PVID and VLANs (tagged) list on the local or peer IPP, but it is not permitted on the local DR interface. · The VLAN has been created on the local DR member device and is permitted on both local and DR interfaces, but it has not been created on the DR peer yet. If no invalid VLANs exist, this field displays None. |
# (Release 6616 and later.) Display global information about type 1 configuration consistency check.
Configuration Local Peer
Link type Access Trunk
PVID 10 20
Global STP Enabled Disabled
STP mode MSTP RSTP
MST region abc def
Revision level 100 200
MSTI(VLANs) 1(1,64,127,190,316,379,442, 1(2,4,61,121,261,291,362)
505,568,631)
STP-enabled VLANs 10,12,14,16,18 20,22,24,26,28
# (Release 6616 and later.) Display global information about type 2 configuration consistency check.
VLANs 1,3,5,7,9 2,4,6,8,10
Vlan-int 10,12,14,17,22,33 11,19,23,27,47
Vlan-int(shutdown) 100,103,107,200,301 200,261,290,333,465
Vlan-int(IPv4) 1019(192.168.1.1/29) 1019(192.168.1.2/29)
Vlan-int(IPv6) 40(fc00:0:0:102:0:0:0:1/64) 40(fc00:0:0:102:0:0:0:2/64)
Vlan-int(VRRPv4) 100(192.168.100.1/24) 100(192.168.100.2/24)
Global BPDU guard Enabled Disabled
MAC aging time 100s No-aging
VSI name vpna
VNI 10
Gateway interface VSI-interface1
VSI name vpnb vpnb
VNI 20 30
VSI interface 1 1
MAC address 1-1-1 2-2-2
IPv4 address 192.168.0.1/24 192.168.0.2/24
IPv6 address 1::1/64 1::2/64
Physical state UP DOWN
Protocol state UP DOWN
VSI interface 2 2
MAC address 1-1-1 2-2-3
IPv4 address 192.168.1.1/24 192.168.1.2/24
IPv6 address 2::2/64 2::2/128
R2 mode Single Disabled
R2 statistics Global ACL
R2 ACL name a b
R2 drop Enabled Disabled
R2 report interval 10 20
R2 inactive timeout 30 50
# (Release 6616 and later.) Display information about type 1 configuration consistency check on DR interface Bridge-Aggregation 1.
LAGG mode Static Dynamic
PVID 10 20
# (Release 6616 and later.) Display information about type 2 configuration consistency check on DR interface Bridge-Aggregation 1.
LACP select speed Enabled Disabled
LAGG ignore speed Enabled Disabled
Root guard Enabled Disabled
Local |
Local configuration. This field displays a hyphen (-) if no configuration inconsistency exists. If the parameter does not have a local configuration, this field is empty. |
Peer |
Peer configuration. This field displays a hyphen (-) if no configuration inconsistency exists. If the parameter does not have a peer configuration, this field is empty. |
Link type |
Link type of the IPP: · Access. · Hybrid. · Trunk. |
PVID |
PVID of the IPP. |
MSTI(VLANs) |
VLAN-to-MSTI mappings. This field displays Inconsistent if inconsistent VLAN-to-MSTI mappings are detected and DRNI cannot obtain VLAN-to-MSTI mappings. |
VLANs |
VLANs permitted by an interface. The system checks tagged VLANs before untagged VLANs. |
Vlan-int(shutdown) |
VLAN interfaces that were administratively shut down. |
Vlan-int(VRRPv4) |
Virtual IPv4 address of the VRRP group on a VLAN interface. |
MAC aging time |
MAC aging timer in seconds. This field displays No-aging if MAC address entries do not age out. |
VSI name |
Name of the VSI that has ACs on a DR interface. |
VNI |
VXLAN ID of the VSI. |
Gateway interface |
VSI interface associated with the VSI. |
VSI interface |
VSI interface number. |
MAC address |
MAC address of the VSI interface. |
IPv4 address |
IPv4 address of the VSI interface. |
IPv6 address |
IPv6 address of the VSI interface. |
Physical state |
Physical link state of the VSI interface: · ADM—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down. · UP—The interface is both administratively and physically up. |
Protocol state |
Data link layer state of the VSI interface: · DOWN—The data link layer protocol is down. · UP—The data link layer protocol is up. |
R2 mode |
Mode used by NetAnalysis to analyze RoCEv2 traffic: · Disabled. · Single. · Bidir. |
R2 statistics |
State of RoCEv2 traffic statistics collection: · Disabled. · Global. · ACL. |
R2 ACL name |
ACL used to match RoCEv2 traffic for RoCEv2 traffic statistics collection. |
R2 drop |
State of global RoCEv2 packet loss analysis: · Enabled. · Disabled. |
R2 report interval |
Interval for reporting RoCEv2 traffic statistics to the NDA, in seconds. |
R2 inactive timeout |
Aging timer for inactive RoCEv2 flows, in seconds. |
LACP select speed |
Whether a DR interface uses port speed as the prioritized criterion for reference port selection: · Enabled. · Disabled. |
LAGG ignore speed |
Whether a DR interface ignores port speed in setting the aggregation states of member ports: · Enabled. · Disabled. |
Use display drni consistency-check status to display the configuration consistency check status.
# Display the configuration consistency check status.
<Sysname> display drni consistency-check status
Global Consistency Check Configuration
Local status : Enabled Peer status : Enabled
Local check mode : Strict Peer check mode : Strict
Consistency Check on Modules
Module Type1 Type2
LAGG Check Check
VLAN Check Check
STP Check Check
MAC Not Check Check
L2VPN Not Check Check
Type1 Consistency Check Result
Global consistency check result: SUCCESS
Inconsistent global modules: -
DR interface DR group ID Check Result Inconsistency modules
BAGG4 4 SUCCESS -
Local status |
Status of configuration consistency check at the local end: · Enabled. · Disabled. |
Peer status |
Status of configuration consistency check at the peer end: · Enabled. · Disabled. |
Local check mode |
Configuration consistency check mode at the local end: · Loose. · Strict. |
Peer check mode |
Configuration consistency check mode at the peer end: · Loose. · Strict. |
Module |
Feature module name. |
Type1 |
Whether DRNI checks the module for a type 1 configuration inconsistency: · Check. · Not Check. |
Type2 |
Whether DRNI checks the module for a type 2 configuration inconsistency: · Check. · Not Check. |
Global consistency check result |
Result of global configuration consistency check: · FAILURE. · SUCCESS. |
Inconsistent global modules |
Modules that failed global configuration consistency check. If the check succeeded, this field displays a hyphen (-). |
DR interface |
Abbreviated name of the DR interface. |
Inconsistency modules |
Modules that failed interface configuration consistency check. If the check succeeded, this field displays a hyphen (-). |
display drni drcp statistics
Use display drni drcp statistics to display DRCPDU statistics.
display drni drcp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a Layer 2 aggregate interface by its type and number. If you do not specify this option, the command displays the DRCPDU statistics about the IPP and all DR interfaces.
# Display DRCPDU statistics.
<Sysname> display drni drcp statistics
* indicates the port is the IPP.
Interface type:
BAGG -- Bridge-Aggregation, Tun -- Tunnel
Interface State Sent Received(Normal/Error/Unknown)
*BAGG3 UP 30 26/0/0
BAGG4 UP 29 26/0/0
# Display DRCPDU statistics about Bridge-Aggregation 4.
<Sysname> display drni drcp statistics interface bridge-aggregation 4
Interface type:
Interface : BAGG4
State : UP
Sent : 31
Received (Normal/Error/Unknown): 28/0/0
Last received packet information:
Source MAC address: 3cd4-437d-0300
Time: 2019/09/11 09:19:58
Action: Accept
Interface type |
Interface type: · BAGG—Layer 2 aggregate interface. · Tun—Tunnel interface. This type is not supported in the current software version. |
Abbreviated interface name. The name of the IPP is prefixed with an asterisk (*). |
State |
Physical state of the interface: · UP. · DOWN. |
Sent |
Number of sent DRCPDUs. |
Received (Normal/Error/Unknown) |
Numbers of received normal, error, and unrecognized DRCPDUs. |
Last received packet information |
Information about the most recently received DRCPDU. |
Time |
Date and time when the DRCPDU was received, in the YYYY/MM/DD hh:mm:ss format. |
Action |
Action taken on the DRCPDU: · Accept. · Drop. If the DRCPDU was dropped, this field also displays the reason for dropping the DRCPDU. |
reset drni drcp statistics
display drni keepalive
Use display drni keepalive to display DR keepalive packet statistics.
# Display DR keepalive packet statistics.
<Sysname> display drni keepalive
Neighbor keepalive link status: Up
Neighbor is alive for: 135642 s 501 ms
Keepalive packet transmission status:
Sent: Successful
Received: Successful
Last received keepalive packet information:
Source IP address: 10.0.0.2
Time: 2019/09/11 09:21:51
Action: Accept
Distributed relay keepalive parameters:
Destination IP address: 10.0.0.2
Source IP address: 10.0.0.1
Keepalive UDP port : 6400
Keepalive VPN name : vpn1
Keepalive interval : 1000 ms
Keepalive timeout : 5 sec
Keepalive hold time: 3 sec
Table 5 Command output
Neighbor keepalive link status |
State of the DR peer: · Unknown—No DR peer is detected because the destination IP address of keepalive packets is not specified. · Up—The DR peer is up. · Down—The DR peer is down. |
Neighbor is alive for |
Time period for which the DR peer has been up. |
Last received keepalive packet information |
Information about the most recently received keepalive packet. |
Time |
Date and time when the keepalive packet was received, in the YYYY/MM/DD hh:mm:ss format. If the device has not received any keepalive packets, this field displays N/A. |
Action |
Action taken on the keepalive packet: · Accept. · Drop. If the keepalive packet was dropped, this field also displays the reason for dropping the packet. |
Destination IP address |
Destination IP address of keepalive packets sent by the device. |
Source IP address |
Source IP address of keepalive packets sent by the device. |
Keepalive UDP port |
Destination UDP port of keepalive packets. |
Keepalive VPN name |
VPN instance for keepalive packets. If no VPN instance is configured for keepalive packets, this field displays N/A. |
Keepalive interval |
Interval at which the device sends keepalive packets. |
Keepalive timeout |
Keepalive timeout timer. |
Keepalive hold time |
Keepalive hold timer setting. The keepalive hold timer specifies the amount of time that the device uses to identify the cause of an IPL down event. |
drni keepalive { ip | ipv6 }
drni keepalive hold-time
drni keepalive interval
display drni mad verbose
Use display drni mad verbose to display detailed DRNI MAD information.
# (Release 6607.) Display detailed DRNI MAD information.
<Sysname> display drni mad verbose
DRNI MAD DOWN state : No
Restore delay : 30 s
Remaining restore delay: -
Keepalive status : Normal
System number Keepalive Destination IP UDP port
1 1.1.1.1 1000
DRNI MAD default action: DOWN
Port configuration for DRNI MAD DOWN action:
Included ports(user-configured):
Bridge-Aggregation1
HundredGigE1/0/5(ineffective)
Included ports(system-configured):
Member interfaces of DR Bridge-Aggregation3:
HundredGigE1/0/3
Excluded ports(user-configured):
Bridge-Aggregation2
HundredGigE1/0/4
Excluded ports(system-configured):
Management interfaces:
M-GigabitEthernet0/0/0
DR interfaces:
Bridge-Aggregation4
IPP:
Bridge-Aggregation3
Member interfaces of IPP Bridge-Aggregation3:
HundredGigE1/0/1
HundredGigE1/0/2
# (Release 6616 and later.) Display detailed DRNI MAD information.
DRNI MAD DOWN persistence: Disabled
Excluding logical interfaces: Disabled
Bridge-Aggregation1
HundredGigE 1/0/3
Bridge-Aggregation2
HundredGigE1/0/4
DR interfaces:
Bridge-Aggregation4
IPP:
Bridge-Aggregation3
HundredGigE1/0/1
HundredGigE1/0/2
Table 6 Command output
DRNI MAD DOWN state |
Whether the network interfaces on the device are in DRNI MAD DOWN state: · Yes—The device has network interfaces placed in DRNI MAD DOWN state. · No—No network interfaces are in DRNI MAD DOWN state. If this field displays Yes, check the IPL for the link down issue to remove multi-active collision. |
Restore delay |
Data restoration interval, in seconds. |
Remaining restore delay |
The remaining time (in seconds) before the data restoration interval expires. If the data restoration interval has not started, this field displays a hyphen (-). |
Keepalive status |
The field is supported only in Release 6607. Keepalive link status: · Normal—The keepalive link is operating correctly. The device can receive keepalive packets from the peer. · Faulty—The keepalive link is not operating correctly. The device cannot receive keepalive packets from the peer. |
System number |
The field is supported only in Release 6607. DR system number. |
Keepalive Destination IP |
The field is supported only in Release 6607. Destination IP address of keepalive packets. |
UDP port |
The field is supported only in Release 6607. Destination UDP port of keepalive packets. |
DRNI MAD default action |
Default action to take on network interfaces when the DR system splits: · DOWN—Shut down interfaces and place them in DRNI MAD DOWN state. · NONE—DRNI MAD does not take action on interfaces. |
DRNI MAD DOWN persistence |
The field is supported only in Release 6616 and later. DRNI MAD DOWN state persistence: · Enabled—The DR member device does not bring up the network interfaces in DRNI MAD DOWN state when its role changes from secondary to primary. · Disabled—The DR member device brings up the network interfaces in DRNI MAD DOWN state when its role changes from secondary to primary. |
Excluding logical interfaces |
Whether all logical interfaces are excluded from the shutdown action by DRNI MAD: · Enabled. · Disabled. |
Included ports(user-configured) |
Network interfaces manually configured to be shut down by DRNI MAD when the DR system splits. An interface entry will be marked as ineffective if the system does not allow the specified interface to be shut down by DRNI MAD. DRNI MAD will not shut down interfaces in ineffective entries when the DR system splits. The following are interfaces not allowed to be shut down by DRNI MAD: · Interfaces automatically excluded from being shut down by DRNI MAD. · Interfaces forced to stay up. |
Included ports(system-configured) |
Network interfaces automatically set by the system to shut down by DRNI MAD when the DR system splits. Aggregation member ports of DR interfaces are in this category of interfaces. |
Excluded ports(user-configured) |
Network interfaces manually configured to not be shut down by DRNI MAD. An interface entry will be marked as ineffective if the specified interface is in the list of ports excluded by the system from the DRNI MAD shutdown action. In this situation, the manual configuration does not take effect. |
Excluded ports(system-configured) |
Network interfaces set by the system to not shut down by DRNI MAD, including: · Management interfaces. · DR interfaces. · IPP. · Aggregation member interfaces if a Layer 2 aggregate interface is used as the IPP. |
drni mad default-action
drni mad exclude interface
drni mad include interface
drni mad persistent
display drni role
Use display drni role to display DR role information.
display drni role
# (Release 6607.) Display DR role information.
<Sysname> display drni role
DR Role priority Bridge MAC Configured role Effective role
Local 32667 0000-0001-002e Primary Primary
Peer 32667 00e0-fc00-512d Secondary Secondary
Table 7 Command output
DR |
Device location: · Local—The local device. · Peer—The DR peer. |
Configured role |
The DR role you have configured for the device: · Primary. · Secondary. If the device role is unknown, this field displays None. |
Effective role |
Current role of the device: · Primary. · Secondary. If the device role is unknown, this field displays None. |
# (Release 6616 and later.) Display DR role information.
Effective role information
Factors Local Peer
Effective role Primary Secondary
Initial role None None
MAD DOWN state Yes Yes
Health level 0 0
Role priority 32768 32768
Bridge MAC 3cd4-3ce1-0200 3cd4-437d-0300
Effective role trigger: IPL calculation
Effective role reason: Bridge MAC
Configured role information
Factors Local Peer
Configured role Primary Secondary
Table 8 Command output
Factors |
Factors used in role calculation. |
Local |
Local configuration. |
Peer |
Peer configuration. |
Effective role |
Effective device role: · None. · Primary. · Secondary. |
Initial role |
Device role before role calculation: · None. · Primary. · Secondary. |
MAD DOWN state |
Whether there were interfaces in DRNI MAD DOWN state during role calculation: · Yes. · No. This field displays N/A if no peer exists. |
Health level |
Health level of the device during role calculation. The member device with a lower value is healthier. This field displays N/A if no peer exists. |
Effective role trigger |
Why effective role calculation was triggered: · DR system init—DR system initialization. · IPL down and all local DR interfaces down—The IPL and all local DR interfaces went down. · IPL down and all peer DR interfaces down—The IPL and all peer DR interfaces went down. · IPL and keepalive link down—Both the IPL and keepalive link went down. · IPL calculation—The local device role was calculated over the IPL. · IPL down and role calculation based on keepalive link—The IPL went down, and the local device role was calculated over the keepalive link. |
Effective role reason |
Factor that determined the effective device role: · No peer existed. In this situation, a hyphen (-) is displayed. · Single None role. One DR member device had the None role, and the other DR member device had the Primary role. · MAD status. · Health level. · Role priority. · Bridge MAC. |
Configured role |
Manually assigned device role: · None. · Primary. · Secondary. |
drni role priority
display drni summary
Use display drni summary to display summary information about the IPP and DR interfaces.
# Display summary information about the IPP and DR interfaces. In this example, global configuration consistency check was successful.
<Sysname> display drni summary
Flags: A -- Aggregate interface down, B -- No peer DR interface configured
C -- Configuration consistency check failed
IPP: BAGG3
IPP state (cause): UP
Keepalive link state (cause): UP
DR interface information
DR interface DR group Local state (cause) Peer state Remaining down time(s)
BAGG4 4 UP UP -
Table 9 Command output
IPP |
Abbreviated name of the IPP. |
IPP state (cause) |
State of the IPP: · UP. · DOWN. If the IPP is down, this field also displays the cause of the down state. |
Keepalive link state |
The field is supported only in Release 6607. State of the keepalive link: · UP. · DOWN. |
Keepalive link state (cause) |
The field is supported only in Release 6616 and later. State of the keepalive link: · UP. · DOWN. Cause of the keepalive link down event: · DR system init—DR system initialization. · Local IP not configured—The local end does not have source and destination IP address settings for the keepalive link. · Local Tx failed—Packet transmission failed on the local end. · Local Rx timeout—Packet reception timed out on the local end. · Peer Rx timeout—Packet reception timed out on the peer end. |
DR interface |
State (Cause) |
The field is supported only in Release 6607. State of the DR interface: · UP. · DOWN. If the DR interface is down, this field also displays the cause of the down state: · A—The aggregate interface went down. · B—The role of the local device was None. · C—The peer DR interface did not exist. · D—The aggregate interface was placed in DRNI MAD DOWN state. · E—Configuration consistency check failed. |
Local state (cause) |
The field is supported only in Release 6616 and later. State of the DR interface: · UP. · DOWN. If the DR interface is down, this field also displays the cause of the down state: · A—The aggregate interface went down. · B—The peer DR interface did not exist. · C—Configuration consistency check failed. |
Peer state |
The field is supported only in Release 6616 and later. State of the peer DR interface: · UP. · DOWN—No peer DR interface exists or the peer DR interface is down. · UNKNOWN—The state of the peer DR interface is unknown when the IPL is down. |
Remaining down time (s) |
Remaining time (in seconds) during which the DR interface will stay in DRNI MAD DOWN state. If the DR interface is not in DRNI MAD DOWN state, this field displays a hyphen (-). |
display drni system
Use display drni system to display the DR system settings.
display drni system
# (Release 6607.) Display the DR system settings.
<Sysname> display drni system
Flags: A -- DR system init, B -- IPL down and all DR interfaces down
C -- IPL and keepalive link down, D -- IPL calculation
E -- IPL down and role calculation based on keepalive link
F -- Local role is None and peer role is Primary before IPL comes up
G -- Local role is Primary and peer role is None before IPL comes up
Local system number: 1 Peer system number: 2
Local system MAC: 0001-0001-0001 Peer system MAC: 0001-0001-0001
Local system priority: 123 Peer system priority: 123
Local role priority: 32768 Peer role priority: 32768
Local bridge MAC: 3cd4-3ce1-0200 Peer bridge MAC: 3cd4-437d-0300
Local configured role: Primary Peer configured role: Secondary
Local effective role(trigger): Primary(D) Peer effective role: Secondary
System timer information
Timer State Value (s) Remaining time (s)
Auto recovery Disabled - -
Restore delay Disabled 30 -
Table 10 Command output
Local system number |
Local DR system number. If the parameter is not configured, this field displays N/A. |
Peer system number |
Peer DR system number. If the parameter is not configured or the peer does not exist, this field displays N/A. |
Local system MAC |
Local DR system MAC address. If the parameter is not configured, this field displays N/A. |
Peer system MAC |
Peer DR system MAC address. If the parameter is not configured or the peer does not exist, this field displays N/A. |
Local system priority |
Local DR system priority. If the parameter is not configured, this field displays N/A. |
Peer system priority |
Peer DR system priority. If the parameter is not configured or the peer does not exist, this field displays N/A. |
Local role priority |
Local DR role priority. If the parameter is not configured, this field displays N/A. |
Peer role priority |
Peer DR role priority. If the parameter is not configured or the peer does not exist, this field displays N/A. |
Local bridge MAC |
Local bridge MAC address. |
Peer bridge MAC |
Peer bridge MAC address. If the peer does not exist, this field displays N/A. |
Local configured role |
The role assigned to the local device: · None. · Primary. · Secondary. |
Peer configured role |
The role assigned to the peer device: · None. · Primary. · Secondary. |
Local effective role(trigger) |
Effective role of the local device: · None. · Primary. · Secondary. Reason for the role change: · A—DR system initialization. · B—All DR interfaces were shut down because the IPL failed. · C—Both the IPL and keepalive link failed. · D—The local role was negotiated over the IPL. · E—The IPL failed and the local role was negotiated over the keepalive link. · F—Because the IPL failed, the local and peer roles were set to none and primary, respectively. · G—Because the IPL failed, the local and peer roles were set to primary and none, respectively. |
Peer effective role |
Effective role of the peer device: · None. · Primary. · Secondary. |
Timer |
Timer type: · Auto recovery—Reload delay timer. · Restore delay—Data restoration interval. |
State |
State of the timer: · Enabled. · Disabled. |
Value (s) |
Value of the timer, in seconds. |
Remaining time (s) |
Remaining time of the timer, in seconds. If the timer has not started, this field displays a hyphen (-). |
# (Release 6616 and later.) Display the DR system settings.
System information
Local effective role: Primary Peer effective role: Secondary
Health level: 0
Standalone mode on split: Enabled
In standalone mode: Yes
Consistency-check delay Disabled 15 -
Standalone delay Disabled - -
Role to None delay Disabled 60 -
Table 11 Command output
Local system MAC |
Peer system MAC |
Local bridge MAC |
Peer bridge MAC |
Local effective role |
Effective role of the local device: · None. · Primary. · Secondary. |
Health level |
Health level of the device. The member device with a lower value is healthier. |
Standalone mode on split |
Whether DRNI standalone mode is enabled: · Enabled. · Disabled. |
In standalone state |
Whether the device is in DRNI standalone mode: · Yes. · No. |
Timer |
Timer type: · Auto recovery—Reload delay timer. · Restore delay—Data restoration interval. · Consistency check delay—Configuration consistency check delay timer. · Standalone delay—Delay that the device must wait before changing to DRNI standalone mode. · Role to None delay—Delay that the device must wait before setting its role to None. |
State |
Value (s) |
display drni troubleshooting
Use display drni troubleshooting to display DRNI troubleshooting information.
display drni troubleshooting [ dr | ipp | keepalive ] [ history ] [ count ]
NOTE: This command is supported only in Release 6616 and later. |
dr: Displays DR interface troubleshooting information.
ipp: Displays IPP troubleshooting information.
keepalive: Displays keepalive link troubleshooting information.
history: Displays troubleshooting records. If you do not specify this keyword, the command displays current troubleshooting information.
count: Specifies the number of events to display, in the range of 1 to 200. If you do not specify this argument, the command displays the most recent 20 events.
If you do not specify the dr, ipp, or keepalive keywords, this command displays troubleshooting information about DR interfaces, the IPP, and the keepalive link.
# Display DRNI troubleshooting records.
<Sysname> display drni troubleshooting history
Total: 3
Time Event description
2019-09-10 14:13:53.103 IPP BAGG10 went down because the IPP role of the
interface was removed. Please reconfigure an interface
as the IPP.
2019-09-10 14:23:53.102 Keepalive link went down because the peer keepalive
timeout timer expired. Please check the keepalive
packet transmission and reception status at the two
ends.
2019-09-10 14:53:53.103 Local DR interface state of BAGG1024 in DR group 1024
changed to down because the aggregate interface went
down. Please check the aggregate link status.
display drni verbose
Use display drni verbose to display detailed information about the IPP and DR interfaces.
display drni verbose [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a DR interface or the IPP by its number. The interface number must already exist. If you do not specify an interface, the command displays detailed information about the IPP and all DR interfaces.
If the specified interface is not the IPP or a DR interface, no information is displayed.
# Display detailed information about DR interface Bridge-Aggregation 1.
<Sysname> display drni verbose interface bridge-aggregation 1
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
D -- IPP_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
G -- Port_Sync, H -- Expired
DR interface/DR group ID: BAGG1/1
Local DR interface state: UP
Peer DR interface state: UP
DR group state: UP
Local DR interface down cause: -
Remaining DRNI DOWN time: -
Local DR interface LACP MAC: Config=0001-0001-0001, Effective=0001-0001-0001
Peer DR interface LACP MAC: Config=0001-0001-0001, Effective=0001-0001-0001
Local DR interface LACP priority: Config=200, Effective=200
Peer DR interface LACP priority: Config=200, Effective=200
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): HGE1/0/1 (260), HGE1/0/2 (261)
Peer Selected ports indexes: 260, 261
# Display detailed information about IPP Bridge-Aggregation 2.
<Sysname> display drni verbose interface bridge-aggregation 2
IPP/IPP ID: BAGG2/1
State: UP
Cause: -
Local Selected ports (index): HGE1/0/1 (258), HGE1/0/2 (259)
Peer Selected ports indexes: 258, 259
Table 12 Command output
Flags |
DRCP state flags. The flag field is one byte long, represented by ABCDEFGH from the lowest bit to the highest bit. A letter is displayed when its bit is 1 and is not displayed when its bit is 0. · A—Indicates whether DRCP is enabled on the local device. 1 indicates enabled. 0 indicates disabled. · B—Indicates whether DRCP is enabled on the DR peer. 1 indicates enabled. 0 indicates disabled. · C—Indicates whether DRCP is enabled on a third DR member device. 1 indicates enabled. 0 indicates disabled. · D—Indicates whether the local IPP has determined that DRCP is enabled on the DR peer. 1 indicates yes. 0 indicates no. · E—Indicates the DRCP timeout timer. 1 indicates the short timeout timer. 0 indicates the long timeout timer. · F—Indicates whether the local IPP permits the packets that contain the negotiated gateway conversation IDs. 1 indicates yes. 0 indicates no. · G—Indicates whether the local IPP permits the packets that contain the negotiated port conversation IDs. 1 indicates yes. 0 indicates no. · H—Indicates whether the local DRCPDU receive machine is in default or expired state. 1 indicates yes. 0 indicates no. |
IPP |
DR interface |
Local DR interface state |
State of the local DR interface: · UP—The DR interface is up if it has Selected ports in its aggregation group. · DOWN—The DR interface is down if it does not have Selected ports in its aggregation group. |
Peer DR interface state |
State of the peer DR interface: · UP—The DR interface is up if it has Selected ports in its aggregation group. · DOWN—The DR interface is down if it does not have Selected ports in its aggregation group. |
DR group state |
State of the DR group: · UP—The DR group is up if it contains a minimum of one member DR interface in UP state. · DOWN—The DR group is down if it all its member DR interfaces are in DOWN state. |
Local DR interface down cause |
Cause of the down state of the local DR interface. If the local DR interface is up, this field displays a hyphen (-). |
Remaining DRNI DOWN time |
State |
State of the IPP: · UP. · DOWN. |
Cause |
Cause of the down state of the IPP. If the IPP is up, this field displays a hyphen (-). |
Local DR interface LACP MAC |
The field is supported only in Release 6616 and later. LACP system MAC address of the local DR interface. |
Peer DR interface LACP MAC |
The field is supported only in Release 6616 and later. LACP system MAC address of the peer DR interface. |
Local DR interface LACP priority |
The field is supported only in Release 6616 and later. LACP system priority of the local DR interface. |
Peer DR interface LACP priority |
The field is supported only in Release 6616 and later. LACP system priority of the peer DR interface. |
Config |
The field is supported only in Release 6616 and later. Configured value. |
Effective |
The field is supported only in Release 6616 and later. Effective value. |
Local DRCP flags |
Local DRCP state flags. If all bits are set to 0, this field displays Unknown. |
Peer DRCP flags |
Peer DRCP state flags. If all bits are set to 0 or no peer exists, this field displays Unknown. |
Local Selected ports (index) |
Abbreviated name of the Selected ports in the local aggregation group and their port indexes. |
Peer Selected ports indexes |
Port indexes of the Selected ports in the peer aggregation group. |
display drni virtual-ip
Use display drni virtual-ip to display DRNI virtual IP addresses.
display drni virtual-ip [ interface interface-type interface-number ]
NOTE: This command is supported only in Release 6635 and later. |
interface interface-type interface-number: Specifies a VLAN interface or loopback interface by its number. The interface number must already exist. If you do not specify an interface, the command displays detailed information about all DRNI virtual IP addresses.
# Display all DRNI virtual IP addresses.
<Sysname> display drni virtual-ip
Interface IP address MAC address Effective State
Vlan2 10.10.10.10/24 0001-0001-0001 ACTIVE
10.10.20.10/24 0001-0001-0002 STANDBY
Loop1 1::20/124 0001-0001-0003 STANDBY
1::10/124 0001-0001-0004 ACTIVE
Table 13 Command output
Abbreviated name of the interface. |
IP address |
Virtual IP address. |
MAC address |
Virtual MAC address. |
Effective State |
State of the virtual IP address: · Active—The virtual IPv4 address is active on the local device. · Standby—The virtual IPv4 address is standby on the local device. |
drni authentication key
Use drni authentication key to enable DRNI packet authentication and configure an authentication key.
Use undo drni authentication key to disable DRNI packet authentication.
drni authentication key { simple | cipher } string
DRNI packet authentication is disabled.
cipher: Specifies an authentication key in encrypted form.
simple: Specifies an authentication key in plaintext form. For security purposes, the authentication key specified in plaintext form will be stored in encrypted form.
string: Specifies the authentication key. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters.
To prevent DRCPDU and keepalive packet tampering from causing link flapping, enable DRNI packet authentication on DR member devices. With this feature enabled, DR member devices compute a message digest by using an authentication key for each outgoing DRCPDU or keepalive packet and insert the message digest into the packet. When receiving a DRCPDU or keepalive packet, a DR member device computes a message digest and compares it with the message digest in the packet. If the message digests match, the packet passes authentication. If the message digests do not match, the device drops the packet.
For successful authentication, configure the same authentication key for the DR member devices.
# Enable DRNI packet authentication and configure the authentication key as abcdefg.
[Sysname] drni authentication key simple abcdefg
Use drni auto-recovery reload-delay to enable DR system auto-recovery and set the reload delay timer.
Use undo drni auto-recovery reload-delay to restore the default.
drni auto-recovery reload-delay delay-value
DR system auto-recovery is disabled and the reload delay timer is not set.
delay-value: Specifies a reload delay in the range of 240 to 3600 seconds.
If only one DR member device recovers after the entire DR system reboots, auto-recovery enables that member device to remove its DR interfaces from the DRNI DOWN interface list.
· If that member device has up DR interfaces, it takes over the primary role when the reload delay timer expires and forwards traffic.
· If that member device does not have up DR interfaces, it is stuck in the None role and does not forward traffic.
If auto-recovery is disabled, that DR member device will be stuck in the None role with all its DR interfaces being DRNI DOWN after it recovers.
If both DR member devices recover and have up DR interfaces after the entire DR system reboots, active-active situation might occur if both IPL and keepalive links were down when the reload delay timer expires. If this rare situation occurs, examine the IPL and keepalive links and restore them.
To avoid incorrect role preemption, make sure the reload delay timer is longer than the amount of time required for the device to restart.
# Enable DR system auto-recovery and set the reload delay timer to 245 seconds.
[Sysname] drni auto-recovery reload-delay 245
display drni role
Use drni consistency-check disable to disable DRNI from performing configuration consistency check.
Use undo drni consistency-check disable to enable DRNI to perform configuration consistency check.
DRNI performs configuration consistency check.
To ensure that the DR system can operate correctly, DRNI by default performs configuration consistency check when the DR system is set up.
Configuration consistency check might fail when you upgrade the DR member devices in a DR system. To prevent the DR system from falsely shutting down DR interfaces, you can temporarily disable configuration consistency check.
You must make sure the DR member devices use the same setting for configuration consistency check.
# Disable DRNI from performing configuration consistency check.
[Sysname] drni consistency-check disable
drni consistency-check mode
Use drni consistency-check mode to set the mode of configuration consistency check.
Use undo drni consistency-check mode to restore the default.
drni consistency-check mode { loose | strict }
Configuration consistency check uses strict mode.
loose: Specifies loose mode.
strict: Specifies strict mode.
The device handles configuration inconsistency depending on the mode of configuration consistency check.
· For type 1 configuration inconsistency:
¡ The device generates log messages if loose mode is enabled.
¡ The device shuts down DR interfaces and generates log messages if strict mode is enabled.
· For type 2 configuration inconsistency, the device only generates log messages, whether strict or loose mode is enabled.
# Enable the loose mode of configuration consistency check.
[Sysname] drni consistency-check mode loose
drni drcp period short
Use drni drcp period short to enable the short DRCP timeout timer (3 seconds) on the IPP or a DR interface.
Use undo drni drcp period to restore the default.
An aggregate interface uses the long DRCP timeout timer (90 seconds).
This command takes effect only on the IPP or a DR interface.
DRCP uses a timeout mechanism to specify the amount of time that an IPP or DR interface must wait to receive DRCPDUs before it determines that the peer interface is down. This timeout mechanism provides the following timer options:
· Short DRCP timeout timer, which is fixed at 3 seconds. If this timer is used, the peer interface sends one DRCPDU every second.
· Long DRCP timeout timer, which is fixed at 90 seconds. If this timer is used, the peer interface sends one DRCPDU every 30 seconds.
Short DRCP timeout timer enables the DR member devices to detect a peer interface down event more quickly than the long DRCP timeout timer. However, this benefit is at the expense of bandwidth and system resources.
To avoid traffic interruption during an ISSU or DRNI process restart, disable the short DRCP timeout timer before you perform an ISSU or DRNI process restart. For more information about ISSU, see Fundamentals Configuration Guide.
# Enable the short DRCP timeout timer on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] drni drcp period short
drni ipp mac-address hold
Use drni ipp mac-address hold to enable the IPP to retain MAC address entries for single-homed devices.
Use undo drni ipp mac-address hold to disable the IPP from retaining MAC address entries for single-homed devices.
The IPP does not retain MAC address entries for single-homed devices when the devices go down.
When a DR member device detects that the link to a single-homed device goes down, the IPP takes the following actions:
· Deletes the MAC address entries for the single-homed device.
· Sends a message to the peer IPP for it to delete the affected MAC address entries.
If the link to a single-homed device flaps constantly, the IPP repeatedly deletes and adds MAC address entries for the device. This situation increases floods of unicast traffic destined for the single-homed device.
To reduce flood traffic, enable the IPP to retain MAC address entries for single-homed devices. After the links to single-homed devices go down, the affected MAC address entries age out on expiration of the MAC aging timer instead of being deleted immediately. The timer is set by using the mac-address timer command. For more information about this command, see MAC address table commands in Layer 2—LAN Switching Command Reference.
# Enable the IPP to retain MAC address entries for single-homed devices.
[Sysname] drni ipp mac-address hold
mac-address timer
Use drni keepalive { ip | ipv6 } to configure DR keepalive packet parameters.
Use undo drni keepalive { ip | ipv6 } to restore the default.
drni keepalive { ip | ipv6 } destination { ipv4-address | ipv6-address } [ source { ipv4-address | ipv6-address } | udp-port udp-number | vpn-instance vpn-instance-name ] *
No keepalive packet parameters are configured.
ip: Specifies IPv4 addresses.
ipv6: Specifies IPv6 addresses.
destination: Specifies an IP address of the DR peer as the destination IP address of keepalive packets.
source: Specifies a local IP address as the source IP address of keepalive packets. If you do not specify a source IP address, the IP address of the outgoing interface is used.
ipv4-address: Specifies an IPv4 address.
ipv6-address: Specifies an IPv6 address.
udp-port udp-number: Specifies the destination UDP port of keepalive packets. The value range for the udp-number argument is 1 to 65535. If you do not specify a UDP port number, 6400 is used.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the keepalive packets belong to the public network, do not specify a VPN instance.
The device accepts only keepalive packets that are sourced from the specified destination IP address. The keepalive link goes down if the device receives keepalive packets sourced from any other IP addresses.
Make sure the DR member devices in a DR system use the same keepalive destination UDP port.
You can set up an IPv4 or IPv6 keepalive link, but not both. If you execute this command multiple times, the most recent configuration takes effect.
# Specify the destination and source IP addresses of keepalive packets as 192.168.68.125 and 192.168.68.100, respectively.
[Sysname] drni keepalive ip destination 192.168.68.125 source 192.168.68.100
Use drni keepalive hold-time to set the keepalive hold timer.
Use undo drni keepalive hold-time to restore the default.
drni keepalive hold-time value
The keepalive hold timer is 3 seconds.
value: Specifies a timer value in the range of 3 to 10 seconds.
IMPORTANT: For the DR member device to correctly determine the cause of an IPL down event, make sure the keepalive hold timer is longer than the keepalive interval and is shorter than the keepalive timeout timer. |
The keepalive hold timer starts when the IPL goes down. The keepalive hold timer specifies the amount of time that the device uses to identify the cause of an IPL down event.
· If the device receives keepalive packets from the DR peer before the timer expires, the IPL is down because the IPL fails.
· If the device does not receive keepalive packets from the DR peer before the timer expires, the IPL is down because the peer DR member device fails.
If you use DRNI and VRRP together, make sure the keepalive hold timer is shorter than the interval at which the VRRP master sends VRRP advertisements. Violation of this restriction might cause a VRRP master/backup switchover to occur before IPL failure is confirmed. To set the interval at which the VRRP master sends VRRP advertisements, use the vrrp vrid timer advertise command. For more information about this command, see High Availability Command Reference.
# Set the keepalive hold timer to 5 seconds.
[Sysname] drni keepalive hold-time 5
vrrp vrid timer advertise (High Availability Command Reference)
Use drni keepalive interval to set the DR keepalive interval and timeout timer.
Use undo drni keepalive interval to restore the default.
drni keepalive interval interval [ timeout timeout ]
The DR keepalive interval is 1000 milliseconds, and the DR keepalive timeout timer is 5 seconds.
interval interval: Specifies the keepalive interval, in the range of 100 to 10000 milliseconds.
timeout timeout: Specifies the keepalive timeout timer, in the range of 3 to 20 seconds. The local keepalive timeout timer must be two times the keepalive interval of the peer at minimum.
The device sends keepalive packets at the specified interval to its DR peer. If the device has not received a keepalive packet from the DR peer before the keepalive timeout timer expires, the device determines that the keepalive link is down.
You must configure the same DR keepalive interval on the DR member devices in a DR system.
# Set the DR keepalive interval and timeout timer to 2000 milliseconds and 6 seconds, respectively.
[Sysname] drni keepalive interval 2000 timeout 6
Changing the keepalive interval might cause system setup failure. Continue? [Y/N]:y
Use drni mad default-action to configure the default DRNI MAD action to take on network interfaces on the secondary DR member device when the DR system splits.
Use undo drni mad default-action to restore the default.
drni mad default-action { down | none }
DRNI MAD shuts down network interfaces on the secondary DR member device.
down: Sets the action to DRNI MAD DOWN. DRNI MAD will shut down all network interfaces on the secondary DR member device when the DR system splits, except the interfaces excluded manually or by the system.
none: Sets the DRNI MAD action to NONE. DRNI MAD will not shut down any network interfaces when the DR system splits, except the interfaces configured manually or by the system to be shut down by DRNI MAD.
In most network environments, use the DRNI MAD DOWN action in conjunction with the drni mad exclude interface command.
· The DRNI MAD DOWN action helps avoid network issues caused by multi-active collision, which occurs if the IPL goes down while the keepalive link is up.
· The drni mad exclude interface command enables you to exclude special-purpose interfaces, for example, interfaces used in DRNI for DR keepalive detection.
This configuration method is inefficient if a large number of interfaces on the secondary DR member must be retained in up state after the DR system splits. For a DR member device to operate correctly, you must retain a large number of logical interfaces (for example, VLAN, aggregate,and loopback interfaces) in up state.
In these situations, use the following method to configure DRNI MAD:
· Set the default DRNI MAD action to NONE.
· Execute the drni mad include interface command to specify interfaces that must be shut down by DRNI MAD in addition to those already automatically specified by the system.
The DRNI MAD DOWN action will not take effect on the following interfaces:
· Interfaces automatically or manually excluded from being shut down by DRNI MAD. To identify these interfaces, execute the display drni mad verbose command.
· Interfaces used for special purposes, including:
¡ Interfaces placed in a loopback test by using the loopback command.
¡ Interfaces assigned to a service loopback group by using the port service-loopback group command.
¡ Mirroring reflector ports configured by using the mirroring-group reflector-port command.
¡ Interfaces forced to stay up by using the port up-mode command.
# Configure DRNI MAD to shut down all network interfaces except excluded interfaces when the DR system splits.
[Sysname] drni mad default-action down
loopback (Interface Command Reference)
mirroring-group reflector-port (Network Management and Monitoring Command Reference)
port up-mode (Interface Command Reference)
Use drni mad exclude interface to add an interface to the user-configured list of excluded ports, which will not be shut down by DRNI MAD when the DR system splits.
Use undo drni mad exclude interface to remove an interface from the user-configured list of excluded ports.
drni mad exclude interface interface-type interface-number
undo drni mad exclude interface interface-type interface-number
DRNI MAD shuts down all network interfaces when detecting a multi-active collision, except for the network interfaces set by the system to not shut down.
This command is typically used when the default DRNI MAD action is set to DRNI MAD DOWN. In this situation, when DRNI MAD detects a multi-active collision, DRNI sets all network interfaces on the secondary DR member device to DRNI MAD DOWN state, except for the following interfaces:
· Network interfaces manually configured to not shut down by DRNI MAD.
· Network interfaces set by the system to not shut down by DRNI MAD, including:
¡ IPP.
¡ Aggregation member interfaces if a Layer 2 aggregate interface is used as the IPP.
¡ DR interfaces.
¡ Management interfaces.
You must exclude the following interfaces from the shutdown action by DRNI MAD:
· For correct keepalive detection, you must exclude the interfaces used for keepalive detection from the shutdown action.
· For DR member devices to synchronize ARP entries, you must exclude the VLAN interfaces of the VLANs to which the DR interfaces and IPPs belong from the shutdown action.
# Exclude HundredGigE 1/0/1 from the shutdown action by DRNI MAD.
[Sysname] drni mad exclude interface hundredgige 1/0/1
Use drni mad exclude logical-interfaces to exclude all logical interfaces from the shutdown action by DRNI MAD.
Use undo drni mad exclude logical-interfaces to restore the default.
By default, DRNI MAD shuts down all network interfaces when it detects a multi-active collision, except for the network interfaces set by the system to not shut down.
For a DR member device to operate correctly after the DR system splits, you must retain a large number of logical interfaces (for example, VLAN, aggregate,and loopback interfaces) in up state. To simplify configuration, you can exclude all logical interfaces from the shutdown action by DRNI MAD.
The drni mad exclude interface and drni mad include interface commands take precedence over the drni mad exclude logical-interfaces command.
# Exclude all logical interfaces from the shutdown action by DRNI MAD.
[Sysname] drni mad exclude logical-interfaces
Use drni mad include interface to add an interface to the user-configured list of included ports, which will be shut down by DRNI MAD when the DR system splits.
Use undo drni mad include interface to remove a network interface from the user-configured list of included ports.
drni mad include interface interface-type interface-number
undo drni mad include interface interface-type interface-number
The user-configured included port list does not contain any ports.
This command is typically used when the default DRNI MAD action is set to NONE. In this situation, DRNI MAD does not shut down the network interfaces on the secondary DR member device when the DR system splits. To avoid network issues caused by multi-active collision, add network interfaces to the user-configured include port list if they are not in the system-configured included port list. DRNI MAD on the secondary DR member device will shut down the interfaces in the system-configured and user-configured included port lists when the DR system splits.
For a DR member device to operate correctly after the DR system splits, you must retain a large number of logical interfaces (for example, VLAN, aggregate,and loopback interfaces) in up state. To improve configuration efficiency, you can set the default DRNI MAD action to NONE and add interfaces to the user-configured include port list.
· Network interfaces automatically or manually excluded from being shut down by DRNI MAD. To identify these interfaces, execute the display drni mad verbose command.
· Network interfaces used for special purposes, including:
# Configure DRNI MAD to shut down Bridge-Aggregation 1 on the secondary DR member device when the DR system splits.
[Sysname] drni mad include interface bridge-aggregation 1
drni mad persistent
Use drni mad persistent to enable DRNI MAD DOWN state persistence.
Use undo drni mad persistent to disable DRNI MAD DOWN state persistence.
drni mad persistent
The secondary DR member device brings up interfaces in DRNI MAD DOWN state when its role changes to primary.
DRNI MAD DOWN state persistence prevents the secondary DR member device from bringing up the network interfaces in DRNI MAD DOWN state when its role change to primary. This feature helps avoid the forwarding issues that might occur in the multi-active situation that occurs because the keepalive link goes down while the IPL is down.
# Enable DRNI MAD DOWN state persistence.
[Sysname] drni mad persistent
drni mad restore
drni mad restore
Use drni mad restore to bring up the interfaces in DRNI MAD DOWN state.
drni mad restore
Execute this command only when both the IPL and the keepalive link are down.
You can bring up the interfaces in DRNI MAD DOWN state on the secondary DR member device for it to forward traffic if the following conditions exist:
· The primary DR member device fails while the IPL is down.
· DRNI MAD DOWN state persists on the secondary DR member device.
# Bring up the interfaces in DRNI MAD DOWN state.
[Sysname] drni mad restore
To avoid network issues, make sure the primary device has failed and cannot forward traffic. Continue? [Y/N]:y
drni mad persistent
drni restore-delay
Use drni restore-delay to set the data restoration interval.
Use undo drni restore-delay to restore the default.
drni restore-delay value
The data restoration interval is 30 seconds.
value: Specifies the data restoration interval, in the range of 1 to 3600 seconds.
The data restoration interval specifies the maximum amount of time for the secondary DR member device to synchronize data with the primary DR member device during DR system setup. Within the data restoration interval, the secondary DR member device sets all network interfaces to DRNI MAD DOWN state, except for the following interfaces:
· IPP.
· Management Ethernet interface.
· Interfaces excluded from the MAD shutdown action.
When the data restoration interval expires, the secondary DR member device brings up all network interfaces.
To avoid packet loss and forwarding failure, increase the data restoration interval if the amount of data is large or if an ISSU is to be performed between the DR member devices.
Make sure the data restoration interval is long enough for the device to reboot and restore forwarding entries after failure occurs.
Adjust the data restoration interval based on the size of forwarding tables. If the DR member devices have small forwarding tables, reduce this interval. If the forwarding tables are large, increase this interval. Typically, set the data restoration interval to 300 seconds.
# Set the data restoration interval to 50 seconds.
[Sysname] drni restore-delay 50
drni role priority
Use drni role priority to set the DR role priority of the device.
Use undo drni role priority to restore the default.
drni role priority priority-value
The DR role priority of the device is 32768.
priority-value: Specifies the DR role priority, in the range of 0 to 65535. The lower the value, the higher the priority.
For features that require centralized traffic processing, a DR member device is assigned the primary or secondary role based on its DR role priority. The secondary DR member device forwards the traffic of those features to the primary DR member device for processing. If the DR member devices use the same DR role priority, the member device with a lower bridge MAC address is assigned the primary role.
As a best practice to avoid network flapping, do not modify the DR role priority of DR member devices after the DR system is established.
# Set the DR role priority of the device to 66.
[Sysname] drni role priority 66
display drni role
drni sequence enable
Use drni sequence enable to enable DRNI sequence number check.
Use undo drni sequence enable to disable DRNI sequence number check.
DRNI sequence number check is disabled.
To protect DR member devices from replay attacks, enable DRNI sequence number check for them to identify attack packets.
With this feature enabled, the DR member devices insert a sequence number into each outgoing DRCPDU or keepalive packet and the sequence number increases by 1 for each sent packet. When receiving a DRCPDU or keepalive packet, the DR member devices check its sequence number and drop the packet if the check result is either of the following:
· The sequence number of the packet is the same as that of a previously received packet.
· The sequence number of the packet is smaller than that of the most recently received packet.
As a best practice to improve security, use DRNI sequence number check together with DRNI packet authentication.
After one DR member device reboots, the other DR member device might receive and accept the packets that were intercepted by an attacker before the reboot. As a best practice, change the authentication key after a DR member device reboots.
# Enable DRNI sequence number check.
[Sysname] drni sequence enable
drni standalone enable
Use drni standalone enable to enable DRNI standalone mode.
Use undo drni standalone enable to disable DRNI standalone mode.
drni standalone enable [ delay delay-time ]
undo drni standalone enable [ delay ]
DRNI standalone mode is disabled.
delay delay-time: Sets the delay that the device must wait before changing to DRNI standalone mode. The value range for this delay is 0 to 3600 seconds. If you do not set this parameter, the device changes to DRNI standalone mode without delay when both the IPL and the keepalive link go down.
Enable DRNI standalone mode to avoid forwarding issues in the multi-active situation that might occur after both the IPL and the keepalive link are down.
DRNI standalone mode helps avoid traffic forwarding issues in this multi-active situation by allowing only the member ports in the DR interfaces on one member device to forward traffic.
As a best practice, enable DRNI standalone mode on both primary and secondary DR member devices.
To prevent member ports of DR interfaces from flapping, set the DRNI standalone mode delay to be longer than the time required for a device reboot.
Before you enable DRNI standalone mode on a DR member device, make sure its LACP system priority is higher than that of the remote aggregation system. This restriction ensures that the reference port is on the remote aggregation system and prevents the interfaces attached to the DR system from flapping.
NOTE: A DR member device changes to DRNI standalone mode only when it detects that both the IPL and the keepalive link are down. It does not change to DRNI standalone mode when the peer DR member device reboots. |
# Enable DRNI standalone mode.
[Sysname] drni standalone enable
drni system-priority
lacp system-priority
port drni system-priority
port lacp system-priority
drni system-mac
Use drni system-mac to configure the DR system MAC address.
Use undo drni system-mac to restore the default.
drni system-mac mac-address
The DR system MAC address is not configured.
mac-address: Specifies a MAC address in the H-H-H format. The MAC address cannot be a multicast MAC address, all-zero MAC address, or all-F MAC address.
CAUTION: Changing the DR system MAC address causes DR system split. When you perform this task on a live network, make sure you are fully aware of its impact. |
The DR system MAC address uniquely identifies the DR system on the network. For the DR member devices to be identified as one DR system, you must configure the same DR system MAC address on them. As a best practice to avoid MAC address collision, use the bridge MAC address of one DR member device as the DR system MAC address.
# Configure the DR system MAC address as 0001-0001-0001.
[Sysname] drni system-mac 1-1-1
Changing the system MAC address might flap the intra-portal link and cause DR system setup failure. Continue? [Y/N]:y
[Sysname]
drni system-number
Use drni system-number to set the DR system number.
Use undo drni system-number to restore the default.
drni system-number system-number
The DR system number is not set.
system-number: Specifies the DR system number. Available values are 1 and 2.
CAUTION: Changing the DR system number causes DR system split. When you perform this task on a live network, make sure you are fully aware of its impact. |
You must assign different DR system numbers to the DR member devices in a DR system.
# Set the DR system number to 1.
[Sysname] drni system-number 1
Changing the system number might flap the intra-portal link and cause DR system setup failure. Continue? [Y/N]:y
[Sysname]
display drni system
Use drni system-priority to set the DR system priority.
Use undo drni system-priority to restore the default.
drni system-priority priority
The DR system priority is 32768.
priority: Specifies a priority value in the range of 0 to 65535. The lower the value, the higher the priority.
CAUTION: Changing the DR system priority causes DR system split. When you perform this task on a live network, make sure you are fully aware of its impact. |
A DR system uses its DR system priority as the system LACP priority to communicate with the remote aggregation system.
You must configure the same DR system priority for the DR member devices in a DR system.
# Set the DR system priority to 64.
[Sysname] drni system-priority 64
Changing the system priority might flap the intra-portal link and cause DR system setup failure. Continue? [Y/N]:y
[Sysname]
display drni system
port drni group
Use port drni group to assign an aggregate interface to a DR group.
Use undo port drni group to restore the default.
port drni group group-id [ allow-single-member ]
An aggregate interface does not belong to a DR group.
group-id: Specifies a DR group number in the range of 1 to 1024.
allow-single-member: Allows the Layer 2 aggregate interface to be the only member of the specified DR group. DRNI MAD will not place the interface in DRNI MAD DOWN state. If you do not specify this keyword, DRNI MAD will shut down the interface if it is the only member of the specified DR group. As a best practice, specify this keyword for a dynamic aggregate interface. This keyword is supported in Release 6635 and later.
To use a Layer 2 aggregate interface as a DR interface, you must assign it to a DR group.
The device can have multiple DR interfaces. However, you can assign a Layer 2 aggregate interface to only one DR group.
A Layer 2 aggregate interface cannot operate as both IPP and DR interface.
To use resilient load sharing on a DR interface, you must configure the resilient load sharing mode before you assign member ports to the DR interface.
If a DR interface or its peer DR interface already has member ports, use the following procedure to configure the resilient load sharing mode on that DR interface:
1. Delete the DR interface.
2. Recreate the DR interface.
3. Configure the resilient load sharing mode.
4. Assign member ports to the DR interface.
For more information about the resilient load sharing mode, see Ethernet link aggregation configuration in Layer 2—LAN Switching Configuration Guide.
If you specify the allow-single-member keyword for a DR interface, the access device attached to the aggregate interface is identified as a single-homed device. The DR interface is a single-homed DR interface.
To change the allow-single-member setting for a single-homed DR interface, first execute the undo port drni group command to remove it from its DR group.
To prevent loops when you assign a single-homed aggregate interface to a DR group, use the following procedure:
1. Assign the aggregate interface to the DR group.
2. Assign ports to the aggregation group of the aggregate interface.
When you remove a single-homed DR interface from its DR group, use the following procedure:
1. Remove the member ports from the aggregation group of the DR interface.
2. Remove the DR interface from the DR group.
# Assign Bridge-Aggregation 1 to DR group 100.
[Sysname-Bridge-Aggregation1] port drni group 100
port drni intra-portal-port
Use port drni intra-portal-port to specify an aggregate interface as the IPP.
Use undo port drni intra-portal-port to restore the default.
port drni intra-portal-port port-id
No interface is the IPP.
port-id: Specifies the IPP ID, which is fixed at 1.
A DR member device can have only one IPP.
As a best practice to reduce the impact of interface flapping on upper-layer services, execute the link-delay command on the IPP.
By default, MAC address learning is enabled on the IPP. This feature is not configurable on the IPP.
# Specify Bridge-Aggregation 2 as the IPP.
[Sysname] interface bridge-aggregation 2
[Sysname-Bridge-Aggregation2] port drni intra-portal-port 1
link-delay
mac-address mac-learning enable
port drni ipv6 virtual-ip
Use port drni ipv6 virtual-ip to assign a DRNI virtual IPv6 address to an interface.
Use undo port drni ipv6 virtual-ip to restore the default.
VLAN interface view:
port drni ipv6 virtual-ip ipv6-address { prefix-length [ active | standby ] [ virtual-mac mac-address ] | link-local }
undo port drni ipv6 virtual-ip [ ipv6-address ]
Loopback interface view:
port drni ipv6 virtual-ip ipv6-address { prefix-length [ active | standby ] | link-local }
No DRNI virtual IPv6 addresses are assigned to interfaces.
VLAN interface view
ipv6-address: Specifies a virtual IPv6 address.
prefix-length: Specifies a prefix length for the IPv6 address, in the range of 0 to 128.
active: Sets the virtual IPv6 address to be active on the local device.
standby: Sets the virtual IPv6 address to be standby on the local device.
virtual-mac mac-address: Specifies a MAC address in the H-H-H format. The MAC address cannot be a multicast MAC address, all-zero MAC address, or all-F MAC address.
link-local: Uses the specified link-local address as the virtual IPv6 address. Specify this keyword only for OSPFv3 neighbor establishment when dual-active gateways exist on the DR system.
To ensure correct traffic forwarding, assign DRNI virtual IPv6 addresses to the following interfaces on the DR system:
· VLAN interfaces that act as dual-active gateways for the same VLAN.
· Loopback interfaces that offer AAA and 802.1X authentication services.
If you do not specify the active or standby keyword for a virtual IPv6 address, the address is active only on the primary DR member device.
If you execute the undo port drni ipv6 virtual-ip command without specifying the ipv6-address argument, the command deletes all DRNI virtual IPv6 addresses on the interface.
When the IPP fails, the standby virtual IPv6 address becomes active on the primary DR member device. If no virtual MAC address is associated with the standby virtual IPv6 address, the MAC address of the interface that owns the standby virtual IPv6 address is used as the virtual MAC address. In this scenario, the devices attached to the primary DR member device will refresh their ND entries.
When you assign multiple DRNI virtual IPv6 addresses to an interface, follow these restrictions and guidelines:
· You can assign a maximum of two virtual IPv6 addresses to an interface.
· If you configure different virtual MAC addresses for a virtual IPv6 address, the most recent configuration takes effect.
· You cannot configure the same virtual MAC address for multiple virtual IPv6 addresses.
If you assign both virtual IPv4 and IPv6 addresses to VLAN interfaces, make sure the virtual IPv4 and IPv6 addresses that use the same virtual MAC address are in the same state on the DR member devices.
When both DR member devices act as gateways for dualhomed user-side devices, the gateway interfaces (VLAN interfaces) on the DR member devices use the same IP address and MAC address. In this scenario, the DR member devices cannot set up neighbor relationships with the user-side devices. To resolve this issue, assign virtual IPv6 addresses to the gateway interfaces and configure routing protocols such as BGP and OSPFv3 to use the virtual IPv6 addresses for neighbor relationship setup.
For the DR member devices to set up BGP peer relationships with other devices, perform the following tasks:
· Execute the port drni ipv6 virtual-ip ipv6-address prefix-length [ active | standby ] [ virtual-mac mac-address ] command.
· Execute the peer source-address command to specify the virtual IPv6 address as the source IPv6 address for establishing TCP connections to peers.
For the DR member devices to set up OSPFv3 neighbor relationships with other devices, execute the port drni ipv6 virtual-ip ipv6-address link-local command.
When dual-active gateways exist on the DR system, you must assign unique virtual IPv6 addresses to the gateway interfaces on the DR member devices and configure both virtual IPv6 addresses to be active. When you assign a virtual MAC address to a VLAN interface, make sure the virtual MAC address is identical to the MAC address assigned to the VLAN interface by using the mac-address command.
# Assign DRNI virtual IPv6 address 1::10/64 to VLAN-interface 2 and set the state of the address to active.
[Sysname-Vlan-interface2] port drni ipv6 virtual-ip 1::10 64 active virtual-mac 1-1-1
nas-ip (Security Command Reference)
peer source-address (Layer 3—IP Routing Command Reference)
port drni system-mac
Use port drni system-mac to configure the DR system MAC address on an aggregate interface.
Use undo port drni system-mac to restore the default.
port drni system-mac mac-address
Aggregate interface view
The DR system MAC address uniquely identifies the DR system on the network. For the DR member devices to be identified as one DR system, you must configure the same DR system MAC address on the DR interfaces in the same DR group. As a best practice to avoid MAC address collision, use the bridge MAC address of one DR member device as the DR system MAC address.
You can configure the DR system MAC address on an aggregate interface only after it is configured as a DR interface.
You can configure the DR system MAC address globally and in aggregate interface view. The global DR system MAC address takes effect on all aggregation groups. On an aggregate interface, the interface-specific DR system MAC address takes precedence over the global DR system MAC address.
# Configure the DR system MAC address as 0001-0001-0001 on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port drni system-mac 1-1-1
drni system-mac
Use port drni system-priority to set the DR system priority on an aggregate interface.
Use undo port drni system-priority to restore the default.
port drni system-priority priority
A DR system uses its DR system priority as the LACP system priority to communicate with the remote aggregation system.
You must configure the same DR system priority for the DR interfaces in the same DR group.
You can configure the DR system priority on an aggregate interface only after it is configured as a DR interface.
You can configure the DR system priority globally and in aggregate interface view. The global DR system priority takes effect on all aggregation groups. On an aggregate interface, the interface-specific DR system priority takes precedence over the global DR system priority.
# Set the DR system priority to 64 on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port drni system-priority 64
port drni virtual-ip
Use port drni virtual-ip to assign a DRNI virtual IPv4 address to an interface.
Use undo port drni virtual-ip to restore the default.
port drni virtual-ip ipv4-address { mask-length | mask } [ active | standby ] virtual-mac mac-address
undo port drni virtual-ip [ ipv4-address ]
No DRNI virtual IPv4 addresses are assigned to interfaces.
VLAN interface view
ipv4-address: Specifies a virtual IPv4 address.
mask-length: Specifies the subnet mask length in the range of 0 to 32.
mask: Specifies the subnet mask in dotted decimal notation.
active: Sets the virtual IPv4 address to be active on the local device.
standby: Sets the virtual IPv4 address to be standby on the local device.
To ensure correct traffic forwarding, assign DRNI virtual IPv4 addresses to the following interfaces on the DR system:
If you do not specify the active or standby keyword for a virtual IPv4 address, the address is active only on the primary DR member device.
If you execute the undo port drni ipv4 virtual-ip command without specifying the ipv4-address argument, the command deletes all DRNI virtual IPv4 addresses on the interface.
When the IPP fails, the standby virtual IPv4 address becomes active on the primary DR member device. If no virtual MAC address is associated with the standby virtual IPv4 address, the MAC address of the interface that owns the standby virtual IPv4 address is used as the virtual MAC address. In this scenario, the devices attached to the primary DR member device will refresh their ARP entries.
When you assign multiple DRNI virtual IPv4 addresses to an interface, follow these restrictions and guidelines:
· You can assign a maximum of two virtual IPv4 addresses to an interface.
· If you configure different virtual MAC addresses for a virtual IPv4 address, the most recent configuration takes effect.
· You cannot configure the same virtual MAC address for multiple virtual IPv4 addresses.
When both DR member devices act as gateways for dualhomed user-side devices, the gateway interfaces (VLAN interfaces) on the DR member devices use the same IP address and MAC address. In this scenario, the DR member devices cannot set up neighbor relationships with the user-side devices. To resolve this issue, assign virtual IPv4 addresses to the gateway interfaces and configure routing protocols such as BGP and OSPF to use the virtual IPv4 addresses for neighbor relationship setup.
· Execute the port drni virtual-ip ipv4-address { mask-length | mask } [ active | standby ] [ virtual-mac mac-address ] command.
· Execute the peer source-address command to specify the virtual IPv4 address as the source IPv4 address for establishing TCP connections to peers.
For the DR member devices to set up OSPF neighbor relationships with other devices, perform the following tasks:
· Execute the ospf peer sub-address enable command to specify the virtual IPv4 address as the secondary IPv4 address for establishing OSPF neighbor relationships.
When dual-active gateways exist on the DR system, you must assign unique virtual IPv4 addresses to the gateway interfaces on the DR member devices and configure both virtual IPv4 addresses to be active. When you assign a virtual MAC address to a VLAN interface, make sure the virtual MAC address is identical to the MAC address assigned to the VLAN interface by using the mac-address command.
# Assign DRNI virtual IPv4 address 10.10.10.10/24 to VLAN-interface 2 and set the state of the address to active.
[Sysname-Vlan-interface2] port drni virtual-ip 10.10.10.10 24 active virtual-mac 1-1-1
ospf peer sub-address enable (Layer 3—IP Routing Command Reference)
reset drni drcp statistics
Use reset drni drcp statistics to clear DRCPDU statistics.
reset drni drcp statistics [ interface interface-list ]
interface interface-list: Specifies a space-separated list of interface items. Each item specifies an aggregate interface or a range of aggregate interfaces in the form of interface-type interface-number1 [ to interface-type interface-number2 ]. The value for interface-number2 must be greater than or equal to the value for interface-number1. The aggregate interfaces must be DR interfaces or the IPP. If you do not specify this option, the command clears the DRCPDU statistics about all DR interfaces and the IPP.
# Clear DRCPDU statistics.
<Sysname> reset drni drcp statistics
display drni drcp statistics
reset drni troubleshooting history
Use reset drni troubleshooting history to clear DRNI troubleshooting records.
# Clear DRNI troubleshooting records.
<Sysname> reset drni troubleshooting history
