02-FRUs and Compatibility Matrixes | 224.28 KB |
FRUs and compatibility matrixes
Switching fabric module slot filler panel
Chassis component ordering information
For transceiver modules or cables compatible with the cards, see H3C S12500X-AF Switch Series Cards and Transceiver Modules Compatibility Matrixes.
MPUs
The switch uses an MPU for control and management. You can install one MPU or two MPUs for redundancy on the switch. Do not install MPUs of different models on the same switch.
Table 1 MPU ordering guide
Switch model |
Available MPUs |
· S12516X-AF · S12508X-AF |
· LSXM1SUPB1 · LSXM1SUPH1 · LSXM2SUPT1 · LSXM1SUPE1 |
S12512X-AF |
· LSXM1SUPB1 · LSXM1SUPH1 · LSXM1SUPE1 |
S12504X-AF |
· LSXM1SUP04B1 · LSXM1SUP04H1 |
S12502X-AF |
LSXM1SUP02B1 |
Table 2 MPU specifications (1)
Item |
LSXM1SUPA1 |
LSXM1SUPB1/LSXM1SUP04B1 |
LSXM1SUP02B1 |
Processor |
MIPS64 (Quad Core) @ 1.2 GHz |
MIPS64 (Dual Core) @ 1.0 GHz |
SDRAM |
8GB DDR3 SDRAM (two DIMM slots) |
8GB DDR3 SDRAM (one DIMM slot) |
Flash |
1 GB (NAND flash) |
NVRAM |
512 KB |
Connector type |
· RJ-45 · USB (Type A) |
· LC · USB (Type A) |
· RJ-45 · LC · USB (Type A) |
Ports |
· One console port · One 10/100/1000BASE-T port for management and upgrade · One USB port (USB2.0, host port) |
· One console port · Two GE SFP ports for management and upgrade · Two 10/100/1000BASE-T ports for management and upgrade · One USB port (USB2.0, host port) |
· One console port · One SFP port for management and upgrade · One 10/100/1000BASE-T port for management and upgrade · One USB port (USB2.0, host port) |
Transmission rate |
· Console port: ≤ 115200 bps (default: 9600 bps) · 10/100/1000BASE-T interface: 10/100/1000 Mbps |
· Console port: ≤ 115200 bps (default: 9600 bps) · SFP port: 1000 Mbps · 10/100/1000BASE-T port: 10/100/1000 Mbps |
Table 3 MPU specifications (2)
Item |
LSXM1SUPH1/LSXM1SUP04H1 |
LSXM2SUPT1 |
Processor |
Intel processor (Quad Core) @ 2.4 GHz |
SDRAM |
16GB DDR3 SDRAM (two DIMM slots) |
Flash |
1 GB (NAND flash) |
4 GB (NAND flash) |
NVRAM |
512 KB |
Connector type |
Ports |
· One console port · SFP port for management and upgrade: ¡ LSXM1SUP04H1: Two SFP ports ¡ LSXM1SUPH1/LSXM2SUPT1: One SFP port · 10/100/1000BASE-T port for management and upgrade: ¡ LSXM1SUP04H1: Two 10/100/1000BASE-T ports ¡ LSXM1SUPH1/LSXM2SUPT1: One 10/100/1000BASE-T port · One USB port (USB2.0, host port) |
Transmission rate |
Table 4 MPU specifications (3)
Item |
LSXM1SUPE1 |
Processor |
Intel processor (Quad Core) @ 2.2 GHz |
SDRAM |
32GB DDR4 SDRAM (two DIMM slots) |
Flash |
4GB (eMMC flash) |
NVRAM |
512 KB |
SSD |
240 GB (SATA) |
Connector type |
· RJ-45 · LC · USB (Type A) · Mini-USB (Type AB) |
Ports |
· 1 × RJ-45 console port · 1 × mini-USB console port · 2 × 10/100/1000BASE-T ports for management and upgrade · 2 × GE SFP ports for management and upgrade · 1 × USB port (USB 3.0, host port) · 1 × 1PPS/ToD time synchronization port · 2 × SMB clock input ports · 2 × SMB clock output ports |
Transmission rate |
· Console port: 9600 bps (default) to 115200 bps · 10/100/1000BASE-T port: 10/100/1000 Mbps · SFP port: 1000 Mbps |
NOTE: · To verify compatibility of the card with the software release you are using, see the release notes. · The USB port outputs power as prescribed by USB 2.0. You can only install a USB 2.0-compliant device in the USB port. · Set the same speed and duplex mode for a management Ethernet interface and its peer port. · If multiple management ports are connected to one remote switch, you must assign their peer ports to different VLANs on the remote switch. Login or file transfer will fail if the peer ports are in the same VLAN. · When using the BootWare menu to upgrade software or BootWare, make sure you use the correct port for image transferring. ¡ LSXM1SUPB1, LSXM1SUPE1, LSXM1SUP04B1, or LSXM1SUP04H1 MPU—Use management port M0/0/3. ¡ LSXM1SUPA1, LSXM1SUPH1, or LSXM2SUPT1 MPU—Use 10/100/1000BASE-T port M0/0/0. |
Cloud supervisor engine unit
The LSXM1X86SUPE1 cloud supervisor engine unit (SEU) contains a switching control unit and an X86 server unit. The switching control unit is the core of control and switching for the device. The X86 server unit is designed for applications such as virtualization and database to meet IDC and cloud computing requirements.
Table 5 LSXM1X86SUPE1 specifications
Item |
Specification |
Processor |
· Switching control unit: MIPS64 (four cores), 1.2 GHz · X86 server unit: Intel Xeon E5-26xx V3, 2.6 GHz |
SDRAM |
· Switching control unit: 16 GB DDR3 SDRAM (two DIMM slots) · X86 server unit: 64 GB DDR4 SDRAM (four DIMM slots) |
Flash |
· Switching control unit: 1 GB (NAND flash) · X86 server unit: ¡ 256 GB (SSD) ¡ 4 GB (NAND flash, for the BMC service) ¡ 4 GB (NAND flash, for the USB service) |
NVRAM |
· Switching control unit: 512 KB · X86 server unit: 1 MB |
Connector |
· RJ-45 · LC · Type A USB |
Ports |
· 2 × GE SFP management port for the switching control units · 2 × 10/100/1000BASE-T management port for the switching control units · 1 × USB port for the X86 server unit · 1 × BMC port for the X86 server unit · 1 × 10/100/1000BASE-T port for the X86 server unit · 2 × 10GE SFP+ port for the X86 server units · 1 × console port for the switching control unit |
Transmission rate |
· Console port: ≤ 115200 bps (default: 9600 bps) · SFP port: 1000 Mbps · SFP+ port: 10 Gbps · 10/100/1000BASE-T port: 10/100/1000 Mbps · USB port: 480 Mbps · BMC port: 10/100/1000 Mbps |
Compatible device models |
· S12516X-AF · S12512X-AF · S12508X-AF |
Interface module adapter
Some S12500-X interface modules (also called LPUs) are compatible with the switch, but the switch has higher and wider LPU slots than the S12500-X switch. To install an S12500-X LPU in an LPU slot, first install an interface module adapter in the slot. The available interface module adapter is LSXM1IMA.
LPUs
The switch supports both the S12500X-AF LPUs and FX and FE series S12500-X LPUs. For the LPU specifications, see Table 6, Table 7, Table 8, Table 10, and Table 10.
S12500X-AF LPUs
No interface module adapter is required to install an S12500X-AF LPU on the switch.
To prevent card damage and ensure correct operation, follow these guidelines before installing LPUs:
· Type F LPUs must be used with Type F switching fabric modules.
· Type H LPUs must be used with Type H switching fabric modules.
· Type T LPUs must be used with Type T switching fabric modules.
To use the LSXM1CGQ48HB1, LSXM1CGQ36HB1, LSXM1CGQ36HF1, LSXM1CGQ18QGHF1, LSXM1CGQ36TD1, LSXM1CGQ48KB1, or LSXM1CDQ24KB1 LPU on the switch, you need to choose high-performance fan trays for the switch. See Table 26 for information about the available fan trays.
Table 6 S12500X-AF Type F LPU specifications
LPU model |
Connector |
Port quantity |
Port speed |
Available transceiver modules |
LSXM3QGS36FX1 |
36-port 40GE QSFP+ Ethernet optical interface card |
· MPO · LC |
36 |
40 Gbps |
· QSFP+ transceiver module · QSFP+ copper cable · QSFP+ to SFP+ copper cable |
LSXM1CGP12FX1 |
12-port 100GE CFP2 Ethernet optical interface card |
LC |
12 |
100 Gbps |
CFP2 transceiver module |
Table 7 S12500X-AF Type H LPU specifications
LPU model |
Connector |
Port quantity |
Port speed |
LSXM1TGS48HB1 |
48-port 10GE SFP+ Ethernet optical interface card |
LC |
48 |
10 Gbps |
· SFP+ transceiver module · SFP+ copper cable · SFP+ fiber cable |
LSXM1TGS48HF1 |
LC |
48 |
10 Gbps |
LSXM1TGS48C2HB1 |
2-port 100GE QSFP28 Ethernet optical interface + 48-port 10GE SFP+ Ethernet optical interface card |
· MPO · LC |
50 |
· SFP+ port: 10 Gbps · QSFP28 port: 100/40 Gbps |
SFP+ port: · SFP+ transceiver module · SFP+ copper cable · SFP+ fiber cable QSFP28 port: · QSFP28 transceiver module · QSFP28 copper cable · QSFP28 fiber cable · QSFP+ transceiver module · QSFP+ copper cable · QSFP+ fiber cable |
LSXM1QGS48HB1 |
48-port 40GE QSFP+ Ethernet optical interface card |
· MPO · LC |
48 |
· 40 Gbps |
LSXM1QGS36HB1 |
· MPO · LC |
36 |
· 40 Gbps |
LSXM1CGQ18QGHB1 |
18-port 100GE QSFP28 Ethernet optical interface/36-port 40GE QSFP+ Ethernet optical interface module |
· MPO · LC |
36 |
· QSFP28 port: 100/40 Gbps · QSFP+ port: 40 Gbps |
LSXM1CGQ18QGHF1 |
· MPO · LC |
36 |
LSXM1CGQ6QGHB1 |
6-port 100GE QSFP28 Ethernet optical interface/12-port 40GE QSFP+ Ethernet optical interface card |
· MPO · LC |
12 |
· QSFP28 transceiver module · QSFP28 copper cable · QSFP28 fiber cable · QSFP+ transceiver module · QSFP+ copper cable · QSFP+ to SFP+ copper cable · QSFP+ fiber cable |
LSXM1CGQ6QGHF1 |
· MPO · LC |
12 |
LSXM1CGQ36HB1 |
36-port 100GE QSFP28 Ethernet optical interface card |
· MPO · LC |
36 |
100/40 Gbps |
LSXM1CGQ48HB1 |
48-port 100GE QSFP28 Ethernet optical interface card |
MPO |
48 |
100/40 Gbps |
LSXM1TGS48QGHA1 |
48-port 10GE SFP+ Ethernet optical interface + 4-port 40GE QSFP+ Ethernet optical interface card |
· MPO · LC |
52 |
· SFP+ port: 10 Gbps · QSFP+ port: 40 Gbps |
SFP+ port: · SFP+ transceiver module · SFP+ copper cable QSFP+ port: · QSFP+ transceiver module · QSFP+ copper cable · QSFP+ fiber cable |
LSXM1CGQ36HF1 |
· MPO · LC |
36 |
100/40 Gbps |
LSXM1QGS24HB1 |
24-port 40GE QSFP+ Ethernet optical interface card |
· MPO · LC |
24 |
40 Gbps |
LSXM1TGS24QGMODHB1 |
24-port 10GE SFP+ Ethernet optical interface + 2-port 40G QSFP+ Ethernet optical interface module, with one expansion slot |
· MPO · LC |
26 fixed ports and interface module port (see Table 11 for the available interface modules) |
40/10 Gbps |
LSXM1TGS24CGMODHD1 |
24-port 10GE SFP+ Ethernet optical interface + 4-port 100G QSFP28 Ethernet optical interface module, with one expansion slot |
· MPO · LC |
26 fixed ports and interface module port (see "Subcards" for the available interface modules) |
100/10 Gbps |
SFP+ port: · SFP+ transceiver module · SFP+ copper cable QSFP28 port: · QSFP28 transceiver module · QSFP28 copper cable · QSFP28 fiber cable |
LSXM2TGS48HB2 |
48-port 10GE SFP+ Ethernet optical interface module |
LC |
48 |
10/1 Gbps |
· 10GE SFP+ transceiver module · 10GE SFP+ copper cable · GE SFP transceiver module |
LSXM2CGQ18QGHB2 |
· MPO · LC |
36 |
NOTE: If high-performance DDR memory is installed on the LPU (labelled with this installation information), see the release notes to verify the switch software compatibility with the memory. |
Table 8 S12500X-AF Type T LPU specifications
LPU model |
Connector |
Port quantity |
Port speed |
LSXM1CGQ36TD1 |
· MPO · LC |
36 |
100/40 Gbps |
Table 9 S12500X-AF Type K LPU specifications
LPU model |
Connector |
Port quantity |
Port speed |
LSXM1CGQ48KB1 |
48-port 100GE QSFP28 Ethernet optical interface module |
MPO |
48 |
100/40 Gbps |
LSXM1CDQ24KB1 |
24-port 400GE QSFP-DD Ethernet optical interface module |
MPO |
24 |
400 Gbps |
· QSFP-DD transceiver module · QSFP-DD copper cable |
S12500-X LPUs
Table 10 describes the S12500-X LPUs available for the switch. To install an S12500-X LPU in an LPU slot, first install an interface module adapter in the slot.
Table 10 Specifications of the available S12500-X LPUs
LPU model |
Connector |
Port quantity |
Port speed |
LSXM1QGS24FE1 |
· MPO · LC |
24 |
40 Gbps |
LSXM1TGS48FE1 |
LC |
48 |
10/1 Gbps |
LSXM1TGS48FX1 |
LC |
48 |
10/1 Gbps |
LSXM1TGS24FX1 |
24-port 10GE SFP+ Ethernet optical interface card |
LC |
24 |
10/1 Gbps |
LSXM1TGW48FX1 |
48-port 10-GE SFP+ LAN/WAN fiber interface card |
LC |
48 |
· LAN mode: 10.31 Gbps · WAN mode: 9.95 Gbps |
· 10GE SFP+ transceiver module · 10GE SFP+ copper cable |
LSXM1GP48FX1 |
48-port GE SFP Ethernet interface card |
LC |
48 |
1 Gbps |
LSXM1QGS36FX1 |
· MPO · LC |
36 |
40 Gbps |
LSXM1QGS24FX1 |
· MPO · LC |
24 |
40 Gbps |
LSXM1QGS12FX1 |
· MPO · LC |
12 |
40 Gbps |
LSXM1CGX8FX1 |
8-port 100GE CXP Ethernet optical interface card |
MPO |
8 |
100 Gbps |
· CXP transceiver module · CXP fiber cable |
LSXM1CGP8FX1 |
8-port 100GE CFP2 Ethernet optical interface card |
LC |
8 |
100 Gbps |
LSXM1TGT48FX1 |
48-port 10GE copper Ethernet interface card |
RJ-45 |
48 |
1/10 Gbps |
N/A |
LSXM1GT48FX1 |
48-port 10/100/1000BASE-T Ethernet interface card |
RJ-45 |
48 |
10/100/1000 Mbps |
N/A |
Subcards
Table 11 describes the subcards available for the LSXM1TGS24QGMODHB1 LPU.
Table 11 Subcards available for the LSXM1TGS24QGMODHB1 LPU
Subcard model |
Port type and quantity |
LSWM18QC |
8-port QSFP+ interface card |
8 × QSFP+ ports |
LSWM124XG2Q |
24-port SFP+ and 2-port QSFP+ interface card with MACSec |
24 × SFP+ ports and 2 × QSFP+ ports |
LSWM124XG2QL |
24-port SFP+ and 2-port QSFP+ interface card |
LSWM124XG2QFC |
24-port SFP+ and 2-port QSFP+ interface card with FC |
LSWM124XGT2Q |
24-port 10GBASE-T and 2-port QSFP+ interface card with MACSec |
24 × 10-GE copper ports and 2 × QSFP+ ports |
LSWM1FWD0 |
LSWM1FWD0 firewall module |
1 × console port, 1 × USB port, and 2 × management ports (1 × RJ-45 port and 1 × SFP port) |
NOTE: When an SFP+ port on the LSWM124XG2QL subcard uses an SFP transceiver module to connect the peer port, the SFP+ port does not support autonegotiation of the speed and duplex mode. You need to execute the speed 1000 and duplex full commands to configure the speed and the duplex mode for the SFP+ port and its peer port. |
Table 12 describes the subcards available for the LSXM1TGS24CGMODHD1 LPU.
Table 12 Subcards available for the LSXM1TGS24CGMODHD1 LPU
Subcard model |
LSWM1FWD0 |
LSWM18QC |
8-port QSFP28 interface card |
8 × QSFP28 ports |
LSWM116Q |
16-port QSFP+ interface card |
16 × QSFP+ ports |
LSWM124TG2H |
24-port SFP28 + 2-port QSFP28 fiber interface card |
24 × SFP28 ports and 2 × QSFP28 ports |
Switching fabric modules
The S12501X-AF and S12502X-AF switches do not require switching fabric modules.
You can install two to six switching fabric modules on the switch. Do not install switching fabric modules of different models on the same switch.
To prevent card damage and ensure correct operation, follow these guidelines before installing switching fabric modules:
· Type F switching fabric modules must be used with Type F LPUs.
· Type H switching fabric modules must be used with Type H LPUs.
· Type T switching fabric modules must be used with Type T LPUs.
· Type K switching fabric modules must be used with Type K LPUs.
Table 13 Type F switching fabric module ordering guide
Switch model |
Available switching fabric modules |
S12516X-AF |
· LSXM1SFF16A1 · LSXM1SFF16B1 · LSXM1SFF16C1 |
S12508X-AF |
· LSXM1SFF08A1 · LSXM1SFF08B1 |
S12504X-AF |
LSXM1SFF04B1 |
Table 14 Type H switching fabric module ordering guide
Switch model |
S12516X-AF |
· LSXM1SFH16C1 · LSXM2SFH16C1 · LSXM1SFH16E1 |
S12512X-AF |
· LSXM1SFH12D1 · LSXM1SFH12C1 |
S12508X-AF |
· LSXM1SFH08C1 · LSXM1SFH08D1 · LSXM1SFH08E1 |
S12504X-AF |
LSXM1SFH04D1 |
Table 15 Type T switching fabric module ordering guide
Switch model |
S12516X-AF |
LSXM1SFT16E1 |
S12508X-AF |
LSXM2SFT08E1 |
Table 16 Type K switching fabric module ordering guide
Switch model |
S12508X-AF |
LSXM1SFK08F1 |
The switch comes with empty switching fabric module slots. For good ventilation, purchase and install filler panels in the empty switching fabric module slots.
Table 17 Switching fabric module slot filler panel ordering guide
Item |
Quantity |
Switching fabric module slot filler panel for the S12516X-AF switch |
0 to 4 |
Switching fabric module slot filler panel for the S12512X-AF switch |
0 to 4 |
Switching fabric module slot filler panel for the S12508X-AF switch |
0 to 4 |
Switching fabric module slot filler panel for the S12504X-AF switch |
0 to 4 |
Slide rails
The switches (except the S12501X-AF) are not shipped with slide rails. Purchase slide rails for the switches as needed. See Table 18 for the applicable slide rails for the switches.
The slide rails provided with the S12501X-AF switch provide an adjustment range of 552 mm to 1059 mm (21.73 in to 41.69 in).
Table 18 Applicable slide rails available for the switches
Device model |
Chassis weight (fully configured) |
Applicable slide rails |
Slide rail model |
Adjustment range |
Occupied space |
S12516X-AF |
400 kg (881.83 lb) |
LSXM1BSR |
630 mm to 900 mm (24.80 in to 35.43 in) |
1 RU |
S12512X-AF |
300 kg (661.38 lb) |
LSXM1BSR |
1 RU |
LSTM2KSGD0 |
500 mm to 800 mm (19.69 in to 31.50 in) |
2 RU |
S12508X-AF |
220 kg (485.01 lb) |
LSXM1BSR |
1 RU |
LSTM2KSGD0 |
2 RU |
S12504X-AF |
120 kg (264.55 lb) |
LSVM1BSR10 |
630 mm to 850 mm (24.80 in to 33.46 in) |
N/A |
S12502X-AF |
70 kg (154.32 lb) |
LSVM1BSR10 |
N/A |
Power modules
CAUTION: You must install power modules of the same model for the switch. |
The switch supports N+N (two power supply systems) or N+1 (one power supply system) power redundancy. You can install appropriate number of power modules according to the power supply mode and system consumption. Make sure the total maximum output power of the installed power modules is greater than the system power consumption. As a best practice, reserve 20% power.
Table 19 describes the power modules available for the switch.
Table 19 Power modules available for the switch
Switch model |
Available power modules |
S12516X-AF S12512X-AF S12508X-AF S12504X-AF |
PSR2400-54A PSR2400-54D PSR3000-54A PSR3000-54AHD |
S12502X-AF |
PSR1800-56A PSR1800-56D |
S12501X-AF |
PSR2400-54A-XC PSR2400-54D PSR3000-54AHD |
IMPORTANT: The PSR2400-54A power modules are available in two product codes: PSR2400-54A and PSR2400-54A-XC. The PSR2400-54A and PSR2400-54A-XC power modules are the same except for their 16A power cords. The 16A power cord for a PSR2400-54A power module uses a C19 straight connector. The 16A power cord for a PSR2400-54A-XC power module uses a C19 angled connector. |
Table 20 PSR1800-56A power module specifications
Item |
Specifications |
Rated input voltage |
100 to 240 VAC @ 50 or 60 Hz |
Rated output voltage |
56 VDC |
Maximum input current |
· 13 A @ 110 VAC · 9 A @ 220 VAC |
Maximum output current |
32.2 A |
Maximum output power |
· 1100 W @ 100 VAC to 200 VAC · 1800 W @ 201 VAC to 240 VAC |
Dimensions (H × W × D) |
40.1 × 82.6 × 297.7 mm (1.58 × 3.25 × 11.72 in) |
Ambient temperature |
Operating temperature |
–10°C to +50°C (–14°F to +122°F) |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Table 21 PSR2400-54A power module specifications
Item |
Specifications |
54 VDC |
16 A |
44.5 A |
· 1200 W @ 110 VAC · 2400 W @ 220 VAC |
41 × 100 × 332 mm (1.61 × 3.94 × 13.07 in) |
Table 22 PSR3000-54A power module specifications
Item |
Specifications |
54 VDC |
16 A |
55.6 A |
· 1200 W @ 100 to 175 VAC · 3000 W @ 175 to 240 VAC |
Table 23 PSR1800-56D power module specifications
Item |
Specifications |
–48 to –60 VDC |
56 VDC |
45 A |
32.2 A |
1800 W |
Table 24 PSR2400-54D power module specifications
Item |
Specifications |
–48 to –60 VDC |
54 VDC |
80 A |
44.5 A |
2400 W |
Table 25 PSR3000-54AHD power module specifications
Item |
Specifications |
AC input |
Rate input voltage |
20 A |
High-voltage DC input |
240 to 380 VDC |
20 A |
54 V |
27.8 A (100 to 175 VAC) 55.6 A (175 to 240 VAC or 240 to 380 VDC) |
1500 W (100 to 175 VAC) 3000 W (175 to 240 VAC or 240 to 380 VDC) |
NOTE: The power module shuts down automatically when its temperature exceeds the acceptable range. When the temperature returns to the acceptable range, the power module automatically restarts. |
Fan trays
Table 26 Fan tray specifications
Model |
Available fan trays |
Number of fans |
Fan diameter |
Maximum air flow rate |
S12516X-AF |
LSXM116XFAN |
6 |
120 mm (4.72 in) |
1020 CFM |
LSXM116XFANH (high-performance) |
6 |
134 mm (5.28 in) |
1860 CFM |
S12512X-AF |
LSXM112XFAN |
5 |
120 mm (4.72 in) |
850 CFM |
LSXM112XFANH (high-performance) |
4 |
134 mm (5.28 in) |
1240 CFM |
S12508X-AF |
LSXM108XFAN |
3 |
120 mm (4.72 in) |
510 CFM |
LSXM108XFANH (high-performance) |
3 |
134 mm (5.28 in) |
930 CFM |
S12504X-AF |
LSXM104XFAN |
2 |
120 mm (4.72 in) |
340 CFM |
LSXM104XFANH (high-performance) |
2 |
120 mm (4.72 in) |
560 CFM |
S12502X-AF |
LSXM102XFAN |
1 |
120 mm (4.72 in) |
170 CFM |
LSXM102XFANH (high-performance) |
1 |
120 mm (4.72 in) |
280 CFM |
S12501X-AF |
FAN-80B-1-A |
1 |
80 mm (3.15 in) |
100 CFM |
DC power cords
DC power cords are used for connecting the switch to the external DC power supply system. DC power cords are not provided. You need to order them as required.
Table 27 describes DC power cords available for the switch.
Table 27 Specifications for the DC power cords
Applicable power modules |
Cable length |
PSR2400-54D |
3 m (9.84 ft) |
PSR2400-54D |
15 m (49.21 ft) |
PSR1800-56D |
3 m (9.84 ft) |
PSR1800-56D |
15 m (49.21 ft) |
PSR3000-54AHD |
3 m (9.84 ft) |
AC power cords
An AC power cord is used to connect an AC power module on the switch to an external AC power source. The AC power cords include standard power cords and jumper power cords.
Selection of an AC power cord depends on the power supply (the current-carrying capacity of the power cord must meet the power supply requirement), power supply system in the equipment room, and connector and plug types in the country or region. Make sure you select a compliant power cord for a power supply.
For more information about AC power cords, see H3C Power Cords & Cables User Guide.
To purchase chassis components, contact the sales agent or H3C sales personnel.
Table 28 Chassis component ordering information
Product code |
Product name |
MPUs |
0231A2RC |
LSXM1SUPA1 |
H3C S12500X-AF supervisor engine module |
0231A2UG |
LSXM1SUPB1 |
0231A5GX |
LSXM1X86SUPE1 |
H3C S12500X-AF cloud supervisor engine unit |
0231A5L9 |
LSXM1SUPH1 |
H3C S12500X-AF supervisor engine unit |
0231A8C3 |
LSXM2SUPT1 |
0231A2YF |
LSXM1SUP04B1 |
H3C S12504X-AF supervisor engine module |
0231A4YU |
LSXM1SUP04H1 |
0231A4BF |
LSXM1SUP02B1 |
H3C S12502X-AF supervisor engine unit |
0231ADUE |
LSXM1SUPE1 |
Switching fabric modules |
0231A3BY |
LSXM1SFF16A1 |
Switching fabric module for S12516X-AF, Type F (Class A) |
0231A2TP |
LSXM1SFF16B1 |
Switching fabric module for S12516X-AF, Type F (Class B) |
0231A2U2 |
LSXM1SFF16C1 |
Switching fabric module for S12516X-AF, Type F (Class C) |
0231A3QT |
LSXM1SFF08A1 |
Switching fabric module for S12508X-AF, Type F (Class A) |
0231A2UB |
LSXM1SFF08B1 |
Switching fabric module for S12508X-AF, Type F (Class B) |
0231A3C3 |
LSXM1SFF04B1 |
Switching fabric module for S12504X-AF, Type F (Class B) |
0231A4PW |
LSXM1SFH16C1 |
H3C S12516X-AF fabric module, Type H (Class C+) |
0231A5CG |
LSXM2SFH16C1 |
H3C S12516X-AF fabric module, Type H (Class C) |
0231A4QG |
LSXM1SFH16E1 |
H3C S12516X-AF fabric module, Type H (Class E) |
0231A5J0 |
LSXM1SFH12C1 |
H3C S12512X-AF fabric module, Type H (Class C) |
0231A4EM |
LSXM1SFH12D1 |
H3C S12512X-AF fabric module, Type H (Class D) |
0231A2UK |
LSXM1SFH08C1 |
Switching fabric module for S12508X-AF, Type H (Class C) |
0231A2UV |
LSXM1SFH08D1 |
H3C S12508X-AF fabric module, Type H (Class D) |
0231A2U3 |
LSXM1SFH08E1 |
Switching fabric module for S12508X-AF, Type H (Class E) |
0231A4PT |
LSXM1SFH04D1 |
H3C S12504X-AF fabric module, Type H (Class D) |
0231A8C5 |
LSXM2SFT08E1 |
H3C S12508X-AF fabric module, Type T (Class E) |
0231A8BW |
LSXM1SFT16E1 |
H3C S12516X-AF fabric module, Type T (Class E) |
0231ABSY |
LSXM1SFK08F1 |
H3C S12508X-AF fabric module, Type K (Class F) |
LPUs |
0231A2UU |
LSXM1CGX8FX1 |
H3C S12500-X 8-port 100GBASE Ethernet optical interface module (CXP) (FX) |
0231A2V5 |
LSXM1QGS12FX1 |
H3C S12500-X 12-port 40GBASE Ethernet optical interface module (QSFP+) (FX) |
0231A2VM |
LSXM1TGT48FX1 |
H3C S12500-X 48-port 10GBASE-T Ethernet electrical interface module (RJ45) (FX) |
0231A3A1 |
LSXM1CGP8FX1 |
H3C S12500-X 8-port 100GBASE Ethernet optical interface module (CFP2) (FX) |
0231A3FY |
LSXM1GT48FX1 |
H3C S12500-X 48-port 1000BASE-T Gigabit Ethernet interface module (RJ45) (FX) |
0231A3G2 |
LSXM1GP48FX1 |
H3C S12500-X 48-port 1000BASE-X Gigabit Ethernet optical interface module (SFP, LC) (FX) |
0231A3G3 |
LSXM1TGS24FX1 |
H3C S12500-X 24-port 10GBASE Ethernet optical interface module (SFP+, LC) (FX) |
0231A3C4 |
LSXM1QGS36FX1 |
H3C S12500-X 36-port 40GBASE Ethernet optical interface module (QSFP+) (FX) |
0231A2US |
LSXM1TGS48FX1 |
H3C S12500-X 48-port 10GBASE Ethernet optical interface module (SFP+, LC) (FX) |
0231A2UT |
LSXM1QGS24FX1 |
H3C S12500-X 24-port 40GBASE Ethernet optical interface module (QSFP+) (FX) |
0231A3FX |
LSXM1TGS48FE1 |
H3C S12500-X 48-port 10GBASE Ethernet optical interface module (SFP+, LC) (FE) |
0231A3PU |
LSXM1QGS24FE1 |
H3C S12500-X 24-port 40GBASE Ethernet optical interface module (QSFP+) (FE) |
0231A3Y2 |
LSXM2TGS48FX1 |
0231A4P0 |
LSXM2QGS24FX1 |
0231A4NS |
LSXM1TGW48FX1 |
H3C S12500-X 48-port 10GBASE Ethernet WAN optical interface module (SFP+, LC) (FX) |
0231A3A2 |
LSXM1CGP12FX1 |
H3C S12500X-AF 12-port 100GBASE Ethernet optical interface module (CFP2) (FX) |
0231A4AR |
LSXM3QGS24FE1 |
H3C S12500X-AF 24-port 40GBASE Ethernet optical interface module (QSFP+) (FE) |
0231A4AT |
LSXM3QGS36FX1 |
H3C S12500X-AF 36-port 40GBASE Ethernet optical interface module (QSFP+) (FX) |
0231A4AV |
LSXM3QGS24FX1 |
H3C S12500X-AF 24-port 40GBASE Ethernet optical interface module (QSFP+) (FX) |
0231A4AW |
LSXM3TGS48FX1 |
H3C S12500X-AF 48-port 10GBASE Ethernet optical interface module (SFP+, LC) (FX) |
0231A4P2 |
LSXM4TGS48FX1 |
0231A4P4 |
LSXM4QGS24FX1 |
0231A4PQ |
LSXM1CGQ36HB1 |
H3C S12500X-AF 36-port 100GBASE Ethernet optical interface module (QSFP28) (HB) |
0231A4QD |
LSXM1CGQ18QGHB1 |
H3C S12500X-AF 18-port 100GBASE (QSFP28)/36-port 40GBASE Ethernet optical interface module (QSFP+) (HB) |
0231A4PN |
LSXM1QGS48HB1 |
H3C S12500X-AF 48-port 40GBASE Ethernet optical interface module (QSFP+) (HB) |
0231A4PS |
LSXM1TGS48C2HB1 |
H3C S12500X-AF,48-port 10GBASE Ethernet optical interface (SFP+, LC) + 2-port 100GBASE Ethernet optical interface module (QSFP28) (HB) |
0231A4PR |
LSXM1CGQ36HF1 |
H3C S12500X-AF 36-port 100GBASE Ethernet optical interface module (QSFP28) (HF) |
0231A4QE |
LSXM1CGQ18QGHF1 |
H3C S12500X-AF 18-port 100GBASE Ethernet optical interface (QSFP28)/36-port 40GBASE Ethernet optical interface module (QSFP+) (HF) |
0231A5KQ |
LSXM1TGS48HB1 |
H3C S12500X-AF 48-port 10GBASE Ethernet optical interface module (SFP+, LC) (HB) |
0231A5Q5 |
LSXM1CGQ6QGHB1 |
H3C S12500X-AF 6-port 100GBASE Ethernet optical interface (QSFP28)/12-port 40GBASE Ethernet optical interface module (QSFP+) (HB) |
0231A5JW |
LSXM1QGS36HB1 |
H3C S12500X-AF 36-port 40GBASE Ethernet optical interface module (QSFP+) (HB) |
0231A5LX |
LSXM1CGQ48HB1 |
H3C S12500X-AF 48-port 100GBASE Ethernet optical interface module (QSFP28) (HB) |
0231A5RS |
LSXM1CGQ6QGHF1 |
H3C S12500X-AF 6-port 100GBASE Ethernet optical interface (QSFP28)/12-Port 40GBASE Ethernet optical interface module (QSFP+) (HF) |
0231A5RU |
LSXM1TGS48HF1 |
H3C S12500X-AF 48-port 10GBASE Ethernet optical interface module (SFP+, LC) (HF) |
0231A6UN |
H3C S12500X-AF 24-port 10GBASE Ethernet optical interface (SFP+, LC) + 2-port 40GBASE Ethernet optical interface module (QSFP+) (HB), with 1 expansion slot |
0231A6NR |
LSXM1TGS48QGHA1 |
H3C S12500X-AF 48-port 10GBASE Ethernet optical interface (SFP+, LC) + 4-port 40GBASE Ethernet optical interface module (QSFP+) (HA) |
0231A8HT |
H3C S12500X-AF 24-port 10GBASE Ethernet optical interface (SFP+, LC) + 4-port 100GBASE Ethernet optical interface module (QSFP28) (HD), with 1 expansion slot |
0231A8GW |
LSXM1QGS24HB1 |
H3C S12500X-AF 24-port 40GBASE Ethernet optical interface module (QSFP+) (HB) |
0231A6TR |
LSXM1CCP8HF1 |
H3C S12500X-AF 8-port 200GBASE Ethernet optical interface module (CFP2) (HF) |
0231A8C0 |
LSXM1CGQ36TD1 |
H3C S12500X-AF 36-port 100GBASE Ethernet optical interface module (QSFP28) (TD) |
0231ACLS |
LSXM2TGS48HB2 |
H3C S12500X-AF/S12500F-AF 48-port 10GBASE Ethernet optical interface module (SFP+, LC) (HB) |
0231ACLR |
LSXM2CGQ18QGHB2 |
H3C S12500X-AF/S12500F-AF 18-port 100GBASE Ethernet optical interface (QSFP28)/36-port 40GBASE Ethernet optical interface module (QSFP+) (HB) |
0231ABV2 |
LSXM1CGQ48KB1 |
H3C S12500X-AF 48-Port 100GBASE Ethernet optical interface module (QSFP28) (KB) |
0231ABS3 |
LSXM1CDQ24KB1 |
H3C S12500X-AF 24-Port 400GBASE Ethernet optical interface module (QSFP-DD) (KB) |
Fan trays |
0231A2T1 |
LSXM116XFAN |
H3C S12516X-AF Ethernet switch fan module |
0231A4EL |
LSXM112XFAN |
H3C S12512X-AF Ethernet switch fan module |
0231A2UH |
LSXM108XFAN |
H3C S12508X-AF Ethernet switch fan module |
0231A2X9 |
LSXM104XFAN |
H3C S12504X-AF Ethernet switch fan module |
0231A4BE |
LSXM102XFAN |
H3C S12502X-AF Ethernet switch fan module |
0231A4WX |
LSXM116XFANH |
H3C S12516X-AF Ethernet switch high speed fan module |
0231A4WY |
LSXM112XFANH |
H3C S12512X-AF Ethernet switch high speed fan module |
0231A4X0 |
LSXM108XFANH |
H3C S12508X-AF Ethernet switch high speed fan module |
0231A4X1 |
LSXM104XFANH |
H3C S12504X-AF Ethernet switch high power fan module |
0231A5RV |
LSXM102XFANH |
H3C S12502X-AF Ethernet switch high speed fan module |
0231A6US |
FAN-80B-1-A |
Fan module with port to power airflow |
Power modules |
0231A2SN |
PSR2400-54A |
AC power module, 2400W |
0231A2X7 |
PSR2400-54D |
DC power module, 2400W |
0231A5CH |
PSR3000-54A |
3000W AC power supply module |
0231A2KX |
PSR1800-56A |
H3C port-to-power airflow 1800W AC power supply |
0231A2KY |
PSR1800-56D |
H3C port-to-power airflow 1800W DC power supply |
0231A6PS |
PSR3000-54AHD |
3000W AC & 240V-380V HVDC power supply |
0231A5XA |
PSR2400-54A-XC |
H3C 2400W AC power supply |
Switching fabric module slot filler panels |
0231A3RK |
LSXM1BFP16A |
16 fabric blank filler panel |
0231A5AY |
LSXM1BFP12A |
12 fabric blank filler panel |
0231A3RL |
LSXM1BFP08A |
08 fabric blank filler panel |
0231A3RM |
LSXM1BFP04A |
04 fabric blank filler panel |
Slide rails |
0231A4EK |
LSXM1BSR |
1U bottom-support rails, 630mm to 900mm |
0231A0PL |
LSTM2KSGD0 |
Slide rail accessories, 500mm to 800mm |
0231A2VL |
LSVM1BSR10 |
H3C S9810 bottom support rails, 630mm to 900mm |
