- 01-AAA configuration
- 02-Password control configuration
- 03-Keychain configuration
- 04-Public key management
- 05-PKI configuration
- 06-IPsec configuration
- 07-SSH configuration
- 08-SSL configuration
- 09-Attack detection and prevention configuration
- 10-IP source guard configuration
- 11-ARP attack protection configuration
- 12-ND attack defense configuration
- 13-uRPF configuration
- 14-Crypto engine configuration
00-Preface | 100.61 KB |
Preface
This configuration guide describes the security fundamentals and configuration procedures. It covers the following features:
· Identity authentication features such as AAA and PKI.
· Data security features such as public key management, IPsec, and SSH.
· Attack protection features such as IP source guard and ARP attack protection.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S12500X-AF Switch Series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
