- 10-High Availability Configuration Examples
- 01-H3C_Ethernet_OAM_Configuration_Examples
- 02-H3C_CFD_Configuration_Examples
- 03-H3C_DLDP_Configuration_Examples
- 04-H3C_RRPP_configuration_examples
- 05-H3C_Smart_Link_Configuration_Examples
- 06-H3C_VRRP_Configuration_Examples
- 07-H3C_BFD_Configuration_Examples
03-H3C_DLDP_Configuration_Examples | 207.13 KB |
H3C DLDP Configuration Examples |
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring the auto port shutdown mode
Example: Configuring the manual port shutdown mode
Example: Configuring the hybrid port shutdown mode
Introduction
This document provides DLDP configuration examples.
The Device Link Detection Protocol (DLDP) was developed by H3C to detect the status of fiber links or twisted-pair links. When DLDP detects unidirectional links, it can automatically shut down the faulty port to avoid network problems. Alternatively, a user can manually shut down the faulty port.
This document assumes that you have basic knowledge of DLDP.
As shown in Figure 1, Device A and Device B are connected through two fiber pairs.
Configure DLDP on the devices so each device performs the following tasks:
· Detects unidirectional links caused by cross-connected fibers or a disconnected fiber.
· Automatically shuts down the faulty interface when detecting a unidirectional link.
· Automatically brings up the interface after the administrator clears the fault.
When you configure DLDP, follow these restrictions and guidelines:
· For DLDP to operate correctly, configure the full duplex mode for the interfaces at the two ends of the link, and configure the same speed for the two interfaces.
· For DLDP to operate correctly, enable DLDP on both sides and make sure the following settings are consistent:
¡ Interval to send Advertisement packets.
¡ DLDP authentication mode.
¡ Password.
Procedures
# Enable DLDP globally.
[DeviceA] dldp global enable
# Configure Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 to operate in full duplex mode at 10000 Mbps, and enable DLDP on the interfaces.
[DeviceA] interface ten-gigabitethernet 3/0/1
[DeviceA-Ten-GigabitEthernet3/0/1] duplex full
[DeviceA-Ten-GigabitEthernet3/0/1] speed 10000
[DeviceA-Ten-GigabitEthernet3/0/1] dldp enable
[DeviceA-Ten-GigabitEthernet3/0/1] quit
[DeviceA] interface ten-gigabitethernet 3/0/2
[DeviceA-Ten-GigabitEthernet3/0/2] undo shutdown
[DeviceA-Ten-GigabitEthernet3/0/2] duplex full
[DeviceA-Ten-GigabitEthernet3/0/2] speed 10000
[DeviceA-Ten-GigabitEthernet3/0/2] dldp enable
[DeviceA-Ten-GigabitEthernet3/0/2] quit
# Set the interval for sending Advertisement packets to 5 seconds (default interval).
[DeviceA] dldp interval 5
# Configure the plain text authentication mode and set the password to abc.
[DeviceA] dldp authentication-mode simple
[DeviceA] dldp authentication-password simple abc
# Set the interface shutdown mode to auto (default mode).
[DeviceA] dldp unidirectional-shutdown auto
2. Configure Device B in the same way Device A is configured. (Details not shown.)
# Display global and interface-specific DLDP configuration for Device A.
[DeviceA] display dldp
DLDP global status: Enabled
DLDP advertisement interval: 5s
DLDP authentication-mode: Simple
DLDP authentication-password: ******
DLDP unidirectional-shutdown mode: Auto
DLDP delaydown-timer value: 1s
Number of enabled ports: 2
Interface Ten-GigabitEthernet3/0/1
DLDP port state: Bidirectional
Number of the port’s neighbors: 1
Neighbor MAC address: 0023-8956-3600
Neighbor port index: 1
Neighbor state: Confirmed
Neighbor aged time: 11s
Interface Ten-GigabitEthernet3/0/2
Neighbor port index: 2
Neighbor aged time: 12s
The output shows that the DLDP port status of both Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 is Bidirectional.
# Enable the monitoring of logs on the current terminal for Device A, and set the lowest level of the logs that can be output to the monitor terminal to 6.
[DeviceA] quit
<DeviceA> terminal monitor
<DeviceA> terminal logging level 6
As shown in Figure 2, the two pairs of fibers between Device A and Device B are cross-connected.
Figure 2 Cross-connected fibers
The following log information is displayed on Device A:
<DeviceA>%Jul 11 17:40:31:089 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/1 link status is DOWN.
%Jul 11 17:40:31:091 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet3/0/1 is DOWN.
%Jul 11 17:40:31:677 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/2 link status is DOWN.
%Jul 11 17:40:31:678 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet3/0/2 is DOWN.
%Jul 11 17:40:38:544 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/1 link status is UP.
%Jul 11 17:40:38:836 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/2 link status is UP.
The output shows that the physical status of both Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 is down and then up. The link status of both interfaces is down.
# Display information about interface Ten-GigabitEthernet 3/0/1 on Device A.
[DeviceA]display interface ten-gigabitethernet 3/0/1
Current state: UP
Line protocol state: DOWN(DLDP)
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 00e0-fc00-5929
Description: Ten-GigabitEthernet3/0/1 Interface
Bandwidth: 10000000kbps
Loopback is not set
Media type is optical fiber, Port hardware type is 10G_BASE_SR_SFP
10Gbps-speed mode, full-duplex mode
Link speed type is autonegotiation, link duplex type is force link
Flow-control is not enabled
The Maximum Frame Length is 10000
Allow jumbo frame to pass
Broadcast MAX-ratio: 100%
Multicast MAX-ratio: 100%
Unicast MAX-ratio: 100%
PVID: 1
Mdi type: automdix
Port link-type: access
Tagged Vlan: none
UnTagged Vlan: 1
Port priority: 0
Peak value of input: 141 bytes/sec, at 2019-01-01 01:37:08
Peak value of output: 84 bytes/sec, at 2019-01-01 05:39:56
Last 300 seconds input: 0 packets/sec 99 bytes/sec 0%
Last 300 seconds output: 0 packets/sec 63 bytes/sec 0%
Input (total): 26470 packets, 2469445 bytes
0 unicasts, 1 broadcasts, 26469 multicasts, 0 pauses
Input (normal): 26470 packets, - bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, - overruns, 0 aborts
- ignored, - parity errors
Output (total): 16962 packets, 1165236 bytes
0 unicasts, 0 broadcasts, 16962 multicasts, 0 pauses
Output (normal): 16962 packets, - bytes
0 lost carrier, - no carrier
The output shows that the physical status of Ten-GigabitEthernet 3/0/1 is up, but DLDP automatically shuts down the interface. The output for interface Ten-GigabitEthernet 3/0/2 is similar to Ten-GigabitEthernet 3/0/1. (Details not shown.)
<DeviceA> display dldp
DLDP port state: Unidirectional
Number of the port’s neighbors: 0 (Maximum number ever detected: 1)
The output shows that the DLDP port status of both Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 is Unidirectional. DLDP has detected a unidirectional link on both interfaces.
# Correct the fiber connections. As a result, the ports shut down by DLDP automatically recover, and Device A displays the following log information:
<DeviceA>%Jul 11 17:42:57:709 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/1 link status is DOWN.
%Jul 11 17:42:58:603 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/2 link status is DOWN.
%Jul 11 17:43:02:342 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/1 link status is UP.
%Jul 11 17:43:02:343 2019 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet3/0/1. The neighbor's system MAC is 0023-8956-3600, and the port index is 1.
%Jul 11 17:43:02:344 2019 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet3/0/1.
%Jul 11 17:43:02:353 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet3/0/1 is UP.
%Jul 11 17:43:02:357 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/2 link status is UP.
%Jul 11 17:43:02:362 2019 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet3/0/2. The neighbor's system MAC is 0023-8956-3600, and the port index is 2.
%Jul 11 17:43:02:362 2019 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet3/0/2.
%Jul 11 17:43:02:368 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet3/0/2 is UP.
The output shows that the physical status and link status of both Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 are up and their DLDP neighbors are determined. The links become bidirectional.
Configuration files
· Device A:
dldp global enable
dldp authentication-password cipher $c$3$wHDzwD/AZNW+q+otXapfZ/tUB/Wgbg==
port link-mode bridge
speed 10000
duplex full
dldp enable
speed 10000
duplex full
dldp enable
· The configuration file for Device B is the same as Device A. (Details not shown.)
Procedures
1. Configure Device A:
# Configure Ten-GigabitEthernet 2/2/1 and Ten-GigabitEthernet 2/2/2 to operate in full duplex mode at 10000 Mbps, and enable DLDP on the interfaces.
[DeviceA] interface ten-gigabitethernet 2/2/1
[DeviceA-Ten-GigabitEthernet2/2/1] duplex full
[DeviceA-Ten-GigabitEthernet2/2/1] speed 10000
[DeviceA-Ten-GigabitEthernet2/2/1] dldp enable
[DeviceA-Ten-GigabitEthernet2/2/1] quit
[DeviceA] interface ten-gigabitethernet 2/2/2
[DeviceA-Ten-GigabitEthernet2/2/2] undo shutdown
[DeviceA-Ten-GigabitEthernet2/2/2] duplex full
[DeviceA-Ten-GigabitEthernet2/2/2] speed 10000
[DeviceA-Ten-GigabitEthernet2/2/2] dldp enable
[DeviceA-Ten-GigabitEthernet2/2/2] quit
Interface Ten-GigabitEthernet2/2/1
Interface Ten-GigabitEthernet2/2/2
The output shows that the DLDP port status of both Ten-GigabitEthernet 2/2/1 and Ten-GigabitEthernet 2/2/2 is Bidirectional.
[DeviceA] quit
As shown in Figure 3, the two pairs of fibers between Device A and Device B are cross-connected.
Figure 3 Cross-connected fibers
<DeviceA>%Jul 11 17:40:31:089 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/1 link status is DOWN.
%Jul 11 17:40:31:091 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet2/2/1 is DOWN.
%Jul 11 17:40:31:677 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/2 link status is DOWN.
%Jul 11 17:40:31:678 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet2/2/2 is DOWN.
%Jul 11 17:40:38:544 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/1 link status is UP.
%Jul 11 17:40:38:836 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/2 link status is UP.
The output shows that the physical status of both Ten-GigabitEthernet 2/2/1 and Ten-GigabitEthernet 2/2/2 is down and then up. The link status of both interfaces is down.
# Display information about interface Ten-GigabitEthernet 2/2/1 on Device A.
[DeviceA]display interface ten-gigabitethernet 2/2/1
Current state: UP
Description: Ten-GigabitEthernet2/2/1 Interface
Loopback is not set
PVID: 1
Mdi type: automdix
Tagged Vlan: none
UnTagged Vlan: 1
Port priority: 0
The output shows that the physical status of Ten-GigabitEthernet 2/2/1 is up, but DLDP automatically shuts down the interface. The output for interface Ten-GigabitEthernet 2/2/2 is similar to Ten-GigabitEthernet 2/2/1. (Details not shown.)
The output shows that the DLDP port status of both Ten-GigabitEthernet 2/2/1 and Ten-GigabitEthernet 2/2/2 is Unidirectional. DLDP has detected a unidirectional link on both interfaces.
<DeviceA>%Jul 11 17:42:57:709 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/1 link status is DOWN.
%Jul 11 17:42:58:603 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/2 link status is DOWN.
%Jul 11 17:43:02:342 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/1 link status is UP.
%Jul 11 17:43:02:343 2019 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet2/2/1. The neighbor's system MAC is 0023-8956-3600, and the port index is 1.
%Jul 11 17:43:02:344 2019 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet2/2/1.
%Jul 11 17:43:02:353 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet2/2/1 is UP.
%Jul 11 17:43:02:357 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/2 link status is UP.
%Jul 11 17:43:02:362 2019 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet2/2/2. The neighbor's system MAC is 0023-8956-3600, and the port index is 2.
%Jul 11 17:43:02:362 2019 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet2/2/2.
%Jul 11 17:43:02:368 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet2/2/2 is UP.
The output shows that the physical status and link status of both Ten-GigabitEthernet 2/2/1 and Ten-GigabitEthernet 2/2/2 are up and their DLDP neighbors are determined. The links become bidirectional.
Configuration files
· Device A:
dldp global enable
speed 10000
duplex full
dldp enable
speed 10000
duplex full
dldp enable
As shown in Figure 4, Device A and Device B are connected through two fiber pairs.
Configure DLDP on the devices to meet the following requirements:
· Each device can detect unidirectional links caused by cross-connected fibers or a disconnected fiber.
· When a unidirectional link is detected, the administrator can manually shut down the faulty port based on the connection status of the link.
· The interface recovers from failure after the administrator clears the fault and manually brings up the port.
¡ Password.
Procedures
# Set the interface shutdown mode to manual.
[DeviceA] dldp unidirectional-shutdown manual
DLDP unidirectional-shutdown mode: Manual
[DeviceA] quit
As shown in Figure 5, the two pairs of fibers between Device A and Device B are cross-connected.
Figure 5 Cross-connected fibers
<DeviceA>%Jul 12 08:29:17:786 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/1 link status is DOWN.
%Jul 12 08:29:17:787 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet3/0/1 is DOWN.
%Jul 12 08:29:17:800 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/2 link status is DOWN.
%Jul 12 08:29:17:800 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet3/0/2 is DOWN.
%Jul 12 08:29:25:004 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/1 link status is UP.
%Jul 12 08:29:25:005 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet3/0/1 is UP.
%Jul 12 08:29:25:893 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/2 link status is UP.
%Jul 12 08:29:25:894 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet3/0/2 is UP.
The output shows that the physical status and link status of both Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 are down and then up.
Current state: UP
Line protocol state: UP
Loopback is not set
PVID: 1
Mdi type: automdix
Tagged Vlan: none
UnTagged Vlan: 1
Port priority: 0
Peak value of output: 104 bytes/sec, at 2019-01-01 06:40:58
Last 300 seconds input: 0 packets/sec 27 bytes/sec 0%
Last 300 seconds output: 1 packets/sec 101 bytes/sec 0%
Input (total): 27226 packets, 2547709 bytes
0 unicasts, 1 broadcasts, 27225 multicasts, 0 pauses
Input (normal): 27226 packets, - bytes
Output (total): 17991 packets, 1260564 bytes
0 unicasts, 0 broadcasts, 17991 multicasts, 0 pauses
Output (normal): 17991 packets, - bytes
The output shows that the physical status and link status of Ten-GigabitEthernet 3/0/1 are up. DLDP does not shut down the interface. The output for interface Ten-GigabitEthernet 3/0/2 is similar to Ten-GigabitEthernet 3/0/1. (Details not shown.)
The output shows that the DLDP port status of both Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 is Unidirectional. DLDP has detected a unidirectional link on both interfaces but does not shut them down.
# Shut down Ten-GigabitEthernet 3/0/1.
[DeviceA-Ten-GigabitEthernet3/0/1] shutdown
[DeviceA-Ten-GigabitEthernet3/0/1]%Jul 12 08:34:23:717 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/1 link status is DOWN.
%Jul 12 08:34:23:718 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet3/0/1 is DOWN.
%Jul 12 08:34:23:778 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/2 link status is DOWN.
%Jul 12 08:34:23:779 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet3/0/2 is DOWN.
The output shows that the physical status and link status of Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 are down.
# Shut down Ten-GigabitEthernet 3/0/2.
[DeviceA-Ten-GigabitEthernet3/0/2] shutdown
# Correct the fiber connections, and bring up Ten-GigabitEthernet 3/0/2.
[DeviceA-Ten-GigabitEthernet3/0/2]%Jul 12 08:46:17:677 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/2 link status is UP.
%Jul 12 08:46:17:678 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet3/0/2 is UP.
%Jul 12 08:46:17:959 2019 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet3/0/2. The neighbor's system MAC is 0023-8956-3600, and the port index is 2.
%Jul 12 08:46:17:959 2019 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet3/0/2.
The output shows that the physical status and link status of Ten-GigabitEthernet 3/0/2 are up and its DLDP neighbor is determined. The links become bidirectional.
# Bring up Ten-GigabitEthernet 3/0/1.
[DeviceA-Ten-GigabitEthernet3/0/1] undo shutdown
[DeviceA-Ten-GigabitEthernet3/0/1]%Jul 12 08:48:25:952 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet3/0/1 link status is UP.
%Jul 12 08:48:25:952 2019 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet3/0/1. The neighbor's system MAC is 0023-8956-3600, and the port index is 1.
%Jul 12 08:48:25:953 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet3/0/1 is UP.
%Jul 12 08:48:25:953 2019 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet3/0/1.
The output shows that the physical status and link status of Ten-GigabitEthernet 3/0/1 are up and its DLDP neighbor is determined. The links become bidirectional.
Configuration files
· Device A:
dldp global enable
speed 10000
duplex full
dldp enable
speed 10000
duplex full
dldp enable
Procedures
[DeviceA] quit
As shown in Figure 6, the two pairs of fibers between Device A and Device B are cross-connected.
Figure 6 Cross-connected fibers
<DeviceA>%Jul 12 08:29:17:786 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/1 link status is DOWN.
%Jul 12 08:29:17:787 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet2/2/1 is DOWN.
%Jul 12 08:29:17:800 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/2 link status is DOWN.
%Jul 12 08:29:17:800 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet2/2/2 is DOWN.
%Jul 12 08:29:25:004 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/1 link status is UP.
%Jul 12 08:29:25:005 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet2/2/1 is UP.
%Jul 12 08:29:25:893 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/2 link status is UP.
%Jul 12 08:29:25:894 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet2/2/2 is UP.
The output shows that the physical status and link status of both Ten-GigabitEthernet 2/2/1 and Ten-GigabitEthernet 2/2/2 are down and then up.
Current state: UP
Loopback is not set
PVID: 1
Mdi type: automdix
Tagged Vlan: none
UnTagged Vlan: 1
Port priority: 0
The output shows that the physical status and link status of Ten-GigabitEthernet 2/2/1 are up. DLDP does not shut down the interface. The output for interface Ten-GigabitEthernet 2/2/2 is similar to Ten-GigabitEthernet 2/2/1. (Details not shown.)
The output shows that the DLDP port status of both Ten-GigabitEthernet 2/2/1 and Ten-GigabitEthernet 2/2/2 is Unidirectional. DLDP has detected a unidirectional link on both interfaces but does not shut them down.
# Shut down Ten-GigabitEthernet 2/2/1.
[DeviceA-Ten-GigabitEthernet2/2/1] shutdown
[DeviceA-Ten-GigabitEthernet2/2/1]%Jul 12 08:34:23:717 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/1 link status is DOWN.
%Jul 12 08:34:23:718 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet2/2/1 is DOWN.
%Jul 12 08:34:23:778 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/2 link status is DOWN.
%Jul 12 08:34:23:779 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet2/2/2 is DOWN.
The output shows that the physical status and link status of Ten-GigabitEthernet 2/2/1 and Ten-GigabitEthernet 2/2/2 are down.
# Shut down Ten-GigabitEthernet 2/2/2.
[DeviceA-Ten-GigabitEthernet2/2/2] shutdown
# Correct the fiber connections, and bring up Ten-GigabitEthernet 2/2/2.
[DeviceA-Ten-GigabitEthernet2/2/2]%Jul 12 08:46:17:677 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/2 link status is UP.
%Jul 12 08:46:17:678 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet2/2/2 is UP.
%Jul 12 08:46:17:959 2019 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet2/2/2. The neighbor's system MAC is 0023-8956-3600, and the port index is 2.
%Jul 12 08:46:17:959 2019 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet2/2/2.
The output shows that the physical status and link status of Ten-GigabitEthernet 2/2/2 are up and its DLDP neighbor is determined. The links become bidirectional.
# Bring up Ten-GigabitEthernet 2/2/1.
[DeviceA-Ten-GigabitEthernet2/2/1] undo shutdown
[DeviceA-Ten-GigabitEthernet2/2/1]%Jul 12 08:48:25:952 2019 DeviceA IFNET/3/PHY_UPDOWN: Ten-GigabitEthernet2/2/1 link status is UP.
%Jul 12 08:48:25:952 2019 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet2/2/1. The neighbor's system MAC is 0023-8956-3600, and the port index is 1.
%Jul 12 08:48:25:953 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface Ten-GigabitEthernet2/2/1 is UP.
%Jul 12 08:48:25:953 2019 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet2/2/1.
The output shows that the physical status and link status of Ten-GigabitEthernet 2/2/1 are up and its DLDP neighbor is determined. The links become bidirectional.
Configuration files
· Device A:
dldp global enable
speed 10000
duplex full
dldp enable
speed 10000
duplex full
dldp enable
As shown in Figure 7, Device A and Device B are connected through two fiber pairs.
Configure DLDP to detect unidirectional links. When a unidirectional link is detected, DLDP automatically shuts down the unidirectional port. The administrator needs to bring up the port after clearing the fault.
¡ Password.
Procedures
# Set the interface shutdown mode to hybrid.
[DeviceA] dldp unidirectional-shutdown hybrid
# Display global and interface-specific DLDP configuration on Device A.
DLDP unidirectional-shutdown mode: Hybrid
The output shows that both Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 are in bidirectional state, which means both links are bidirectional.
# Enable the monitoring of logs on the current terminal on Device A. Set the lowest level of the logs that can be output to the current terminal to 6.
[DeviceA] quit
As shown in Figure 8, the two pairs of fibers between Device A and Device B are cross-connected..
Figure 8 Cross-connected fibers
<DeviceA>%Jan 4 07:16:06:556 2019 DeviceA DLDP/5/DLDP_NEIGHBOR_AGED: A neighbor on interface
Ten-GigabitEthernet3/0/1 was deleted because the neighbor was aged. The neighbor's system MAC is 0023-8956-3600, and the port index is 162.
%Jan 4 07:16:06:560 2019 DeviceA DLDP/5/DLDP_NEIGHBOR_AGED: A neighbor on interface
Ten-GigabitEthernet3/0/2 was deleted because the neighbor was aged. The neighbor's system MAC is 0023-8956-3600, and the port index is 165.
%Jan 4 07:16:06:724 2019 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet3/0/1 changed to down.
%Jan 4 07:16:06:730 2019 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet3/0/2 changed to down.
%Jan 4 07:16:06:736 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet3/0/1 changed to down.
%Jan 4 07:16:06:738 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet3/0/2 changed to down.
%Jan 4 07:16:07:152 2019 DeviceA DLDP/3/DLDP_LINK_UNIDIRECTIONAL: DLDP detected a unidirectional link on interface Ten-GigabitEthernet3/0/1. DLDP automatically shut down the interface. Please manually bring up the interface.
%Jan 4 07:16:07:156 2019 DeviceA DLDP/3/DLDP_LINK_UNIDIRECTIONAL: DLDP detected a unidirectional link on interface Ten-GigabitEthernet3/0/2. DLDP automatically shut down the interface. Please manually bring up the interface.
The output shows that the port status and link status of both Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 are down.
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 00e0-fc00-5929
Loopback is not set
Link speed type is force link, link duplex type is force link
Maximum frame length: 9216
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
Mdi type: automdix
Port link-type: Access
Tagged Vlan: none
UnTagged Vlan: 1
Port priority: 0
Last link flapping: 0 hours 11 minutes 9 seconds
Peak input rate: 141 bytes/sec, at 2019-01-01 01:37:08
Peak output rate: 84 bytes/sec, at 2019-01-01 05:39:56
Last 300 second input: 0 packets/sec 99 bytes/sec 0%
Last 300 second output: 0 packets/sec 63 bytes/sec 0%
The output shows that the physical status and link status of Ten-GigabitEthernet 3/0/1 are down. The output for interface Ten-GigabitEthernet 3/0/2 is similar to Ten-GigabitEthernet 3/0/1. (Details not shown.)
# Correct the fiber connections, and bring up Ten-GigabitEthernet 3/0/1.
[DeviceA-Ten-GigabitEthernet3/0/1]%Jan 4 07:33:26:574 2019 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet3/0/1 changed to up.
%Jan 4 07:33:57:562 2019 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet3/0/1. The neighbor's system MAC is 0023-8956-3600, and the port index is 162.
%Jan 4 07:33:57:563 2019 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet3/0/1.
%Jan 4 07:33:57:590 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet3/0/1 changed to up.
%Jan 4 07:33:57:609 2019 DeviceA STP/6/STP_DETECTED_TC: Instance 0's port Ten-GigabitEthernet3/0/1 detected a topology change.
The output shows that the port status and link status of Ten-GigabitEthernet 3/0/1 are now up and its DLDP neighbors are determined. The links become bidirectional.
# Bring up Ten-GigabitEthernet 3/0/2.
[DeviceA] interface Ten-GigabitEthernet3/0/2
[DeviceA-Ten-GigabitEthernet3/0/2]%Jan 4 07:35:26:574 2019 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet3/0/2 changed to up.
%Jan 4 07:35:57:562 2019 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet3/0/2. The neighbor's system MAC is 0023-8956-3600, and the port index is 162.
%Jan 4 07:35:57:563 2019 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet3/0/2.
%Jan 4 07:35:57:590 2019 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet3/0/2 changed to up.
%Jan 4 07:35:57:609 2019 DeviceA STP/6/STP_DETECTED_TC: Instance 0's port Ten-GigabitEthernet3/0/2 detected a topology change.
The output shows that the port status and link status of Ten-GigabitEthernet 3/0/2 are now up and its DLDP neighbors are determined. The links become bidirectional.
Configuration files
· Device A:
dldp global enable
speed 10000
duplex full
dldp enable
speed 10000
duplex full
dldp enable
Related documentation
· H3C S7500X Switch Series High Availability Command Reference-R759X
· H3C S7500X Switch Series High Availability Configuration Guide-R759X
