- 04-Layer 3-IP Services Configuration Guide
- 01-ARP configuration
- 02-IP addressing configuration
- 03-DHCP configuration
- 04-DNS configuration
- 05-mDNS relay configuration
- 06-IP forwarding basics configuration
- 07-IRDP configuration
- 08-IP performance optimization configuration
- 09-Fast forwarding configuration
- 10-UDP helper configuration
- 11-IPv6 basics configuration
- 12-DHCPv6 configuration
- 13-IPv6 fast forwarding configuration
- 14-Adjacency table configuration
- 15-GRE configuration
- 16-HTTP redirect configuration
- 17-Tunneling configuration
10-UDP helper configuration | 81.65 KB |
Configuring UDP helper to convert broadcast to unicast
Configuring UDP helper to convert broadcast to multicast
Display and maintenance commands for UDP helper
UDP helper configuration examples
Example: Configuring UDP helper to convert broadcast to unicast
Example: Configuring UDP helper to convert broadcast to multicast
About UDP helper
UDP helper can provide the following packet conversion services for packets with specific UDP destination port numbers:
· Convert broadcast to unicast, and forward the unicast packets to specific destinations.
· Convert broadcast to multicast, and forward the multicast packets.
About broadcast to unicast conversion
You can configure UDP helper to convert broadcast packets with specific UDP port numbers to unicast packets.
Upon receiving a UDP broadcast packet, UDP helper uses the configured UDP ports to match the UDP destination port number of the packet.
· If a match is found, UDP helper duplicates the packet and modifies the destination IP address of the copy to the configured unicast address. Then UDP helper forwards the unicast packet to the unicast address.
· If no match is found, UDP helper does not process the packet.
1. Enter system view.
2. Enable UDP helper.
udp-helper enable
By default, UDP helper is disabled.
3. Specify a UDP port number for UDP helper.
By default, no UDP port numbers are specified for UDP helper.
Do not set UDP ports 67 and 68 for UDP helper, because UDP helper cannot forward DHCP broadcast packets.
You can specify a maximum of 256 UDP ports for UDP helper.
4. Enter interface view.
5. Specify a destination server for UDP helper to convert broadcast to unicast.
udp-helper server ip-address [ global | vpn-instance vpn-instance-name ]
By default, no destination servers are specified.
Use this command on the interface that receives broadcast packets.
You can specify a maximum of 20 unicast and multicast addresses for UDP helper to convert broadcast packets on an interface.
About broadcast to multicast conversion
You can configure UDP helper to convert broadcast packets with specific UDP port numbers to multicast packets.
· If a match is found, UDP helper duplicates the packet and modifies the destination IP address of the copy to the configured multicast address. Then UDP helper forwards the packet to the multicast group.
udp-helper enable
5. Specify a destination multicast address for UDP helper to convert broadcast to multicast.
udp-helper broadcast-map multicast-address [ acl acl-number ]
By default, no destination multicast addresses are specified for UDP helper.
Execute display command in any view and reset commands in user view.
Task |
Command |
Display information about broadcast to unicast conversion by UDP helper on an interface. |
display udp-helper interface interface-type interface-number |
Clear packet statistics for UDP helper. |
reset udp-helper statistics |
As shown in Figure 1, configure UDP helper to convert broadcast to unicast on VLAN-interface 1 of Switch A. This feature enables Switch A to forward broadcast packets with UDP destination port number 55 to the destination server 10.2.1.1/16.
Make sure Switch A can reach the subnet 10.2.0.0/16.
# Enable UDP helper.
[SwitchA] System-view
[SwitchA] udp-helper enable
# Enable the UDP port 55 for UDP helper.
[SwitchA] udp-helper port 55
# Specify the destination server 10.2.1.1 for UDP helper to convert broadcast to unicast on VLAN-interface 1.
[SwitchA-Vlan-interface1] ip address 10.110.1.1 16
[SwitchA-Vlan-interface1] udp-helper server 10.2.1.1
# Display information about broadcast to unicast conversion by UDP helper on VLAN-interface 1.
[SwitchA-Vlan-interface1] display udp-helper interface vlan-interface 1
Interface Server VPN instance Server address Packets sent
Vlan-interface1 N/A 10.2.1.1 5
As shown in Figure 2, VLAN-interface 1 of Switch B can receive multicast packets destined to 225.1.1.1.
Configure UDP helper to convert broadcast to multicast on VLAN-interface 1 of Switch A. This feature enables Switch A to forward broadcast packets with UDP destination port number 55 to the multicast group 225.1.1.1.
1. Configure Switch A:
# Configure UDP helper to convert broadcast packets to multicast packets destined for 225.1.1.1.
[SwitchA-Vlan-interface1] udp-helper broadcast-map 225.1.1.1
# Enable IP multicast routing globally.
[SwitchA] multicast routing
[SwitchA-mrib] quit
Enable PIM-DM on VLAN-interface 1.
[SwitchA-Vlan-interface1] pim dm
# Enable PIM-DM and IGMP on VLAN-interface 2.
[SwitchA-Vlan-interface2] pim dm
[SwitchA-Vlan-interface2] igmp enable
# Configure VLAN-interface 2 as a static member of multicast group 225.1.1.1.
[SwitchA-Vlan-interface2] igmp static-group 225.1.1.1
2. Configure Switch B:
[SwitchB] multicast routing
[SwitchB-mrib] quit
# Enable PIM-DM and IGMP on VLAN-interface 1.
[SwitchB] interface vlan-interface 1
[SwitchB-Vlan-interface1] pim dm
[SwitchB-Vlan-interface1] igmp enable
# Configure VLAN-interface 1 as a static member of multicast group 225.1.1.1.
[SwitchB-Vlan-interface1] igmp static-group 225.1.1.1
Verify that you can capture multicast packets from Switch A on Switch B.
