- 04-Layer 3-IP Services Configuration Guide
- 01-ARP configuration
- 02-IP addressing configuration
- 03-DHCP configuration
- 04-DNS configuration
- 05-mDNS relay configuration
- 06-IP forwarding basics configuration
- 07-IRDP configuration
- 08-IP performance optimization configuration
- 09-Fast forwarding configuration
- 10-UDP helper configuration
- 11-IPv6 basics configuration
- 12-DHCPv6 configuration
- 13-IPv6 fast forwarding configuration
- 14-Adjacency table configuration
- 15-GRE configuration
- 16-HTTP redirect configuration
- 17-Tunneling configuration
01-ARP configuration | 252.85 KB |
Configuring a static ARP entry
Configuring a short static ARP entry
Configuring a long static ARP entry
Configuring a multiport ARP entry
Configuring features for dynamic ARP entries
Setting the dynamic ARP learning limit for a device
Setting the dynamic ARP learning limit for an interface
Setting the aging timer for dynamic ARP entries
Setting the maximum number of probes for dynamic ARP entries
Setting the interval for probing dynamic ARP entries
Enabling dynamic ARP entry check
Synchronizing ARP entries across all member devices
Configuring a customer-side or network-side port
Enabling recording user IP address conflicts
Enabling interface consistency check between ARP and MAC address entries
Enabling recording user port migrations
Display and maintenance commands for ARP
Example: Configuring a long static ARP entry
Example: Configuring a short static ARP entry
Example: Configuring a multiport ARP entry
Gratuitous ARP packet learning
Periodic sending of gratuitous ARP packets
Gratuitous ARP tasks at a glance
Enabling IP conflict notification
Enabling gratuitous ARP packet learning
Enabling periodic sending of gratuitous ARP packets
Configuring gratuitous ARP packet retransmission for the device MAC address change
Display and maintenance commands for proxy ARP
Common proxy ARP configuration example
Example: Configuring common proxy ARP
Creation of ARP snooping entries
Enabling ARP snooping for a VLAN
Enabling ARP snooping for a VSI
Display and maintenance commands for ARP snooping
Configuring ARP direct route advertisement
About ARP direct route advertisement
Mechanism of ARP direct route advertisement
Application in Layer 3 access networks
Enabling ARP direct route advertisement
Display and maintenance commands for ARP direct route advertisement
Configuring ARP
About ARP
ARP resolves IP addresses into MAC addresses on Ethernet networks.
ARP message format
ARP uses two types of messages: ARP request and ARP reply. Figure 1 shows the format of ARP request/reply messages. Numbers in the figure refer to field lengths.
· Hardware type—Hardware address type. The value 1 represents Ethernet.
· Protocol type—Type of the protocol address to be mapped. The hexadecimal value 0x0800 represents IP.
· Hardware address length and protocol address length—Length, in bytes, of a hardware address and a protocol address. For an Ethernet address, the value of the hardware address length field is 6. For an IPv4 address, the value of the protocol address length field is 4.
· OP—Operation code, which describes the type of ARP message. The value 1 represents an ARP request, and the value 2 represents an ARP reply.
· Sender hardware address—Hardware address of the device sending the message.
· Sender protocol address—Protocol address of the device sending the message.
· Target hardware address—Hardware address of the device to which the message is being sent.
· Target protocol address—Protocol address of the device to which the message is being sent.
ARP operating mechanism
As shown in Figure 2, Host A and Host B are on the same subnet. Host A sends a packet to Host B as follows:
1. Host A looks through the ARP table for an ARP entry for Host B. If one entry is found, Host A uses the MAC address in the entry to encapsulate the IP packet into a data link layer frame. Then Host A sends the frame to Host B.
2. If Host A finds no entry for Host B, Host A buffers the packet and broadcasts an ARP request. The payload of the ARP request contains the following information:
¡ Sender IP address and sender MAC address—Host A's IP address and MAC address.
¡ Target IP address—Host B's IP address.
¡ Target MAC address—An all-zero MAC address.
All hosts on this subnet can receive the broadcast request, but only the requested host (Host B) processes the request.
3. Host B compares its own IP address with the target IP address in the ARP request. If they are the same, Host B operates as follows:
a. Adds the sender IP address and sender MAC address into its ARP table.
b. Encapsulates its MAC address into an ARP reply.
c. Unicasts the ARP reply to Host A.
4. After receiving the ARP reply, Host A operates as follows:
a. Adds the MAC address of Host B into its ARP table.
b. Encapsulates the MAC address into the packet and sends the packet to Host B.
Figure 2 ARP address resolution process
If Host A and Host B are on different subnets, Host A sends a packet to Host B as follows:
1. Host A broadcasts an ARP request where the target IP address is the IP address of the gateway.
2. The gateway responds with its MAC address in an ARP reply to Host A.
3. Host A uses the gateway's MAC address to encapsulate the packet, and then sends the packet to the gateway.
4. If the gateway has an ARP entry for Host B, it forwards the packet to Host B directly. If not, the gateway broadcasts an ARP request, in which the target IP address is the IP address of Host B.
5. After the gateway gets the MAC address of Host B, it sends the packet to Host B.
ARP entry types
An ARP table stores dynamic ARP entries, OpenFlow ARP entries, Rule ARP entries, and static ARP entries.
Dynamic ARP entry
ARP automatically creates and updates dynamic entries. A dynamic ARP entry is removed when its aging timer expires or the output interface goes down. In addition, a dynamic ARP entry can be overwritten by a static ARP entry.
Static ARP entry
A static ARP entry is manually configured and maintained. It does not age out and cannot be overwritten by any dynamic ARP entry.
Static ARP entries protect communication between devices because attack packets cannot modify the IP-to-MAC mapping in a static ARP entry.
The device supports the following types of static ARP entries:
· Long static ARP entry—It is directly used for forwarding packets. A long static ARP entry contains the IP address, MAC address, and one of the following combinations:
¡ VLAN and output interface.
¡ Input and output interfaces.
· Short static ARP entry—It contains only the IP address and MAC address.
If the output interface is a Layer 3 Ethernet interface, the short ARP entry can be directly used to forward packets.
If the output interface is a VLAN interface, the device sends an ARP request whose target IP address is the IP address in the short entry. If the sender IP and MAC addresses in the received ARP reply match the short static ARP entry, the device performs the following operations:
¡ Adds the interface that received the ARP reply to the short static ARP entry.
¡ Uses the resolved short static ARP entry to forward IP packets.
· Multiport ARP entry—It contains the IP address, MAC address, and VLAN information.
The device can use a multiport ARP entry that has the same MAC address and VLAN as a multicast or multiport unicast MAC address entry for packet forwarding. A multiport ARP entry is manually configured. It does not age out and cannot be overwritten by any dynamic ARP entry.
To communicate with a host by using a fixed IP-to-MAC mapping, configure a short static ARP entry on the device. To communicate with a host by using a fixed IP-to-MAC mapping through an interface in a VLAN, configure a long static ARP entry on the device.
OpenFlow ARP entry
ARP creates OpenFlow ARP entries by learning from the OpenFlow module. An OpenFlow ARP entry does not age out, and it cannot be updated. An OpenFlow ARP entry can be used directly to forward packets. For more information about OpenFlow, see OpenFlow Configuration Guide.
Rule ARP entry
Rule ARP entries can be directly used for packet forwarding. A Rule ARP entry does not age out, and it cannot be updated. It can be overwritten by a static ARP entry.
ARP creates Rule ARP entries by learning from the following modules:
· Portal. For more information about portal, see Security Configuration Guide.
· VXLAN. For more information about VXLAN, see VXLAN Configuration Guide.
· OVSDB. For more information about OVSDB, see VXLAN configuration in VXLAN Configuration Guide.
All ARP tasks are optional.
· Configuring a static ARP entry
¡ Configuring a short static ARP entry
¡ Configuring a long static ARP entry
¡ Configuring a multiport ARP entry
· Configuring features for dynamic ARP entries
¡ Setting the dynamic ARP learning limit for a device
¡ Setting the dynamic ARP learning limit for an interface
¡ Setting the aging timer for dynamic ARP entries
¡ Setting the maximum number of probes for dynamic ARP entries
¡ Setting the interval for probing dynamic ARP entries
¡ Enabling dynamic ARP entry check
· Synchronizing ARP entries across all member devices
· Configuring a customer-side or network-side port
· Enabling user information checking for ARP entries:
¡ Enabling recording user IP address conflicts
¡ Enabling interface consistency check between ARP and MAC address entries
¡ Enabling recording user port migrations
Static ARP entries are effective when the device functions correctly.
A resolved short static ARP entry becomes unresolved upon certain events, for example, when the resolved output interface goes down, or the corresponding VLAN or VLAN interface is deleted.
1. Enter system view.
2. Configure a short static ARP entry.
arp static ip-address mac-address [ vpn-instance vpn-instance-name ]
About long static ARP entries
Long static ARP entries can be effective or ineffective. Ineffective long static ARP entries cannot be used for packet forwarding. A long static ARP entry is ineffective when any of the following conditions exists:
· The IP address in the entry conflicts with a local IP address.
· No local interface has an IP address in the same subnet as the IP address in the ARP entry.
A long static ARP entry for a VLAN is deleted if the VLAN or VLAN interface is deleted.
2. Configure a long static ARP entry.
arp static ip-address mac-address [ vlan-id interface-type interface-number | vsi-interface vsi-interface-id tunnel number vsi vsi-name | vsi-interface vsi-interface-id interface-type interface-number service-instance instance-id vsi vsi-name ] [ vpn-instance vpn-instance-name ]
About multiport ARP entries
A multiport ARP entry contains an IP address, MAC address, output interface, and VLAN ID information. The VLAN and output interfaces are specified by a multiport unicast MAC address entry or a multicast MAC address entry. For more information about multiport unicast MAC address entries, see Layer—2 LAN Switching Configuration Guide. For more information about multicast MAC address entries, see IP Multicast Configuration Guide.
A multiport ARP entry can overwrite a dynamic, short static or long static ARP entry. Conversely, a short static or long static ARP entry can overwrite a multiport ARP entry.
For a multiport ARP entry to be effective for packet forwarding, make sure the following conditions are met:
· A multiport unicast MAC address entry or a multicast MAC address entry exists.
· The multiport ARP entry must have the same MAC address and VLAN ID as the multiport unicast MAC address entry or the multicast MAC address entry.
· The IP address in the multiport ARP entry must reside on the same subnet as the VLAN interface of the specified VLAN.
If an aggregate interface is the output interface of an entry and its member ports reside on multiple IRF member devices, the device cannot use the entry to forward packets. To resolve this issue, set the global link-aggregation load sharing mode to a mode other than source or destination MAC address-based by using the link-aggregation global load-sharing mode command. For more information about this command, see Ethernet link aggregation in Layer 2—LAN Switching Command Reference.
2. Configure a multiport unicast MAC address entry or a multicast MAC address entry.
¡ In a common network, configure a multiport unicast MAC address entry.
¡ In a common network, configure a multicast MAC address entry.
3. Configure a multiport ARP entry.
arp multiport ip-address mac-address vlan-id [ vpn-instance vpn-instance-name ]
About the dynamic ARP learning limit for a device
A device can dynamically learn ARP entries. To prevent a device from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the device can learn. When the limit is reached, the device stops ARP learning.
If you set a value lower than the number of existing dynamic ARP entries, the device does not delete the existing entries unless they age out. You can use the reset arp dynamic command to clear dynamic ARP entries.
2. Set the dynamic ARP learning limit for the device.
arp max-learning-number max-number slot slot-number
By default, the dynamic ARP learning limit is the ARP table capacity, which varies by available device resources and whether the arp mode uni command is configured.
To disable the device from dynamic ARP learning, set the value to 0.
About setting the dynamic ARP learning limit for an interface
An interface can dynamically learn ARP entries. To prevent an interface from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the interface can learn. When the limit is reached, the interface stops ARP learning.
You can set limits for both a Layer 2 interface and the VLAN interface for a permitted VLAN on the Layer 2 interface. The Layer 2 interface learns an ARP entry only when neither limit is reached.
The total dynamic ARP learning limit for all interfaces will not be higher than the dynamic ARP learning limit for the device.
2. Enter interface view.
3. Set the dynamic ARP learning limit for the interface.
arp max-learning-num max-number [ alarm alarm-threshold ]
To disable the interface from dynamic ARP learning, set the value to 0.
About the aging timer for dynamic ARP entries
Each dynamic ARP entry in the ARP table has a limited lifetime, called an aging timer. The aging timer of a dynamic ARP entry is reset each time the dynamic ARP entry is updated. A dynamic ARP entry that is not updated before its aging timer expires is deleted from the ARP table.
You can set the aging timer for dynamic ARP entries in system view or in interface view. The aging timer set in interface view takes precedence over the aging timer set in system view.
2. Set the aging timer for dynamic ARP entries.
¡ Set the aging timer for dynamic ARP entries in system view.
arp timer aging { aging-minutes | second aging-seconds }
By default, the aging timer for dynamic ARP entries in system view is 20 minutes.
¡ Execute the following commands in sequence to set the aging timer for dynamic ARP entries in interface view:
By default, the aging timer for dynamic ARP entries in interface view is the aging timer set in system view.
About the maximum number of probes for dynamic ARP entries
This probe mechanism keeps legal dynamic ARP entries valid and avoids unnecessary ARP resolution during later traffic forwarding. It sends ARP requests for the IP address in a dynamic ARP entry.
· If the device receives an ARP reply before the entry aging timer expires, the device resets the aging timer.
· If the device does not receive any ARP reply after the maximum number of probes is made, the device deletes the entry when the entry aging timer expires.
You can set the maximum number of probes in system view or in interface view. The probe count set in interface view takes precedence over the probe count set in system view.
2. Set the maximum number of probes for dynamic ARP entries.
¡ Set the maximum number of probes for dynamic ARP entries in system view.
arp timer aging probe-count count
By default, the maximum number of probes in system view for dynamic ARP entries is 3.
¡ Execute the following commands in sequence to set the maximum number of probes for dynamic ARP entries:
By default, the maximum number of probes in interface view for dynamic ARP entries is the maximum number of probes set in system view.
About the interval for probing dynamic ARP entries
The probing feature keeps legal dynamic ARP entries valid and avoids unnecessary ARP resolution during later traffic forwarding.
Before a dynamic ARP entry is aged out, the device sends ARP requests for the IP address in the ARP entry.
· If the device receives an ARP reply during the probe interval, the device resets the aging timer.
· If the device does not receive any ARP reply during the probe interval, the device starts a new probe.
· If the maximum number probes are made, and still no ARP reply is received, the device deletes the entry.
You can set the probe interval in system view and in interface view. The probe interval in interface view takes precedence over the probe interval in system view.
· If massive traffic exists in the network, set a long interval.
· During the dynamic ARP entry probing process, a dynamic ARP entry will not be deleted if its aging time expires. If a reply is received during the probe, the aging timer of the ARP entry is reset.
· For the device to perform the specified number of probes, make sure the following requirement is met:
Aging time of the dynamic ARP entries > the maximum number of probes × probe interval
2. Set the interval for probing dynamic ARP entries.
¡ Set the interval for probing dynamic ARP entries in system view.
arp timer aging probe-interval interval
By default, the probe interval is 5 seconds.
¡ Execute the following commands in sequence to set the interval for probing dynamic ARP entries:
By default, the probe interval depends on the setting in system view.
About dynamic ARP entry check
The dynamic ARP entry check feature disables the device from supporting dynamic ARP entries that contain multicast MAC addresses. The device cannot learn dynamic ARP entries containing multicast MAC addresses. You cannot manually add static ARP entries containing multicast MAC addresses.
When dynamic ARP entry check is disabled, ARP entries containing multicast MAC addresses are supported. The device can learn dynamic ARP entries containing multicast MAC addresses obtained from the ARP packets sourced from a unicast MAC address. You can also manually add static ARP entries containing multicast MAC addresses.
2. Enable dynamic ARP entry check.
arp check enable
By default, dynamic ARP entry check is enabled.
About ARP entry synchronization
This task ensures that all IRF member devices in an IRF fabric have the same ARP entries.
To synchronize ARP entries across all member devices in a timely manner, you can schedule the device to automatically execute the arp smooth command. For information about scheduling a task, see the device management configuration in Fundamentals Configuration Guide.
To synchronize ARP entries from the master device to all subordinate devices, execute the following command in user view:
arp smooth
About the customer-side and network-side port
By default, a port is a network-side port. The device can generate a host route based on an ARP entry learned from the port. To save hardware resources, you can configure a port that connects to a user terminal as a customer-side port. The device will not generate a host route based on the ARP entry learned from the port.
Restricted to the hardware next hop resources on the device, the maximum number of dynamic ARP entries that a customer-side port can learn might be smaller than the value you set.
3. Configure the interface as a customer-side port or a network-side port.
¡ Configure the interface as a customer-side port.
arp mode uni
¡ Configure the interface as a network-side port.
undo arp mode uni
By default, a port operates as a network-side port.
About recording user IP address conflicts
This feature enables the device to detect and record user IP address conflicts. The device determines that a conflict occurs if an incoming non-gratuitous ARP packet has the same sender IP address as an existing ARP entry but a different sender MAC address. The device generates a user IP address conflict record, logs the conflict, and sends the log to the information center. For information about the log destination and output rule configuration in the information center, see the information center in Network Management and Monitoring Configuration Guide.
2. Enable recording user IP address conflicts.
arp user-ip-conflict record enable
By default, recording user IP address conflicts is disabled.
About interface consistency check between ARP and MAC address entries
In an unstable network, the receiving interface for packets from a user might change. The interface in the MAC address entry can be updated immediately while the interface in the ARP entry cannot. In this case, the packets matching the ARP entry will be sent out of an incorrect interface. To solve this problem, you can use this feature to periodically check the interface consistency between the ARP and MAC address entry for a user. If the interfaces are not the same, ARP sends ARP requests in the VLAN of the ARP entry and updates the entry with the ARP reply receiving interface.
Use display mac-address to display MAC address entries. For more information about this command, see MAC address table in Layer 2—LAN Switching Command Reference.
2. Enable interface consistency check between ARP and MAC address entries.
arp mac-interface-consistency check enable
By default, interface consistency check between ARP and MAC address entries is disabled.
About recording user port migrations
This feature enables the device to detect and record user port migration events. A user port migrates if an incoming ARP packet has the same sender IP address and sender MAC address as an existing ARP entry but a different ingress port. The device generates a user port migration record, logs the migration event, sends the log to the information center, and updates the interface for the ARP entry. For information about the log destination and output rule configuration in the information center, see the information center in Network Management and Monitoring Configuration Guide.
To avoid device performance degradation, disable recording user port migrations if too many user port migration logs are generated.
2. Enable recording user port migrations.
arp user-move record enable
By default, recording user port migrations is disabled.
Enabling ARP logging
About ARP logging
This feature enables a device to log ARP events when ARP cannot resolve IP addresses correctly. The log information helps administrators locate and solve problems. The device can log the following ARP events:
· On a proxy ARP-disabled interface, the target IP address of a received ARP packet is not one of the following IP addresses:
¡ The IP address of the receiving interface.
¡ The virtual IP address of the VRRP group.
· The sender IP address of a received ARP reply conflicts with one of the following IP addresses:
The device sends ARP log messages to the information center. You can use the info-center source command to specify the log output rules for the information center. For more information about information center, see Network Management and Monitoring Configuration Guide.
2. Enable ARP logging.
By default, ARP logging is disabled.
IMPORTANT: Clearing ARP entries from the ARP table might cause communication failures. Make sure the entries to be cleared do not affect current communications. |
Task |
Command |
Display ARP entries. |
display arp [ [ all | dynamic | multiport | static ] [ slot slot-number ] | vlan vlan-id | interface interface-type interface-number ] [ count | verbose ] |
Display the maximum number of ARP entries that a device supports. |
display arp entry-limit |
Display the ARP entry for an IP address. |
display arp ip-address [ slot slot-number ] [ verbose ] |
Display the number of OpenFlow ARP entries. |
display arp openflow count [ slot slot-number ] |
Display the aging timer of dynamic ARP entries. |
display arp timer aging |
Display the ARP table usage. |
display arp usage |
Display user IP address conflicts. |
display arp user-ip-conflict record [ slot slot-number ] |
Display user port migrations. |
display arp user-move record [ slot slot-number ] |
Display the ARP entries for a VPN instance. |
display arp vpn-instance vpn-instance-name [ count ] |
Clear ARP entries from the ARP table. |
reset arp { all | dynamic | interface interface-type interface-number | multiport | slot slot-number | static } |
ARP configuration examples
As shown in Figure 3, hosts are connected to Device B. Device B is connected to Device A through interface GigabitEthernet 1/0/1 in VLAN 10.
To ensure secure communications between Device A and Device B, configure a long static ARP entry for Device A on Device B.
# Create VLAN 10.
[DeviceB] vlan 10
[DeviceB-vlan10] quit
# Add interface GigabitEthernet 1/0/1 to VLAN 10.
[DeviceB-GigabitEthernet1/0/1] port access vlan 10
# Create VLAN-interface 10 and configure its IP address.
[DeviceB] interface vlan-interface 10
[DeviceB-vlan-interface10] ip address 192.168.1.2 8
[DeviceB-vlan-interface10] quit
# Configure a long static ARP entry that has IP address 192.168.1.1, MAC address 00e0-fc01-0000, and output interface GigabitEthernet 1/0/1 in VLAN 10.
[DeviceB] arp static 192.168.1.1 00e0-fc01-0000 10 gigabitethernet 1/0/1
# Verify that Device B has a long static ARP entry for Device A.
[DeviceB] display arp static
Type: S-Static D-Dynamic O-Openflow R-Rule M-Multiport I-Invalid
IP address MAC address VLAN/VSI name Interface Aging Type
192.168.1.1 00e0-fc01-0000 10 GE1/0/1 -- S
As shown in Figure 4, hosts are connected to Device B. Device B is connected to Device A through interface GigabitEthernet 1/0/2.
To ensure secure communications between Device A and Device B, configure a short static ARP entry for Device A on Device B.
# Configure an IP address for GigabitEthernet 1/0/2.
[DeviceB-GigabitEthernet1/0/2] ip address 192.168.1.2 24
# Configure a short static ARP entry that has IP address 192.168.1.1 and MAC address 00e0-fc01-001f.
[DeviceB] arp static 192.168.1.1 00e0-fc01-001f
# Verify that Device B has a short static ARP entry for Device A
192.168.1.1 00e0-fc01-001f -- -- -- S
As shown in Figure 5, a device connects to three servers through interfaces GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 in VLAN 10. The servers share the IP address 192.168.1.1/24 and MAC address 00e0-fc01-0000.
Configure a multiport ARP entry so that the device sends IP packets with the destination IP address 192.168.1.1 to the three servers.
# Create VLAN 10.
[Device] vlan 10
[Device-vlan10] quit
# Add GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 to VLAN 10.
[Device-GigabitEthernet1/0/1] port access vlan 10
[Device-GigabitEthernet1/0/2] port access vlan 10
[Device] interface gigabitethernet 1/0/3
[Device-GigabitEthernet1/0/3] port access vlan 10
[Device-GigabitEthernet1/0/3] quit
# Create VLAN-interface 10 and specify its IP address.
[Device] interface vlan-interface 10
[Device-vlan-interface10] ip address 192.168.1.2 24
[Device-vlan-interface10] quit
# Configure a multiport unicast MAC address entry that has MAC address 00e0-fc01-0000, and output interfaces GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 in VLAN 10.
[Device] mac-address multiport 00e0-fc01-0000 interface gigabitethernet 1/0/1 to gigabitethernet 1/0/3 vlan 10
# Configure a multiport ARP entry with IP address 192.168.1.1 and MAC address 00e0-fc01-0000.
[Device] arp multiport 192.168.1.1 00e0-fc01-0000 10
# Verify that the device has a multiport ARP entry with IP address 192.168.1.1 and MAC address 00e0-fc01-0000.
[Device] display arp
192.168.1.1 00e0-fc01-0000 10 -- -- M
About gratuitous ARP
In a gratuitous ARP packet, the sender IP address and the target IP address are the IP address of the sending device.
A device sends a gratuitous ARP packet for either of the following purposes:
· Determine whether its IP address is already used by another device. If the IP address is already used, the device is informed of the conflict by an ARP reply.
· Inform other devices of a MAC address change.
IP conflict detection
When an interface obtains an IP address, the device broadcasts gratuitous ARP packets in the LAN where the interface resides. If the device receives an ARP reply, its IP address conflicts with the IP address of another device in the LAN. The device displays a log message about the conflict and informs the administrator to change the IP address. The device will not use the conflicting IP address. If no ARP reply is received, the device uses the IP address.
This feature enables a device to create or update ARP entries by using the sender IP and MAC addresses in received gratuitous ARP packets.
When this feature is disabled, the device uses received gratuitous ARP packets to update existing ARP entries only. ARP entries are not created based on the received gratuitous ARP packets, which saves ARP table space.
Periodic sending of gratuitous ARP packets helps downstream devices update ARP entries or MAC entries in a timely manner.
This feature can implement the following functions:
· Prevent gateway spoofing.
Gateway spoofing occurs when an attacker uses the gateway address to send gratuitous ARP packets to the hosts on a network. The traffic destined for the gateway from the hosts is sent to the attacker instead. As a result, the hosts cannot access the external network.
To prevent such gateway spoofing attacks, you can enable the gateway to send gratuitous ARP packets at intervals. Gratuitous ARP packets contain the primary IP address and manually configured secondary IP addresses of the gateway, so hosts can learn correct gateway information.
· Prevent ARP entries from aging out.
If network traffic is heavy or if the host CPU usage is high, received ARP packets can be discarded or are not promptly processed. Eventually, the dynamic ARP entries on the receiving host age out. The traffic between the host and the corresponding devices is interrupted until the host re-creates the ARP entries.
To prevent this problem, you can enable the gateway to send gratuitous ARP packets periodically. Gratuitous ARP packets contain the primary IP address and manually configured secondary IP addresses of the gateway, so the receiving hosts can update ARP entries in a timely manner.
· Prevent the virtual IP address of a VRRP group from being used by a host.
The master router of a VRRP group can periodically send gratuitous ARP packets to the hosts on the local network. The hosts can then update local ARP entries and avoid using the virtual IP address of the VRRP group. The sender MAC address in the gratuitous ARP packet is the virtual MAC address of the virtual router. For more information about VRRP, see High Availability Configuration Guide.
· Update MAC entries of devices in the VLANs having ambiguous Dot1q or QinQ termination configured.
In VRRP configuration, if ambiguous Dot1q or QinQ termination is configured for multiple VLANs and VRRP groups, interfaces configured with VLAN termination must be disabled from transmitting broadcast/multicast packets. Also, a VRRP control VLAN must be configured so that VRRP advertisements can be transmitted within the control VLAN only. In such cases, you can enable periodic sending of gratuitous ARP packets containing the following addresses:
¡ The VRRP virtual IP address.
¡ The primary IP address or a manually configured secondary IP address of the sending interface on the subinterfaces.
When a VRRP failover occurs, devices in the VLANs can use the gratuitous ARP packets to update their corresponding MAC entries in a timely manner. For more information about ambiguous Dot1q or QinQ termination, see Layer 2—LAN Switching Configuration Guide.
All gratuitous ARP tasks are optional. If all of the following features are disabled, gratuitous ARP still provides the IP conflict detection function.
· Enabling IP conflict notification
· Enabling gratuitous ARP packet learning
· Enabling periodic sending of gratuitous ARP packets
· Configuring gratuitous ARP packet retransmission for the device MAC address change
About IP conflict notification
Upon detecting an IP conflict, the device will sends a gratuitous ARP request. By default, the device displays an error message only after it receives an ARP reply. You can enable this feature to allow the device to display an error message immediately upon detecting an IP conflict.
2. Enable IP conflict notification.
arp ip-conflict log prompt
By default, IP conflict notification is disabled.
2. Enable gratuitous ARP packet learning.
gratuitous-arp-learning enable
By default, gratuitous ARP packet learning is enabled.
· You can enable periodic sending of gratuitous ARP packets on a maximum of 1024 interfaces.
· Periodic sending of gratuitous ARP packets takes effect on an interface only when the following conditions are met:
¡ The data link layer state of the interface is up.
¡ The interface has an IP address.
· If you change the sending interval for gratuitous ARP packets, the configuration takes effect at the next sending interval.
· The sending interval for gratuitous ARP packets might be much longer than the specified sending interval in any of the following circumstances:
¡ This feature is enabled on multiple interfaces.
¡ Each interface is configured with multiple secondary IP addresses.
¡ A small sending interval is configured when the previous two conditions exist.
3. Enable periodic sending of gratuitous ARP packets.
arp send-gratuitous-arp [ interval interval ]
By default, periodic sending of gratuitous ARP packets is disabled.
Enabling sending gratuitous ARP packets for ARP requests with sender IP address on a different subnet
2. Enable the device to send gratuitous ARP packets upon receiving ARP requests whose sender IP address belongs to a different subnet.
gratuitous-arp-sending enable
By default, a device does not send gratuitous ARP packets upon receiving ARP requests whose sender IP address belongs to a different subnet.
About gratuitous ARP packet retransmission for the device MAC address change
The device sends a gratuitous ARP packet to inform other devices of its MAC address change. However, the other devices might fail to receive the packet because the device sends the gratuitous ARP packet once only by default. Configure the gratuitous ARP packet retransmission feature to ensure that the other devices can receive the packet.
2. Set the times and the interval for retransmitting a gratuitous ARP packet for the device MAC address change.
gratuitous-arp mac-change retransmit times interval seconds
By default, the device sends a gratuitous packet to inform its MAC address change once only.
Configuring proxy ARP
About proxy ARP
Proxy ARP enables a device on one network to answer ARP requests for an IP address on another network. With proxy ARP, hosts on different broadcast domains can communicate with each other as they would on the same broadcast domain.
Proxy ARP includes common proxy ARP and local proxy ARP.
· Common proxy ARP—Allows communication between hosts that connect to different Layer 3 interfaces and reside in different broadcast domains.
· Local proxy ARP—Allows communication between hosts that connect to the same Layer 3 interface and reside in different broadcast domains.
Enabling common proxy ARP
The following interface types are supported:
¡ VLAN interface.
¡ Layer 3 Ethernet interface.
¡ Layer 3 Ethernet subinterface.
¡ Layer 3 aggregate interface.
¡ Layer 3 aggregate subinterface.
3. Enable common proxy ARP.
By default, common proxy ARP is disabled.
Enabling local proxy ARP
¡ VLAN interface.
3. Enable local proxy ARP.
local-proxy-arp enable [ ip-range start-ip-address to end-ip-address ]
By default, local proxy ARP is disabled.
Task |
Command |
Display local proxy ARP status. |
display local-proxy-arp [ interface interface-type interface-number ] |
Display common proxy ARP status. |
display proxy-arp [ interface interface-type interface-number ] |
Display statistics about proxy ARP reply packets. |
display proxy-arp statistics |
As shown in Figure 6, Host A and Host D have the same IP prefix and mask, but they are located on different subnets separated by the switch. Host A belongs to VLAN 1, and Host D belongs to VLAN 2. No default gateway is configured on Host A and Host D.
Configure common proxy ARP on the switch to enable communication between the two hosts.
# Create VLAN 2.
<Switch> system-view
[Switch] vlan 2
[Switch-vlan2] quit
# Configure the IP address of VLAN-interface 1.
[Switch] interface vlan-interface 1
[Switch-Vlan-interface1] ip address 192.168.10.99 255.255.255.0
# Enable common proxy ARP on VLAN-interface 1.
[Switch-Vlan-interface1] proxy-arp enable
[Switch-Vlan-interface1] quit
# Configure the IP address of VLAN-interface 2.
[Switch-Vlan-interface2] ip address 192.168.20.99 255.255.255.0
# Enable common proxy ARP on VLAN-interface 2.
[Switch-Vlan-interface2] proxy-arp enable.
# Verify that Host A and Host D can ping each other.
Configuring ARP snooping
About ARP snooping
ARP snooping is used in Layer 2 switching networks. It creates ARP snooping entries by using information in ARP packets. Manual-mode MFF can use the ARP snooping entries. For more information about MFF, see Security Configuration Guide.
If you enable ARP snooping for a VLAN or VXLAN, ARP packets received in the VLAN or VXLAN are redirected to the CPU. For the VLAN, the CPU uses the sender IP and MAC addresses of the ARP packets, and the receiving VLAN and port to create ARP snooping entries. For the VXLAN, the CPU uses the sender IP and MAC addresses of the ARP packets, VSI name, and link ID to create ARP snooping entries. For more information about VXLAN, see VXLAN overview in VXLAN Configuration Guide.
Aging of ARP snooping entries
The aging timer and valid period of an ARP snooping entry are 25 minutes and 15 minutes. If an ARP snooping entry is not updated in 12 minutes, the device sends an ARP request. The ARP request uses the IP address of the entry as the target IP address. If an ARP snooping entry is not updated in 15 minutes, it becomes invalid and cannot be used. After that, if an ARP packet matching the entry is received, the entry becomes valid, and its aging timer restarts.
If the aging timer of an ARP snooping entry expires, the entry is removed.
Protection for ARP snooping
An attack occurs if an ARP packet has the same sender IP address as a valid ARP snooping entry but a different sender MAC address. The ARP snooping entry becomes invalid, and it is removed in 1 minute.
2. Enter VLAN view.
vlan vlan-id
3. Enable ARP snooping for the VLAN.
arp snooping enable
By default, ARP snooping is disabled for a VLAN.
2. Enter VSI view.
vsi vsi-name
3. Enable ARP snooping for the VSI.
arp snooping enable
By default, ARP snooping is disabled for a VSI.
Task |
Command |
Display ARP snooping entries. |
display arp snooping { vlan [ vlan-id ]| vsi [vsi-name ] } [ slot slot-number ] [ count ] display arp snooping vlan ip ip-address [ slot slot-number ] |
Delete ARP snooping entries. |
reset arp snooping { vlan [ vlan-id ] | vsi [ vsi-name ] } reset arp snooping vlan ip ip-address |
This feature generates direct routes based on ARP entries for packet forwarding and route advertisement.
As shown in Figure 7, ARP direct route advertisement is enabled on Interface A and Interface B. This feature generates a direct route to Server A and a host route to Server B for the routing protocols to advertise. So each device forwards only the traffic destined to the server within the network, which saves bandwidth.
Figure 7 Application in a Layer 3 access network
3. Enable ARP direct route advertisement.
arp route-direct advertise [ preference preference-value | tag tag-value ] *
By default, ARP direct route advertisement is disabled.
Task |
Command |
Display information about ARP-advertised direct routes. |
display arp route-direct advertise interface interface-type interface-number |
