07-Loopback, null, and inloopback interface commands | 169.72 KB |
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth of a loopback interface is 0 kbps.
Loopback interface view
# Set the expected bandwidth of Loopback 0 to 1000 kbps.
[Sysname] interface loopback 0
[Sysname-LoopBack0] bandwidth 1000
default
Use default to restore the default settings for an interface.
default
Null interface view
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command before using it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Loopback 0.
[Sysname-LoopBack0] default
description
The interface description uses the interface name Interface format, for example, LoopBack0 Interface.
Null interface view
text: Specifies the description, a case-sensitive string of 1 to 255 characters.
Configure a description for an interface for easy identification and management purposes.
You can use the display interface command to view the configured description.
# Configure the description of Loopback 0 as for RouterID.
[Sysname-LoopBack0] description for RouterID
display interface inloopback
Use display interface inloopback to display information about the inloopback interface.
display interface [ inloopback [ 0 ] ] [ brief [ description | down ] ]
inloopback [ 0 ]: Specifies an inloopback interface by its number. If you do not specify the inloopback keyword, the command displays information about all interfaces except VA interfaces. For more information about VA interfaces, see PPPoE in Layer 2—WAN Access Configuration Guide.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions. The description of an inloopback interface is always InLoopBack0 Interface and cannot be configured.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
The device has only one inloopback interface Inloopback 0. If you specify the inloopback keyword, the command displays information about the interface Inloopback 0 regardless of whether you specify the 0 keyword.
# Display detailed information about Inloopback 0.
<Sysname> display interface inloopback
InLoopBack0
Current state: UP
Line protocol state: UP(spoofing)
Description: InLoopBack0 Interface
Maximum transmission unit: 1536
Physical: InLoopBack
Current state |
Physical link state of the interface, which is always UP, meaning that the inloopback interface can receive and transmit packets. |
Line protocol state |
Data link layer state of the interface, which is always UP(spoofing). UP(spoofing) represents that the data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces. |
Description of the interface, which is always InLoopBack0 Interface and cannot be configured. |
Maximum transmission unit |
MTU of the interface, which is always 1536 and cannot be configured |
Physical: InLoopBack |
The physical type of the interface is inloopback. |
Last 300 seconds input rate:? 0 bytes/sec, 0 bits/sec, 0 packets/sec |
Average input rate during the last 300 seconds (displayed when the interface supports traffic statistics collection): · bytes/sec—Average number of bytes received per second. · bits/sec—Average number of bits received per second. · packets/sec—Average number of packets received per second. |
Last 300 seconds output rate:? 0 bytes/sec, 0 bits/sec, 0 packets/sec |
Average output rate over the last 300 seconds (displayed when the interface supports traffic statistics collection): · bytes/sec—Average number of bytes sent per second. · bits/sec—Average number of bits sent per second. · packets/sec—Average number of packets sent per second. |
Input: 0 packets, 0 bytes, 0 drops |
Total number and size (in bytes) of incoming packets of the interface and the number of dropped packets (displayed when the interface supports traffic statistics collection). |
Output: 0 packets, 0 bytes, 0 drops |
Total number and size (in bytes) of outgoing packets of the interface and the number of dropped packets (displayed when the interface supports traffic statistics collection). |
# Display brief information about Inloopback 0.
<Sysname> display interface inloopback 0 brief
Protocol: (s) - spoofing
Interface??????????? Link Protocol Primary IP???????? Description
InLoop0????????????? UP?? UP(s)??? --
Link |
Physical link state of the interface, which is always UP, meaning that the link is physically up. |
Protocol |
Data link layer protocol state of the interface, which is always UP(s). UP(s) represents that the data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
IP address of the interface. Because inloopback interfaces do not support CLI configuration, this field does not display a value. |
Description of the interface. Because inloopback interfaces do not support CLI configuration, this field does not display a value. |
display interface loopback
Use display interface loopback to display information about the specified or all existing loopback interfaces.
display interface [ loopback [ interface-number ] ] [ brief [ description | down ] ]
loopback [ interface-number ]: Specifies a loopback interface by its number, which can be the number of any existing loopback interface. If you do not specify the loopback keyword, the command displays information about all interfaces except VA interfaces. If you specify the loopback keyword but do not specify the interface-number argument, the command displays information about all existing loopback interfaces on the device. For more information about VA interfaces, see PPPoE in Layer 2—WAN Access Configuration Guide.
This command is supported only after a loopback interface is created.
# Display detailed information about Loopback 0.
<Sysname> display interface loopback 0
LoopBack0
Current state: UP
Description: LoopBack0 Interface
Bandwidth: 1000 kbps
Physical: Loopback
Last clearing of counters:? Never
Current state |
Physical link state of the interface: · UP—The loopback interface can receive and transmit packets. · Administratively DOWN—The interface has been shut down by using the shutdown command. |
Data link layer state of the interface. UP (spoofing) means that the data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. This field is not displayed when the value is 0. |
MTU of the interface. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · HCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · BOOTP-Allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3—IP Services Configuration Guide. · PPP-Negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2—WAN Access Configuration Guide. · Unnumbered—IP address borrowed from another interface. · MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide. · MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide. |
Physical: Loopback |
The physical type of the interface is loopback. |
Last clearing of counters |
Time when statistics on the logical interface were last cleared by using the reset counters interface command. If the statistics of the interface have never been cleared by using the reset counters interface command since the device started, this field displays Never. |
Average input rate during the last 300 seconds (displayed when the interface supports traffic statistics collection): bytes/sec—Average number of bytes received per second. bits/sec—Average number of bits received per second. packets/sec—Average number of packets received per second. |
# Display brief information about all loopback interfaces.
<Sysname> display interface loopback brief
Interface??????????? Link Protocol Primary IP????? Description
Loop0??????????????? UP?? UP(s)??? --????????????? forLAN1
# Display information about all loopback interfaces in down state and the causes.
<Sysname> display interface loopback brief down
Interface??????????? Link Cause
Loop0??????????????? ADM? Administratively
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Primary IP |
Primary IP address of the interface. |
Cause |
Cause for the physical link state of the interface to be DOWN. Administratively represents that the interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. |
interface loopback
reset counters interface loopback
display interface null
Use display interface null to display information about the null interface.
display interface [ null [ 0 ] ] [ brief [ description | down ] ]
null [ 0 ]: Specifies a null interface by its number. If you do not specify the null keyword, the command displays information about all interfaces except VA interfaces. For more information about VA interfaces, see PPPoE in Layer 2—WAN Access Configuration Guide.
The device has only one null interface Null 0. If you specify the null keyword, the command displays information about the interface Null 0 regardless of whether you specify the 0 keyword.
# Display detailed information about Null 0.
<Sysname> display interface null 0
NULL0
Current state: UP
Description: NULL0 Interface
Bandwidth: 1000000 kbps
Physical: NULL DEV
# Display brief information about Null 0.
<Sysname> display interface null 0 brief
NULL0??????????? ????UP?? UP(s)??? --?????????????
For the command output, see Table 3 and Table 4.
interface null
reset counters interface null
interface loopback
Use interface loopback to create a loopback interface and enter its view, or enter the view of an existing loopback interface.
Use undo interface loopback to remove a loopback interface.
interface loopback interface-number
undo interface loopback interface-number
No loopback interfaces exist.
interface-number: Specifies a loopback interface by its number.
The physical layer state and link layer protocols of a loopback interface are always up unless the loopback interface is manually shut down. You can use a loopback interface to achieve the following purposes:
· Prevent the connection from being affected by the physical state of the interface.
· Improve the reliability of the connection.
For example, you can configure a loopback interface as the source interface for establishing an FTP connection, or use the loopback interface address as the Router ID in BGP.
# Create Loopback 0.
interface null
Use interface null to enter null interface view.
interface null 0
A device has only one null interface (Null 0), which cannot be created or deleted.
0: Specifies Null 0. The null interface number is always 0.
# Enter Null 0 interface view.
[Sysname] interface null 0
Use reset counters interface loopback to clear the statistics on the specified or all loopback interfaces.
reset counters interface [ loopback [ interface-number ] ]
loopback [ interface-number ]: Specifies a loopback interface by its number. If you do not specify the loopback keyword, the command clears the statistics on all interfaces except VA interfaces. If you specify the loopback keyword but do not specify the interface-number argument, the command clears the statistics on all loopback interfaces.
To determine whether a loopback interface works correctly within a period by collecting the traffic statistics within that period, first use the reset counters interface [ loopback [ interface-number ] ] command to clear the statistics. Then have the interface automatically collect the statistics.
This command is available only if a minimum of one loopback interface has been created.
# Clear the statistics on Loopback 0.
<Sysname> reset counters interface loopback 0
Use reset counters interface null to clear the statistics on the null interface.
reset counters interface [ null [ 0 ] ]
null [ 0 ]: Specifies a null interface by its number. If you do not specify the null keyword, the command clears the statistics on all interfaces except VA interfaces.
To determine whether the null interface works correctly within a period by collecting the traffic statistics within that period, first use the reset counters interface [ null [ 0 ] ] command to clear the statistics. Then have the interface automatically collect the statistics.
# Clear the statistics on Null 0.
<Sysname> reset counters interface null 0
shutdown
Use shutdown to shut down a loopback interface.
Use undo shutdown to bring up a loopback interface.
shutdown
A loopback interface is up.
Use the shutdown command with caution, because the command disconnects the connection of the interface and disables the interface from communicating.
# Shut down Loopback 0.
[Sysname-LoopBack0] shutdown
