03-WAN interface commands | 875.89 KB |
Common WAN interface commands
bandwidth
Use bandwidth to configure the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
E1-F interface view
Serial interface view
Serial subinterface view
T1-F interface view
# Set the expected bandwidth to 50 kbps for Serial 2/1/0.
[Sysname] interface serial 2/1/0
[Sysname-Serial2/1/0] bandwidth 50
default
Use default to restore the default settings for an interface.
default
CE1 interface view
CT1 interface view
CT3 interface view
E1-F interface view
T1-F interface view
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. You can use the display this command in interface view to check for these commands, and use their undo forms or follow the command reference to restore their respective default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings of Serial 2/1/0.
[Sysname-Serial2/1/0] default
description
The interface description uses the interface name Interface format, for example, Serial2/1/0 Interface.
CE1 interface view
CT1 interface view
CT3 interface view
E1-F interface view
T1-F interface view
text: Specifies the description, a case-sensitive string of 1 to 255 characters.
# Configure the description of Serial 2/1/0 as router-interface.
[Sysname-Serial2/1/0] description router-interface
mtu
Use mtu to set the MTU for an interface.
mtu size
undo mtu
The MTU of an interface is 1500 bytes.
E1-F interface view
T1-F interface view
size: Sets the maximum transmission unit (MTU) in bytes.The value range for this argument is 128 to 2000.
The MTU setting affects IP packet assembly and fragmentation on the interface.
After configuring the MTU for a WAN interface, you must use the shutdown command and then the undo shutdown command on the interface for the modification to take effect.
# Set the MTU to 1430 bytes for Serial 2/1/0.
[Sysname-Serial2/1/0] mtu 1430
shutdown
Use shutdown to shut down an interface.
Use undo shutdown to restore the default.
shutdown
A WAN interface is up.
CE1 interface view
CT1 interface view
CT3 interface view
E1-F interface view
T1-F interface view
# Shut down Serial 2/1/0.
[Sysname-Serial2/1/0] shutdown
timer-hold
Use timer-hold to set the keepalive interval.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The keepalive interval is 10 seconds.
E1-F interface view
T1-F interface view
seconds: Specifies the interval at which an interface sends keepalive packets. The value range is 0 to 32767 seconds.
On an interface encapsulated with PPP, FR, or HDLC, the data link layer sends keepalive packets at keepalive intervals to detect the availability of the remote end. The data link layer determines that the peer end is down if it does not receive a response after the maximum number of keepalive attempts have been made. The data link layer then reports the link down event to the upper-layer protocols.
To set the maximum number of keepalive attempts, use the timer-hold retry command.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive interval to 15 seconds for Serial 2/1/0.
[Sysname-Serial2/1/0] timer-hold 15
timer-hold retry
timer-hold retry
Use timer-hold retry to set the maximum number of keepalive attempts.
Use undo timer-hold retry to restore the default.
timer-hold retry retries
The maximum number of keepalive attempts is 5.
E1-F interface view
T1-F interface view
retries: Specifies the maximum number of keepalive attempts, in the range of 1 to 255.
The interface determines that the remote end is down if it does not receive a response after the maximum number of keepalive attempts have been made.
This command applies to interfaces encapsulated with PPP, FR, or HDLC. To set the keepalive interval, use the timer-hold command.
On a slow link, increase the maximum number of keepalive attempts to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the maximum number of keepalive attempts to 10 for Serial 2/1/0.
[Sysname-Serial2/1/0] timer-hold retry 10
timer-hold
Serial interface commands
baudrate
Use baudrate to set the baud rate for a synchronous serial interface.
Use undo baudrate to restore the default.
baudrate baudrate
undo baudrate
The baud rate is 64000 bps on a synchronous serial interface.
Synchronous serial interface view
baudrate: Specifies a baud rate (in bps) for a serial interface. The baud rate range on a synchronous serial interface depends on the applied physical electric specifications.
· For V.24 DTE/DCE, available baud rates (in bps) are:
Baud rates |
1200 |
9600 |
56000 |
2400 |
19200 |
57600 |
4800 |
38400 |
64000 |
· For V.35 DCE/DCE, X.21 DTE/DCE, EIA/TIA-449 DTE/DCE, and EIA-530 DTE/DCE, available baud rates (in bps) are:
Baud rates |
1200 |
57600 |
384000 |
2400 |
64000 |
512000 |
4800 |
72000 |
1024000 |
9600 |
115200 |
2048000 |
19200 |
128000 |
4096000 |
38400 |
192000 |
8192000bps |
56000 |
256000 |
This command is available only on serial interfaces on the MIM-2SAE, MIM-4SAE, and MIM-8SAE interface modules.
Take the physical electric specifications of the cable into consideration when you set the baud rate for a serial interface.
The baud rate used by a DCE-DTE pair is determined by the DCE.
# Set the baud rate to 115200 bps on the DCE-side Serial 2/1/0.
[Sysname-Serial2/1/0] baudrate 115200
virtualbaudrate
clock
Use clock to set the clock selection mode for a synchronous serial interface.
Use undo clock to restore the default.
clock { dteclk1 | dteclk2 | dteclk3 | dteclk4 | dteclk5 | dteclkauto }
clock { dceclk1 | dceclk2 | dceclk3 }
undo clock
The DTE-side clock is dteclk1 and the DCE-side clock is dceclk1.
dteclk1: Sets the interface clock selection mode to DTE clock option 1.
dteclk2: Sets the interface clock selection mode to DTE clock option 2.
dteclk3: Sets the interface clock selection mode to DTE clock option 3.
dteclk4: Sets the interface clock selection mode to DTE clock option 4.
dteclk5: Sets the interface clock selection mode to DTE clock option 5.
dteclkauto: Sets the interface clock selection mode to DTE auto-negotiation.
dceclk1: Sets the interface clock selection mode to DCE clock option 1.
dceclk2: Sets the interface clock selection mode to DCE clock option 2.
dceclk3: Sets the interface clock selection mode to DCE clock option 3.
In DTE mode, the synchronous serial interface supports the clock { dteclk1 | dteclk2 | dteclk3 | dteclk4 | dteclk5 | dteclkauto } command.
In DCE mode, the synchronous serial interface supports the clock { dceclk1 | dceclk2 | dceclk3 } command.
A synchronous serial interface can operate as a DCE or DTE.
· As a DCE, the interface provides the DCEclk clock for the DTE.
· As a DTE, the interface accepts the clock provided by the DCE. Because transmitting and receiving clocks of synchronization devices are independent, the receiving clock of a DTE device can be either the transmitting or receiving clock of the DCE device. The transmitting clock of a DTE device can be either the transmitting or receiving clock of the DCE device. Therefore, five clock options are available for a DTE device.
In Figure 1, TxClk represents transmitting clock, and RxClk represents receiving clock.
Figure 1 Selecting a clock for a synchronous serial interface
Table 1 describes the four clock selection options for a synchronous serial interface operating as a DTE. The clock preceding the equal sign (=) is the DTE clock, and the clock that follows the equal sign is the DCE clock.
Table 1 Clock options available for a synchronous serial interface operating as a DTE
Clock selection option |
DTEclk1 |
TxClk = TxClk, RxClk = RxClk. |
DTEclk2 |
TxClk = TxClk, RxClk = TxClk. |
DTEclk3 |
TxClk = RxClk, RxClk = TxClk. |
DTEclk4 |
TxClk = RxClk, RxClk = RxClk. |
DTEclk5 |
TxClk = Local, RxClk = Local. |
Table 2 describes the clock selection options for a synchronous serial interface operating as a DCE. The clock preceding the equal sign (=) is the DCE clock, and the clock that follows the equal sign is the clock signal source.
Table 2 Clock options available for a synchronous serial interface operating as a DCE
DCEclk1 |
DCEclk2 |
TxClk = Local, RxClk = Line. |
DCEclk3 |
TxClk = Line, RxClk = Line. |
# Configure Serial 2/1/0 operating as a DTE to use the clock selection option dteclk2.
[Sysname-Serial2/1/0] clock dteclk2
code
Use code to configure the digital signal coding format on a synchronous serial interface.
Use undo code to restore the default.
code { nrz | nrzi }
undo code
The digital signal coding format is NRZ.
nrz: Sets the digital signal coding format to nonreturn to zero (NRZ).
nrzi: Sets the digital signal coding format to nonreturn to zero inverted (NRZI).
# Set the digital signal coding format to NRZI on Serial 2/1/0.
[Sysname-Serial2/1/0] code nrzi
crc
Use crc to set the CRC mode for a synchronous serial interface.
Use undo crc to restore the default.
crc { 16 | 32 | none }
undo crc
16-bit CRC is used.
16: Specifies 16-bit CRC.
32: Specifies 32-bit CRC.
none: Disables CRC.
# Configure Serial 2/1/0 to use 32-bit CRC.
[Sysname-Serial2/1/0] crc 32
detect dcd
Use detect dcd to enable data carrier detection (DCD) on a serial interface.
Use undo detect dcd to disable DCD on a serial interface.
detect dcd
undo detect dcd
DCD is enabled on a serial interface.
When determining whether a synchronous serial interface is up, the system detects by default the DSR signal, DCD signal, and presence of cable connection. The interface is considered to be up only when the three signals are all valid.
# Enable DCD on Serial 2/1/0.
[Sysname-Serial2/1/0] detect dcd
detect dsr-dtr
detect dsr-dtr
Use detect dsr-dtr to enable level detection on a serial interface.
Use undo detect dsr-dtr to disable level detection on a serial interface.
detect dsr-dtr
undo detect dsr-dtr
Level detection is enabled on a serial interface.
In level detection, the system detects the following items for the data service unit (DSU) or the channel service unit (CSU):
· Data set ready (DSR) signals.
· Data terminal ready (DTR) signals.
When determining whether a synchronous serial interface is up, the system detects by default the DSR signal, DCD signal, and presence of a cable connection. The interface is considered to be up only when the three signals are all valid.
If level detection is disabled on a synchronous serial interface, the system considers the interface to be up after detecting the cable connection. The DTR and DSR are also reported as up.
[Sysname-Serial2/1/0] detect dsr-dtr
detect dcd
display interface serial
Use display interface serial to display information about serial interfaces.
display interface serial [ interface-number ] [ brief [ description | down ] ]
serial [ interface-number ]: Specifies a serial interface by its number. If you do not specify the serial keyword, this command displays information about all interfaces. If you specify the serial keyword without specifying an interface, this command displays information about all serial interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays physically down interfaces and their down causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about Serial 2/1/0.
<Sysname> display interface serial 2/1/0
Serial2/1/0
Current state: UP
Line protocol state: UP
Description: Serial2/1/0 Interface
Bandwidth: 64kbps
Hold timer: 10 seconds, retry times: 5
Internet Address: 9.9.9.6/24 Primary
Link layer protocol: PPP
LCP: opened
Last link flapping: 6 hours 39 minutes 25 seconds
Current system time:2017-12-14 10:00:37
Last time when physical state changed to up:-
Last time when physical state changed to down:2017-12-14 09:47:16
Physical layer: synchronous, Baudrate: 64000 bps
Interface: DCE
Cable type: V35
Clock mode: DCECLK1
Last 300 seconds input rate: 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
Last 300 seconds output rate: 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
Input:
6668 packets, 80414 bytes
0 broadcasts, 0 multicasts
0 errors, 0 runts, 0 giants
0 crc, 0 align errors, 0 overruns
0 aborts, 0 no buffers, 1 frame errors
Output:
6670 packets, 80446 bytes
0 errors, 0 underruns, 0 collisions
0 deferred
DCD: UP, DTR: UP, DSR: UP, RTS: UP, CTS: UP
# Display brief information about Serial 2/1/0.
<Sysname> display interface serial 2/1/0 brief
Protocol: (s) - spoofing
Ser2/1/0 UP UP(s) --
# Display brief information about all serial interfaces in down state and the causes.
<Sysname> display interface serial brief down
Interface Link Cause
Ser2/1/0 ADM Administratively
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer. · UP—The data link layer protocol is up. · DOWN—The data link layer protocol is down. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. |
Maximum transmission unit |
MTU of the interface. |
Hold timer |
Interval at which the interface sends keepalive packets. |
retry times |
Maximum number of keepalive attempts. The interface determines that the remote end is down if it does not receive a keepalive response after the maximum number of keepalive attempts have been made. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet Address |
IP address of the interface. The primary attribute indicates that the address is the primary IP address. |
Link layer protocol |
Link layer protocol of the interface. |
LCP: opened |
A PPP connection is established successfully. |
Output queue - Urgent queuing: Size/Length/Discards Output queue - Protocol queuing: Size/Length/Discards Output queue - FIFO queuing: Size/Length/Discards |
Information about the urgent, protocol, and FIFO output queues: · Size—Number of packets in the queue. · Length—Maximum number of packets that the queue can contain. · Discards—Number of dropped packets. |
Last link flapping |
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup. |
Last clearing of counters |
The most recent time that the reset counters interface serial command was executed. This field displays Never if this command has not been executed since the device startup. |
Physical layer |
Physical layer information. |
Baudrate |
Baud rate of the interface. |
Interface: DCE Cable type: V35 Clock mode: DCECLK1 |
Synchronizes the clock mode on the DCE side of the interface. |
Last 300 seconds input rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec |
Average input rates (in Bps, bps, and pps) for the last 300 seconds. |
Last 300 seconds output rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec |
Average output rates (in Bps, bps, and pps) for the last 300 seconds. |
Input: 6668 packets, 80414 bytes 0 broadcasts, 0 multicasts 0 errors, 0 runts, 0 giants 0 crc, 0 align errors, 0 overruns 0 aborts, 0 no buffers, 1 frame errors |
Incoming traffic statistics for the interface: · broadcasts—Number of incoming broadcast packets. · multicasts—Number of incoming multicast packets. · errors—Number of error packets detected at the physical layer. · runts—Number of incoming undersized packets. · giants—Number of incoming oversized packets. · crc—Number of incoming normal-size packets with CRC errors. · align errors—Number of incoming packets with alignment errors. · overruns—Number of packet drops because the input rate of the interface exceeded the queuing capability. · frame errors—Number of packets with framing errors. · aborts—Number of anomalous errors. · no buffers—Number of packet drops because the receive buffer is full. |
Output: 6670 packets, 80446 bytes 0 errors, 0 underruns, 0 collisions 0 deferred |
Outgoing traffic statistics for the interface: · errors—Number of error packets detected at the physical layer. · underruns—Number of packets that fail to be forwarded because the interface reads from memory slower than it forwards packets. · collisions—Number of packets that the interface stopped transmitting because packet collisions were detected during transmission. · deferred—Number of packets that the interface deferred to transmit because of detected collisions or timeout events. |
DCD: DOWN, DTR: UP, DSR: DOWN, RTS: UP, CTS: DOWN |
Status of Data Carrier Detect (DCD), Data Terminal Ready (DTR), Data Set Ready (DSR), Request to Send (RTS), and Clear to Send (CTS) signals. For more information about DSR, DTR, and DCD, see "detect dcd." |
Brief information on interfaces in route mode: |
Brief information about Layer 3 interfaces. |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty). |
idle-code
Use idle-code to set the line idle code of a synchronous serial interface.
Use undo idle-code to restore the default.
idle-code { 7e | ff }
undo idle-code
The line idle code of a synchronous serial interface is 7e.
7e: Sets the line idle code to 7e (hexadecimal).
ff: Sets the line idle code to ff (hexadecimal).
In most cases, a synchronous serial interface uses 7e (hexadecimal) to identify the idle state of the line. You might need to set the line idle code to ff (hexadecimal) to interoperate with devices that use ff as the line idle code.
# Set the line idle code to ff for Serial 2/1/0.
[Sysname-Serial2/1/0] idle-code ff
interface serial
Use interface serial to create a serial subinterface and enter its view, or enter the view of an existing serial interface or serial subinterface.
Use undo interface serial to remove a serial subinterface.
interface serial { interface-number | interface-number.subnumber [ p2mp | p2p ] }
undo interface serial interface-number.subnumber
No serial subinterfaces exist.
interface-number: Specifies a serial interface by its number.
interface-number.subnumber: Specifies a serial subinterface by its number. The interface-number argument specifies the number of the serial interface. The subnumber argument specifies the subinterface index in the range of 0 to 1023.
p2mp: Sets the subinterface type to point-to-multipoint. By default, a serial subinterface is P2MP type.
p2p: Sets the subinterface type to point-to-point.
A subinterface can be created only when the upper data link layer protocol of the serial interface is FR.
# Create serial subinterface Serial 2/1/0.1.
[Sysname] interface serial 2/1/0.1
[Sysname-Serial2/1/0.1]
link-protocol
invert receive-clock
Use invert receive-clock to invert the receive-clock signal on the DTE-side synchronous serial interface.
Use undo invert receive-clock to restore the default.
Receive-clock signal inversion is disabled on DTE-side synchronous serial interfaces.
You might need to invert the receive-clock signal on a DTE-side serial interface to eliminate the half clock-period delay on the line. This command is necessary only when the DTE-side serial interface is connected to some special DCE devices. In common applications, do not invert the clock.
# Invert the receive-clock on DTE-side synchronous serial interface Serial 2/1/0.
[Sysname-Serial2/1/0] invert receive-clock
invert transmit-clock
Use invert transmit-clock to invert the transmit-clock signal on the DTE-side synchronous serial interface.
Use undo invert transmit-clock to restore the default.
Transmit-clock signal inversion is disabled on DTE-side synchronous serial interfaces.
You might need to invert the transmit-clock signal on a DTE-side serial interface to eliminate the half clock-period delay on the line. This command is necessary only when the DTE-side serial interface is connected to some special DCE devices. In common applications, do not invert the clock.
# Invert the transmit-clock on DTE-side synchronous serial interface Serial 2/1/0.
[Sysname-Serial2/1/0] invert transmit-clock
itf
Use itf to set the number of interframe filling tags.
Use undo itf to restore the default.
itf number number
undo itf number
The number of interframe filling tags is 4.
number number: Sets the number of interframe filling tags, in the range of 0 to 14. An interframe filling tag is one byte in length.
# Set the number of interframe filling tags to 5.
[Sysname-Serial2/1/0] itf number 5
link-protocol
Use link-protocol to configure the data link layer protocol for an interface.
link-protocol { fr | hdlc | mfr | ppp }
undo link-protocol
A synchronous serial interface uses PPP as the data link layer protocol.
fr: Specifies the FR data link layer protocol.
hdlc: Specifies the HDLC data link layer protocol.
mfr: Specifies the MFR data link layer protocol.
ppp: Specifies the PPP data link layer protocol.
# Specify HDLC as the data link layer protocol of Serial 2/1/0.
[Sysname-Serial2/1/0] link-protocol hdlc
loopback
Use loopback to enable loopback on a serial interface.
Use undo loopback to disable loopback on a serial interface.
loopback
undo loopback
Loopback is disabled on a serial interface.
Loopback is intended for testing only. Disable the feature when the interface is operating correctly.
# Enable loopback on Serial 2/1/0.
[Sysname-Serial2/1/0] loopback
Use reset counters interface serial to clear serial interface statistics.
reset counters interface serial [ interface-number ]
serial [ interface-number ]: Specifies a serial interface by its number. If you do not specify the serial keyword, this command clears statistics for all interfaces. If you specify the serial keyword without specifying an interface, this command clears statistics for all serial interfaces.
Use this command to clear history statistics before you collect traffic statistics for a time period.
# Clear statistics for Serial 2/1/0.
<Sysname> reset counters interface serial 2/1/0
reverse-rts
Use reverse-rts to reverse RTS signal.
Use undo reverse-rts to restore the default.
reverse-rts
undo reverse-rts
RTS signal reverse is disabled.
When this command is configured, the remote end is not allowed to send data while the local end is sending data.
Use this command only for debugging purposes.
# Reverse the RTS signal.
[Sysname-Serial2/1/0] reverse-rts
sub-interface rate-statistic
Use sub-interface rate-statistic to enable subinterface rate statistics collection on a serial interface.
Use undo sub-interface rate-statistic to disable subinterface rate statistics collection on a serial interface.
The system does not collect subinterface rate statistics for a serial interface.
Synchronous interface view
CAUTION: This command is resource intensive. When you use this command, make sure you fully understand its impact on system performance. |
The subinterface rate statistics collection feature is available only on the following serial interfaces:
· Synchronous serial interfaces.
· Serial interfaces created through channelization.
# Enable subinterface rate statistics collection on Serial 2/1/0.
[Sysname-Serial2/1/0] sub-interface rate-statistic
virtualbaudrate
Use virtualbaudrate to set a virtual baud rate for a DTE-side interface.
Use undo virtualbaudrate to remove the virtual baud rate.
virtualbaudrate virtualbaudrate
The virtual baud rate for a synchronous serial interface is 64000 bps.
virtualbaudrate: Specifies a virtual baud rate (in bps). Available values are:
Virtual baud rates |
1200 |
57600 |
384000 |
2400 |
64000 |
512000 |
4800 |
72000 |
1024000 |
9600 |
115200 |
2048000 |
19200 |
128000 |
4096000 |
38400 |
192000 |
56000 |
256000 |
When operating as a DTE, the serial interface automatically sets its baud rate to be the same as the DCE side through negotiation.
If you use this command to set the baud rate of a DTE-side interface, you must make sure the baud rate is the same as the DCE-side interface.
If the clock selection mode of the serial interface is dteclk5, the configured virtual baud rate is the line rate.
Configure the baudrate command on the DCE side and the virtualbaudrate command on the DTE side only when the interface is operating in synchronous mode. Do not configure the two commands at the same end of a link.
On the DCE side, the display interface command displays the baud rate of the interface. On the DTE side, the command displays the virtual baud rate of the interface.
# Set the virtual baud rate to 19200 bps on the DTE-side interface Serial 2/1/0.
[Sysname-Serial2/1/0] virtualbaudrate 19200
baudrate
clock
Basic CE1 interface commands
alarm-detect
Use alarm-detect to enable RAI detection on an interface.
Use undo alarm-detect to disable RAI detection on an interface.
alarm-detect rai
undo alarm-detect rai
RAI detection is enabled on an interface.
CE1 interface view
rai: Remote Alarm Indication (RAI).
This command is applicable when the interface operates in CE1 mode.
# Enable RAI detection on E1 2/3/0.
[Sysname] controller e1 2/3/0
[Sysname-E1 2/3/0] alarm-detect rai
cable (CE1 interface)
Use cable to set the cable type for a CE1 interface.
Use undo cable to restore the default.
cable { long | short }
undo cable
The long keyword applies.
CE1 interface view
long: Specifies the attenuation of the receiver as –43 dB.
short: Specifies the attenuation of the receiver as –10 dB.
# Set the cable length matching E1 2/3/0 to short.
[Sysname-E1 2/3/0] cable short
channel-set (CE1 interface)
Use channel-set to bundle timeslots on a CE1 interface into a channel set.
Use undo channel-set to cancel the bundling.
channel-set set-number timeslot-list list
undo channel-set [ set-number ]
No channel sets exist on an interface.
CE1 interface view
set-number: Specifies the number of the channel set for the timeslot bundle. The value range is 0 to 30.
timeslot-list list: Specifies a comma-separated list of timeslot items. An item can be an individual timeslot or a timeslot range. Use a hyphen (-) to separate the start and end timeslot numbers of a range. The value range for the timeslot number is 1 to 31.
A CE1 interface in CE1 mode is physically divided into 32 timeslots numbered 0 through 31. All the timeslots except timeslot 0 can be bundled into multiple channel sets. For each channel set, the system automatically creates a serial interface that has the same logical features as a standard synchronous serial interface.
The serial interface name uses the serial interface-number:set-number format. The interface-number argument specifies the CE1 interface number. The set-number argument specifies the channel set number.
# Bundle timeslots 1, 2, 5, 10 through 15, and 18 into channel set 0 on E1 2/3/0.
[Sysname-E1 2/3/0] channel-set 0 timeslot-list 1,2,5,10-15,18
clock (CE1 interface)
Use clock to set the clock mode of a CE1 interface.
clock { master | slave }
undo clock
The clock mode of a CE1 interface is slave.
CE1 interface view
master: Sets the clock mode to master.
slave: Sets the clock mode to slave.
When the clock mode of an interface is master, it uses the internal clock source. When the clock mode of an interface is slave, it uses the line clock source.
Set the clock mode for an interface according to its operating mode:
· When the interface is operating in DCE mode, set its clock mode to master.
· When the interface is operating in DTE mode, set its clock mode to slave.
# Set the clock mode to master for CE1 interface E1 2/3/0.
[Sysname-E1 2/3/0] clock master
clock-change auto
Use clock-change auto to enable automatic clock mode switchover on an interface.
Use undo clock-change auto to disable automatic clock mode switchover.
clock-change auto
Automatic clock mode switchover is disabled on an interface.
CE1 interface view
When automatic clock mode switchover is enabled, the interface automatically switches to the master clock mode when both of the following conditions exist:
· The interface uses the slave clock mode.
· The interface receives an alarm indication signal (AIS), loss of signal (LOS), or loss of frame (LOF) alarm.
After the alarm is cleared, the interface automatically switches back to the slave mode.
When automatic clock mode switchover is disabled, the interface uses the user-configured clock mode.
# Enable automatic clock mode switchover for E1 2/3/0.
[Sysname-E1 2/3/0] clock-change auto
clock
code (CE1 interface)
Use code to set the line code format for a CE1 interface.
code { ami | hdb3 }
undo code
The line code format is HDB3 for the CE1 interface.
CE1 interface view
ami: Specifies the alternate mark inversion (AMI) line code format.
hdb3: Specifies the high-density bipolar 3 (HDB3) line code format.
An interface must use the same line code format as its remote end.
For the interface to operate correctly, configure the data-coding inverted command on the interface if the AMI format is used.
# Set the line code format to AMI for E1 2/3/0.
[Sysname-E1 2/3/0] code ami
data-coding
controller e1
Use controller e1 to enter CE1 interface view.
controller e1 interface-number
interface-number: Specifies a CE1 interface by its number.
# Enter E1 2/3/0 interface view.
[Sysname-E1 2/3/0]
data-coding (CE1 interface)
Use data-coding to enable user data inversion on a CE1 interface.
Use undo data-coding to restore the default.
data-coding { inverted | normal }
undo data-coding
Data inversion is disabled on a CE1 interface.
CE1 interface view
inverted: Enables user data inversion.
normal: Disables user data inversion.
To prevent 7e in valid data from being mistaken for padding characters, HDLC inserts a zero after every five consecutive ones in the data stream. In data inversion, each bit one is inverted to bit zero, and each bit zero is inverted to bit one. After the inversion, at least a bit one is present in every eight consecutive bits.
When AMI encoding is used on an E1 interface, data inversion eliminates the presence of multiple consecutive zeros.
The data inversion setting must be the same on the CE1 interfaces at two ends of an E1 line.
# Enable user data inversion on E1 2/3/0.
[Sysname-E1 2/3/0] data-coding inverted
detect-ais
Use detect-ais to enable alarm indication signal (AIS) detection on an interface.
Use undo detect-ais to disable AIS detection.
detect-ais
undo detect-ais
AIS detection is enabled on an interface.
CE1 interface view
This command takes effect when a CE1 interface operates in E1 mode.
# Enable AIS detection on E1 2/3/0.
[Sysname-E1 2/3/0] using e1
[Sysname-E1 2/3/0] detect-ais
display controller e1
Use display controller e1 to display information about CE1 interfaces.
display controller [ e1 [ interface-number ] ]
e1 [ interface-number ]: Specifies a CE1 interface by its number. If you do not specify the e1 keyword, the command displays information about all CE1 interfaces, CPOS interfaces, CE3 interfaces, CT1 interfaces, and CT3 interfaces. If you specify the e1 keyword without specifying an interface, the command displays information about all CE1 interfaces.
# Display information about E1 2/3/0.
<Sysname> display controller e1 2/3/0
E1 2/3/0
Current state: UP
Description: E1 2/3/0 Interface
Current system time:2017-11-11 15:51:05
Last time when physical state changed to up:2017-11-11 15:51:00
Last time when physical state changed to down:2017-11-11 15:50:51
Basic Configuration:
Work mode is E1 framed, Cable type is non-E1 type.
Frame-format is no-crc4.
Line code is hdb3, Source clock is slave.
Idle code is 7e, Itf type is 7e, Itf number is 0.
Loop back is not set.
Alarm State:
Receiver alarm state is Loss-of-Signal.
Transmitter is sending remote alarm.
Historical Statistics:
Data in current interval (2721 seconds elapsed):
0 Loss Frame Alignment Secs, 1 Framing Error Secs,
2 CRC Error Secs, 0 Alarm Indication Secs, 2694 Loss-of-signals Secs,
0 Code Violations Secs, 0 Slip Secs, 0 E-Bit error Secs
Current state |
Work mode is E1 framed |
Operating mode of the interface: E1 or CE1. |
Cable type is non-E1 type |
Cable type of the interface. |
Frame-format is no-crc4 |
Framing format of the E1 interface. |
Line code is hdb3 |
Line code: AMI or HDB3. |
Source clock is slave |
Clock source used by the interface: master or slave. |
Idle code is 7e |
Idle code: 7e or ff. |
Itf type is 7e |
Interframe filling tag: 7e or ff. |
Itf number is 0 |
Number of interframe filling tags between two successive frames. |
Loop back is not set |
Loopback state. |
Historical Statistics |
Statistics for the interface. |
Data in current interval (2721 seconds elapsed): 0 Loss Frame Alignment Secs, 1 Framing Error Secs, 2 CRC Error Secs, 0 Alarm Indication Secs, 2694 Loss-of-signals Secs, 0 Code Violations Secs, 0 Slip Secs, 0 E-Bit error Secs |
Error statistics for the current interval. |
reset counters controller e1
frame-format (CE1 interface)
Use frame-format to set the framing format for a CE1 interface.
Use undo frame-format to restore the default.
frame-format { crc4 | no-crc4 }
undo frame-format
The framing format on a CE1 interface is no-CRC4.
CE1 interface view
crc4: Sets the framing format to CRC4.
no-crc4: Sets the framing format to no-CRC4.
A CE1 interface in CE1 mode supports both CRC4 and no-CRC4 framing formats. Only CRC4 supports four-bit CRC on physical frames.
# Set the framing format to CRC4 on E1 2/3/0.
[Sysname-E1 2/3/0] frame-format crc4
idle-code (CE1 interface)
Use idle-code to set the line idle code on a CE1 interface.
Idle-code { 7e | ff }
undo idle-code
The line idle code on a CE1 interface is 7e.
CE1 interface view
The line idle code is sent in timeslots that are not bundled into logical channels.
# Set the line idle code to 7e on E1 2/3/0.
[Sysname-E1 2/3/0] idle-code 7e
itf (CE1 interface)
Use itf to set the type and number of interframe filling tags on a CE1 interface.
itf { number number | type { 7e | ff } }
undo itf { number | type }
The interframe filling tag is 7e and the number of interframe filling tags is 4 on CE1 interfaces. The number of interframe filling tags is fixed at 0 for interfaces on MIC-X-ET16 interface modules.
CE1 interface view
type: Specifies the interframe filling tag type.
7e: Sets the interframe filling tag type to 7e (hexadecimal).
ff: Sets the interframe filling tag type to ff (hexadecimal).
Interframe filling tags are sent when no service data is sent on the timeslots that are bundled into logical channels on the CE1 interface.
If the ff interframe filling tag is used on a CE1 interface in E1 mode, consecutive ones sent when the line is idle might trigger AIS alarms. To prevent false AIS alarms, use the undo detect-ais command to disable AIS detection.
# Set the type of interframe filling tag to ff on E1 2/3/0.
[Sysname-E1 2/3/0] itf type ff
# Set the number of interframe filling tags to 5 on E1 2/3/0.
[Sysname-E1 2/3/0] itf number 5
loopback (CE1 interface)
Use loopback to enable loopback and set the loopback mode on an interface.
Use undo loopback to disable loopback on an interface.
loopback { local | payload | remote }
undo loopback
Loopback is disabled on a CE1 interface.
CE1 interface view
local: Sets the interface to operate in local loopback mode.
payload: Sets the interface to operate in external payload loopback mode.
remote: Sets the interface to operate in external loopback mode.
You can bundle timeslots on the CE1 interface to form a serial interface and encapsulate it with PPP. After you enable loopback on this serial interface, it is normal that the state of the link layer protocol is reported as down.
# Set E1 2/3/0 to operate in internal loopback mode.
[Sysname-E1 2/3/0] loopback local
Use reset counters controller e1 to clear CE1 interface statistics.
reset counters controller e1 [ interface-number ]
interface-number: Specifies a CE1 interface by its number. If you do not specify this argument, the command clears statistics for all CE1 interfaces.
The reset counters interface command clears statistics for all interfaces.
To display CE1 interface statistics, use the display controller e1 command.
# Clear statistics for CE1 interface E1 2/3/0.
<Sysname> reset counters controller e1 2/3/0
using (CE1 interface)
Use using to set the operating mode of a CE1 interface.
Use undo using to restore the default.
using { ce1 | e1 }
undo using
A CE1 interface operates in channelized mode.
CE1 interface view
ce1: Sets the interface to operate in channelized mode.
e1: Sets the interface to operate in E1 mode.
A CE1 interface can operate in channelized or unchannelized mode.
· Channelized modes include CE1 mode. In CE1 mode, the CE1 interface is physically divided into 32 timeslots numbered 0 through 31. Timeslot 0 is used for FSC.
· Unchannelized modes include CEM mode and E1 mode.
¡ For a CE1 interface in E1 mode, the system automatically creates a 2.048 Mbps serial interface. The interface name uses the serial interface-number:0 format. The interface-number argument specifies the CE1 interface number. This interface has the same logical features as a standard synchronous serial interface.
# Set E1 2/3/0 to operate in E1 mode.
Basic CT1 interface commands
alarm-detect
alarm-detect rai
CT1 interface view
This command is applicable when the framing format used on the interface is ESF.
# Enable RAI detection on T1 2/4/0.
[Sysname] controller t1 2/4/0
[Sysname-T1 2/4/0] alarm detect rai
alarm-threshold
Use alarm-threshold to set LOS, AIS, or LFA alarm thresholds on a CT1 interface.
Use undo alarm-threshold to restore the default.
alarm-threshold { ais { level-1 | level-2 } | lfa { level-1 | level-2 | level-3 | level-4 } | los { pulse-detection | pulse-recovery } value }
undo alarm-threshold { ais | lfa | los { pulse-detection | pulse-recovery } }
For AIS and LFA, the alarm threshold is level-1.
For LOS, the pulse-detection threshold is 176, and pulse-recovery threshold is 22. A LOS alarm is generated if the number of pulses detected within 176 pulse intervals is less than 22.
CT1 interface view
ais: Specifies an alarm indication signal (AIS) alarm.
· level-1: Specifies the condition when the number of zeros in the bit stream of an SF or ESF frame is less than or equal to 2.
· level-2: Specifies one of the following conditions:
¡ In an SF frame, the number of zeros is less than or equal to 3 in the bit stream.
¡ In an ESP frame, the number of zeros is less than or equal to 5 in the bit stream.
lfa: Specifies a loss of frame alignment (LFA) alarm.
· level-1: Specifies the condition when two of four frame alignment bits are lost.
· level-2: Specifies the condition when two of five frame alignment bits are lost.
· level-3: Specifies the condition when two of six frame alignment bits are lost.
· level-4: Specifies the condition when errors are detected in four consecutive ESF frames. This keyword is available only for ESF frames.
los: Specifies a loss of signal (LOS) alarm.
· pulse-detection: Specifies the pulse detection duration threshold of the LOS alarm, in units of pulse intervals.
· pulse-recovery: Specifies the pulse threshold of the LOS alarm.
value: Specifies the value of the pulse-detection threshold or pulse-recovery threshold.
· For the pulse-detection threshold, this argument is in the range of 16 to 4096.
· For the pulse-recovery threshold, this argument is in the range of 1 to 256.
If the number of the pulses detected during the total length of the specified pulse detection intervals is smaller than the pulse-recovery threshold, a LOS alarm occurs.
# Set the number of detection intervals to 300 for the pulse detection duration threshold.
[Sysname-T1 2/4/0] alarm-threshold los pulse-detection 300
bert (CT1 interface)
Use bert to start a bit error rate test (BERT) on an interface.
Use undo bert to stop the BERT test running on an interface.
bert pattern { 2^20 | 2^15 } time minutes [ unframed ]
undo bert
No BERT test is performed on an interface.
CT1 interface view
pattern: Sets a BERT pattern.
· 2^15: Specifies the pattern length (in bits) as two to the fifteenth power.
· 2^20: Specifies the pattern length (in bits) as two to the twentieth power.
time minutes: Sets the duration (in minutes) of a BERT test. The minutes argument is in the range of 1 to 1440.
unframed: Sets the test pattern to cover the overhead bits of the frame.
The CT1 interface supports only the 2^15 and 2^20 BERT patterns defined in ITU O.151, ITU O.153, and ANSI T1.403-1999.
To perform a BERT test, the local end sends out a pattern. The pattern is looped over on the line and sent back to the local end. The local end examines the received pattern for bit error rate to help determine the line condition. You must configure loopback to allow the transmitted pattern to loop back from a point on the line. For example, enable far-end loopback on the remote interface.
To display the state and result of the BERT test, use the display controller t1 command.
# Run a 10-minute 2^20 BERT test on T1 2/4/0.
[Sysname-T1 2/4/0] bert pattern 2^20 time 10
cable (CT1 interface)
Use cable to set the cable attenuation and length on a CT1 interface.
cable { long { 0db | -7.5db | -15db | -22.5db } | short { 133ft | 266ft | 399ft | 533ft | 655ft } }
undo cable
The cable length is long 0db on a CT1 interface.
CT1 interface view
long: Matches 199.6-meter (655-feet) and longer cable length. The options for this parameter include 0db, -7.5db, -15db, and -22.5db. The attenuation parameter is selected depending on the signal quality received at the receiving end. No external CSU is needed.
short: Matches a cable length shorter than 199.6 meters (655 feet). The options for this parameter include 133ft, 266ft, 399ft, 533ft, and 655ft. The length argument is selected depending on the actual transmission distance.
You can use this command to adapt signal waveform to different transmission conditions such as the quality of the signal received by the receiver. If the signal quality is good, you can use the default setting. The CT1 interface does not need an external CSU device.
# Set the cable length to 40.5 meters (133 feet) on CT1 interface T1 2/4/0.
[Sysname-T1 2/4/0] cable short 133ft
channel-set (CT1 interface)
Use channel-set to bundle timeslots on a CT1 interface into a channel set.
Use undo channel-set to remove a channel set.
channel-set set-number timeslot-list list [ speed { 56k | 64k } ]
No channel sets exist on a CT1 interface.
CT1/PRI interface view
set-number: Number of the channel set for the timeslot bundle. The value range is 0 to 23.
timeslot-list list: Specifies a comma-separated list of timeslot items. An item can be an individual timeslot or a timeslot range. Use a hyphen (-) to separate the start and end timeslot numbers of a range. The value range for the timeslot number is 1 to 24.
speed { 56k | 64k }: Speed of the timeslot bundle (the channel set) in kbps. If 56k is selected, the timeslots are bundled into n × 56 kbps bundles. If 64k (the default) is selected, the timeslots are bundled into n × 64 kbps bundles.
A CT1 interface is divided into 24 timeslots numbered 1 through 24. In actual applications, all the timeslots can be bundled into multiple channel sets. For each channel set, the system automatically creates a serial interface that has the same logical features as a standard synchronous serial interface.
The serial interface name uses the serial interface-number:set-number format. The interface-number argument specifies the CT1 interface number. The set-number argument specifies the channel set number.
# Bundle timeslots 1, 2, 5, 10 through 15, and 18 into channel set 0 on T1 2/4/0.
[Sysname-T1 2/4/0] channel-set 0 timeslot-list 1,2,5,10-15,18
clock (CT1 interface)
Use clock to set the clock mode of a CT1 interface.
undo clock
The clock mode of a CT1 interface is slave.
CT1 interface view
When the clock mode of a CT1 interface is master, it uses the internal clock source. When the clock mode of a CT1 interface is slave, it uses the line clock source.
Set the clock mode for a CT1 interface as follows:
· When the CT1 interface is operating in DCE mode, set its clock mode to master.
· When two CT1 interfaces on two routers are directly connected, configure the two ends with different clock modes.
· When the CT1 interface on a router is connected to a switch, the CT1 interface on the router operates as a DTE. The switch operates as a DCE. Set the clock mode of the CT1 interface on the router to slave to accept the clock provided by the switch.
# Set the clock mode to master on T1 2/4/0.
[Sysname-T1 2/4/0] clock master
code (CT1 interface)
Use code to set the line code format for a CT1 interface.
code { ami | b8zs }
undo code
The line code format is B8ZS for the CT1 interface.
CT1 interface view
ami: Specifies the AMI line code format.
b8zs: Specifies the bipolar 8-zero substitution (B8ZS) line code format.
A CT1 interface must use the same line code format as its remote end.
# Set the line code format to AMI for T1 2/4/0.
[Sysname-T1 2/4/0] code ami
data-coding
controller t1
Use controller t1 to enter CT1 interface view.
controller t1 interface-number
interface-number: Specifies a CT1 interface by its number.
# Enter the view of T1 2/4/0.
[Sysname-T1 2/4/0]
data-coding (CT1 interface)
Use data-coding to enable user data inversion on a CT1 interface.
undo data-coding
Data inversion is disabled on a CT1 interface.
CT1 interface view
When AMI encoding is used on a T1 interface, data inversion eliminates the presence of multiple consecutive zeros.
The data inversion setting must be the same on the CT1 interfaces at two ends of a T1 line.
# Enable user data inversion on T1 2/4/0.
[Sysname-T1 2/4/0] data-coding inverted
Use display controller t1 to display information about CT1 interfaces.
display controller [ t1 [ interface-number ] ]
t1 [ interface-number ]: Specifies a CT1 interface by its number. If you do not specify the t1 keyword, the command displays information about all CT1 interfaces, CPOS interfaces, CE3 interfaces, CE1 interfaces, and CT3 interfaces. If you specify the t1 keyword without specifying an interface, the command displays information about all CT1 interfaces.
# Display information about T1 2/4/0.
<Sysname> display controller t1 2/4/0
T1 2/4/0
Current state: UP
Description: T1 2/2/2/1 Interface
Current system time:2017-11-11 16:11:54
Last time when physical state changed to up:2017-11-11 16:04:52
Last time when physical state changed to down:2017-11-11 16:04:49
Work mode: T1 framed, Cable type: 100 Ohm balanced
Frame-format: esf, fdl: none, Line code: b8zs
Source clock: slave, Data-coding: normal
Idle code: ff, Itf type: ff, Itf number: 2
Loop back: not set
Alarm State:
Pulse density violation detected
SendLoopCode History:
Inband-llb-up: 0 times, Inband-llb-down: 0 times
Fdl-ansi-llb-up: 0 times, Fdl-ansi-llb-down: 0 times
Fdl-ansi-plb-up: 0 times, Fdl-ansi-plb-down: 0 times
Fdl-att-plb-up: 0 times, Fdl-att-plb-down: 0 times
BERT state:(stopped, not completed)
Test pattern: 2^15, Status: Not Sync, Sync Detected: 0
Time: 0 minutes, Time past: 0 minutes
Bit Errors (since test started): 0 bits
Bits Received (since test started): 0 Kbits
Bit Errors (since latest sync): 0 bits
Bits Received (since latest sync): 0 Kbits
Data in current interval (285 seconds elapsed):
Line Code Violations: 0, Path Code Violations: 0
Ais Alarm: 0 seconds, Los Alarm: 286 seconds
Slip: 7 seconds, Fr Loss: 286 seconds
Line Err: 0 seconds, Degraded: 0 minutes
Errored: 0 seconds, Bursty Err: 0 seconds
Severely Err: 0 seconds, Unavail: 286 seconds
Data in Interval 1:
Ais Alarm: 0 seconds, Los Alarm Secs: 901 seconds
Slip: 22 seconds, Fr Loss: 901 seconds
Severely Err: 0 seconds, Unavail: 901 seconds
Data in Interval 2:
Ais Alarm: 0 seconds, Los Alarm: 900 seconds
Slip: 23 seconds, Fr Loss: 900 seconds
Severely Err: 0 seconds, Unavail: 900 seconds
Total Data (last 2 15 minute intervals):
Ais Alarm: 0 seconds, Los Alarm: 2087 seconds
Slip: 52 seconds, Fr Loss: 2087 seconds
Severely Err: 0 seconds, Unavail: 2087 seconds
Table 5 Command output
Current state |
Basic Configuration |
Basic configurations of the interface. |
Work mode |
Operating mode of the interface. |
Cable type |
Frame-format |
Frame format configured on the interface: ESF or SF. |
fdl |
FDL format: ANSI, ATT, or none. |
Line code |
Line code: AMI or B8ZS. |
Source clock |
Data-coding |
Normal or inverted. |
Idle code |
Itf type |
Type of interframe filling tag: 7e or ff. |
Itf number |
Number of interframe filling tags. |
Loop back |
Loopback setting on the interface: local, payload, remote, or not set. |
Receiver alarm state is Loss-of-Signal |
Type of received alarm: none, LOS, LOF, RAI, or AIS. |
Transmitter is sending remote alarm. |
Type of transmitted alarm: RAI, or none. |
Pulse density violation detected |
The detected pulse density is incompliant with the specification. |
SendLoopCode History: Inband-llb-up: 0 times, Inband-llb-down: 0 times Fdl-ansi-llb-up: 0 times, Fdl-ansi-llb-down: 0 times Fdl-ansi-plb-up: 0 times, Fdl-ansi-plb-down: 0 times Fdl-att-plb-up: 0 times, Fdl-att-plb-down: 0 times |
History of loopback code sending to the peer end, including the number of transmissions for each type of code, and the type of the last sent code. |
BERT state |
BERT test state: · completed—The test has been completed. · stopped—The test has been manually terminated. · running—The test is running. |
Test pattern |
Test pattern in use (2^20 or 2^15). |
Status |
Whether synchronization is being performed. |
¡ Sync Detected |
Number of detected synchronizations. |
Time |
Duration of the BERT test. |
Time past |
Time that has elapsed. |
Bit Errors (since test started) |
Number of bit errors received since the start of the BERT test. |
Bits Received (since test started) |
Number of bits received since the start of the BERT test. |
Bit Errors (since latest sync) |
Number of bit errors received since last synchronization. |
Bits Received (since latest sync) |
Number of bits received since last synchronization. |
Historical statistics for the interface. |
The most recent time that the reset counters controller t1 command was executed. This field displays Never if this command has not been executed since the device startup. |
Data in current interval (285 seconds elapsed): Line Code Violations: 0, Path Code Violations: 0 Ais Alarm: 0 seconds, Los Alarm: 286 seconds Slip: 7 seconds, Fr Loss: 286 seconds Line Err: 0 seconds, Degraded: 0 minutes Errored: 0 seconds, Bursty Err: 0 seconds Severely Err: 0 seconds, Unavail: 286 seconds |
Statistics in the current interval. The statistical items, such as AIS alarm, LOS signal, and LFA, are provided according to the T1 specifications for the physical layer. For more information, see ANSI T1.403 and AT&T TR 54016. |
Data in Interval 1: Line Code Violations: 0, Path Code Violations: 0 Ais Alarm: 0 seconds, Los Alarm Secs: 901 seconds Slip: 22 seconds, Fr Loss: 901 seconds Line Err: 0 seconds, Degraded: 0 minutes Errored: 0 seconds, Bursty Err: 0 seconds Severely Err: 0 seconds, Unavail: 901 seconds |
Statistics spanning the first interval. The statistical items are the same as those provided by the statistics spanning the current interval. |
Data in Interval 2: Line Code Violations: 0, Path Code Violations: 0 Ais Alarm: 0 seconds, Los Alarm: 900 seconds Slip: 23 seconds, Fr Loss: 900 seconds Line Err: 0 seconds, Degraded: 0 minutes Errored: 0 seconds, Bursty Err: 0 seconds Severely Err: 0 seconds, Unavail: 900 seconds |
Statistics spanning the second interval. The statistical items are the same as those provided by the statistics spanning the current interval. |
Total Data (last 2 15 minute intervals): Line Code Violations: 0, Path Code Violations: 0 Ais Alarm: 0 seconds, Los Alarm: 2087 seconds Slip: 52 seconds, Fr Loss: 2087 seconds Line Err: 0 seconds, Degraded: 0 minutes Errored: 0 seconds, Bursty Err: 0 seconds Severely Err: 0 seconds, Unavail: 2087 seconds |
Statistics spanning the last two intervals. The statistical items are the same as those provided by the statistics spanning the current interval. |
fdl
Use fdl to set the behavior of the CT1 interface on the FDL in ESF framing.
Use undo fdl to restore the default.
fdl { ansi | att | both | none }
undo fdl
FDL in ESF framing is disabled (none).
CT1 interface view
ansi: Specifies ANSI T1.403 for facilities data link (FDL).
att: Specifies AT&T TR 54016 for FDL.
both: Specifies both ANSI T1.403 and AT&T TR 54016 for FDL.
none: Disables FDL.
Facility Data Link (FDL) is an embedded 4 kbps overhead channel within the ESF format for transmitting alarm information, performance statistics, or loopback code. FDL uses ANSI T1.403 and ATT TR 54016. You can change the setting depending on the setting at the far end.
# Implement AT&T FDL on T1 2/4/0.
[Sysname-T1 2/4/0] fdl att
frame-format (CT1 interface)
Use frame-format to set the framing format on a CT1 interface.
frame-format { esf | sf }
undo frame-format
The framing format on a CT1 interface is esf.
CT1 interface view
esf: Sets the framing format to extended super frame (ESF).
sf: Sets the framing format to super frame (SF).
CT1 interfaces support the following framing formats:
· ESF format—Allows you to test the system without affecting the ongoing service.
· SF format—Provides more significant bits for user data transmission because multiple frames can share the same FSC and signaling information.
# Set the framing format to SF for T1 2/4/0.
[Sysname-T1 2/4/0] frame-format sf
idle-code (CT1 interface)
Use idle-code to set the line idle code on a CT1 interface.
undo idle-code
The line idle code on a CT1 interface is 7e.
CT1 interface view
The line idle code is sent in the timeslots that are not bundled into logical channels on the interface.
# Set the line idle code to 7e on T1 2/4/0.
[Sysname-T1 2/4/0] idlecode 7e
itf (CT1 interface)
Use itf to set the type and the number of interframe filling tags on a CT1 interface.
On a CT1 interface, the interframe filling tag is 7e, and the number of interframe filling tags is 4.
CT1 interface view
Interframe filling tags are sent when no service data is sent on the timeslots that are bundled into logical channels on a CT1 interface.
# Set the type of interframe filling tag to ff on T1 2/4/0.
[Sysname-T1 2/4/0] itf type ff
# Set the number of interframe filling tags to 5 on T1 2/4/0.
[Sysname-T1 2/4/0] itf number 5
loopback (CT1 interface)
Use loopback to enable a type of loopback on a CT1 interface.
Use undo loopback to disable loopback on a CT1 interface.
undo loopback
Loopback is disabled on a CT1 interface.
CT1 interface view
local: Enables local loopback.
payload: Enables external payload loopback.
remote: Enables remote loopback.
You can bundle timeslots on a CT1 interface to form a serial interface and encapsulate it with PPP. After you enable loopback on this serial interface, it is normal that the state of the link layer protocol is reported as down.
# Enable local loopback on T1 2/4/0.
[Sysname-T1 2/4/0] loopback local
Use reset counters controller t1 to clear CT1 interface statistics.
reset counters controller t1 [ interface-number ]
interface-number: Specifies a CT1 interface by its number. If you do not specify this argument, the command clears statistics for all CT1 interfaces.
To display CT1 interface statistics, use the display controller t1 command.
# Clear statistics for the CT1 interface T1 2/4/0.
<Sysname> reset counters controller t1 2/4/0
sendloopcode
Use sendloopcode to send remote loopback control code.
sendloopcode { fdl-ansi-llb-down | fdl-ansi-llb-up | fdl-ansi-plb-down | fdl-ansi-plb-up | fdl-att-plb-down | fdl-att-plb-up | inband-llb-down | inband-llb-up }
No remote loopback control code is sent.
CT1 interface view
fdl-ansi-llb-down: Sends ANSI-compliant LLB deactivation request code in the FDL to remove remote loopback.
fdl-ansi-llb-up: Sends ANSI-compliant line loopback (LLB) activation request code in the FDL to start remote loopback.
fdl-ansi-plb-down: Sends ANSI-compliant PLB deactivation request code in the FDL to remove remote loopback.
fdl-ansi-plb-up: Sends ANSI-compliant payload loopback (PLB) activation request code in the FDL to start remote loopback.
fdl-att-plb-down: Sends AT&T-complaint PLB deactivation request code in the FDL to remove remote loopback.
fdl-att-plb-up: Sends AT&T-complaint PLB activation request code in the FDL to start remote loopback.
inband-llb-down: Sends in-band LLB deactivation request code in compliance with the ANSI or AT&T implementation to remove remote loopback.
inband-llb-up: Sends in-band line loopback (LLB) activation request code compliant with the ANSI and AT&T implementation to start remote loopback.
You can configure loopback on the remote CT1 interface by sending loopback request code. Before you configure this command, make sure the remote CT1 interface can automatically receive the loopback control code.
In LLB mode, all 193 bits (one synchronization bit and 192 effective payload bits) in a T1 PCM frame are looped back. In PLB mode, only 192 effective payload bits are looped back.
The format of loopback code is compliant with ANSI T1.403 or AT&T TR 54016.
In SF framing, LLB code is sent using the effective bandwidth. In ESF framing, both LLB code and PLB code are sent and received in the FDL.
Use this command in conjunction with the far-end T1 device. The far-end device must be able to set loopback mode depending on the detected loopback code. The sending of remote loopback control code lasts 5 seconds without affecting the operation of other interfaces.
# Send in-band LLB activation request code.
[Sysname-T1 2/4/0] sendloopcode inband-llb-up
E1-F interface commands
clock-change auto
Use clock-change auto to enable automatic clock mode switchover on an E1-F interface.
Use undo clock-change auto to disable the automatic clock mode switchover on an E1-F interface.
clock-change auto
Automatic clock mode switchover is disabled on an E1-F interface.
E1-F interface view
After the alarm is cleared, the interface automatically switches back to the slave clock mode.
# Enable automatic clock mode switchover for the E1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] clock-change auto
fe1 clock
crc
Use crc to configure CRC mode for an E1-F interface.
undo crc
The CRC mode for an E1-F interface is 16-bit CRC.
E1-F interface view
none: Disables CRC.
# Specify 32-bit CRC on the E1-F interface Serial 2/1/0.
display fe1
Use display fe1 to display information about E1-F interfaces.
display fe1 [ serial interface-number ]
serial interface-number: Specifies an E1-F interface by its number. If you do not specify an interface, this command displays information about all E1-F interfaces.
If the specified interface is a common serial interface rather than an E1-F interface, the system displays a prompt.
# Display information about the E1-F interface Serial 2/1/0.
<Sysname> display fe1 serial 2/1/0
Serial2/1/0
Work mode: E1 framed, Cable type: 75 Ohm unbalanced
Frame format: no-crc4
Line code: hdb3, Source clock: slave
Idle code: 7e, Itf type: 7e, Itf number: 4
Loopback: not set
Alarm State:
Receiver alarm state is None.
Data in current interval (19349 seconds elapsed):
Loss Frame Alignment: 129 seconds, Framing Error: 0 seconds
CRC Error: 0 seconds, Alarm Indication: 0 seconds
Loss-of-signals: 129 seconds, Code Violations: 0 seconds
Slip: 0 seconds, E-Bit Error: 0 seconds
Table 6 Command output
Cable type |
Cable type of the interface (75 ohm unbalanced or 120 ohm balanced). |
Frame-format |
Framing format: CRC4 or no-CRC4. |
Line Code |
Line code format: AMI or HDB3. |
Source clock |
Idle code |
Itf type |
Itf number |
Loopback |
Whether loopback is configured on the interface. |
Data in current interval (19349 seconds elapsed): Loss Frame Alignment: 129 seconds, Framing Error: 0 seconds CRC Error: 0 seconds, Alarm Indication: 0 seconds Loss-of-signals: 129 seconds, Code Violations: 0 seconds Slip: 0 seconds, E-Bit Error: 0 seconds |
Time duration that each error lasts within the interval. The errors include frame misalignment, frame errors, alarms, loss of signals, code violation, and frame slipping. |
fe1 alarm-detect
Use fe1 alarm-detect to enable RAI detection on an E1-F interface.
Use undo fe1 alarm-detect to disable RAI detection on an E1-F interface.
fe1 alarm-detect rai
undo fe1 alarm-detect rai
RAI detection is enabled on an E1-F interface.
E1-F interface view
This command is applicable when the interface operates in framed mode.
# Disable RAI detection on Serial 2/1/0.
[Sysname-Serial2/1/0] undo fe1 alarm-detect rai
fe1 unframed
fe1 cable
Use fe1 cable to set the cable length for an E1-F interface.
Use undo fe1 cable to restore the default.
fe1 cable { long | short }
undo fe1 cable
E1-F interface view
long: Supports long cables.
short: Supports short cables.
# Set the cable length type to short on the E1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] fe1 cable short
fe1 clock
Use fe1 clock to set the clock mode of an E1-F interface.
Use undo fe1 clock to restore the default.
fe1 clock { master | slave }
undo fe1 clock
The clock mode for an E1-F interface is slave.
E1-F interface view
When the clock mode of an E1-F interface is master, it uses the internal clock source. When the clock mode of an E1-F interface is slave, it uses the line clock source.
Set the clock mode for an E1-F interface as follows:
· When the E1-F interface is operating in DCE mode, set its clock mode to master.
· When the E1-F interface is operating in DTE mode, set its clock mode to slave.
# Set the clock mode to master for the E1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] fe1 clock master
clock-change auto
fe1 code
Use fe1 code to set the line code format for an E1-F interface.
Use undo fe1 code to restore the default.
fe1 code { ami | hdb3 }
undo fe1 code
The line code format is HDB3 for the E1-F interface.
E1-F interface view
hdb3: Specifies the HDB3 line code format.
An E1-F interface must use the same line code format as its remote end. For the interface to operate correctly, configure the fe1 data-coding inverted command if the AMI format is used.
# Set the line code format to AMI for the E1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] fe1 code ami
fe1 data-coding
fe1 data-coding
Use fe1 data-coding to enable or disable user data inversion for an E1-F interface.
Use undo fe1 data-coding to restore the default.
fe1 data-coding { inverted | normal }
User data inversion is disabled for an E1-F interface.
E1-F interface view
When AMI encoding is used on an E1-F interface, data inversion eliminates the presence of multiple consecutive zeros.
The data inversion setting must be the same at the two ends of an E1-F line.
# Enable user data inversion on the E1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] fe1 data-coding inverted
fe1 code
fe1 detect-ais
Use fe1 detect-ais to enable AIS detection on an E1-F interface.
Use undo fe1 detect-ais to disable AIS detection on an E1-F interface.
fe1 detect-ais
undo fe1 detect-ais
AIS detection is enabled on an E1-F interface.
E1-F interface view
This command is available when the E1-F interface is operating in unframed mode.
# Enable AIS detection on the E1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] fe1 detect-ais
fe1 unframed
fe1 frame-format
Use fe1 frame-format to set the framing format for an E1-F interface.
Use undo fe1 frame-format to restore the default.
fe1 frame-format { crc4 | no-crc4 }
The framing format of an E1-F interface is no-CRC4.
E1-F interface view
crc4: Sets framing format to CRC4.
no-crc4: Sets framing format to no-CRC4.
An E1-F interface in framed mode supports both CRC4 and no-CRC4 framing formats. Only CRC4 supports four-bit CRC on physical frames.
# Set the framing format to crc4 for the E1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] fe1 frame-format crc4
fe1 unframed
fe1 idle-code
Use fe1 idle-code to set the line idle code on an E1-F interface.
Use undo fe1 idle-code to restore the default.
fe1 idle-code { 7e | ff }
undo fe1 idle-code
The line idle code on an E1-F interface is 7e.
E1-F interface view
# Set the line idle code to 7e on the E1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] fe1 idlecode 7e
fe1 itf
Use fe1 itf to set the type and number of interframe filling tags on an E1-F interface.
Use undo fe1 itf to restore the default.
fe1 itf { number number | type { 7e | ff } }
undo fe1 itf { number | type }
On an E1-F interface, the interframe filling tag is 7e, and the number of interframe filling tags is 4.
E1-F interface view
type: Specifies the type of interframe filling tag type.
The bundled timeslots on the E1-F interface send interframe filling tags when no service data is present.
# Set the type of interframe filling tag to ff on the E1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] fe1 itf type ff
# Set the number of interframe filling tags to 5 on the E1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] fe1 itf number 5
fe1 loopback
Use fe1 loopback to enable a type of loopback on an E1-F interface.
Use undo fe1 loopback to disable loopback on an E1-F interface.
fe1 loopback { local | payload | remote }
undo fe1 loopback
Loopback is disabled on an E1-F interface.
E1-F interface view
local: Enables internal loopback.
remote: Enables external loopback.
The three loopback modes cannot be used simultaneously on an E1-F interface.
# Enables internal loopback on the E1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] fe1 loopback local
fe1 timeslot-list
Use fe1 timeslot-list to bundle timeslots on an E1-F interface.
Use undo fe1 timeslot-list to restore the default.
fe1 timeslot-list list
All the timeslots on an E1-F interface are bundled to form a 1984 kbps interface.
E1-F interface view
Timeslot bundling results in interface rate change. For example, if you bundle timeslots 1 through 10, the interface rate is 10 × 64 kbps.
You can create only one channel set on an E1-F interface. For the channel set, the system creates one synchronous serial interface. The number of the serial interface is identical to the number of the E1-F interface.
On a CE1 interface, you can create multiple channel sets. For each set, the system automatically creates a synchronous serial interface.
Timeslot 0 on E1-F interfaces is used for transmitting synchronization information. A bundling operation only involves timeslots 1 through 31.
When the E1-F interface is operating in unframed mode, the fe1 timeslot-list command is invalid.
# Bundle timeslots 1, 2, 5, 10 through 15, and 18 on the E1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] fe1 timeslot-list 1,2,5,10-15,18
fe1 unframed
fe1 unframed
Use fe1 unframed to configure an E1-F interface to operate in unframed mode.
Use undo fe1 unframed to restore the default.
fe1 unframed
undo fe1 unframed
An E1-F interface operates in framed mode.
E1-F interface view
In unframed mode, an E1-F interface is a 2048 kbps interface without timeslot division and has the same logical features as a standard synchronous serial interface.
In framed mode, an E1-F interface is physically divided into 32 timeslots numbered 0 through 31, with timeslot 0 for synchronization.
# Set the E1-F interface Serial 2/1/0 to operate in unframed mode.
[Sysname-Serial2/1/0] fe1 unframed
fe1 timeslot-list
T1-F interface commands
crc
Use crc to configure the CRC mode on a T1-F interface.
Use undo crc to restore the default.
crc { 16 | 32 | none }
undo crc
The CRC mode is 16-bit CRC.
T1-F interface view
16: Specifies 16 bit CRC.
32: Specifies 32 bit CRC.
none: Disables CRC.
# Specify 32-bit CRC on the T1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] crc 32
display ft1
Use display ft1 to display information about a T1-F interface.
display ft1 [ serial interface-number ]
serial interface-number: Specifies a T1-F interface by its number. If you do not specify an interface, this command displays information about all T1-F interfaces.
If the specified interface is a common serial interface rather than a T1-F interface, the system displays a prompt.
# Display information about the T1-F interface Serial 2/1/0.
<Sysname> display ft1 serial 2/1/0
Serial2/1/0
Loopback: not set
Alarm State:
Pulse density violation detected.
Data in Interval 1:
Ais Alarm: 0 seconds, Los Alarm: 901 seconds
Data in Interval 2:
Table 7 Command output
Basic configurations for the interface. |
Work mode |
T1 interface operating mode: T1 or CT1. |
Cable type |
Cable type of the interface, 100 ohm balanced in this sample output. |
Frame-format |
fdl |
Line code |
AMI or B8ZS. |
Source clock |
Data-coding |
Idle code |
Itf type |
Type of inter-frame filling tags: 7e or ff. |
Itf number |
Number of inter-frame filling tags. |
Loop back |
Transmitter is sending remote alarm |
Type of transmitted alarm: RAI or none. |
History of loopback code sending to the far-end, including the number of transmissions for each type of code, and the type of the last sent code. (For more information, see "ft1 sendloopcode.") |
BERT state |
Test pattern |
Test pattern in use: 2^15 or 2^20. |
Status |
Whether the interface is being synchronized: · Sync—The interface is being synchronized. · Not Sync—The interface is not being synchronized. |
Sync Detected |
Time |
Time past |
Number of bit errors received since the last synchronization. |
Number of bits received since the last synchronization. |
Historical Statistics: |
Last link flapping |
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup. |
Last clearing of counters |
The most recent time that the reset counters interface serial command was executed. This field displays Never if this command has not been executed since the device startup. |
Statistics spanning the current interval. The statistical items, such as AIS alarm, LOS signal, and LFA, are provided according to the T1 specifications for the physical layer. For more information, see ANSI T1.403 and AT&T TR 54016. |
Data in Interval 1: Line Code Violations: 0, Path Code Violations: 0 Ais Alarm: 0 seconds, Los Alarm: 901 seconds Slip: 22 seconds, Fr Loss: 901 seconds Line Err: 0 seconds, Degraded: 0 minutes Errored: 0 seconds, Bursty Err: 0 seconds Severely Err: 0 seconds, Unavail: 901 seconds |
ft1 alarm-detect
Use ft1 alarm-detect to enable RAI detection on an interface.
Use undo ft1 alarm-detect to disable RAI detection on an interface.
ft1 alarm-detect rai
undo ft1 alarm-detect rai
T1-F interface view
This command is applicable when the framing format on the interface is ESF.
[Sysname-Serial2/1/0] undo ft1 alarm-detect rai
ft1 frame-format
ft1 alarm-threshold
Use ft1 alarm-threshold to set LOS, AIS, or LFA alarm thresholds on a T1-F interface.
Use undo ft1 alarm-threshold to restore the default.
ft1 alarm-threshold { ais { level-1 | level-2 } | lfa { level-1 | level-2 | level-3 | level-4 } | los { pulse-detection | pulse-recovery } value }
undo ft1 alarm-threshold { ais | lfa | los { pulse-detection | pulse-recovery } }
For LOS, the value of pulse-detection is 176 and the value of pulse-recovery is 22. A LOS alarm is generated if the number of pulses detected within 176 pulse intervals is less than 22.
T1-F interface view
ais: Specifies an AIS alarm.
lfa: Specifies an LFA alarm.
los: Specifies a LOS alarm.
If the number of the pulses detected during the total length of the specified pulse detection intervals is smaller than the pulse-recovery threshold, a LOS alarm occurs. For example, if the two thresholds take their defaults, a LOS alarm is generated if the number of pulses detected within 176 pulse intervals is less than 22.
[Sysname-Serial2/1/0] ft1 alarm-threshold los pulse-detection 300
ft1 frame-format
ft1 bert
Use ft1 bert to start a BERT test on a T1-F interface.
Use undo ft1 bert to stop the BERT test running on a T1-F interface.
ft1 bert pattern { 2^20 | 2^15 } time minutes [ unframed ]
undo ft1 bert
No BERT test is performed on a T1-F interface.
T1-F interface view
The T1-F interface supports only the 2^15 and 2^20 BERT patterns defined in ITU O.151, ITU O.153, and ANSI T1.403-1999.
To display the state and result of a BERT test, use the display ft1 command.
# Run a 10-minute 2^20 BERT test on the T1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] ft1 bert pattern 2^20 time 10
display ft1
ft1 cable
Use ft1 cable to set the cable attenuation and length on a T1-F interface.
Use undo ft1 cable to restore the default.
ft1 cable { long decibel | short length }
undo ft1 cable
The cable attenuation length on a T1-F interface is long 0db.
T1-F interface view
long decibel: Matches 199.6-meter (655-feet) and longer cable length. The decibel argument can be 0db, -7.5db, -15db, or -22.5db, depending on the signal quality at the receiving end. No external CSU is required.
short length: Matches a cable length shorter than 199.6 meters (655 feet). The length argument can be 133ft, 266ft, 399ft, 533ft, or 655ft, depending on the actual transmission distance.
You can use this command to adapt the signal waveform to different transmission conditions such as the quality of the signal received by the receiver. If signal quality is good, use the default setting.
# Set the cable length to 133 feet (40.5 meters) on the T1-F interface Serial 2/1/0.
[Sysname] interface serial 2/1/0
[Sysname-Serial2/1/0] ft1 cable short 133ft
ft1 frame-format
ft1 clock
Use ft1 clock to set the clock mode of a T1-F interface.
Use undo ft1 clock to restore the default.
ft1 clock { master | slave }
undo ft1 clock
The clock mode of a T1-F interface is slave.
T1-F interface view
When the clock mode of a T1-F interface is master, it uses the internal clock source. When the clock mode of a T1-F interface is slave, it uses the line clock source.
Set the clock mode for a T1-F interface as follows:
· When the T1-F interface is operating in DCE mode, set its clock mode to master.
· When the T1-F interface is operating in DTE mode, set its clock mode to slave.
· When two T1-F interfaces on two routers are directly connected, configure the two ends with different clock modes.
· When the T1-F interface on a router is connected to a switch, the T1-F interface on the router operates as a DTE. The switch operates as a DCE. Set the clock mode to slave for the T1-F interface on the router to accept the clock provided by the switch.
# Set the clock mode to master on the T1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] ft1 clock master
ft1 code
Use ft1 code to set the line code format for a T1-F interface.
Use undo ft1 code to restore the default.
ft1 code { ami | b8zs }
undo ft1 code
The line code format is B8ZS for the T1-F interface.
T1-F interface view
b8zs: Specifies the B8ZS line code format.
A T1-F interface must use the same line code format as its remote end. For the interface to operate correctly, configure the ft1 data-coding inverted command if the AMI format is used.
# Set the line code format to AMI for the T1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] ft1 code ami
ft1 data-coding
ft1 data-coding
Use ft1 data-coding to enable or disable user data inversion for a T1-F interface.
Use undo ft1 data-coding to restore the default.
ft1 data-coding { inverted | normal }
Data inversion is disabled for a T1-F interface.
T1-F interface view
To prevent the string 7e in valid data from being used as paddings, HDLC inserts a zero after every five consecutive ones in the data stream. In data inversion, each bit one is inverted to bit zero, and each bit zero is inverted to bit one. After the inversion, at least a bit one is present in every eight consecutive bits.
When AMI encoding is used on a T1-F interface, data inversion eliminates the presence of multiple consecutive zeros.
At the two ends of a T1-F line, the data inversion settings must be the same.
# Enable user data inversion on the T1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] ft1 data-coding inverted
ft1 code
ft1 fdl
Use ft1 fdl to set the behavior of a T1-F interface on the FDL in ESF framing.
Use undo ft1 fdl to restore the default.
ft1 fdl { ansi | att | both | none }
undo ft1 fdl
FDL is disabled (none).
T1-F interface view
ansi: Specifies ANSI T1.403 for FDL.
none: Disables FDL.
FDL is an embedded 4 kbps overhead channel within the ESF format for transmitting performance statistics or loopback code.
# Set ANSI FDL on the T1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] ft1 fdl ansi
ft1 frame-format
ft1 frame-format
Use ft1 frame-format to set the framing format for a T1-F interface.
Use undo ft1 frame-format to restore the default.
ft1 frame-format { esf | sf }
The framing format on a T1-F interface is esf.
T1-F interface view
esf: Sets the framing format to ESF.
sf: Sets the framing format to SF.
T1-F interfaces support the following framing formats:
# Set the framing format to SF for the T1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] ft1 frame-format sf
ft1 fdl
ft1 idle-code
Use ft1 idle-code to set the line idle code on a T1-F interface.
Use undo ft1 idle-code to restore the default.
ft1 idle-code { 7e | ff }
undo ft1 idle-code
The line idle code on a T1-F interface is 7e.
T1-F interface view
7e: Sets the line idle code to 7e (hexadecimal).
ff: Sets the line idle code to ff (hexadecimal).
# Set the line idle code to 7e on the T1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] ft1 idlecode 7e
ft1 itf
Use ft1 itf to set the type and the number of interframe filling tags on a T1-F interface.
Use undo ft1 itf to restore the default.
ft1 itf { number number | type { 7e | ff } }
undo ft1 itf { number | type }
On a T1-F interface, the interframe filling tag is 7e, and the number of interframe filling tags is 4.
T1-F interface view
number number: Sets the number of interframe filling tags, in the range of 0 to 14. An interframe filling tag is one byte in length.
Interframe filling tags are sent when no service data is sent on the timeslots bundled into logical channels on a T1-F interface.
Do not use the ft1 itf type ff command if both the ft1 code ami command and the ft1 data-coding inverted command are configured. Otherwise, the T1-F interface will not operate correctly.
# Set the type of interframe filling tag to ff on the T1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] ft1 itf type ff
# Set the number of interframe filling tags to 5 on the T1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] ft1 itf number 5
ft1 code
ft1 data-coding
ft1 loopback
Use ft1 loopback to enable a type of loopback on a T1-F interface.
Use undo ft1 loopback to disable loopback on a T1-F interface.
ft1 loopback { local | payload | remote }
undo ft1 loopback
Loopback is disabled on a T1-F interface.
T1-F interface view
Loopback is intended for testing only. Disable the feature when the interface is operating correctly.
The three loopback modes cannot be used simultaneously on a T1-F interface.
# Enable local loopback on the T1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] ft1 loopback local
ft1 sendloopcode
Use ft1 sendloopcode to send remote loopback control code.
ft1 sendloopcode { fdl-ansi-llb-down | fdl-ansi-llb-up | fdl-ansi-plb-down | fdl-ansi-plb-up | fdl-att-plb-down | fdl-att-plb-up | inband-llb-down | inband-llb-up }
T1-F interface view
fdl-ansi-llb-down: Sends ANSI-compliant LLB deactivation request code in the FDL to remove the remote loopback.
fdl-ansi-plb-down: Sends ANSI-compliant PLB deactivation request code in the FDL to remove the remote loopback.
fdl-att-plb-down: Sends AT&T-complaint PLB deactivation request code in the FDL to remove the remote loopback.
fdl-att-plb-up: Sends AT&T-complaint PLB activation request code in the FDL to start the remote loopback.
inband-llb-down: Sends in-band LLB deactivation request code compliant with the ANSI or AT&T implementation to remove the remote loopback.
inband-llb-up: Sends in-band line loopback (LLB) activation request code compliant with the ANSI or AT&T implementation to start the remote loopback.
You can configure loopback on the remote T1-F interface by sending a loopback request code.
The format of the loopback code is compliant with ANSI T1.403 or AT&T TR 54016.
In SF framing, LLB code is sent using the effective bandwidth (timeslots 1 through 24). In ESF framing, both LLB code and PLB code are sent and received in the FDL in ESF frames.
You can use this command only when the remote T1-F interface can automatically detect loopback request code from the network.
[Sysname-Serial2/1/0] ft1 sendloopcode inband-llb-up
ft1 frame-format
ft1 timeslot-list
Use ft1 timeslot-list to bundle timeslots on a T1-F interface.
Use undo ft1 timeslot-list to restore the default.
ft1 timeslot-list list [ speed { 56k | 64k } ]
All the timeslots on the T1-F interface are bundled to form a 1536 kbps interface.
T1-F interface view
speed { 56k | 64k }: Time slot bundling speed in kbps. If 56k applies, timeslots are bundled into an n × 56 kbps bundle. If 64k (the default) applies, timeslots are bundled into an n × 64 kbps bundle.
Timeslot bundling results in interface rate change. For example, if you bundle timeslots 1 through 10, the interface rate is 10 × 64 kbps or 10 × 56 kbps.
You can create only one channel set on a T1-F interface. For the channel set, the system creates one synchronous serial interface. The number of the serial interface is identical to the number of the T1-F interface.
On a CT1 interface, you can create multiple channel sets. For each set, the system automatically creates a synchronous serial interface.
# Bundle timeslots 1, 2, 5, 10 through 15, and 18 on the T1-F interface Serial 2/1/0.
[Sysname-Serial2/1/0] ft1 timeslot-list 1,2,5,10-15,18
Use reset counters interface serial to clear serial interface statistics.
reset counters interface serial [ interface-number ]
serial [ interface-number ]: Specifies a serial interface by its number. If you do not specify the serial keyword, this command clears statistics for all interfaces. If you specify the serial keyword without specifying an interface, this command clears statistics for all serial interfaces.
Use this command to clear history statistics before you collect traffic statistics for a time period.
# Clear statistics for Serial 2/1/0.
<Sysname> reset counters interface serial 1/0
CT3 interface commands
alarm
Use alarm to enable a CT3 interface to detect/send alarm signals.
Use undo alarm to remove the alarm signal detection/sending setting.
alarm { detect | generate { ais | febe | idle | rai } }
undo alarm { detect | generate { ais | febe | idle | rai } }
Periodic alarm detection is enabled.
Alarm signal sending is disabled.
CT3 interface view
detect: Enables periodical alarm signal detection.
generate: Sends alarm signals for line state test.
· ais: Alarm indication signal.
· febe: Far end block error signal.
· idle: Idle signal.
· rai: Remote alarm indication signal.
At startup, periodical alarm signal detection is enabled on the CT3 interface. When the interface detects LOS, LOF, or AIS signals, it sends RAI signals to its peer.
The supported alarm signals (LOS, LOF, AIS, RAI, FEBE, and idle) are ANSI T1.107-1995 compliant.
You can configure the CT3 interface to send a type of alarm signal. To send another type of signal, you must first remove the previous setting by using the undo alarm command. If a RAI signal is present because an LOS, LOF, or AIS alarm is detected, you must first use the undo alarm detect command to remove the signal.
To display the real-time alarm state on the CT3 interface, use the display controller t3 command.
# Enable periodical alarm signal detection on CT3 interface T3 2/4/0.
[Sysname] controller t3 2/4/0
[Sysname-T3 2/4/0] alarm detect
# Enable CT3 interface T3 2/4/0 to send AIS alarm signals.
[Sysname-T3 2/4/0] alarm generate ais
cable
Use cable to configure the cable length on a CT3 interface.
Use undo cable to restore the default.
cable feet
undo cable
The cable length on a CT3 interface is 49 feet (14.9 meters).
CT3 interface view
feet: Cable length in the range of 0 to 450 feet (0 to 137.2 meters).
The cable length in this command refers to the distance between the router and the cable distribution rack.
# Set the cable length to 50 feet (15.24 meters) on T3 2/4/0.
[Sysname-T3 2/4/0] cable 50
clock
Use clock to set the clock mode of a CT3 interface.
Use undo clock to restore the default.
undo clock
The clock mode for a CT3 interface is slave.
CT3 interface view
master: Sets the clock mode to master.
slave: Sets the clock mode to slave.
When the clock mode of a CT3 interface is master, it uses the internal clock source. When the clock mode of a CT3 interface is slave, it uses the line clock source.
When connected to a transmission device, the CT3 interface must use the slave clock. The clock provided by the transmission device is more precise.
When two CT3 interfaces are directly connected, you must configure the two ends with different clock modes.
# Set the clock mode to master for T3 2/4/0.
[Sysname-T3 2/4/0] clock master
controller t3
Use controller t3 to enter CT3 interface view.
controller t3 interface-number
interface-number: Specifies a CT3 interface by its number.
# Enter the view of T3 2/4/0.
[Sysname-T3 2/4/0]
Use display controller t3 to display information about CT3 interfaces.
display controller [ t3 [ interface-number ] [ t1 line-number ] ]
t3 [ interface-number ]: Specifies a CT3 interface by its number. If you do not specify the t3 keyword, the command displays information about all CT3 interfaces, CPOS interfaces, CT1 interfaces, CE1 interfaces, and CE3 interfaces. If you specify the t3 keyword without specifying an interface, the command displays information about all CT3 interfaces.
t1 line-number: Specifies a T1 line by its number.
In addition to the state information about the CT3 interface, the command displays information about each T1 line on the CT3 interface if the interface is operating in CT3 mode.
# Display information about T3 2/4/0.
<Sysname> display controller t3 2/4/0
T3 2/4/0
Current state: UP
Description: T3 2/4/0 Interface
Current system time:2017-11-11 17:25:32
Last time when physical state changed to up:2017-11-11 17:25:26
Last time when physical state changed to down:2017-11-11 09:59:32
Basic Configuration:
Work mode: CT3, cable length: 49 feet
Frame-format: C-BIT Parity, line code: B3ZS
Source clock: slave, loopback: not set
Alarm state:
Receiver alarm state is none
MDL state:
No message is sent now.
Message data elements:
EIC: line, LIC: line, FIC: line, UNIT: line
PFI: line, PORT_NO: line, GEN_NO: line
Periodical detection: disabled
FEAC state:
No code is sent now.
Periodical detection is enabled, no code received now.
Test pattern: 2^7, Status: Not Sync, Sync Detected: 0
Bit errors (since test started): 0 bits
Bits received (since test started): 0 Mbits
Bit errors (since latest sync): 0 bits
Bits received (since latest sync): 0 Mbits
Last link flapping: 6 hours 39 minutes 25 seconds
Data in current interval (22 seconds elapsed):
Line Code Violations: 0 seconds Far End Block Error: 0 seconds
C-Bit Coding Violation: 0 seconds
P-bit Coding Violation: 0 seconds
Framing Bit Err: 0 seconds, Severely Err Framing: 0 seconds
C-bit Err: 0 seconds, C-bit Severely Err: 0 seconds
P-bit Err: 0 seconds, P-bit Severely Err: 0 seconds
Unavailable: 0 seconds, Line Err: 0 seconds
T3 2/4/0 CT1 1: up
Frame-format: ESF, clock: slave, loopback: not set
FDL Performance Report: disabled
Transmitter is sending none
Line loop back deactivate code using inband signal last sent
Test pattern: 2^11, Status: Not Sync, Sync Detected: 0
Bits received (since test started): 0 Kbits
Bits received (since latest sync): 0 Kbits
Table 8 Command output
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
Description of the interface. |
The most recent time that the reset counters controller t3 command was executed. This field displays Never if this command has not been executed since the device startup. |
Work mode |
Operating mode of the interface: CT3 or T3. |
cable length |
Cable length supported by the interface. |
Frame-format |
Frame format: C-bit parity or M23. |
Source clock |
Clock source used by the interface: master or slave. |
loopback |
Loopback setting on the interface: local, remote, payload, or not set. |
Receiver alarm state is none |
Type of the received alarm: none, LOS, LOF, RAI, or AIS. If the interface receives a LOS, LOF, or AIS alarm and sends out an RAI alarm, Transmitter is sending RAI is displayed. |
No message is sent now. |
No MDL message is being sent. If an MDL message, path or idle-signal for example, is being sent, Message sent now: path. idle signal is displayed. |
Message data elements |
MDL data elements. |
EIC: line, LIC: line, FIC: line, UNIT: line |
EIC, LIC, FIC, and UNIT are four elements present in all types of MDL messages. Their values are user configurable and default to line. |
PFI: line, PORT_NO: line, GEN_NO: line |
FI is contained in MDL path messages, PORT_NO in MDL idle signal messages, and GEN_NO in MDL test signal messages. Their values are user configurable and default to line. |
Periodical detection |
State of periodical detection of MDL. Periodical MDL message detection is disabled by default at the startup of the router. When this function is enabled, Periodical detection is enabled is displayed. When MDL messages are detected, information about detected MDL messages is displayed. |
No code is sent now. DS3 Line Loop Back Deactivate was last sent. |
No FEAC signal is sent. The FEAC signal sent last time is DS3 Line Loop Back Deactivate. |
Periodical detection is enabled, no code received now. |
Periodical detection of FEAC is enabled and no FEAC signal is received now. Periodical FEAC signal detection is enabled by default at the startup of the router. |
DS3 Line Loop Back Deactivate last received. |
The FEAC signal received last time is DS3 Line Loop Back Deactivate. |
BERT state:(stopped, not completed) |
BERT state: completed, stopped (not completed), or running. |
Test pattern: 2^7, Status: Not Sync, Sync Detected: 0 |
Test pattern in use (such as 2^7, 2^11, 2^15, and QRSS), 2^7 in this sample output; synchronization state, and the number of detected synchronizations. |
Time |
Time past |
Bit errors (since test started) |
Bits received (since test started) |
Bit errors (since latest sync) |
Bits received (since latest sync) |
Data in current interval (22 seconds elapsed): |
Statistics spanning the current 15-minute interval. |
Line Code Violations |
Line code violations: BPV, or EXZ. |
Far End Block Error |
Far-end block error. |
C-Bit Coding violation |
C-bit coding violation. |
P-bit Coding Violation |
P-bit coding violation. |
Framing Bit Err |
Framing bit error. |
Severely Err Framing Secs |
Severely erroneous second. |
C-bit Err Secs |
C-bit erroneous second. |
C-bit Severely Err Secs |
C-bit severely erroneous second. |
P-bit Err Secs |
P-bit erroneous second. |
P-bit Severely Err Secs |
P-bit severely erroneous second. |
Unavailable Secs |
Service unavailable second. |
Line Err Secs |
Line erroneous second, during which LOS, BPV, EXZ, C-bit, P-bit, and other errors occur. |
Data in Interval 1: |
Statistics spanning interval 1. |
Total Data (last 17 15 minute intervals) |
Total data spanning the last 17 intervals. |
T3 2/4/0 CT1 1 is up |
State of T1 line on the CT3 interface: up or down. In this output sample, T1 line 1 is up. |
Frame-format ESF, clock slave, loopback not set |
Information about the T1 line: · Framing format—ESF or SF. · Clock source—Slave for the line clock and master for the internal clock. · Loopback—Local, remote, payload, or not set. |
FDL Performance Report is disabled |
Transmission of PPR in the FDL is disabled. You can enable it by using the t1 set fdl ansi command. |
Transmitter is sending RAI |
The transmitter of the T1 line is sending RAI signals. When the T1 line receives LOS, LOF, or AIS signals, it sends RAI signals. |
Receiver alarm state is LOF |
Type of alarm signal that the T1 line can receive: LOS, LOF, AIS, or RAI. |
Line loop back activate code using inband signal last sent |
The loopback code sent last time is in-band LLB activation request code. |
feac
Use feac to enable far end and control signal (FEAC) channel signal detection and transmission on a CT3 interface.
Use undo feac to remove the current FEAC settings.
feac { detect | generate { ds3-los | ds3-ais | ds3-oof | ds3-idle | ds3-eqptfail | loopback { ds3-line | ds3-payload } } }
undo feac { detect | generate { ds3-los | ds3-ais | ds3-oof | ds3-idle | ds3-eqptfail | loopback { ds3-line | ds3-payload } } }
On a CT3 interface, periodical FEAC channel signal detection is enabled, and FEAC signal transmission is disabled.
CT3 interface view
detect: Enables periodical FEAC channel signal detection.
generate: Generates a specific type of FEAC signal.
· ds3-los: Specifies the DS3 LOS signal.
· ds3-ais: Specifies the DS3 AIS signal.
· ds3-oof: Specifies the DS3 OOF signal.
· ds3-idle: Specifies the DS3 idle signal.
· ds3-eqptfail: Specifies DS3 equipment failure signal.
loopback: Sends a specific type of loopback code for activating a specific loopback.
· ds3-line: Specifies far-end line loopback.
· ds3-payload: Specifies payload loopback.
FEAC is a channel formed by using the third C-bit in the first subframe in C-bit framing. The channel is used for the following purposes:
· Transmits alarm state signals for line test.
· Transmits loopback control code to activate or deactivate far-end loopback during a loopback test.
According to ANSI T1.107a, the framing format of FEAC channels is bit-oriented protocol (BOP).
After far-end loopback is activated by using the feac generate loopback { ds3-line | ds3-payload } command, you can remove it by using the undo form of the command.
Before you configure far-end loopback by using this command, disable FEAC detection on the local end to prevent loopback deadlock. Loopback deadlock occurs when the local end enables loopback after detecting the loopback code sent back by the far end.
To display the transmitting and receiving state of the FEAC channel, use the display controller t3 command.
# Enable FEAC channel signal detection on T3 2/4/0.
[Sysname-T3 2/4/0] feac detect
# Send DS3 LOS signal on T3 2/4/0.
[Sysname-T3 2/4/0] feac generate ds3-los
# On T3 2/4/0, send loopback code to the far end to place the far end in a line loopback.
[Sysname-T3 2/4/0] feac generate loopback ds3-line
frame-format
Use frame-format to set the framing format for a CT3 interface.
Use undo frame-format to restore the default.
frame-format { c-bit | m23 }
undo frame-format
The framing format for a CT3 interface is C-bit.
CT3 interface view
c-bit: Sets the framing format to C-bit.
m23: Sets the framing format to m23.
This command is available only in channelized mode.
# Set the framing format to m23 for T3 2/4/0.
[Sysname-T3 2/4/0] frame-format m23
using
ft3
Use ft3 to configure a CT3 interface to operate in FT3 mode and set the DSU mode or the subrate, or enable payload scrambling for the interface.
Use undo ft3 to restore the default.
ft3 { dsu-mode { 0 | 1 | 2 | 3 | 4 } | subrate number | scramble }
undo ft3 { dsu-mode | subrate | scramble }
DSU mode 0 (the Digital Link mode) is used, and the subrate is 44210 kbps. Payload scrambling is disabled.
CT3 interface view
dsu-mode: Specifies the DSU mode.
Keyword |
DSU mode (vendor) |
Subrate range |
Total number of subrate grades |
0 |
Digital Link |
300 to 44210 kbps in steps of 300746 bps |
147 |
1 |
Kentrox |
1500 to 35000 kbps in steps of 500000 bps 44210 kbps |
69 |
2 |
Larscom |
3100 to 44210 kbps in steps of 3157835 bps |
14 |
3 |
Adtran |
75 to 44210 kbps in steps of 75187 bps |
588 |
4 |
Verilink |
1500 to 44210 kbps in steps of 1578918 bps |
20 |
subrate number: Specifies the subrate for the CT3 interface. The number argument is in the range of 1 to 44210 (in kbps).
scramble: Enables payload scrambling for the CT3 interface.
This command is applicable only to CT3 cards that support FT3.
This command is available only in T3 mode.
FT3 (Fractional T3 or Subrate T3) mode is a nonstandard E3 application mode. FE3 subrate ranges and the number of subrate grades vary by vendor. You can use the ft3 command to configure the device to be compatible with the FE3 DSU modes listed in Table 9.
After you set the subrate by using the ft3 subrate command, the T3 interface searches the subrate levels corresponding to the DSU mode in which it is operating. The T3 interface selects the subrate level that is closest to subrate level set by the ft3 subrate command. The device adjusts the hardware to allow for the subrate.
Use the ft3 scramble command to enable payload scrambling for the interface. Payload scrambling improves line quality by preventing the presence of long strings of all 1s or all 0s.
You can use the display interface serial interface-number:0 command to check the following settings of a CT3 interface:
· DSU mode.
· Subrate.
· Actual rate.
The actual rate does not count in the overhead bits.
· Baud rate.
The baud rate is the actual T3 line rate (44736 kbps), with the overhead bits counted in.
· Payload scrambling setting.
# Configure T3 2/4/0 to operate in the FT3 mode. Set the DSU mode to 1 and the subrate to 3000 kbps. Enable payload scrambling for the interface.
[Sysname-T3 2/4/0] using t3
[Sysname-T3 2/4/0] ft3 dsu-mode 1
[Sysname-T3 2/4/0] ft3 subrate 3000
[Sysname-T3 2/4/0] ft3 scramble
loopback
Use loopback to enable a type of loopback on a CT3 interface.
Use undo loopback to disable loopback on a CT3 interface.
undo loopback
Loopback is disabled on CT3 interfaces.
CT3 interface view
If a CT3 interface encapsulated with PPP or HDLC is placed in a loopback, the state of the link layer protocol is reported as down.
# Enable internal loopback on interface T3 2/4/0.
[Sysname-T3 2/4/0] loopback local
mdl
Use mdl to configure MDL message detection and transmission on a CT3 interface.
Use undo mdl to restore the default.
mdl { data { eic string | fic string | gen-no string | lic string | pfi string | port-no string | unit string } | detect | generate { idle-signal | path | test-signal } }
undo mdl [ data [ eic | fic | gen-no | lic | pfi | port-no | unit ] | detect | generate [ idle-signal | path | test-signal ] ]
Periodic MDL detection is disabled. CT3 interfaces do not send MDL messages.
CT3 interface view
data: Sets MDL message parameters. If you do not specify a parameter, a default string of line is set in the MDL messages.
· eic string: Specifies the equipment identification code, a string of 1 to 10 characters. This parameter is contained in all three types of MDL messages.
· fic string: Specifies the frame identification code, a string of 1 to 10 characters. This parameter is contained in all three types of MDL messages.
· gen-no string: Specifies the generator number, a string of 1 to 38 characters. This parameter is specific to test signal messages.
· lic string: Specifies the location identification code, a string of 1 to 11 characters. This parameter is contained in all three types of MDL messages.
· pfi string: Specifies the path facility identification, a string of 1 to 38 characters. This parameter is specific to path messages.
· port-no string: Specifies the port number in idle signal message, a string of 1 to 38 characters. This parameter is specific to idle signal messages.
· unit string: Specifies the unit, a string of 1 to 6 characters. This parameter is contained in all three types of MDL messages.
detect: Enables periodical MDL message detection.
generate: Sends a specific type of MDL message.
· idle-signal: Specifies MDL idle signal messages.
· path: Specifies MDL path messages.
· test-signal: Specifies MDL test signal messages.
MDL is a channel formed by using the three C-bits in the fifth subframe in C-bit framing. According to ANSI T1.107a, MDL can transmit path, idle signal, and test signal messages. The data framing format is LAPD for MDL messages.
To send idle signal, path, and test signal messages simultaneously, repeat the mdl command to specify the idle-signal, path, and test-signal keywords.
To display the receiving and transmission status of the MDL link, use the display controller t3 command.
# Enable MDL detection on T3 2/4/0.
[Sysname-T3 2/4/0] mdl detect
# Set LIC to hello for CT3 interface T3 2/4/0.
[Sysname-T3 2/4/0] mdl data lic hello
# Send path messages on CT3 interface T3 2/4/0.
[Sysname-T3 2/4/0] mdl generate path
Use reset counters controller t3 to clear CT3 interface statistics.
reset counters controller t3 [ interface-number ]
interface-number: Specifies a CT3 interface by its number. If you do not specify this argument, the command clears statistics for all CT3 interfaces.
The reset counters interface command clears statistics for all interfaces.
To display CT3 interface statistics, use the display controller t3 command.
# Clear statistics for T3 2/4/0.
<Sysname> reset counters controller t3 2/4/0
t1 alarm
Use t1 alarm to enable a T1 line on a CT3 interface to detect/send alarm signals.
Use undo t1 alarm to remove the alarm signal detection/sending setting.
t1 line-number alarm { detect | generate { ais | rai } }
undo t1 line-number alarm { detect | generate { ais | rai } }
On a CT3 interface, periodical alarm detection is enabled, and alarm signal sending is disabled.
CT3 interface view
line-number: Specifies a T1 line number in the range of 1 to 28.
detect: Specifies periodical alarm signal detection.
generate: Sends a specific type of alarm signals. These alarm signals are used for line status test.
At startup, periodical alarm signal detection is enabled on all T1 lines on the CT3 interface. When a T1 line detects LOS, LOF, or AIS signals, it sends RAI signals to its peer.
The supported alarm signals (LOS, LOF, AIS, RAI, FEBE, and idle) are ANSI T1.403 compliant.
Only one type of alarm signal can be sent on a T1 line at a time. To send another type of signal, you must first remove the previous setting by using the undo t1 alarm command. If a RAI signal is present because an LOS, LOF, or AIS alarm is detected, you must first use the undo t1 alarm detect command to remove the signal.
To display the real-time alarm state on T1 lines, use the display controller t3 command.
# Enable periodical alarm signal detection on T1 line 1 on T3 2/4/0.
[Sysname-T3 2/4/0] t1 1 alarm detect
# Enable T1 line 1 on T3 2/4/0 to send AIS alarm signals.
[Sysname-T3 2/4/0] t1 1 alarm generate ais
t1 channel-set
Use t1 channel-set to bundle timeslots into a channel set on a T1 line.
Use undo t1 channel-set to remove a channel set.
t1 line-number channel-set set-number timeslot-list list [ speed { 56k | 64k } ]
undo t1 line-number channel-set set-number
No channel sets exist on a T1 line.
CT3 interface view
set-number: Specifies the number of a channel set created by timeslot bundling on a T1 line, in the range of 0 to 23.
timeslot-list list: Specifies a comma-separated list of timeslot items. An item can be an individual timeslot or a timeslot range. Use a hyphen (-) to separate the start and end timeslot numbers of a range. The value range for the timeslot number is 1 to 24.
speed { 56k | 64k }: Speed of the timeslot bundle (the channel set) in kbps. If 56k is selected, the timeslots are bundled into an n × 56 kbps bundle. If 64k, the default, is selected, the timeslots are bundled into an n × 64 kbps bundle.
When a T1 line is operating in framed (CT1) mode, you can bundle timeslots on it. For each channel set, the system automatically creates a serial interface named serial number/line-number:set-number. This interface operates at n × 64 kbps or n × 56 kbps, where n is the number of bundled timeslots. This interface has the same logical features as a standard synchronous serial interface. You can configure this serial interface in the same way you configure a standard synchronous serial interface.
# Create a 128 kbps serial interface through timeslot bundling on T1 line 1 on T3 2/4/0.
[Sysname-T3 2/4/0] t1 1 channel-set 1 timeslot-list 1,2
t1 unframed
t1 clock
Use t1 clock to set the clock mode of a T1 line on a CT3 interface.
Use undo t1 clock to restore the default.
t1 line-number clock { master | slave }
undo t1 line-number clock
The clock mode of a T1 line on a CT3 interface is slave.
CT3 interface view
When the clock mode of a T1 line is master, it uses the internal clock source. When the clock mode of a T1 line is slave, it uses the line clock source.
When a CT3 interface is operating in channelized mode, its T1 lines might use separate clocks.
# Set the clock mode to slave for T1 line 1 on T3 2/4/0.
[Sysname-T3 2/4/0] t1 1 clock slave
t1 fdl
Use t1 fdl to set the behavior of a T1 line on the FDL in ESF framing.
Use undo t1 fdl to disable FDL of T1.
t1 line-number fdl { ansi | att | both | none}
undo t1 line-number fdl
FDL is disabled in ESF framing.
CT3 interface view
none: Disables the use of FDL on the T1 line.
FDL is an embedded 4 kbps overhead channel within the ESF format for transmitting periodical performance report (PPR) statistics or loopback code.
According to ANSI T1.403, the format of PPR is LAPD, and the format of loopback code is BOP.
The t1 set fdl command only starts PPR transmission. It cannot enable loopback code transmission or detection.
This command only applies to channelized T1 lines with a T1 frame format of ESF.
# Set the FDL to be ANSI T1.403 compliant for T1 line 1 on T3 2/4/0.
[Sysname-T3 2/4/0] t1 1 fdl ansi
t1 frame-format
t1 frame-format
Use t1 frame-format to set the framing format for a T1 line.
Use undo t1 frame-format to restore the default.
t1 line-number frame-format { esf | sf }
undo t1 line-number frame-format
The framing format of a T1 line is ESF.
CT3 interface view
esf: Sets the T1 line to use the ESF format.
sf: Sets the T1 line to use the SF format.
You can configure this command only when the T1 line is operating in framed mode. To configure a T1 line to operate in framed mode, use the undo t1 unframed command.
# Set the framing format to SF for T1 line 1 on T3 2/4/0.
[Sysname-T3 2/4/0] t1 1 frame-format sf
t1 unframed
t1 loopback
Use t1 loopback to enable a type of loopback for a T1 line on a CT3 interface.
Use undo t1 loopback to disable loopback for a T1 line on a CT3 interface.
t1 line-number loopback { local | payload | remote }
undo t1 line-number loopback
Loopback is disabled on T1 lines.
CT3 interface view
payload: Enables payload loopback mode.
If a T1 line encapsulated with PPP or HDLC is in loopback mode, the state of the link layer protocol is reported as down.
# Enable internal loopback on T1 line 1 on T3 2/4/0.
[Sysname-T3 2/4/0] t1 1 loopback local
t1 sendloopcode
Use t1 sendloopcode to set the loopback mode of a far-end T1 line.
Use undo t1 sendloopcode to remove the corresponding setting.
t1 line-number sendloopcode { fdl-ansi-line-up | fdl-ansi-payload-up | fdl-att-payload-up | inband-line-up }
undo t1 line-number sendloopcode { fdl-ansi-line-up | fdl-ansi-payload-up | fdl-att-payload-up | inband-line-up }
No loopback mode is set.
CT3 interface view
line-number: Specifies a T1 line number, in the range of 1 to 28.
fdl-ansi-line-up: Sends ANSI-compliant LLB activation request code in the FDL to start remote loopback.
fdl-ansi-payload-up: Sends ANSI-compliant PLB activation request code in the FDL to start remote loopback.
fdl-att-payload-up: Sends AT&T-compliant PLB activation request code in the FDL to start remote loopback.
inband-line-up: Sends in-band LLB activation request code compliant with the ANSI and AT&T implementation to start remote loopback.
Loopback is an effective method of diagnosis. You can place a far-end device into loopback mode either at the command line on it or by sending loopback control code to it. The types and formats of loopback control code supported on T1 interfaces are compliant with ANSI T1.403.
Loopback can be divided into line loopback and payload loopback. The data stream is looped back at the framer only in the line loopback.
You can transmit loopback control code by using the in-band signal (the 192 effective bandwidth bits or all 193 bits of T1) or the FDL in ESF frames.
# Send the in-band signal on T1 line 1 on T3 2/4/0 to place the far-end T1 line in line loopback mode.
[Sysname-T3 2/4/0] t1 1 sendloopcode inband-line-up
t1 show
Use t1 show to have a quick look at the line state of a T1 line on a CT3 interface.
t1 line-number show
CT3 interface view
show: Displays the physical line state of the specified T1 line.
# Display line state of T1 line 1 on T3 2/4/0.
[Sysname-T3 2/4/0] t1 1 show
T3 2/4/0 CT1 1: up
Time: 0 minutes, Time past: 0 minutes
Table 10 Command output
State of T1 line 1 on the CT3 interface: up or down. |
Frame-format |
Framing format of T1: ESF or SF. |
clock |
Clock source used by the T1 line: master or slave. |
loopback |
Loopback state or mode: local, remote, payload, or not set. |
BERT state |
BERT test state: running, complete, or stopped (not completed). |
Test pattern |
Test pattern in use. |
Status |
Synchronization state. |
Sync Detected |
Number of detected synchronizations. |
Time |
Duration of the BERT test. |
Time past |
Time that has elapsed. |
Number of bit errors received since the start of the BERT test. |
Number of bits received since the start of the BERT test. |
t1 shutdown
Use t1 shutdown to shut down a T1 line on a CT3 interface.
Use undo t1 shutdown to bring up a T1 line.
t1 line-number shutdown
undo t1 line-number shutdown
T1 lines on a CT3 interface are up.
CT3 interface view
Shutting down or bringing up a T1 line also shuts down or brings up the serial interface created for it.
# Shut down T1 line 1 on T3 2/4/0.
[Sysname-T3 2/4/0] t1 1 shutdown
t1 unframed
Use t1 unframed to set a T1 line on a CT3 interface to operate in unframed mode (T1 mode).
Use undo t1 unframed to set a T1 line on a CT3 interface to operate in framed mode (CT1 mode).
t1 line-number unframed
undo t1 line-number unframed
T1 lines on a CT3 interface are operating in framed mode.
CT3 interface view
A T1 line in unframed mode does not contain frame control information or support timeslot division. The system automatically creates a 1544 kbps serial interface named serial number/line-number:0. This interface has the same logical features as a standard synchronous serial interface. You can configure this serial interface in the same way you configure a standard synchronous serial interface.
# Set T1 line 1 on T3 2/4/0 to operate in unframed mode.
[Sysname-T3 2/4/0] t1 1 unframed
t1 channel-set
using
Use using to configure the operating mode of a CT3 interface.
Use undo using to restore the default.
using { ct3 | t3 }
undo using
A CT3 interface operates in channelized mode.
CT3 interface view
ct3: Sets the CT3 interface to operate in channelized mode.
t3: Sets the CT3 interface to operate in unchannelized mode.
You can only configure T1 lines on CT3 interfaces in channelized mode.
When a CT3 interface operates in unchannelized mode, the system automatically creates a 44.736 Mbps serial interface named serial number/0:0 for it. This interface has the same logical features as a standard synchronous serial interface. You can configure this serial interface in the same way you configure a standard synchronous serial interface.
# Configure T3 2/4/0 to operate in unchannelized mode.
