- H3C S12500X-AF & S12500-X & S9800 Switch Series Configuration Examples-Release 27xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-GRE Tunnel Configuration Examples
- 14-GRE with OSPF Configuration Examples
- 15-OSPF Configuration Examples
- 16-IS-IS Configuration Examples
- 17-BGP Configuration Examples
- 18-Policy-Based Routing Configuration Examples
- 19-OSPFv3 Configuration Examples
- 20-IPv6 IS-IS Configuration Examples
- 21-Routing Policy Configuration Examples
- 22-IGMP Snooping Configuration Examples
- 23-IGMP Configuration Examples
- 24-Multicast VPN Configuration Examples
- 25-Basic MPLS Configuration Examples
- 26-MPLS L3VPN Configuration Examples
- 27-ACL Configuration Examples
- 28-Control Plane-Based QoS Policy Configuration Examples
- 29-Traffic Policing Configuration Examples
- 30-GTS and Rate Limiting Configuration Examples
- 31-Priority Mapping and Queue Scheduling Configuration Examples
- 32-Traffic Filtering Configuration Examples
- 33-AAA Configuration Examples
- 34-SSH Configuration Examples
- 35-IP Source Guard Configuration Examples
- 36-Ethernet OAM Configuration Examples
- 37-CFD Configuration Examples
- 38-DLDP Configuration Examples
- 39-VRRP Configuration Examples
- 40-BFD Configuration Examples
- 41-NTP Configuration Examples
- 42-SNMP Configuration Examples
- 43-NQA Configuration Examples
- 44-Mirroring Configuration Examples
- 45-sFlow Configuration Examples
- 46-FCoE Configuration Examples
- 47-OpenFlow Configuration Examples
- 48-MAC Address Table Configuration Examples
- 49-Static Multicast MAC Address Entry Configuration Examples
- 50-IP Unnumbered Configuration Examples
- 51-MVRP Configuration Examples
- 52-MCE Configuration Examples
- 53-Congestion Avoidance and Queue Scheduling Configuration Examples
- 54-Attack Protection Configuration Examples
- 55-Smart Link Configuration Examples
- 56-RRPP Configuration Examples
- 57-BGP Route Selection Configuration Examples
- 58-IS-IS Route Summarization Configuration Examples
- 59-IRF Configuration Examples
- 60-MPLS OAM Configuration Examples
- 61-MPLS TE Configuration Examples
- 62-VXLAN Configuration Examples
- 63-NetStream Configuration Examples
- 64-MDC + EVPN Configuration Examples
- 65-DRNI Configuration Examples
- 66-MDC Configuration Examples
- 67-DRNI and EVPN Configuration Examples
- 68-VCF Fabric Configuration Examples
18-Policy-Based Routing Configuration Examples | 103.94 KB |
H3C S12500X-AF & S12500-X & S9800 |
S12500X-AF Switch Series
S12500-X Switch Series
S9800 Switch Series
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides PBR configuration examples.
PBR uses a user-defined policy to route packets based on fields such as the source address, destination address, IP precedence, and protocol. PBR takes precedence over destination-based routing.
This document assumes that you have basic knowledge of PBR.
When you configure the action of forwarding traffic to a next hop, do not specify the following addresses:
· An IPv6 address in an IPv4 ACL rule.
· An IPv4 address in an IPv6 ACL rule.
Example: Configuring PBR
As shown in Figure 1, on Device, all packets destined for Server are forwarded to the next hop 10.4.1.2 by default.
Configure PBR to meet the following requirements:
· Packets with source IPv4 address 10.2.1.1 received on VLAN-interface 2 are forwarded to the next hop 10.5.1.2.
· HTTP packets with source IPv4 addresses other than 10.2.1.1 received on VLAN-interface 2 are forwarded to the next hop 10.3.1.2.
Analysis
To forward the two types of packets to different next hops, you must perform the following tasks:
· Configure two ACLs to classify the two types of packets.
· Configure two policy nodes to forward the packets to the specified next hops.
To ensure that packets with source address 10.2.1.1 are forwarded to the next hop 10.5.1.2, assign a node a smaller node ID to match the packets.
Software versions used
Table 1 shows the software versions used in this configuration example.
Table 1 Product and software version compatibility
Product |
Software version |
S12500X-AF Switch Series |
S12500X-CMW710-R2712 |
S12500-X Switch Series |
S9800 Switch Series |
S9800-CMW710-R2712 |
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
# Configure an IPv4 address for VLAN-interface 2.
[Device] interface vlan-interface 2
[Device-Vlan-interface2] ip address 10.1.2.1 255.255.255.0
[Device-Vlan-interface2] quit
# Configure IPv4 addresses for other interfaces in the same way VLAN-interface 2 is configured. (Details not shown.)
# Configure three static routes and configure 10.4.1.2 as the default next hop.
[Device] ip route-static 192.168.1.0 24 10.3.1.2
[Device] ip route-static 192.168.1.0 24 10.4.1.2 preference 40
[Device] ip route-static 192.168.1.0 24 10.5.1.2
# Create ACL 3005 to match packets with source address 10.2.1.1.
[Device] acl advanced 3005
[Device-acl-ipv4-adv-3005] rule 0 permit ip source 10.2.1.1 0
[Device-acl-ipv4-adv-3005] quit
# Create ACL 3006 to match HTTP packets with source addresses other than 10.2.1.1.
[Device] acl advanced 3006
[Device-acl-ipv4-adv-3006] rule 0 permit tcp destination-port eq www
[Device-acl-ipv4-adv-3006] quit
# Configure Node 0 for policy pbr1 to forward packets matching ACL 3005 to the next hop 10.5.1.2.
[Device] policy-based-route pbr1 permit node 0
[Device-pbr-pbr1-0] if-match acl 3005
[Device-pbr-pbr1-0] apply next-hop 10.5.1.2
[Device-pbr-pbr1-0] quit
# Configure Node 1 for policy pbr1 to forward packets matching ACL 3006 to the next hop 10.3.1.2.
[Device] policy-based-route pbr1 permit node 1
[Device-pbr-pbr1-1] if-match acl 3006
[Device-pbr-pbr1-1] apply next-hop 10.3.1.2
[Device-pbr-pbr1-1] quit
# Apply policy pbr1 to VLAN-interface 2.
[Device-Vlan-interface2] ip policy-based-route pbr1
# On Device, display PBR policy information.
[Device] display ip policy-based-route policy pbr1
Policy name: pbr1
node 0 permit:
if-match acl 3005
node 1 permit:
if-match acl 3006
The output shows that the PBR configurations are successful.
# On Switch, display the path for forwarding non-HTTP packets with source address 10.1.1.1.
NOTE: Before you use a tracert command, perform the following tasks: · Enable sending of ICMP timeout packets on the intermediate devices. · Enable sending of ICMP destination unreachable packets on the destination device. |
<Switch> tracert -a 10.1.1.1 192.168.1.1
traceroute to 192.168.1.1 (192.168.1.1) from 10.1.1.1, 30 hops at most, 52 bytes
each packet, press CTRL_C to break
1 10.1.2.1 (10.1.2.1) 2.178 ms 1.364 ms 1.058 ms
2 10.4.1.2 (10.4.1.2) 1.548 ms 1.248 ms 1.112 ms
3 192.168.1.1 (192.168.1.1) 1.594 ms 1.321 ms 1.093 ms
The output shows that non-HTTP packets with source address 10.1.1.1 are forwarded to the next hop 10.4.1.2.
# On Switch, display the path for forwarding packets with source address 10.2.1.1.
<Switch> tracert -a 10.2.1.1 192.168.1.1
traceroute to 192.168.1.1 (192.168.1.1) from 10.2.1.1, 30 hops at most, 40 bytes
1 10.1.2.1 (10.1.2.1) 1.721 ms 1.226 ms 1.050 ms
2 10.5.1.2 (10.5.1.2) 4.494 ms 1.385 ms 1.170 ms
3 192.168.1.1 (192.168.1.1) 1.448 ms 1.304 ms 1.093 ms
The output shows that packets with source address 10.2.1.1 are forwarded to the next hop 10.5.1.2.
Configuration files
vlan 1
vlan 2 to 5
if-match acl 3005
if-match acl 3006
interface Vlan-interface2
interface Vlan-interface3
ip address 10.3.1.1 255.255.255.0
interface Vlan-interface4
ip address 10.4.1.1 255.255.255.0
interface Vlan-interface5
ip address 10.5.1.1 255.255.255.0
acl number 3005
acl number 3006
Example: Configuring IPv6 PBR
As shown in Figure 2, on Device, all packets destined for Server are forwarded to the next hop 2004::2 by default.
Configure IPv6 PBR to meet the following requirements:
· Packets with source IPv6 address 2002::1 received on VLAN-interface 2 are forwarded to the next hop 2005::2.
· HTTP packets with source IPv6 addresses other than 2002::1 received on VLAN-interface 2 are forwarded to the next hop 2003::2.
Analysis
To ensure that packets with source address 2002::1 are forwarded to the next hop 2005::2, assign a node a smaller node ID to match the packets.
Table 2 shows the software versions used in this configuration example.
Table 2 Product and software version compatibility
Product |
Software version |
Procedures
# Configure an IPv6 address for VLAN-interface 2.
[Device-Vlan-interface2] ipv6 address 2007::1 64
# Configure IPv6 addresses for other interfaces in the same way VLAN-interface 2 is configured. (Details not shown.)
# Configure three static routes and configure 2004::2/64 as the default next hop.
[Device] ipv6 route-static 3001::1 64 2003::2
[Device] ipv6 route-static 3001::1 64 2004::2 preference 40
[Device] ipv6 route-static 3001::1 64 2005::2
# Create IPv6 ACL 3005 to match packets with source address 2002::1.
[Device] acl ipv6 advanced 3005
[Device-acl-ipv6-adv-3005] rule 0 permit ipv6 source 2002::1/128
[Device-acl-ipv6-adv-3005] quit
# Create IPv6 ACL 3006 to match HTTP packets with source addresses other than 2002::1.
[Device] acl ipv6 advanced 3006
[Device-acl-ipv6-adv-3006] rule 0 permit tcp destination-port eq www
[Device-acl-ipv6-adv-3006] quit
# Configure Node 0 for policy pbr1 to forward packets matching IPv6 ACL 3005 to the next hop 2005::2.
[Device] ipv6 policy-based-route pbr1 permit node 0
[Device-pbr6-pbr1-0] if-match acl 3005
[Device-pbr6-pbr1-0] apply next-hop 2005::2
[Device-pbr6-pbr1-0] quit
# Configure Node 1 for policy pbr1 to forward packets matching IPv6 ACL 3006 to the next hop 2003::2.
[Device] ipv6 policy-based-route pbr1 permit node 1
[Device-pbr6-pbr1-1] if-match acl 3006
[Device-pbr6-pbr1-1] apply next-hop 2003::2
[Device-pbr6-pbr1-1] quit
[Device-Vlan-interface2] ipv6 policy-based-route pbr1
# On Device, display IPv6 PBR policy information.
[Device] display ipv6 policy-based-route policy pbr1
Policy name: pbr1
node 0 permit:
if-match acl 3005
node 1 permit:
if-match acl 3006
The output shows that the IPv6 PBR configurations are successful.
# On Device, verify the forwarding of packets with source address 2002::1. (Details not shown.)
· If 2005::2 is reachable, packets are forwarded to the next hop 2005::2.
· If 2005::2 is not reachable, packets are forwarded to the next hop 2004::2.
# On Device, verify the forwarding of HTTP packets. (Details not shown.)
· If 2003::2 is reachable, packets are forwarded to the next hop 2003::2.
· If 2003::2 is not reachable, packets are forwarded to the next hop 2004::2.
Configuration files
vlan 1
vlan 2 to 5
if-match acl 3005
if-match acl 3006
ipv6 address 2007::1/64
ipv6 address 2003::1 64
ipv6 address 2004::1 64
ipv6 address 2005::1 64
ipv6 route-static 3001:: 64 2003::2
ipv6 route-static 3001:: 64 2004::2 preference 40
ipv6 route-static 3001:: 64 2005::2
acl ipv6 number 3005
acl ipv6 number 3006
Related documentation
· H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 3—IP Routing Command Reference (R27xx)
· H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 3—IP Routing Configuration Guide (R27xx)
