- H3C S12500X-AF & S12500-X & S9800 Switch Series Configuration Examples-Release 27xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-GRE Tunnel Configuration Examples
- 14-GRE with OSPF Configuration Examples
- 15-OSPF Configuration Examples
- 16-IS-IS Configuration Examples
- 17-BGP Configuration Examples
- 18-Policy-Based Routing Configuration Examples
- 19-OSPFv3 Configuration Examples
- 20-IPv6 IS-IS Configuration Examples
- 21-Routing Policy Configuration Examples
- 22-IGMP Snooping Configuration Examples
- 23-IGMP Configuration Examples
- 24-Multicast VPN Configuration Examples
- 25-Basic MPLS Configuration Examples
- 26-MPLS L3VPN Configuration Examples
- 27-ACL Configuration Examples
- 28-Control Plane-Based QoS Policy Configuration Examples
- 29-Traffic Policing Configuration Examples
- 30-GTS and Rate Limiting Configuration Examples
- 31-Priority Mapping and Queue Scheduling Configuration Examples
- 32-Traffic Filtering Configuration Examples
- 33-AAA Configuration Examples
- 34-SSH Configuration Examples
- 35-IP Source Guard Configuration Examples
- 36-Ethernet OAM Configuration Examples
- 37-CFD Configuration Examples
- 38-DLDP Configuration Examples
- 39-VRRP Configuration Examples
- 40-BFD Configuration Examples
- 41-NTP Configuration Examples
- 42-SNMP Configuration Examples
- 43-NQA Configuration Examples
- 44-Mirroring Configuration Examples
- 45-sFlow Configuration Examples
- 46-FCoE Configuration Examples
- 47-OpenFlow Configuration Examples
- 48-MAC Address Table Configuration Examples
- 49-Static Multicast MAC Address Entry Configuration Examples
- 50-IP Unnumbered Configuration Examples
- 51-MVRP Configuration Examples
- 52-MCE Configuration Examples
- 53-Congestion Avoidance and Queue Scheduling Configuration Examples
- 54-Attack Protection Configuration Examples
- 55-Smart Link Configuration Examples
- 56-RRPP Configuration Examples
- 57-BGP Route Selection Configuration Examples
- 58-IS-IS Route Summarization Configuration Examples
- 59-IRF Configuration Examples
- 60-MPLS OAM Configuration Examples
- 61-MPLS TE Configuration Examples
- 62-VXLAN Configuration Examples
- 63-NetStream Configuration Examples
- 64-MDC + EVPN Configuration Examples
- 65-DRNI Configuration Examples
- 66-MDC Configuration Examples
- 67-DRNI and EVPN Configuration Examples
- 68-VCF Fabric Configuration Examples
09-VLAN Configuration Examples | 139.73 KB |
H3C S12500X-AF & S12500-X & S9800 |
S12500X-AF Switch Series
S12500-X Switch Series
S9800 Switch Series
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring port-based VLANs
Example: Configuring the super VLAN
Example: Configuring the private VLAN
Introduction
This document provides examples of configuring the port-based VLAN, super VLAN and private VLAN.
This document assumes that you have basic knowledge of VLANs.
As shown in Figure 1:
· Host A and Host C belong to Department A. VLAN 100 is assigned to Department A.
· Host B and Host D belong to Department B. VLAN 200 is assigned to Department B.
Configure port-based VLANs so that hosts only in the same department can communicate with each other.
Software versions used
Table 1 shows the software versions used in this configuration example.
Table 1 Product and software version compatibility
Product |
Software version |
S12500X-AF Switch Series |
S12500X-CMW710-R2712 |
S12500-X Switch Series |
S9800 Switch Series |
S9800-CMW710-R2712 |
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
# Configure the ports Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 to operate in bridge mode.
[DeviceA] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[DeviceA-if-range] port link-mode bridge
[DeviceA-if-range] quit
# Create VLAN 100, and assign Ten-GigabitEthernet 1/0/1 to VLAN 100.
[DeviceA-vlan100] port ten-gigabitethernet 1/0/1
[DeviceA-vlan100] quit
# Create VLAN 200, and assign Ten-GigabitEthernet 1/0/2 to VLAN 200.
[DeviceA-vlan200] port ten-gigabitethernet 1/0/2
[DeviceA-vlan200] quit
# Configure Ten-GigabitEthernet 1/0/3 as a trunk port, and assign it to VLANs 100 and 200.
[DeviceA] interface ten-gigabitethernet 1/0/3
[DeviceA-Ten-GigabitEthernet1/0/3] port link-type trunk
[DeviceA-Ten-GigabitEthernet1/0/3] port trunk permit vlan 100 200
2. Configure Device B in the same way Device A is configured. (Details not shown.)
3. Configure hosts:
a. Configure Host A and Host C to be on the same IP subnet. For example, 192.168.100.0/24.
b. Configure Host B and Host D to be on the same IP subnet. For example, 192.168.200.0/24.
# Verify that Host B and Host D can ping each other, but they both fail to ping Host A or Host C. (Details not shown.)
# Display information about VLANs 100 and 200 on Device A.
[DeviceA-Ten-GigabitEthernet1/0/3] display vlan 100
VLAN ID: 100
VLAN type: Static
Description: VLAN 0100
Tagged ports:
Untagged ports:
Ten-GigabitEthernet1/0/1
[DeviceA-Ten-GigabitEthernet1/0/3] display vlan 200
VLAN ID: 200
VLAN type: Static
Description: VLAN 0200
Tagged ports:
Untagged ports:
Ten-GigabitEthernet1/0/2
The output shows that:
· Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/1 permit packets from 100 to pass through.
· Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/2 permit packets from 200 to pass through.
Configuration files
Configuration files on both Device B and Device A are the same. The following configuration files use Device A as an example.
vlan 100
vlan 200
port access vlan 100
port access vlan 200
port trunk permit vlan 1 100 200
As shown in Figure 2:
· Users in VLAN 2 access the network through Ten-GigabitEthernet 1/0/1 of Device A.
· Users in VLAN 3 access the network through Ten-GigabitEthernet 1/0/2 of Device A.
· Ten-GigabitEthernet 1/0/3 of Device A and Ten-GigabitEthernet 1/0/1 of Device B are in VLAN 20.
· Users in VLAN 20 use the gateway address 192.168.2.1 and IP addresses on the IP network segment 192.168.2.0/24.
Configure a super VLAN to meet the following requirements:
· Users in VLAN 2 and VLAN 3 use the gateway address 192.168.1.1 and IP addresses on the IP network segment 192.168.1.0/24.
· Users in VLAN 2, VLAN 3, and VLAN 20 are isolated at Layer 2 but interoperable at Layer 3.
Table 2 shows the software versions used in this configuration example.
Table 2 Product and software version compatibility
Product |
Software version |
A super VLAN does not have physical ports. A VLAN that has physical ports cannot be configured as a super VLAN.
Procedures
Configuring Device A
# Create VLAN 10 and configure it as a super VLAN.
[DeviceA] vlan 10
[DeviceA-vlan10] supervlan
[DeviceA-vlan10] quit
# Create VLAN 2, and assign Ten-GigabitEthernet 1/0/1 to VLAN 2.
[DeviceA] vlan 2
[DeviceA-vlan2] port ten-gigabitethernet 1/0/1
[DeviceA-vlan2] quit
# Create VLAN 3, and assign Ten-GigabitEthernet 1/0/2 to VLAN 3.
[DeviceA] vlan 3
[DeviceA-vlan3] port ten-gigabitethernet 1/0/2
[DeviceA-vlan3] quit
# Associate super VLAN 10 with VLANs 2 and 3.
[DeviceA] vlan 10
[DeviceA-vlan10] subvlan 2 3
# Create VLAN-interface 10, and assign IP address 192.168.1.1 to it.
[DeviceA-Vlan-interface10] ip address 192.168.1.1 24
# Enable local proxy ARP on VLAN-interface 10.
[DeviceA-Vlan-interface10] local-proxy-arp enable
# Create VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] quit
# Configure Ten-GigabitEthernet 1/0/3 as a trunk port, and remove the port from VLAN 1.
[DeviceA-Ten-GigabitEthernet1/0/3] undo port trunk permit vlan 1
# Assign Ten-GigabitEthernet 1/0/3 to VLAN 20.
[DeviceA-Ten-GigabitEthernet1/0/3] port trunk permit vlan 20
# Create VLAN-interface 20, and assign IP address 192.168.2.1 to it.
[DeviceA] interface Vlan-interface 20
[DeviceA-Vlan-interface20] ip address 192.168.2.1 24
[DeviceA-Vlan-interface20] quit
Configuring Device B
# Create VLAN 20.
[DeviceB] vlan 20
[DeviceB-vlan20] quit
# Configure Ten-GigabitEthernet 1/0/1 as a trunk port, and remove the port from VLAN 1.
[DeviceB-Ten-GigabitEthernet1/0/1] port link-type trunk
[DeviceB-Ten-GigabitEthernet1/0/1] undo port trunk permit vlan 1
# Assign Ten-GigabitEthernet 1/0/1 to VLAN 20.
[DeviceB-Ten-GigabitEthernet1/0/1] port trunk permit vlan 20
# Assign Ten-GigabitEthernet 1/0/2 to VLAN 20.
[DeviceB] vlan 20
[DeviceB-vlan20] port ten-gigabitethernet 1/0/2
# Verify the super VLAN configuration.
[DeviceA] display supervlan
Super VLAN ID: 10
Sub-VLAN ID: 2-3
VLAN ID: 10
VLAN type: Static
It is a super VLAN.
Route interface: Configured
IPv4 address: 192.168.1.1
IPv4 subnet mask: 255.255.255.0
Description: VLAN 0010
Tagged ports: none
Untagged ports: none
VLAN ID: 2
VLAN type: Static
It is a sub-VLAN.
Description: VLAN 0002
Tagged ports: none
Untagged ports:
VLAN ID: 3
VLAN type: Static
It is a sub-VLAN.
Description: VLAN 0003
Tagged ports: none
Untagged ports:
# Verify that Host A and Host B can ping each other. In the ARP table of Host A, the IP address of Host B corresponds to the MAC address of VLAN-interface 10. In the ARP table of Host B, the IP address of Host A corresponds to the MAC address of VLAN-interface 10. (Details not shown.)
# Verify that Host A and Host C can ping each other. In the ARP table of Host A, no entry about Host C exists. In the ARP table of Host C, no entry about Host A exists. (Details not shown.)
# Verify that Host B and Host C can ping each other. In the ARP table of Host B, no entry about Host C exists. In the ARP table of Host C, no entry about Host B exists. (Details not shown.)
Configuration files
· Device A:
vlan 2
vlan 3
vlan 10
supervlan
subvlan 2 3
vlan 20
interface Vlan-interface10
interface Vlan-interface20
ip address 192.168.2.1 255.255.255.0
port access vlan 2
port access vlan 3
· Device B:
vlan 20
port access vlan 20
As shown in Figure 3:
· The aggregation-layer device Device A assigns VLAN 10 to Device B. Hosts access the network through VLAN-interface 10.
· Users connected to Device B are on the same subnet 10.0.0.0/24.
· Host A and Host B are in the Marketing department. Host C and Host D are in the Finance department.
Configure the private VLAN feature to meet the following requirements:
· Device A is only aware of the primary VLAN 10.
· Hosts in the same secondary VLAN are interoperable at Layer 2.
· Hosts in different secondary VLANs are isolated at Layer 2.
Requirements analysis
The private VLAN configuration is required only on Device B.
Table 3 shows the software versions used in this configuration example.
Table 3 Product and software version compatibility
Product |
Software version |
The system default VLAN (VLAN 1) does not support the private VLAN configuration.
Procedures
# Create VLAN 10 and configure it as a primary VLAN.
[DeviceB] vlan 10
[DeviceB-vlan10] private-vlan primary
[DeviceB-vlan10] quit
# Create VLANs 201 and 202.
[DeviceB] vlan 201 to 202
# Associate primary VLAN 10 with secondary VLANs 201 and 202.
[DeviceB] vlan 10
[DeviceB-vlan10] private-vlan secondary 201 to 202
# Configure the uplink port Ten-GigabitEthernet 1/0/1 as a promiscuous port of VLAN 10.
[DeviceB-Ten-GigabitEthernet1/0/1] port private-vlan 10 promiscuous
# Assign the downlink ports Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 to VLAN 201 as host ports.
[DeviceB] interface range ten-gigabitethernet 1/0/2 to ten-gigabitethernet 1/0/3
[DeviceB-if-range] port link-mode bridge
[DeviceB-if-range] port access vlan 201
[DeviceB-if-range] port private-vlan host
[DeviceB-if-range] quit
# Assign the downlink ports Ten-GigabitEthernet 1/0/4 and Ten-GigabitEthernet 1/0/5 to VLAN 202 as host ports.
[DeviceB] interface range ten-gigabitethernet 1/0/4 to ten-gigabitethernet 1/0/5
[DeviceB-if-range] port access vlan 202
# Create VLAN 10.
[DeviceA] vlan 10
[DeviceA] quit
# Assign Ten-GigabitEthernet 1/0/1 to VLAN 10.
[DeviceA-Ten-GigabitEthernet1/0/1] port link-mode bridge
[DeviceA-Ten-GigabitEthernet1/0/1] port access vlan 10
# Create VLAN-interface 10, and assign IP address 10.0.0.1 to it.
[DeviceA-Vlan-interface10] ip address 10.0.0.1 24
# Verify that Device A can ping Host A, Host B, Host C, and Host D successfully. (Details not shown.)
# Display the ARP table of Device A.
[DeviceA] display arp
Type: S-Static D-Dynamic O-Openflow R-Rule M-Multiport I-Invalid
IP address MAC address VLAN/VSI Interface/Link ID Aging Type
10.0.0.2 d485-64a1-7e4a 10 XGE1/0/1 19 D
10.0.0.3 7446-a0aa-7774 10 XGE1/0/1 19 D
10.0.0.4 6805-ca05-39ae 10 XGE1/0/1 20 D
10.0.0.5 6805-ca05-414e 10 XGE1/0/1 20 D
# Display the private VLAN configuration on Device B.
[DeviceB] display private-vlan
Primary VLAN ID: 10
Secondary VLAN ID: 201-202
VLAN ID: 10
VLAN type: Static
Private VLAN type: Primary
Tagged ports: None
Untagged ports:
Ten-GigabitEthernet1/0/1 Ten-GigabitEthernet1/0/2
Ten-GigabitEthernet1/0/3 Ten-GigabitEthernet1/0/4
Ten-GigabitEthernet1/0/5
VLAN ID: 201
VLAN type: Static
Private VLAN type: Secondary
Description: VLAN 0201
Tagged ports: None
Untagged ports:
VLAN ID: 202
VLAN type: Static
Description: VLAN 0202
Tagged ports: None
Untagged ports:
Ten-GigabitEthernet1/0/1 Ten-GigabitEthernet1/0/4
· The promiscuous port Ten-GigabitEthernet1/0/1 is an untagged member of primary VLAN 10 and secondary VLANs 201 and 202.
· The host ports Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 are untagged members of secondary VLANs 201.
· The host ports Ten-GigabitEthernet 1/0/4 and Ten-GigabitEthernet 1/0/5 are untagged members of secondary VLANs 202.
# Verify that Hosts in the same secondary VLAN can ping each other, but they fail to ping hosts in the other secondary VLAN. (Details not shown.)
Configuration files
· Device B:
vlan 1
vlan 10
vlan 201 to 202
port link-type hybrid
undo port hybrid vlan 1
port hybrid vlan 10 201 to 202 untagged
port hybrid pvid vlan 10
port hybrid vlan 10 201 untagged
port hybrid pvid vlan 201
interface Ten-GigabitEthernet1/0/4
port hybrid vlan 10 202 untagged
port hybrid pvid vlan 202
interface Ten-GigabitEthernet1/0/5
· Device A:
vlan 1
vlan 10
ip address 10.0.0.1 255.255.255.0
port access vlan 10
Related documentation
· H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 2—LAN Switching Command Reference (R27xx)
· H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 2—LAN Switching Configuration Guide (R27xx)
