- 09-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Port security commands
- 06-Password control commands
- 07-Public key management commands
- 08-PKI commands
- 09-IPsec commands
- 10-SSH commands
- 11-SSL commands
- 12-IP source guard commands
- 13-ARP attack protection commands
- 14-MFF commands
- 15-Crypto engine commands
- 16-FIPS commands
- 17-User profile commands
- 18-Attack detection and prevention commands
- 19-ND attack defense commands
- 20-Keychain commands
17-User profile commands | 36.38 KB |
display user-profile
display user-profile [ name profile-name ] [ slot slot-number ]
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, and underscores (_). The name must start with an English letter. If you do not specify this option, the command displays configuration and online user information for all user profiles.
# Display configuration and online user information for all user profiles.
<Sysname> display user-profile
User-Profile: abc
Inbound:
Policy: abc
Outbound:
Policy: abc
slot 1:
User -:
Authentication type: 802.1X
Network attributes:
Interface : Ten-GigabitEthernet1/0/1
MAC address : 6805-ca06-557b
Service VLAN : 1
User profile name. |
Policy name. |
· 802.1X—802.1X authentication. · MACA—MAC authentication. |
user-profile
Use user-profile to create a user profile and enter user profile view.
Use undo user-profile to remove a user profile.
undo user-profile profile-name
No user profile exists.
profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. A user profile name can only contain English letters, digits, and underscores (_), and it must start with an English letter.
You can use the command to enter the view of an existing user profile.
# Create user profile a123 and enter the view of user profile a123.
[Sysname] user-profile a123
