- 09-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Port security commands
- 06-Password control commands
- 07-Public key management commands
- 08-PKI commands
- 09-IPsec commands
- 10-SSH commands
- 11-SSL commands
- 12-IP source guard commands
- 13-ARP attack protection commands
- 14-MFF commands
- 15-Crypto engine commands
- 16-FIPS commands
- 17-User profile commands
- 18-Attack detection and prevention commands
- 19-ND attack defense commands
- 20-Keychain commands
06-Password control commands | 141.26 KB |
display password-control blacklist
password-control { aging | composition | history | length } enable
password-control alert-before-expire
password-control expired-user-login
password-control login idle-time
password-control login-attempt
password-control super composition
password-control update-interval
reset password-control blacklist
reset password-control history-record
Use display password-control to display password control configuration.
display password-control [ super ]
super: Displays the password control information for the super passwords. If you do not specify this keyword, the command displays the global password control configuration.
# Display the global password control configuration.
Password control: Disabled
Password aging: Enabled (90 days)
Password length: Enabled (10 characters)
Password composition: Enabled (1 types, 1 characters per type)
Password history: Enabled (max history records:4)
Early notice on password expiration: 7 days
Maximum login attempts: 3
Action for exceeding login attempts: Lock user for 1 minutes
Minimum interval between two updates: 24 hours
User account idle time: 90 days
Logins with aged password: 3 times in 30 days
Password complexity: Disabled (username checking)
Disabled (repeated characters checking)
# Display the password control configuration for super passwords.
Password control |
Whether the password control feature is enabled. |
Password aging |
Whether password expiration is enabled and, if enabled, the expiration time. |
Password length |
Whether the minimum password length restriction feature is enabled and, if enabled, the setting. |
Password composition |
Whether the password composition restriction feature is enabled and, if enabled, the settings. |
Password history |
Whether the password history feature is enabled and, if enabled, the setting. |
Early notice on password expiration |
Number of days during which the user is notified of the pending password expiration. |
Maximum login attempts |
Allowed maximum number of consecutive failed login attempts for FTP and VTY users. |
Action for exceeding login attempts |
Action to be taken after a user fails to log in after the specified number of attempts. |
Minimum interval between two updates |
Minimum password update interval. |
Logins with aged password |
Number of times and maximum number of days a user can log in using an expired password. |
Password complexity |
Whether the following password complexity checking is enabled: · username checking—Checks whether a password contains the username or the reverse of the username. · repeated characters checking—Checks whether a password contains any character that appears consecutively three or more times. |
Use display password-control blacklist to display password control blacklist information. The users' IP addresses and user accounts are added to the password control blacklist when the users fail authentication.
display password-control blacklist [ user-name name | ip ipv4-address | ipv6 ipv6-address ]
user-name name: Specifies a user by its name, a case-sensitive string of 1 to 55 characters.
ip ipv4-address: Specifies the IPv4 address of a user.
ipv6 ipv6-address: Specifies the IPv6 address of a user.
If you do not specify any arguments, this command displays information about all users in the password control blacklist.
If an FTP or virtual terminal line (VTY) user fails authentication, the system adds the user to a password control blacklist. You can use this command to view information about these users in the blacklist.
Users accessing the system through the console ports are not blacklisted. This is because the system is unable to obtain the IP addresses of these users and these users are privileged and, therefore, relatively secure to the system.
# Display information about users in the password control blacklist.
<Sysname> display password-control blacklist
Username: test
IP: 192.168.44.1 Login failures: 1 Lock flag: unlock
Blacklist items matched: 1.
IP |
IP address of the user. |
Login failed times |
Number of login failures. |
Lock flag |
Whether the user is prohibited from logging in: · unlock—Not prohibited. · lock—Prohibited temporarily or permanently, depending on the password-control login-attempt command. |
Blacklist items matched |
Number of blacklisted users. |
Use password-control { aging | composition | history | length } enable to enable the password expiration, composition restriction, history, or minimum length restriction feature.
Use undo password-control { aging | composition | history | length } enable to disable a password control feature.
The password control features (aging, composition, history, and length) are all enabled.
aging: Enables the password expiration feature.
composition: Enables the password composition restriction feature.
history: Enables the password history feature.
length: Enables the minimum password length restriction feature.
To enable a specific password control feature, first enable the global password control feature.
The system stops recording history passwords after you execute the undo password-control history enable command, but it does not delete the prior records.
If the global password control feature is enabled but the minimum password length restriction feature is disabled, the following rules apply:
· In non-FIPS mode, a password must contain at least 4 characters and at least 4 characters must be different.
· In FIPS mode, a password must contain at least 15 characters and at least 4 characters must be different.
# Enable the password control feature globally.
# Enable the password composition restriction feature.
[Sysname] password-control composition enable
# Enable the password expiration feature.
[Sysname] password-control aging enable
# Enable the minimum password length restriction feature.
[Sysname] password-control length enable
# Enable the password history feature.
[Sysname] password-control history enable
· display password-control
· password-control enable
Use password-control aging to set the password expiration time.
Use undo password-control aging to restore the default.
A password expires after 90 days. The password expiration time for a user group equals the global setting. The password expiration time for a local user equals that of the user group to which the local user belongs.
System view, user group view, local user view
aging-time: Specifies the password expiration time in days, in the range of 1 to 365.
The expiration time depends on the view:
· The time in system view has global significance and applies to all user groups.
· The time in user group view applies to all local users in the user group.
· The time in local user view applies only to the local user.
A password expiration time with a smaller application scope has higher priority. The system prefers to use the password expiration time in local user view for a local user
· If no password expiration time is configured for the local user, the system uses the password expiration time for the user group to which the local user belongs.
· If no password expiration time is configured for the user group, the system uses the global password expiration time.
# Globally set the passwords to expire after 80 days.
[Sysname] password-control aging 80
# Set the passwords for user group test to expire after 90 days.
[Sysname] user-group test
[Sysname-ugroup-test] password-control aging 90
[Sysname-ugroup-test] quit
# Set the password for device management user abc to expire after 100 days.
[Sysname] local-user abc class manage
[Sysname-luser-manage-abc] password-control aging 100
· display local-user
· display user-group
· password-control aging enable
Use password-control alert-before-expire to set the number of days before a user's password expires during which the user is notified of the pending password expiration.
Use undo password-control alert-before-expire to restore the default.
The default is 7 days.
alert-time: Specifies the number of days before a user password expires during which the user is notified of the pending password expiration. The value range is 1 to 30.
This command is effective only for non-FTP users. FTP users can only have their passwords changed by the administrator.
# Configure the device to notify a user about pending password expiration 10 days before the user's password expires.
[Sysname] password-control alert-before-expire 10
password-control complexity
Use password-control complexity to configure the password complexity checking policy.
Use undo password-control complexity to remove a password complexity checking item.
undo password-control complexity { same-character | user-name } check
The global password complexity checking policy is that both username checking and repeated character checking are disabled. The password complexity checking policy for a user group equals the global setting. The password complexity checking policy for a local user equals that of the user group to which the local user belongs.
same-character: Refuses a password that contains any character appearing consecutively three or more times. For example, the password aaabc is not complex enough.
user-name: Refuses a password that contains the username or the reverse of the username. For example, if the username is 123, a password such as abc123 or 321df is not complex enough.
The password complexity checking policy depends on the view:
· The policy in system view has global significance and applies to all user groups.
· The policy in user group view applies to all local users in the user group.
· The policy in local user view applies only to the local user.
A password complexity checking policy with a smaller application scope has higher priority. The system prefers to use the password complexity checking policy in local user view for a local user.
· If no policy is configured for the local user, the system uses the policy for the user group to which the local user belongs.
· If no policy is configured for the user group, the system uses the global policy.
You can enable both username checking and repeated character checking.
After the password complexity checking is enabled, complexity-incompliant passwords will be refused.
# Configure the password complexity checking policy, refusing any password that contains the username or the reverse of the username.
Use password-control composition to configure the password composition policy.
Use undo password-control composition to restore the default.
In non-FIPS mode, the password using the global composition policy must contain at least one character type and at least one character for each type.
In FIPS mode, the password using the global composition policy must contain at least four character types and at least one character for each type.
In both non-FIPS and FIPS modes, the password composition policy for a user group is the same as the global policy. The password composition policy for a local user is the same as that of the user group to which the local user belongs.
type-number type-number: Specifies the minimum number of character types that a password must contain. The value range for the type-number argument is 1 to 4 in non-FIPS mode and fixed at 4 in FIPS mode. The following character types are available:
· Uppercase letters A to Z.
· Lowercase letters a to z.
· Digits 0 to 9.
· Special characters in Table 3.
Character name |
Symbol |
Character name |
Symbol |
Ampersand sign |
Apostrophe |
Asterisk |
At sign |
Back quote |
Back slash |
Blank space |
N/A |
Caret |
Colon |
Comma |
Dollar sign |
Dot |
Equal sign |
Exclamation point |
Left angle bracket |
Left brace |
Left bracket |
Left parenthesis |
Minus sign |
Percent sign |
Plus sign |
Pound sign |
Quotation marks |
Right angle bracket |
Right brace |
Right bracket |
Right parenthesis |
Semi-colon |
Slash |
Tilde |
Underscore |
_ |
Vertical bar |
type-length type-length: Specifies the minimum number of characters that are from each type in the password. The value range for the type-length argument is 1 to 63 in non-FIPS mode, and 1 to 15 in FIPS mode.
The password composition policy depends on the view:
A password composition policy with a smaller application scope has higher priority. The system prefers to use the password composition policy in local user view for a local user.
The product of the minimum number of character types and minimum number of characters for each type must be smaller than the maximum length of passwords.
# Specify that all passwords must each contain at least four character types and at least five characters for each type.
[Sysname] password-control composition type-number 4 type-length 5
# Specify that passwords in user group test must contain at least four character types and at least five characters for each type.
[Sysname-ugroup-test] password-control composition type-number 4 type-length 5
# Specify that the password of device management user abc must contain at least four character types and at least five characters for each type.
[Sysname-luser-manage-abc] password-control composition type-number 4 type-length 5
· password-control composition enable
Use password-control enable to enable the password control feature globally.
Use undo password-control enable to disable the password control feature globally.
In non-FIPS mode, the password control feature is disabled globally.
In FIPS mode, the password control feature is enabled globally and cannot be disabled.
A specific password control feature takes effect only after the global password control feature is enabled.
After the global password control feature is enabled, you cannot display the password and super password configurations for device management users by using the corresponding display commands. The configuration for network access user passwords can be displayed. The first password configured for device management users must contain at least four different characters.
· password-control { aging | composition | history | length } enable
Use password-control expired-user-login to set the maximum number of days and maximum number of times that a user can log in after the password expires.
Use undo password-control expired-user-login to restore the defaults.
A user can log in three times within 30 days after the password expires.
delay delay: Sets the maximum number of days during which a user can log in using an expired password. The value range for the delay argument is 1 to 90.
times times: Sets the maximum number of times a user can log in after the password expires. The value range is 0 to 10 and 0 means that a user cannot log in after the password expires.
This command is effective only on non-FTP login users. An FTP user cannot continue to log in after its password expires.
# Specify that a user can log in five times within 60 days after the password expires.
Use password-control history to set the maximum number of history password records for each user.
Use undo password-control history to restore the default.
password-control history max-record-num
The maximum number of history password records for each user is 4.
max-record-num: Specifies the maximum number of history password records for each user. The value range is 2 to 15.
When the number of history password records reaches the set maximum number, the subsequent history record overwrites the earliest one.
The system stops recording passwords after you execute the undo password-control history enable command, but it does not delete the prior records.
To delete the existing records, use one of the following methods:
· Use the undo password-control enable command to disable the password control feature globally.
· Use the reset password-control history-record command to clear the passwords manually.
# Set the maximum number of history password records for each user to 10.
[Sysname] password-control history 10
· password-control history enable
· reset password-control blacklist
Use password-control length to set the minimum password length.
Use undo password-control length to restore the default.
In non-FIPS mode, the global minimum password length is 10 characters.
In FIPS mode, the global minimum password length is 15 characters.
In both non-FIPS and FIPS modes, the minimum password length for a user group equals the global setting. The minimum password length for a local user equals that of the user group to which the local user belongs.
length: Specifies the minimum password length in characters. The value range for this argument is 4 to 32 in non-FIPS mode, and 15 to 32 in FIPS mode.
Before you execute this command, make sure the global password control feature and the minimum length feature are enabled. Otherwise, your configuration cannot take effect.
The minimum length setting depends on the view:
· The setting in system view has global significance and applies to all user groups.
· The setting in user group view applies to all local users in the user group.
· The setting in local user view applies only to the local user.
A minimum password length with a smaller application scope has higher priority. The system prefers to use the minimum password length in local user view for a local user.
· If no minimum password length is configured for the local user, the system uses the minimum password length for the user group to which the local user belongs.
· If no minimum password length is configured for the user group, the system uses the global minimum password length.
# Set the global minimum password length to 16 characters.
# Set the minimum password length to 16 characters for user group test.
[Sysname-ugroup-test] password-control length 16
# Set the minimum password length to 16 characters for device management user abc.
[Sysname-luser-manage-abc] password-control length 16
· password-control length enable
Use password-control login idle-time to set the maximum account idle time. If a user account is idle for this period of time, you can no longer use this account to log in to the device.
Use undo password-control login idle-time to restore the default.
You cannot use a user account to log in to the device if the account has been idle for 90 days.
idle-time: Specifies the maximum account idle time in days, in the range of 0 to 365. 0 means no restriction for account idle time.
If a user has not been logged in within the specified idle time since the last successful login, the user account becomes invalid.
# Set the maximum account idle time to 30 days.
Use password-control login-attempt to configure the login attempt limit. The settings include the maximum number of consecutive login failures and the action to be taken when the maximum number is reached.
Use undo password-control login-attempt to restore the default.
The global login-attempt settings:
· The maximum number of consecutive login failures is 3.
· The locking period is 1 minute.
The login-attempt settings for a user group equal the global settings.
The login-attempt settings for a local user equal those for the user group to which the local user belongs.
login-times: Specifies the maximum number of consecutive login failures. The value range is 2 to 10.
exceed: Specifies an action to be taken for the user who fails to log in after making the maximum number of attempts.
· lock: Disables the user account permanently.
· lock-time time: Disables the user account for a period of time. The user can uses this user account when the timer expires. The value range for the time argument is 1 to 360 minutes.
· unlock: Allows the user account to continue using this account to perform login attempts.
The login-attempt policy depends on the view:
A login-attempt policy with a smaller application scope has higher priority. The system prefers to use the login-attempt policy in local user view for a local user.
If an FTP or VTY user fails to log in, the system adds the user account and the user's IP address to the password control blacklist. When the maximum number of consecutive login failures is reached, the login attempt limit feature is triggered.
Whether a blacklisted user and user account are locked depends on the locking setting:
· If a user account is permanently locked for a user, the user cannot use this account unless this account is removed from the password control blacklist. To remove the user account, use the reset password-control blacklist command.
· To use a temporarily locked user account, the user can perform either of the following tasks:
¡ Wait until the locking timer expires.
¡ Remove the user account from the password control blacklist.
· If the user account and the user are blacklisted but not locked, the user can continue using this account to log in. The account and the user's IP address are removed from the password control blacklist when the user uses the account to successfully log in to the device.
NOTE: This account is locked only for this user. Other users can still use this account, and the blacklisted user can use other user accounts. |
The password-control login-attempt command takes effect immediately after being executed, and can affect the users already in the password control blacklist.
# Allow a maximum of four consecutive login failures on a user account, and disable the user account if the limit is reached.
[Sysname] password-control login-attempt 4 exceed lock
# Use the user account test to log in to the device, and enter incorrect password for four times.
# Display the password control blacklist. The output shows that the user account is on the blacklist, and its status is lock.
[Sysname] display password-control blacklist
Username: test
IP: 192.168.44.1 Login failures: 4 Lock flag: lock
# Verify that the user at 192.168.44.1 cannot use this user account to log in.
# Allow a maximum of two consecutive login failures on a user account, and disable the account for 3 minutes if the limit is reached.
[Sysname] password-control login-attempt 2 exceed lock-time 3
# Use the user account test to log in to the device, and enter incorrect password for two attempts.
# Display the password control blacklist. The output shows that the user account is on the blacklist and its status is lock.
Username: test
IP: 192.168.44.1 Login failures: 2 Lock flag: lock
# Verify that after 3 minutes, the user account is removed from the password control blacklist and the user at 192.168.44.1 can use this account.
· display password-control blacklist
password-control super aging
Use password-control super aging to set the expiration time for super passwords.
Use undo password-control super aging to restore the default.
A super password expires after 90 days.
aging-time: Specifies the super password expiration time in days, in the range of 1 to 365.
# Set the super passwords to expire after 10 days.
[Sysname] password-control super aging 10
Use password-control super composition to configure the composition policy for super passwords.
Use undo password-control super composition to restore the default.
In non-FIPS mode, a super password must contain at least one character type and at least one character for each type.
In FIPS mode, a super password must contain at least four character types and at least one character for each type.
type-number type-number: Specifies the minimum number of character types that a super password must contain. The value range for the type-number argument is 1 to 4 in non-FIPS mode and fixed at 4 in FIPS mode.
type-length type-length: Specifies the minimum number of characters that are from each character type. The value range for the type-length argument is 1 to 63 in non-FIPS mode, and 1 to 15 in FIPS mode.
The product of the minimum number of character types and minimum number of characters for each type must be smaller than the maximum length of the super password.
# Specify that a super password must contain at least four character types and at least five characters for each type.
password-control super length
Use password-control super length to set the minimum length for super passwords.
Use undo password-control super length to restore the default.
In non-FIPS mode, the minimum super password length is 10 characters.
In FIPS mode, the minimum super password length is 15 characters.
length: Specifies the minimum length of super passwords in characters. The value range for this argument is 4 to 63 in non-FIPS mode, and 15 to 63 in FIPS mode.
# Set the minimum length of super passwords to 16 characters.
[Sysname] password-control super length 16
Use password-control update-interval to set the minimum password update interval, which is the minimum interval at which users can change their passwords.
Use undo password-control update-interval to restore the default.
password-control update-interval interval
The minimum password update interval is 24 hours.
interval: Specifies the minimum password update interval in hours, in the range of 0 to 168. 0 means no requirements for password update interval.
The set minimum interval is not effective for a user who is prompted to change the password at the first login or after the password expires.
# Set the minimum password update interval to 36 hours.
Use reset password-control blacklist to remove blacklisted users.
reset password-control blacklist [ user-name name ]
user-name name: Specifies the user to be removed from the password control blacklist. The name argument is the username, a case-sensitive string of 1 to 55 characters.
To allow a user blacklisted due to excessive login attempts to log in again, you can use this command to remove the user from the password control blacklist.
# Remove the user named test from the password control blacklist.
<Sysname> reset password-control blacklist user-name test
Are you sure to delete the specified user in blacklist? [Y/N]:
Use reset password-control history-record to delete history password records.
reset password-control history-record [ super [ role role name ] | user-name name ]
super: Deletes the history records of a specified super password or all super passwords.
role role name: Specifies a user role, in the range of 1 to 63.
user-name name: Specifies the username of the user whose password records are to be deleted. The name argument is a case-sensitive string of 1 to 55 characters.
If you do not specify any arguments or keywords, this command deletes the history password records of all local users.
If you do not specify the role role name option, this command deletes the history records of all super passwords.
# Clear the history password records of all local users (enter Y to confirm).
<Sysname> reset password-control history-record
Are you sure to delete all local user's history records? [Y/N]:y
