- 06-Layer 3 - IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-NAT commands
- 06-IP forwarding basics commands
- 07-Fast forwarding commands
- 08-Flow classification commands
- 09-Adjacency table commands
- 10-IRDP commands
- 11-IP performance optimization commands
- 12-UDP Helper commands
- 13-IPv6 basics commands
- 14-DHCPv6 commands
- 15-IPv6 fast forwarding commands
- 16-Tunneling commands
- 17-GRE commands
- 18-ADVPN commands
- 19-AFT commands
- 20-WAAS commands
| 20-WAAS commands | 122.18 KB |
display waas tfo auto-discovery blacklist
reset waas tfo auto-discovery blacklist
waas tfo auto-discovery blacklist enable
waas tfo auto-discovery blacklist hold-time
WAAS commands
class
Use class to specify a Wide Area Application Services (WAAS) class for a WAAS policy and enter WAAS policy class view.
Use undo class to remove a WAAS class from a WAAS policy.
class class-name [ insert-before existing-class ]
undo class class-name
No WAAS class exists in a WAAS policy.
WAAS policy view
class-name: Specifies a WAAS class by its name, a case-insensitive string of 1 to 63 characters. The specified class must already exist.
insert-before existing-class: Inserts the new class before an existing class in the WAAS policy. If you do not specify this option, the new class is placed at the end of the WAAS policy.
A WAAS policy can use system-defined WAAS classes (see Table 7).
A packet is checked against WAAS classes in the specified order. When a packet matches a class, the action for the class is performed on the packet, and the match process ends.
You can also use this command to arrange existing WAAS classes in a WAAS policy.
If you do not configure an action for a WAAS class, the device ignores the WAAS class.
As a best practice, configure a WAAS class by modifying a system-defined WAAS class.
# Specify the system-defined WAAS class AFS for the WAAS policy waas_global, and enter the view of the WAAS class AFS.
[Sysname] waas policy waas_global
[Sysname-waaspolicy-waas_global] class AFS
[Sysname-waaspolicy-waas_global-AFS]
# Specify the system-defined WAAS class AOL for the WAAS policy waas_global, insert it before AFS, and enter the view of the WAAS class AOL.
[Sysname-waaspolicy-waas_global] class AOL insert-before AFS
[Sysname-waaspolicy-waas_global-AOL]
# Change the position of the WAAS class AOL in the WAAS policy waas_global by inserting it before AFS, and enter the view of the WAAS class AOL.
display waas policy
waas class
waas policy
display waas class
Use display waas class to display WAAS classes.
display waas class [ class-name ]
class-name: Specifies a WAAS class by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a WAAS class, this command displays all WAAS classes.
# Display the WAAS class class1.
<Sysname> display waas class class1
WAAS class: class1
match 1 tcp source 1.1.1.1/24 port 50000 60000
match 6 tcp destination 2.2.2.2 port 1 1024
match 11 tcp source 1001::1111/96 port 50000 60000
match 16 tcp destination 2002::2222 port 1 1024
match |
Match criterion of the WAAS class. |
match tcp
waas class
display waas policy
Use display waas policy to display WAAS policies.
display waas policy [ policy-name ]
policy-name: Specifies a WAAS policy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a WAAS policy, this command displays all WAAS policies.
# Display the WAAS policy po1.
<Sysname> display waas policy po1
WAAS policy: po1
class cl1
optimize TFO DRE LZ
class cl2
optimize TFO DRE
class cl3
passthrough
class cl4
optimize TFO LZ
class cl5
WAAS class in the WAAS policy. |
Optimization actions: · TFO (works with only TCP). · DRE. · LZ compression. |
Action that does not perform any optimization. |
class
waas policy
display waas session
Use display waas session to display WAAS session information.
In standalone mode:
display waas session { ipv4 | ipv6 } [ client-ip client-ip ] [ client-port client-port ] [ server-ip server-ip ] [ server-port server-port ] [ peer-id peer-id ] [ verbose ] [ slot slot-number ]
In IRF mode:
display waas session { ipv4 | ipv6 } [ client-ip client-ip ] [ client-port client-port ] [ server-ip server-ip ] [ server-port server-port ] [ peer-id peer-id ] [ verbose ] [ chassis chassis-number slot slot-number ]
ipv4: Specifies IPv4 sessions.
ipv6: Specifies IPv6 sessions.
client-ip client-ip: Displays the WAAS session information for the client specified by its IP address.
client-port client-port: Displays the WAAS session information for the clients specified by port number in the range of 1 to 65535.
server-ip server-ip: Displays the WAAS session information for the server specified by its IP address.
server-port server-port: Displays the WAAS session information for the servers specified by port number in the range of 1 to 65535.
peer-id peer-id: Displays the WAAS session information for the peer specified by its bridge MAC address in the format of H-H-H.
verbose: Displays detailed information about WAAS sessions. If you do not specify this keyword, the command displays brief information about WAAS sessions.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays WAAS session information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays WAAS session information for all cards. (In IRF mode.)
If you specify only the ipv4 or ipv6 keyword, this command displays information about all IPv4 or IPv6 WAAS sessions.
# Display brief information about all IPv4 WAAS sessions.
<Sysname> display waas session ipv4
Peer ID: 0021-90ad-0012
Start Time: Fri Mar 21 10:43:05 2014
Source IP/Port: 1.1.1.1/34572
Destination IP/Port: 2.2.2.2/80
Peer ID: 0011-10ad-0012
Start Time: Fri Mar 21 10:45:05 2014
Source IP/Port: 2.2.1.1/34572
Destination IP/Port: 3.2.2.3/80
Total 2 sessions found.
# Display detailed information about all IPv4 WAAS sessions.
<Sysname> display waas session ipv4 verbose
Peer ID: 0021-90ad0-01221
Start Time: Fri Mar 21 11:43:05 2014
LAN interface: Serial1/0/1
WAN interface: Serial1/0/2
Configured Policy: TFO DRE LZ
Negotiated Policy: TFO DRE LZ
LAN->WAN bytes: Original 104884 Optimized 88594
WAN->LAN bytes: Original 744588 Optimized 3355445
LZ section:
Encode status:
Bytes in: 0
Bytes out: 0
Bypass bytes: 400
Space saved: 0%
Average Latency: 0 usec
Decode status:
Bytes in: 329
Bytes out: 393
Bypass bytes: 63
Space saved: 16%
Average Latency: 2 usec
DRE section:
Encode status:
Bytes in: 0
Bytes out: 0
Bypass bytes: 314
Space saved: 0%
Average latency: 0 usec
Decode status:
Bytes in: 399
Bytes out: 332
Bypass bytes: 0
Space saved: 0%
Chunk miss: 0
Collision: 0
Average latency: 23 usec
Bridge MAC address of the peer device. A bridge MAC address uniquely identifies a peer device. |
Time when the WAAS session was established. |
IP address and port number of the client. |
IP address and port number of the server. |
Optimization actions configured on the local device, which can be one or any combination of the following actions: · TFO (works with only TCP). · DRE. · LZ compression. |
Optimization actions negotiated with the peer device, which can be one or any combination of the following actions: · TFO (works with only TCP). · DRE. · LZ compression. The negotiated optimization actions are the union of the optimization actions configured on the local device and those configured on the peer device. |
Statistics for LAN-to-WAN data: · Original—Number of bytes before optimization. · Optimized—Number of bytes after optimization. |
Statistics for WAN-to-LAN data: · Original—Number of bytes before optimization. · Optimized—Number of bytes after optimization. |
LZ compression statistics. |
DRE statistics. |
Compression statistics. |
Decompression statistics. |
Number of input bytes. |
Number of output bytes. |
Number of bytes bypassed by DRE. |
· Compression ratio: (1–Bytes out/Bytes in) x 100. · Decompression ratio: (1–Bytes in/Bytes out) x 100. |
Average latency in milliseconds for the most recent compression or decompression. When multiple CPUs are available on a card, the average latency is the latency time divided by the number of CPUs. |
Cumulative number of times that DRE failed to find a dictionary entry according to a dictionary index. |
Cumulative number of times that data checks failed. |
display waas statistics dre
Use display waas statistics dre to display DRE statistics.
In standalone mode:
display waas statistics dre [ peer-id peer-id ] [ slot slot-number ]
In IRF mode:
display waas statistics dre [ peer-id peer-id ] [ chassis chassis-number slot slot-number ]
peer-id peer-id: Specifies a peer device by its bridge MAC address in the format of H-H-H. If you do not specify a peer device, the command displays DRE statistics for all peer devices.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DRE statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays DRE statistics for all cards. (In IRF mode.)
# Display DRE statistics for all peer devices.
<Sysname> display waas statistics dre
Peer-ID: 0016-9d38-ca1d
Peer version: 1.0
Cache in storage: 19426304 bytes
Index number: 75884
Age: 00 weeks, 00 days, 00 hours, 00 minutes, 33 seconds
Total connections: 1
Active connections: 0
Encode Statistics
Dre msgs: 2
Bytes in: 392 bytes
Bytes out: 424 bytes
Bypass bytes: 0 bytes
Bytes Matched: 0 bytes
Space saved: -8%
Decode Statistics
Dre msgs: 196407
Bytes in: 29132703 bytes
Bytes out: 42413368 bytes
Space saved: 31%
Peer-ID: 0d38-9d38-ca1d
Peer version: 1.0
Cache in storage: 33554944 bytes
Index number: 131074
Age: 00 weeks, 00 days, 00 hours, 21 minutes, 31 seconds
Total connections: 2
Encode Statistics
Dre msgs: 514872
Bytes in: 111390296 bytes
Bytes out: 60085884 bytes
Bytes Matched: 56336640 bytes
Space saved: 46%
Decode Statistics
Dre msgs: 4
Bytes in: 849 bytes
Bytes out: 785 bytes
Space saved: -8%
# Display DRE statistics for a specific peer device.
<Sysname> display waas statistics dre peer 0016-9d38-ca1d
Peer version: 1.0
Encode Statistics
Dre msgs: 514872
Space saved: 46%
Decode Statistics
Dre msgs: 4
Bytes in: 849 bytes
Space saved: -8%
Peer ID |
WAAS version of the peer device. |
Disk space used by metadata. Metadata are original data that have indexes in the dictionary. |
Number of dictionary indexes. |
Amount of time that has elapsed since the local device initially established an optimized TCP connection with the peer. |
Total number of DRE connections. |
Number of active DRE connections. |
Number of data blocks. |
Bytes in |
Bytes out |
Bypass bytes |
Number of bytes matched by DRE. |
Space saved |
Average Latency |
display waas status
Use display waas status to display the global WAAS status.
display waas status
# Display the global WAAS status.
WAAS Version: 1.0
Local ID: 0023-89b7-5dbb
DRE Status: Enabled
LZ Status: Enabled
BlackList Status: Disabled
Total Active connections: 0
Total data storage size: 0 bytes
Total index number: 0
Blacklist Hold-time: 5 minutes
Interfaces Applied policy
Total policy interfaces: 0
Table 5 Command output
Bridge MAC address of the local device. A bridge MAC address uniquely identifies a local device. |
Total number of active WAAS connections. |
Disk space used by all metadata. Metadata are original data that have indexes in the dictionary. |
Total number of dictionary indexes. |
Aging time for blacklist entries. |
List of interfaces with WAAS policies applied. |
Number of interfaces with WAAS policies applied. |
Use display waas tfo auto-discovery blacklist to display autodiscovered blacklist information.
In standalone mode:
display waas tfo auto-discovery blacklist { ipv4 | ipv6 } [ slot slot-number ]
In IRF mode:
display waas tfo auto-discovery blacklist { ipv4 | ipv6 } [ chassis chassis-number slot slot-number ]
ipv4: Specifies IPv4 blacklist information.
ipv6: Specifies IPv6 blacklist information.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays autodiscovered blacklist information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays autodiscovered blacklist information for all cards. (In IRF mode.)
# Display all IPv4 blacklist information.
<Sysname> display waas tfo auto-discovery blacklist ipv4
Server IP address/Port Insert Time
1.1.1.1/8080 Fri Mar 21 10:43:05 2014
1.1.1.2/8080 Fri Mar 21 10:43:06 2014
2.2.2.2/443 Fri Mar 21 10:20:37 2014
Total 3 entries found.
Table 6 Command output
Time when a blacklist entry was generated. |
match tcp
Use match tcp to configure a match criterion.
Use undo match tcp to delete a match criterion.
match [ match-id ] tcp { any | destination | source } [ ip-address ipv4-address [ mask-length | mask ] | ipv6-address ipv6-address [ prefix-length ] ] [ port port-list ]
undo match match-id
No match criterion exists.
WAAS class view
match-id: Specifies the ID of the match criterion, in the range of 1 to 65535. If you specify an unused ID, you can create a new match criterion. If you specify a used ID, you can modify the existing match criterion. If you do not specify an ID, the system automatically assigns the lowest available ID.
tcp: Matches TCP packets.
any: Matches any TCP packets.
destination: Specifies destination elements for matching TCP packets.
source: Specifies source elements for matching TCP packets.
ip-address ipv4-address: Specifies an IPv4 address for matching TCP packets.
mask-length: Specifies the mask length for the IPv4 address, in the range of 0 to 32. The default is 32.
mask: Specifies the mask for the IPv4 address. The default is 255.255.255.255.
ipv6-address ipv6-address: Specifies an IPv6 address for matching TCP packets.
prefix-length: Specifies the prefix length for the IPv6 address, in the range of 0 to 128. The default is 128.
port port-list: Specifies a space-separated list of up to 10 port items for matching TCP packets. Each item specifies a port number or a range of port numbers in the form of port-number1 to port-number2. The value for port-number2 must be greater than or equal to the value for port-number1. The value range for the port-number argument is 1 to 65535. If you do not specify a port list, all port numbers are matched.
If you specify the destination or source keyword, you must specify the ip-address (or ipv6-address) option, the port option, or both.
If you specify the any keyword, the ip-address (or ipv6-address) option, and the port option, the ip-address (or ipv6-address) and port options match either source or destination fields of packets.
You cannot configure the same match criteria with different match IDs.
A WAAS class can have a maximum of 65535 match criteria. A packet is checked against match criteria in their order of appearance. The packet belongs to the WAAS class if it matches any one of the match criteria.
A WAAS class without any match criteria is not used to match packets.
# Create a WAAS class named http_class, and configure the class to match packets with source IP address 192.168.0.1/16 and port number 80 or port number in the range of 8000 to 8080.
[Sysname] waas class http_class
[Sysname-waasclass-http_class] match tcp source ip-address 192.168.0.1 16 port 80 8000 to 8080
# Create a WAAS class named http_class, and configure the class to match any TCP packets.
[Sysname-waasclass-http_class] match tcp any
display waas policy
waas class
optimize
Use optimize to configure optimization actions for a WAAS class.
Use undo optimize to restore the default.
undo optimize
No optimization actions are configured for a WAAS class.
tfo: Specifies TFO.
dre: Specifies DRE.
lz: Specifies LZ compression.
If you configure both this command and the passthrough command, the most recent configuration takes effect.
An optimization action takes effect only when the corresponding feature is enabled.
An optimization action does not optimize the traffic that matches a blacklist entry.
# Configure optimization actions TFO, DRE, and LZ for the WAAS class AFS.
[Sysname-waaspolicy-waas_global-AFS] optimize tfo dre lz
class
display waas policy
passthrough
waas policy
waas tfo optimize dre
waas tfo optimize lz
passthrough
Use passthrough to configure the pass-through action for a WAAS class.
Use undo passthrough to restore the default.
passthrough
undo passthrough
The pass-through action is not configured.
The pass-through action allows packets to pass through unoptimized.
If you configure both this command and the optimize command, the most recent configuration takes effect.
# Configure the pass-through action for the WAAS class AFS.
class
display waas policy
optimize
waas policy
reset waas cache dre
Use reset waas cache dre to clear DRE data dictionaries.
reset waas cache dre [ peer-id peer-id ]
peer-id peer-id: Specifies a peer device by its bridge MAC address in the format of H-H-H. If you do not specify a peer device, this command clears DRE data dictionaries for all peer devices.
# Clear the DRE data dictionary for the peer device with the bridge MAC address 0789-445d-effa.
<Sysname> reset waas cache dre peer 0789-445d-effa
reset waas statistics dre
Use reset waas statistics dre to clear DRE statistics.
reset waas statistics dre [ peer-id peer-id ]
peer-id peer-id: Specifies a peer device by its bridge MAC address in the format of H-H-H. If you do not specify a peer device, this command clears DRE statistics for all peer devices.
# Clear DRE statistics for all peer devices.
<Sysname> reset waas statistics dre
Use reset waas tfo auto-discovery blacklist to clear all autodiscovered blacklist entries.
# Clear all autodiscovered blacklist entries.
<Sysname> reset waas tfo auto-discovery blacklist
waas apply policy
Use waas apply policy to apply a WAAS policy to an interface.
Use undo waas apply policy to restore the default.
waas apply policy [ policy-name ]
No WAAS policy is applied to an interface.
Interface view
policy-name: Specifies a WAAS policy by its name, a case-insensitive string of 1 to 63 characters. The specified policy must already exist. If you do not specify a WAAS policy, this command applies the system-defined WAAS policy waas_default.
Apply a WAAS policy to an interface that connects to the WAN (not an interface that connects to the LAN). The device optimizes or passes through the traffic entering and leaving the WAN according to the configured policy. If the incoming and outgoing interfaces of the traffic are both connected to the WAN, the traffic is not optimized.
A global logical interface (such as a Layer 3 aggregate interface or VLAN interface) that spans multiple cards or IRF member devices can be used to connect to the WAN. To ensure the traffic optimization effect for such an interface, use the service command to specify one of these cards or IRF member devices to forward traffic for the interface.
# Apply the WAAS policy global_policy to the interface GigabitEthernet 2/1/1.
[Sysname] interface gigabitethernet 2/1/1
[Sysname-GigabitEthernet2/1/1] waas apply policy global_policy
display waas policy
display waas status
waas policy
waas class
Use waas class to create a WAAS class and enter its view, or enter the view of an existing WAAS class.
Use undo waas class to delete a WAAS class.
waas class class-name
undo waas class class-name
Only system-defined WAAS classes exist.
class-name: Specifies a name for the WAAS class, a case-insensitive string of 1 to 63 characters.
As a best practice, configure a WAAS class by modifying a system-defined WAAS class (see Table 7).
# Create a WAAS class named waas_global and enter WAAS class view.
[Sysname] waas class waas_global
[Sysname-waasclass-waas_global]
class
display waas class
waas config remove-all
Use waas config remove-all to delete all WAAS settings.
This command deletes all configuration data and running data for WAAS and exits the WAAS process.
# Delete all WAAS settings.
[Sysname] waas config remove-all
The command will clear all the WAAS configuration. Continue? [Y/N]:y
waas config restore-default
Use waas config restore-default to restore system-defined WAAS settings.
This command restores the system-defined WAAS policy and WAAS classes to their settings at the time when the WAAS process starts for the first time.
To successfully restore system-defined WAAS settings, make sure none of the interfaces has a WAAS policy applied.
# Restore system-defined WAAS settings.
[Sysname] waas config restore-default
The command will restore all the WAAS configuration to default. Continue? [Y/N]:y
waas policy
Use waas policy to create a WAAS policy and enter its view, or enter the view of an existing WAAS policy.
Use undo waas policy to delete a WAAS policy.
waas policy policy-name
undo waas policy policy-name
Only the system-defined WAAS policy waas_default exists.
policy-name: Specifies a name for the WAAS policy, a case-insensitive string of 1 to 63 characters.
To delete a WAAS policy applied to an interface, first remove the WAAS policy from the interface.
As a best practice, configure a WAAS policy by entering the system-defined WAAS policy view and modifying the system-defined WAAS policy. The system-defined WAAS policy is created by the system when the WAAS process starts for the first time. The system-defined WAAS policy uses all system-defined WAAS classes. Only system-defined WAAS classes FTP-Data and FTPS-Data use source ports as match options. All other system-defined WAAS classes use destination ports as match options.
Table 7 System-defined WAAS policy
WAAS actions |
Source ports |
Destination ports |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
3200–3219, 3221–3224, 3226–3267, 3270–3282, 3284–3305, 3307–3388, 3390–3399, 3600–3659, 3662–3699 |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
# Enter system-defined WAAS policy view.
[Sysname] waas policy waas_default
[Sysname-waaspolicy-waas_default]
display waas policy
Use waas tfo auto-discovery blacklist enable to enable the TFO blacklist autodiscovery feature.
Use undo waas tfo auto-discovery blacklist enable to disable the TFO blacklist autodiscovery feature.
The TFO blacklist autodiscovery feature is disabled.
This feature automatically discovers servers that cannot receive TCP packets with options and adds the server IP addresses and port numbers to a blacklist.
During the 3-way handshake, the local device considers the TCP connection attempt failed if either of the following situations occurs:
· The peer device does not respond within the specified time period.
· The peer device closes the TCP connection.
# Enable the TFO blacklist autodiscovery feature.
[Sysname] waas tfo auto-discovery blacklist enable
Use waas tfo auto-discovery blacklist hold-time to set the aging time for autodiscovered blacklist entries.
Use undo waas tfo auto-discovery blacklist hold-time to restore the default.
waas tfo auto-discovery blacklist hold-time minutes
The aging time for autodiscovery blacklist entries is 5 minutes.
minutes: Specifies the aging time for autodiscovered blacklist entries, in the range of 1 to 10080 minutes.
An aging timer is started when a blacklist entry is created. The system automatically deletes an autodiscovered blacklist entry to make room for a new blacklist entry when the aging timer expires.
# Set the aging time to 30 minutes for autodiscovered blacklist entries.
[Sysname] waas tfo auto-discovery blacklist hold-time 30
waas tfo base-congestion-window
Use waas tfo base-congestion-window to set the initial congestion window size for slow start.
Use undo waas tfo base-congestion-window to restore the default.
waas tfo base-congestion-window segments
The initial congestion window size is two TCP segments.
segments: Specifies the initial congestion window size in the range of 1 to 10 TCP segments.
The congestion window size changes with the congestion status and transmission speed. An appropriate initial congestion window size can quickly restore the network to its full transmission capacity after congestion occurs.
# Set the initial congestion window size to three segments.
[Sysname] waas tfo base-congestion-window 3
waas tfo congestion-method
Use waas tfo congestion-method to specify a TCP congestion control algorithm for the WAN side.
Use undo waas tfo congestion-method to restore the default.
waas tfo congestion-method { bic | reno }
WAAS uses BIC as the TCP congestion control algorithm on the WAN side.
bic: Specifies BIC as the TCP congestion control algorithm.
reno: Specifies Reno as the TCP congestion control algorithm.
# Specify Reno as the TCP congestion control algorithm for the WAN side.
[Sysname] waas tfo congestion-method reno
waas tfo keepalive
Use waas tfo keepalive to enable TFO keepalives.
Use undo waas tfo keepalive to disable TFO keepalives.
waas tfo keepalive
TFO keepalives are disabled.
After you enable TFO keepalives, the system starts the 2-hour TCP keepalive timer. If the local device does not send or receive any data when the timer expires, it sends a keepalive to the peer to maintain the connection.
# Enable TFO keepalives.
[Sysname] waas tfo keepalive
Use waas tfo optimize dre to enable DRE.
Use undo waas tfo optimize dre to disable DRE.
DRE is enabled.
The DRE optimization action configured in a WAAS policy takes effect only when DRE is enabled.
# Disable DRE.
[Sysname] undo waas tfo optimize dre
display waas status
Use waas tfo optimize lz to enable LZ compression.
Use undo waas tfo optimize lz to disable LZ compression.
LZ compression is enabled.
The LZ optimization action configured in a WAAS policy takes effect only when LZ compression is enabled.
# Disable LZ compression.
[Sysname] undo waas tfo optimize lz
display waas status
waas tfo receive-buffer
Use waas tfo receive-buffer to set the TFO receiving buffer size.
Use undo waas tfo receive-buffer to restore the default.
waas tfo receive-buffer buffer-size
The TFO receiving buffer size is 64 KB.
buffer-size: Specifies the TFO receiving buffer size in the range of 32 to 16384 KB.
The TFO receiving buffer size affects network throughput.
# Set the TFO receiving buffer size to 1024 KB.
[Sysname] waas tfo receive-buffer 1024
