| 06-Process placement commands | 66.71 KB |
affinity location-set
Use affinity location-set to set the affinity of a process to a set of CPUs.
Use undo affinity location-set to remove the affinity setting for the specified CPUs for a process.
affinity location-set { chassis chassis-number slot slot-number }&<1-5> { attract strength | default | none | repulse strength }
undo affinity location-set { chassis chassis-number slot slot-number }&<1-5>
No location affinity is configured for any process.
Placement process view
chassis chassis-number slot slot-number: Specifies an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the device, which is fixed at 0. (In IRF mode.)
&<1-5>: Indicates that you can specify a maximum of five CPUs.
attract strength: Sets a positive affinity in the range of 1 to 100000. The higher the value, the stronger the preference for the process to run in the specified CPU.
default: Sets the affinity to the default, a positive affinity of 200.
none: Sets the affinity to 0, which means the active process has no preference for any location and the system determines its location.
repulse strength: Sets a negative affinity in the range of 1 to 100000. The higher the value, the weaker the preference for the process to run in the specified CPU.
This command sets the preference for a process to run on a specific CPU.
# (In IRF mode.) Set a positive affinity of 500 to the MPU in slot 0 on IRF member device 1 for BGP.
[Sysname] placement program bgp
[Sysname-program-bgp] affinity location-set chassis 1 slot 0 attract 500
affinity location-type
Use affinity location-type to set the affinity of a process to a location type.
Use undo affinity location-type to remove the affinity setting for the specified location type for a process.
affinity location-type { current | paired | primary } { attract strength | default | none | repulse strength }
undo affinity location-type { current | paired | primary }
No location type affinity is configured for any process.
current: Specifies the affinity to the current location. You can use the display placement program command to view the current location of a process.
paired: Specifies the affinity to the location of a standby process.
primary: Specifies the affinity to the master device. (In IRF mode.)
attract strength: Sets a positive affinity in the range of 1 to 100000. The higher the value, the stronger the preference of the process to run on the specified location type.
none: Sets the affinity to 0.
repulse strength: Sets a negative affinity in the range of 1 to 100000. The higher the value, the weaker the preference for the process to run on the specified location type.
# Set a positive affinity of 500 to the current location for BGP.
[Sysname-program-bgp] affinity location-type current attract 500
affinity program
affinity program
Use affinity program to set the affinity for one process to run on the same location as another process.
Use undo affinity program to remove the affinity setting for one process to run on the same location as the specified process.
affinity program program-name { attract strength | default | none | repulse strength }
undo affinity program program-name
No process affinity is set for any process.
program-name: Specifies the name of a process, a case-insensitive string of 1 to 15 characters. You can use the display placement program all command to view information about placeable processes.
attract strength: Sets a positive affinity in the range of 1 to 100000. The higher the value, the stronger the preference for the current process to run on the same location as the specified process.
none: Sets the affinity to 0, which means the active process has no preference for any other process and the system determines its location.
repulse strength: Sets a negative affinity in the range of 1 to 100000. The higher the value, the weaker the preference for the current process to run on the same location as the specified process.
Use this command to have processes run on the same location or different locations.
# Set a negative affinity of 200 for OSPF to run on the same location as BGP.
[Sysname] placement program ospf
[Sysname-program-ospf] affinity program bgp repulse 200
affinity self
Use affinity self to set the affinity of one instance of a process to any other instance of the same process.
Use undo affinity self to restore the default.
affinity self { attract strength | default | none | repulse strength }
undo affinity self
No self affinity is set for any process.
attract strength: Specifies a positive affinity in the range of 1 to 100000. The higher the value, the stronger the preference for all the instances of the current process to run on the same location.
none: Sets the affinity to 0, which means the instances of the process have no preference to run on the same location and the system determines their locations.
repulse strength: Sets a negative affinity in the range of 1 to 100000. The higher the value, the weaker the preference for all the instances of the current process to run on the same location.
This command sets the preference for a process to run all its instances on the same location or different locations. If the process has only one instance, the command does not take effect.
The self affinity in the placement process view of a process and any of its instances overwrite each other, and whichever is configured the last takes effect on all the instances of the process.
To view the instances of a process, use the display placement program all command.
# Set a negative self affinity of 200 for BGP.
[Sysname-program-bgp] affinity self repulse 200
display ha service-group
Use display ha service-group to display service group information.
display ha service-group { program-name [ instance instance-name ] | all }
program-name: Specifies a service group by its name, a case-insensitive string of 1 to 15 characters.
all: Specifies all service groups running on the device.
instance instance-name: Specifies an instance by its name, a case-insensitive string of 1 to 31 characters. Whether a service group has multiple instances depends on the system software.
# (In IRF mode.) Display information about all service groups.
<Sysname> display ha service-group all
Service Group Current Location State
syslog 1/0/0 Realtime Backup
cryptomgr 1/0/0 Realtime Backup
lagg 1/0/0 Realtime Backup
trange 1/0/0 Realtime Backup
aaa 1/0/0 Realtime Backup
copp 1/0/0 Realtime Backup
lauth 1/0/0 Realtime Backup
ethbase 1/0/0 Realtime Backup
acl 1/0/0 Realtime Backup
oap 1/0/0 Realtime Backup
qos 1/0/0 Realtime Backup
comsh 1/0/0 Realtime Backup
bfd 1/0/0 Realtime Backup
netstream 1/0/0 Realtime Backup
ethoam 1/0/0 Realtime Backup
userprofile 1/0/0 Realtime Backup
mgroup 1/0/0 Realtime Backup
vrrp4 1/0/0 Realtime Backup
vrrp6 1/0/0 Realtime Backup
telnet 1/0/0 Realtime Backup
pppoes 1/0/0 Realtime Backup
pim6 1/0/0 Realtime Backup
rib 1/0/0 Realtime Backup
staticroute 1/0/0 Realtime Backup
ipbase 1/0/0 Realtime Backup
ppp 1/0/0 Realtime Backup
xmlcfg 1/0/0 Realtime Backup
ipaddr 1/0/0 Realtime Backup
l3vpn 1/0/0 Realtime Backup
ospf 1/0/0 Realtime Backup
pbr4 1/0/0 Realtime Backup
pbr6 1/0/0 Realtime Backup
tunnel 1/0/0 Realtime Backup
eviisis 1/0/0 Realtime Backup
l2vpn 1/0/0 Realtime Backup
rib6 1/0/0 Realtime Backup
staticroute6 1/0/0 Realtime Backup
ip6base 1/0/0 Realtime Backup
ip6addr 1/0/0 Realtime Backup
bgpmgr 1/0/0 Realtime Backup
bgp-default 1/0/0 Realtime Backup
ipsec 1/0/0 Realtime Backup
pim 1/0/0 Realtime Backup
vams 1/0/0 Realtime Backup
# (In IRF mode.) Display information about the staticroute service group.
<Sysname>display ha service-group staticroute
staticroute 1/0/0 (Active) Realtime Backup
Detailed information about services of the program:
Service PID Type Location State
ifm 246 Active 1/0/0 Realtime Backup
staticroute 246 Active 1/0/0 Realtime Backup
Service Group |
Service group name. |
Current Location |
Current location of the active processes for a service group. |
State |
Backup state of the active and standby processes for a service group. |
Detailed information about services of the program |
Detailed information about all active and standby processes in a service group. |
Service |
Service name. |
PID |
Process ID. |
Type |
Process type: active or standby. |
Location |
Location of the active process of a service. |
State |
Process status: · Realtime Backup · Batch Backup · Stopping · Degrading · Upgrading |
display placement location
Use display placement location to display the processes running on a specific location.
display placement location { all | chassis chassis-number slot slot-number }
all: Displays all processes running on the device.
chassis chassis-number slot slot-number: Specifies an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the device, which is fixed at 0. If you do not specify an IRF member device, this command displays the processes running on all member devices. (In IRF mode.)
# (In IRF mode.) Display the processes running on IRF member device 1.
<Sysname> display placement location chassis 1 slot 0
Program(s) placed at location: 1/0/0
syslog
cryptomgr
lagg
trange
aaa
copp
lauth
ethbase
acl
oap
qos
comsh
bfd
netstream
ethoam
userprofile
mgroup
vrrp4
vrrp6
telnet
pppoes
pim6
rib
staticroute
ipbase
ppp
xmlcfg
ipaddr
l3vpn
ospf
pbr4
pbr6
ib
tunnel
eviisis
l2vpn
rib6
staticroute6
isis
ip6base
ip6addr
bgpmgr
bgp-default
ipsec
pim
vams
igmp
display placement policy
Use display placement policy to display process placement policy information.
display placement policy program { program-name | all | default }
program-name: Displays the placement policy for a process. The process name is a case-insensitive string of 1 to 15 characters.
all: Displays all process placement policies.
default: Displays the default process placement policy. It is not displayed if no default process placement policy is configured with the placement program default command.
The information about a placement policy is displayed only when the placement policy is configured for the specified process.
# (In IRF mode.) Display the default process placement policy.
Program: [default] : source
affinity self none : system [default]
affinity program bgp none : system [default]
Program |
Process name. |
source |
Source of the setting. The text system [default] identifies a default placement setting configured in the view you enter with the placement program default command. The text system bgp identifies a placement setting for the process bgp configured in the view you enter with the placement program program-name command. |
Use display placement program to display the location of an active process.
display placement program { program-name | all }
program-name: Specifies a process by its name, a case-insensitive string of 1 to 15 characters.
all: Specifies all processes.
# (In IRF mode.) Display the location of BGP.
<Sysname> display placement program bgp
Program Placed at Location
bgp 1/0/0
Program |
Process name. |
Placed at location |
Location of the process. If NA is displayed, the process is not available because the service is abnormal or the process is starting up or shut down. |
display placement reoptimize
Use display placement reoptimize to display the predicted changes that will occur when you run the placement reoptimize command.
display placement reoptimize program { program-name [ instance instance-name ] | all }
program-name: Displays changes for a process (that supports process optimization) specified by its name, a case-insensitive string of 1 to 15 characters.
instance instance-name: Specifies an instance of the specified process by name, a case-insensitive string of 1 to 31 characters. Whether a process has multiple instances depends on the system software.
all: Displays changes for all processes that support process optimization.
# (In IRF mode.) Display the predicted changes for all processes.
<Sysname> display placement reoptimize program all
Program Current location New location
pim6 1/0/0 1/0/0
rib 1/0/0 1/0/0
staticroute 1/0/0 1/0/0
ospf 1/0/0 1/0/0
eviisis 1/0/0 1/0/0
l2vpn 1/0/0 1/0/0
rib6 1/0/0 1/0/0
staticroute6 1/0/0 1/0/0
isis 1/0/0 1/0/0
bgpmgr 1/0/0 1/0/0
bgp-default 1/0/0 1/0/0
ipsec 1/0/0 1/0/0
pim 1/0/0 1/0/0
vams 1/0/0 1/0/0
igmp 1/0/0 1/0/0
The output shows the process name, current location of the active process, and new location of the active process after optimization.
placement program
Use placement program to enter placement process view.
Use undo placement program to delete the placement policy for a process.
placement program { program-name [ instance instance-name ] | default }
undo placement program { program-name [ instance instance-name ] | default }
program-name: Specifies a process name, a case-insensitive string of 1 to 15 characters.
instance instance-name: Specifies the name of an instance of the specified process. The instance name is a case-insensitive string of 1 to 31 characters. If a process has only one instance, the system displays a prompt when you specify this option.
default: Configures the default placement policy for all processes.
You configure a process placement policy to optimize the distribution of processes in your system for optimal distribution of CPU and memory resources.
An active process running only on the master device does not support placement optimization. If you configure a process placement policy for the process, the system displays a configuration failure prompt. When such an active process fails, the system automatically restarts the process. The standby processes are used for active/standby switchover and ISSU. (In IRF mode.)
Some active processes can run on either the master or subordinate device. When such an active process fails, the system uses a placement policy to select a new active process among standby processes. (In IRF mode.)
A process placement policy contains the affinity location-type, affinity location-set, affinity program, and affinity self commands. The commands describe the preferences of the process for a specific location.
You can configure all the affinity commands in the placement policy for a process. Based on the placement policy and hardware resources, the system automatically determines the location for running the process. Before you apply the policy, you can use the display placement reoptimize command to view the predicted location for the process.
# Enter the placement process view of BGP.
# Enter the placement process view of BGP instance 100.
[Sysname] placement program bgp instance 100
[Sysname-program-bgp-100]
# Enter default placement process view.
[Sysname] placement program default
[Sysname-program-default]
Use placement reoptimize to apply configured process placement policies for optimizing process placement.
After you execute this command, the system bases its placement decisions on the new process placement policies, hardware resources, and locations and states of active processes. If the new location for an active process is different from its current location, the system changes its state to standby and the state of the standby process on the new location to active.
To keep the system stable, do not perform any tasks that require process restart when you execute this command.
# (In IRF mode.) Reoptimize process placement.
[Sysname] placement reoptimize
rib 1/0/0 1/0/0
Continue? [y/n]:y
