| 04-BFD commands | 87.01 KB |
bfd multi-hop authentication-mode
bfd multi-hop destination-port
bfd multi-hop detect-multiplier
bfd multi-hop min-receive-interval
bfd multi-hop min-transmit-interval
BFD commands
bfd authentication-mode
Use bfd authentication-mode to configure the BFD authentication mode for single-hop BFD control packets.
Use undo bfd authentication-mode to restore the default.
bfd authentication-mode { m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
Single-hop BFD control packets are not authenticated.
Interface view
BFD template view
m-md5: Specifies the Meticulous MD5 algorithm.
m-sha1: Specifies the Meticulous SHA1 algorithm.
md5: Specifies the MD5 algorithm.
sha1: Specifies the SHA1 algorithm.
simple: Specifies the simple authentication mode.
key-id: Sets the authentication key ID in the range of 1 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 33 to 53 characters.
Use this command to enhance BFD session security.
BFD version 0 does not support this command. The configuration does not take effect.
# Configure GigabitEthernet 1/1/1 to perform simple authentication for single-hop BFD control packets, setting the authentication key ID to 1 and plaintext key to 123456.
[Sysname] interface gigabitethernet 1/1/1
[Sysname-GigabitEthernet1/1/1] bfd authentication-mode simple 1 plain 123456
bfd demand enable
Use bfd demand enable to enable the Demand BFD session mode.
Use undo bfd demand enable to restore the default.
bfd demand enable
The BFD session is in Asynchronous mode.
Interface view
In Demand mode, the device periodically sends BFD control packets. If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets. If the peer end is operating in Demand mode, both ends stop sending BFD control packets. When the connectivity to another system needs to be verified explicitly, a system sends several BFD control packets with the Poll (P) bit set at the negotiated transmit interval. If no response is received within the detection interval, the session is considered down. If the connectivity is found to be up, no more BFD control packets are sent until the next command is issued.
In Asynchronous mode, the device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within a specific interval.
# Enable the Demand BFD session mode on GigabitEthernet 1/1/1.
[Sysname-GigabitEthernet1/1/1] bfd demand enable
bfd detect-interface
Use bfd detect-interface source-ip to create a BFD session for detecting the local interface state.
Use undo bfd detect-interface to remove the BFD session.
bfd detect-interface source-ip ip-address
No BFD session is created for detecting the local interface state.
Interface view
ip-address: Specifies the source IP address for BFD control packets.
This command implements fast collaboration between interface state and BFD session state. When BFD detects a link fault, it sets the link layer protocol state to DOWN(BFD). This behavior helps applications relying on the link layer protocol state achieve fast convergence. The member ports in Layer 3 aggregation groups do not have IP addresses, and they do not support fast detection mechanisms. You can use this command to detect link faults and locate faulty member ports of Layer 3 aggregate interfaces. This command applies to member ports of Layer 3 aggregate interfaces and common Layer 3 Ethernet interfaces.
Before you configure this command, you must enable the BFD control packet mode on both ends of the BFD session. The destination IP address for BFD control packets is 224.0.0.184, and it cannot be configured.
As a best practice, configure the IP address of the interface as the source IP address. If the interface has no IP address configured, configure a unicast address other than 0.0.0.0.
If you configure both the bfd detect-interface and bfd echo enable commands for an interface, only the bfd detect-interface command takes effect.
# Create a BFD session to detect the state of GigabitEthernet 1/1/1, and specify the source IP address as 20.1.1.1.
[Sysname-GigabitEthernet1/1/1] bfd detect-interface source-ip 20.1.1.1
bfd detect-multiplier
Use bfd detect-multiplier to set the single-hop detection time multiplier.
Use undo bfd detect-multiplier to restore the default.
bfd detect-multiplier value
The single-hop detection time multiplier is 5.
Interface view
BFD template view
value: Specifies a single-hop detection time multiplier in the range of 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD packets (including control packets and echo packets) that can be discarded.
Table 1 Detection interval calculation method
Mode |
Detection interval |
Echo packet mode |
Detection time multiplier of the sender × actual packet sending interval of the sender |
Control packet mode BFD session in asynchronous mode |
Detection time multiplier of the receiver × actual packet sending interval of the receiver |
Control packet mode BFD session in demand mode |
# Set the single-hop detection time multiplier to 6 on GigabitEthernet 1/1/1.
[Sysname-GigabitEthernet1/1/1] bfd detect-multiplier 6
bfd echo enable
Use bfd echo enable to enable the echo packet mode.
Use undo bfd echo enable to disable the echo packet mode.
undo bfd echo [ receive | send ] enable
The echo packet mode is disabled.
Interface view
receive: Specifies the echo packet receiving capability.
send: Specifies the echo packet sending capability.
If you enable the echo packet mode for a BFD session in which control packets are sent and the session comes up, BFD performs the following operations:
· Periodically sends echo packets to detect link connectivity.
· Decreases the control packet receiving rate at the same time.
To enable only the echo packet receiving capability, use the bfd echo receive enable command.
To enable only the echo packet sending capability, use the bfd echo send enable command.
If you do not specify the receive or send keyword, the command enables both the echo packet receiving and sending capabilities.
# Enable the echo packet mode on GigabitEthernet 1/1/1.
[Sysname-GigabitEthernet1/1/1] bfd echo enable
bfd echo-source-ip
Use bfd echo-source-ip to configure the source IP address of BFD echo packets.
Use undo bfd echo-source-ip to remove the configured source IP address of BFD echo packets.
bfd echo-source-ip ip-address
No source IP address is configured for BFD echo packets.
ip-address: Specifies the source IP address of BFD echo packets.
As a best practice, do not configure the source IP address to be on the same network segment as any local interface's IP address. If you configure such a source IP address, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IP address of BFD echo packets as 8.8.8.8.
[Sysname] bfd echo-source-ip 8.8.8.8
bfd echo-source-ipv6
Use bfd echo-source-ipv6 to configure the source IPv6 address of BFD echo packets.
Use undo bfd echo-source-ipv6 to remove the configured source IPv6 address of BFD echo packets.
No source IPv6 address is configured for BFD echo packets.
ipv6-address: Specifies the source IPv6 address for BFD echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
As a best practice, do not configure the source IPv6 address to be on the same network segment as any local interface's IP address. If you configure such a source IPv6 address, a large number of ICMPv6 redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IPv6 address of BFD echo packets as 80::2.
[Sysname] bfd echo-source-ipv6 80::2
bfd init-fail timer
Use bfd init-fail-timer to set the delay timer for BFD to notify upper-layer protocols of session establishment failures.
Use undo bfd init-fail-timer to restore the default.
bfd init-fail-timer seconds
BFD does not notify upper-layer protocols of session establishment failures.
seconds: Specifies the delay timer in the range of 5 to 600 seconds.
This command takes effect only for control packet mode.
In some cases, for an upper-layer protocol to act correctly, BFD must notify the upper-layer protocol of session establishment failures. For example, with this command configured, the link aggregation module can promptly set the state of a member port from Selected to Unselected in the case of a link failure.
For session establishment failures caused by configuration mismatches at the two ends, this command can cause the upper-layer protocol to act incorrectly. Therefore, use this command with caution. BFD status mismatch and BFD authentication configuration mismatch are examples of configuration mismatches.
# Set the delay timer to 10 seconds for BFD to notify upper-layer protocols of session establishment failures.
[Sysname] bfd init-fail-timer 10
bfd min-echo-receive-interval
Use bfd min-echo-receive-interval to set the minimum interval for receiving BFD echo packets.
Use undo bfd min-echo-receive-interval to restore the default.
The minimum interval for receiving BFD echo packets is 400 milliseconds.
Interface view
interval: Specifies the minimum interval for receiving BFD echo packets, in milliseconds. A value of 0 means the device does not receive echo packets. The value for this argument takes 0 or is in the range of 10 to 1000.
This command sets the BFD echo packet receiving interval, which is the actual BFD echo packet sending interval.
# Set the minimum interval for receiving BFD echo packets to 500 milliseconds on GigabitEthernet 1/1/1.
[Sysname-GigabitEthernet1/1/1] bfd min-echo-receive-interval 500
bfd min-receive-interval
Use bfd min-receive-interval to set the minimum interval for receiving single-hop BFD control packets.
Use undo bfd min-receive-interval to restore the default.
The minimum interval for receiving single-hop BFD control packets is 400 milliseconds.
Interface view
BFD template view
interval: Specifies the minimum interval for receiving single-hop BFD control packets, in milliseconds. The value range for this argument is 10 to 1000.
Use this command to prevent the control packet sending rate of the peer end from exceeding the control packet receiving rate of the local end.
The actual control packet sending interval of the peer end takes the greater value between the following values:
· Minimum interval for transmitting BFD control packets on the peer end.
· Minimum interval for receiving BFD control packets on the local end.
# Set the minimum interval for receiving single-hop BFD control packets to 500 milliseconds on GigabitEthernet 1/1/1.
[Sysname-GigabitEthernet1/1/1] bfd min-receive-interval 500
bfd min-transmit-interval
Use bfd min-transmit-interval to set the minimum interval for transmitting single-hop BFD control packets.
Use undo bfd min-transmit-interval to restore the default.
The minimum interval for transmitting single-hop BFD control packets is 400 milliseconds.
Interface view
BFD template view
interval: Specifies the minimum interval for transmitting single-hop BFD control packets, in milliseconds. The value range for this argument is 10 to 1000.
Use this command to prevent the BFD packet sending rate from exceeding the device capability. The actual BFD control packet transmitting interval on the local end is the greater value between the following values:
· Minimum interval for transmitting BFD control packets on the local end.
· Minimum interval for receiving BFD control packets on the peer end.
# Set the minimum interval for transmitting single-hop BFD control packets to 500 milliseconds on GigabitEthernet 1/1/1.
[Sysname-GigabitEthernet1/1/1] bfd min-transmit-interval 500
Use bfd multi-hop authentication-mode to configure the authentication mode for multihop BFD control packets.
Use undo bfd multi-hop authentication-mode to restore the default.
bfd multi-hop authentication-mode { m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
No authentication is performed.
# Configure the simple authentication mode for multihop BFD control packets, setting the authentication key ID to 1 and key to 123456.
[Sysname] bfd multi-hop authentication-mode simple 1 plain 123456
Use bfd multi-hop destination-port to configure the destination port number for multihop BFD control packets.
Use undo bfd multi-hop destination-port to restore the default.
The destination port number for multihop BFD control packets is 4784.
port-number: Specifies the destination port number of multihop BFD control packets, 3784 or 4784.
# Specify the destination port number for multihop BFD control packets as 3784.
[Sysname] bfd multi-hop destination-port 3784
Use bfd multi-hop detect-multiplier to set the multihop detection time multiplier.
Use undo bfd multi-hop detect-multiplier to restore the default.
The multihop detection time multiplier is 5.
value: Specifies the multihop detection time multiplier in the range of 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD control packets that can be discarded.
Table 2 Detection interval calculation method
Mode |
# Set the multihop detection time multiplier to 6.
[Sysname] bfd multi-hop detect-multiplier 6
Use bfd multi-hop min-receive-interval to set the minimum interval for receiving multihop BFD control packets.
Use undo bfd multi-hop min-receive-interval to restore the default.
The minimum interval for receiving multihop BFD control packets is 400 milliseconds.
interval: Specifies the minimum interval for receiving multihop BFD control packets, in milliseconds. The value range for this argument is 10 to 1000.
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving capability (minimum control packet receiving interval) of the local end. If the receiving capability is exceeded, the peer end dynamically adjusts the BFD control packet sending interval to the minimum control packet receiving interval of the local end.
# Set the minimum interval for receiving multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-receive-interval 500
Use bfd multi-hop min-transmit-interval to set the minimum interval for transmitting multihop BFD control packets.
Use undo bfd multi-hop min-transmit-interval to restore the default.
The minimum interval for transmitting multihop BFD control packets is 400 milliseconds.
interval: Specifies the minimum interval for transmitting multihop BFD control packets, in milliseconds. The value range for this argument is 10 to 1000.
# Set the minimum interval for transmitting multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-transmit-interval 500
bfd session init-mode
Use bfd session init-mode to configure the mode for establishing a BFD session.
Use undo bfd session init-mode to restore the default.
BFD uses the active mode.
active: Specifies the active mode. In active mode, BFD actively transmits BFD control packets to the remote device, regardless of whether it receives a BFD control packet from the remote device.
passive: Specifies the passive mode. In passive mode, BFD does not actively transmit a BFD control packet to the remote end; it transmits a BFD control packet only after receiving a BFD control packet from the remote end.
A minimum of one end must operate in active mode for a BFD session to be established.
# Configure the session establishment mode as passive.
[Sysname] bfd session init-mode passive
bfd template
Use bfd template to create a BFD template and enter its view, or enter the view of an existing BFD template.
Use undo bfd template to delete the BFD template.
bfd template template-name
undo bfd template template-name
No BFD templates exist.
template-name: Specifies the template name, a case-sensitive string of 1 to 63 characters.
# Create BFD template bfd1 and enter BFD template view.
[Sysname] bfd template bfd1
[Sysname-bfd-template-bfd1]
display bfd session
Use display bfd session to display BFD session information.
display bfd session [ discriminator value | verbose ]
discriminator value: Specifies a local ID in the range of 1 to 4294967295. If this option is not specified, the command displays brief information about all BFD sessions.
verbose: Displays detailed BFD session information. If this keyword is not specified, the command displays brief BFD session information.
# Display all IPv4 BFD session information.
<Sysname> display bfd session
Total Session Num: 1 Up Session Num: 1 Init Mode: Active
513/513 1.1.1.1 1.1.1.2 Up 2297ms GE1/1/1
# Display all IPv6 BFD session information.
IPv6 Session Working Under Ctrl Mode:
Local Discr: 513 Remote Discr: 513
Source IP: FE80::20C:29FF:FED4:7171
Destination IP: FE80::20C:29FF:FE72:AC4D
Session State: Up Interface: GE1/1/2
# Display detailed IPv4 BFD session information.
<Sysname> display bfd session verbose
Source IP: 1.1.1.1 Destination IP: 1.1.1.2
Session State: Up Interface: GigabitEthernet1/1/1
Min Tx Inter: 500ms Act Tx Inter: 500ms
Min Rx Inter: 500ms Detect Inter: 2500ms
Rx Count: 42 Tx Count: 43
Connect Type: Direct Running Up for: 00:00:20
Hold Time: 2078ms Auth mode: None
Detect Mode: Async Slot: 0
Protocol: OSPF
Version: 1
Diag Info: No Diagnostic
# Display detailed IPv6 BFD session information.
Session State: Up Interface: GigabitEthernet1/1/2
Rx Count: 38 Tx Count: 38
Connect Type: Direct Running Up for: 00:00:15
Hold Time: 2211ms Auth mode: None
Protocol: OSPFv3
Version: 1
Total Session Num |
Total number of BFD sessions. |
Up Session Num |
Total number of active BFD sessions. |
Init Mode |
BFD operating mode: Active or passive. |
Session Working Under Ctrl Mode |
IPv4/IPv6 BFD session mode: · Ctrl—Control packet mode. · Echo—Echo packet mode. |
Local Discr/LD |
Local ID of the session. |
Remote Discr/RD |
Remote ID of the session. |
Source IP/SourceAddr |
Source IP address of the session. |
Destination IP/DestAddr |
Destination IP address of the session. |
Session State/State |
Session state: Up or down. |
Name of the interface of the session. |
Min Tx Inter |
Minimum transmit interval. |
Min Rx Inter |
Minimum receive interval. |
Act Tx Inter |
Actual transmit interval. |
Detect Inter |
Actual session detection timer. |
Rx Count |
Number of packets received. |
Tx Count |
Number of packets sent. |
Hold Time/Holdtime |
Length of time before session detection timer expires. For a BFD session in down state, this field displays 0ms. |
Auth mode |
Session authentication mode. |
Connect Type |
Connection type of the interface: Direct or indirect. |
Running up for |
Time period for which the session has been up. |
Detect Mode |
Detection mode: · Async—Asynchronous mode. · Demand—Demand mode. · Async/Echo—Asynchronous mode with echo detection enabled. · Demand/Echo—Demand mode with echo detection enabled. |
Slot |
Slot number. |
Diag Info |
Diagnostic information about the session. |
reset bfd session statistics
Use reset bfd session statistics to clear the BFD session statistics.
# Clear the BFD session statistics.
<Sysname> reset bfd session statistics
snmp-agent trap enable bfd
Use snmp-agent trap enable bfd to enable SNMP notifications for BFD.
Use undo snmp-agent trap enable bfd to disable SNMP notifications for BFD.
All SNMP notifications are enabled for BFD.
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
# Disable SNMP notifications for BFD.
[Sysname] undo snmp-agent trap enable bfd
