| 05-CPOS interface commands | 133.99 KB |
alarm-detect
Use alarm-detect to configure the action to take when an RDI, SD, or SF alarm occurs on an interface.
Use undo alarm-detect to restore the default.
alarm-detect { rdi | sd | sf } action link-down
undo alarm-detect { rdi | sd | sf }
The device does not take any actions on the interface when an RDI, SD, or SF alarm occurs.
CPOS interface view
rdi: Specifies remote defect indication (RDI) alarms.
sd: Specifies signal degrade (SD) alarms.
sf: Specifies signal fail (SF) alarms.
action: Specifies the action to take when the specified alarm is detected on the interface.
link-down: Places the interface in down state.
An RDI alarm occurs if the device receives multiplexer section remote defect indication (MS-RDI) signals from the remote end.
An SD or SF alarm occurs if the bit error rate of incoming packets crosses the SD or SF alarm threshold. To set the SD or SF alarm threshold, use the threshold command.
# Configure CPOS 1/1/1 to go down when an SD alarm occurs.
[Sysname] controller cpos 1/1/1
[Sysname-Cpos1/1/1] alarm-detect sd action link-down
threshold
clock
Use clock to set the clock mode of a CPOS interface.
Use undo clock to restore the default.
clock { master | slave }
undo clock
The clock mode of a CPOS interface is slave.
CPOS interface view
master: Sets the clock mode to master.
slave: Sets the clock mode to slave.
When the clock mode of a CPOS interface is master, it uses the internal clock source.
When the clock mode of a CPOS interface is slave, it uses the line clock source.
When connected to a SONET/SDH device, the CPOS interface must use the slave clock mode. The SONET/SDH network clock is more precise.
When two CPOS interfaces are directly connected, you must configure the two ends with different clock modes.
# Set the clock mode to master for CPOS 1/1/1.
[Sysname-Cpos1/1/1] clock master
controller cpos
Use controller cpos to enter CPOS interface view.
controller cpos cpos-number
cpos-number: Specifies a CPOS interface by its number.
# Enter the interface view of CPOS 1/1/1.
[Sysname-Cpos1/1/1]
default
Use default to restore the default settings for a CPOS interface.
default
CPOS interface view
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network. |
This command might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to check for these commands and perform their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
# Restore the default settings for CPOS 1/1/1.
[Sysname-Cpos1/1/1] default
description
Use description to configure a description for a CPOS interface.
The description of a CPOS interface is in interface name Interface format, for example, Cpos1/1/1 Interface.
CPOS interface view
# Configure the description of CPOS 1/1/1 as CPOS-interface.
[Sysname-Cpos1/1/1] description CPOS-interface
display controller cpos
Use display controller cpos to display status information for CPOS interfaces.
display controller cpos [ cpos-number ]
cpos-number: Specifies a CPOS interface by its number. If you do not specify a CPOS number, this command displays the information about all CPOS interfaces.
This command also displays alarms and errors that occurred to the regenerator section, multiplex section, and higher-order path.
The following table lists the possible error types in the command output.
Table 1 Possible output error types
FRED |
Receive loss of basic frame alignment, or receive frames with red alarm errors. |
COFA |
Change of frame alignment. |
SEF |
Severely error frame. Four consecutive frame synchronization errors generate one SEF. |
FERR |
Framing Bit Error. It refers to frames with the Ft/Fs/FPS/FAS error. |
CERR |
CRC error. |
FEBE |
Far end block error. This error occurs when the E1 channel uses the CRC4 framing format. |
BERR |
PRBS bit error (pseudo-random binary sequence bit error, for test purposes only). |
BIP |
Bit-interleaved parity. |
REI |
Remote error indication. |
In this table, FRED, COFA, and SEF are called alarm errors (AERRs).
# Display CPOS 1/1/1 status information.
<Sysname> display controller cpos 1/1/1
Cpos1/1/1
Current state: UP
Description : Cpos1/1/1 Interface
Frame-format SDH,multiplex AU-4,clock master,loopback none
SD threshold: 6, SF threshold: 3
Optical:Absent
Regenerator section:
Alarm: LOS LOF OOF
ERROR: RS_BIP(B1) 0
Tx: J0: ""
Rx: J0: unknown
Multiplex section:
Alarm: MS_AIS MS_SF MS_SD
ERROR: MS_BIP(B2) 0, MS_REI 0
High order Path(AU-4-1):
Alarm: HP_TIU HP_RDI HP_ERDI HP_PLM
ERROR: HP_BIP(B3) 0, HP_REI 0, HP_PJE 0, HP_NJE 0
TX: J1: ""
RX: J1: unknown
TX: C2: 0x02
RX: C2: 0x6d
TX: S1S0: 0x02
RX: S1S0: 0x02
CT1 1 is down
Frame-format: ESF, clock: slave, loopback: none
CT1 2 is down
CT1 3 is down
CT1 83 is down
CT1 84 is down
Current state |
Current physical state of the CPOS interface. |
Interface description. |
Last clearing of counters |
Time when the reset counters controller cpos command was last used to clear the interface statistics. This field displays Never if the reset counters controller cpos command has never been used on the interface since device startup. |
Frame-format SDH, multiplex AU-4, clock master, loopback none |
Physical layer information of the CPOS interface: · The framing format is SDH. · The multiplexing path is AU-4. · The clock mode is master. · Loopback is disabled. |
SD threshold: 6 , SF threshold: 3 |
SD threshold and SF threshold of the CPOS interface. |
Optical |
Transmission medium. |
Transmitted overhead bytes. |
Received overhead bytes. |
Alarm statistics. |
Error statistics. |
Higher-order path. The multiplex path is AU-4. There is only one VC-4 for STM-1. |
The physical state of T1 channel is down. |
Physical layer information for the T1 channel: · The framing format is ESF. · The clock mode is slave. · Loopback is disabled. |
display controller cpos e1
display controller cpos t1
Use display controller cpos e1 to display status information for an E1 channel on a CPOS interface.
display controller cpos cpos-number e1 e1-number
e1-number: Specifies an E1 channel by its number on a CPOS interface, in the range of 1 to 63.
This command displays errors and alarms that occurred to lower-order paths and E1 frames.
# Display the status information of E1 channel 1 on CPOS 1/1/1.
<Sysname> display controller cpos 1/1/1 e1 1
Cpos1/1/1
Current state: UP
Description: Cpos1/1/1 Interface
Alarm: LP-AIS LP-RDI LP-RFI LP-C2-Mismatched LP-J2-Unstable LP-J2-Mismat
ched
ERROR:BIP2 2, FEBE 1356
TX: J2: ""
RX: J2: unknown
TX: LPC2: 0x02
RX: LPC2: 0x07
CE1 1 is down
Frame-format: NO-CRC4, clock: slave, loopback: none
Alarm: AIS LFA Red
Error: 0 Fer
Current state |
If the J2 overhead bytes are invisible characters, this field displays RX: J2: unknow. |
Alarm |
Alarm statistics. |
Error |
Error statistics. |
CE1 1 is down |
E1 channel 1 is physically down. |
Frame-format: NO-CRC4, clock: slave, loopback: none |
Physical layer information for the E1 channel: · The framing format is NO-CRC4. · The clock mode is slave. · Loopback is disabled. |
Use display controller cpos t1 to display status information for a T1 channel on a CPOS interface.
display controller cpos cpos-number t1 t1-number
t1-number: Specifies a T1 channel by its number on a CPOS interface. The value range for this argument is 1 to 84.
This command displays errors and alarms that occurred to lower-order paths and T1 frames.
# Display the status information of T1 channel 1 on CPOS 1/1/1.
<Sysname> display controller cpos 1/1/1 t1 1
Cpos1/1/1
Current state: UP
ched
ERROR:BIP2 2, FEBE 1958
TX: J2: ""
RX: J2: unknown
TX: LPC2: 0x02
RX: LPC2: 0x07
CT1 1 is down
Frame-format: ESF, Clock: slave, Loopback: none
Alarm: AIS LFA Red Bit Error 0, Fer 0, OOF 0
Current state |
Received overhead bytes. If the J2 overhead bytes are invisible characters, this field displays RX: J2: unknow. |
Alarm |
Alarm statistics. |
Error |
Error statistics. |
CT1 1 is down |
T1 channel 1 is physically down. |
e1 channel-set
Use e1 channel-set to bundle timeslots on an E1 channel into one channel set.
Use undo e1 channel-set to remove a channel set.
e1 e1-number channel-set set-number timeslot-list range
undo e1 e1-number channel-set set-number
An E1 channel is not channelized.
e1-number: Specifies an E1 channel by its number on the CPOS interface. The value range for this argument is 1 to 63.
set-number: Specifies a channel set number in the range of 0 to 30.
timeslot-list range: Specifies a comma-separated list of timeslot items. An item can be an individual timeslot or a timeslot range. Use a hyphen (-) to separate the start and end timeslot numbers of a range. The value range for the timeslot number is 1 to 31.
When the E1 channel is channelized, timeslot 0 is used for synchronization. The other 31 timeslots can be bundled to form one or multiple serial interfaces. These serial interfaces use the interface number/channel number:channel set number format.
IMPORTANT: For successful communication, make sure the local end has the same timeslot bundling settings as the remote end. |
# Bundle timeslots 1 to 31 into a channel set on E1 channel 63.
[Sysname-Cpos1/1/1] e1 63 channel-set 1 timeslot-list 1-31
# Enter the view of the serial interface created for the channel set.
[Sysname-Cpos1/1/1] quit
[Sysname] interface serial 1/1/1/63:1
[Sysname-Serial1/1/1/63:1]
e1 unframed
e1 clock
Use e1 clock to set the clock mode of an E1 channel.
Use undo e1 clock to restore the default clock mode of an EI channel.
e1 e1-number clock { master | slave }
undo e1 e1-number clock
The clock mode of an E1 channel is slave.
CPOS interface view
The clock mode settings of E1 channels on a CPOS interface are independent of one another.
Set the clock mode on an E1 channel depending on its connected device.
· If the connected device is a SONET/SDH device, enable the slave clock mode on the channel. The SONET/SDH network clock is more precise than the clock provided by the device.
· If the E1 channel is directly connected to a router, make sure the E1 channel uses a different clock mode than the peer end.
# Set the clock mode to master on E1 channel 1.
[Sysname-Cpos1/1/1] e1 1 clock master
e1 flag
Use e1 flag to set the C2 or J2 overhead byte for an E1 channel.
Use undo e1 flag to restore the default C2 or J2 overhead byte for an E1 channel.
e1 e1-number flag { c2 c2-value | j2 { sdh | sonet } j2-string }
undo e1 e1-number flag { c2 | j2 { sdh | sonet } }
C2 is 02 (hexadecimal) and J2 is cyclic null.
CPOS interface view
e1-number: Specifies an E1 channel by its number. The value range for this argument is 1 to 63.
c2: Specifies the low-order channel signal tag byte C2.
c2-value: Specifies the value of the low-order channel signal flag byte C2, one byte in length and in the range of 0x0 to 0x7 (except 0x5).
j2: Specifies the low-order channel trace byte J2.
sdh: Specifies the trace byte in SDH format.
sonet: Specifies the trace byte in SONET format.
j2-string: Specifies the low-order channel trace byte J2, a string of 1 to 15 characters for SDH or a string of 1 to 62 characters for SONET.
# Set C2 to 0x7 for E1 channel 3 on CPOS 1/1/1.
[Sysname-Cpos1/1/1] e1 3 flag c2 7
e1 frame-format
Use e1 frame-format to set the framing format of an E1 channel.
Use undo e1 frame-format to restore the default framing format of an E1 channel.
e1 e1-number frame-format { crc4 | no-crc4 }
undo e1 e1-number frame-format
The framing format of an E1 channel is no-CRC4.
CPOS interface view
crc4: Sets the framing format to CRC4.
no-crc4: Sets the framing format to no-CRC4.
# Set the framing format to CRC4 for E1 channel 1.
[Sysname-Cpos1/1/1] e1 1 set frame-format crc4
e1 loopback
Use e1 loopback to set the loopback mode for an E1 channel.
Use undo e1 loopback to disable loopback for an EI channel.
e1 e1-number loopback { local | payload | remote }
undo e1 e1-number loopback
Loopback is disabled on an E1 channel.
CPOS interface view
local: Enables internal loopback.
payload: Enables external payload loopback.
remote: Enables external loopback.
You can test E1 channels by using the loopback command with different keywords.
· In an internal loopback, the sender's data is directly looped to the receiver.
· In an external payload loopback, data received by the receiver is looped back at the E1 framer as payload.
· In an external loopback, data received by the receiver is looped back directly without passing through the E1 framer.
# Enable external payload loopback on E1 channel 1.
[Sysname-Cpos1/1/1] e1 1 set loopback payload
e1 shutdown
Use e1 shutdown to shut down an E1 channel.
Use undo e1 shutdown to bring up an E1 channel.
e1 e1-number shutdown
undo e1 e1-number shutdown
E1 channels are up.
CPOS interface view
When you shut down an E1 channel, its associated serial interfaces are also shut down.
[Sysname-Cpos1/1/1] e1 1 shutdown
e1 unframed
Use e1 unframed to configure an E1 channel on a CPOS interface to operate in unframed mode.
Use undo e1 unframed to restore the default operating mode of an EI channel on a CPOS interface.
e1 e1-number unframed
undo e1 e1-number unframed
E1 channels on a CPOS interface operate in framed mode.
CPOS interface view
e1-number: Specifies an E1 channel by its number on a CPOS interface. The value range for this argument is 1 to 63.
E1 channels on CPOS interfaces support the unframed (clear channel) mode and the framed (channelized) mode.
· In unframed mode, an E1 channel can form a 2.048 Mbps serial interface without timeslot division. It is numbered in the format of Serial interface number/channel number:0.
· In framed mode, all timeslots except timeslot 0 on the E1 channel can be bundled randomly to form serial interfaces.
# Set E1 channel 3 on CPOS 1/1/1 to operate in unframed mode.
[Sysname-Cpos1/1/1] e1 3 unframed
flag
Use flag to set an overhead byte for SONET/SDH frames.
Use undo flag to restore the default of the specified overhead byte for SONET/SDH frames.
flag { c2 path-number c2-value | s1s0 path-number s1s0-value }
undo flag { c2 path-number | s1s0 path-number }
flag { j0 | j1 path-number } { sdh | sonet } flag-value
undo flag { j0 | j1 path-number } { sdh | sonet }
· c2 is 0x02.
· s1s0 is 0x00 for SONET and 0x02 for SDH.
· j0 is 0x01 for SONET and a 16-byte null character for SDH.
· j1 is a 64-byte null character for SONET and a 16-byte null character for SDH.
CPOS interface view
c2 path-number c2-value: Specifies the number of a path and the path signal label byte. The value range for the c2-value argument is 0x00 to 0xFF.
s1s0 path-number s1s0-value: Specifies the number of a path and the AU type and TU type. The value range for the s1s0-value argument is 0 to 3.
j0 flag-value: Specifies the regenerator section trace message, which is a section overhead byte used to detect the continuity of the connection between two interfaces at the section layer. In SDH frames, the flag-value argument is a string of 1 to 15 characters. In SONET frames, the flag-value argument is in the range of 0x00 to 0xFF.
j1 path-number: Specifies the path trace message, which is a higher-order path overhead byte used to detect the continuity of the connection between two interfaces at the path layer. In SDH frames, the flag-value argument is a string of 1 to 15 characters. In SONET frames, the flag-value argument is a string of 1 to 62 characters.
sdh: Specifies the SDH framing format.
sonet: Specifies the SONET framing format.
SONET/SDH frames provide a variety of overhead bytes for operation and maintenance (OAM) such as layered management on transmission networks.
J1, J0 and C2 are used to support interoperability between devices from different countries, areas, and vendors.
J0 is a section overhead byte used for detecting the continuity of the connection between two interfaces at the section layer. J1 and C2 are higher-order path overhead bytes. The J1 byte is used for detecting the continuity of the connection between two interfaces at the path layer. The C2 byte is used for indicating the multiplexing structure of a VC frame and the property of payload.
S1S0 are two bits in the H1 byte. They are used by ITU to indicate the AU-n/TU-n type. S1S0 must be set to 2 for AU-4, AU-3, and TU-3.
# Set J0 to aa on CPOS 1/1/1.
[Sysname-Cpos1/1/1] flag j0 sdh aa
flag vc-3
Use flag vc-3 to set an overhead byte for VC-3 frames.
Use undo flag vc-3 to restore the default of the specified overhead byte for VC-3 frames.
flag vc-3 path-number { c2 c2-value | j1 { sdh sdh-string | sonet sonet-string } | s1s0 s1s0-value }
undo flag vc-3 path-number { c2 | j1 { sdh | sonet } | s1s0 }
· c2 is 0x02.
· s1s0 is 0 (hexadecimal) for SONET and 2 (hexadecimal) for SDH.
CPOS interface view
path-number: Specifies a channel by its number in VC-3.
c2 c2-value: Specifies the path signal label byte in the range of 0x00 to 0xFF.
j1 sdh sdh-string: Specifies the higher order path trace byte for SDH frames, a string of 1 to 15 characters.
j1 sonet sonet-string: Specifies the higher order path trace byte for SONET frames, a string of 1 to 62 characters.
s1s0 s1s0-value: Specifies the AU/TU type indicator.
A large set of overhead bytes are available to implement operation, administration, and maintenance (OAM) functions such as hierarchical management of transmission networks for SONET/SDH frames.
The J1 and C2 bytes are higher-order path overhead bytes. The J1 byte is used for detecting the continuity of the connection between two interfaces at the path layer. The C2 byte is used for indicating the multiplexing structure of a VC frame and the property of payload. The J1 and C2 bytes are mainly used for interoperability between devices from different countries, areas, and vendors.
# Set the C2 overhead byte to 2 for VC-3 frames on channel 2 of VC-3 on CPOS 1/1/1.
[Sysname-Cpos1/1/1] flag vc-3 2 c2 2
flag vc-4
Use flag vc-4 to set an overhead byte for VC-4 frames.
Use undo flag vc-4 to restore the default of the specified overhead byte for VC-4 frames.
flag vc-4 path-number { c2 c2-value | j1 { sdh sdh-string | sonet sonet-string } | s1s0 s1s0-value }
undo flag vc-4 path-number { c2 | j1 { sdh | sonet } | s1s0 }
· c2 is 0x02.
CPOS interface view
path-number: Specifies a channel by its number in VC-4.
A large set of overhead bytes are available to implement operation and maintenance (OAM) functions such as hierarchical management of transmission networks for SONET/SDH frames.
# Set the J1 byte to abcd for VC-4 frames on channel 1 of VC-4 on CPOS 1/1/1 in SDH mode.
[Sysname-Cpos1/1/1] flag vc-4 1 j1 sdh abcd
frame-format
Use frame-format to set the framing format on a CPOS interface.
Use undo frame-format to restore the default framing format on a CPOS interface.
frame-format { sdh | sonet }
undo frame-format
The framing format on a CPOS interface is SDH.
CPOS interface view
# Set the framing format to SONET on CPOS 1/1/1.
[Sysname-Cpos1/1/1] frame-format sonet
link-delay
Use link-delay to set the physical state change suppression interval on a CPOS interface.
Use undo link-delay to restore the default.
link-delay seconds
undo link-delay
The physical state change suppression interval is 0 seconds on a CPOS interface.
CPOS interface view
seconds: Sets the physical state change suppression interval in seconds. The value range for this argument is 0 to 30.
When the physical state changes, a CPOS interface reports the event to the upper-layer modules, and generates log and SNMP notification messages. To reduce system overhead caused by frequent physical state changes, use this command to suppress physical state changes within an interval. The interface will ignore any changes that occur during each suppression interval. When the suppression interval expires, the interface will not report the change event or generate messages if the change is removed.
For example, the suppression interval starts when the interface changes from up to down. The interface reports the change event and generates messages if it is still down when the interval expires. The interface does not report the change event or generate messages if it is up when the interval expires.
# Set the physical state change suppression interval to 8 seconds on CPOS 1/1/1.
[Sysname-Cpos1/1/1] link-delay 8
loopback
Use loopback to enable loopback on a CPOS interface.
Use undo loopback to disable loopback on a CPOS interface.
loopback { local | remote }
undo loopback
Loopback is disabled on a CPOS interface.
CPOS interface view
local: Enables internal loopback to test the physical interface.
remote: Enables external loopback to test the cable connected to the interface.
Loopback is intended for testing only. Disable the feature when the interface is operating correctly.
# Enable external loopback testing on CPOS 1/1/1.
[Sysname-Cpos1/1/1] loopback remote
multiplex mode
Use multiplex mode to set AUG multiplexing mode for a CPOS interface.
Use undo multiplex mode to restore the default AUG multiplexing mode for a CPOS interface.
multiplex mode { au-3 | au-4 }
undo multiplex mode
The AUG multiplexing mode is au-4.
CPOS interface view
au-3: Gets AUG through AU-3.
au-4: Gets AUG through AU-4.
SDH provides the following payload mapping/multiplexing solutions:
· ANSI—Uses the AU-3 multiplexing scheme. This scheme multiplexes the lower-order payload to the VC-3 higher-order path. VC-3 plus an AU pointer forms AU-3. Three such AU-3s can be synchronized and multiplexed to form one AUG.
· ETSI—Uses the AU-4 multiplexing scheme. This scheme multiplexes the lower-order payload to the VC-4 higher-order path. VC-4 plus an AU pointer forms an AU-4. This AU-4 can be synchronized and multiplexed to form one AUG.
When the CPOS interface is operating in SDH mode, you can multiplex AUG to AU-4 or AU-3 by using the multiplex mode command.
When the CPOS interface is operating in SONET mode, AUG can be multiplexed only to AU-3. The multiplex mode command does not take effect.
Countries and regions use different multiplexing schemes. You must use the same multiplexing scheme as the peer device. For example, the AU-4 multiplexing scheme is used in China.
# In SDH mode, multiplex AUG to AU-3.
[Sysname-Cpos1/1/1] frame-format sdh
[Sysname-Cpos1/1/1] multiplex mode au-3
frame-format
oc-12
Use oc-12 to create a 622 Mbps channel on a 2.5 Gbps CPOS interface and enter 622 Mbps channel view, or enter the view of an existing 622 Mbps channel.
Use undo oc-12 to delete a 622 Mbps channel.
oc-12 oc-12-number
undo oc-12 oc-12-number
No 622 Mbps channels exist on a 2.5 Gbps CPOS interface.
2.5 Gbps CPOS interface view
oc-12-number: Specifies a 622 Mbps channel number in the range of 1 to 4.
You can create up to four 622 Mbps channels on a 2.5 Gbps CPOS interface operating in channelized mode.
When you delete a 622 Mbps channel, all low-order channels on it and all the related POS channel interfaces are deleted automatically. Low-order channels include 155 Mbps channels.
# Create a 622 Mbps channel with a channel number of 2 on 2.5 Gbps CPOS interface CPOS 1/1/1.
[Sysname-Cpos1/1/1] oc-12 2
[Sysname-Cpos1/1/1-oc-12-2]
oc-3
Use oc-3 to create a 155 Mbps channel on a 622 Mbps channel and enter 155 Mbps channel view, or enter the view of an existing 155 Mbps channel.
Use undo oc-3 to delete a 155 Mbps channel.
oc-3 oc-3-number
undo oc-3 oc-3-number
No 155 Mbps channels exist on a 622 Mbps channel.
oc-3-number: Specifies a 155 Mbps channel number in the range of 1 to 4.
You can create up to four 155 Mbps channels on a 622 Mbps channel operating in channelized mode.
A 155 Mbps channel created on a 2.5 Gbps CPOS interface can only operate in concatenated mode. When you create a 155 Mbps channel, the system automatically sets its operating mode to concatenated.
When you delete a 155 Mbps channel, its POS channel interface is deleted automatically.
# Create a 155 Mbps channel with a channel number of 1 on a 622 Mbps channel on CPOS 1/1/1.
[Sysname-Cpos1/1/1] oc-12 1
[Sysname-Cpos1/1/1-oc-12-1] oc-3 1
[Sysname-Cpos1/1/1-oc-12-1-oc-3-1]
Use reset counters controller cpos to clear CPOS interface statistics.
reset counters controller cpos [ interface-number ]
interface-number: Specifies an interface by its number. If you do not specify an interface, this command clears statistics for all CPOS interfaces.
Use this command to clear history statistics before you collect traffic statistics for a time period.
To display CPOS interface statistics, use the display controller cpos command.
# Clear statistics for CPOS 1/1/1.
<Sysname> reset counters controller cpos 1/1/1
shutdown
Use shutdown to shut down a CPOS physical interface.
Use undo shutdown to bring up a CPOS physical interface.
shutdown
The CPOS physical interface is up.
The shutdown command on the CPOS physical interface shuts down all E1/T1 channels and serial interfaces formed by timeslot bundles. As a result, they stop transmitting and receiving data. To bring them up, use the undo shutdown command on the CPOS physical interface.
t1 channel-set
Use t1 channel-set to bundle timeslots on a T1 channel into one channel set.
Use undo t1 channel-set to remove a channel set.
t1 t1-number channel-set set-number timeslot-list range [ speed { 56k | 64k } ]
undo t1 t1-number channel-set set-number
A T1 channel is not channelized.
CPOS interface view
t1-number: Specifies a T1 channel by its number on the CPOS interface. The value range for this argument is 1 to 84.
set-number: Specifies a channel set by its number in the range of 0 to 23.
timeslot-list range: Specifies a comma-separated list of timeslot items. An item can be an individual timeslot or a timeslot range. Use a hyphen (-) to separate the start and end timeslot numbers of a range. The value range for the timeslot number is 1 to 24.
speed: Specifies the speed of a timeslot. The default timeslot speed is 64 kbps.
When you bundle timeslots on a T1 channel, the system automatically creates a serial interface numbered interface number/channel number:channel set number. The interface speed is the number of bundled timeslots multiplying the timeslot speed specified in this command.
# Bundle timeslots 1 through 23 into a channel set on T1 channel 1.
[Sysname-Cpos1/1/1] t1 1 channel-set 1 timeslot-list 1-23
[Sysname] interface serial 1/1/1/1:1
[Sysname-Serial1/1/1/1:1]
t1 unframed
t1 clock
Use t1 clock to set the clock mode of a T1 channel.
Use undo t1 clock to restore the default clock mode of a T1 channel.
t1 t1-number clock { master | slave }
undo t1 t1-number clock
The clock mode of a T1 channel is slave.
CPOS interface view
The clock mode settings of the T1 channels on a CPOS interface are independent of one another.
Set the clock mode on a T1 channel depending on its connected device.
· If the T1 channel is directly connected to a router, make sure the T1 channel uses a different clock mode than the peer end.
# Set the clock mode to master on T1 channel 1.
[Sysname-Cpos1/1/1] t1 1 clock master
t1 flag
Use t1 flag to set the C2 or J2 overhead byte for a T1 channel.
Use undo t1 flag to restore the default C2 or J2 overhead byte for a T1 channel.
t1 t1-number flag { c2 c2-value | j2 { sdh | sonet } j2-string }
undo t1 t1-number flag { c2 | j2 { sdh | sonet } }
C2 is 0x02 and J2 is cyclic null.
CPOS interface view
t1-number: Specifies a T1 channel by its number. The value range for this argument is 1 to 84.
c2-value: Specifies the value of the low-order channel signal tag byte C2, one byte in length and in the range of 0x0 to 0x7 (except 0x5).
j2-string: Specifies the low-order channel trace byte J2, a string of 1 to 15 characters (in SDH format) or of 1 to 62 characters (in SONET format).
# Set C2 to 0x7 for T1 channel 3 on CPOS 1/1/1.
[Sysname-Cpos1/1/1] t1 3 flag c2 7
t1 frame-format
Use t1 frame-format to set the framing format for a T1 channel.
Use undo t1 frame-format to restore the default framing format for a T1 channel.
t1 t1-number frame-format { esf | sf }
undo t1 t1-number frame-format
The framing format for a T1 channel is ESF.
CPOS interface view
esf: Specifies the extended super frame (ESF) format.
sf: Specifies the super frame (SF) format.
# Set the framing format to SF for T1 channel 1.
[Sysname-Cpos1/1/1] t1 1 set frame-format sf
t1 loopback
Use t1 loopback to set the loopback mode for a T1 channel.
Use undo t1 loopback to disable loopback for a T1 channel.
t1 t1-number loopback { local | payload | remote }
undo t1 t1-number loopback
Loopback is disabled on T1 channels.
CPOS interface view
Loopback is intended for testing only. Disable the feature when the TI channel is operating correctly.
# Enable external loopback on T1 channel 1.
[Sysname-Cpos1/1/1] t1 1 set loopback payload
t1 shutdown
Use t1 shutdown to shut down a T1 channel.
Use undo t1 shutdown to bring up a T1 channel.
t1 t1-number shutdown
undo t1 t1-number shutdown
T1 channels are up.
CPOS interface view
When you shut down a T1 channel, its associated serial interfaces are also shut down.
# Shut down T1 channel 1.
[Sysname-Cpos1/1/1] t1 1 shutdown
t1 unframed
Use t1 unframed to configure a T1 channel on a CPOS interface to operate in unframed mode.
Use undo t1 unframed to restore the default operating mode of a T1 channel on a CPOS interface.
t1 t1-number unframed
undo t1 t1-number unframed
T1 operates in framed mode.
CPOS interface view
T1 channels on CPOS interfaces support the unframed (clear channel) mode and the framed (channelized) mode.
· In unframed mode, a T1 channel can form a 1.544 Mbps serial interface without timeslot division. This interface is numbered in the format of Serial interface number/channel number:0.
· In framed mode, 24 timeslots of a T1 channel can be bound randomly to form serial interfaces.
# Set T1 channel 3 on CPOS 1/1/1 to operate in unframed mode.
[Sysname-Cpos1/1/1] t1 3 unframed
threshold
Use threshold to configure the power for setting the SD or SF alarm threshold on a CPOS interface.
Use undo threshold to restore the default power for setting the SD or SF alarm threshold on a CPOS interface.
threshold { sd sdvalue | sf sfvalue } *
undo threshold [ sd | sf ]
The SD threshold is 10e to the power of negative 6 (10e–6). The SF threshold is 10e to the power of negative 3 (10e–3).
CPOS interface view
sd: Specifies the SD alarm threshold.
sdvalue: Specifies the power for setting the SD alarm threshold. The threshold is 10e to the power of negative sdvalue (10e–sdvalue). The value range for this argument is 3 to 9. The greater the value, the lower the SD alarm threshold.
sf: Specifies the SF alarm threshold. The SF alarm threshold must be higher than the SD alarm threshold.
sfvalue: Specifies the power for setting the SF alarm threshold. The threshold is 10e to the power of negative sdvalue (10e–sfvalue). The value range for this argument is 3 to 9. The greater the value, the lower the SF alarm threshold.
SD and SF alarms indicate line performance. SF alarms are more severe than SD alarms.
· An SD alarm occurs if the number of B2 errors reaches the SD alarm threshold.
· An SF alarm occurs if the number of B2 errors reaches the SF alarm threshold.
# Set the SD threshold to 10e to the power of negative 4 (10e–4) on CPOS 1/1/1.
[Sysname] interface cpos 1/1/1
[Sysname-Cpos1/1/1] threshold sd 4
using oc-12/using oc-12c
Use using oc-12 to set a 622 Mbps channel to channelized mode.
Use using oc-12c to set a 622 Mbps channel to concatenated mode.
Use undo using to restore the default.
using { oc-12 | oc-12c }
undo using
A 622 Mbps channel operates in channelized mode.
When you set a 622 Mbps channel to concatenated mode, the system automatically creates a 622 Mbps POS channel interface for the channel. The POS channel interface uses the POS interface number [/622 Mbps channel number]:0 format.
When you execute the using oc-12 or undo using command to change the 622 Mbps channel mode from concatenated to channelized, the system automatically deletes the POS channel interface.
# Configure 622 Mbps channel 1 on CPOS 1/1/1 to operate in concatenated mode.
[Sysname-Cpos1/1/1-oc-12-1] using oc-12c
# Configure 622 Mbps channel 1 on CPOS 1/1/1 to operate in channelized mode.
[Sysname-Cpos1/1/1-oc-12-1] undo using
using oc-3c
Use using oc-3c to set a 155 Mbps channel to concatenated mode.
using oc-3c
A 155 Mbps channel operates in channelized mode.
When you set a 155 Mbps channel to concatenated mode, the system automatically creates a 155 Mbps POS channel interface for the channel. The POS channel interface uses the POS interface number [ [/622 Mbps channel number]/155 Mbps channel number]:0 format.
# Configure 155 Mbps channel 1 on CPOS 1/1/1 to operate in concatenated mode.
[Sysname-Cpos1/1/1-oc-12-1-oc-3-1] using oc-3c
using oc-48
Use using oc-48 to set a 2.5 Gbps CPOS interface to channelized mode.
using oc-48
undo using
A 2.5 Gbps CPOS interface operates in channelized mode.
# Configure 2.5 Gbps CPOS interface CPOS 1/1/1 to operate in channelized mode.
[Sysname-Cpos1/1/1] using oc-48
