| 04-POS interface commands | 120.02 KB |
This chapter describes configuration commands for POS interfaces, including standard POS interfaces, POS subinterfaces, and POS channel interfaces.
alarm-detect
Use alarm-detect to configure the action to take when an RDI, SD, or SF alarm occurs on an interface.
Use undo alarm-detect to restore the default.
alarm-detect { rdi | sd | sf } action link-down
undo alarm-detect { rdi | sd | sf }
The device does not take any actions on the interface when an RDI, SD, or SF alarm occurs.
Standard POS interface view
rdi: Specifies remote defect indication (RDI) alarms.
sd: Specifies signal degrade (SD) alarms.
sf: Specifies signal fail (SF) alarms.
action: Specifies the action to take when the specified alarm is detected on the interface.
link-down: Places the interface in down state.
An RDI alarm occurs if the device receives multiplexer section remote defect indication (MS-RDI) signals from the remote end.
An SD or SF alarm occurs if the bit error rate of incoming packets crosses the SD or SF alarm threshold. To set the SD or SF alarm threshold, use the threshold command.
# Configure POS 1/1/1 to go down when an SD alarm occurs.
[Sysname] interface pos 1/1/1
[Sysname-Pos1/1/1] alarm-detect sd action link-down
threshold
bandwidth
Use bandwidth to configure the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
POS subinterface view
POS channel interface view
# Set the expected bandwidth to 50 kbps for POS 1/1/1.
[Sysname-Pos1/1/1] bandwidth 50
clock
Use clock to set the clock mode of a standard POS interface.
Use undo clock to restore the default.
clock { master | slave }
undo clock
The clock mode of a POS interface is slave.
master: Sets the clock mode to master.
slave: Sets the clock mode to slave.
Standard POS interfaces support the following clock modes:
· Master—Uses internal clock signal.
· Slave—Uses line clock signal.
If the standard POS interface is connected to another router, set its clock mode to be different from the mode used by the remote end. If the standard POS interface is connected to a SONET/SDH device, which provides higher clock precision, always set its clock mode to slave.
# Set the clock mode to master for POS 1/1/1.
[Sysname-Pos1/1/1] clock master
crc
Use crc to set the CRC length on an interface.
Use undo crc to restore the default.
crc { 16 | 32 }
undo crc
The CRC length on an interface is 32 bits.
16: Sets the CRC length to 16 bits.
32: Sets the CRC length to 32 bits.
The CRC length must be the same at both ends.
# Set the CRC length to 16 bits on POS 1/1/1.
[Sysname-Pos1/1/1] crc 16
dampening
Use dampening to enable the device to dampen an interface when it is flapping.
Use undo dampening to disable interface dampening.
undo dampening
Interface dampening is disabled on POS interfaces.
half-life: Specifies the amount of time (in seconds) for a penalty to decrease by half of its value. The interface has an initial penalty of 0. When the interface flaps, it is assigned a penalty of 1000 for each down event until the maximum penalty is reached. When the interface stops flapping, the penalty decreases by half each time the half-life timer expires until the penalty drops to the reuse threshold. The value range for the half-life timer is 1 to 120 seconds, and the default is 54 seconds.
reuse: Specifies the reuse threshold. When the accumulated penalty decreases to this threshold, the interface is not dampened. Interface state changes are reported to the higher layers. The value range for the reuse threshold is 200 to 20000, and the default is 750. The reuse threshold must be less than the suppression threshold.
suppress: Specifies the suppression threshold. This threshold is the accumulated penalty that triggers the device to dampen the interface. In dampened state, the interface does not report its state changes to the higher layers. The value range for the suppression threshold is 200 to 20000, and the default is 2000.
max-suppress-time: Specifies the maximum amount of time the interface can be dampened. If the penalty is still higher than the reuse threshold when this timer expires, the penalty stops increasing for down events. The penalty starts to decrease until it drops below the reuse threshold. The value range for the maximum suppression time is 1 to 255 seconds, and the default is 162 seconds (three times the half-life timer).
NOTE: · The maximum penalty is equal to 2(Max-suppress-time/half-life) × reuse threshold. It is not user configurable. · The penalty does not increase for up events. |
Interface dampening uses an exponential decay mechanism to suppress the effects of excessive interface flapping events on routing protocols and routing tables in the network.
If an interface is not dampened, its state changes are reported. For each state change, the system also generates an SNMP notification and log message.
After a flapping interface is dampened, it does not report its state changes to the CPU. For state change events, the interface only generates SNMP notifications and log messages. Suppression of interface state change events protects the system processing resources.
This command and the link-delay command cannot be both configured on an interface.
This command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the higher layer protocols.
# Configure interface dampening on POS 1/1/1.
[Sysname-Pos1/1/1] dampening 2 800 3000 5
display interface pos
link-delay
default
Use default to restore the default settings for an interface.
default
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. You can use the display this command in interface view to check for these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
# Restore the default settings of POS 1/1/1.
[Sysname-Pos1/1/1] default
description
Use description to configure a description for an interface.
Interface description uses the interface-name Interface format, for example, Pos1/1/1 Interface.
# Configure the description of POS 1/1/1 as pos-interface.
[Sysname-Pos1/1/1] description pos-interface
Use display interface pos to display information about POS interfaces.
display interface [ pos [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
interface-number: Specifies a standard POS interface or POS channel interface by its interface number.
interface-number.subnumber: Specifies a POS subinterface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number in the range of 0 to 1023.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays physically down interfaces and their down causes. If you do not specify this keyword, the command displays information about interfaces in any state.
If you do not specify the pos keyword, this command displays information about all interfaces on the device.
If you specify the pos keyword without specifying an interface, this command displays information about all POS interfaces.
# Display detailed information about POS 1/1/1.
<Sysname> display interface pos 1/1/1
Pos1/1/1
Current state: DOWN
Line protocol state: DOWN
Description: Pos1/1/1 Interface
Bandwidth: 50kbps
Hold timer: 10 seconds, retry times: 5
Dampening enabled:
Penalty: 0 (not suppressed)
Ceiling: 4525
Reuse: 800
Suppress: 3000
Half-life: 2 seconds
Max-suppress-time: 5 seconds
Flap count: 0
Link layer protocol: PPP
LCP: initial
Physical layer is non-channelized STM-1/OC-3
Frame-format is SDH, Current baudrate is 155520000 bps
Scramble enabled, crc 32, clock slave, loopback not set
SD Threshold: 6 , SF Threshold: 3
Optical:Absent
Output queue - FIFO queuing: Size/Length/Discards 0/1024/0
Last link flapping: Never
Regenerator section:
Alarm: LOS
ERROR: RS_BIP(B1) 0
Tx: J0: ""
Rx: J0: unknown
Multiplex section:
Alarm: NONE
ERROR: MS_BIP(B2) 0, MS_REI 0
High order Path:
Alarm: NONE
ERROR: HP_BIP(B3) 0, HP_REI 0, HP_PJE 0, HP_NJE 0
TX: J1: ""
RX: J1: unknown
TX: C2: 0x16
RX: C2: 0xff
Last 300 seconds input rate 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
Last 300 seconds output rate 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
Input: 0 packets, 0 bytes, 0 no buffers
0 errors, 0 runts, 0 giants, 0 CRC,
0 overruns, 0 aborts
Output:0 packets, 0 bytes
0 errors, 0 underruns, 0 aborts
# Display brief information about POS 1/1/1.
<Sysname> display interface pos 1/1/1 brief
Protocol: (s) - spoofing
Pos1/1/1 DOWN DOWN --
# Display brief information about all standard POS interfaces, POS subinterfaces, and POS channel interfaces in a down state and the causes.
<Sysname> display interface pos brief down
Interface Link Cause
Pos1/1/1 DOWN Not connected
Pos1/1/1 Current state |
Current physical and administrative state of the interface: · DOWN (Administratively)—The interface has been shut down by using the shutdown command. · DOWN—The interface is physically down because no physical link is present or the link has failed. · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface: · UP—The data link layer protocol is up. · DOWN—The data link layer protocol is down. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. |
Maximum transmission unit |
MTU of the interface. |
Hold timer |
Interval at which the interface sends keepalive packets. |
retry times |
Maximum number of keepalive attempts. The interface determines that the remote end is down if it does not receive a keepalive response after the maximum number of keepalive attempts have been made. |
Dampening enabled: Penalty: 0 (not suppressed) Ceiling: 4525 Reuse: 800 Suppress: 3000 Half-life: 2 seconds Max-suppress-time: 5 seconds Flap count: 0 |
Interface dampening information: · Dampening enabled—The dampening feature is enabled. · Penalty—Penalty value. The interface suppression state is displayed in parentheses. ¡ Not suppressed—The interface is not dampened. Interface state changes are reported to higher layer protocols. ¡ Suppressed—The interface is dampened. Interface state changes are not reported to higher layer protocols. · Ceiling—Maximum penalty value. · Reuse—Reuse threshold. · Suppress—Suppression threshold. · Half-life—Half-life timer. · Max-suppress-time—Maximum suppression time. · Flap count—Number of times that the interface has flapped. If interface dampening is disabled, the command does not display these fields. For more information about dampening settings, see "dampening." |
Internet protocol processing: Disabled |
The interface does not have an IP address and cannot process packets. |
Internet Address |
Network address of the interface. |
Link layer protocol |
Data link layer protocol of the interface. |
LCP |
LCP negotiation. |
IPCP |
IPCP negotiation. |
Physical layer |
Physical interface. |
Frame-format |
Framing format of the interface. |
Current baudrate |
Baud rate of the interface. |
Scramble |
Payload scrambling state. |
crc |
CRC length. |
clock |
Clock mode. |
loopback |
Loopback state. |
SD Threshold |
SD alarm threshold. |
SF Threshold |
SF alarm threshold. |
Optical |
Transmission medium. |
Output queue - Urgent queuing: Size/Length/Discards Output queue - Protocol queuing: Size/Length/Discards Output queue - FIFO queuing: Size/Length/Discards |
Information about the urgent, protocol, and FIFO output queues: · Size—Number of packets in the queue. · Length—Maximum number of packets that the queue can contain. · Discards—Number of dropped packets. |
Last link flapping |
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup. |
Last clearing of counters |
The most recent time that the reset counters interface command was executed. This field displays Never if the command has never been executed on the interface since device startup. |
Regenerator section |
Alarm and error statistics for the regenerator section. |
Alarm |
Alarm statistics for the tributary unit group. |
ERROR |
Error statistics. |
Tx |
Transmitted overhead byte. |
Rx |
Received overhead byte. |
Multiplex section |
Alarm and error statistics for the multiplex section. |
High order Path |
Alarm and error statistics for the higher-order path. |
Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec |
Average input rates (in Bps, bps, and pps) for the last 300 seconds. |
Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec |
Average output rates (in Bps, bps, and pps) for the last 300 seconds. |
Input: 0 packets, 0 bytes 0 errors, 0 runts, 0 giants, 0 CRC 0 overruns, 0 aborts, 0 no buffers |
Inbound traffic statistics for the POS interface: · errors—Number of inbound packets with errors detected at the physical layer. · runts—Number of inbound packets shorter than the minimum frame length. · giants—Number of inbound packets larger than the maximum frame length. · CRC—Total number of inbound normal-size packets with CRC errors. · overruns—Number of packet drops because the input rate of the interface exceeded the forwarding capability. · aborts—Number of invalid inbound frames. · no buffers—Number of packet drops because the receive buffer is full. |
Output: 0 packets, 0 bytes 0 errors, 0 underruns, 0 aborts |
Outbound traffic statistics for the POS interface: · errors—Number of outbound packets with errors detected at the physical layer. · underruns—Number of packets dropped because the output rate of the interface exceeded the memory reading rate. · aborts—Total number of invalid outbound packets. |
Brief information on interfaces in route mode: |
Brief information about Layer 3 interfaces. |
Link: ADM - administratively down; Stby - standby |
Link status: · ADM—The interface has been administratively shut down. To bring up the interface, use the undo shutdown command. · Stby—The interface is operating as a backup interface. To see the primary interface, use the display interface-backup state command in High Availability Command Reference. |
Protocol: (s) - spoofing |
If the data link layer of an interface is spoofing up, its protocol state is followed by an s enclosed in parentheses. This state is typical of interfaces that have on-demand links. |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The physical link of the interface is up. · DOWN—The physical link of the interface is down. · ADM—The interface has been administratively shut down. To bring up the interface, use the undo shutdown command. · Stby—The interface is operating as a backup interface. |
Protocol |
Data link layer state of the interface: · UP—The data link layer of the interface is up. · DOWN—The data link layer of the interface is down. · UP(s)—The data link layer of the interface is spoofing up. This state is available for on-demand link setup applications. This state enables the device to initiate an on-demand link setup when a link is not present. |
Primary IP |
Main IP address of the interface. |
Description of the interface configured by using the description command. · If the description keyword is not specified in the display interface brief command, this field displays a maximum of 27 characters. · If the description keyword is specified in the display interface brief command, this field displays the full interface description. |
Cause |
Causes for the physical state of an interface to be down. · Administratively—The port is manually shut down by using the shutdown command. To bring up the interface, use the undo shutdown command. · Not connected—No physical connection exists possibly because the network cable is disconnected or faulty. |
flag c2
Use flag c2 to set the C2 path signal label byte.
Use undo flag c2 to restore the default.
flag c2 flag-value
undo flag c2
The C2 value is 0x16.
flag-value: Specifies a C2 byte value, a hexadecimal number in the range of 0x00 to 0xFF.
The C2 byte is a higher-order path overhead byte. It indicates the multiplex structure of virtual container (VC) frames and the property of payload.
The C2 byte must be the same at both ends of a link.
# Set the C2 byte to 0x01 on POS 1/1/1.
[Sysname-Pos1/1/1] flag c2 01
flag j0
Use flag j0 to set the J0 regenerator section trace byte for SONET or SDH frames.
Use undo flag j0 to restore the default.
flag j0 { sdh | sonet } flag-value
undo flag j0 { sdh | sonet }
The device uses the SDH framing format. In SDH frames, the J0 byte is an empty string.
flag-value: Specifies the J0 byte. It must be a string of 1 to 15 characters for SDH, and a hexadecimal number in the range of 0x00 to 0xFF for SONET.
sdh: Specifies the SDH framing format.
sonet: Specifies the SONET framing format.
J0 byte is a section overhead byte. SDH and SONET use this byte to test continuity of the connection between two interfaces at the section level.
The J0 byte can be different on devices of the same service provider. On the interfaces between two service providers, the J0 byte must be the same.
# Set the J0 byte to 0xFF for SDH on POS 1/1/1.
[Sysname-Pos1/1/1] flag j0 sdh ff
frame-format
flag j1
Use flag j1 to set the J1 path trace byte for SONET or SDH frames.
Use undo flag j1 to restore the default.
flag j1 { sdh | sonet } flag-value
undo flag j1 { sdh | sonet }
The device uses the SDH framing format. In SDH frames, the J1 byte is an empty string.
flag-value: Specifies a J1 byte value. It must be a string of 1 to 15 characters for SDH and a string of 1 to 62 characters for SONET.
J1 byte is a higher-order path overhead byte. SDH and SONET use this byte to test continuity of the connection between two interfaces at the path level.
The J1 byte must be the same at both ends of a link.
# Set the J1 byte to aabbcc for SDH on POS 1/1/1.
[Sysname-Pos1/1/1] flag j1 sdh aabbcc
flag j1 ignore
frame-format
flag j1 ignore
Use flag j1 ignore to ignore CRC of the J1 byte.
Use undo flag j1 ignore to restore the default.
flag j1 ignore
undo flag j1 ignore
CRC is performed for the J1 byte.
# Ignore CRC of the J1 byte on POS 1/1/1.
[Sysname-Pos1/1/1] flag j1 ignore
flag j1
flow-interval
Use flow-interval to set the packet statistics collection interval for an interface.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The packet statistics collection interval is 300 seconds for an interface.
interval: Specifies the packet statistics collection interval in the range of 5 to 300 and in steps of 5, in seconds.
# Set the packet statistics collection interval to 180 seconds.
[Sysname] flow-interval 180
frame-format
Use frame-format to set the framing format on a standard POS interface.
Use undo frame-format to restore the default.
frame-format { sdh | sonet }
undo frame-format
The framing format is SDH on a standard POS interface.
# Set the framing format to SONET on POS 1/1/1.
[Sysname-Pos1/1/1] frame-format sonet
flag j0
flag j1
interface pos
Use interface pos to create a POS subinterface and enter its view, or enter the view of an existing standard POS interface, POS channel interface, or POS subinterface.
Use undo interface pos to delete a POS subinterface.
interface pos { interface-number | interface-number.subnumber [ p2mp | p2p ] }
undo interface pos interface-number.subnumber
No POS subinterfaces exist.
interface-number: Specifies a standard POS interface or POS channel interface by its number.
p2mp: Sets the subinterface type to point-to-multipoint. By default, a POS subinterface is P2MP type.
p2p: Sets the subinterface type to point-to-point.
You can create POS subinterfaces only on Frame Relay-enabled standard POS interfaces.
# Create POS subinterface POS 1/1/1.1.
[Sysname] interface pos 1/1/1.1
[Sysname-Pos1/1/1.1]
link-protocol
link-delay
Use link-delay to set the physical state change suppression interval on an interface.
Use undo link-delay to restore the default.
link-delay msec milliseconds
undo link-delay
The physical state change suppression interval is 0 milliseconds on an interface.
msec milliseconds: Sets the physical state change suppression interval on an interface, in milliseconds. The value range for this argument is 0 to 10000 in steps of 5.
When the physical state changes, a POS interface reports the event to the upper-layer modules, and generates log and SNMP notification messages. To reduce system overhead caused by frequent physical state changes, use this command to suppress physical state changes within an interval. The interface will ignore any changes that occur during each suppression interval. When the suppression interval expires, the interface will not report the change event or generate messages if the change is removed.
For example, the suppression interval starts when the interface changes from up to down. The interface reports the change event and generates messages if it is still down when the interval expires. The interface does not report the change event or generate messages if it is up when the interval expires.
This command and the dampening command cannot both be configured on an interface.
# Set the physical state change suppression interval to 100 milliseconds for POS 1/1/1.
[Sysname-Pos1/1/1] link-delay msec 100
dampening
link-protocol
Use link-protocol to set the data link layer protocol of an interface.
link-protocol { fr | hdlc | ppp | mfr }
PPP is used.
fr: Specifies Frame Relay as the data link layer protocol of the interface.
hdlc: Specifies HDLC as the data link layer protocol of the interface.
ppp: Specifies PPP as the data link layer protocol of the interface.
mfr: Specifies MFR as the data link layer protocol of the interface.
# Specify HDLC as the data link protocol of POS 1/1/1.
[Sysname-Pos1/1/1] link-protocol hdlc
loopback
Use loopback to enable loopback for a standard POS interface.
Use undo loopback to disable loopback for a standard POS interface.
loopback { local | remote }
undo loopback
Loopback is disabled on a standard POS interface.
local: Enables internal loopback.
remote: Enables external loopback.
Loopback is intended for testing only. Disable the feature when the interface is operating correctly.
When you enable internal loopback on a standard POS interface before the interface is connected to the peer end, the state of the data link layer protocol is reported as up.
# Enable internal loopback on POS 1/1/1.
[Sysname-Pos1/1/1] loopback local
clock
mtu
Use mtu to set the MTU size for an interface.
mtu size
undo mtu
The MTU is 1500 bytes for an interface.
size: Sets the maximum transmission unit (MTU) in bytes. The value range for this argument is 128 to 9600.
The MTU setting affects the assembly and fragmentation of IP packets.
After configuring the MTU for an interface, you must use the shutdown command and then the undo shutdown command on the interface for the modification to take effect.
# Set the MTU to 1430 bytes for POS 1/1/1.
[Sysname-Pos1/1/1] mtu 1430
port-type switch
Use port-type switch to change the type of an interface.
In standard POS interface view:
port-type switch gigabitethernet
In Layer 3 GigabitEthernet interface view:
port-type switch pos
2: System level
gigabitethernet: Change a standard POS interface to a Layer 3 GigabitEthernet interface.
pos: Change a Layer 3 GigabitEthernet interface to a standard POS interface.
This command is available only on routers installed with HIM-TS8P interface modules.
When you execute this command, the device performs the following operations:
1. Removes the original interface.
2. Creates a new-type interface with the same number as the original interface.
3. Enters the interface view of the new-type interface.
# Change POS 1/1/1 to GigabitEthernet 1/1/1.
[Sysname-Pos1/1/1] port-type switch gigabitethernet
Changing port type can result in loss of port configuration. Are you sure to continue? [Y/N]:y
[Sysname-GigabitEthernet1/1/1]
Use reset counters interface to clear interface statistics.
reset counters interface [ pos [ interface-number | interface-number.subnumber ] ]
pos: Clears statistics for standard POS interfaces, POS subinterfaces, or POS channel interfaces.
Use this command to clear history statistics before you collect statistics for a time period.
· If you do not specify the pos keyword, this command clears statistics for all interfaces.
· If you specify the pos keyword without specifying an interface, this command clears statistics for all standard POS interfaces, POS subinterfaces, and POS channel interfaces.
· If you specify a POS interface, this command clears statistics for the specified interface.
# Clear statistics for POS 1/1/1.
<Sysname> reset counters interface pos 1/1/1
scramble
Use scramble to enable payload scrambling on an interface.
Use undo scramble to disable payload scrambling on an interface.
scramble
undo scramble
Payload scrambling is enabled on standard POS interfaces and POS channel interfaces.
The payload scrambling setting must be the same at both ends of a link.
Payload scrambling enables an interface to scramble outgoing data and unscramble incoming data. Several physical layer protocols rely on transitions between 1s and 0s to maintain clocking. By preventing the presence of long strings of all 1s or all 0s, payload scrambling enables the receiving end to extract the line clock signal correctly.
If payload scrambling is disabled, the interface does not scramble outgoing data or unscramble incoming data.
# Enable payload scrambling on POS 1/1/1.
[Sysname-Pos1/1/1]scramble
shutdown
Use shutdown to shut down an interface.
Use undo shutdown to bring up an interface.
shutdown
An interface is up.
# Shut down POS 1/1/1.
[Sysname-Pos1/1/1] shutdown
snmp-agent trap enable { b1-tca | b2-tca | b3-tca }
Use snmp-agent trap enable { b1-tca | b2-tca | b3-tca } to enable SNMP notifications about signal transmission performance for a standard POS interface.
Use undo snmp-agent trap enable { b1-tca | b2-tca | b3-tca } to disable SNMP notifications about signal transmission performance for a standard POS interface.
Signal transmission performance notifications are enabled for the standard POS interface.
To generate SNMP notifications when a B1, B2, or B3 alarm occurs on a standard POS interface, use this command.
B1, B2, and B3 bytes indicate the signal transmission performance of a line at different levels.
· B1 alarm occurs if the bit error rate of a complete STM-N frame exceeds the B1 alarm threshold.
· B2 alarm occurs if the bit error rate of an STM-1 frame exceeds the B2 alarm threshold.
· B3 alarm occurs if the bit error rate of a multiplexed signal (VC3 or VC4 frame) in the STM-1 frame exceeds the B3 alarm threshold.
For B1, B2, or B3 alarm SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Disable B1 alarm notifications on POS 1/1/1.
[Sysname-Pos1/1/1] undo snmp-agent trap enable b1-tca
threshold { b1-tca | b2-tca | b3-tca }
speed
Use speed to set the rate of a standard POS interface.
Use undo speed to restore the default.
speed speed-value
undo speed
The rate of a standard POS interface is 155 Mbps.
speed-value: Specifies the rate in Mbps. The value range for this argument can be 155, 622, 2500, and 10000.
# Set the rate to 2.5 Gbps for POS 1/1/1.
[Sysname-Pos1/1/1] speed 2500
sub-interface rate-statistic
Use sub-interface rate-statistic to enable subinterface rate statistics collection on an interface.
Use undo sub-interface rate-statistic to disable subinterface rate statistics collection on an interface.
Subinterface rate statistics collection is disabled on an interface.
This command is resource intensive. When you use this command, make sure you fully understand its impact on system performance.
# Enable subinterface rate statistics collection on POS 1/1/1.
[Sysname-Pos1/1/1] sub-interface rate-statistic
threshold
Use threshold to configure the power for setting the SD or SF alarm threshold on a standard POS interface.
Use undo threshold to restore the default power for setting the SD or SF alarm threshold on a standard POS interface.
threshold { sd sdvalue | sf sfvalue } *
undo threshold [ sd | sf ]
The SD threshold is 10e to the power of negative 6 (10e–6). The SF threshold is 10e to the power of negative 3 (10e–3).
sd: Specifies the SD alarm threshold.
sdvalue: Specifies the power for setting the SD alarm threshold. The threshold is 10e to the power of negative sdvalue (10e–sdvalue). The value range for this argument is 3 to 9. The greater the value, the lower the SD alarm threshold.
sf: Specifies the SF alarm threshold. The SF alarm threshold must be higher than the SD alarm threshold.
sfvalue: Specifies the power for setting the SF alarm threshold. The threshold is 10e to the power of negative sdvalue (10e–sfvalue). The value range for this argument is 3 to 9. The greater the value, the lower the SF alarm threshold.
SD and SF alarms indicate line performance. SF alarms are more severe than SD alarms.
· An SD alarm occurs if the number of B2 errors reaches the SD alarm threshold.
· An SF alarm occurs if the number of B2 errors reaches the SF alarm threshold.
# Set the SD threshold to 10e to the power of negative 4 (10e–4) on POS 1/1/1.
[Sysname-Pos1/1/1] threshold sd 4
timer-hold
Use timer-hold to set the keepalive interval.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The keepalive interval is 10 seconds.
seconds: Specifies the interval at which the interface sends keepalive packets. The value range for this argument is 0 to 32767 seconds.
On an interface encapsulated with PPP, FR, or HDLC, the data link layer sends keepalive packets at keepalive intervals to detect the availability of the remote end. The data link layer determines that the peer end is down if it does not receive a response after the maximum number of keepalive attempts have been made. The data link layer then reports the link down event to the upper-layer protocols.
To set the maximum number of keepalive attempts, use the timer-hold retry command.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive interval to 15 seconds for POS 1/1/1.
[Sysname-Pos1/1/1] timer-hold 15
timer-hold retry
timer-hold retry
Use timer-hold retry to set the maximum number of keepalive attempts.
Use undo timer-hold retry to restore the default.
timer-hold retry retries
The maximum number of keepalive attempts is 5.
retries: Specifies the maximum number of keepalive attempts, in the range of 1 to 255.
This command applies to interfaces encapsulated with PPP, FR, or HDLC. To set the keepalive interval, use the timer-hold command.
On a slow link, increase the maximum number of keepalive attempts to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the maximum number of keepalive attempts to 10 for POS 1/1/1.
[Sysname-Pos1/1/1] timer-hold retry 10
timer-hold
