Title | Size | Downloads |
H3C SR6600_SR6600-X Routers Probe Commands(V7)-6PW100-book.pdf | 1.28 MB |
Preface
The H3C SR6600/SR6600-X Routers Probe Commands describes the commands in the probe view.
This preface includes:
· Audience
· About the H3C SR6600/SR6600-X documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the routers
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
WARNING |
CAUTION |
IMPORTANT |
NOTE |
TIP |
Network topology icons
Represents an access point. |
Represents a security card, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG card. |
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C SR6600/SR6600-X documentation set includes:
Documents |
Purposes |
Product description and specifications |
Marketing brochures |
Describe product specifications and benefits. |
Technology white papers |
Provide an in-depth description of software features and technologies. |
Card datasheets |
Describe card specifications, features, and standards. |
Hardware specifications and installation |
Compliance and safety manual |
Provides regulatory information and the safety instructions that must be followed during installation. |
Installation guide |
Provides a complete guide to hardware installation and hardware specifications. |
Card manuals |
Provide the hardware specifications of cards. |
H3C N68 Cabinet Installation and Remodel Introduction |
Guides you through installing and remodeling H3C N68 cabinets. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
H3C SR6602 Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
H3C SR6608 Release notes |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
service@h3c.com
http://www.h3c.com
Documentation feedback
We appreciate your comments.
