26-WLAN Command References(AC)
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References-R6749-6W10026-WLAN Command References(AC)
03-Radio management commands
Radio management commands· 1
a-mpdu· 1
a-msdu· 2
ani 2
antenna type· 3
auto-channel european-gap enable· 4
beacon-interval 5
bss-color 6
channel 7
channel auto-select 8
channel band-width· 9
channel-usage measure· 11
channel-usage threshold· 11
client dot11ac-only· 12
client dot11b-forbidden· 13
client dot11n-only· 14
client max-count 15
continuous-mode· 16
display wlan ap continuous-mode· 16
display wlan ap radio· 17
display wlan ap radio channel 19
display wlan ap radio type· 20
display wlan statistics ap radio· 20
distance· 28
dl-ofdma· 29
dot11ac mandatory maximum-nss· 30
dot11ac multicast-nss· 31
dot11ac support maximum-nss· 32
dot11g protection· 33
dot11n mandatory maximum-mcs· 34
dot11n multicast-mcs· 35
dot11n protection· 36
dot11n support maximum-mcs· 37
dtim·· 38
fragment-threshold· 39
green-energy-management 40
ldpc· 40
long-retry threshold· 41
max-power 42
mimo· 43
mu-txbf 44
power-lock· 45
preamble· 46
protection-mode· 47
protection-threshold· 48
radar-detect disable· 49
radio· 50
radio enable· 51
radio scheduled-shutdown time-range· 51
rate· 52
reset wlan channel all 53
reset wlan statistics ap radio· 54
short-gi 54
short-retry threshold· 55
smart-antenna· 56
smart-antenna policy· 57
stbc· 58
su-txbf 59
twt negotiate· 60
type· 61
ul-mu-mimo· 62
ul-ofdma· 63
wlan error-frame optimization· 64
wlan radio· 65
wlan radio channel default 65
wlan radio max-power default 66
wlan retransmit-frame optimization· 66
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
a-mpdu
Use a-mpdu enable to enable the A-MPDU aggregation method.
Use a-mpdu disable to disable the A-MPDU aggregation method.
Use undo a-mpdu to restore the default.
a-mpdu { disable | enable }
undo a-mpdu
In radio view, a radio uses the configuration in an AP group's radio view.
In an AP group's radio view, the A-MPDU aggregation method is enabled.
Radio view
This command is applicable only to 802.11n, 802.11ac, 802.11gac, 802.11ax, and 802.11gax radios. Changing the radio mode to 802.11a, 802.11b, or 802.11g invalidates the command.
The configuration in radio view takes precedence over the configuration in an AP group's radio view.
# Disable the A-MPDU aggregation method for radio 1 of AP ap1.
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] type dot11an
[Sysname-wlan-ap-ap1-radio-1] a-mpdu disable
# Disable the A-MPDU aggregation method for radio 1 of APs with model WA6320 in AP group apgroup1.
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA6320WA6320
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] type dot11an
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] a-mpdu disable
a-msdu
Use a-msdu enable to enable the A-MSDU aggregation method.
Use a-msdu disable to disable the A-MSDU aggregation method.
Use undo a-msdu to restore the default.
a-msdu { disable | enable }
undo a-msdu
In an AP group's radio view, the A-MSDU aggregation method is enabled.
Radio view
The device can receive but cannot send A-MSDUs.
# Disable the A-MSDU aggregation method for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] a-msdu disable
# Disable the A-MSDU aggregation method for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] a-msdu disable
ani
Use ani enable to enable Adaptive Noise Immunity (ANI).
Use ani disable to disable ANI.
Use undo ani to restore the default.
ani { disable | enable }
undo ani
In an AP group's radio view, ANI is enabled.
Radio view
ANI enables the device to adjust the anti-noise level based on the environment to reduce interference from the surrounding environment.
# Enable ANI for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] ani enable
# Enable ANI for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] ani enable
antenna type
Use antenna type to set the antenna type for an AP.
Use undo antenna type to restore the default.
antenna type { antenna-type | custom gain custom-gain }
undo antenna type
In an AP group's radio view, the default antenna type for an AP varies by device model.
Radio view
antenna-type: Specifies an antenna type, a string of 1 to 10 characters. Antenna types supported by an AP vary by AP model.
custom gain custom-gain: Specifies the gain of the third-party antenna, in the range of 0 to 20 dBi.
Perform this task to set the antenna type and antenna gain for an AP after you change the AP antenna.
You can perform this task to specify the antenna type of an H3C antenna or a third-party antenna.
·     When an H3C antenna is used, make sure the antenna type is consistent with the actual type of the antenna used on the AP.
·     When a third-party antenna is used, make sure the antenna gain is the actual gain of the third-party antenna.
If you set the gain of a third-party antenna in an AP group's radio view, make sure all APs of the same model in the AP group are configured with the same antenna gain.
# Set the antenna type to internal for AP ap1.
[Sysname] wlan ap ap1 model WA6620X
[Sysname-wlan-ap-ap1-radio-1] antenna type internal
# Set the antenna type to internal for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1] ap-model WA6620X
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6620X] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6620X-radio-1] antenna type internal
Use auto-channel european-gap enable to configure 2.4 GHz radios to use the European gap for auto channel selection.
Use undo auto-channel european-gap enable to restore the default.
2.4 GHz radios use non-European channel gap 5 to automatically select channels 1, 6, and 11.
Global configuration view
Configure this command for 2.4 GHz radios to use European channel gap 6 to automatically select channels 1, 7, and 13.
# Configure 2.4 GHz radios to use the European channel gap for auto channel selection.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] auto-channel european-gap enable
channel
beacon-interval
Use beacon-interval to set the beacon interval.
Use undo beacon-interval to restore the default.
beacon-interval interval
In an AP group's radio view, the beacon interval is 100 Time Units (TUs).
Radio view
interval: Specifies the beacon interval in the range of 32 to 8191 TUs.
# Set the beacon interval to 1000 TUs for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] beacon-interval 1000
# Set the beacon interval to 1000 TUs for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] beacon-interval 1000
bss-color
Use bss-color enable to enable BSS coloring.
Use bss-color disable to disable BSS coloring.
Use undo bss-color to restore the default.
bss-color { disable | enable }
undo bss-color
In radio view, an AP uses the configuration in an AP group's radio view.
In an AP group's radio view, BSS coloring is disabled.
Radio view
This command takes effect only on 802.11ax and 802.11gax radios. Changing the radio mode to 802.11a/b/g/n/ac/gac removes the configuration.
BSS coloring enables the system to assign a color to each BSS and include the color ID in data packets for clients to identify if a packet comes from the associated AP. To avoid conflicts, clients that detect an 802.11ax data packet with the same color as its associated BSS will postpone transmission.
Enabling BSS coloring in a high density environment can improve system performance and channel usage.
# Enable BSS coloring for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] type dot11ax
[Sysname-wlan-ap-ap1-radio-1] bss-color enable
# Enable BSS coloring for radio 1 of APs in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1]ap-model WA6320
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] type dot11ax
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] bss-color enable
type dot11ax
channel
Use channel to specify a working channel for a radio.
Use undo channel to restore the default.
channel { channel-number | auto { lock | unlock } }
undo channel [ auto ]
In an AP group's radio view, the AC automatically selects a channel for a radio and the channel is unlocked.
Radio view
AP group radio view
channel-number: Specifies a channel by its number. The value range for this argument varies by region code and radio mode.
auto lock: Configures the AC to automatically select a channel for a radio and lock the channel.
auto unlock: Configures the AC to automatically select a channel for a radio and not lock the channel.
When radar signals are detected on the working channel of a radio, one of the following events occurs:
·     If the channel is automatically assigned, the radio changes its channel.
·     If the channel is manually specified, the radio changes its channel, and switches back to the specified channel after 30 minutes and then starts the quiet timer. If no radar signals are detected within the quiet time, the radio starts to use the channel. If radar signals are detected within the quiet time, the radio changes it channel again.
If you manually specify a channel in the range of 36 to 64, whether the 5.1 GHz band can be used outdoors depends on the device region.
·     For outdoor devices that use the 5150 to 5250 Hz band:
¡     China—Not supported.
¡     EU—Not supported.
¡     US—Supported if the maximum effective isotropic radiated power (EIRP) at any elevation angle above 30 degrees does not exceed 125mW and you are to deploy 1000 or fewer devices at a time. To install over 1000 devices at one deployment, contact Federal Communications Commission (FCC) and reduce the total transmit power.
¡     Canada—Not supported.
·     For outdoor devices that use the 5250 to 5350 Hz band:
¡     EU—Not supported.
¡     US—Supported if Depth First Search (DFS) is used.
¡     Canada—Supported if Depth First Search (DFS) is used.
# Specify working channel 149 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] channel 149
# Specify working channel 149 for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] channel 149
channel auto-select
Use channel auto-select to configure the channel selection blacklist or whitelist.
Use undo channel auto-select to remove the specified channels from the channel selection blacklist or whitelist.
channel auto-select { blacklist | whitelist } channel-number
undo channel auto-select { blacklist | whitelist } { all | channel-number }
In an AP group's radio view, no channel selection blacklist or whitelist exists
Radio view
AP group radio view
blacklist: Adds channels to the channel selection blacklist. An AP will not select channels in the blacklist.
whitelist: Adds channels to the channel selection whitelist. An AP will only select channels in the whitelist.
channel-number: Specifies channels by their channel numbers. The value range for this argument varies by region code and radio mode.
all: Specifies all channels in the channel selection blacklist or whitelist.
You cannot configure both the channel selection blacklist and whitelist for the same AP.
This command takes effect only on APs operating in auto channel selection mode.
Make sure adjacent channels in the channel selection whitelist can form a 40, 80, or 160 MHz channel if you set the bandwidth mode to 40, 80, or 160 MHz for an AP. If they cannot form such a channel, the AP will select a channel in the whitelist, and will be forcibly logged off because it operates on a channel different than the configured one.
# Add channels 149, 153, and 157 to the channel selection whitelist for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] channel auto-select whitelist 149 153 157
# Add channels 149, 153, and 157 to the channel selection whitelist for APs with model WA6320 in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] channel auto-select whitelist 149 153 157
channel
channel band-width
Use channel band-width to set the bandwidth mode.
Use undo channel band-width to restore the default.
channel band-width { 20 | 40 [ auto-switch ] | 80 | { 160 | dual-80 } [ secondary-channel channel-number ] }
In an AP group's radio view, the bandwidth mode is 80 MHz for 802.11ax radios, 20 MHz for 802.11gax radios, 80 MHz for 802.11ac radios, 20 MHz for 802.11gac radios, 40 MHz for 802.11an radios, and 20 MHz for 802.11gn radios.
Radio view
20: Sets the bandwidth mode to 20 MHz.
40: Sets the bandwidth mode to 40 MHz.
80: Sets the bandwidth mode to 80 MHz.
auto-switch: Allows a radio to switch its bandwidth mode between 20 MHz and 40 MHz. This keyword is applicable only to 802.11gn, 802.11gac, and 802.11gax radios.
160: Sets the bandwidth mode to 160 MHz. Support for this keyword depends on the AP model.
dual-80: Sets the bandwidth mode to 80+80 MHz. Support for this keyword depends on the AP model.
secondary-channel channel-number: Specifies the secondary channel for the 160 MHz or 80+80 MHz bandwidth mode. Support for this option depends on the AP model.
This command is applicable only to 802.11n, 802.11ac, and 802.11gac radios. When you change the mode of a radio, the default setting of this command for the new radio mode is restored.
The radio uses the specified 40/80/160 MHz bandwidth if adjacent channels can be bound to form a 40/80/160 channel. If adjacent channels cannot form a 40/80/160 channel, the radio uses the next available bandwidth less than the specified one.
For example, the bandwidth mode is set to 80 MHz. The radio uses the 80 MHz bandwidth if adjacent channels that can be bound together exist. If adjacent channels that can be bound to an 80 MHz channel do not exist, but two adjacent channels that can be bound to a 40 MHz channel exist, the 40 MHz bandwidth is used. If no adjacent channels that can be bound together exist, the radio uses the 20 MHz bandwidth.
When the bandwidth mode is set to 80+80 MHz, the radio uses the 160 MHz bandwidth if two adjacent 80 MHz channels that can be bound together exist. If a 160 MHz channel cannot be formed but two non-adjacent 80 MHz channels are available, the radio uses the two 80 MHz channels to achieve the 160 MHz bandwidth.
If the working channel is specified, you can specify the secondary 80 MHz channel for the 160 MHz or 80+80 MHz bandwidth mode. If no working channel is specified, the device automatically selects a secondary channel. The working channel forwards all packets and the secondary channel forwards only data packets.
# Set the bandwidth mode to 40 MHz for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] channel band-width 40
# Set the bandwidth mode to 40 MHz for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] channel band-width 40
channel
Use channel-usage measure to perform on-demand channel usage measurement.
Radio view
This feature enables an AP to scan supported channels and display the channel usage after measurement. The measurement of each channel takes about one second.
# Perform on-demand channel usage measurement on radio 2 of AP ap1.
[Sysname-wlan-ap-ap1] radio 2
[Sysname-wlan-ap-ap1-radio-2] channel-usage measure
Please wait......Done.
Channel  Usage
1        63%
2        61%
3        55%
4        45%
5        64%
6        74%
7        66%
8        48%
9        35%
10       38%
11       54%
12       30%
13       72%
Use channel-usage threshold to set the channel usage alarm threshold.
Use undo channel-usage threshold to restore the default.
channel-usage threshold threshold
In an AP group's radio view, the channel usage alarm threshold is 90%.
Radio view
threshold: Specifies the channel usage alarm threshold in percentage. The value range is 5 to 100.
If the actual channel usage exceeds the threshold, the device reports an alarm to the information center.
# Set the channel usage alarm threshold to 20% for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] channel-usage threshold 20
# Set the channel usage alarm threshold to 20% for radio 1 of APs with model WA6320 in AP group 1.
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] ap-model WA6320
[Sysname-wlan-ap-group-1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] channel-usage threshold 20
client dot11ac-only
Use client dot11ac-only enable to enable the client dot11ac-only feature.
Use client dot11ac-only disable to disable the client dot11ac-only feature.
Use undo client dot11ac-only to restore the default.
client dot11ac-only { disable | enable }
In an AP group's radio view, the client dot11ac-only feature is disabled.
Radio view
This command is applicable only to 802.11ac, 802.11gac, 802.11ax, and 802.11gax radios. Changing the radio mode invalidates the command.
After you configure this command on a radio, the radio accepts only 802.11ac and 802.11ax clients, and all non-802.11ac and non-802.11ax clients that are associated with the radio are logged off.
# Enable the client dot11ac-only feature for AP ap1.
<System> system-view
[System] wlan ap ap1 model WA6320
[System-wlan-ap-ap1] radio 1
[System-wlan-ap-ap1-radio-1] type dot11ac
[System-wlan-ap-ap1-radio-1] client dot11ac-only enable
# Enable the client dot11ac-only feature for AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] client dot11ac-only enable
Use client dot11b-forbidden enable to disable access services for 802.11b clients.
Use client dot11b-forbidden disable to enable access services for 802.11b clients.
Use undo client dot11b-forbidden to restore the default.
client dot11b-forbidden { disable | enable }
In an AP group's radio view, access services for 802.11b clients are enabled.
Radio view
Enabling an 802.11g, 802.11gac, 802.11gn, or 802.11gax radio to reject 802.11b clients reduces the impact of low-speed 802.11b clients and speeds up wireless data transmission.
# Configure AP ap1 to reject 802.11b clients.
[Sysname-wlan-ap-ap1-radio-2] client dot11b-forbidden enable
# Configure AP group apgroup1 to reject 802.11b clients.
[Sysname-wlan-ap-group-apgroup1-model-WA6320] radio 2
[Sysname-wlan-ap-group-apgroup1-model-WA6320-radio-2] client dot11b-forbidden enable
client dot11n-only
Use client dot11n-only enable to enable the client dot11n-only feature.
Use client dot11n-only disable to disable the client dot11n-only feature.
Use undo client dot11n-only to restore the default.
client dot11n-only { disable | enable }
In an AP group's radio view, the client dot11n-only feature is disabled.
Radio view
This command is applicable only to 802.11n, 802.11ac, and 802.11gac radios. Changing the radio mode to 802.11a, 802.11b, or 802.11g invalidates the command.
After you configure this command on a radio, the radio accepts only the 802.11n and 802.11ac clients, and all 802.11a/b/g clients that are associated with the radio are logged off.
# Enable the client dot11n-only feature for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] client dot11n-only enable
# Enable the client dot11n-only feature for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] client dot11n-only enable
client max-count
Use client max-count to set the maximum number of clients that can associate with an AP.
Use undo client max-count to restore the default.
client max-count max-number
In an AP group's radio view, no limit is set for the number of clients that can associate with an AP.
Radio view
max-number: Specifies the maximum number of clients that can associate with an AP. The value range depends on the AP model.
When the maximum number of clients is reached on an AP, the AP stops accepting new clients.
The command limits clients associated with the AP and the AC separately. If a radio is bound with two service templates enabled with client association at the AP and client association at the AC, the total number of clients on the radio is twice the maximum number of clients allowed on the radio. In this case, configure this command based on the number of clients expected to come online on a radio.
# Set the maximum number of clients that can associate with an AP to 38 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] client max-count 38
# Set the maximum number of clients that can associate with an AP to 38 for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] client max-count 38
continuous-mode
Use continuous-mode to enable the continuous mode for a radio.
Use undo continuous-mode to restore the default.
continuous-mode { mcs mcs-index | nss nss-index vht-mcs vhtmcs-index | rate rate-value }
The continuous mode is disabled.
Radio view
mcs mcs-index: Specifies the MCS index in the range of 0 to 76.
nss nss-index vht-mcs vhtmcs-index: Specifies the VHT-MCS index. The value ranges for the nss-index and vhtmcs-index arguments are 1 to 8 and 0 to 9, respectively.
rate rate-value: Specifies the transmit rate in Mbps.
This feature is used for network testing only. Do not use it under any other circumstances.
It enables continuous data packet sending at the specified rate. When the feature is enabled, do not perform any other operations except changing the transmit rate.
For an 802.11a, 802.11b, or 802.11g radio, set the transmit rate. For an 802.11n radio, set the transmit rate or MCS index. For an 802.11ac or 802.11gac radio, set the transmit rate, MCS index, or VHT-MCS index.
# Enable the continuous mode and set the transmit rate to 6 Mbps.
[Sysname-wlan-ap-ap1-radio-1] continuous-mode rate 6
Use display wlan ap continuous-mode to display information about the continuous mode.
display wlan ap { all | name ap-name } continuous-mode
all: Specifies all APs.
name ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Display information about the continuous mode for radios on AP ap1.
<Sysname> display wlan ap name ap1 continuous-mode
AP name    Radio ID    Radio type      Rate    Mcs-Index   Nss   Vht-mcs
ap1        1           802.11a         6       N/A         N/A   N/A
Mcs-Index
MCS index.
Nss
NSS index.
Vht-mcs
VHT-MCS index.
continuous-mode
Use display wlan ap radio to display AP radio information.
display wlan ap { all | name ap-name } radio [ frequency-band { 5 | 2.4 } ]
frequency-band: Specifies a frequency band.
5: Specifies the 5 GHz frequency band.
2.4: Specifies the 2.4 GHz frequency band.
# Display radio information for all APs.
<Sysname> display wlan ap all radio
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 6144
Remaining APs: 6144
Total AP licenses: 128
local AP licenses: 0
Server AP licenses: 0
Remaining local AP licenses: 127
Sync AP licenses: 0
AP name                  RID State Channel          Usage TxPower Clients
                                                    (%)   (dBm)
ap1                      1   Up    149(auto)        10     20     5
ap1                      2   Up    11(auto)         15     20     10
# Display 2.4 GHz radio information for AP ap1.
<Sysname> display wlan ap name ap1 radio frequency-band 2.4
                                                    (%)   (dBm)
ap1                      2   Up    11(auto)         15     20     15
Total number of connected WTUs.
An inside AP is a manual AP automatically created for radio management when an anchor AP acts as an AC. The name and serial ID of the inside AP are the MAC address and serial ID of the anchor AP, respectively.
Maximum number of supported APs, including fit APs and WTUs, on the AC.
Remaining APs
Remaining number of supported APs. The value equals the number of maximum supported APs minus the number of connected common APs and the number of connected WTUs.
Total AP licenses
Total number of AP licenses. Each WTU license is considered as 0.25 AP licenses.
local AP licenses
Number of local AP licenses on the AC.
Server AP licenses
Number of AP licenses applied from the server by the AC.
Number of remaining local AP licenses. Each AP occupies one AP license and each WTU occupies 0.25 AP licenses.
Sync AP licenses
Number of synchronized AP licenses.
Radio state:
·     Up.
·     Down.
Usage
Channel usage.
TxPower (dBm)
Transmission power. By default, the maximum supported power is used to transmit packets.
Clients
Number of online clients.
Use display wlan ap radio channel to display radio channel information.
display wlan ap { all | name ap-name } radio channel
# Display radio channel information for AP ap3.
<Sysname> display wlan ap name ap3 radio channel
AP name                  RID Channel          Band-width           CenterFreq
                                              (MHz)
ap3                       1  36(auto)         20/40/80/160/(80+80) 42/58
ap3                       2  149              20/40/80             155
ap3                       3  11(auto)         20                   0
Band-width (MHz)
Supported channel bandwidth.
CenterFreq
Central frequencies. This field is available only when the supported channel bandwidth reaches 80 MHz. This field displays the central frequencies for both the main and the secondary channels when 160 MHz or 80+80 MHz bandwidth is supported.
Use display wlan ap radio type to display radio type information.
display wlan ap { all | name ap-name } radio type
name ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Display radio type information for AP ap1.
<Sysname> display wlan ap name ap1 radio type
AP name                  RID  AP state  Radio state  Radio type
ap1                      1    Up        Up           802.11n(5GHz)
ap1                      2    Up        Down         802.11n(2.4GHz)
AP state
AP state:
·     Up—The AP has established a CAPWAP tunnel with the AC.
·     Down—The AP has not established a CAPWAP tunnel with the AC.
Radio state
Radio state:
·     Up.
·     Down.
Use display wlan statistics ap radio to display radio statistics.
display wlan statistics ap { all | name ap-name } radio
# Display radio statistics for AP ap1.
<Sysname> display wlan statistics ap name ap1 radio
                                 Radio statistics
 AP name:ap1                                   Radio ID:1
Transmitted frame statistics:
   Total frames                              :836532
   Total frame bytes                         :214040681
   Unicast frames                            :4
   Unicast frame bytes                       :900
   Broadcast/Multicast frames                :836528
   Broadcast/Multicast frame bytes           :214039781
   Other frames                              :0
   Other frame bytes                         :0
   Discarded frames                          :0
   Failed RTS frames                         :0
   Retransmissions                           :6
   Successful RTS frames                     :0
   Retransmitted frames                      :3
   No-ACK frames                             :1555
   Authentication frames                     :1
   Association frames                        :1
   Packet statistics by size:
     Smaller than or equal to 128            :747
     Between 128 and 512 (inclusive)         :85983
     Between 512 and 1024 (inclusive)        :0
     Larger than 1024                        :0
   Packet statistics by rate:
       1 Mbps  :0            2 Mbps  :0
     5.5 Mbps  :0            6 Mbps  :0
       9 Mbps  :0           11 Mbps  :0
      12 Mbps  :0           18 Mbps  :0
      24 Mbps  :880         36 Mbps  :0
      48 Mbps  :0           54 Mbps  :0
  Packet statistics based on data rate:
    6.5 Mbps  :0             7.2 Mbps  :0
     13 Mbps  :0            13.5 Mbps  :0
   14.4 Mbps  :0              15 Mbps  :0
   19.5 Mbps  :0            21.7 Mbps  :0
     26 Mbps  :0              27 Mbps  :0
   28.9 Mbps  :0            29.3 Mbps  :0
     30 Mbps  :0            32.5 Mbps  :0
     39 Mbps  :0            40.5 Mbps  :0
   43.3 Mbps  :0              45 Mbps  :0
     52 Mbps  :0              54 Mbps  :0
   57.8 Mbps  :0            58.5 Mbps  :0
     60 Mbps  :0              65 Mbps  :0
   72.2 Mbps  :0              78 Mbps  :1
     81 Mbps  :0            86.7 Mbps  :0
   87.8 Mbps  :0              90 Mbps  :0
   97.5 Mbps  :0             104 Mbps  :3
    108 Mbps  :0           115.6 Mbps  :0
    117 Mbps  :0             120 Mbps  :0
  121.5 Mbps  :0             130 Mbps  :0
    135 Mbps  :0           144.4 Mbps  :0
    150 Mbps  :0             156 Mbps  :0
    162 Mbps  :0           173.3 Mbps  :0
  175.5 Mbps  :0             180 Mbps  :0
    195 Mbps  :0             200 Mbps  :0
    216 Mbps  :0           216.7 Mbps  :0
    234 Mbps  :0             240 Mbps  :0
    243 Mbps  :0             260 Mbps  :0
  263.3 Mbps  :0             270 Mbps  :0
  288.9 Mbps  :0           292.5 Mbps  :0
    300 Mbps  :0             324 Mbps  :0
    325 Mbps  :0             351 Mbps  :0
    360 Mbps  :0           364.5 Mbps  :0
    390 Mbps  :0             400 Mbps  :0
    405 Mbps  :0           433.3 Mbps  :0
    450 Mbps  :0            468 Mbps  :0
    486 Mbps  :0            520 Mbps  :0
  526.5 Mbps  :0            540 Mbps  :0
    585 Mbps  :0            600 Mbps  :0
    650 Mbps  :0            702 Mbps  :0
    780 Mbps  :0          866.7 Mbps  :0
  877.5 Mbps  :0            975 Mbps  :0
   1053 Mbps  :0           1170 Mbps  :0
   1300 Mbps  :0
Received frame statistics:
   Total frames                         :420815
   Total frame bytes                    :24112652
   Unicast frames                       :585
   Unicast frame bytes                  :15357
   Broadcast/Multicast frames           :420230
   Broadcast/Multicast frame bytes      :24097295
   Fragmented frames                    :0
   Duplicate frames                     :0
   FCS failures                         :474471639
   Decryption errors                    :0
     Smaller than or equal to 128            :420759
     Between 128 and 512 (inclusive)         :54
     Larger than 1024                        :0
       6 Mbps  :420115       9 Mbps  :0
      24 Mbps  :0           36 Mbps  :1
      48 Mbps  :0           54 Mbps  :2
      52 Mbps  :1              54 Mbps  :2
    57.8 Mbps  :0            58.5 Mbps  :17
      60 Mbps  :0              65 Mbps  :10
    72.2 Mbps  :0              78 Mbps  :48
      81 Mbps  :0            86.7 Mbps  :70
    97.5 Mbps  :0             104 Mbps  :87
     108 Mbps  :0           115.6 Mbps  :170
     117 Mbps  :130           120 Mbps  :0
   121.5 Mbps  :0             130 Mbps  :140
     135 Mbps  :0           144.4 Mbps  :22
    1300 Mbps  :0
                                 Radio statistics
 AP name:ap1                                   Radio ID:2
   Total frames                              :13134
   Total frame bytes                         :3259997
   Unicast frames                            :11
   Unicast frame bytes                       :3518
   Broadcast/Multicast frames                :13123
   Broadcast/Multicast frame bytes           :3256479
   Other frames                              :0
   Discarded frames                          :0
   Retransmissions                           :58
   Retransmitted frames                      :11
   No-ACK frames                             :7541
   Authentication frames                     :14
   Association frames                        :8
     Smaller than or equal to 128            :1020
     Between 128 and 512 (inclusive)         :11386
     Larger than 1024                        :0
       1 Mbps  :0            2 Mbps  :0
       9 Mbps  :0           11 Mbps  :1121
      24 Mbps  :0           36 Mbps  :0
    6.5 Mbps  :3             7.2 Mbps  :0
     13 Mbps  :1            13.5 Mbps  :0
   19.5 Mbps  :4            21.7 Mbps  :0
     39 Mbps  :1            40.5 Mbps  :0
   72.2 Mbps  :0              78 Mbps  :0
   97.5 Mbps  :0             104 Mbps  :1
    117 Mbps  :1             120 Mbps  :0
   1300 Mbps  :0
   Total frames                         :32156
   Total frame bytes                    :3076192
   Unicast frames                       :1613
   Unicast frame bytes                  :102957
   Broadcast/Multicast frames           :30543
   Broadcast/Multicast frame bytes      :2973235
   Duplicate frames                     :2
   FCS failures                         :9978084
     Smaller than or equal to 128            :25327
     Between 128 and 512 (inclusive)         :6097
     Larger than 1024                        :0
      1 Mbps  :28718        2 Mbps  :1895
    5.5 Mbps  :284          6 Mbps  :29
      9 Mbps  :12          11 Mbps  :0
     12 Mbps  :10          18 Mbps  :24
     24 Mbps  :11          36 Mbps  :5
     48 Mbps  :4           54 Mbps  :0
    6.5 Mbps  :45                7.2 Mbps  :0
     13 Mbps  :53               13.5 Mbps  :0
   19.5 Mbps  :120              21.7 Mbps  :0
     26 Mbps  :136                27 Mbps  :0
     39 Mbps  :59               40.5 Mbps  :0
     52 Mbps  :17                 54 Mbps  :0
   57.8 Mbps  :0                58.5 Mbps  :20
     60 Mbps  :0                  65 Mbps  :4
   97.5 Mbps  :0                 104 Mbps  :0
   1300 Mbps  :0
Table 5 Command output
Total frames
Total number of transmitted frames, including probe responses and beacon frames.
Total frame bytes
Total bytes of transmitted frames, including probe responses and beacon frames.
Unicast frames
Total number of transmitted unicast frames, excluding probe responses.
Unicast frame bytes
Total bytes of transmitted unicast frames, excluding probe responses.
Total number of transmitted broadcast and multicast frames, excluding beacon frames.
Total bytes of transmitted broadcast and multicast frames, excluding beacon frames.
Others frames
Total number of other transmitted frames.
Others frame bytes
Total bytes of other transmitted frames.
Total number of packets classified by 802.11a/b/g rates.
Total number of packets classified by 802.11n rates. This field is not available if the device does not support 802.11n.
Total frames
Total number of received frames.
Total frame bytes
Total bytes of received frames.
Unicast frames
Total number of received unicast frames.
Unicast frame bytes
Total bytes of received unicast frames.
Total number of received broadcast and multicast frames.
Total bytes of received broadcast and multicast frames.
Fragmented frames
Total number of received fragmented frames.
FCS failures
Total number of received packets with FCS failures.
Decryption errors
Total number of received packets with decryption errors.
distance
Use distance to set the maximum transmission distance.
Use undo distance to restore the default.
distance distance
undo distance
In an AP group's radio view, the maximum transmission distance is 1 km (0.62 miles).
Radio view
distance: Specifies the maximum transmission distance in the range of 1 to 40 km (0.62 to 24.86 miles).
# Set the maximum transmission distance to 5 km (3.11 miles) for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] distance 5
# Set the maximum transmission distance to 5 km (3.11 miles) for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] distance 5
dl-ofdma
Use dl-ofdma enable to enable downlink OFDMA.
Use dl-ofdma disable to disable downlink OFDMA.
Use undo dl-ofdma to restore the default.
dl-ofdma { disable | enable }
undo dl-ofdma
In an AP group's radio view, downlink OFDMA is disabled.
Radio view
OFDMA can provide the following benefits if enabled in a high density environment where small data packets are transmitted:
·     Concurrent transmission to multiple users.
·     Improved radio usage.
·     Shortened transmission latency.
·     Reduced conflict backoff.
# Disable downlink OFDMA for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] dl-ofdma enable
# Disable downlink OFDMA for radio 1 of APs in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] dl-ofdma enable
type dot11ax
Use dot11ac mandatory maximum-nss to set the maximum mandatory NSS.
Use undo dot11ac mandatory maximum-nss to restore the default.
dot11ac mandatory maximum-nss nss-number
In radio view, if the maximum supported NSS is set, no maximum mandatory NSS is set. If the maximum supported NSS is not set, a radio uses the configuration in an AP group's radio view.
In an AP group's radio view, no maximum mandatory NSS is set.
Radio view
nss-number: Specifies the maximum mandatory NSS in the range of 1 to 8.
This command is applicable only to 802.11ac and 802.11gac radios. Changing the radio mode to non-802.11ac modes invalidates the command.
The maximum mandatory NSS cannot be greater than the maximum supported NSS.
After you modify the maximum mandatory NSS, clients that are associated with the radio and that do not support the modified NSS will go offline.
# Set the maximum mandatory NSS to 7 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] type dot11ac
[Sysname-wlan-ap-ap1-radio-1] dot11ac mandatory maximum-nss 7
# Set the maximum mandatory NSS to 7 for AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] type dot11ac
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] dot11ac mandatory maximum-nss 7
Use dot11ac multicast-nss to set the multicast NSS and specify a VHT-MCS index.
Use undo dot11ac multicast-nss to restore the default.
dot11ac multicast-nss nss-number vht-mcs index
In radio view, the default settings are as follows:
·     If the maximum supported NSS or the maximum mandatory NSS is set, no multicast NSS is set.
·     If neither the maximum supported NSS nor the maximum mandatory NSS is set, a radio uses the configuration in an AP group's radio view.
In an AP group's radio view, no multicast NSS is set.
Radio view
nss-number: Specifies the multicast NSS in the range of 1 to 8.
index: Specifies a VHT-MCS index in the range of 0 to 9.
Before configuring this command, you must configure the dot11ac mandatory maximum-nss command.
The multicast NSS cannot be greater than the maximum mandatory NSS.
# Set the maximum mandatory NSS, multicast NSS, and VHT-MCS index for AP ap1 to 2, 2, and 2, respectively.
[Sysname-wlan-ap-ap1-radio-1] dot11ac mandatory maximum-nss 2
[Sysname-wlan-ap-ap1-radio-1] dot11ac multicast-nss 2 vht-mcs 2
# Set the maximum mandatory NSS, multicast NSS, and VHT-MCS index for AP group 2 to 2, 2, and 6, respectively.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] dot11ac mandatory maximum-nss 2
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] dot11ac multicast-nss 2 vht-mcs 2
Use dot11ac support maximum-nss to set the maximum supported NSS.
Use undo dot11ac support maximum-nss to restore the default.
dot11ac support maximum-nss nss-number
·     If the maximum mandatory NSS is set, the maximum supported NSS is 8.
·     If the maximum mandatory NSS is not set, a radio uses the configuration in an AP group's radio view.
In an AP group's radio view, the maximum supported NSS is 8.
Radio view
nss-number: Specifies the maximum supported NSS in the range of 1 to 8.
The maximum supported NSS cannot be smaller than the maximum mandatory NSS.
# Set the maximum supported NSS to 7 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] dot11ac support maximum-nss 7
# Set the maximum supported NSS to 7 for AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] dot11ac support maximum-nss 7
dot11g protection
Use dot11g protection enable to enable 802.11g protection.
Use dot11g protection disable to disable 802.11g protection.
Use undo dot11g protection to restore the default.
dot11g protection { disable | enable }
In an AP group's radio view, 802.11g protection is disabled.
Radio view
This command is applicable only to 802.11g, 802.11n (2.4 GHz), 802.11gac, and 802.11gax radios. If you change the mode of a radio to a mode other than the three modes, 802.11g protection configuration is removed.
802.11g, 802.11n, 802.11gac devices send RTS/CTS or CTS-to-self packets before sending data only when 802.11b signals are detected on the channel.
802.11g protection automatically takes effect when 802.11b clients associate with an 802.11g, 802.11n (2.4 GHz), 802.11gac, or 802.11gax radio.
# Enable 802.11g protection for AP ap1.
[Sysname-wlan-ap-ap1-radio-2] type dot11gn
[Sysname-wlan-ap-ap1-radio-2] dot11g protection enable
# Enable 802.11g protection for the APs with model WA6320 in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320] radio 2
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-2] type dot11gn
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-2] dot11g protection enable
protection-mode
Use dot11n mandatory maximum-mcs to set the maximum mandatory MCS index.
Use undo dot11n mandatory maximum-mcs to restore the default.
dot11n mandatory maximum-mcs index
·     If the maximum supported MCS index is set, no maximum mandatory MCS index is set.
·     If the maximum supported MCS index is not set, a radio uses the configuration in an AP group's radio view.
In an AP group's radio view, no maximum mandatory MCS index is set.
Radio view
index: Specifies the maximum mandatory MCS index in the range of 0 to 76.
Before configuring the dot11n multicast-mcs command, you must set the maximum mandatory MCS index.
After you modify the maximum mandatory MCS index, clients that are associated with the radio and that do not support the modified MCS index will go offline.
# Set the maximum mandatory MCS index to 14 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] dot11n mandatory maximum-mcs 14
# Set the maximum mandatory MCS index to 14 for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] dot11n mandatory maximum-mcs 14
Use dot11n multicast-mcs to set the multicast MCS index.
Use undo dot11n multicast-mcs to restore the default.
dot11n multicast-mcs index
·     If the maximum mandatory MCS index or the maximum supported MCS index is set, no multicast MCS index is set.
·     If neither the maximum mandatory MCS index nor the maximum supported MCS index is set, a radio uses the configuration in an AP group's radio view.
In an AP group's radio view, no multicast MCS index is set.
Radio view
index: Specifies the multicast MCS index in the range of 0 to 76.
The multicast MCS index takes effect only when the radio associates only with 802.11n and 802.11ac clients.
If 802.11a/b/g clients exist, the AP and clients use the 802.11a/b/g multicast rate to multicast packets.
The multicast MCS index maps to a rate in 20 MHz bandwidth mode regardless of whether the bandwidth mode is 20 MHz or 40 MHz.
# Set the multicast MCS index to 14 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] dot11n mandatory maximum-mcs 15
[Sysname-wlan-ap-ap1-radio-1] dot11n multicast-mcs 14
# Set the multicast MCS index to 14 for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] dot11n multicast-mcs 14
dot11n protection
Use dot11n protection enable to enable 802.11n protection.
Use dot11n protection disable to disable 802.11n protection.
Use undo dot11n protection to restore the default.
dot11n protection { disable | enable }
In an AP group's radio view, 802.11n protection is disabled.
Radio view
This command is applicable only to 802.11n, 802.11ac, 802.11gac, 802.11ax, and 802.11gax radios. If you change the mode of a radio to a mode other than the three modes, the 802.11n protection configuration is removed.
802.11n, 802.11ac, and 802.11gac devices notify clients that 802.11n protection is started when 802.11a/b/g signals are detected on the channel.
802.11n protection automatically takes effect when 802.11a/b/g clients associate with an 802.11n, 802.11ac, 802.11gac, 802.11ax, or 802.11gax radio.
# Enable 802.11n protection for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] dot11n protection enable
# Enable 802.11n protection for the APs with model WA6320 in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] dot11n protection enable
Use dot11n support maximum-mcs to set the maximum supported MCS index.
Use undo dot11n support maximum-mcs to restore the default.
dot11n support maximum-mcs index
·     If the maximum mandatory MCS index is set, the maximum supported MCS index is 76.
·     If the maximum mandatory MCS index is not set, a radio uses the configuration in an AP group's radio view.
In an AP group's radio view, the maximum supported MCS index is 76.
Radio view
index: Specifies the maximum supported MCS index in the range of 0 to 76.
The maximum supported MCS index cannot be smaller than the maximum mandatory MCS index.
# Set the maximum supported MCS index to 14 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] dot11n support maximum-mcs 14
# Set the maximum supported MCS index to 14 for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] dot11n support maximum-mcs 14
dtim
Use dtim to set the Delivery Traffic Indication Map (DTIM) interval.
Use undo dtim to restore the default.
dtim counter
undo dtim
In an AP group's radio view, the DTIM interval is 1, and an AP sends buffered broadcast and multicast frames after every beacon frame.
Radio view
counter: Specifies the DTIM interval in the range of 1 to 31.
An AP periodically broadcasts a beacon compliant with the DTIM. After the AP broadcasts the beacon, it sends buffered broadcast and multicast frames based on the value of the DTIM interval. For example, if you set the DTIM interval to 5, the AP sends buffered broadcast and multicast frames every five beacon frames.
# Set the DTIM interval to 5 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] dtim 5
# Set the DTIM interval to 5 for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] dtim 5
fragment-threshold
Use fragment-threshold to set the frame fragmentation threshold.
Use undo fragment-threshold to restore the default.
fragment-threshold size
In an AP group's radio view, the fragmentation threshold is 2346 bytes.
Radio view
size: Specifies the fragmentation threshold in the range of 256 to 2346 bytes. The value for this argument must be an even number.
Frames larger than the fragmentation threshold are fragmented before transmission. Frames smaller than the fragmentation threshold are transmitted without fragmentation.
In a WLAN with great interference, decrease the fragmentation threshold and set the MTU (ip mtu command) of packets sent over the radio to be lower than the fragmentation threshold. This improves the network throughput and efficiency.
# Set the fragmentation threshold to 2048 bytes for AP ap1.
[Sysname] wlan ap ap1 model WA4620i-ACN
[Sysname-wlan-ap-ap1-radio-1] fragment-threshold 2048
# Set the fragmentation threshold to 2048 bytes for the APs with model WA4620i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1] ap-model WA4620i-ACN
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4620i-ACN] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4620i-ACN-radio-1] fragment-threshold 2048
Use green-energy-management enable to enable the energy-saving feature.
Use green-energy-management disable to disable the energy-saving feature.
Use undo green-energy-management to restore the default.
green-energy-management { disable | enable }
In an AP group's radio view, the energy-saving feature is disabled.
Radio view
After you enable the energy-saving feature, the multiple-input and multiple-output (MIMO) mode of a radio automatically changes to 1x1 if no clients associate with the radio and the radio is not enabled with WIPS. This reduces power consumption.
# Enable the energy-saving feature for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] green-energy-management enable
# Enable the energy-saving feature for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] green-energy-management enable
ldpc
Use ldpc enable to enable LDPC.
Use ldpc disable to disable LDPC.
Use undo ldpc to restore the default.
ldpc { disable | enable }
undo ldpc
In an AP group's radio view, LDPC is enabled.
Radio view
The device can receive but cannot send LDPC packets.
For 802.11ax radios, LDPC is enabled by default and cannot be disabled. The ldpc disable configuration does not take effect on 802.11ax radios.
# Disable LDPC for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] ldpc disable
# Disable LDPC for AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] type dot11an
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] ldpc disable
Use long-retry threshold to set the hardware retransmission limit for large frames.
Use undo long-retry threshold to restore the default.
long-retry threshold count
In an AP group's radio view, the hardware retransmission limit is 4 for large frames.
Radio view
count: Specifies the hardware retransmission limit for large frames, in the range of 1 to 15.
Perform this task to set the hardware retransmission limit for frames larger than the RTS threshold.
# Set the hardware retransmission limit for large frames to 5 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] long-retry threshold 5
# Set the hardware retransmission limit for large frames to 5 for the APs with model WA4620i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4620i-ACN-radio-1] long-retry threshold 5
max-power
Use max-power to set the maximum transmit power.
Use undo max-power to restore the default.
max-power radio-power
undo max-power
In an AP group's radio view, the AP uses the maximum supported transmit power.
Radio view
radio-power: Specifies the maximum transmit power.
The transmit power range supported by a radio varies by region code, channel, AP model, radio mode, antenna type, and bandwidth mode. If you change these attributes for a radio after you set the maximum transmit power, the configured maximum transmit power might be out of the supported transmit power range. If this happens, the system automatically adjusts the maximum transmit power to a valid value.
If you enable power lock, the locked power becomes the maximum transmit power.
# Set the maximum transmit power to 15 dBm for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] max-power 15
# Set the maximum transmit power to 15 dBm for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] max-power 15
mimo
Support for the parameters of this command depends on the AP model.
Use mimo to specify a MIMO mode for a radio.
Use undo mimo to restore the default.
mimo { 1x1 | 2x2 | 3x3 | 4x4 | 5x5 | 6x6 | 7x7 | 8x8}
undo mimo
In an AP group's radio view, the default setting for this command varies by AP model.
Radio view
1x1: Sends and receives signals through one spatial stream.
2x2: Sends and receives signals through two spatial streams.
3x3: Sends and receives signals through three spatial streams.
4x4: Sends and receives signals through four spatial streams.
5x5: Sends and receives signals through five spatial streams.
6x6: Sends and receives signals through six spatial streams.
7x7: Sends and receives signals through seven spatial streams.
8x8: Sends and receives signals through eight spatial streams.
MIMO enables a radio to send and receive wireless signals through multiple spatial streams. This improves system capacity and spectrum usage without requiring higher bandwidth.
# Set the MIMO mode to 2x2 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] mimo 2x2
# Set the MIMO mode to 2x2 for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] mimo 2x2
mu-txbf
Support for this command depends on the AP model.
Use mu-txbf enable to enable multi-user transmit beamforming (TxBF).
Use mu-txbf disable to disable multi-user TxBF.
Use undo mu-txbf to restore the default.
mu-txbf { disable | enable }
undo mu-txbf
In an AP group's radio view, multi-user TxBF is disabled.
Radio view
This command is applicable only to 802.11ac, 802.11gac, 802.11ax, and 802.11gax radios. Changing the radio mode to 802.11a, 802.11b, 802.11g, or 802.11n invalidates the command.
TxBF enables an AP to adjust transmitting parameters based on the channel information to focus RF signals on intended clients. This feature improves the RF signal quality.
Multi-user TxBF is part of 802.11ac Wave2. Multi-user TxBF enables an AP to focus different RF signals on their intended clients to reduce interference and transmission delay. This improves traffic throughput and bandwidth usage. Multi-user TxBF is applicable to WLANs that have a large number of clients and require high bandwidth usage and low transmission delay.
Multi-user TxBF takes effect only when single-user TxBF is enabled.
As a best practice, do not modify the default MIMO settings for an AP enabled with multi-user TxBF.
# Enable multi-user TxBF for AP ap1.
[Sysname] wlan ap ap1 model WA5620i-ACN
[Sysname-wlan-ap-ap1-radio-1] su-txbf enable
[Sysname-wlan-ap-ap1-radio-1] mu-txbf enable
# Enable multi-user TxBF for APs with model WA5620i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1] ap-model WA5620i-ACN
[Sysname-wlan-ap-group-apgroup1-ap-model-WA5620i-ACN] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA5620i-ACN-radio-1] su-txbf enable
[Sysname-wlan-ap-group-apgroup1-ap-model-WA5620i-ACN-radio-1] mu-txbf enable
mimo
su-txbf
power-lock
Use power-lock enable to enable power lock.
Use power-lock disable to disable power lock.
Use undo power-lock to restore the default.
power-lock { disable | enable }
undo power-lock
In an AP group's radio view, power lock is disabled.
Radio view
If you enable power lock, the current power is locked and becomes the maximum transmit power. The locked power still takes effect after the AC restarts.
If a radio enabled with power lock switches to a new channel that provides lower power than the locked power, the maximum power supported by the new channel takes effect.
# Enable power lock for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] power-lock enable
# Enable power lock for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] power-lock enable
preamble
Use preamble to set the preamble type.
Use undo preamble to restore the default.
preamble { long | short }
undo preamble
In an AP group's radio view, the short preamble is used.
Radio view
long: Specifies a long preamble. A long preamble ensures compatibility with all wireless devices that use an earlier standard than 802.11n.
short: Specifies a short preamble. A short preamble can improve network performance.
This command is applicable only to 802.11b, 802.11g, and 802.11gn radios.
A preamble is a set of bits in a packet header to synchronize transmission signals between sender and receiver.
# Set the preamble type to long for AP ap1.
[Sysname-wlan-ap-ap1-radio-2] preamble long
# Set the preamble type to long for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] type dot11g
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] preamble long
protection-mode
Use protection-mode to specify a collision avoidance mode.
Use undo protection-mode to restore the default.
protection-mode { cts-to-self | rts-cts }
In an AP group's radio view, the CTS-to-self mode is used.
Radio view
cts-to-self: Specifies the CTS-to-self mode.
rts-cts: Specifies the RTS/CTS mode.
You can specify either of the following collision avoidance modes for an AP:
·     RTS/CTS—An AP sends an RTS packet to a client before sending data to the client. After receiving the RTS packet, the client sends a CTS packet to the AP. The AP begins to send data after receiving the CTS packet, and other devices that detect the RTS or CTS packet do not send data within a specific time period.
·     CTS-to-self—An AP sends a CTS packet with its own MAC address as the destination MAC address before sending data to a client. After receiving the CTS-to-self packet, the AP begins to send data, and other devices that detect the CTS-to-self packet do not send data within a specific time period.
# Specify the RTS/CTS mode for AP ap1.
[Sysname-wlan-ap-ap1-radio-2] protection-mode rts-cts
# Specify the RTS/CTS mode for the APs with model WA6320 in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-2] protection-mode rts-cts
dot11g protection
Use protection-threshold to set the RTS threshold.
Use undo protection-threshold to restore the default.
protection-threshold size
In an AP group's radio view, the RTS threshold is 2346 bytes.
Radio view
size: Specifies the RTS threshold in the range of 0 to 2346 bytes.
The system performs collision avoidance only for packets larger than the RTS threshold.
# Set the RTS threshold to 2048 bytes for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] protection-threshold 2048
# Set the RTS threshold to 2048 bytes for the APs with model WA4620i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4620i-ACN-radio-1] protection-threshold 2048
protection-mode
Use radar-detect disable to disable radar avoidance.
Use undo radar-detect to restore the default.
undo radar-detect
In radio view, the AP uses the configuration in an AP group's radio view.
In an AP group's radio view, radar avoidance is enabled.
Radio view
Radar avoidance enables a radio to change its working channel or keep silent when radar signals are detected on the working channel, avoiding interference on radars. After 30 minutes, the radio switches back to the previous working channel or restarts transmission. If radar signals can still be detected, the radio changes its working channel or keeps silent again.
With this feature disabled, radios continue to transmit or receive traffic on the working channels even if radar signals are detected on the channels.
Disable radar avoidance only when you perform device debugging.
# Disable radar avoidance for radio 1 on AP ap1.
[Sysname-wlan-ap-ap1-radio-1] radar-detect disable
# Disable radar avoidance for radio 1 on the WA6320 APs in AP group default-group.
[Sysname] wlan ap-group default-group
[Sysname-wlan-ap-group-default-group] ap-model WA6320
[Sysname-wlan-ap-group-default-group-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-default-group-ap-model-WA6320-radio-1] radar-detect disable
radio
Use radio to enter radio view.
radio radio-id
AP view
AP group's AP model view
radio-id: Specifies a radio by its ID. The value range for this argument varies by AP model.
# Enter radio view.
# Enter an AP group's radio view.
radio enable
Use radio enable to enable a radio.
Use radio disable to disable a radio.
Use undo radio to restore the default.
radio { disable | enable }
undo radio
In an AP group's radio view, a radio is disabled.
Radio view
# Enable radio 1 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] radio enable
# Enable radio 1 for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] radio enable
Use radio scheduled-shutdown time-range to enable a radio to disable wireless services as scheduled.
Use undo radio scheduled-shutdown time-range to restore the default.
radio scheduled-shutdown time-range range-name
This command is not configured.
Radio view
time-range range-name: Specifies a time range name. The name is a case-insensitive string of 1 to 32 characters. To avoid confusion, do not use all as the time range name.
# Enable radio 1 on AP ap1 to disable wireless services as scheduled by time range t1.
[Sysname-wlan-ap-ap1-radio-1] radio scheduled-shutdown time-range t1
time-range (ACL and QoS Command Reference)
rate
Use rate to set the transmission rates for a radio.
Use undo rate to restore the default.
rate { multicast { auto | rate-value } | { disabled | mandatory | supported } rate-value }
undo rate
In an AP group's radio view:
·     802.11a/802.11an/802.11ac/802.11ax:
¡     Prohibited rates—None.
¡     Mandatory rates—6, 12, and 24.
¡     Multicast rate—Selected from the mandatory rates.
¡     Supported rates—9, 18, 36, 48, and 54.
·     802.11b:
¡     Mandatory rates—1 and 2.
¡     Supported rates—5.5 and 11.
·     802.11g/802.11gn/802.11gac/802.11gax:
¡     Mandatory rates—1, 2, 5.5, and 11.
¡     Supported rates—6, 9, 12, 18, 24, 36, 48, and 54.
Radio view
disabled: Specifies rates that cannot be used by an AP.
mandatory: Specifies rates that the clients must support to associate with an AP.
multicast: Specifies the rate at which an AP multicasts packets. The multicast rate must be selected from the mandatory rates.
supported: Specifies rates that an AP supports. After a client associates with an AP, the client can select a higher or lower rate from the supported rates to communicate with the AP.
auto: Automatically selects a mandatory rate as the multicast rate.
rate-value: Specifies the rate value in Mbps. You can set multiple rates and separate them by spaces. The available values for this argument are as follows:
·     802.11a/802.11an/802.11ac/802.11ax—6, 9, 12, 18, 24, 36, 48, and 54.
·     802.11b—1, 2, 5.5, and 11.
·     802.11g/802.11gn/802.11gac/802.11gax—1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, and 54.
The mandatory rates and multicast rate cannot be null. When there is only one mandatory rate, you cannot specify the mandatory rate as a supported rate or prohibited rate.
# Set the mandatory rates to 6 Mbps, 12 Mbps, and 24 Mbps for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] rate mandatory 6 12 24
# Set the mandatory rates to 6 Mbps, 12 Mbps, and 24 Mbps for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] rate mandatory 6 12 24
Use reset wlan channel all to reassign working channels.
CAUTION
CAUTION:
This feature affects services for a short period of time. Use this feature with caution.
This command reassigns working channels for radios on APs associated with the AC that do not have specified working channels. This command is applicable to scenarios where bulk working channel adjustment is required.
To achieve the best adjustment effect, make sure the APs are deployed reasonably with ordered names.
# Reassign working channels.
<Sysname> reset wlan channel all
Resetting working channels for radios without a working channel specified will affect services temporarily. Continue? [Y/N]:
reset wlan statistics ap radio
Use reset wlan statistics ap radio to clear radio statistics.
reset wlan statistics ap { all | name ap-name } radio
# Clear radio statistics for AP ap1.
<Sysname> reset wlan statistics ap name ap1 radio
short-gi
Use short-gi enable to enable short Guard Interval (GI).
Use short-gi disable to disable short GI.
Use undo short-gi to restore the default.
short-gi { disable | enable }
undo short-gi
In radio view, a radio uses the configuration in an AP group's radio view.
In an AP group's radio view, short GI is enabled.
Radio view
This command is applicable only to 802.11n, 802.11ac, 802.11gac, 802.11ax, and 802.11gax radios. Changing the radio mode to 802.11a, 802.11b, or 802.11g invalidates the command.
The configuration in radio view takes precedence over the configuration in an AP group's radio view.
# Disable short GI for AP ap1.
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] type dot11an
[Sysname-wlan-ap-ap1-radio-1] short-gi disable
# Disable short GI for AP group apgroup1.
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA6320
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] type dot11an
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] short-gi disable
short-retry threshold
Use short-retry threshold to set the hardware retransmission limit for small frames.
Use undo short-retry threshold to restore the default.
short-retry threshold count
In an AP group's radio view, the hardware retransmission limit is 7 for small frames.
Radio view
count: Specifies the hardware retransmission limit for small frames, in the range of 1 to 15.
Perform this task to set the hardware retransmission limit for frames smaller than or equal to the RTS threshold.
# Set the hardware retransmission limit for small frames to 10 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] short-retry threshold 10
# Set the hardware retransmission limit for small frames to 10 for the APs with model WA4620i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4620i-ACN-radio-1] short-retry threshold 10
smart-antenna
Use smart-antenna enable to enable the smart antenna feature.
Use smart-antenna disable to disable the smart antenna feature.
Use undo smart-antenna to restore the default.
smart-antenna { disable | enable }
undo smart-antenna
In an AP group's radio view, the smart antenna feature is enabled.
Radio view
# Enable smart antenna for AP ap1.
[Sysname] wlan ap ap1 model WA5530i
[Sysname-wlan-ap-ap1-radio-1] smart-antenna enable
# Enable smart antenna for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1] ap-model WA5530i
[Sysname-wlan-ap-group-apgroup1-ap-model-WA5530i] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA5530i-radio-1] smart-antenna enable
smart-antenna policy
Use smart-antenna policy to specify a smart antenna mode.
Use undo smart-antenna policy to restore the default.
smart-antenna policy { auto | high-availability | high-throughput }
In an AP group's radio view, the auto mode is used.
Radio view
auto: Specifies the auto mode. When this mode is enabled, high availability mode is used for audio and video packets, and high throughput mode is used for other packets.
high-availability: Specifies the high availability mode. This mode ensures guaranteed bandwidth for clients and is applicable to WLANs that require stable bandwidth.
high-throughput: Specifies the high throughput mode. This mode ensures as more associations as possible and is applicable to WLANs that require high performance.
The smart antenna mode configuration takes effect only after you enable the smart antenna feature.
# Set the smart antenna mode to high-availability for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] smart-antenna policy high-availability
# Set the smart antenna mode to high-availability for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA5530i-radio-1] smart-antenna policy high-availability
stbc
Use stbc enable to enable Space-Time Block Coding (STBC).
Use stbc disable to disable STBC.
Use undo stbc to restore the default.
stbc { disable | enable }
undo stbc
In an AP group's radio view, STBC is enabled.
Radio view
# Enable STBC for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] stbc enable
# Enable STBC for AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] stbc enable
su-txbf
Use su-txbf enable to enable single-user TxBF.
Use su-txbf disable to disable single-user TxBF.
Use undo su-txbf to restore the default.
su-txbf { disable | enable }
undo su-txbf
In an AP group's radio view, single-user TxBF is disabled.
Radio view
Single-user TxBF enables an AP to improve the signal to one intended client. Single-user TxBF is applicable to WLANs that have widely spread clients, poor network quality, and serious signal attenuation.
# Enable single-user TxBF for AP ap1.
# Enable single-user TxBF for APs with model WA5620i-ACN in AP group apgroup1.
mimo
mu-txbf
twt negotiate
Support for this command varies by AP model.
Use twt negotiate enable to enable Target Wake Time (TWT) negotiation.
Use twt negotiate disable to disable TWT negotiation.
Use undo twt negotiate to restore the default.
twt negotiate { disable | enable }
undo twt negotiate
In radio view, a radio uses the configuration in AP group view.
In an AP group's radio view, the default setting varies by AP model.
Radio view
TWT negotiation enables clients and APs to exchange data packets only in service periods and schedules client hibernation to reduce client power consumption and wireless resource competition.
With TWT negotiation enabled, clients send negotiation requests that carry the service period, TWT interval, and first wake time (calculated by clients) to APs. Upon receiving such a request, an AP sends a response. Then, the clients wake up as scheduled and wait for trigger frames from that AP. Upon receiving a trigger frame, clients enter a service period and start to exchange data packets with that AP. When a service period expires, clients enter hibernation mode even if data packet exchange is not finished.
A radio can provide the TWT service to a maximum of eight clients. After responding to the TWT negotiation requests of eight clients, the radio rejects the requests from the other clients.
This feature takes effect only on 802.11ax and 802.11gax radios. Changing the radio mode to a non-802.11ax or non-802.11gax mode removes the configuration.
# Enable TWT negotiation for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] type dot11ax
[Sysname-wlan-ap-ap1-radio-1] twt negotiate enable
# Enable TWT negotiation for radio 1 of APs in AP group apgroup2.
[Sysname-wlan-ap-group-apgroup1]ap-model WA6320
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] type dot11ax
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] twt negotiate enable
type
type
Use type to specify a radio mode.
Use undo type to restore the default.
type { dot11a | dot11ac | dot11an | dot11ax | dot11b | dot11g | dot11gac | dot11gax | dot11gn }
undo type
The default setting varies by AP model.
Radio view
dot11a: Specifies the 802.11a radio mode.
dot11ac: Specifies the 802.11ac radio mode.
dot11an: Specifies the 802.11n (5 GHz) radio mode.
dot11ax: Specifies the 802.11ax radio mode.
dot11b: Specifies the 802.11b radio mode.
dot11g: Specifies the 802.11g radio mode.
dot11gac: Specifies the 802.11gac radio mode.
dot11gax: Specifies the 802.11gax radio mode.
dot11gn: Specifies the 802.11n (2.4 GHz) radio mode.
When you change the radio mode in an AP group's radio view, the default settings for the radio mode related commands are restored.
# Set the radio mode to 802.11n (5 GHz) for radio 1 on AP ap1.
# Set the radio mode to 802.11n (5 GHz) for radio 1 in AP group apgroup1.
ul-mu-mimo
Use ul-mu-mimo enable to enable uplink MU-MIMO.
Use ul-mu-mimo disable to disable uplink MU-MIMO.
Use undo ul-mu-mimo to restore the default.
ul-mu-mimo { disable | enable }
undo ul-mu-mimo
In radio view, an AP uses the configuration in an AP group's radio view.
In an AP group's radio view, uplink MU-MIMO is disabled.
Radio view
This command takes effect only on 802.11ax and 802.11gax radios. Changing the radio mode to 802.11a/b/g/n/ac/gac removes the configuration.
Uplink MU-MIMO enables an AP to receive data packets from multiple clients concurrently. With this feature enabled, an AP sends an HE_Trig message to all associated clients to inform the transmission time, frequency, sampling clock, and power requirements. Upon receiving the message, clients send data packets to the AP as required at the same time.
This feature is applicable to scenarios that have a large number of clients and high AP bandwidth usage and transmission latency requirements.
# Disable uplink MU-MIMO for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] ul-mu-mimo disable
# Disable uplink MU-MIMO for radio 1 of APs in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] ul-mu-mimo disable
mu-txbf
ul-ofdma
Use ul-ofdma enable to enable uplink OFDMA.
Use ul-ofdma disable to disable uplink OFDMA.
Use undo ul-ofdma to restore the default.
ul-ofdma { disable | enable }
undo ul-ofdma
In an AP group's radio view, uplink OFDMA is disabled.
Radio view
# Disable uplink OFDMA for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] ul-ofdma disable
# Disable uplink OFDMA for radio 1 of APs in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] ul-ofdma disable
type dot11ax
wlan error-frame optimization
Use wlan error-frame optimization to set the index for optimizing the error packet ratio.
Use undo wlan error-frame optimization to restore the default.
wlan error-frame optimization value
The index for optimizing the error packet ratio is not specified.
value: Specifies the index for optimizing the error packet ratio, in the range of 0 to 1000. The smaller the index is, the smaller the recalculated ratio will be.
The error packet ratio is the number of received error data packets divided by the total number of received data packets.
This command enables the device to recalculate the error packet ratio by using the specified index to get a smaller radio value.
# Set the index for optimizing the error packet ratio to 100.
[Sysname] wlan error-frame optimization 100
wlan radio
Use wlan radio enable to enable all radios.
Use wlan radio disable to disable all radios.
Use undo wlan radio to restore the default.
wlan radio { disable | enable }
undo wlan radio
Radios are disabled unless they are already enabled in radio view or AP group radio view.
CAUTION
CAUTION:
This feature takes effect on all manual APs and online auto APs.
If you execute both the wlan radio { disable | enable } command and the radio { disable | enable } command, the most recent configuration takes effect.
# Enable all radios.
[Sysname] wlan radio enable
wlan radio channel default
Use wlan radio channel default to restore the default working channel mode for all radios.
In default working channel mode, the AC automatically selects a channel for a radio and the channel is unlocked.
This command takes effect on all APs associated with the AC, including offline APs.
This operation might change the working channel of some radios and log off online clients. Please use this command with caution.
# Restore the default working channel mode for all radios.
[Sysname] wlan radio channel default
Restoring the default working channels might log off some online clients. Continue anyway? [Y/N]:y
wlan radio max-power default
Use wlan radio max-power default to restore the default maximum transmit power for all radios.
# Restore the default maximum transmit power for all radios.
[Sysname] wlan radio max-power default
wlan retransmit-frame optimization
Use wlan retransmit-frame optimization to set the index for optimizing the retransmission ratio.
Use undo wlan retransmit-frame optimization to restore the default.
wlan retransmit-frame optimization value
The index for optimizing the retransmission ratio is not set.
Default user roles
value: Specifies the index for optimizing the retransmission ratio, in the range of 0 to 100. The smaller the index is, the smaller the recalculated ratio will be.
The retransmission ratio is the number of retransmitted data packets divided by the total number of transmitted data packets.
This command enables the device to recalculate the retransmission ratio by using the specified index to get a smaller ratio value.
# Set the index for optimizing the retransmission ratio to 100.
[Sysname] wlan retransmit-frame optimization 100
  • Become a Partner
  • Partner Resources
