15-Network Management and Monitoring Command References
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References-R6749-6W10015-Network Management and Monitoring Command References
05-PoE commands
05-PoE commands 144.40 KB
PoE commands
The MSR810-10-PoE, MSR3610-I-IG, and MSR3610-IE-IG routers are single-PSE devices and support only commands available for single-PSE devices.
The following matrixes show the support of hardware platforms for PoE:
Hardware
PoE compatibility
Remarks
MSR810-10-PoE, MSR3610-I-IG, MSR3610-IE-IG
Yes
N/A
Device models installed with one of the following interface modules:
·     SIC-4FSWP
·     DSIC-9FSWP
·     HMIM-24GSWP
Yes
For interface module compatibility with devices, see the interface module manual.
apply poe-profile
Use apply poe-profile to apply a PoE profile to a power interface (PI).
Use undo apply poe-profile to restore the default.
apply poe-profile { index index | name profile-name }
undo apply poe-profile { index index | name profile-name }
No PoE profile is applied to PIs.
PI view
index index: Specifies a PoE profile by its index number in the range of 1 to 100.
name profile-name: Specifies a PoE profile by its name, a case-sensitive string of 1 to 15 characters.
# Apply the PoE profile named forIPphone to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] apply poe-profile name forIPphone
apply poe-profile interface
display poe-profile
Use apply poe-profile interface to apply a PoE profile to PIs.
Use undo apply poe-profile interface to remove the PoE profile application from PIs.
apply poe-profile { index index | name profile-name } interface interface-range
undo apply poe-profile { index index | name profile-name } interface interface-range
No PoE profile is applied to a PI.
interface-range: Specifies a range of Ethernet interfaces in the form of interface-type interface-number [ to interface-type interface-number ], where interface-type interface-number represents the interface type and interface number. The start interface number must be smaller than the end interface number. If an interface in the specified range does not support PoE, it is ignored when the PoE profile is applied.
[Sysname] apply poe-profile name forIPphone interface gigabitethernet 1/0/1
# Apply the PoE profile with index number 1 to PIs GigabitEthernet 1/0/2 to GigabitEthernet 1/0/6.
[Sysname] apply poe-profile index 1 interface gigabitethernet 1/0/2 to gigabitethernet 1/0/6
apply poe-profile
display poe-profile interface
display poe device
Use display poe device to display general PSE information.
In standalone mode:
display poe device
In IRF mode:
display poe device [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays general PSE information about all PSEs in the IRF fabric. (In IRF mode.)
# Display general PSE information.
<Sysname> display poe device
 PSE ID  Slot No. SSlot No. PortNum  MaxPower(W)  State  Model
4        10        4           8         200            Off
LSBMPOEGV48TP
PSE ID
ID of the PSE.
Slot No.
Slot number of the PSE.
SSlot No.
Sub-slot number of the PSE.
PortNum
Number of PIs on the PSE.
MaxPower(W)
Maximum power of the PSE.
PSE status:
·     On—The PSE is supplying power.
·     Off—The PSE is not supplying power.
·     Faulty—The PSE has failed.
Model
PSE model.
display poe interface
Use display poe interface to display power supplying information for PIs.
display poe interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power supplying information for all PIs.
# Display power supplying information for GigabitEthernet 1/0/1.
<Sysname> display poe interface gigabitethernet 1/0/1
 PoE Status                         : Enabled
 Power Priority                    : Critical
 Oper                                : On
 IEEE Class                         : 1
 Detection Status                  : Delivering power
 Power Mode                         : Signal
 Current Power                      : 11592    mW
 Average Power                      : 11610    mW
 Peak Power                          : 11684    mW
 Max Power                           : 15400    mW
 Electric Current                   : 244      mA
 Voltage                              : 51.7     V
 PD Description                      : IP Phone For Room 101
PoE Status
PoE status:
·     Enabled.
·     Disabled.
Power Priority
Power supply priority of the PI:
·     Critical (highest).
·     High.
·     Low.
Oper
Operating status:
·     Off—PoE is disabled.
·     On—Power is being supplied to the PI correctly.
·     Power-lack—Remaining guaranteed power is insufficient for a critical PI.
·     Power-deny—The PSE refuses to supply power. The power required by the PD is higher than the configured power.
·     Power-itself—The PD is using another power supply.
·     Power-limit—The PSE is supplying power to the PD based on the configured power though the PD requires more power than the configured power.
IEEE Class
PD power class by which the PI supplies power to the PD.
If the PI does not support supplying power to the PD, this field displays a hyphen (-).
Detection Status
Power detection status:
·     Disabled—The PoE function is disabled.
·     Searching—The PI is searching for the PD.
·     Delivering power—The PI is supplying power to the PD.
·     Fault—A fault occurred during the test.
·     Test—The PI is undergoing a test.
·     Other fault—A fault has caused the PSE to enter the idle status.
·     PD disconnected—The PD is disconnected.
Power Mode
Power transmission mode:
·     Signal—Power is transmitted over the signal pairs of a twisted pair cable.
·     Spare—Power is transmitted over the spare pairs of a twisted pair cable.
Current Power
Current power, including PD consumption power and transmission loss.
Average Power
Average power.
Peak Power
Peak power.
Max Power
Maximum power.
Electric Current
Current.
Voltage
Voltage.
PD Description
Type and location description for the PD connected to the PI.
# Display power supplying information for all PIs.
 Interface    PoE       Priority  CurPower  Oper      IEEE  Detection
                                      (W)                   Class Status
 GE1/0/1      Enabled   Low        4.4       On         1      Delivering Power
 GE1/0/2      Enabled   Critical  0.0       On         -      Disabled
 GE1/0/3      Enabled   Low        0.0       On         -      Disabled
 GE1/0/4      Enabled   Critical  0.0       On         -      Searching
 GE1/0/5      Enabled   Low        4.0       On         2      Delivering Power
 GE1/0/6      Enabled   Low        0.0       On         -      Disabled
 GE1/0/7      Disabled  Low        0.0       Off        -      Fault
   ---  On State Ports: 2; Used: 8.4(W); Remaining: 171.6(W)  ---
Interface name.
PoE
PoE status:
·     Enabled.
·     Disabled.
Priority
Power priority:
·     High.
·     Low.
CurPower
Current power.
Oper
Operating status:
IEEE Class
Detection Status
·     Disabled—PoE function is disabled.
·     Delivering Power—The PI is supplying power for the PD.
On State Ports
Number of PIs that are supplying power.
Used
Power consumed by the current PI.
Remaining
Total remaining power of the system.
display poe interface power
Use display poe interface power to display power information for PIs.
display poe interface power [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power information for all PIs.
# Display power information for GigabitEthernet 1/0/1.
<Sysname> display poe interface power gigabitethernet 1/0/1
Interface    Current   Peak      Max       PD Description
               (W)       (W)       (W)
 GE1/0/1      15.0      15.3      30.0      Access Point on Room 509 for Peter
# Display power information for all PIs.
               (W)       (W)       (W)
 GE1/0/1     4.4        4.5       30.0         IP Phone in Room 309 for Peter Smith
 GE1/0/2     4.4        4.5       30.0        IP Phone in Room 409 for Peter Pan
 GE1/0/3     15.0      15.3       30.0        Access Point in Room 509 for Peter
 GE1/0/4     0.0        0.0       30.0        IP Phone in Room 609 for Peter John
 GE1/0/5     0.0        0.0       30.0        IP Phone in Room 709 for Jack
 GE1/0/6     0.0        0.0       30.0        IP Phone in Room 809 for Alien
--- On State Ports: 3; Used: 23.8(W);  Remaining: 776.2(W) ---
Interface name.
CurPower
Current power.
PeakPower
Peak power.
MaxPower
Maximum power.
PD Description
Type and location description for the PD connected to a PI.
On State Ports
Used
Power consumed by all PIs.
Remaining
display poe power-usage
Use display poe power-usage to display power usage statistics for PoE power supplies and PSEs.
In standalone mode:
In IRF mode:
display poe power-usage [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays information about all PSEs in the IRF fabric. (In IRF mode.)
# Display power usage statistics for the PoE power supply and all PSEs.
<Sysname> display poe power-usage
 PoE Current Power                    : 12    W
 PoE Max Power                         : 2000  W
 PoE Max Guaranteed Power            : 2000  W
 PoE Remaining Allocable Power      : 1800  W
 PoE Remaining Guaranteed Power     : 2000  W
 Powered PoE Ports                     : 1
 Statistics by PSE:
 PSE ID  Max     Current  Peak     Average  Remaining      Powered
         (W)     (W)       (W)      (W)        Guaranteed(W) Ports
 5       200     12        12        6          200             1
Table 5 Command output
PoE Current Power
Total power that has been consumed by PSEs.
PoE Max Power
Maximum PoE power.
Maximum power that can be supplied to critical PSEs.
Remaining allocable PoE power = Maximum PoE power – Total maximum power of all PoE-enabled PSEs.
Remaining guaranteed PoE power = Maximum guaranteed PoE power – Total maximum power of all critical PSEs.
Typically, the maximum guaranteed PoE power is equal to the maximum PoE power.
Powered PoE Ports
PSE ID
ID of the PSE.
Max
Current
Current power of the PSE.
Peak
Peak power of the PSE.
Average
Average power of the PSE.
Remaining guaranteed power of the PSE = Maximum guaranteed power of the PSE – Total maximum power of all critical PIs of the PSE
Typically, the maximum guaranteed PSE power is equal to the maximum PSE power.
Powered Ports
Number of PIs that are receiving power from the PSE.
display poe pse
Use display poe pse to display detailed PSE information.
Single-PSE device:
display poe pse
Multi-PSE device:
display poe pse [ pse-id ]
pse-id: Specifies a PSE by its ID. If you do not specify a PSE, this command displays detailed PSE information about all PSEs.
# Display detailed PSE information.
<Sysname> display poe pse
 PSE ID                                    : 1
 Slot NO.                                  : 1
 SSlot NO.                                 : 0
 PSE Model                                 : LSBMPOEGV48TP
 PSE Status                                : Enabled
 PSE Preempted                             : No
 Power Priority                            : Low
 Current Power                             : 130      W
 Average Power                             : 20       W
 Peak Power                                : 240      W
 Max Power                                 : 200      W
 Remaining Guaranteed Power             : 120      W
 PSE CPLD Version                         : 100
 PSE Software Version                    : 200
 PSE Hardware Version                    : 100
 Legacy PD Detection                      : Disabled
 Power Utilization Threshold            : 80
 PSE Power Policy                         : Disabled
 PD Power Policy                          : Disabled
 PD Disconnect-Detection Mode           : DC
Table 6 Command output
PSE ID
ID of the PSE.
SSlot No.
Sublsot number of the PSE.
PSE Status
PoE status of the PSE:
·     Enabled.
·     Disabled.
Preempted
Power preemption status for the PSE:
·     No—The system has sufficient power for the PSE.
·     Yes—The system has supplied power to other PSEs and does not have sufficient power for this PSE.
Power Priority
Power priority of the PSE.
Current Power
Average Power
Peak Power
Max Power
Remaining guaranteed power of the PSE = Maximum guaranteed power of the PSE – Total maximum power of all critical PIs of the PSE.
PSE CPLD Version
PSE CPLD version number.
PSE software version number.
PSE hardware version number.
Legacy PD Detection
Nonstandard PD detection status:
·     Enabled.
·     Disabled.
PSE power alarm threshold.
PSE Power Policy
PSE power management policy mode.
PD Power Policy
PD power management policy mode.
PD disconnection detection mode.
display poe pse interface (multi-PSE device)
Use display poe pse interface to display the PoE status of all PIs on a PSE.
display poe pse pse-id interface
pse pse-id: Specifies a PSE ID. To display PSE ID and slot mappings, use the display poe device command.
# Display the status of all PIs on PSE 4.
<Sysname> display poe pse 4 interface
                                      (W)                             Class    Status
 GE1/0/2     Enabled   Critical  0.0        Power-lack          -        Disabled
 GE1/0/3     Enabled   Low        0.0        Power-deny          -        Disabled
 GE1/0/5     Enabled   Low        4.0        Power-limit        2         Delivering Power
 GE1/0/6     Enabled   Low        0.0        Power-itself       -         Disabled
   ---  On State Ports: 2; Used: 8.4(W); Remaining: 171.6 (W)  ---
Table 7 Command output
Interface name.
PoE
PoE status:
·     Enabled.
·     Disabled.
Priority
Priority:
·     High.
·     Low.
CurPower
Current power.
Oper
Operating status:
IEEE Class
Detection Status
·     Delivering Power—The PI is supplying power to the PD.
·     Other Fault—A fault has caused the PSE to enter the idle status.
·     PD Disconnected—The PD is disconnected.
On State Ports
Used
Power consumed by PIs on the PSE.
Remaining
Remaining power on the PSE.
display poe pse interface power (multi-PSE device)
Use display poe pse interface power to display power information for PIs on a PSE.
display poe pse pse-id interface power
pse pse-id: Specifies a PSE by its ID. To display PSE ID and slot mappings, use the display poe device command.
# Display power information for PIs on PSE 4.
<Sysname> display poe pse 4 interface power
            (W)        (W)        (W)
 GE1/0/25  4.4        4.5        4.6         IP Phone on Room 309 for Peter Smith
 GE1/0/26  4.4        4.5        15.4        IP Phone on Room 409 for Peter Pan
 GE1/0/27  15.0       15.3       15.4        Access Point on Room 509 for Peter
 GE1/0/28  0.0        0.0        5.0         IP Phone on Room 609 for Peter John
 GE1/0/29  0.0        0.0        4.0         IP Phone on Room 709 for Jack
 GE1/0/30  0.0        0.0        5.0         IP Phone on Room 809 for Alien
Table 8 Command output
Interface name.
Current
Current power.
Peak
Peak power.
Max
Maximum power.
PD Description
Type and location description for the PD connected with a PI.
On State Ports
Used
Remaining
‌display poe-profile
Use display poe-profile to display information about the PoE profile.
display poe-profile [ index index | name profile-name ]
If you do not specify a profile, the command displays information about all PoE profiles.
# Display information about all PoE profiles.
<Sysname> display poe-profile
 PoE Profile     Index   ApplyNum  Interfaces     Configuration
 forIPphone      1        4           GE1/0/1        poe enable
                                        GE1/0/2           poe priority critical
                                        GE1/0/3
                                        GE1/0/4
 forAP            2        2           GE1/0/5         poe enable
                                        GE1/0/6         poe max-power 14000
   ---  Total PoE profiles: 2, total ports: 6  ---
# Display information about the PoE profile with index number 1.
<Sysname> display poe-profile index 1
 forIPphone      1        6          GE1/0/1         poe enable
                                       GE1/0/3
                                       GE1/0/4
                                       GE1/0/5
                                       GE1/0/6
   ---  Total ports: 6  ---
Table 9 Command output
PoE Profile
Name of the PoE profile.
Index
Index number of the PoE profile.
ApplyNum
Number of PIs to which the PoE profile is applied.
Interfaces
Interface name of the PI to which the PoE configuration is applied.
Configuration
Configurations of the PoE profile.
Total PoE profiles
Number of PoE profiles.
Total ports
Number of PIs to which all PoE profiles are applied.
Use display poe-profile interface to display information about the PoE profile on a PI.
display poe-profile interface interface-type interface-number
# Display information about the PoE profile on GigabitEthernet 1/0/1.
<Sysname> display poe-profile interface gigabitethernet 1/0/1
 PoEProfile     Index   ApplyNum  Interface   Effective configuration
The Effective configuration field displays the configurations that have taken effect. For the descriptions of other fields, see Table 9.
poe disconnect (multi-PSE device)
Use poe disconnect to configure a PD disconnection detection mode.
Use undo poe disconnect to restore the default.
poe disconnect { ac | dc }
undo poe disconnect
The PD disconnection detection mode is the AC detection mode.
ac: Specifies the PD disconnection detection mode as ac.
dc: Specifies the PD disconnection detection mode as dc.
If you change the PD disconnection detection mode while the device is running, the connected PDs are powered off.
# Set the PD disconnection detection mode to dc.
[Sysname] poe disconnect dc
display poe pse
poe enable
Use poe enable to enable PoE on a PI.
Use undo poe enable to disable PoE on a PI.
poe enable
undo poe enable
PoE is disabled on a PI.
PI view
PoE profile view
If a PoE profile has been applied to a PI, remove the application before configuring the PI in PoE profile view.
If a PI has been configured, remove the configuration before configuring the PI in PI view.
# Enable PoE on a PI in PI view.
[Sysname-GigabitEthernet1/0/1] poe enable
# Enable PoE on a PI in PoE profile view.
[Sysname] poe-profile abc
[Sysname-poe-profile-abc-1] poe enable
poe-profile
poe enable pse (multi-PSE device)
Use poe enable pse to enable PoE for a PSE.
Use undo poe enable pse to disable PoE for the PSE.
poe enable pse pse-id
undo poe enable pse pse-id
PoE is disabled on PSEs.
# Enable PoE for PSE 4.
[Sysname] poe enable pse 4
display poe pse
poe legacy enable
Use poe legacy enable to enable the PSE to detect nonstandard PDs.
Use undo poe legacy enable to disable the PSE from detecting nonstandard PDs.
Single-PSE device:
poe legacy enable
Multi-PSE device:
poe legacy enable pse pse-id
undo poe legacy enable pse pse-id
Nonstandard PD detection is disabled.
# Enable the PSE to detect nonstandard PDs. (Single-PSE device)
[Sysname] poe legacy enable
# Enable PSE 4 to detect nonstandard PDs. (Multi-PSE device)
[Sysname] poe legacy enable pse 4
display poe pse
poe max-power (interface view)
Use poe max-power to set the maximum PI power.
Use undo poe max-power to restore the default.
poe max-power max-power
undo poe max-power
The maximum PI power is 15400 milliwatts.
PI view
PoE profile view
max-power: Sets the maximum PI power in milliwatts. The value is in the range of 1000 to 36000 in increments of 1.
# Set the maximum PI power to 12000 milliwatts in PI view.
[Sysname-GigabitEthernet1/0/1] poe max-power 12000
# Set the maximum PI power to 12000 milliwatts in PoE profile view.
[Sysname-poe-profile-abc-1] poe max-power 12000
poe max-power (system view)
poe max-power (system view) (multi-PSE device)
Use poe max-power to set the maximum PSE power.
poe pse pse-id max-power max-power
undo poe pse pse-id max-power
The maximum PSE power is 37 W.
max-power: Sets the maximum PSE power in watts. The value range is 37 to 87 for the router models installed with the SIC-4FSWP module. The value range is 37 to 174 for the router models installed with the DSIC-9FSWP module.
To avoid the PSE power overload situation, make sure the total power of all PSEs is less than the maximum PoE power.
The maximum power of the PSE must be greater than or equal to the total maximum power of all its critical PIs on the PSE to guarantee these PIs power.
# Set the maximum power for PSE 4 to 150 watts.
[Sysname] poe pse 4 max-power 150
poe priority pse
poe pd-description
Use poe pd-description to configure a description for the PD that connects to a PI.
Use undo poe pd-description to restore the default.
poe pd-description text
No description is configured for the PD that connects to a PI.
PI view
text: Configures a description for the PD connected to the PI, a case-sensitive string of 1 to 80 characters.
# Configure the description for the PD as IP Phone for Room 101.
[Sysname-GigabitEthernet1/0/1] poe pd-description IP Phone For Room 101
poe pd-policy priority
Use poe pd-policy priority to enable PI power management.
Use undo poe pd-policy priority to restore the default.
PI power management is disabled.
If PI power management is disabled, the PSE does not supply power to new PDs when PSE power overload occurs.
If PI power management is enabled, when a PSE is overloaded, the PSE allocates power to PDs based on the priority of their PIs.
# Enable PI power management.
[Sysname] poe pd-policy priority
poe priority
poe priority (interface view)
Use poe priority to set the power supply priority for a PI.
Use undo poe priority to restore the default.
poe priority { critical | high | low }
undo poe priority
The power supply priority of a PI is low.
PI view
PoE profile view
critical: Sets the power supply priority to critical. The PI with critical power priority operates in guaranteed mode. Power is first supplied to the PD connected to the critical PI.
high: Sets the power supply priority to high.
low: Sets the power supply priority to low.
When the PoE power is insufficient, power is first supplied to PIs with higher priority.
For PIs with same power supply priority, the PI with the smallest ID is allocated with power first.
# Set the power supply priority of the PI to critical in PI view.
[Sysname-GigabitEthernet1/0/1] poe priority critical
# Set the power supply priority of the PI to critical in PoE profile view.
[Sysname-poe-profile-abc-1] poe priority critical
[Sysname-poe-profile-abc-1] quit
[Sysname-GigabitEthernet1/0/1] apply poe-profile name abc
poe priority (system view) (multi-PSE device)
Use poe priority to set the power supply priority for a PSE.
poe priority { critical | high | low } pse pse-id
undo poe priority pse pse-id
The power supply priority of a PSE is low.
critical: Sets the power supply priority to critical. The PSE with critical power priority operates in guaranteed mode, and power is supplied to it first.
If PSE power management is disabled, the system does not supply power to new PSEs when PoE power overload occurs.
If PSE power management is enabled, when PSE power overload occurs, the system supplies power to a PSE with higher priority. For multiple PSEs with the same priority, the PSE with a smaller ID gets power supplied first.
For example, if PoE is enabled for a PSE, and the PSE has higher priority, the system performs the following operations:
·     Stops supplying power to a PSE with lower priority.
·     Supplies power to the PSE that has higher priority.
# Set the power supply priority of PSE 4 to critical.
[Sysname] poe priority critical pse 4
poe pse-policy priority
poe pse-policy priority (multi-PSE device)
Use poe pse-policy priority to enable PSE power management.
Use undo poe pse-policy priority to disable PSE power management.
PSE power management is disabled.
If PSE power management is enabled, the system supplies power based on the PSE priority and PSE ID when a new PSE causes PoE power overload.
# Enable PSE power management.
[Sysname] poe pse-policy priority
poe update
Use poe update to upgrade the PSE firmware when the device is operating.
Single-PSE device:
poe update { full | refresh } filename
Multi-PSE device:
poe update { full | refresh } filename [ pse pse-id ]
full: Upgrades the PSE firmware in full mode.
refresh: Upgrades the PSE firmware in refresh mode.
filename: Specifies the name of the upgrade file, a case-insensitive string of 1 to 64 characters. The specified file must be in the root directory of the file system of the device.
pse pse-id: Specifies a PSE by its ID. If you do not specify a PSE, all PSEs are upgraded.
You can upgrade the PSE firmware in service in either of the following modes:
·     Refresh mode—Updates the PSE firmware without deleting it. You can use the refresh mode in most cases.
·     Full mode—Deletes the current PSE firmware and reloads a new one. Use the full mode if the PSE firmware is damaged and you cannot execute any PoE commands.
# Upgrade the firmware of PSE 4 in service.
[Sysname] poe update refresh POE-168.bin pse 4
This command will refresh the PSE firmware. Continue? [Y/N]:y
poe utilization-threshold
Use poe utilization-threshold to configure a power alarm threshold for the PSE.
Use undo poe utilization-threshold to restore the default power alarm threshold of the PSE.
poe utilization-threshold value pse pse-id
undo poe utilization-threshold pse pse-id
The power alarm threshold for the PSE is 80%.
value: Specifies alarm threshold as a percentage of 1 to 99.
If PSE power usage crosses the threshold multiple times in succession, the system sends notification messages only for the first crossing. For more information, see "Configuring SNMP."
# Set the power alarm threshold of PSE 4 to 90%.
[Sysname] poe utilization-threshold 90 pse 4
poe-profile
Use poe-profile to create a PoE profile and enter its view, or enter the view of an existing PoE profile.
Use undo poe-profile to delete a PoE profile.
poe-profile profile-name [ index ]
undo poe-profile { index index | name profile-name }
No PoE profiles exist.
profile-name: Specifies a PoE profile name, a case-sensitive string of 1 to 15 characters. A PoE configuration file name begins with a letter and must not contain reserved keywords including undo, all, name, interface, user, poe, disable, max-power, mode, priority, or enable.
index: Specifies the index number of a PoE profile, in the range of 1 to 100.
To configure PIs in batches, use the PoE profile.
If you do not specify a profile index, the system automatically assigns an index (starting from 1) to the PoE profile.
If a PoE profile is applied, use the undo apply poe-profile command to remove the application before deleting the PoE profile.
# Create a PoE profile, name it abc, and specify the index number as 3.
[Sysname] poe-profile abc 3
[Sysname-poe-profile-abc-3]
# Create a PoE profile and name it def. Do not specify the index number.
[Sysname] poe-profile def
[Sysname-poe-profile-def-1]
apply poe-profile
poe enable
poe priority
  • Become a Partner
  • Partner Resources
