12-Security Command References
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References-R6749-6W10012-Security Command References
03-802.1X commands
03-802.1X commands 191.74 KB
802.1X commands
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
For information about MSR routers that can offer WLAN services as fat APs, see "Compatibility of hardware and AP functionality."
The following matrix shows the compatibility of hardware and 802.1X:
Hardware
Remarks
·     Fixed Layer 2 Ethernet ports on the following routers:
¡     MSR610
¡     MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
¡     MSR810-LMS, MSR810-LUS
¡     MSR810-SI, MSR810-LM-SI
¡     MSR810-LMS-EA, MSR810-LME
¡     MSR1004S-5G, MSR1004S-5G-CN
¡     MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN
¡     MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
¡     MSR2600-10-X1
¡     MSR3600-28, MSR3600-51, MSR3600-28-SI, MSR3600-51-SI
¡     MSR3600-28-X1, MSR3600-28-X1-DP, MSR3600-51-X1, MSR3600-51-X1-DP
¡     MSR3600-28-G-DP, MSR3600-51-G-DP
¡     MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
¡     MSR810-W-WiNet, MSR810-LM-WiNet
¡     MSR830-4LM-WiNet
¡     MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
¡     MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
¡     MSR2600-6-WiNet
¡     MSR2600-10-X1-WiNet
¡     MSR3600-28-WiNet
¡     MSR2630-XS
¡     MSR3600-28-XS
¡     MSR3610-I-XS, MSR3610-IE-XS
¡     MSR810-LM-GL, MSR810-W-LM-GL
¡     MSR2600-6-X1-GL
¡     MSR3600-28-SI-GL
¡     MSR830-6EI-GL, MSR860-6EI-XS, MSR830-10EI-GL
¡     MSR830-6HI-GL, MSR860-6HI-XS, MSR830-10HI-GL
¡     MSR1004S-5G-GL
·     The following Layer 2 interface modules installed on routers:
¡     HMIM-24GSW
¡     HMIM-24GSWP
¡     HMIM-8GSW
¡     HMIM-8GSWF
¡     SIC-4GSW
¡     SIC-4GSWF
¡     SIC-4GSWP
For information about the support of the routers for Layer 2 interface modules, see H3C MSR Router Series Comware 7 Interface Module Guide.
display dot1x
Use display dot1x to display information about 802.1X.
display dot1x [ sessions | statistics ] [ ap ap-name [ radio radio-id ] | interface interface-type interface-number ]
sessions: Displays 802.1X session information.
statistics: Displays 802.1X statistics.
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify a radio, this command displays 802.1X information for all radios on the specified AP.
interface interface-type interface-number: Specifies a port by its type and number.
If you do not specify the sessions keyword or the statistics keyword, this command displays all information about 802.1X, including session information, statistics, and settings.
If you do not specify the ap ap-name [ radio radio-id ] option or the interface interface-type interface-number option, this command displays all 802.1X information, including wired 802.1X information and wireless 802.1X information.
If you do not specify any parameters, this command displays all 802.1X information.
# Display all information about 802.1X.
<Sysname> display dot1x
Global 802.1X parameters:
   802.1X authentication  : Enabled
   CHAP authentication    : Enabled
   Max-tx period          : 30 s
   Handshake period       : 15 s
   Quiet timer            : Disabled
         Quiet period     : 60 s
   Supp timeout           : 30 s
   Server timeout         : 100 s
   Reauth period          : 3600 s
   Max auth requests      : 2
   SmartOn supp timeout   : 30 s
   SmartOn retry counts   : 3
   EAD assistant function : Disabled
       URL                : http://www.dwsoft.com
       Free IP            : 6.6.6.0         255.255.255.0
       EAD timeout        : 30 min
   Domain delimiter       : @
 Online 802.1X wired users    : 1
 Online 802.1X wireless users : 1
 GigabitEthernet1/0/1  is link-up
   Handshake                  : Enabled
   Handshake reply            : Disabled
   Handshake security         : Disabled
   Unicast trigger            : Disabled
   Periodic reauth            : Disabled
   Port role                  : Authenticator
   Authorization mode         : Auto
   Port access control        : Port-based
   Multicast trigger          : Enabled
   Mandatory auth domain      : Not configured
   Guest VLAN                 : 3
   Auth-Fail VLAN             : Not configured
   Critical VLAN              : Not configured
   Critical voice VLAN        : Disabled
   Max online users           : 256
   SmartOn                    : Disabled
   EAPOL packets: Tx 3, Rx 4
   Sent EAP Request/Identity packets : 1
        EAP Request/Challenge packets: 1
        EAP Success packets: 1
        EAP Failure packets: 0
   Received EAPOL Start packets : 1
            EAPOL LogOff packets: 1
            EAP Response/Identity packets : 1
            EAP Response/Challenge packets: 1
            Error packets: 0
   Online 802.1X users: 1
          MAC address         Auth state
          0001-0000-0000      Authenticated
AP name: AP1  Radio ID: 1  SSID: wlan_dot1x_ssid
   BSSID                      : 1111-1111-1111
   Handshake                  : Enabled
        Error packets: 0
          0001-0000-0002      Authenticated
Global 802.1X configuration.
Whether 802.1X is enabled globally.
CHAP authentication
Performs EAP termination and uses CHAP to communicate with the RADIUS server.
EAP authentication
Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server.
PAP authentication
Performs EAP termination and uses PAP to communicate with the RADIUS server.
Max-tx period
Username request timeout timer in seconds.
Handshake period
Handshake timer in seconds.
Quiet timer
Status of the quiet timer, enabled or disabled.
Quiet period
Quiet timer in seconds.
Supp timeout
Client timeout timer in seconds.
Server timeout
Server timeout timer in seconds.
Reauth period
Periodic reauthentication timer in seconds.
Max auth requests
Maximum number of attempts for sending an authentication request to a client.
SmartOn client timeout timer in seconds.
Maximum number of attempts for retransmitting an EAP-Request/Notification packet to a client.
Whether EAD assistant is enabled.
URL
Redirect URL for unauthenticated users using a Web browser to access the network.
Free IP
Network segment accessible to unauthenticated users.
EAD timeout
EAD rule timer in minutes.
Domain delimiter
Domain delimiters supported by the device.
Number of wired online 802.1X users, including users that have passed 802.1X authentication and users that are performing 802.1X authentication.
Number of wireless online 802.1X users, including users that have passed 802.1X authentication and users that are performing 802.1X authentication.
Status of the port. In this example, GigabitEthernet 1/0/1 is up.
Whether 802.1X is enabled on the port.
Handshake
Whether the online user handshake feature is enabled on the port.
Handshake reply
Whether the online user handshake reply feature is enabled on the port.
Handshake security
Whether the online user handshake security feature is enabled on the port.
Unicast trigger
Whether the 802.1X unicast trigger is enabled on the port.
Periodic reauth
Whether 802.1X periodic reauthentication is enabled on the port.
Port role
Role of the port. The port functions only as an Authenticator.
Authorization mode
Authorization state of the port, which can be Force-Authorized, Auto, or Force-Unauthorized.
Port access control
Access control method of the port:
·     MAC-based—MAC-based access control.
·     Port-based—Port-based access control.
Multicast trigger
Whether the 802.1X multicast trigger feature is enabled.
Mandatory authentication domain on the port.
Guest VLAN
802.1X guest VLAN configured on the port.
If no 802.1X guest VLAN is configured on the port, this field displays Not configured.
Auth-Fail VLAN
802.1X Auth-Fail VLAN configured on the port.
If no 802.1X Auth-Fail VLAN is configured on the port, this field displays Not configured.
Critical VLAN
802.1X critical VLAN configured on the port.
If no 802.1X critical VLAN is configured on the port, this field displays Not configured.
Critical voice VLAN
Whether the 802.1X critical voice VLAN feature is enabled on the port.
Whether to log off online 802.1X users or keep them online when no server is reachable for 802.1X reauthentication.
Max online users
Maximum number of concurrent 802.1X users on the port.
SmartOn
Whether SmartOn authentication is enabled on the port.
EAPOL packets
Number of sent (Tx) and received (Rx) EAPOL packets.
Number of sent EAP-Request/Identity packets.
Number of sent EAP-Request/MD5-Challenge packets.
EAP Success packets
Number of sent EAP-Success packets.
EAP Failure packets
Number of sent EAP-Failure packets.
Number of received EAPOL-Start packets.
Number of received EAPOL-LogOff packets.
Number of received EAP-Response/Identity packets.
Number of received EAP-Response/MD5-Challenge packets.
Error packets
Number of received error packets.
Online 802.1X users
Number of online 802.1X users on the port, including users that have passed 802.1X authentication and users that are performing 802.1X authentication.
MAC address
MAC addresses of the online 802.1X users.
Auth state
Authentication status of the online 802.1X users.
AP name
Name of the AP with which users are associated.
Radio ID
ID of the radio with which users are associated.
SSID
SSID with which users are associated.
BSSID
ID of the BSS with which users are associated.
display dot1x connection
Use display dot1x connection to display information about online 802.1X users.
In standalone mode:
display dot1x connection [ ap ap-name [ radio radio-id ] | interface interface-type interface-number | user-mac mac-address | user-name name-string ]
In IRF mode:
display dot1x connection [ ap ap-name [ radio radio-id ] | interface interface-type interface-number | slot slot-number | user-mac mac-address | user-name name-string ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). If you do not specify an AP, this command displays information about online 802.1X users for all APs.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify a radio, this command displays information about online 802.1X users for all radios on the specified AP.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays online 802.1X user information for all ports.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays online 802.1X user information for all member devices. (In IRF mode.)
user-mac mac-address: Specifies an 802.1X user by MAC address. The mac-address argument represents the MAC address of the user, in the form of H-H-H. If you do not specify an 802.1X user, this command displays online user information for all 802.1X users.
user-name name-string: Specifies an 802.1X user by its name. The name-string argument represents the username, a case-sensitive string of 1 to 253 characters. If you do not specify an 802.1X user, this command displays online user information for all 802.1X users.
(In standalone mode.) If you do not specify any parameters, this command displays information about online 802.1X users for all ports.
(In IRF mode.) If you do not specify any parameters, this command displays information about online 802.1X users for all member devices.
# (In standalone mode.) splay all online 802.1X user information.
<Sysname> display dot1x connection
Total connections: 2
Slot ID: 0
Username: ias
Authentication domain: abc
IPv4 address: 192.168.1.1
Authentication method: CHAP
Initial VLAN: 1
Authorization untagged VLAN: 6
Authorization tagged VLAN list: 1 to 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 29 31 33
                                35 37 40 to 100
Termination action: Default
Session timeout period: 2 s
Online from: 2013/03/02  13:14:15
Online duration: 0h 2m 15s
User MAC address                : 0016-ecb7-a879
AP name                         : ap1
Radio ID                        : 1
SSID                            : wlan_dot1x_ssid
BSSID                           : 0015-e9a6-7cf0
User name                       : ias
Authentication domain           : 1
IPv4 address                    : 192.168.1.1
IPv6 address                    : 2000:0:0:0:1:2345:6789:abcd
Authentication method           : CHAP
Initial VLAN                    : 1
Authorization VLAN              : N/A
Authorization ACL number        : 3001
Authorization user profile      : N/A
Authorization CAR               :
  Average input rate            : 102400 bps
  Average output rate           : 102400 bps
Authorization URL               : http://oauth.h3c.com
Termination action              : Default
Session timeout period          : 2 sec
Online from                     : 2013/03/02 13:14:15
Online duration                 : 0 h 2 m 15 s
Level flow statistic            :
Level-0    Sent  packets/bytes  : 1/54
        Received packets/bytes  : 0/0
Level-1     Sent packets/bytes  : 0/0
        Received packets/bytes  : 45/1248
# (In IRF mode.) Display all online 802.1X user information.
Slot ID: 0
Username: ias
Initial VLAN: 1
                                35 37 40 to 100
AP name                         : ap1
Radio ID                        : 1
User name                       : ias
Initial VLAN                    : 1
Authorization CAR               :
Level-0     Sent packets/bates  : 1/54
        Received packets/bates  : 0/0
Level-1     Sent packets/bates  : 0/0
        Received packets/bates  : 45/1248
Total connections
Number of online 802.1X users.
User MAC address
MAC address of the user.
Access interface
Interface through which the user access the device.
AP name
Name of the AP with which the user is associated.
Radio ID
ID of the radio with which the user is associated.
SSID
SSID with which the user is associated.
BSSID
ID of the BSS with which the user is associated.
ISP domain used for 802.1X authentication.
IPv4 address
IPv4 address of the user.
If the device does not get the IPv4 address of the user, this field is not available.
IPv6 address
IPv6 address of the user.
If the device does not get the IPv6 address of the user, this field is not available.
EAP message handling method:
·     CHAP—Performs EAP termination and uses CHAP to communicate with the RADIUS server.
·     EAP—Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server.
·     PAP—Performs EAP termination and uses PAP to communicate with the RADIUS server.
Initial VLAN
VLAN to which the user belongs before 802.1X authentication.
Untagged VLAN authorized to the user.
Tagged VLANs authorized to the user.
Number or name of the ACL authorized to the user.
If no ACL is authorized, this field displays N/A.
If ACL authorization fails, this field displays (Not effective) after the ACL number or name.
User profile authorized to the user.
Authorization CAR
Authorization CAR attributes assigned by the server.
·     Average input rate—Average rate of inbound traffic in bps.
·     Average output rate—Average rate of outbound traffic in bps.
If no authorization CAR attributes are assigned, this field displays N/A.
Authorization URL
Redirect URL authorized to the user.
Termination action
Action attribute assigned by the server to terminate the user session:
·     Default—Logs off the online authenticated 802.1X user when the session timeout timer expires. This attribute does not take effect when 802.1X periodic reauthentication is enabled and the periodic reauthentication timer is shorter than the session timeout timer.
·     Radius-request—Reauthenticates the online user when the session timeout timer expires, regardless of whether the 802.1X periodic reauthentication feature is enabled or not.
If the device performs local authentication, this field displays N/A.
Session timeout timer assigned by the server.
Online from
Time from which the 802.1X user came online.
Online duration
Online duration of the 802.1X user.
dot1x
Use dot1x to enable 802.1X globally or on a port.
Use undo dot1x to disable 802.1X globally or on a port.
dot1x
undo dot1x
802.1X is neither enabled globally nor enabled for any port.
For the 802.1X feature to take effect on a port, you must enable the feature both globally and on the port.
# Enable 802.1X globally.
[Sysname] dot1x
# Enable 802.1X on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x
display dot1x
dot1x authentication-method
Use dot1x authentication-method to specify an EAP message handling method.
Use undo dot1x authentication-method to restore the default.
The access device performs EAP termination and uses CHAP to communicate with the RADIUS server.
chap: Configures the access device to perform Extensible Authentication Protocol (EAP) termination and use the Challenge Handshake Authentication Protocol (CHAP) to communicate with the RADIUS server.
eap: Configures the access device to relay EAP packets, and supports any of the EAP authentication methods to communicate with the RADIUS server.
pap: Configures the access device to perform EAP termination and use the Password Authentication Protocol (PAP) to communicate with the RADIUS server.
The access device terminates or relays EAP packets.
·     In EAP termination mode—The access device re-encapsulates and sends the authentication data from the client in standard RADIUS packets to the RADIUS server. The device performs either CHAP or PAP authentication with the RADIUS server. In this mode, the RADIUS server supports only MD5-Challenge EAP authentication and the username and password EAP authentication initiated by an iNode client.
¡     PAP transports usernames and passwords in plain text. The authentication method applies to scenarios that do not require high security. To use PAP, the client can be an iNode 802.1X client.
¡     CHAP transports usernames in plain text and passwords in encrypted form over the network. CHAP is more secure than PAP.
·     In EAP relay mode—The access device relays EAP messages between the client and the RADIUS server. The EAP relay mode supports multiple EAP authentication methods, such as MD5-Challenge, EAP-TLS, and PEAP. To use this mode, make sure the RADIUS server meets the following requirements:
¡     Supports the EAP-Message and Message-Authenticator attributes.
¡     Uses the same EAP authentication method as the client.
If this mode is used, the user-name-format command configured in RADIUS scheme view does not take effect. For more information about the user-name-format command, see "RADIUS commands."
If RADIUS authentication is used, you must configure the access device to use the same authentication method (PAP, CHAP, or EAP) as the RADIUS server.
# Enable the access device to terminate EAP packets and perform PAP authentication with the RADIUS server.
[Sysname] dot1x authentication-method pap
display dot1x
dot1x auth-fail vlan
Use dot1x auth-fail vlan to configure an 802.1X Auth-Fail VLAN on a port.
Use undo dot1x auth-fail vlan to restore the default.
dot1x auth-fail vlan authfail-vlan-id
No 802.1X Auth-Fail VLAN exists on a port.
authfail-vlan-id: Specifies the ID of the 802.1X Auth-Fail VLAN on the port. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created. If the port type is hybrid, verify that the VLAN to be specified as the Auth-Fail VLAN is not in the tagged VLAN list on the port.
An 802.1X Auth-Fail VLAN accommodates users that have failed 802.1X authentication for any reason other than unreachable servers. Users in the Auth-Fail VLAN can access a limited set of network resources.
You cannot specify a VLAN as both a super VLAN and an 802.1X Auth-Fail VLAN on a port. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
To delete a VLAN that has been configured as an 802.1X Auth-Fail VLAN, you must first use the undo dot1x auth-fail vlan command.
# Configure VLAN 100 as the Auth-Fail VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x auth-fail vlan 100
display dot1x
dot1x critical vlan
Use dot1x critical vlan to configure an 802.1X critical VLAN on a port.
Use undo dot1x critical vlan to restore the default.
dot1x critical vlan critical-vlan-id
No 802.1X critical VLAN exists on a port.
critical-vlan-id: Specifies the ID of the 802.1X critical VLAN on the port. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created. If the port type is hybrid, verify that the VLAN to be specified as the critical VLAN is not in the tagged VLAN list on the port.
An 802.1X critical VLAN accommodates users that fail 802.1X authentication because all the RADIUS servers in their ISP domains are unreachable. Users in the critical VLAN can access a limited set of network resources depending on the configuration.
You cannot specify a VLAN as both a super VLAN and an 802.1X critical VLAN on a port. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
To delete a VLAN that has been configured as an 802.1X critical VLAN, you must first use the undo dot1x critical vlan command.
# Specify VLAN 100 as the 802.1X critical VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x critical vlan 100
display dot1x
dot1x domain-delimiter
Use dot1x domain-delimiter to specify a set of domain name delimiters supported by the device.
Use undo dot1x domain-delimiter to restore the default.
dot1x domain-delimiter string
The device supports only the at sign (@) delimiter for 802.1X users.
string: Specifies a set of 1 to 16 domain name delimiters for 802.1X users. No space is required between delimiters. Available delimiters include the at sign (@), backslash (\), dot (.), and forward slash (/). If you want to use backslash (\) as the domain name delimiter, you must enter the escape character (\) along with the backslash (\) sign.
Any character in the configured set can be used as the domain name delimiter for 802.1X authentication users. Usernames that include domain names can use the format of username@domain-name, domain-name\username, username.domain-name, or username/domain-name.
The delimiter set you configured overrides the default setting. If the at sign (@) is not included in the delimiter set, the device does not support the 802.1X users that use this sign as the domain name delimiter.
If a username string contains multiple configured delimiters, the device takes the rightmost delimiter in the username string as the domain name delimiter. For example, if you configure the forward slash (/), dot (.), and backslash (\) as delimiters, the domain name delimiter for the username string 121.123/22\@abc is the backslash (\). The username is @abc and the domain name is 121.123/22.
# Specify the at sign (@) and forward slash (/) as domain name delimiters.
[Sysname] dot1x domain-delimiter @/
display dot1x
dot1x ead-assistant enable
Use dot1x ead-assistant enable to enable the EAD assistant feature.
Use undo dot1x ead-assistant enable to disable the EAD assistant feature.
The EAD assistant feature is disabled.
The EAD assistant feature enables the access device to redirect the HTTP requests of a user to a URL to download and install EAD client. This feature eliminates the tedious job of the administrator to deploy EAD clients.
For the EAD assistant feature to take effect on a port, you must set the port authorization mode to auto.
The feature is mutually exclusive with MAC authentication on devices except MSR3600-28-X1, MSR3600-28-X1-DP, MSR3600-51-X1, MSR3600-51-X1-DP, and MSR3600-28-XS. You must disable MAC authentication globally before you enable the EAD assistant feature.
The feature is mutually exclusive with port security. You must disable port security before you enable the EAD assistant feature.
When you use both EAD assistant and MAC authentication on the device, follow these restrictions and guidelines:
·     If both EAD assistant and MAC authentication are configured, the device does not mark the MAC address of a user that has failed MAC authentication as a silent MAC address. If the user has never passed MAC authentication, packets from the user can trigger MAC authentication again only after the user's EAD entry ages out.
·     As a best practice, do not configure MAC authentication guest VLANs or critical VLANs. These VLANs might fail to take effect when both EAD assistant and MAC authentication are configured on the device.
·     As a best practice, do not configure the IP source guard feature. This feature might fail to take effect when both EAD assistant and MAC authentication are configured on the device.
·     If a MAC address has been marked as a silent MAC address before you enable EAD assistant, packets from that MAC address can trigger EAD assistant only after the quiet timer expires.
# Enable the EAD assistant feature.
[Sysname] dot1x ead-assistant enable
display dot1x
dot1x ead-assistant free-ip
dot1x ead-assistant url
Use dot1x ead-assistant free-ip to configure a free IP.
Use undo dot1x ead-assistant free-ip to remove the specified or all free IP addresses.
dot1x ead-assistant free-ip ip-address { mask-address | mask-length }
undo dot1x ead-assistant free-ip { ip-address { mask-address | mask-length } | all }
No free IPs exist. Users cannot access any segments before they pass 802.1X authentication.
ip-address: Specifies a freely accessible IP address segment, also called a free IP.
mask: Specifies an IP address mask.
mask-length: Specifies IP address mask length in the range of 1 to 32.
all: Removes all free IP addresses.
With EAD assistant enabled on the device, unauthenticated 802.1X users can access the network resources in the free IP segments before they pass 802.1X authentication.
When global MAC authentication is enabled, the free IPs cannot take effect.
When port security is enabled, the free IPs cannot take effect.
Execute this command multiple times to configure multiple free IPs.
# Configure 192.168.1.1/16 as a free IP.
[Sysname] dot1x ead-assistant free-ip 192.168.1.1 255.255.0.0
display dot1x
Use dot1x ead-assistant url to configure a redirect URL for EAD assistant.
Use undo dot1x ead-assistant url to restore the default.
dot1x ead-assistant url url-string
No redirect URL exists for EAD assistant.
url-string: Specifies the redirect URL, a case-sensitive string of 1 to 64 characters.
When an unauthenticated user uses a Web browser to access any network other than the free IP, the device redirects the HTTP requests of the user to the redirect URL.
The redirect URL must be on the free IP subnet.
# Configure the redirect URL as http://test.com.
[Sysname] dot1x ead-assistant url http://test.com
display dot1x
dot1x guest-vlan
Use dot1x guest-vlan to configure an 802.1X guest VLAN on a port.
Use undo dot1x guest-vlan to restore the default.
dot1x guest-vlan guest-vlan-id
No 802.1X guest VLAN exists on a port.
guest-vlan-id: Specifies the ID of the 802.1X guest VLAN. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created. If the port type is hybrid, verify that the VLAN to be specified as the guest VLAN is not in the tagged VLAN list on the port.
An 802.1X guest VLAN accommodates users that have not performed 802.1X authentication. In the guest VLAN, users can access a limited set of network resources, such as a software server, to download anti-virus software and system patches.
You cannot specify a VLAN as both a super VLAN and an 802.1X guest VLAN on a port. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
To delete a VLAN that has been configured as a guest VLAN, you must use the undo dot1x guest-vlan command first.
# Specify VLAN 100 as the 802.1X guest VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x guest-vlan 100
display dot1x
dot1x handshake
Use dot1x handshake to enable the online user handshake feature.
Use undo dot1x handshake to disable the online user handshake feature.
dot1x handshake
The online user handshake feature is enabled.
The online user handshake feature enables the device to periodically send EAP-Request/Identity packets to the client for verifying the connectivity status of online 802.1X users. The device sets a user to the offline state if it does not receive an EAP-Response/Identity packet from the user after making the maximum attempts within the handshake period. To set the handshake timer, use the dot1x timer handshake-period command. To set the maximum handshake attempts, use the dot1x retry command.
# Enable the online user handshake feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x handshake
display dot1x
dot1x retry
dot1x handshake reply enable
Use dot1x handshake reply enable to enable the 802.1X online user handshake reply feature.
Use undo dot1x handshake reply enable to disable the 802.1X online user handshake reply feature.
The 802.1X online user handshake reply feature is disabled.
This command enables the device to reply to 802.1X clients' EAP-Response/Identity packets with EAP-Success packets during the online handshake process.
Use this command only if 802.1X clients will go offline without receiving EAP-Success packets from the device.
# Enable the 802.1X online user handshake reply feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x handshake reply enable
dot1x handshake
dot1x handshake secure
Use dot1x handshake secure to enable the online user handshake security feature.
Use undo dot1x handshake secure to disable the online user handshake security feature.
The online user handshake security feature is disabled.
The online user handshake security feature enables the device to prevent users from using illegal client software.
The feature is implemented based on the online user handshake feature. To bring the security function into effect, make sure the online user handshake feature is enabled.
The online user handshake security feature takes effect only on the network where the iNode client and IMC server are used.
# Enable the online user handshake security feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x handshake secure
display dot1x
dot1x handshake
dot1x mandatory-domain
Use dot1x mandatory-domain to specify a mandatory 802.1X authentication domain on a port.
Use undo dot1x mandatory-domain to restore the default.
No mandatory 802.1X authentication domain is specified on a port.
domain-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters.
When the system authenticates an 802.1X user trying to access a port, it selects an authentication domain in the following order:
1.     Mandatory domain.
2.     ISP domain specified in the username.
3.     Default ISP domain.
# Specify my-domain as the mandatory authentication domain for 802.1X users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x mandatory-domain my-domain
display dot1x
dot1x max-user
Use dot1x max-user to set the maximum number of concurrent 802.1X users on a port.
Use undo dot1x max-user to restore the default.
dot1x max-user max-number
undo dot1x max-user
The default is 4294967295.
max-number: Sets the maximum number of concurrent 802.1X users on a port. The value range is 1 to 4294967295.
Set the maximum number of concurrent 802.1X users on a port to prevent the system resources from being overused. When the maximum number is reached, the port denies subsequent 802.1X users.
# Set the maximum number of concurrent 802.1X users to 32 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x max-user 32
dot1x multicast-trigger
Use dot1x multicast-trigger to enable the 802.1X multicast trigger feature.
Use undo dot1x multicast-trigger to disable the 802.1X multicast trigger feature.
The 802.1X multicast trigger feature is enabled.
The multicast trigger feature enables the device to act as the initiator. The device periodically multicasts EAP-Request/Identity packets out of a port to detect 802.1X clients and trigger authentication. You can use the dot1x timer tx-period command to set the interval for sending multicast EAP-Request/Identity packets.
Disable the multicast trigger in a wireless LAN. Wireless clients and the wireless module of the access device can both initiate 802.1X authentication.
# Enable the multicast trigger feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x multicast-trigger
display dot1x
dot1x unicast-trigger
dot1x port-control
Use dot1x port-control to set the authorization state for the port.
Use undo dot1x port-control to restore the default.
dot1x port-control { authorized-force | auto | unauthorized-force }
The default port authorization state is auto.
authorized-force: Places the port in authorized state, enabling users on the port to access the network without authentication.
auto: Places the port initially in unauthorized state to allow only EAPOL packets to pass, and places the port in authorized state after a user passes authentication. You can use this option in most scenarios.
unauthorized-force: Places the port in unauthorized state, denying any access requests from users on the port.
You can use this command to set the port authorization state to determine whether a client is granted access to the network.
# Set the authorization state of GigabitEthernet 1/0/1 to unauthorized-force.
[Sysname-GigabitEthernet1/0/1] dot1x port-control unauthorized-force
display dot1x
dot1x port-method
Use dot1x port-method to specify an access control method for the port.
Use undo dot1x port-method to restore the default.
dot1x port-method { macbased | portbased }
MAC-based access control applies.
macbased: Uses MAC-based access control on the port to separately authenticate each user attempting to access the network. Using this method, when an authenticated user logs off, no other online users are affected.
portbased: Uses port-based access control on the port. Using this method, once an 802.1X user passes authentication on the port, any subsequent user can access the network through the port without authentication. When the authenticated user logs off, all other users are logged off.
CAUTION
CAUTION:
If online 802.1X users are present on a port, changing its access control method will cause the online users to go offline.
MAC-based access control provides higher security than port-based access control.
# Configure GigabitEthernet 1/0/1 to implement port-based access control.
[Sysname-GigabitEthernet1/0/1] dot1x port-method portbased
display dot1x
dot1x quiet-period
Use dot1x quiet-period to enable the quiet timer.
Use undo dot1x quiet-period to disable the quiet timer.
dot1x quiet-period
The quiet timer is disabled.
When a client fails 802.1X authentication, the device must wait a period of time before it can process authentication requests from the client. You can use the dot1x timer quiet-period command to set the quiet timer.
# Enable the quiet timer and set the quiet timer to 100 seconds.
[Sysname] dot1x quiet-period
[Sysname] dot1x timer quiet-period 100
display dot1x
dot1x timer
dot1x re-authenticate
Use dot1x re-authenticate to enable the 802.1X periodic reauthentication feature.
Use undo dot1x re-authenticate to disable the 802.1X periodic reauthentication feature.
The 802.1X periodic reauthentication feature is disabled.
Periodic reauthentication enables the access device to periodically authenticate online 802.1X users on a port. This feature tracks the connection status of online users and updates the authorization attributes assigned by the server, such as the ACL and VLAN.
You can use the dot1x timer reauth-period command to configure the interval for reauthentication.
# Enable the 802.1X periodic reauthentication feature on GigabitEthernet 1/0/1, and set the periodic reauthentication interval to 1800 seconds.
[Sysname] dot1x timer reauth-period 1800
[Sysname-GigabitEthernet1/0/1] dot1x re-authenticate
display dot1x
dot1x timer
dot1x re-authenticate server-unreachable keep-online
Use dot1x re-authenticate server-unreachable keep-online to enable the keep-online feature on a port.
Use undo dot1x re-authenticate server-unreachable to restore the default.
The keep-online feature is disabled on a port. The device logs off online 802.1X authenticated users if no server is reachable for 802.1X reauthentication.
This feature keeps authenticated 802.1X users online when no server is reachable for 802.1X reauthentication.
# Enable the keep-online feature on GigabitEthernet 1/0/1 for 802.1X reauthentication.
[Sysname-GigabitEthernet1/0/1] dot1x re-authenticate server-unreachable keep-online
display dot1x
dot1x retry
Use dot1x retry to set the maximum number of attempts for sending an authentication request to a client.
Use undo dot1x retry to restore the default.
dot1x retry retries
undo dot1x retry
A maximum of two attempts are made to send an authentication request to a client.
retries: Specifies the maximum number of attempts for sending an authentication request to a client. The value range is 1 to 10.
The access device retransmits an authentication request to a client in any of the following situations:
·     The device does not receive any responses from the client within the username request timeout interval. The timer is set by using the dot1x timer tx-period tx-period-value command for the EAP-Request/Identity packet.
·     The device does not receive any responses from the client within the client timeout interval. The timer is set by using the dot1x timer supp-timeout supp-timeout-value command for the EAP-Request/MD5-Challenge packet.
The access device stops retransmitting the request, if it has made the maximum number of request transmission attempts but still received no response.
# Set the maximum number of attempts to 9 for sending an authentication request to a client.
[Sysname] dot1x retry 9
display dot1x
dot1x timer
dot1x smarton
Use dot1x smarton to enable the SmartOn feature on a port.
Use undo dot1x smarton to disable the SmartOn feature on a port.
dot1x smarton
undo dot1x smarton
The SmartOn feature is disabled on a port.
When a SmartOn-enabled port receives an EAPOL-Start packet from an 802.1X client, it sends a unicast EAP-Request/Notification packet to the client. The client will respond with an EAP-Response/Notification packet, which contains the SmartOn switch ID and the MD5 digest of the SmartOn password. The device compares the digest in the packet with the digest on the device. If they are the same, the device continues to perform 802.1X authentication for the client. Otherwise, the device denies the client's 802.1X authentication request.
The SmartOn feature and the online user handshake feature are mutually exclusive.
# Enable the SmartOn feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x smarton
display dot1x
dot1x smarton switched
dot1x smarton password
Use dot1x smarton password to set a SmartOn password.
Use undo dot1x smarton password to restore the default.
dot1x smarton password { cipher | simple } string
No SmartOn password is set.
simple: Specifies password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 1 to 53 characters
The device checks the MD5 digest of the SmartOn password in each received EAP-Response/Notification packet. If the digest is different from the SmartOn password digest on the device, the device stops the 802.1X authentication process for the client that sends this packet.
# Set the SmartOn password to abc in plaintext form.
[Sysname] dot1x smarton password simple abc
display dot1x
dot1x smarton
dot1x smarton retry
Use dot1x smarton retry to set the maximum number of attempts for retransmitting an EAP-Request/Notification packet to a client.
Use undo dot1x smarton retry to restore the default.
dot1x smarton retry retries
A maximum of three attempts are made to retransmit an EAP-Request/Notification packet to a client.
retries: Specifies the maximum attempts for retransmitting an EAP-Request/Notification packet to a client. The value range is 1 to 10.
When the device sends an EAP-Request/Notification packet to the client, the SmartOn client timeout timer (set by using the dot1x smarton timer supp-timeout command) starts. If the device does not receive any EAP-Response/Notification packets from the client before the timer expires, it retransmits the EAP-Request/Notification packet to the client. After the device has made the maximum retransmission attempts but received no response, it stops the 802.1X authentication process for the client.
# Set the maximum attempts to 5 for retransmitting an EAP-Request/Notification packet.
[Sysname] dot1x smarton retry 5
display dot1x
dot1x smarton switchid
Use dot1x smarton switchid to set a SmartOn switch ID.
Use undo dot1x smarton switchid to restore the default.
dot1x smarton switchid switch-string
No SmartOn switch ID exists.
switch-string: Specifies the SmartOn switch ID, a case-sensitive string of 1 to 30 characters.
The device checks the SmartOn switch ID in each received EAP-Response/Notification packet. If the switch ID is not the same as the switch ID on the device, the device stops the 802.1X authentication process for the client that sends this packet.
# Set the SmartOn switch ID to abc.
[Sysname] dot1x smarton switchid abc
display dot1x
dot1x smarton
Use dot1x smarton timer supp-timeout to set the SmartOn client timeout timer.
Use undo dot1x smarton timer supp-timeout to restore the default.
dot1x smarton timer supp-timeout supp-timeout-value
The SmartOn client timeout timer is 30 seconds.
supp-timeout-value: Sets the SmartOn client timeout timer in seconds. The value range is 10 to 120.
The SmartOn client timeout timer starts when the device sends an EAP-Request/Notification packet to the client. If the device does not receive any EAP-Response/Notification packets from the client within the timer interval, it retransmits the EAP-Request/Notification packet. After the device has made the maximum retransmission attempts but received no response, it stops the 802.1X authentication process for the client. To set the maximum retransmission attempts, use the dot1x smarton retry command.
# Set the SmartOn client timeout timer to 20 seconds.
[Sysname] dot1x smarton timer supp-timeout 20
display dot1x
dot1x smarton retry
dot1x timer
Use dot1x timer to set an 802.1X timer.
Use undo dot1x timer to restore the default of an 802.1X timer.
dot1x timer { ead-timeout ead-timeout-value | handshake-period handshake-period-value | quiet-period quiet-period-value | reauth-period reauth-period-value | server-timeout server-timeout-value | supp-timeout supp-timeout-value | tx-period tx-period-value }
undo dot1x timer { ead-timeout | handshake-period | quiet-period | reauth-period | server-timeout | supp-timeout | tx-period }
The following 802.1X timers apply:
·     EAD rule timer: 30 minutes.
·     Handshake timer: 15 seconds.
·     Quiet timer: 60 seconds.
·     Periodic reauthentication timer: 3600 seconds.
·     Server timeout timer: 100 seconds.
·     Client timeout timer: 30 seconds.
·     Username request timeout timer: 30 seconds.
ead-timeout ead-timeout-value: Sets the EAD rule timer in minutes. The value range for the ead-timeout-value argument is 1 to 1440.
handshake-period handshake-period-value: Sets the handshake timer in seconds. The value range for the handshake-period-value argument is 5 to 1024.
quiet-period quiet-period-value: Sets the quiet timer in seconds. The value range for the quiet-period-value argument is 10 to 120.
reauth-period reauth-period-value: Sets the periodic reauthentication timer in seconds. The value range for the reauth-period-value argument is 60 to 7200.
server-timeout server-timeout-value: Sets the server timeout timer in seconds. The value range for the server-timeout-value argument is 100 to 300.
supp-timeout supp-timeout-value: Sets the client timeout timer in seconds. The value range for the supp-timeout-value argument is 1 to 120.
tx-period tx-period-value: Sets the username request timeout timer in seconds. The value range for the tx-period-value argument is 1 to 120.
In most cases, the default settings are sufficient. You can edit the timers, depending on the network conditions.
·     In a low-speed network, increase the client timeout timer.
·     In a vulnerable network, set the quiet timer to a high value.
·     In a high-performance network with quick authentication response, set the quiet timer to a low value.
·     In a network with authentication servers of different performance, adjust the server timeout timer.
The network device uses the following 802.1X timers:
·     EAD rule timer (ead-timeout)—Sets the lifetime of each EAD rule. When the timer expires or the user passes authentication, the rule is removed. If users fail to download the EAD client or fail to pass authentication within the timer interval, they must reconnect to the network to access the free IP.
·     Handshake timer (handshake-period)—Sets the interval at which the access device sends client handshake requests to check the online status of a client that has passed authentication. If the device does not receive a response after sending the maximum number of handshake requests, it considers that the client has logged off.
·     Quiet timer (quiet-period)—Starts when a client fails authentication. The access device must wait the time period before it can process the authentication attempts from the client.
·     Periodic reauthentication timer (reauth-period)—Sets the interval at which the access device periodically reauthenticates online 802.1X users. To enable 802.1X periodic reauthentication on a port, use the dot1x re-authenticate command.
·     Server timeout timer (server-timeout)—Starts when the access device sends a RADIUS Access-Request packet to the authentication server. If no response is received when this timer expires, 802.1X authentication fails.
·     Client timeout timer (supp-timeout)—Starts when the access device sends an EAP-Request/MD5-Challenge packet to a client. If no response is received when this timer expires, the access device retransmits the request to the client.
·     Username request timeout timer (tx-period)—Starts when the access device sends an EAP-Request/Identity packet to a client in response to an authentication request. If the device does not receive a response before this timer expires, it retransmits the request. The timer also sets the interval at which the access device sends multicast EAP-Request/Identity packets to detect clients that cannot actively request authentication.
The change to the periodic reauthentication timer applies to the users that have been online only after the old timer expires. Other timer changes take effect immediately on the device.
# Set the server timeout timer to 150 seconds.
[Sysname] dot1x timer server-timeout 150
display dot1x
Use dot1x unicast-trigger to enable the 802.1X unicast trigger feature.
Use undo dot1x unicast-trigger to disable the 802.1X unicast trigger feature.
The 802.1X unicast trigger feature is disabled.
The unicast trigger feature enables the access device to initiate 802.1X authentication when the device receives a data frame from an unknown source MAC address. The device sends a unicast EAP-Request/Identity packet to the unknown source MAC address. It will retransmit the packet if it does not receive any responses within a period of time (set by using the dot1x timer tx-period command). This process continues until the maximum number of request attempts (set by using the dot1x retry command) is reached.
As a best practice, do not use the unicast trigger on a port that performs port-based access control. If you do so, users on that port might fail to come online.
# Enable the unicast trigger feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x unicast-trigger
display dot1x
dot1x port-method
dot1x retry
dot1x timer
reset dot1x guest-vlan
Use reset dot1x guest-vlan to remove users from the 802.1X guest VLAN on a port.
reset dot1x guest-vlan interface interface-type interface-number [ mac-address mac-address ]
mac-address mac-address: Specifies the MAC address of an 802.1X user in the guest VLAN. If you do not specify this option, the command removes all 802.1X users from the 802.1X guest VLAN on the port.
# Remove the 802.1X user with MAC address 1-1-1 from the 802.1X guest VLAN on GigabitEthernet 1/0/1.
<Sysname> reset dot1x guest-vlan interface gigabitethernet 1/0/1 mac-address 1-1-1
dot1x guest-vlan
reset dot1x statistics
Use reset dot1x statistics to clear 802.1X statistics.
reset dot1x statistics [ ap ap-name [ radio radio-id ] | interface interface-type interface-number ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).If you do not specify an AP, this command clears statistics of 802.1X users for all APs.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify a radio, this command clears 802.1X statistics for all radios on the specified AP.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command clears 802.1X statistics on all ports.
If you do not specify any parameters, this command clears all 802.1X statistics.
# Clear 802.1X statistics on GigabitEthernet 1/0/1.
<Sysname> reset dot1x statistics interface gigabitethernet 1/0/1
display dot1x
  • Become a Partner
  • Partner Resources
