- 10-MPLS Command References
- 01-Basic MPLS commands
- 02-Static LSP commands
- 03-LDP commands
- 04-MPLS TE commands
- 05-Static CRLSP commands
- 06-RSVP commands
- 07-Tunnel policy commands
- 08-MPLS L3VPN commands
- 09-MPLS L2VPN commands
- 10-VPLS commands
- 11-L2VPN access to L3VPN or IP backbone commands
- 12-MPLS OAM commands
- 13-MPLS protection switching commands
- 14-MCE commands
07-Tunnel policy commands | 247.57 KB |
The following compatibility matrixes show the support of hardware platforms for tunnel policy:
Hardware |
Tunnel policy compatibility |
MSR610 |
No |
Yes |
MSR810-LMS, MSR810-LUS |
Yes |
MSR810-SI, MSR810-LM-SI |
Yes |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR1004S-5G, MSR1004S-5G-CN |
Yes |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN |
Yes |
MSR2600-6-X1, MSR2600-10-X1, MSR2600-15-X1, MSR2600-15-X1-T |
Yes |
MSR 2630 |
No |
MSR3600-28, MSR3600-51 |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet, MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
binding-destination
Use binding-destination to bind tunnels to a destination IP address in a tunnel policy, so the tunnels can be used only for a specific VPN service.
Use undo binding-destination to remove the tunnel bindings for a destination IP address.
binding-destination dest-ipv4-address { sr-policy group sr-policy-group-id | te { tunnel number }&<1-n> } [ ignore-destination-check ] [ down-switch ]
binding-destination dest-ipv6-address { srv6-policy group srv6-policy-group-id | srv6-policy { name policy-name | end-point ipv6 ipv6-address color color-value } } [ ignore-destination-check ] [ down-switch ]
undo binding-destination { dest-ipv4-address | dest-ipv6-address [ srv6-policy group srv6-policy-group-id | srv6-policy { name policy-name | end-point ipv6 ipv6-address color color-value } ] }
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware |
Command compatibility |
MSR610 |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
A tunnel policy does not bind tunnels to a destination IP address.
Tunnel policy view
dest-ipv4-address: Specifies a destination IPv4 address.
dest-ipv6-address: Specifies a destination IPv6 address.
sr-policy group sr-policy-group-id: Specifies the SR-MPLS TE policy group to be bound with the specified destination IPv4 address. The sr-policy-group-id argument represents the ID of the SR-MPLS TE policy group, in the range of 1 to 4294967295.
te: Specifies TE tunnels for binding.
tunnel number: Specifies a tunnel to be bound with the specified destination IPv4 address. The number argument represents an existing tunnel interface number on the device.
&<1-n>: Indicates that you can bind a maximum of n tunnels. The value for n is 16. Traffic will be load shared among the bound tunnels.
srv6-policy group srv6-policy-group-id: Specifies the SRv6 TE policy group to be bound with the specified destination IPv6 address. The srv6-policy-group-id argument represents the ID of the SRv6 TE policy group, in the range of 1 to 4294967295.
srv6-policy: Specifies the SRv6 TE policy to be bound with the specified destination IPv6 address.
name policy-name: Specifies an SRv6 TE policy by its name, a case-sensitive string of 1 to 59 characters.
end-point ipv6 ipv6-address color color-value: Specifies an SRv6 TE policy by the destination node address and color value. The ipv6-address argument specifies the IPv6 address of the destination node. The color-value argument represents the color value, in the range of 0 to 4294967295.
ignore-destination-check: Ignores destination check. After this keyword is specified, a bound tunnel (TE tunnel, SR-MPLS TE policy group, SRv6 TE policy group, or SRv6 TE policy) can be selected even if the destination IP address of the bound tunnel is different from the destination IP address of the tunnel policy. If you do not specify this keyword, the destination address of a bound tunnel must be the same as the destination IP address of the tunnel policy.
down-switch: Enables automatic tunnel switchover within the tunnel policy when the bound tunnels (TE tunnels, SR-MPLS TE policy group tunnels, SRv6 TE policy group tunnels, or SRv6 TE policy tunnels) are not available. After this keyword is specified, the tunnel policy selects a tunnel by using the following methods in descending order of priority: tunnel binding—preferred tunnel—load sharing. If you do not specify this keyword, the device selects tunnels only from the bound tunnels of the tunnel policy.
After a tunnel is bound to a destination IP address, traffic destined for the destination IP address will be forwarded only by the bound tunnel.
You can bind tunnels to multiple destination IP addresses in a tunnel policy.
In the same tunnel policy and for the same IPv4 destination address:
· If you execute this command multiple times to bind different types of tunnels, the most recent configuration takes effect.
· If you execute this command multiple times to bind the same type of tunnels, this command takes effect as follows:
¡ If you bind multiple MPLS TE tunnels, the MPLS TE tunnels will load share the traffic.
¡ If you bind SR-MPLS TE policy groups multiple times, the most recent configuration takes effect. That is, you can bind only one SR-MPLS TE policy group to a destination IPv4 address in a tunnel policy.
In the same tunnel policy and for the same IPv6 destination address:
¡ If you bind multiple SRv6 TE policies, the SRv6 TE policy tunnels will load share the traffic.
¡ If you bind SRv6 TE policy groups multiple times, the most recent configuration takes effect. That is, you can bind only one SRv6 TE policy group to a destination IPv6 address in a tunnel policy.
If you execute the binding-destination, preferred-path, and select-seq load-balance-number commands simultaneously for a tunnel policy, the binding-destination command has the highest priority in tunnel selection. More specifically, the tunnel policy selects tunnels as follows:
· If the destination address of a bound tunnel identifies a peer PE, the tunnel policy uses the bound tunnel to forward the traffic to the peer PE. For an SR-MPLS TE policy group, the tunnel destination address is the destination node address of the SR-MPLS TE policy group. For an SRv6 TE policy group, the tunnel destination address is the destination node address of the SRv6 TE policy group. For an SRv6 TE policy, the tunnel destination address is the destination node address of the SRv6 TE policy.
· If no bound tunnels are available for the peer PE, the tunnel policy selects a preferred tunnel whose destination address can identify the peer PE to forward traffic.
· If no preferred tunnel is available for the peer PE, the tunnel policy uses the load sharing method to forward the traffic to the peer PE.
# In tunnel policy policy1, bind destination address 100.1.1.9 to four TE tunnels. Ignore destination check, and allow tunnel selection using other tunnel selection methods within the tunnel policy when the binding TE tunnels are not available.
[Sysname] tunnel-policy policy1
[Sysname-tunnel-policy-policy1] binding-destination 100.1.1.9 te tunnel 1 tunnel 2 tunnel 3 tunnel 4 ignore-destination-check down-switch
preferred-path
display mpls tunnel
Use display mpls tunnel to display tunnel information.
display mpls tunnel { all | statistics | [ vpn-instance vpn-instance-name ] destination { ipv4-address | ipv6-address }
all: Displays all tunnels. GRE and MPLS TE tunnel information is displayed only when the network layer is up.
statistics: Displays tunnel statistics.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays tunnel information for the public network.
destination: Displays the tunnel destined for the specified address.
ipv4-address: Specifies the tunnel destination IPv4 address.
ipv6-address: Specifies the tunnel destination IPv6 address.
# Display information about all tunnels.
<Sysname> display mpls tunnel all
Destination Type Tunnel/NHLFE VPN Instance
2.2.2.2 LSP NHLFE1024 -
3.3.3.3 CRLSP Tunnel2 -
Destination |
Tunnel destination address. |
Type |
Tunnel type: · LSP. · GRE. · CRLSP. · SRLSP. · SRPolicy (SR-MPLS TE policy tunnel). · SRPGroup (SR-MPLS TE policy group tunnel). |
Tunnel/NHLFE |
Tunnel, tunnel bundle, NHLFE entry, or SR-MPLS TE policy group ID. NHLFEnumber represents the ingress LSP or SR-MPLS TE policy tunnel that matches the NHLFE entry with NID of number. |
VPN Instance |
VPN instance name. If the tunnel belongs to the public network, this field displays a hyphen (-). |
# Display tunnel statistics.
<Sysname> display mpls tunnel statistics
LSP : 0
GRE : 0
CRLSP : 0
SRLSP : 0
SRPOLICY : 0
SRPGROUP : 0
SRv6-TE Policy : 0
SRv6-TE Policy Group: 0
LSP |
Number of LSP tunnels. |
GRE |
Number of GRE tunnels. |
CRLSP |
Number of CRLSP tunnels. |
SRLSP |
Number of SRLSP tunnels. |
SRPolicy |
Number of SR-MPLS TE policy tunnels. |
SRPGroup |
Number of SR-MPLS TE policy group tunnels. |
SRv6-TE Policy |
Number of SRv6 TE policy tunnels. |
SRv6-TE Policy Group |
Number of SRv6 TE policy group tunnels. |
display tunnel-info ipv6
Use display tunnel-info ipv6 to display information about IPv6 tunnels.
display tunnel-info ipv6 { all | destination ipv6-address | statistics }
Hardware |
MSR610 |
No |
Yes |
No |
No |
No |
Yes |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
all: Display information about all IPv6 tunnels.
destination ipv6-address: Displays information about tunnels with the specified destination IPv6 address.
Statistics: Displays statistics about IPv6 tunnels.
# Display information about all IPv6 tunnels.
<Sysname> display tunnel-info ipv6 all
Destination : 222::2
Type : SRv6-TE Policy
Color : 10
Forwarding index: 2150629377
VPN instance : -
Policy name : P100
# Display statistics about IPv6 tunnels.
<Sysname> display tunnel-info ipv6 statistics
LSP : 0
GRE : 0
CRLSP : 0
SRLSP : 0
SRv6-TE Policy : 0
Destination |
Type |
Tunnel type: · MPLS LDP—Tunnel established on an IPv6 LDP LSP. · (Not supported.) SRv6 TE Policy—Tunnel established on the forwarding path selected by an SRv6 TE policy. · (Not supported.) SRv6 TE Policy Group—Tunnel established on the forwarding path selected by an SRv6 TE policy group. |
Color |
Color value of the SRv6 TE policy. This field is available only when the tunnel type is SRv6-TE Policy. |
Forwarding Index |
Forwarding entry index. |
VPN Instance |
Name of the VPN instance. For the public network, this field displays a hyphen (-). |
Policy Name |
SRv6 TE policy name. This field is available only when the tunnel type is SRv6-TE Policy. |
Group ID |
SRv6 TE policy group ID. |
LSP |
GRE |
Number of GRE tunnels |
CRLSP |
SRLSP |
SRv6-TE Policy |
This field is not supported in the current software version. Number of tunnels of the SRv6 TE Policy type. |
This field is not supported in the current software version. Number of tunnels of the SRv6 TE Policy Group type. |
display tunnel-policy
Use display tunnel-policy to display tunnel policy information.
display tunnel-policy [ tunnel-policy-name ]
Hardware |
MSR610 |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a tunnel policy, this command displays information about all tunnel policies.
# Display information about all tunnel policies.
<Sysname> display tunnel-policy
Tunnel policy name: abc
Select-Seq: LSP, GRE, CRLSP, SRLSP, SRv6-TE Policy
Load balance number : 1
Strict : No
Preferred paths:
Type : TE
Tunnel: Tunnel11
Type : SRv6-TE Policy(End-point/Color)
Tunnel: 4::4/20
Binding-destination:
Destination IP address: 4::4
Tunnel Type : SRv6-TE Policy(Name)
Tunnels : abc
Tunnel Type : SRv6-TE Policy(End-point/Color)
Tunnels : 1000::1/10
Ignore destnation : No
Down switch : No
Select-Seq |
Tunnel selection order. The tunnel types are displayed in descending order of priority in tunnel selection. SR-TE Policy is not supported in the current software version. |
Load balance number |
Number of tunnels for load balancing. |
Strict |
Whether the strict method is used to select tunnels for load balancing: · No—The tunnel policy can use a hybrid of the specified types of tunnels for load balancing. · Yes—The tunnel policy uses only one type of tunnels for load balancing. |
Preferred paths |
Preferred tunnels information. |
Type |
Type of the preferred tunnel: · TE—MPLS TE tunnel. · Tunnel-bundle—MPLS TE tunnel bundle. · (Not supported.) SR-TE Policy(Name)—SR-MPLS TE policy identified by its name. · (Not supported.) SR-TE Policy(End-point/Color)—SR-MPLS TE policy identified by the endpoint address and color value. · SRv6-TE Policy(Name)—SRv6 TE policy identified by its name. · SRv6-TE Policy(End-point/Color)—SRv6 TE policy identified by the endpoint address and color value. |
Tunnel |
Name of the preferred tunnel: · For an MPLS TE tunnel, this field displays the MPLS TE tunnel interface name in the format of Tunnelnumber. · For an MPLS TE tunnel bundle, this field displays the MPLS TE tunnel bundle interface name in the format of Tunnel-bundlenumber. · For an SRv6 TE policy (endpoint/color), this field displays the endpoint address and color value of the SRv6 TE policy in the format of ip-address/color. · For an SRv6 TE policy (name), this field displays the name of the SRv6 TE policy. |
Binding destination |
Destination-tunnel binding information. |
Destination IP address |
Destination IP address for tunnel binding. |
Tunnel type |
Type of tunnels bound to the destination IP address: · TE—MPLS TE tunnel. · SR-TE Policy Group—SR-MPLS TE policy group tunnel. · (Not supported.) SRv6-TE Policy Group—SRv6 TE policy group tunnel. · SRv6-TE Policy(Name)—SRv6 TE policy identified by its name. · SRv6-TE Policy(End-point/Color)—SRv6 TE policy identified by the endpoint address and color value. |
Tunnels |
Names of the bound tunnels: · For an SRv6 TE policy group, this field displays the group ID in the format of GroupID. · For an SRv6 TE policy (endpoint/color), this field displays the endpoint address and color value of the SRv6 TE policy in the format of ip-address/color. · For an SRv6 TE policy (name), this field displays the name of SRv6 TE policy. |
Ignore destination |
Whether to ignore the destination check. · No—Performs destination check. The destination address of a bound tunnel must be the same as the destination IP address of the tunnel policy. · Yes—Ignores the destination check. A bound tunnel can be selected even if its destination IP address is different from the destination IP address of the tunnel policy. |
Down switch |
Whether to enable automatic tunnel switchover within the tunnel policy when the bound tunnels are not available. · No—Not enabled. · Yes—Enabled. |
mpls te reserved-for-binding
Use mpls te reserved-for-binding to reserve an MPLS TE tunnel for tunnel binding in a tunnel policy.
Use undo mpls te reserved-for-binding to restore the default.
Hardware |
MSR610 |
No |
Yes |
No |
No |
No |
Yes |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
An MPLS TE tunnel can be used by any tunnel policy implementation methods.
Tunnel interface view
If a VPN has high requirements on bandwidth, you can select TE tunnels for the VPN by applying a tunnel policy bound with TE tunnels to the VPN.
You must execute this command for an MPLS TE tunnel before the tunnel can be bound to a destination address in a tunnel policy.
After you execute this command for an MPLS TE tunnel, the tunnel can only be used as a bound tunnel of a tunnel policy. For more information about tunnel binding, see the binding-destination command.
# Reserve an MPLS TE tunnel for tunnel binding in a tunnel policy.
[Sysname] interface tunnel 10 mode mpls-te
[Sysname-Tunnel10] mpls te reserved-for-binding
binding-destination
preferred-path
Use preferred-path to configure a preferred tunnel.
Use undo preferred-path to remove a preferred tunnel.
preferred-path { sr-policy { name sr-policy-name | end-point ipv4 ipv4-address color color-value } | srv6-policy { name srv6-policy-name | end-point ipv6 ipv6-address color color-value } | tunnel number | tunnel-bundle number }
undo preferred-path { sr-policy { name sr-policy-name | end-point ipv4 ipv4-address color color-value } | srv6-policy { name srv6-policy-name | end-point ipv6 ipv6-address color color-value } | tunnel number | tunnel-bundle number }
No preferred tunnels are configured.
Tunnel policy view
sr-policy: Specifies an SR-MPLS TE policy as the preferred tunnel.
The following compatibility matrixes show the support of hardware platforms for the sr-policy keyword:
Hardware |
Parameter compatibility |
MSR610 |
No |
Yes |
No |
No |
Yes |
No |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
No |
MSR3640-X1-HI |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
No |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
name sr-policy-name: Specifies an SR-MPLS TE policy by its name, a case-sensitive string of 1 to 59 characters.
The following compatibility matrixes show the support of hardware platforms for the name sr-policy-name option:
Hardware |
MSR610 |
No |
Yes |
No |
No |
Yes |
No |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
No |
MSR3640-X1-HI |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
No |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
end-point ipv4 ipv4-address color color-value: Specifies an SR-MPLS TE policy by the destination node address and color value. The ipv4-address argument specifies the IPv4 address of the destination node. The color-value argument represents the color value, in the range of 0 to 4294967295.
srv6-policy: Specifies an SRv6 TE policy as the preferred tunnel.
The following compatibility matrixes show the support of hardware platforms for the srv6-policy keyword:
Hardware |
MSR610 |
No |
Yes |
No |
No |
Yes |
No |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
No |
MSR3640-X1-HI |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
No |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
name srv6-policy-name: Specifies an SRv6 TE policy by its name, a case-sensitive string of 1 to 59 characters.
The following compatibility matrixes show the support of hardware platforms for the end-point ipv6 ipv6-address color color-value option;
Hardware |
MSR610 |
No |
Yes |
No |
No |
Yes |
No |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
No |
MSR3640-X1-HI |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
No |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
tunnel number: Specifies an MPLS TE tunnel or a GRE tunnel by its tunnel interface number. The value range for the tunnel interface number is 0 to 10239.
tunnel-bundle number: Specifies a tunnel bundle by its tunnel bundle interface number.
The following compatibility matrixes show the value ranges for the tunnel bundle interface number:
Hardware |
Value range |
MSR610 |
Not supported |
0 to 1023 |
0 to 1023 |
0 to 1023 |
0 to 1023 |
0 to 1023 |
0 to 1023 |
0 to 1023 |
MSR2600-10-X1 |
0 to 1023 |
MSR 2630 |
0 to 1023 |
0 to 1023 |
Not supported |
0 to 1023 |
0 to 2047 |
0 to 2047 |
0 to 2047 |
0 to 2047 |
0 to 2047 |
MSR3640-G |
Not supported |
MSR3640-X1-HI |
Not supported |
Hardware |
Value range |
0 to 1023 |
MSR830-4LM-WiNet |
0 to 1023 |
0 to 1023 |
0 to 1023 |
MSR2600-6-WiNet |
0 to 1023 |
0 to 1023 |
MSR2630-WiNet |
0 to 1023 |
MSR3600-28-WiNet |
0 to 1023 |
MSR3610-X1-WiNet |
0 to 2047 |
0 to 2047 |
Hardware |
Value range |
MSR860-6EI-XS |
0 to 1023 |
MSR860-6HI-XS |
0 to 1023 |
MSR2630-XS |
0 to 1023 |
MSR3600-28-XS |
0 to 1023 |
MSR3610-XS |
0 to 2047 |
MSR3620-XS |
0 to 2047 |
MSR3610-I-XS |
0 to 2047 |
MSR3610-IE-XS |
0 to 2047 |
MSR3620-X1-XS |
0 to 2047 |
MSR3640-XS |
0 to 2047 |
MSR3660-XS |
Not supported |
Hardware |
Value range |
MSR810-LM-GL |
0 to 1023 |
MSR810-W-LM-GL |
0 to 1023 |
MSR830-6EI-GL |
0 to 1023 |
MSR830-10EI-GL |
0 to 1023 |
MSR830-6HI-GL |
0 to 1023 |
MSR830-10HI-GL |
0 to 1023 |
MSR1004S-5G-GL |
0 to 1023 |
MSR2600-6-X1-GL |
0 to 1023 |
MSR3600-28-SI-GL |
Not supported |
You can configure an SR-MPLS TE policy, SRv6 TE policy, MPLS TE tunnel, a GRE tunnel, or a tunnel bundle as a preferred tunnel of a tunnel policy.
As a best practice for an MPLS VPN, configure a preferred tunnel and make sure the destination address of the preferred tunnel interface identifies the peer PE. In this method, the local PE forwards traffic destined for the peer PE over the preferred tunnel.
For a tunnel policy to solely use a tunnel, a tunnel bundle, an SR-MPLS TE policy, or an SRv6 TE policy, do not configure the tunnel, tunnel bundle, SR-MPLS TE policy, or SRv6 TE policy as the preferred tunnel in other tunnel policies.
If you configure multiple preferred tunnels that have the same destination address in a tunnel policy, only the first configured tunnel takes effect. If the first tunnel is not available, the second tunnel is used, and so forth. No load balancing will be performed on these tunnels.
You can configure a maximum of 128 preferred tunnels in a tunnel policy.
# Configure tunnel 1 and tunnel 2 as preferred tunnels for tunnel policy policy1.
[Sysname-tunnel-policy-policy1] preferred-path tunnel 1
[Sysname-tunnel-policy-policy1] preferred-path tunnel 2
Use select-seq load-balance-number to configure the tunnel selection order and set the number of tunnels for load balancing.
Use undo select-seq to restore the default.
select-seq [ strict ] { cr-lsp | gre | lsp | sr-lsp | sr-policy | srv6-policy } * load-balance-number number
undo select-seq
The device selects only one tunnel in LSP, GRE, CRLSP, SRLSP, SR-MPLS TE policy, and SRv6 TE policy order.
Tunnel policy view
strict: Uses the same type of tunnels for load balancing.
· If you specify this keyword, the tunnel policy uses only one type of tunnels for load balancing. For example, if the select-seq strict lsp cr-lsp load-balance-number 3 command is used, the tunnel policy uses only one type of tunnels. If LSP tunnels are available, the tunnel policy uses only LSP tunnels. If no LSP tunnels are available, the tunnel policy uses only CRLSP tunnels.
· If you do not specify this keyword, the tunnel policy can use a hybrid of the specified types of tunnels for load balancing. For example, if the select-seq lsp cr-lsp load-balance-number 3 command is used, the tunnel policy preferentially uses LSP tunnels for load balancing. If the number of LSP tunnels is zero or less than three, the tunnel policy uses CRLSP tunnels to remedy the deficiency of LSP tunnels.
· SR-MPLS TE policy tunnels or SRv6 TE policy tunnels cannot share load with other types of tunnels regardless of whether you have specified this keyword or not.
cr-lsp: Uses CRLSP tunnels.
gre: Uses GRE tunnels.
lsp: Uses LSP tunnels.
sr-lsp: Uses SRLSP tunnels.
sr-policy: Uses SR-MPLS TE policy tunnels.
Hardware |
MSR610 |
No |
Yes |
No |
No |
No |
Yes |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
srv6-policy: Uses SRv6 TE policy tunnels.
Hardware |
MSR610 |
No |
Yes |
No |
No |
No |
Yes |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
load-balance-number number: Specifies the number of tunnels for load balancing.
The following compatibility matrixes show the value ranges for the number argument:
Hardware |
Value range |
MSR610 |
Not supported |
1 to 128 |
1 to 32 |
1 to 128 |
1 to 32 |
1 to 128 |
1 to 128 |
1 to 128 |
MSR2600-10-X1 |
1 to 128 |
MSR 2630 |
1 to 128 |
1 to 128 |
1 to 32 |
1 to 128 |
1 to 128 |
1 to 128 |
1 to 128 |
MSR3610, MSR3620, MSR3620-DP, MSR3640, MSR3660 |
1 to 128 |
1 to 128 |
MSR3640-G |
1 to 32 |
MSR3640-X1-HI |
1 to 32 |
Hardware |
Value range |
1 to 128 |
MSR830-4LM-WiNet |
1 to 128 |
1 to 128 |
1 to 128 |
MSR2600-6-WiNet |
1 to 128 |
1 to 128 |
MSR2630-WiNet |
1 to 128 |
MSR3600-28-WiNet |
1 to 128 |
MSR3610-X1-WiNet |
1 to 128 |
1 to 128 |
Hardware |
Value range |
MSR860-6EI-XS |
1 to 128 |
MSR860-6HI-XS |
1 to 128 |
MSR2630-XS |
1 to 128 |
MSR3600-28-XS |
1 to 128 |
MSR3610-XS |
1 to 128 |
MSR3620-XS |
1 to 128 |
MSR3610-I-XS |
1 to 128 |
MSR3610-IE-XS |
1 to 128 |
MSR3620-X1-XS |
1 to 128 |
MSR3640-XS |
1 to 128 |
MSR3660-XS |
1 to 128 |
Hardware |
Value range |
MSR810-LM-GL |
1 to 128 |
MSR810-W-LM-GL |
1 to 128 |
MSR830-6EI-GL |
1 to 128 |
MSR830-10EI-GL |
1 to 128 |
MSR830-6HI-GL |
1 to 128 |
MSR830-10HI-GL |
1 to 128 |
MSR1004S-5G-GL |
1 to 128 |
MSR2600-6-X1-GL |
1 to 128 |
MSR3600-28-SI-GL |
1 to 32 |
A tunnel type closer to the select-seq keyword has a higher priority.
Tunnels selected by this method are not fixed, making it hard to plan VPN traffic. As a best practice, do not use this method.
· If the destination address of a bound tunnel identifies a peer PE, the tunnel policy uses the bound tunnel to forward the traffic to the peer PE. For an SR-MPLS TE policy group, the tunnel destination address is the destination node address of the SR-MPLS TE policy group. For an SR-MPLS TE policy group, the tunnel destination address is the destination node address of the SR-MPLS TE policy group. For an SRv6 TE policy group, the tunnel destination address is the destination node address of the SRv6 TE policy group. For an SRv6 TE policy, the tunnel destination address is the destination node address of the SRv6 TE policy.
# Configure tunnel policy policy1 to use only CRLSP tunnels, and set the load balancing number to 2.
[Sysname-tunnel-policy-policy1] select-seq cr-lsp load-balance-number 2
tunnel-policy (system view)
Use tunnel-policy to create a tunnel policy and enter its view, or enter the view of an existing tunnel policy.
Use undo tunnel-policy to delete a tunnel policy.
tunnel-policy tunnel-policy-name [ default ]
undo tunnel-policy tunnel-policy-name
No tunnel policies exist.
tunnel-policy-name: Specifies a name for the tunnel policy, a case-sensitive string of 1 to 19 characters.
default: Uses the policy as the global tunnel policy.
The device supports only one global tunnel policy.
By default, a tunnel policy selects only one tunnel in LSP—GRE—CRLSP—SRLSP order.
An MPLS VPN uses the global tunnel policy if it is not bound with a specific tunnel policy or the bound policy does not exist. If the bound policy exists but is null, the MPLS VPN selects only one tunnel in LSP—GRE—CRLSP—SRLSP order.
# Create tunnel policy policy1 and enter its view.
Tunnel selector commands
apply tunnel-policy
Use apply tunnel-policy to specify a tunnel policy for a tunnel selector.
Use undo apply tunnel-policy to restore the default.
apply tunnel-policy tunnel-policy-name
No tunnel policy is specified for a tunnel selector.
Tunnel selector view
If you specify a nonexistent tunnel policy for a tunnel selector, use the tunnel-policy command to create the policy and then configure the policy.
# Specify tunnel policy policy1 for tunnel selector ts1.
[Sysname-tunnel-policy-policy1] select-seq cr-lsp lsp load-balance-number 1
[Sysname-tunnel-policy-policy1] quit
[Sysname] tunnel-selector ts1 permit node 10
[Sysname-tunnel-selector-ts1-10] if-match rd-list 1
[Sysname-tunnel-selector-ts1-10] apply tunnel-policy policy1
display tunnel-selector
tunnel-policy
tunnel-selector
apply tunnel-selector
Use apply tunnel-selector to apply a tunnel selector to BGP VPNv4 routes, BGP VPNv6 routes, or labeled BGP IPv4 or IPv6 unicast routes.
Use undo apply tunnel-selector to cancel the application.
In BGP IPv4 unicast address family view/BGP-VPN IPv4 unicast address family view/BGP IPv6 unicast address family view/BGP-VPN IPv6 unicast address family view:
apply tunnel-selector tunnel-selector-name [ all ]
In BGP VPNv4 address family view/BGP VPNv6 address family view:
No tunnel selector is applied to BGP VPNv4 routes, BGP VPNv6 routes, or labeled BGP IPv4 or IPv6 unicast routes.
tunnel-selector-name: Specifies a tunnel selector by its name, a case-sensitive string of 1 to 40 characters.
all: Applies the tunnel selector to all BGP unicast routes, including labeled routes and subnet routes.
This command can perform route recursion for BGP VPNv4, BGP VPNv6, or labeled BGP IPv4 or IPv6 unicast routes to select expected types of tunnels. It mainly applicable to the following BGP/MPLS L3VPN scenarios:
· In an inter-AS Option B network, an ASBR is not configured with VPN instances but it needs to apply a tunnel policy to the BGP VPNv4 or BGP VPNv6 routes received from the PEs.
· In an HoVPN, an SPE needs to apply a tunnel policy to the BGP VPNv4 or VPNv6 routes received from UPEs.
· In an inter-AS Option C network, the local PE needs to apply a tunnel policy to the BGP labeled routes advertised to the remote PEs.
In an inter-AS Option C network, to perform tunnel load balancing for BGP labeled routes, execute the apply tunnel-selector tunnel-selector-name all command on the ASBR.
Deleting the applied tunnel selector might cause VPN service interruption because the routes cannot recurse to tunnels.
# In BGP IPv4 unicast address family view, apply tunnel selector ts1 to BGP labeled routes.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] apply tunnel-selector ts1
tunnel-selector
display ip rd-list
Use display ip rd-list to display RD list information.
rd-list-number: Specifies an RD list by its number, in the range of 1 to 65535. If you do not specify an RD list, this command display information about all RD lists.
# Display information about all RD lists.
<Sysname> display ip rd-list
Route Distinguisher List Number 1
Index: 1 permit 1.1.1.1:1 2.2.2.2:* 100:1 200:*
Route Distinguisher List Number 2
Index: 2 deny 1:1 2:2
Table 5 Command output
Route Distinguisher List Number |
RD list number. |
Index |
Index of an RD list item. |
permit |
Match mode of the RD list item: · Permit. · Deny. |
ip rd-list
Use display tunnel-selector to display tunnel selector information.
display tunnel-selector [ tunnel-selector-name ]
tunnel-selector-name: Specifies a tunnel selector by its name, a case-sensitive string of 1 to 40 characters. If you do not specify a tunnel selector, this command displays information about all tunnel selectors.
# Display information about all tunnel selectors.
<Sysname> display tunnel-selector
Tunnel-selector: ts1
Permit : 1
if-match ip next-hop prefix-list ipv4prefix1
Tunnel-selector: ts2
Permit : 2
if-match ip address acl 2222
if-match ip rd-list 2
apply tunnel-policy policy2
Table 6 Command output
Tunnel-selector |
Tunnel selector name. |
Permit |
Node match mode and node number of the tunnel selector. The node match mode can be Permit or Deny. |
if-match |
Match criterion configured by the if-match clause. |
apply |
The action to be applied to the matching routes. |
tunnel-selector
if-match community
Use if-match community to configure a community list match criterion for BGP routes
Use undo if-match community to delete a community list match criterion for BGP routes.
undo if-match community [ { basic-community-list-number | name comm-list-name } [ whole-match ] | adv-community-list-number ]&<1-32>
No BGP community list match criterion is configured.
basic-community-list-number: Specifies a basic community list by its number, in the range of 1 to 99.
adv-community-list-number: Specifies an advanced community list by its number, in the range of 100 to 199.
name comm-list-name: Specifies a community list by its name, a case-sensitive string of 1 to 63 characters that cannot contain only numbers.
whole-match: Exactly matches the specified community list. All of the specified communities and only those communities must be present.
&<1-32>: Indicates that you can specify a maximum of 32 community lists.
If the specified community list number or name does not exist, use the ip community-list command to create it.
The whole-match keyword takes effect only on the community list specified in front of this keyword. If you specify multiple community lists and require exact match for each community list, add this keyword after each filter. This keyword takes effect only on basic community lists.
# Configure community list 1 to permit BGP routes with community number 100 or 200. Then configure node 10 in permit mode for tunnel selector ts1 to use community list 1 to match BGP routes.
[Sysname-tunnel-selector-ts1-10] if-match community 1
ip community-list (Layer 3—IP Routing Command Reference)
if-match ip
Use if-match ip to configure an IPv4 route match criterion.
Use undo if-match ip to delete the specified IPv4 route match criterion.
if-match ip { address | next-hop } { acl ipv4-acl-number | prefix-list prefix-list-name }
undo if-match ip { address | next-hop } [ acl | prefix-list ]
No IPv4 route match criterion is configured.
address: Matches the destination address of IPv4 routes.
next-hop: Matches the next hop of IPv4 routes.
acl ipv4-acl-number: Specifies an ACL by its number. The value range for the ipv4-acl-number argument is 2000 to 3999 for the address keyword, and 2000 to 2999 for the next-hop keyword.
prefix-list prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
If the specified ACL or IP prefix list does not exist, use the acl command or the ip prefix-list command to create it.
If the specified ACL does not exist or no rules exist in the ACL, the ACL does not take effect in IPv4 route matching.
If the specified ACL contains a rule with the vpn-instance keyword, the ACL rule does not take effect in IPv4 route matching.
# Create a tunnel selector named ts1, and configure node 10 for the tunnel selector to permit IPv4 routes whose next hop matches IP prefix list p1.
[Sysname-tunnel-selector-ts1-10] if-match ip next-hop prefix-list p1
acl (ACL and QoS Command Reference)
ip prefix-list (Layer 3—IP Routing Command Reference)
if-match ipv6
Use if-match ipv6 to configure an IPv6 route match criterion.
Use undo if-match ipv6 to delete the specified IPv6 route match criterion.
if-match ipv6 { address | next-hop } { acl ipv6-acl-number | prefix-list prefix-list-name }
undo if-match ipv6 { address | next-hop } [ acl | prefix-list ]
No IPv6 route match criterion is configured.
address: Matches the destination address of IPv6 routes.
next-hop: Matches the next hop of IPv6 routes.
acl ipv6-acl-number: Specifies an IPv6 ACL by its number. The value range for the ipv6-acl-number argument is 2000 to 3999 for the address keyword, and 2000 to 2999 for the next-hop keyword.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
If the specified IPv6 ACL or IPv6 prefix list does not exist, use the acl command or the ipv6 prefix-list command to create it.
If the specified IPv6 ACL does not exist or no rules exist in the IPv6 ACL, the IPv6 ACL does not take effect in IPv6 route matching.
If the specified IPv6 ACL contains a rule with the vpn-instance keyword, the IPv6 ACL rule does not take effect in IPv6 route matching.
# Create a tunnel selector named ts1, and configure node 10 for the tunnel selector to permit IPv6 routes whose next hop matches IPv6 prefix list p1.
[Sysname-tunnel-selector-ts1-10] if-match ipv6 next-hop prefix-list p1
ipv6 prefix-list (Layer 3—IP Routing Command Reference)
if-match rd-list
Use if-match rd-list to configure an RD list match criterion for BGP routes.
Use undo if-match rd-list to delete the RD list match criterion.
No RD list match criterion is configured for BGP routes.
When you configure an RD list match criterion for BGP route filtering, the following applies:
· If the specified RD list is not configured (by using the ip rd-list command), routes are permitted by the RD list.
· If the RD list is well configured but a route does not match any RD specified in the list, the route is denied by the RD list.
· The relation between the RDs specified in an RD list are logical OR in route matching, because each route has only one RD.
# Configure RD list 1 to permit BGP routes with RD 1:1. Create tunnel selector ts1, and configure node 10 for the tunnel selector to permit BGP routes that match RD list 1.
[Sysname] ip rd-list 1 permit 1:1
ip rd-list
ip rd-list
Use ip rd-list to configure an RD list.
Use undo ip rd-list to delete an RD list.
undo ip rd-list rd-list-number [ index index-number ] [ { deny | permit } route-distinguisher&<1-10> ]
No RD lists exist.
rd-list-number: Specifies the RD list number, in the range of 1 to 65535.
index index-number: Specifies the index number for an RD list item. The value range for the index-number argument is 1 to 4294967295. An item with a smaller index number is matched first. If you do not specify this option, the system automatically assigns index numbers starting from 10 and in steps of 10. If the maximum value has been assigned, the system assigns index numbers from the available values, in ascending order.
deny: Sets the match mode of the RD list to deny.
permit: Sets the match mode of the RD list to permit.
route-distinguisher&<1-10>: Specifies up to 10 RDs. An RD is a string of 3 to 21 characters, and can be configured in one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 16-bit AS number:wildcard. For example, 101:*.
· 32-bit IPv4 address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit IPv4 address:wildcard. For example, 192.168.122.15:*.
· 32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
· 32-bit AS number:wildcard, where the minimum value of the AS number is 65536. For example, 65536:*.
After you configure RD lists by using the ip rd-list command, you can implement BGP route filtering by using a tunnel selector as follows:
1. Use the if-match rd-list command to specify a created RD list to configure an RD list match criterion in tunnel selector view.
2. Applies the tunnel selector to BGP routes.
If an RD list is used for route filtering, the following applies:
· If the RD list is not configured, routes are permitted by the RD list.
# Create RD list 1 to permit routes with RD 100:1.
[Sysname] ip rd-list 1 permit 100:1
· display ip rd-list
· if-match rd-list
tunnel-selector
Use tunnel-selector to create a tunnel selector and enter its view, or enter the view of an existing tunnel selector.
Use undo tunnel-selector to delete a tunnel selector.
tunnel-selector tunnel-selector-name { deny | permit } node node-number
undo tunnel-selector tunnel-selector-name { deny | permit } node node-number
No tunnel selectors exist.
tunnel-selector-name: Specifies the tunnel selector name, a case-sensitive string of 1 to 40 characters.
deny: Sets the match mode of the tunnel selector to deny. If a route matches all the if-match clauses of a node, the route is denied and does not match the next node. If a route does not match an if-match clause of a node, the route continues to match the next node.
permit: Sets the match mode of the tunnel selector to permit. If a route matches all the if-match clauses of a node, the route matches the node. If a route does not match an if-match clause of a node, the route continues to match the next node.
node node-number: Specifies a node number for the tunnel selector. The value range for node-number argument is 0 to 65535. The node with a smaller node number is matched first.
A tunnel selector is needed in the following BGP/MPLS L3VPN scenarios:
# Create a tunnel selector and enter its view. Specify the tunnel selector name as ts1, node number as 10, and match mode as permit.
