- 27-WLAN Configuration Guide(FAT AP)
- 01-Compatibility of hardware and AP functionality
- 02-Radio management configuration
- 03-WLAN access configuration
- 04-WLAN security configuration
- 05-WLAN authentication configuration
- 06-WLAN QoS configuration
- 07-WLAN load balancing configuration
- 08-Band navigation configuration
- 09-WLAN multicast optimization configuration
00-Preface | 100.00 KB |
Preface
This configuration guide describes WLAN(FAT AP) features.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
