03-EVPN VPLS configuration | 781.12 KB |
Neighbor auto-discovery and PW establishment
MAC address learning, aging, and withdrawal
Traffic forwarding and flooding
LDP or static PW ACs for EVPN PWs
Restrictions and guidelines: EVPN VPLS configuration
Mapping a Layer 3 interface to a VSI
Mapping an Ethernet service instance to a VSI
Configuring BGP to advertise BGP EVPN routes
Restrictions and guidelines for BGP EVPN route advertisement
Enabling BGP to advertise BGP EVPN routes
Enabling advertisement of MPLS-encapsulated BGP EVPN routes
Configuring optimal route selection and route advertisement settings
Configuring EVPN VPLS multihoming
Restrictions and guidelines for EVPN VPLS multihoming
Assigning an ESI to an interface
Configuring the DF election algorithm
Setting the advertisement delay timer for Ethernet auto-discovery routes
Configuring local FRR for EVPN VPLS
Generating MAC address entries for received MAC/IP advertisement routes
Enabling VSIs to ignore the state of ACs
Disabling advertisement of EVPN multihoming routes
Enabling the device to monitor the BGP peer status of another local edge device
Managing remote MAC address entries and remote ARP learning
Disabling MAC address advertisement
Disabling learning of MAC addresses from ARP information
Disabling ARP information advertisement
Enabling conversational learning for remote ARP entries
Configuring LDP or static PWs as ACs for EVPN PWs
About LDP or static PW AC configuration for EVPN PWs
Restrictions and guidelines for LDP or static PW AC configuration for EVPN PWs
Prerequisites for LDP or static PW AC configuration for EVPN PWs
Configuring LDP PWs as ACs for EVPN PWs
Configuring static PWs as ACs for EVPN PWs
Confining floods to the local site
Enabling ARP flood suppression
Enabling packet statistics for an AC
Restrictions and guidelines for AC packet statistics
Enabling packet statistics for a Layer 3 interface
Enabling packet statistics for an Ethernet service instance
Enabling SNMP notifications for L2VPN PWs
Display and maintenance commands for EVPN VPLS
EVPN VPLS configuration examples (on routers)
Example: Configuring EVPN VPLS between singlehomed sites
Example: Configuring EVPN VPLS multihoming (access through aggregate links)
Example: Configuring EVPN VPLS multihoming (access through an S-Trunk system)
Example: Configuring local FRR for EVPN VPLS
Example: Configuring LDP PWs as ACs for EVPN PWs
EVPN VPLS configuration examples (on switches)
About EVPN VPLS
EVPN Virtual Private LAN Service (VPLS) is a Layer 2 VPN technology that uses MP-BGP to advertise EVPN routes in the control plane and MPLS for forwarding in the data plane. EVPN VPLS provides point-to-multipoint forwarding services for users with MAC address table lookup in VSIs.
EVPN VPLS network model
As shown in Figure 1, an EVPN VPLS network contains the following devices:
· Customer edge (CE)—Customer device directly connected to the service provider network.
· Provider edge (PE)—Service provider device connected to CEs. PEs provide access to the EVPN VPLS network and forward traffic between customer network sites by using public tunnels.
A PE uses ACs, PWs, tunnels, and VSIs to provide EVPN VPLS services.
· Attachment circuit (AC)—A physical or virtual link between a CE and a PE.
· Pseudowire (PW)—A pair of unidirectional virtual connections in opposite directions between two PEs.
· Public tunnel—A connection that carries one or more PWs across the MPLS or IP backbone. A public tunnel can be an LSP, GRE, or MPLS TE tunnel.
· Virtual Switch Instance (VSI)—A virtual switch instance provides Layer 2 switching services for a VPLS instance (EVPN instance) on a PE. A VSI acts as a virtual switch that has all the functions of a conventional Ethernet switch, including source MAC address learning, MAC address aging, and flooding. VPLS uses VSIs to forward Layer 2 data packets in EVPN instances.
A PE uses IMET routes to automatically discover neighbors and establish PWs. When a PE receives an IMET route in a VSI, it compares the export route targets of the route with the import route targets of the EVPN instance associated with the VSI. If they are match, the PE will establish a unidirectional virtual connection based on the PE address and PW label information carried in the route. PW establishment is finished when two virtual connections in opposite directions are established between two PEs.
Source MAC address learning
A PE uses the MAC address table of a VSI to forward Layer 2 unicast traffic for that VSI.
A PE learns source MAC addresses in the following ways:
· Local MAC address learning—When the PE receives a frame from a local CE, it first identifies the VSI of the frame. Then, the PE adds the source MAC address of the frame (the MAC address of the local CE) to the MAC address table of the VSI. The output interface of the MAC address entry is the AC that receives the frame.
· Remote MAC address learning—A PE advertises the MAC addresses of local CEs to remote PEs through BGP EVPN MAC/IP advertisement routes. When a remote PE receives the routes, it adds the received MAC addresses to the MAC address table of the corresponding VSI. The output interface is the PW.
MAC address aging
· Local MAC address aging—The MAC address table uses an aging timer for each dynamic MAC address entry. If no packet is received from a MAC address before the aging timer expires, VPLS deletes the MAC address.
· Remote MAC address aging—Remote MAC addresses advertised through MAC/IP advertisement routes are not removed from the MAC address table until routes to withdraw the MAC addresses are received.
MAC address withdrawal
When an AC goes down, the PE deletes MAC addresses on the AC. Then it sends an LDP address withdrawal message to notify all other PEs in the EVPN instance to delete those MAC addresses.
Unicast traffic forwarding
After a PE receives a unicast packet with a known destination MAC address from an AC, the PE searches the MAC address table of the VSI bound to the AC for packet forwarding.
· If the output interface in the entry is a PW, the PE inserts the PW label of the PW to the packet, and adds the public tunnel header to the packet. It then forwards the packet to the remote PE over the PW. If the public tunnel is an LSP or MPLS TE tunnel, each packet on the PW contains two labels. The inner label is the PW label, which identifies the PW and ensures that the packet is forwarded to the correct VSI. The outer label is the public LSP or MPLS TE tunnel label, which ensures that the packet is correctly forwarded to the remote PE.
· If the output interface in the entry is a local interface, the PE directly forwards the packet to the local interface.
After a PE receives a unicast packet with a known destination MAC address from a PW, the PE searches the MAC address table of the VSI bound to the PW for packet forwarding. The PE forwards the packet through the output interface in the matching MAC address entry.
Flooding
When a PE receives flood traffic from an AC in a VSI, it will flood the traffic to the following interfaces:
· All ACs in the VSI except for the incoming AC.
· All PWs associated with the VSI.
When a PE receives flood traffic from a PW, it will flood the traffic to all ACs in the VSI bound to the PW.
Full mesh and split horizon
A Layer 2 network requires a loop prevention protocol such as STP to avoid loops. However, a loop prevention protocol on PEs brings management and maintenance difficulties. Therefore, EVPN VPLS uses the following methods to prevent loops:
· Full mesh—Every two PEs in an EVPN instance must establish PWs. The PWs form a full mesh among PEs in the EVPN instance.
· Split horizon—A PE does not forward packets received from a PW to any other PWs in the same VSI but only forwards those packets to ACs.
About EVPN VPLS multihoming
As shown in Figure 2, EVPN VPLS supports deploying multiple PEs at a site for redundancy and high availability. On the redundant PEs, Ethernet links connected to the site form an ES that is uniquely identified by an ESI. EVPN VPLS supports only dualhoming.
Figure 2 EVPN VPLS multihoming
DF election
To prevent redundant PEs from sending duplicate flood traffic to a multihomed site, a designated forwarder (DF) is elected from the PEs to forward flood traffic to the local site. PEs that fail the election are assigned the backup designated forwarder (BDF) role. BDFs do not forward flood traffic to the local site.
DF election can be performed by using a VLAN tag-based algorithm or preference-based algorithm.
· VLAN tag-based DF election
PEs select a DF for each AC based on the VLAN tag and PE IP address as follows:
a. Arrange source IP addresses in Ethernet segment routes with the same ESI in ascending order and assign a sequence number to each IP address, starting from 0.
b. Divide the lowest VLAN ID permitted on an AC by the number of the redundant PEs, and match the reminder to the sequence numbers of IP addresses.
c. Assign the DF role to the PE that uses the IP address with the matching sequence number.
The following uses PE 1 and PE 2 in Figure 4 as an example to explain the DF election procedure:
a. PE 1 and PE 2 send Ethernet segment routes to each other.
b. The PEs assign sequence numbers 0 and 1 to IP addresses 1.1.1.1 and 2.2.2.2 in the Ethernet segment routes, respectively.
c. The PEs divide 4 (the lowest VLAN ID permitted by the ACs) by 2 (the number of redundant PEs), and match the reminder 0 to the sequence numbers of the IP addresses.
d. The DF role is assigned to PE 1 at 1.1.1.1.
Figure 4 VLAN tag-based DF election
· Preference-based DF election
PEs select a DF for each ES based on the DF election preference, the Don't Preempt Me (DP) bit in Ethernet segment routes, and PE IP address. The DP bit can be set to one of the following values:
¡ 1—Non-revertive mode is enabled for preference-based DF election (DF preemption is disabled). A DF retains its role when a new DF is elected.
¡ 0—Non-revertive mode is disabled for preference-based DF election (DF preemption is enabled).
Preference-based DF election uses the following rules to select a DF for an ES:
a. The PE with higher preference becomes the DF.
b. If two PEs have the same preference, the PE with the DP bit set to 1 becomes the DF.
c. If both of the PEs have the DP bit set to 1, the PE with a lower IP address becomes the DF.
As shown in Figure 5, PE 2 is the DF for ES 1, and PE 1 is the DF for ES 2.
Figure 5 Preference-based DF election
Redundancy mode
The device supports single-active redundancy mode and all-active redundancy mode of EVPN VPLS multihoming.
· Single-active mode—This mode allows one of the redundant PEs to forward traffic. When the primary PE becomes unavailable because of device failure or link failure, traffic is switched to the secondary PE for forwarding.
· All-active mode—This mode allows all redundant PEs to a multihomed site to load share unicast traffic.
IP aliasing
In all-active redundancy mode, all redundant PEs of an ES advertise the ES to remote PEs through MP-BGP. IP aliasing allows a remote PE to add the IP addresses of all the redundant PEs as the next hops for the MAC or ARP information received from one of these PEs. This mechanism creates ECMP routes between the remote PE and the redundant PEs.
Local FRR for EVPN VPLS
As shown in Figure 6, CE 1 is dualhomed to PE 1 and PE 2, and PE 1 is the DF. When the AC on PE 1 fails, PE 1 deletes the corresponding MAC address entries and advertises the local unreachable event to PE 2 and remote PEs (PE 3 in this example). Then, the remote PEs will switch traffic destined for CE 1 to the tunnels to PE 2. This process takes some time. PE 1 might receive packets destined for CE 1 before the remote PEs are notified of the unreachable event and perform link switchover. In this situation, PE 1 drops the packets, because the AC's MAC address entries have been deleted. To resolve this issue, enable local FRR on PE 1. If an AC fails, PE 1 changes the output interface of the AC's MAC address entries to the index of the PW between PE 1 and PE 2. When receiving packets from remote PEs after its AC fails, PE 1 forwards the packets to PE 2 over the PW to prevent traffic loss.
Figure 6 Local FRR network diagram
ARP flood suppression reduces ARP request broadcasts by enabling a PE to reply to ARP requests on behalf of VMs.
As shown in Figure 7, this feature snoops ARP requests, ARP responses, and BGP EVPN routes to populate the ARP flood suppression table with local and remote MAC addresses. If an ARP request has a matching entry, the PE replies to the request on behalf of the VM. If no match is found, the PE floods the request to both local and remote sites.
Figure 7 ARP flood suppression
ARP flood suppression uses the following workflow:
1. CE1 sends an ARP request to obtain the MAC address of CE 2.
2. PE 1 creates a suppression entry for CE 1, floods the ARP request to local CEs and remote PEs (PE 2 and PE 3) in the VSI, and sends the suppression entry to PE 2 and PE 3 through BGP EVPN. Unicast-mode flooding is used to illustrate the workflow.
3. PE 2 and PE 3 de-encapsulate the ARP request and broadcast the request to local CEs in the VSI.
4. CE 2 sends an ARP reply after it receives the ARP request.
5. PE 2 creates a suppression entry for CE 2, forwards the ARP reply to PE 1, and sends the suppression entry to PE 1 and PE 3 through BGP EVPN.
6. PE 1 de-encapsulates the ARP reply and forwards the ARP reply to CE 1.
7. CE 4 sends an ARP request to obtain the MAC address of CE 1.
8. PE 1 creates a suppression entry for CE 4 and replies to the ARP request.
9. CE 3 sends an ARP request to obtain the MAC address of CE 1.
10. PE 3 creates a suppression entry for CE 3 and replies to the ARP request.
Control word
The control word field is between the MPLS label stack and the Layer 2 data. It carries control information for the Layer 2 frame, for example, the sequence number.
The control word feature has the following functions:
· Avoids fragment disorder. In multipath forwarding, fragments received might be disordered. The control word feature reorders the fragments according to the sequence number carried in the control word field.
· Identifies the original payload length for packets that include padding.
The control word field is optional for EVPN VPLS. You can configure whether to carry the control word field in packets sent on PWs. If you enable the control word feature on PEs at both ends of a PW, packets transmitted on the PW carry the control word field. Otherwise, the packets do not carry the control word field.
MAC mobility
MAC mobility refers to the movement of a VM or host from one ES to another. The source PE is unaware of the MAC move event. To notify other PEs of the change, the destination PE advertises a MAC/IP advertisement route for the MAC address. The source PE withdraws the old route for the MAC address after receiving the new route. The MAC/IP advertisement route has a sequence number that increases when the MAC address moves. The sequence number identifies the most recent move if the MAC address moves multiple times.
EVPN E-tree
About EVPN E-tree
In an EVPN VPLS network, EVPN E-tree isolates unicast and flood traffic (broadcast, multicast, and unknown unicast) of ACs in the same EVPN instance based on the AC roles. With EVPN E-tree, the device isolates unicast and flood traffic of ACs in the same EVPN instance as follows:
· Leaf ACs can access root ACs.
· Leaf ACs cannot access each other.
· Root ACs can access each other and access leaf ACs.
Figure 8 EVPN E-tree network diagram
Local traffic isolation
EVPN E-tree isolates traffic between local ACs on a PE as follows:
· When the PE receives packets from a leaf AC on a VSI, it forwards the packets only to root ACs on the VSI.
· When the PE receives packets from a root AC on a VSI, it forwards the packets to all local ACs on the VSI except the incoming AC.
Remote known unicast traffic isolation
With EVPN E-tree, PEs perform MAC address learning for hosts attached to leaf ACs as follows:
1. When a PE receives a packet from a leaf AC, it learns the source MAC address of the packet and adds the Leaf flag to the MAC address.
2. The PE advertises the MAC address to the remote PE in a MAC/IP advertisement route. The route carries the E-tree extended community attribute that contains the Leaf flag.
3. The remote PE adds the MAC address that carries the Leaf flag to the MAC address table.
When one PE receives a packet destined for a host on another PE from a local AC, it searches the MAC address table for the destination MAC address. If the entry of the destination MAC address has the Leaf flag and the packet is also from a leaf AC, the PE discards the packet. In other situations, the PE forwards the packet.
Remote flood traffic isolation
With EVPN E-tree, a PE assigns a Leaf label to the leaf ACs of each VSI. The PE adds the Leaf label to the E-tree extended community attribute in Ethernet auto-discovery routes and advertises the routes to remote PEs.
EVPN E-tree isolates flood traffic from one PE to another PE as follows:
1. When a PE receives a flood packet from a leaf AC on a VSI, it adds the Leaf label of that VSI to the packet, and then adds the private network label and public network label to the packet. After that, the PE forwards the packet to the remote PE.
2. The remote PE removes the private network label and public network label and finds the Leaf label. Then, the PE forwards the packet only to local root ACs on the same VSI.
This feature ensures that a traditional VPLS network and an EVPN VPLS network can communicate with each other. The LDP or static PWs in the VPLS network are configured as ACs to the EVPN VPLS network. These ACs are referred to as UPWs in the EVPN VPLS network. Packets can be forwarded between EVPN PWs and UPWs, so the VPLS and EVPN VPLS networks can communicate with each other.
With this feature, an LDP or static PW can be single-homed to an EVPN PW or two LDP or static PWs can be dual-homed to two EVPN PWs.
As shown in Figure 9, in the VPLS network, PE 1 is connected to PE 2 and PE 3 through LDP or static PWs. One of the PWs is the primary PW and the other PW is the backup PW. The PWs are UPWs. In the EVPN VPLS network, PE 4 is connected to PE 2 and PE 3 through EVPN PWs. The UPWs in the VPLS network act as ACs for the EVPN VPLS network. When PE 2 or PE 3 receives packets from the UPWs, it decapsulates MPLS encapsulation from the packets and looks up the MAC address table for a matching EVPN PW. Then, the PE adds MPLS encapsulation to the packets based on the EVPN PW and forwards the packets to PE 4. When PE 2 or PE 3 receives packets from an EVPN PW, it uses the same procedure to process the packets.
Figure 9 LDP or static PW ACs for EVPN PWs
EVPN VPLS tasks at a glance
To configure EVPN VPLS, perform the following tasks:
b. (Optional.) Configure VSI parameters
2. Configuring an EVPN instance
¡ Mapping a Layer 3 interface to a VSI
¡ Mapping an Ethernet service instance to a VSI
4. Configuring BGP to advertise BGP EVPN routes
a. Enabling BGP to advertise BGP EVPN routes
b. Enabling advertisement of MPLS-encapsulated BGP EVPN routes
c. (Optional.) Configuring optimal route selection and route advertisement settings
d. (Optional.) Maintaining BGP sessions
5. (Optional.) Configuring a PW class
6. (Optional.) Configuring EVPN VPLS multihoming
a. Assigning an ESI to an interface
b. (Optional.) Configuring the DF election algorithm
c. (Optional.) Setting the DF election delay
d. (Optional.) Setting the advertisement delay timer for Ethernet auto-discovery routes
e. (Optional.) Configuring local FRR for EVPN VPLS
f. (Optional.) Generating MAC address entries for received MAC/IP advertisement routes
g. (Optional.) Enabling VSIs to ignore the state of ACs
h. (Optional.) Disabling advertisement of EVPN multihoming routes
i. (Optional.) Ignoring the Ethernet tag on advertisement of Ethernet auto-discovery and MAC/IP advertisement routes
j. (Optional.) Enabling the device to monitor the BGP peer status of another local edge device
7. (Optional.) Managing remote MAC address entries and remote ARP learning
¡ Disabling MAC address advertisement
¡ Disabling learning of MAC addresses from ARP information
¡ Disabling ARP information advertisement
8. (Optional.) Enabling conversational learning for remote ARP entries
9. (Optional.) Enabling EVPN E-tree
10. (Optional.) Optimizing and maintaining an EVPN VPLS network:
¡ Confining floods to the local site
¡ Enabling ARP flood suppression
¡ Enabling packet statistics for an AC
¡ Enabling SNMP notifications for L2VPN PW
EVPN VPLS is mutually exclusive with EVPN-DCI dualhoming. Do not use the evpn edge group command in an EVPN VPLS network. For more information about EVPN-DCI dualhoming and the evpn edge group command, see "Configuring EVPN-DCI."
Configuring a VSI
Creating a VSI
1. Enter system view.
2. Enable L2VPN.
l2vpn enable
By default, L2VPN is disabled.
3. Create a VSI and enter VSI view.
vsi vsi-name
4. Bring up the VSI.
By default, a VSI is not administratively down.
2. Enter VSI view.
vsi vsi-name
3. Configure a VSI description.
By default, a VSI does not have a description.
4. Set the MTU of the VSI.
mtu mtu
The default MTU for a VSI is 1500 bytes.
5. Set the maximum bandwidth for known unicast traffic of the VSI.
bandwidth bandwidth
By default, the maximum bandwidth is not limited for known unicast traffic of a VSI.
6. Set the broadcast, multicast, or unknown unicast bandwidth restraints of the VSI.
restrain { broadcast | multicast | unknown-unicast } bandwidth
The default for this command varies by device model.
7. Configure MAC address learning features for the VSI:
a. Enable MAC address learning for the VSI.
mac-learning enable
By default, MAC address learning is enabled for a VSI.
b. (Optional.) Set a limit for the VSI's MAC address table.
mac-table limit mac-limit
By default, no limit is set for a VSI's MAC address table.
c. (Optional.) Enable the VSI to drop source-unknown unicast frames if the MAC address table is full.
mac-table limit drop-unknown
By default, the VSI forwards source-unknown unicast frames without learning the source MAC address if the MAC address table is full.
The BGP EVPN routes advertised by a PE carry the RD and route targets configured for the EVPN instance of the routes.
You can configure routing policies in VSI EVPN instance view. An import routing policy is used for filtering the BGP EVPN routes received by the EVPN instance, and an export routing policy is used for filtering the BGP EVPN routes advertised by the EVPN instance.
You can bind a VSI only to one EVPN instance.
2. Enter VSI view.
vsi vsi-name
3. Create an EVPN instance and enter VSI EVPN instance view.
evpn encapsulation mpls
4. Configure an RD for the EVPN instance.
By default, no RD is configured for an EVPN instance.
5. Configure route targets for the EVPN instance.
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ]
By default, an EVPN instance does not have route targets.
Parameter |
Do not specify the same export targets for the EVPN instances of different VSIs. Do not specify the same export targets for the EVPN instances created in different views (system view, VSI view, VPN instance view, public instance view, and cross-connect group view). As a best practice, the export targets configured for the following objects do not match the import targets configured for the EVPN instances created in cross-connect group view: · VPN instances. · The public instance. · EVPN instances created in VSI view, VPN instance view, and public instance view. |
import-extcommunity |
As a best practice, the import targets configured for the following objects do not match the export targets configured for the EVPN instances created in cross-connect group view: · VPN instances. · The public instance. · EVPN instances created in VSI view, VPN instance view, and public instance view. |
6. (Optional.) Apply a PW class to the EVPN instance.
pw-class class-name
By default, no PW class is applied to an EVPN instance.
The specified PW class applies to all PWs in the EVPN instance.
7. (Optional.) Apply a tunnel policy to the EVPN instance.
tunnel-policy tunnel-policy-name
By default, no tunnel policy is applied to an EVPN instance.
8. (Optional.) Apply an export routing policy to the EVPN instance.
By default, no export routing policy is applied to an EVPN instance. The EVPN instance does not filter advertised routes.
9. (Optional.) Apply an import routing policy to the EVPN instance.
By default, no import routing policy is applied to an EVPN instance. The EVPN instance accepts a route when the export route targets of the route match local import route targets.
Mapping ACs to a VSI
To assign the customer traffic on a Layer 3 interface to a VSI, map that interface to the VSI. The VSI uses its MAC address table to forward the customer traffic.
For more information about the commands in this task, see VPLS in MPLS Command Reference.
2. Enter Layer 3 interface view.
3. Map the Layer 3 interface to a VSI.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ]
By default, a Layer 3 interface is not mapped to a VSI.
An Ethernet service instance matches a list of VLANs on a site-facing interface by using a frame match criterion. The frame match criterion specifies the characteristics of traffic from the VLANs, such as tagging status and VLAN IDs. The PE assigns traffic from the VLANs to a VSI by mapping the Ethernet service instance to the VSI. The VSI performs Layer 2 forwarding for the VLANs based on its MAC address table.
An Ethernet service instance can contain only one match criterion. To change the match criterion, you must remove the original criterion first. When you remove the match criterion in an Ethernet service instance, the mapping between the service instance and the VSI is removed automatically.
2. Enter interface view.
3. Create an Ethernet service instance and enter Ethernet service instance view.
service-instance instance-id
4. Choose one option to configure a frame match criterion.
¡ Match frames with the specified inner VLAN tags.
encapsulation c-vid { vlan-id | vlan-id-list }
¡ Match frames with the specified outer VLAN tags.
encapsulation s-vid { vlan-id | vlan-id-list } [ only-tagged ]
¡ Match frames with the specified inner and outer VLAN tags.
encapsulation s-vid vlan-id c-vid { vlan-id-list | all }
¡ Match any VLAN tagged or untagged frames.
encapsulation { tagged | untagged }
¡ Match frames that do not match any other service instance on the interface.
encapsulation default
An interface can contain only one Ethernet service instance that uses the default match criterion.
An Ethernet service instance that uses the default match criterion matches any frames if it is the only instance on the interface.
By default, an Ethernet service instance does not contain a frame match criterion.
5. Map the Ethernet service instance to a VSI.
By default, an Ethernet service instance is not mapped to a VSI.
For more information about BGP commands in this task, see Layer 3—IP Routing Command Reference.
2. Configure a global router ID.
router id router-id
By default, no global router ID is configured.
3. Enable a BGP instance and enter BGP instance view.
By default, BGP is disabled and no BGP instances exist.
4. Specify remote PEs as BGP peers.
5. Create the BGP EVPN address family and enter BGP EVPN address family view.
address-family l2vpn evpn
6. Enable BGP to exchange BGP EVPN routes with a peer or peer group.
By default, BGP does not exchange BGP EVPN routes with peers.
Perform this task on PEs for them to establish PWs.
2. Enter BGP instance view.
3. Enter BGP EVPN address family view.
4. Enable MPLS encapsulation for the BGP EVPN routes advertised to a peer or peer group.
peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
By default, BGP EVPN routes use VXLAN encapsulation.
4. Permit the local AS number to appear in routes from a peer or peer group and set the number of appearances.
By default, the local AS number is not allowed in routes from peers.
5. Enable route target filtering for BGP EVPN routes.
policy vpn-target
By default, route target filtering is enabled for BGP EVPN routes.
6. Set a high priority for BGP routes learned from a peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } high-priority
By default, BGP does not prefer routes learned from any peer or peer groups during optimal route selection.
7. Configure BGP route reflection settings:
a. Configure the device as an RR and specify a peer or peer group as its client.
By default, no RR or client is configured.
b. (Optional.) Enable BGP EVPN route reflection between clients.
reflect between-clients
By default, BGP EVPN route reflection between clients is enabled.
c. (Optional.) Configure the cluster ID of the RR.
By default, an RR uses its own router ID as the cluster ID.
d. (Optional.) Create a reflection policy for the RR to filter reflected BGP EVPN routes.
rr-filter { ext-comm-list-number | ext-comm-list-name }
By default, an RR does not filter reflected BGP EVPN routes.
e. (Optional.) Create a reflection policy for the RR to filter reflected BGP EVPN routes.
reflect change-path-attribute
8. Configure the device to not change the next hop of routes advertised to an EBGP peer or peer group.
By default, the device uses its address as the next hop of routes advertised to EBGP peers.
9. Apply a routing policy to routes received from or advertised to a peer or peer group.
By default, no routing policies are applied to routes received from or advertised to peers or peer groups.
10. Advertise the COMMUNITY attribute to a peer or peer group.
By default, the COMMUNITY attribute is not advertised to a peer or peer group.
11. Configure the BGP additional path feature.
¡ Configure the BGP additional path capabilities.
peer { group-name | ipv4-address [ mask-length ] } additional-paths { receive | send } *
By default, no BGP additional path capabilities are configured.
¡ Set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise additional-paths best number
By default, a maximum number of one Add-Path optimal route can be advertised to a peer or peer group.
¡ Set the maximum number of Add-Path optimal routes that can be advertised to all peers.
By default, a maximum number of one Add-Path optimal route can be advertised to all peers.
Perform the following tasks in user view:
· Reset BGP sessions of the BGP EVPN address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } l2vpn evpn
· Soft-reset BGP sessions of the BGP EVPN address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } l2vpn evpn
In a PW class, you can configure PW attributes such as the PW data encapsulation type, and whether to enable control word. To simplify PW attribute configuration for PWs, you can configure a PW class and apply the PW class to the PWs.
Make sure the same data encapsulation type is configured for the two PEs that are connected by the same PW.
For correct PW setup, make sure the status of the control word feature is the same on the two PEs that are connected by the same PW.
For more information about PW class commands, see MPLS L2VPN in MPLS Command Reference.
2. Create a PW class and enter PW class view.
pw-class class-name
3. Enable control word.
control-word enable
By default, control word is disabled.
4. Specify the PW data encapsulation type.
pw-type { ethernet | vlan }
By default, the PW data encapsulation type is VLAN.
Support for parameters in this command depends on device model.
In a multihomed site, AC configuration must be consistent on redundant PEs of the same ES.
You can assign an ESI to a main interface or a subinterface.
· For a subinterface, the ESI assigned to the subinterface takes precedence over that assigned to its main interface. If an ESI is assigned to a subinterface, the ES-related settings configured on the subinterface take effect, including the evpn df-election algorithm, evpn df-election preference, evpn df-election preference non-revertive, and evpn timer es-delay commands.
· If you assign an ESI only to a main interface, its subinterfaces inherit the ESI and ES settings of the main interface. The ES-related settings configured on the subinterface cannot take effect.
An ESI uniquely identifies an ES. The links on interfaces with the same ESI belong to the same ES. Traffic of the ES can be distributed among the links for load sharing.
¡ Enter Layer 3 Ethernet interface view.
¡ Enter Layer 3 aggregate interface view.
3. Assign an ESI to the interface.
esi esi-id
By default, no ESI is assigned to an interface.
At a multihomed EVPN network site, you can modify the DF election algorithm to control the DF election result.
You can configure the DF election algorithm in system view and in interface view. The global DF election algorithm takes effect on all ESs, and the interface-specific DF election algorithm takes effect only on the ESs on an interface. The interface-specific DF election algorithm takes precedence over the global DF election algorithm.
Configuring the DF election algorithm globally
2. Configure the DF election algorithm.
evpn df-election algorithm algorithm
By default, the VLAN tag-based algorithm is used for DF election.
Configuring the DF election algorithm on an interface
3. Configure the DF election algorithm.
By default, the DF election algorithm specified in system view takes effect.
Configuring parameters for preference-based DF election
3. Set the DF election preference.
evpn df-election preference preference
By default, the DF election preference is 32767.
The larger the value, the higher the preference.
4. (Optional.) Enable non-revertive mode for preference-based DF election.
By default, non-revertive mode is disabled for preference-based DF election.
The DF election can be triggered by site-facing interface status changes, redundant PE membership changes, and interface ESI changes. To prevent frequent DF elections from degrading network performance, set the DF election delay. The DF election delay defines the minimum interval allowed between two DF elections.
2. Set the DF election delay.
evpn multihoming timer df-delay delay-value
By default, the DF election delay is 3 seconds.
The advertisement delay timer for Ethernet auto-discovery routes helps reduce the traffic loss caused by a PE reboot at a multihomed EVPN VPLS network site.
At a multihomed EVPN VPLS network site, CE 1 is dualhomed to PE 1 and PE 2 through an aggregate link or smart trunk, and PE 3 is at a remote site. PE 1 forwards all traffic sent from CE 1 to the remote site, and PE 3 forwards the traffic that the remote site sends to CE 1 to both PE 1 and PE 2. When PE 1 reboots, it advertises Ethernet auto-discovery routes that carry next hop information to PE 3. If PE 3 has not received the MAC/IP advertisement routes advertised by PE 2 when receiving the Ethernet auto-discovery routes, it will forward traffic to both PE 1 and PE 2. In this situation, PE 1 does not have MAC address entries for CE 1 and drops the traffic.
To resolve this issue, set the advertisement delay timer for Ethernet auto-discovery routes on the CE-facing interface of PE 1. This timer allows PE 3 to receive the MAC/IP advertisement routes advertised by PE 2 before the Ethernet auto-discovery routes advertised by PE 1 and update its MAC address table timely.
2. Enable interface view.
3. Set the advertisement delay timer for Ethernet auto-discovery routes.
evpn timer ad-delay delay-time
By default, advertisement of Ethernet auto-discovery routes is not delayed.
Local fast reroute (FRR) enables two PEs at a multihomed EVPN VPLS network site to set up a PW between them. This feature helps reduce the traffic loss caused by AC failure.
On an EVPN instance, EVPN instance-specific local FRR configuration takes precedence over global local FRR configuration.
If you have executed the evpn frr local enable command on an EVPN instance, the undo evpn multihoming vpls-frr local command does not disable local FRR for the EVPN instance.
Perform this task on redundant PEs at a multihomed EVPN VPLS network site.
Enabling local FRR globally
2. Enable local FRR globally for EVPN VPLS.
By default, local FRR is disabled globally for EVPN VPLS.
Configuring local FRR on an EVPN instance created in VSI view
2. Enter VSI view.
vsi vsi-name
3. Enter VSI EVPN instance view.
4. Configure local FRR on the EVPN instance.
evpn frr local { disable | enable }
By default, an EVPN instance uses the global local FRR configuration of EVPN VPLS.
This task helps reduce the traffic loss caused by AC failure at a dualhomed EVPN VPLS network site.
At a multihomed EVPN VPLS network site, CE 1 is dualhomed to PE 1 and PE 2 through an aggregate link or smart trunk, and PE 3 is at a remote site. PE 1 forwards all traffic sent from CE 1 to the remote site, and PE 3 forwards the traffic that the remote site sends to CE 1 to both PE 1 and PE 2. When the AC on PE 1 fails, PE 1 withdraws the MAC/IP advertisement routes advertised to PE 2 and PE 3. In this situation, PE 3 does not have MAC address entries for CE 1 until PE 2 learns MAC address entries for CE 1 and advertises them to PE 3. As a result, traffic interruption occurs.
To resolve this issue, perform this task on PE 2. When receiving the MAC/IP advertisement routes advertised by PE 1, PE 2 generates MAC address entries for the routes and advertises the entries to PE 3. PE 3 can use those MAC address entries to forward traffic to CE 1 when the AC on PE 1 fails.
You must enable FRR for EVPN VPLS before you perform this task.
2. Enable the device to generate MAC address entries for received MAC/IP advertisement routes.
evpn multihoming re-originated mac
By default, the device does not generate MAC address entries for received MAC/IP advertisement routes.
This task helps reduce the traffic loss caused by AC failure at a multihomed EVPN VPLS network site that uses single-active redundancy mode.
At a multihomed EVPN VPLS network site that uses single-active redundancy mode, CE 1 is dualhomed to PE 1 and PE 2 through a smart trunk. PE 1 is the primary PE, and PE 2 is the secondary PE. When the AC on PE 1 fails, PE 1 and PE 2 act as follows:
· PE 1 withdraws advertised Ethernet auto-discovery routes.
· PE 2 brings up its AC and advertises Ethernet auto-discovery routes to remote PEs.
The remote PEs switch traffic to the paths to PE 2 only after receiving the Ethernet auto-discovery routes advertised by PE 2, and traffic loss occurs during path switchover. To resolve this issue, enable VSIs to ignore the state of ACs on PE 2. This feature allows PE 2 to advertise Ethernet auto-discovery routes to remote PEs regardless of the state of ACs and speeds up path switchover when the AC on PE 1 fails.
Restrictions and guidelines for AC state ignore configuration
On a VSI, VSI-specific AC state ignore configuration takes precedence over global AC state ignore configuration.
If you have executed the ignore-ac-state enable command on a VSI, the undo l2vpn ignore-ac-state command does not disable the VSI from ignoring the state of ACs.
Perform this task together with the feature of generating MAC address entries for received MAC/IP advertisement routes.
Enabling VSIs to ignore the state of ACs globally
2. Enable VSIs to ignore the state of ACs globally.
By default, VSIs does not ignore the state of ACs.
Configuring a VSI to ignore the state of ACs
2. Enter VSI view.
vsi vsi-name
3. Enable a VSI to ignore the state of ACs or disable a VSI from ignoring the state of ACs.
ignore-ac-state { enable | disable }
By default, a VSI uses the global AC state ignore configuration.
EVPN multihoming routes include Ethernet auto-discovery routes and Ethernet segment routes.
In a multihomed EVPN network, perform this task on a redundant PE before you reboot it. This operation allows other PEs to refresh their EVPN routing table to prevent traffic interruption caused by the reboot.
2. Disable advertisement of EVPN multihoming routes and withdraw the EVPN multihoming routes that have been advertised to remote sites.
evpn multihoming advertise disable
By default, the device advertises EVPN multihoming routes.
Perform this task on the redundant PEs at a dualhomed site.
This task enables the device to perform the following operations:
· Withdraw the Ethernet auto-discovery routes and MAC/IP advertisement routes that have been advertised.
· Set the Ethernet tag to 0 for the Ethernet auto-discovery routes and MAC/IP advertisement routes and re-advertise them.
After you configure ESIs for ACs on the redundant PEs at a dualhomed site, the PEs carry Ethernet tags in Ethernet auto-discovery and MAC/IP advertisement routes advertised to remote sites. If the remote peers are unable to identify Ethernet tags, you must perform this task on the redundant PEs to enable communication with the peers.
After you assign an ESI to a Layer 2 Ethernet or aggregate interface, you must map the Ethernet service instances created on the interface to different VSIs. If two interfaces use the same ESI, you must map the Ethernet service instances created on them to different VSIs.
After you assign an ESI to a Layer 3 main interface, its subinterfaces inherit the ESI if they do not have one. In addition, you must map two subinterfaces to different VSIs if the subinterfaces have the same ESI.
2. Enable the device to ignore the Ethernet tag when advertising Ethernet auto-discovery routes and MAC/IP advertisement routes.
evpn multihoming advertise ignore-ethernet-tag
By default, the device advertises Ethernet auto-discovery routes and MAC/IP advertisement routes that carry Ethernet tags.
Perform this task on the CE-facing interfaces of the edge devices multihomed to a site to prevent device reboots from causing inter-site forwarding failure.
This task excludes unavailable edge devices from DF election at a multihomed site. After an edge device recovers from failure and brings up its CE-facing interface, it starts the advertisement delay timer for Ethernet segment routes and checks the status of the BGP peer specified in the evpn track peer command. If the BGP peer comes up before the timer expires, the edge device advertises Ethernet segment routes to the peer. If the BGP peer is still down when the timer expires, the edge device does not advertise Ethernet segment routes to the peer. The edge devices then perform DF election based on the Ethernet segment routes they have received.
3. Enable the device to monitor the BGP peer status of another local edge device.
evpn track peer peer-address
By default, the device does not monitor the BGP peer status of the other edge devices at a multihomed site.
4. Set the advertisement delay timer for Ethernet segment routes.
evpn timer es-delay delay-time
By default, advertisement of Ethernet segment routes is not delayed.
The MAC information and ARP information advertised by the PE overlap. To avoid duplication, disable MAC address advertisement and withdraw the MAC addresses advertised to remote PEs.
2. Enter VSI view.
vsi vsi-name
4. Disable MAC address advertisement and withdraw advertised MAC addresses.
mac-advertising disable
By default, MAC address advertisement is enabled.
The MAC information and ARP information advertised by a remote PE overlap. To avoid duplication, disable the learning of MAC addresses from ARP information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
2. Enter VSI view.
vsi vsi-name
4. Disable the EVPN instance from learning MAC addresses from ARP information.
arp mac-learning disable
By default, an EVPN instance learns MAC addresses from ARP information.
In an EVPN VPLS network, you can disable ARP information advertisement for an EVPN instance to save resources if all user terminals in the EVPN instance are attached to one PE. The EVPN instance will stop advertising ARP information through MAC/IP advertisement routes and withdraw advertised ARP information.
2. Enter VSI view.
vsi vsi-name
4. Disable ARP information advertisement for the EVPN instance.
arp-advertising disable
By default, ARP information advertisement is enabled for an EVPN instance.
By default, the device issues a remote ARP entry to the hardware after the ARP information is advertised to the local site by BGP EVPN routes. This feature enables the device to issue a remote ARP entry to the hardware only when the entry is required for packet forwarding. This feature saves hardware resources on the device.
After you enable this feature, the device periodically examines whether the ARP entries are used for packet forwarding. An ARP entry is deleted if its aging timer expires.
When a large number of remote ARP entries exist, set an appropriate aging timer to avoid traffic interruption caused by the aging of ARP entries. As a best practice, set the aging timer value higher than or equal to the number of remote ARP entries divided by 200.
Use this feature only on an EVPN network.
2. Enable conversational learning for remote ARP entries.
arp forwarding-conversational-learning [ aging aging-time ]
By default, conversational learning is disabled for remote ARP entries.
Use EVPN E-tree to isolate traffic between ACs based on the AC roles. This feature can better control AC access and improve security.
Inter-site EVPN E-tree controls communication between local ACs and remote ACs. You do not need to enable this feature if you want to control communication between local ACs.
2. Enter VSI view.
vsi vsi-name
4. Enable inter-site EVPN E-tree.
e-tree enable
By default, inter-site EVPN E-tree is disabled.
5. Return to system view.
6. Execute the following commands to configure a Layer 3 interface as a leaf AC:
a. Enter Layer 3 interface view.
b. Configure the AC as a leaf AC.
xconnect vsi vsi-name leaf
If you do not specify the leaf keyword for an AC, the AC acts as a root AC.
7. Execute the following commands to configure an Ethernet service instance as a leaf AC:
a. Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
b. Enter Ethernet service instance view.
c. Configure the AC as a leaf AC.
Use this feature to ensure that a VPLS network and an EVPN VPLS network can communicate with each other.
As a best practice, set the same redundancy mode for the UPWs that use the same ESI at a multihomed site.
If the all-active redundancy mode is used at a multihomed site, you must enable the dual receive feature for PW redundancy on the multihomed PEs. To enable this feature, use the protection dual-receive command.
Complete the following tasks:
· In the VPLS network, complete VPLS settings on the PEs and set up LDP or static PWs.
· In the EVPN VPLS network, complete EVPN VPLS settings on the PEs and set up EVPN PWs.
The data encapsulation type of an LDP PW must be the same as the access mode of the ACs mapped to the same VSI as the LDP PW. If they are different, perform one of the following tasks:
· Use the pw-type command on the PW class to which the LDP PW belongs to change the PW data encapsulation type.
· Use the xconnect vsi command on the ACs and specify the access-mode parameter in the command to change the access mode of the ACs.
2. Enter VSI view.
vsi vsi-name
4. Return to VSI view.
5. Configure the VSI to use LDP to establish LDP PWs, and enter VSI LDP signaling view.
pwsignaling ldp
By default, no PW signaling protocol is specified for a VSI.
6. Configure a VSI LDP PW, disables split horizon forwarding for the PW, and enter VSI LDP PW view.
peer ip-address [ pw-id pw-id ] no-split-horizon [ hub | ignore-standby-state | pw-class class-name | tunnel-policy tunnel-policy-name ] *
The LDP PW configured by using this command is called an UPW, which acts as an AC for the EVPN VPLS network.
For more information about this command, see VPLS commands in MPLS Command Reference.
7. (Optional.) Assign an ESI to the UPW.
esi esi-id
By default, no ESI is assigned to an UPW.
At a multihomed site, use this command on the PEs in the VPLS and EVPN VPLS networks.
For more information about this command, see EVPN commands in EVPN Command Reference.
8. (Optional.) Set the redundancy mode of the UPW.
evpn redundancy-mode { all-active | single-active }
By default, the redundancy mode is all-active.
9. Configure a VSI LDP backup PW and enter its view.
backup-peer ip-address [ pw-id pw-id ] [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
At a multihomed site, use this command on the multihomed PEs.
2. Enter VSI view.
vsi vsi-name
5. Configure the VSI to establish static PWs and enter VSI static configuration view.
pwsignaling static
6. Configure a static PW, disable split horizon forwarding for the PW, and enter VSI static PW view.
peer ip-address [ pw-id pw-id ] in-label label-value out-label label-value no-split-horizon [ hub | pw-class class-name | tunnel-policy tunnel-policy-name ] *
The static PW configured by using this command is called an UPW, which acts as an AC for the EVPN VPLS network.
esi esi-id
9. Configure a VSI static backup PW and enter its view.
backup-peer ip-address [ pw-id pw-id ] in-label label-value out-label label-value [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
By default, the PE floods broadcast, unknown unicast, and unknown multicast frames received from the local site to the following interfaces in the frame's VSI:
· All site-facing interfaces except for the incoming interface.
· All PWs.
To confine a kind of flood traffic to the site-facing interfaces, disable flooding for that kind of flood traffic on the VSI. The VSI will not flood the corresponding frames to PWs.
To exclude a remote MAC address from the flood suppression done by using this feature, enable selective flood for the MAC address. The PE will flood the frames destined for the MAC address to remote sites.
2. Enter VSI view.
vsi vsi-name
3. Disable flooding for the VSI.
flooding disable
By default, flooding is enabled for a VSI.
4. (Optional.) Enable selective flood for a MAC address.
selective-flooding mac-address mac-address
Use ARP flood suppression to reduce ARP request broadcasts.
The aging timer is fixed at 25 minutes for ARP flood suppression entries. If the flooding disable command is configured, set the MAC aging timer to a higher value than the aging timer for ARP flood suppression entries on all PEs. This setting prevents the traffic blackhole that occurs when a MAC address entry ages out before its ARP flood suppression entry ages out. To set the MAC aging timer, use the mac-address timer command.
2. Enter VSI view.
vsi vsi-name
3. Enable ARP flood suppression.
arp suppression enable
By default, ARP flood suppression is disabled.
For the ac statistics enable command to take effect on a Layer 3 interface, you must map the Layer 3 interface to a VSI. When you modify the VSI mapping, the packet statistics of the interface are cleared. To display the statistics, use the display l2vpn interface verbose command.
For the statistics enable command to take effect on an Ethernet service instance, you must configure a frame match criterion for the Ethernet service instance and map it to a VSI. When you modify the frame match criterion or VSI mapping, the packet statistics of the instance are cleared. To display the statistics, use the display l2vpn service-instance verbose command.
To clear packet statistics for ACs, use the reset l2vpn statistics ac command.
3. Enable packet statistics for the Layer 3 interface.
By default, the packet statistics feature is disabled for Layer 3 interfaces that act as ACs.
3. Enter Ethernet service instance view.
4. Enable packet statistics for the Ethernet service instance.
statistics enable
By default, the packet statistics feature is disabled for all Ethernet service instances.
This feature enables L2VPN to generate SNMP notifications when PW deletions, PW switchovers, or PW status changes occur. For L2VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
2. Enable SNMP notifications for L2VPN PWs.
snmp-agent trap enable l2vpn [ pw-delete | pw-switch | pw-up-down ] *
By default, SNMP notifications for L2VPN PWs are disabled.
For more information about the following BGP commands, see Layer 3—IP Routing Command Reference:
· display bgp group.
· display bgp peer.
· display bgp update-group.
Task |
Command |
Display BGP peer group information. |
display bgp [ instance instance-name ] group l2vpn evpn [ group-name group-name ] |
Display BGP EVPN routes. |
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ statistics ] | [ route-distinguisher route-distinguisher | route-type { auto-discovery | es | imet | mac-ip } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info ] | ipv4-address | ipv6-address | mac-address ] | statistics ] |
Display BGP peer or peer group information. |
display bgp [ instance instance-name ] peer l2vpn evpn [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] |
Display information about BGP update groups. |
display bgp [ instance instance-name ] update-group l2vpn evpn [ ipv4-address ] |
Display information about peers that are automatically discovered through BGP. |
display evpn auto-discovery { { imet | mac-ip } [ mpls ] [ peer ip-address] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] } |
Display EVPN ES information. |
display evpn es { local [ count | [ vsi vsi-name ] [ esi esi-id ] [ verbose ] ] | remote [ vsi vsi-name ] [ esi esi-id ] [ nexthop next-hop ] [ verbose ] } |
Display EVPN ARP entries. |
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ count ] |
Display ARP flood suppression entries. |
display evpn route arp suppression [ mpls | vxlan ] [ local | remote ] [ vsi vsi-name ] [ count ] |
Display EVPN MAC address entries. |
display evpn route mac [ mpls | vxlan ] [ local | remote ] [ vsi vsi-name ] [ count ] |
Display the routing table for a VPN instance. |
display evpn routing-table { public-instance | vpn-instance vpn-instance-name } [ count ] |
Display EVPN instance information. |
display evpn instance [ vsi vsi-name ] [ verbose ] |
Display site-facing interfaces excluded from traffic forwarding by split horizon. |
Centralized devices: display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | ac interface interface-type interface-number service-instance instance-id | tunnel tunnel-number } Distributed devices in standalone mode:Centralized IRF devices: display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | ac interface interface-type interface-number service-instance instance-id | tunnel tunnel-number } [ slot slot-number [ cpu cpu-number ] ] Distributed devices in IRF mode: display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | ac interface interface-type interface-number service-instance instance-id | tunnel tunnel-number } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display information about EVPN VPLS forwarding. |
Centralized devices: display l2vpn forwarding evpn vsi [ name vsi-name ] [ verbose ] Distributed devices in standalone mode:Centralized IRF devices: display l2vpn forwarding evpn vsi [ name vsi-name ] [ slot slot-number [ cpu cpu-number ] ] [ verbose ] Distributed devices in IRF mode: display l2vpn forwarding evpn vsi [ name vsi-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ verbose ] |
As shown in Figure 10, set up a path between PE 1 and PE 2 for the CEs in site 1 and site 2 to communicate through EVPN VPLS over the MPLS or IP backbone network.
Device |
IP address |
Device |
IP address |
CE 1 |
GE1/0/1 |
10.1.1.10/24 |
P |
Loop0 |
3.3.3.3/32 |
PE 1 |
Loop0 |
1.1.1.1/32 |
GE1/0/1 |
11.1.1.2/24 |
GE1/0/1 |
N/A |
GE1/0/2 |
11.1.2.2/24 |
GE1/0/2 |
11.1.1.1/24 |
PE 2 |
Loop0 |
2.2.2.2/32 |
CE 2 |
GE1/0/1 |
10.1.1.20/24 |
GE1/0/1 |
N/A |
GE1/0/2 |
11.1.2.1/24 |
1. Configure CE 1.
<CE1> system-view
[CE1] interface gigabitethernet 1/0/1
[CE1-GigabitEthernet1/0/1] ip address 10.1.1.10 24
[CE1-GigabitEthernet1/0/1] quit
2. Configure PE 1:
# Configure the LSR ID.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 1.1.1.1
# Enable L2VPN.
[PE1] l2vpn enable
# Enable global LDP.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure GigabitEthernet 1/0/2 (the interface connected to the P device), and enable LDP on the interface.
[PE1] interface gigabitethernet 1/0/2
[PE1-GigabitEthernet1/0/2] ip address 11.1.1.1 24
[PE1-GigabitEthernet1/0/2] mpls enable
[PE1-GigabitEthernet1/0/2] mpls ldp enable
[PE1-GigabitEthernet1/0/2] quit
# Configure OSPF for LDP to create LSPs.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Create an IBGP connection to PE 2, and enable BGP to advertise L2VPN information to PE 2.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.2 as-number 100
[PE1-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[PE1-bgp-default] address-family l2vpn evpn
[PE1-bgp-default-evpn] peer 2.2.2.2 enable
[PE1-bgp-default-evpn] peer 2.2.2.2 advertise encap-type mpls
[PE1-bgp-default-evpn] quit
[PE1-bgp-default] quit
# Create VSI vpna, create an EVPN instance on the VSI, enable MPLS encapsulation, and configure an RD and route targets for the EVPN instance.
[PE1] vsi vpna
[PE1-vsi-vpna] evpn encapsulation mpls
[PE1-vsi-vpna-evpn-mpls] route-distinguisher 1:1
[PE1-vsi-vpna-evpn-mpls] vpn-target 1:1 export-extcommunity
[PE1-vsi-vpna-evpn-mpls] vpn-target 1:1 import-extcommunity
[PE1-vsi-vpna-evpn-mpls] quit
[PE1-vsi-vpna] quit
# Map GigabitEthernet 1/0/1 (the interface connected to CE 1) to VSI vpna.
[PE1-GigabitEthernet1/0/1] xconnect vsi vpna
3. Configure the P device:
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 3.3.3.3 32
[P-LoopBack0] quit
[P] mpls lsr-id 3.3.3.3
[P] mpls ldp
[P-ldp] quit
# Configure GigabitEthernet 1/0/1 (the interface connected to PE 1), and enable LDP on the interface.
[P] interface gigabitethernet 1/0/1
[P-GigabitEthernet1/0/1] ip address 11.1.1.2 24
[P-GigabitEthernet1/0/1] mpls enable
[P-GigabitEthernet1/0/1] mpls ldp enable
[P-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet 1/0/2 (the interface connected to PE 2), and enable LDP on the interface.
[P] interface gigabitethernet 1/0/2
[P-GigabitEthernet1/0/2] ip address 11.1.2.2 24
[P-GigabitEthernet1/0/2] mpls enable
[P-GigabitEthernet1/0/2] mpls ldp enable
[P-GigabitEthernet1/0/2] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 11.1.2.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
4. Configure PE 2:
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.2 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 2.2.2.2
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface gigabitethernet 1/0/2
[PE2-GigabitEthernet1/0/2] ip address 11.1.2.1 24
[PE2-GigabitEthernet1/0/2] mpls enable
[PE2-GigabitEthernet1/0/2] mpls ldp enable
[PE2-GigabitEthernet1/0/2] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 11.1.2.0 0.0.0.255
[PE2-ospf-1] quit
# Create an IBGP connection to PE 1, and enable BGP to advertise L2VPN information to PE 1.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.1 as-number 100
[PE2-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[PE2-bgp-default] address-family l2vpn evpn
[PE2-bgp-default-evpn] peer 1.1.1.1 enable
[PE2-bgp-default-evpn] peer 1.1.1.1 advertise encap-type mpls
[PE2-bgp-default-evpn] quit
[PE2-bgp-default] quit
[PE2] vsi vpna
[PE2-vsi-vpna] evpn encapsulation mpls
[PE2-vsi-vpna-evpn-mpls] route-distinguisher 1:1
[PE2-vsi-vpna-evpn-mpls] vpn-target 1:1 export-extcommunity
[PE2-vsi-vpna-evpn-mpls] vpn-target 1:1 import-extcommunity
[PE2-vsi-vpna-evpn-mpls] quit
[PE2-vsi-vpna] quit
# Map GigabitEthernet 1/0/1 (the interface connected to CE 2) to VSI vpna.
[PE2] interface gigabitethernet 1/0/1
[PE2-GigabitEthernet1/0/1] xconnect vsi vpna
[PE2-GigabitEthernet1/0/1] quit
5. Configure CE 2.
<CE2> system-view
[CE2] interface gigabitethernet 1/0/1
[CE2-GigabitEthernet1/0/1] ip address 10.1.1.20 24
[CE2-GigabitEthernet1/0/1] quit
# Verify that an EVPN PW has been established between PE 1 and PE 2.
[PE1] display l2vpn pw
N - no split horizon, A - administration, ABY - ac-bypass
PBY - pw-bypass
Total number of PWs: 1
1 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
VSI Name: vpna
Peer PWID/RmtSite/SrvID In/Out Label Proto Flag Link ID State
2.2.2.2 - 775127/775127 EVPN M 8 Up
# Display PW information on PE 2.
[PE2] display l2vpn pw
PBY - pw-bypass
VSI Name: vpna
1.1.1.1 - 775127/775127 EVPN M 8 Up
# Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Example: Configuring EVPN VPLS multihoming (access through aggregate links)
As shown in Figure 11, configure EVPN VPLS for dualhomed site 1 and singlehomed site 2 to communicate over the MPLS or IP backbone network.
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
192.1.1.1/32 |
CE 1 |
RAGG1 |
100.1.1.1/24 |
GE1/0/1 |
N/A |
CE 2 |
GE1/0/1 |
100.1.1.2/24 |
GE1/0/2 |
10.1.1.1/24 |
PE 3 |
Loop0 |
192.3.3.3/32 |
GE1/0/3 |
10.1.3.1/24 |
GE1/0/1 |
N/A |
PE 2 |
Loop0 |
192.2.2.2/32 |
GE1/0/2 |
10.1.1.2/24 |
GE1/0/1 |
N/A |
GE1/0/3 |
10.1.2.2/24 |
GE1/0/2 |
10.1.2.1/24 |
GE1/0/3 |
10.1.3.2/24 |
1. Configure CE 1:
# Create static Layer 3 aggregate interface 1 and assign it an IP address.
<CE1> system-view
[CE1] interface route-aggregation 1
[CE1-Route-Aggregation1] ip address 100.1.1.1 24
[CE1-Route-Aggregation1] quit
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to aggregation group 1.
[CE1-GigabitEthernet1/0/1] port link-aggregation group 1
[CE1] interface gigabitethernet 1/0/2
[CE1-GigabitEthernet1/0/2] port link-aggregation group 1
[CE1-GigabitEthernet1/0/2] quit
2. Configure PE 1:
<PE1> system-view
[PE1-LoopBack0] ip address 192.1.1.1 32
[PE1] mpls lsr-id 192.1.1.1
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
# Configure GigabitEthernet 1/0/2 (the interface connected to PE 3), and enable LDP on the interface.
[PE1-GigabitEthernet1/0/2] ip address 10.1.1.1 24
# Configure GigabitEthernet 1/0/3 (the interface connected to PE 2), and enable LDP on the interface.
[PE1] interface gigabitethernet 1/0/3
[PE1-GigabitEthernet1/0/3] ip address 10.1.3.1 24
[PE1-GigabitEthernet1/0/3] mpls enable
[PE1-GigabitEthernet1/0/3] mpls ldp enable
[PE1-GigabitEthernet1/0/3] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 10.1.3.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 192.1.1.1 0.0.0.0
[PE1-ospf-1] quit
# Create IBGP connections to PE 2 and PE 3, and enable BGP to advertise routes to PE 2 and PE 3.
[PE1] bgp 100
[PE1-bgp-default] peer 192.2.2.2 as-number 100
[PE1-bgp-default] peer 192.2.2.2 connect-interface loopback 0
[PE1-bgp-default] peer 192.3.3.3 as-number 100
[PE1-bgp-default] peer 192.3.3.3 connect-interface loopback 0
[PE1-bgp-default-evpn] peer 192.2.2.2 enable
[PE1-bgp-default-evpn] peer 192.3.3.3 enable
[PE1-bgp-default-evpn] peer 192.2.2.2 advertise encap-type mpls
[PE1-bgp-default-evpn] peer 192.3.3.3 advertise encap-type mpls
# Assign an ESI to GigabitEthernet 1/0/1.
[PE1-GigabitEthernet1/0/1] esi 1.1.1.1.1
[PE1] vsi vpna
[PE1-vsi-vpna] quit
3. Configure PE 2:
<PE2> system-view
[PE2-LoopBack0] ip address 192.2.2.2 32
[PE2] mpls lsr-id 192.2.2.2
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-GigabitEthernet1/0/2] ip address 10.1.2.1 24
# Configure GigabitEthernet 1/0/3 (the interface connected to PE 1), and enable LDP on the interface.
[PE2] interface gigabitethernet 1/0/3
[PE2-GigabitEthernet1/0/3] ip address 10.1.3.2 24
[PE2-GigabitEthernet1/0/3] mpls enable
[PE2-GigabitEthernet1/0/3] mpls ldp enable
[PE2-GigabitEthernet1/0/3] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 10.1.3.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 192.2.2.2 0.0.0.0
[PE2-ospf-1] quit
# Create IBGP connections to PE 1 and PE 3, and enable BGP to advertise routes to PE 1 and PE 3.
[PE2] bgp 100
[PE2-bgp-default] peer 192.1.1.1 as-number 100
[PE2-bgp-default] peer 192.1.1.1 connect-interface loopback 0
[PE2-bgp-default] peer 192.3.3.3 as-number 100
[PE2-bgp-default] peer 192.3.3.3 connect-interface loopback 0
[PE2-bgp-default-evpn] peer 192.1.1.1 enable
[PE2-bgp-default-evpn] peer 192.3.3.3 enable
[PE2-bgp-default-evpn] peer 192.1.1.1 advertise encap-type mpls
[PE2-bgp-default-evpn] peer 192.3.3.3 advertise encap-type mpls
[PE2-GigabitEthernet1/0/1] esi 1.1.1.1.1
[PE2] vsi vpna
[PE2-vsi-vpna] quit
4. Configure PE 3:
<PE3> system-view
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 192.3.3.3 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 192.3.3.3
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] mpls ldp
[PE3-ldp] quit
# Configure GigabitEthernet 1/0/2 (the interface connected to PE 1) and GigabitEthernet 1/0/3 (the interface connected to PE 2), and enable LDP on the interfaces.
[PE3] interface gigabitethernet 1/0/2
[PE3-GigabitEthernet1/0/2] ip address 10.1.1.2 24
[PE3-GigabitEthernet1/0/2] mpls enable
[PE3-GigabitEthernet1/0/2] mpls ldp enable
[PE3-GigabitEthernet1/0/2] quit
[PE3] interface gigabitethernet 1/0/3
[PE3-GigabitEthernet1/0/3] ip address 10.1.2.2 24
[PE3-GigabitEthernet1/0/3] mpls enable
[PE3-GigabitEthernet1/0/3] mpls ldp enable
[PE3-GigabitEthernet1/0/3] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 192.3.3.3 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[PE3-ospf-1] quit
# Create IBGP connections to PE 1 and PE 2, and enable BGP to advertise routes to PE 1 and PE 2.
[PE3] bgp 100
[PE3-bgp-default] peer 192.1.1.1 as-number 100
[PE3-bgp-default] peer 192.1.1.1 connect-interface loopback 0
[PE3-bgp-default] peer 192.2.2.2 as-number 100
[PE3-bgp-default] peer 192.2.2.2 connect-interface loopback 0
[PE3-bgp-default] address-family l2vpn evpn
[PE3-bgp-default-evpn] peer 192.1.1.1 enable
[PE3-bgp-default-evpn] peer 192.2.2.2 enable
[PE3-bgp-default-evpn] peer 192.1.1.1 advertise encap-type mpls
[PE3-bgp-default-evpn] peer 192.2.2.2 advertise encap-type mpls
[PE3-bgp-default-evpn] quit
[PE3-bgp-default] quit
[PE3] vsi vpna
[PE3-vsi-vpna] evpn encapsulation mpls
[PE3-vsi-vpna-evpn-mpls] route-distinguisher 1:1
[PE3-vsi-vpna-evpn-mpls] vpn-target 1:1 export-extcommunity
[PE3-vsi-vpna-evpn-mpls] vpn-target 1:1 import-extcommunity
[PE3-vsi-vpna-evpn-mpls] quit
[PE3-vsi-vpna] quit
[PE3] interface gigabitethernet 1/0/1
[PE3-GigabitEthernet1/0/1] xconnect vsi vpna
[PE3-GigabitEthernet1/0/1] quit
5. Configure CE 2.
<CE2> system-view
[CE2-GigabitEthernet1/0/1] ip address 100.1.1.2 24
# Verify that PE 1 has established EVPN PWs to PE 2 and PE 3.
<PE1> display l2vpn pw
PBY - pw-bypass
Total number of PWs: 2
2 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
VSI name: vpna
192.3.3.3 - 710263/710265 EVPN M 8 Up
192.2.2.2 - 710263/710124 EVPN M 9 Up
# Verify that PE 1 has local ES information.
<PE1> display evpn es local
Redundancy mode: A - All-active, S - Single-active
VSI name : vpna
ESI Tag ID DF address Mode State ESI label
0001.0001.0001.0001.0001 - 192.1.1.1 A Up 775128
# Verify that PE 1 has remote ES information.
<Sysname> display evpn es remote
Control Flags: P - Primary, B - Backup, C - Control word
VSI name : vpna
ESI : 0001.0001.0001.0001.0001
Ethernet segment routes :
192.2.2.2
A-D per ES routes :
Peer IP Remote Redundancy mode
192.2.2.2 All-active
A-D per EVI routes :
Tag ID Peer IP Control Flags
- 192.2.2.2 B
# Verify that PE 2 has established EVPN PWs to PE 1 and PE 3.
<PE2> display l2vpn pw
PBY - pw-bypass
VSI name: vpna
192.1.1.1 - 710124/710263 EVPN M 8 Up
192.3.3.3 - 710124/710265 EVPN M 9 Up
# Verify that PE 3 has established EVPN PWs to PE 1 and PE 2.
<PE3> display l2vpn pw
PBY - pw-bypass
VSI name: vpna
192.1.1.1 - 710265/710263 EVPN M 8 Up
192.2.2.2 - 710265/710124 EVPN M 9 Up
# Verify that CE 1 and CE 2 can ping each other when the PW on PE 1 or PE 2 fails. (Details not shown.)
Example: Configuring EVPN VPLS multihoming (access through an S-Trunk system)
As shown in Figure 12, configure EVPN VPLS for dualhomed site 1 and singlehomed site 2 to communicate over the MPLS or IP backbone network. Configure PE 1 and PE 2 to form an S-Trunk system.
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
192.1.1.1/32 |
CE 1 |
RAGG1 |
100.1.1.1/24 |
GE1/0/1 |
CE 2 |
GE1/0/1 |
100.1.1.2/24 |
GE1/0/2 |
10.1.1.1/24 |
PE 3 |
Loop0 |
192.3.3.3/32 |
GE1/0/3 |
10.1.3.1/24 |
GE1/0/1 |
PE 2 |
Loop0 |
192.2.2.2/32 |
GE1/0/2 |
10.1.1.2/24 |
GE1/0/1 |
GE1/0/3 |
10.1.2.2/24 |
GE1/0/2 |
10.1.2.1/24 |
GE1/0/3 |
10.1.3.2/24 |
1. Configure CE 1:
# Create dynamic Layer 3 aggregate interface 1 and assign it an IP address.
<CE1> system-view
[CE1-Route-Aggregation1] link-aggregation mode dynamic
2. Configure PE 1:
<PE1> system-view
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
[PE1] bgp 100
# Configure S-Trunk to set up a multichassis aggregate link to CE 1.
[PE1] lacp system-priority 10
[PE1] lacp system-mac 1-1-1
[PE1] lacp system-number 1
[PE1] s-trunk id 1
[PE1-s-trunk1] s-trunk ip destination 10.1.3.2 source 10.1.3.1
[PE1-s-trunk1] quit
[PE1] interface route-aggregation 1
[PE1-Route-Aggregation1] link-aggregation mode dynamic
[PE1-Route-Aggregation1] s-trunk 1
[PE1-Route-Aggregation1] s-trunk port-role primary
[PE1-Route-Aggregation1] quit
[PE1-GigabitEthernet1/0/1] port link-aggregation group 1
# On Route-Aggregation 1, configure an ESI and enable all-active redundancy mode.
[PE1-Route-Aggregation1] esi 1.1.1.1.1
[PE1-Route-Aggregation1] evpn redundancy-mode all-active
[PE1] vsi vpna
[PE1-vsi-vpna] quit
# Map Route-Aggregation 1 (the interface connected to CE 1) to VSI vpna.
[PE1-Route-Aggregation1] xconnect vsi vpna
3. Configure PE 2:
<PE2> system-view
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
[PE2] bgp 100
[PE2] lacp system-priority 10
[PE2] lacp system-mac 1-1-1
[PE2] lacp system-number 2
[PE2] s-trunk id 1
[PE2-s-trunk1] s-trunk ip destination 10.1.3.1 source 10.1.3.2
[PE2-s-trunk1] quit
[PE2] interface route-aggregation 1
[PE2-Route-Aggregation1] link-aggregation mode dynamic
[PE2-Route-Aggregation1] s-trunk 1
[PE2-Route-Aggregation1] s-trunk port-role primary
[PE2-Route-Aggregation1] quit
[PE2-GigabitEthernet1/0/1] port link-aggregation group 1
[PE2-Route-Aggregation1] esi 1.1.1.1.1
[PE2-Route-Aggregation1] evpn redundancy-mode all-active
[PE2] vsi vpna
[PE2-vsi-vpna] quit
[PE2-Route-Aggregation1] xconnect vsi vpna
4. Configure PE 3:
<PE3> system-view
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
[PE3] bgp 100
[PE3] vsi vpna
[PE3-vsi-vpna] quit
5. Configure CE 2.
<CE2> system-view
PBY - pw-bypass
VSI name: vpna
VSI name : vpna
VSI name : vpna
192.2.2.2
A-D per ES routes :
- 192.2.2.2 B
PBY - pw-bypass
VSI name: vpna
PBY - pw-bypass
VSI name: vpna
Example: Configuring local FRR for EVPN VPLS
As shown in Figure 13:
· CE 1 is dualhomed to PE 1 and PE 2 through an aggregate link.
· Configure EVPN VPLS on PE 1, PE 2, and PE 3 for CE 1 and CE 2 to communicate at Layer 2 over the backbone network.
· Enable local FRR on PE 1 and PE 2 to prevent traffic loss caused by AC failure.
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
192.1.1.1/32 |
CE 1 |
GE1/0/1 |
100.1.1.1/24 |
GE1/0/1 |
CE 2 |
GE1/0/1 |
100.1.1.2/24 |
GE1/0/2 |
10.1.1.1/24 |
PE 3 |
Loop0 |
192.3.3.3/32 |
GE1/0/3 |
10.1.3.1/24 |
GE1/0/1 |
PE 2 |
Loop0 |
192.2.2.2/32 |
GE1/0/2 |
10.1.1.2/24 |
GE1/0/1 |
GE1/0/3 |
10.1.2.2/24 |
GE1/0/2 |
10.1.2.1/24 |
GE1/0/3 |
10.1.3.2/24 |
1. Configure CE 1:
# Create dynamic Layer 3 aggregate interface Route-Aggregation 1 and assign it an IP address.
<CE1> system-view
2. Configure PE 1:
# Configure an LSR ID.
<PE1> system-view
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
# Configure GigabitEthernet 1/0/2 (the interface connected to PE3), and enable MPLS and LDP on the interface.
# Configure GigabitEthernet 1/0/3 (the interface connected to PE 2), and enable MPLS and LDP on the interface.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure PE 1 to establish IBGP peer relationships with PE 2 and PE 3, and configure BGP to advertise BGP EVPN routes.
[PE1] bgp 100
# Configure a smart trunk to establish an aggregate link across PE 1 and PE 2.
[PE1] s-trunk id 1
[PE1-s-trunk1] quit
# Create VSI vpna, create an EVPN instance on it, and enable MPLS encapsulation. Configure an RD and route targets for the EVPN instance.
[PE1] vsi vpna
[PE1-vsi-vpna] quit
# Assign an ESI to Route-Aggregation 1.
# Map Route-Aggregation 1 to VSI vpna.
# Enable local FRR for EVPN VPLS globally.
[PE1] evpn multihoming vpls-frr local
3. Configure PE 2:
<PE2> system-view
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
# Configure GigabitEthernet 1/0/2 (the interface connected to PE 3), and enable MPLS and LDP on the interface.
# Configure GigabitEthernet 1/0/3 (the interface connected to PE 1), and enable MPLS and LDP on the interface.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# Configure PE 2 to establish IBGP peer relationships with PE 1 and PE 3, and configure BGP to advertise BGP EVPN routes.
[PE2] bgp 100
[PE2] s-trunk id 1
[PE2-s-trunk1] quit
[PE2] vsi vpna
[PE2-vsi-vpna] quit
[PE2] evpn multihoming vpls-frr local
4. Configure PE 3:
<PE3> system-view
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] mpls ldp
[PE3-ldp] quit
# Configure GigabitEthernet 1/0/2 (the interface connected to PE 1), and enable MPLS and LDP on the interface.
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
# Configure PE 3 to establish IBGP peer relationships with PE 1 and PE 2, and configure BGP to advertise EVPN routes.
[PE3] bgp 100
[PE3] vsi vpna
[PE3-vsi-vpna] quit
# Map GigabitEthernet 1/0/1 to VSI vpna.
5. Configure CE 2.
<CE2> system-view
1. Verify PW information:
# Verify that PE 1 has established PWs with PE 3 and PE 2.
PBY - pw-bypass
VSI name: vpna
# Verify that PE 2 has established PWs with PE 1 and PE 3.
PBY - pw-bypass
VSI name: vpna
# Verify that PE 3 has established PWs with PE 1 and PE 2.
PBY - pw-bypass
VSI name: vpna
2. Verify ES information:
# Display local ES information on PE 1.
VSI name : vpna
# Display remote ES information on PE 1.
VSI name : vpna
192.2.2.2
A-D per ES routes :
- 192.2.2.2 B
3. Verify that CE 1 and CE 2 can ping each other when all PWs are up and when a PW is down. (Details not shown.)
Example: Configuring LDP PWs as ACs for EVPN PWs
As shown in Figure 14:
· PE 1 and PE 2 are edge devices on both the VPLS network and EVPN VPLS network.
· PE 1, PE 2, and PE 4 use LDP to establish LDP PWs.
· On PE 1 and PE 2, configure LDP PWs as UPWs (ACs) for EVPN PWs to ensure that the VPLS and EVPN VPLS networks can communicate with each other.
· PE 4 is dual-homed to PE 1 and PE 2 through two LDP PWs (UPWs).
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
1.1.1.9/32 |
PE 3 |
Loop0 |
3.3.3.9/32 |
GE1/0/1 |
10.1.1.1/24 |
GE1/0/1 |
GE1/0/2 |
30.1.1.1/24 |
GE1/0/2 |
30.1.1.3/24 |
GE1/0/3 |
10.1.3.1/24 |
GE1/0/3 |
10.1.2.3/24 |
PE 2 |
Loop0 |
2.2.2.9/32 |
PE 4 |
Loop0 |
4.4.4.9/32 |
GE1/0/1 |
20.1.1.2/24 |
GE1/0/3 |
GE1/0/2 |
10.1.2.2/24 |
GE1/0/1 |
10.1.1.4/24 |
GE1/0/3 |
10.1.3.2/24 |
GE1/0/2 |
20.1.1.4/24 |
CE 1 |
GE1/0/1 |
100.1.1.1/32 |
CE 2 |
GE1/0/1 |
100.1.1.2/32 |
1. Configure CE 1:
# Configure an IP address and mask for GigabitEthernet 1/0/1.
<CE1> system-view
[CE1-GigabitEthernet1/0/1] ip address 100.1.1.1 24
2. Configure PE 4:
# Configure MPLS basic capabilities.
<PE4> system-view
[PE4] interface loopback 0
[PE4-LoopBack0] ip address 1.1.1.9 32
[PE4-LoopBack0] quit
[PE4] mpls lsr-id 1.1.1.9
# Enable LDP globally.
[PE4] mpls ldp
[PE4-ldp] quit
# Enable L2VPN.
[PE4] l2vpn enable
# Configure GigabitEthernet 1/0/1, the interface connected to PE 1.
[PE4] interface gigabitethernet 1/0/1
[PE4-GigabitEthernet1/0/1] ip address 10.1.1.4 24
[PE4-GigabitEthernet1/0/1] ospf 1 area 0
[PE4-GigabitEthernet1/0/1] mpls enable
[PE4-GigabitEthernet1/0/1] mpls ldp enable
[PE4-GigabitEthernet1/0/1] undo shutdown
[PE4-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet 1/0/2, the interface connected to PE 2.
[PE4] interface gigabitethernet 1/0/2
[PE4-GigabitEthernet1/0/2] ip address 20.1.1.4 24
[PE4-GigabitEthernet1/0/2] ospf 1 area 0
[PE4-GigabitEthernet1/0/2] mpls enable
[PE4-GigabitEthernet1/0/2] mpls ldp enable
[PE4-GigabitEthernet1/0/2] undo shutdown
[PE4-GigabitEthernet1/0/2] quit
# Configure VSI vpna to use LDP to establish LDP PWs. The LDP PW between PE 1 and PE 4 is the primary PW and the LDP PW between PE 2 and PE 4 is the backup PW. Enable the dual receive feature for PW redundancy.
[PE4] vsi vpna
[PE4-vsi-vpna] protection dual-receive
[PE4-vsi-vpna] pwsignaling ldp
[PE4-vsi-vpna-ldp] peer 1.1.1.9 pw-id 500
[PE4-vsi-vpna-ldp-1.1.1.9-500] backup-peer 2.2.2.9 pw-id 500
[PE4-vsi-vpna-ldp-1.1.1.9-500-backup] quit
[PE4-vsi-vpna-ldp-1.1.1.9-500] quit
[PE4-vsi-vpna-ldp] quit
[PE4-vsi-vpna] quit
# Map GigabitEthernet 1/0/3 to VSI vpna.
[PE4] interface gigabitethernet 1/0/3
[PE4-GigabitEthernet1/0/3] xconnect vsi vpna
[PE4-GigabitEthernet1/0/3] quit
3. Configure PE 1:
# Configure interface Loopback 0.
<PE1> system-view
[PE1-LoopBack1] ip address 1.1.1.9 32
[PE1-LoopBack1] quit
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
# Enable L2VPN.
[PE1] l2vpn enable
# Run OSPF on PE 1 to set up LSPs.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Configure GigabitEthernet 1/0/1, the interface connected to PE 4.
[PE1-GigabitEthernet1/0/1] ip address 10.1.1.1 24
[PE1-GigabitEthernet1/0/1] mpls enable
[PE1-GigabitEthernet1/0/1] mpls ldp enable
[PE1-GigabitEthernet1/0/1] undo shutdown
# Configure GigabitEthernet 1/0/2, the interface connected to PE 3.
[PE1-GigabitEthernet1/0/2] ip address 30.1.1.1 24
[PE1-GigabitEthernet1/0/2] undo shutdown
# ConfigureGigabitEthernet 1/0/3, the interface connected to PE 2.
[PE1-GigabitEthernet1/0/3] undo shutdown
# Establish IBGP connections to PE 2 and PE 3, and enable BGP EVPN to advertise route information to PE 2 and PE 3.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default-evpn] peer 2.2.2.9 enable
[PE1-bgp-default-evpn] peer 3.3.3.9 enable
[PE1-bgp-default-evpn] peer 2.2.2.9 advertise encap-type mpls
[PE1-bgp-default-evpn] peer 3.3.3.9 advertise encap-type mpls
# Create a PW class and set the PW data encapsulation type to Ethernet for the PW class.
[PE1] pw-class aaa
[PE1-pw-aaa] pw-type ethernet
[PE1-pw-aaa] quit
# Create VSI vpna, create an EVPN instance for it, enable MPLS encapsulation, and configure an RD and route targets for the EVPN instance.
[PE1] vsi vpna
[PE1-vsi-vpna-evpn-srv6] route-distinguisher 1:1
[PE1-vsi-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE1-vsi-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE1-vsi-vpna-evpn-srv6] quit
# Configure VSI vpna to use LDP to establish LDP PWs. Configure PE 1 to establish an UPW with PE 4, assign an ESI to the UPW, and set the redundancy mode of the UPW to all-active.
[PE1-vsi-vpna] pwsignaling ldp
[PE1-vsi-vpna-ldp] peer 4.4.4.9 pw-id 500 no-split-horizon pw-class aaa
[PE1-vsi-vpna-ldp-4.4.4.9-500] esi 1.1.1.1.1
[PE1-vsi-vpna-ldp-4.4.4.9-500] evpn redundancy-mode all-active
[PE1-vsi-vpna-ldp-4.4.4.9-500] quit
[PE1-vsi-vpna-ldp] quit
[PE1-vsi-vpna] quit
4. Configure PE 2:
<PE2> system-view
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2] mpls lsr-id 2.2.2.9
[PE2] mpls ldp
[PE2-ldp] quit
# Enable L2VPN.
[PE2] l2vpn enable
# Run OSPF on PE 2 to set up LSPs.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1] quit
# Configure GigabitEthernet 1/0/3, the interface connected to PE 1.
[PE2-GigabitEthernet1/0/3] undo shutdown
[PE2-GigabitEthernet1/0/2] undo shutdown
[PE2-GigabitEthernet1/0/1] ip address 20.1.1.2 24
[PE2-GigabitEthernet1/0/1] mpls enable
[PE2-GigabitEthernet1/0/1] mpls ldp enable
[PE2-GigabitEthernet1/0/1] undo shutdown
# Establish IBGP connections to PE 1 and PE 3 and enable BGP EVPN to advertise route information to PE 1 and PE 3.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default] peer 3.3.3.9 as-number 100
[PE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-default-evpn] peer 1.1.1.9 enable
[PE2-bgp-default-evpn] peer 3.3.3.9 enable
[PE2-bgp-default-evpn] peer 1.1.1.9 advertise encap-type mpls
[PE2-bgp-default-evpn] peer 3.3.3.9 advertise encap-type mpls
[PE2] pw-class aaa
[PE2-pw-aaa] pw-type ethernet
[PE2-pw-aaa] quit
[PE2] vsi vpna
[PE2-vsi-vpna-evpn-srv6] route-distinguisher 1:1
[PE2-vsi-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE2-vsi-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE2-vsi-vpna-evpn-srv6] quit
# Configure VSI vpna to use LDP to establish LDP PWs. Configure PE 2 to establish an UPW with PE 4, assign an ESI to the UPW, and set the redundancy mode of the UPW to all-active.
[PE2] vsi vpna
[PE2-vsi-vpna] pwsignaling ldp
[PE2-vsi-vpna-ldp] peer 1.1.1.9 pw-id 500 no-split-horizon pw-class aaa
[PE2-vsi-vpna-ldp-1.1.1.9-500] esi 1.1.1.1.1
[PE2-vsi-vpna-ldp-1.1.1.9-500] evpn redundancy-mode all-active
[PE2-vsi-vpna-ldp-1.1.1.9-500] quit
[PE2-vsi-vpna-ldp] quit
[PE2-vsi-vpna] quit
5. Configure PE 3:
<PE3> system-view
[PE3-LoopBack0] ip address 3.3.3.9 32
[PE1] mpls lsr-id 3.3.3.9
[PE1] mpls ldp
[PE1-ldp] quit
# Enable L2VPN.
[PE3] l2vpn enable
# Run OSPF on PE 3 to set up LSPs.
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE3-ospf-1] quit
# Configure GigabitEthernet 1/0/2, the interface connected to PE 1.
[PE3-GigabitEthernet1/0/2] ip address 30.1.1.3 24
[PE3-GigabitEthernet1/0/2] undo shutdown
# Configure GigabitEthernet 1/0/3, the interface connected to PE 2.
[PE3-GigabitEthernet1/0/3] ip address 10.1.2.3 24
[PE3-GigabitEthernet1/0/3] undo shutdown
# Establish IBGP connections to PE 1 and PE 2, and enable BGP EVPN to advertise route information to PE 1 and PE 2.
[PE3] bgp 100
[PE3-bgp-default] peer 1.1.1.9 as-number 100
[PE3-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE3-bgp-default] peer 2.2.2.9 as-number 100
[PE3-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE3-bgp-default-evpn] peer 1.1.1.9 enable
[PE3-bgp-default-evpn] peer 2.2.2.9 enable
[PE3-bgp-default-evpn] peer 1.1.1.9 advertise encap-type mpls
[PE3-bgp-default-evpn] peer 2.2.2.9 advertise encap-type mpls
[PE3] vsi vpna
[PE3-vsi-vpna-evpn-srv6] route-distinguisher 1:1
[PE3-vsi-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE3-vsi-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE3-vsi-vpna-evpn-srv6] quit
6. Configure CE 2.
<CE2> system-view
# On PE 1, display PW information. Verify that PE 1 has established an LDP PW with PE 4 and EVPN PWs with PE 2 and PE 3.
PBY - pw-bypass
Total number of PWs: 3
3 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
VSI Name: vpna
4.4.4.9 500 1147/- LDP MN 8 Up
2.2.2.9 - 1148/1148 EVPN M 9 Up
3.3.3.9 - 1148/1149 EVPN M 10 Up
# On PE 1, display local ES information. Verify that the LDP PW (UPW) has multihoming settings.
<PE1> display evpn es local verbose
VSI name : vpna
Interface : -
Redundancy mode : All-active
State : Up
UPWs :
Link ID Service instance ID Tag ID DF address ESI label
8 - - - 1146
# Display information on PE 2 in the same way as information is displayed on PE 1. (Details not shown.)
EVPN VPLS configuration examples (on switches)
Example: Configuring EVPN VPLS between singlehomed sites
As shown in Figure 15, set up a path between PE 1 and PE 2 for the CEs in VLAN 10 of site 1 and site 2 to communicate through EVPN VPLS over the MPLS or IP backbone network.
Device |
IP address |
Device |
IP address |
CE 1 |
Vlan-int10 |
10.1.1.10/24 |
P |
Loop0 |
3.3.3.3/32 |
PE 1 |
Loop0 |
1.1.1.1/32 |
Vlan-int23 |
11.1.1.2/24 |
Vlan-int23 |
11.1.1.1/24 |
Vlan-int26 |
11.1.2.2/24 |
CE 2 |
Vlan-int10 |
10.1.1.20/24 |
PE 2 |
Loop0 |
2.2.2.2/32 |
Vlan-int26 |
11.1.2.1/24 |
Create VLANs on all devices and assign interfaces to the VLANs.
1. Configure CE 1.
<CE1> system-view
[CE1] interface vlan-interface 10
[CE1-Vlan-interface10] ip address 10.1.1.10 24
[CE1-Vlan-interface10] quit
2. Configure PE 1:
<PE1> system-view
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
# Configure VLAN-interface 23 (the interface connected to the P device), and enable LDP on the interface.
[PE1] interface vlan-interface 23
[PE1-Vlan-interface23] ip address 11.1.1.1 24
[PE1-Vlan-interface23] mpls enable
[PE1-Vlan-interface23] mpls ldp enable
[PE1-Vlan-interface23] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
[PE1] bgp 100
[PE1] vsi vpna
[PE1-vsi-vpna] quit
# Configure Ethernet service instance 1000 to match VLAN 10 on GigabitEthernet 1/0/1 (the interface connected to CE 1).
[PE1-GigabitEthernet1/0/1] service-instance 1000
[PE1-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 10
# Map Ethernet service instance 1000 to VSI vpna.
[PE1-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[PE1-GigabitEthernet1/0/1-srv1000] quit
<P> system-view
[P-LoopBack0] quit
[P] mpls ldp
[P-ldp] quit
# Configure VLAN-interface 23 (the interface connected to PE 1), and enable LDP on the interface.
[P] interface vlan-interface 23
[P-Vlan-interface23] ip address 11.1.1.2 24
[P-Vlan-interface23] mpls enable
[P-Vlan-interface23] mpls ldp enable
[P-Vlan-interface23] quit
# Configure VLAN-interface 26 (the interface connected to PE 2), and enable LDP on the interface.
[P] interface vlan-interface 26
[P-Vlan-interface26] ip address 11.1.2.2 24
[P-Vlan-interface26] mpls enable
[P-Vlan-interface26] mpls ldp enable
[P-Vlan-interface26] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
4. Configure PE 2:
<PE2> system-view
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
# Configure VLAN-interface 26 (the interface connected to the P device), and enable LDP on the interface.
[PE2] interface vlan-interface 26
[PE2-Vlan-interface26] ip address 11.1.2.1 24
[PE2-Vlan-interface26] mpls enable
[PE2-Vlan-interface26] mpls ldp enable
[PE2-Vlan-interface26] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
[PE2] bgp 100
[PE2] vsi vpna
[PE2-vsi-vpna] quit
# Configure Ethernet service instance 1000 to match VLAN 10 on GigabitEthernet 1/0/1 (the interface connected to CE 2).
[PE2-GigabitEthernet1/0/1] service-instance 1000
[PE2-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 10
[PE2-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[PE2-GigabitEthernet1/0/1-srv1000] quit
5. Configure CE 2.
<CE2> system-view
[CE2] interface vlan-interface 10
[CE2-Vlan-interface10] ip address 10.1.1.20 24
[CE2-Vlan-interface10] quit
PBY - pw-bypass
VSI name: vpna
# Verify that the PW is created on PE 2.
PBY - pw-bypass
VSI name: vpna
As shown in Figure 16, configure EVPN VPLS for dualhomed site 1 and singlehomed site 2 to communicate over the MPLS or IP backbone network.
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
192.1.1.1/32 |
CE 1 |
Vlan-int10 |
100.1.1.1/24 |
GE1/0/1 |
N/A |
CE 2 |
Vlan-int10 |
100.1.1.2/24 |
Vlan-int13 |
10.1.1.1/24 |
PE 3 |
Loop0 |
192.3.3.3/32 |
Vlan-int11 |
10.1.3.1/24 |
GE1/0/1 |
N/A |
PE 2 |
Loop0 |
192.2.2.2/32 |
Vlan-int13 |
10.1.1.2/24 |
GE1/0/1 |
N/A |
Vlan-int23 |
10.1.2.2/24 |
Vlan-int23 |
10.1.2.1/24 |
Vlan-int11 |
10.1.3.2/24 |
1. Configure CE 1:
# Create VLAN-interface 10 and assign it an IP address.
<CE1> system-view
[CE1-Vlan-interface10] ip address 100.1.1.1 24
2. Configure PE 1:
<PE1> system-view
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
# Configure VLAN-interface 13 (the interface connected to PE 3), and enable LDP on the interface.
[PE1] interface vlan-interface 13
[PE1-Vlan-interface13] ip address 10.1.1.1 24
[PE1-Vlan-interface13] mpls enable
[PE1-Vlan-interface13] mpls ldp enable
[PE1-Vlan-interface13] quit
# Configure VLAN-interface 11 (the interface connected to PE 2), and enable LDP on the interface.
[PE1] interface vlan-interface 11
[PE1-Vlan-interface11] ip address 10.1.3.1 24
[PE1-Vlan-interface11] mpls enable
[PE1-Vlan-interface11] mpls ldp enable
[PE1-Vlan-interface11] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
[PE1] bgp 100
[PE1] vsi vpna
[PE1-vsi-vpna] quit
3. Configure PE 2:
<PE2> system-view
[PE2] mpls ldp
[PE2-ldp] quit
# Configure VLAN-interface 23 (the interface connected to PE 3), and enable LDP on the interface.
[PE2] interface vlan-interface 23
[PE2-Vlan-interface23] ip address 10.1.2.1 24
[PE2-Vlan-interface23] mpls enable
[PE2-Vlan-interface23] mpls ldp enable
[PE2-Vlan-interface23] quit
[PE2] interface vlan-interface 11
[PE2-Vlan-interface11] ip address 10.1.3.2 24
[PE2-Vlan-interface11] mpls enable
[PE2-Vlan-interface11] mpls ldp enable
[PE2-Vlan-interface11] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
[PE2] bgp 100
[PE2] vsi vpna
[PE2-vsi-vpna] quit
4. Configure PE 3:
<PE3> system-view
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] mpls ldp
[PE3-ldp] quit
# Configure VLAN-interface 13 (the interface connected to PE 1) and VLAN-interface 23 (the interface connected to PE 2), and enable LDP on the interfaces.
[PE3] interface vlan-interface13
[PE3-Vlan-interface13] ip address 10.1.1.2 24
[PE3-Vlan-interface13] mpls enable
[PE3-Vlan-interface13] mpls ldp enable
[PE3-Vlan-interface13] quit
[PE3] interface vlan-interface23
[PE3-Vlan-interface23] ip address 10.1.2.2 24
[PE3-Vlan-interface23] mpls enable
[PE3-Vlan-interface23] mpls ldp enable
[PE3-Vlan-interface23] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
[PE3] bgp 100
[PE3] vsi vpna
[PE3-GigabitEthernet1/0/1] service-instance 1000
[PE3-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 10
[PE3-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[PE3-GigabitEthernet1/0/1-srv1000] quit
5. Configure CE 2.
<CE2> system-view
[CE2-Vlan-interface10] ip address 100.1.1.2 24
PBY - pw-bypass
VSI name: vpna
VSI name : vpna
VSI name : vpna
192.2.2.2
A-D per ES routes :
- 192.2.2.2 B
PBY - pw-bypass
VSI name: vpna
PBY - pw-bypass
VSI name: vpna
As shown in Figure 17:
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
1.1.1.9/32 |
PE 3 |
Loop0 |
3.3.3.9/32 |
Vlan-int15 |
10.1.1.1/24 |
GE1/0/1 |
Vlan-int13 |
30.1.1.1/24 |
Vlan-int13 |
30.1.1.3/24 |
Vlan-int11 |
10.1.3.1/24 |
Vlan-int23 |
10.1.2.3/24 |
PE 2 |
Loop0 |
2.2.2.9/32 |
PE 4 |
Loop0 |
4.4.4.9/32 |
Vlan-int26 |
20.1.1.2/24 |
GE1/0/1 |
Vlan-int23 |
10.1.2.2/24 |
Vlan-int15 |
10.1.1.4/24 |
Vlan-int11 |
10.1.3.2/24 |
Vlan-int26 |
20.1.1.4/24 |
CE 1 |
Vlan-int10 |
100.1.1.1/24 |
CE 2 |
Vlan-int10 |
100.1.1.2/24 |
1. Configure CE 1:
# Configure an IP address and mask for VLAN-interface 10.
<CE1> system-view
[CE1] interface vlan-interface10
2. Configure PE 4:
<PE4> system-view
[PE4] mpls ldp
[PE4-ldp] quit
# Enable L2VPN.
[PE4] l2vpn enable
# Configure VLAN-interface 15, the interface connected to PE 1.
[PE4] interface vlan-interface 15
[PE4-Vlan-interface15] ip address 10.1.1.4 24
[PE4-Vlan-interface15] ospf 1 area 0
[PE4-Vlan-interface15] mpls enable
[PE4-Vlan-interface15] mpls ldp enable
[PE4-Vlan-interface15] undo shutdown
[PE4-Vlan-interface15] quit
# Configure VLAN-interface 26, the interface connected to PE 2.
[PE4] interface vlan-interface 26
[PE4-Vlan-interface26] ip address 20.1.1.4 24
[PE4-Vlan-interface26] ospf 1 area 0
[PE4-Vlan-interface26] mpls enable
[PE4-Vlan-interface26] mpls ldp enable
[PE4-Vlan-interface26] undo shutdown
[PE4-Vlan-interface26] quit
[PE4] vsi vpna
[PE4-vsi-vpna] quit
# Create Ethernet service instance 10 on GigabitEthernet 1/0/1, configure the Ethernet service instance to match VLAN 10, and map the Ethernet service instance to VSI vpna.
[PE4-GigabitEthernet1/0/1] service-instance 10
[PE4-GigabitEthernet1/0/1-srv10] encapsulation s-vid 10
[PE4-GigabitEthernet1/0/1-srv10] xconnect vsi vpna
[PE4-GigabitEthernet1/0/1-srv10] quit
3. Configure PE 1:
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure VLAN-interface 13, the interface connected to PE 3.
[PE1-Vlan-interface13] ip address 30.1.1.1 24
# Configure VLAN-interface 11, the interface connected to PE 2.
# Configure VLAN-interface 15, the interface connected to PE 4.
[PE1] interface vlan-interface 15
[PE1-Vlan-interface15] ip address 10.1.1.1 24
[PE1-Vlan-interface15] mpls enable
[PE1-Vlan-interface15] mpls ldp enable
[PE1-Vlan-interface15] quit
[PE1] bgp 100
[PE1] vsi vpna
[PE1-vsi-vpna] quit
4. Configure PE 2:
<PE2> system-view
[PE2] mpls ldp
[PE2-ldp] quit
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# Configure VLAN-interface 23, the interface connected to PE 3.
[PE2-Vlan-interface23] ip address 10.1.2.2 24
# Configure VLAN-interface 11, the interface connected to PE 1.
# Configure VLAN-interface 26, the interface connected to PE 4.
[PE2-Vlan-interface26] ip address 20.1.1.2 24
[PE2] bgp 100
[PE2] vsi vpna
[PE2] vsi vpna
[PE2-vsi-vpna] quit
5. Configure PE 3:
<PE3> system-view
[PE1] mpls ldp
[PE1-ldp] quit
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
# Configure VLAN-interface 13, the interface connected to PE 1.
[PE3] interface vlan-interface 13
[PE3-Vlan-interface13] ip address 30.1.1.3 24
# Configure VLAN-interface 23, the interface connected to PE 2.
[PE3-Vlan-interface23] ip address 10.1.2.3 24
[PE3] bgp 100
[PE3] vsi vpna
[PE3-GigabitEthernet1/0/1-srv10] encapsulation s-vid 10
[PE3-GigabitEthernet1/0/1-srv10] xconnect vsi vpna
6. Configure CE 2.
<CE2> system-view
PBY - pw-bypass
VSI Name: vpna
VSI name : vpna
Interface : -
State : Up
UPWs :
8 - - - 1146
