02-Fundamentals Command Reference
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesCommand ReferencesH3C WX3800X Series Access Controllers Command References(R1210P01)-6W10002-Fundamentals Command Reference
07-Software upgrade commands
07-Software upgrade commands 92.97 KB
As a best practice, store the startup images in a fixed storage medium. If you store the startup images in a hot swappable storage medium, do not remove the hot swappable storage medium during the startup process.
boot-loader file
Use boot-loader file to specify startup image files.
boot-loader file boot filename system filename [ feature filename&<1-30> ] [ patch filename&<1-30> ] { backup | main }
boot-loader file ipe-filename [ patch filename&<1-30> ] { backup | main }
boot: Specifies a boot image file.
system: Specifies a system image file.
feature: Specifies a space-separated list of up to 30 feature image files.
patch: Specifies a space-separated list of up to 30 incremental patch image files or 16 non-incremental patch image files. Because the boot, system, and feature images each can have one non-incremental patch image file, you can specify a maximum of 16 non-incremental patch image files.
filename: Specifies a .bin file in the filesystemname/filename.bin format. The file must be stored in the root directory of a file system on the device. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see Fundamentals Configuration Guide.
ipe-filename: Specifies an .ipe image package file in the filesystemname/filename.ipe format. The file must be stored in the root directory of a file system on the device. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see Fundamentals Configuration Guide.
backup: Specifies the files as backup startup image files. Backup images are used only when main images are not available.
main: Specifies the files as main startup image files. The device always first attempts to start up with main startup files.
The boot-loader file command overwrites the entire startup image list. To add new startup feature images, specify all feature image files in the old startup image list, including feature image files. The new startup image list will contain only the feature image files that are specified in the command.
To load the specified startup software images, you must reboot the system.
The system will verify the digital signature of the specified images before it updates the startup image list with the specified images. If the digital signature verification fails, the system will not update the startup image list and you will receive a digital signature verification failure message.
# Specify flash:/all.ipe as the main startup image file.
<Sysname> boot-loader file flash:/all.ipe main
Verifying the file flash:/all.ipe on the device.............Done.
H3C WX3510X images in IPE:
  boot.bin
  system.bin
This command will set the main startup software images. Continue? [Y/N]:Y
Add images to the device.
File flash:/boot.bin already exists on the device.
File flash:/system.bin already exists on the device.
Overwrite the existing files? [Y/N]:Y
Decompressing file boot.bin to flash:/boot.bin........................Done.
Decompressing file system.bin to flash:/system.bin...............................Done.
Verifying the file flash:/boot.bin on the device...Done.
Verifying the file flash:/system.bin on the device.............Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on the device.
# Specify flash:/boot.bin and flash:/system.bin as the main startup boot and system image files.
<Sysname> boot-loader file boot flash:/boot.bin system flash:/system.bin main
This command will set the main startup software images. Continue? [Y/N]:y
display boot-loader
display boot-loader
Use display boot-loader to display current software images and startup software images.
display boot-loader
# Display the current software images and startup software images.
<Sysname> display boot-loader
Software images on the device:
Current software images:
  flash:/boot.bin
  flash:/system.bin
Main startup software images:
  flash:/boot.bin
  flash:/system.bin
Backup startup software images:
  flash:/boot.bin
  flash:/system.bin
  Image                 Version
  flash:/boot.bin       Release 0053
  flash:/system.bin     Release 0053
  Image                 Version
  flash:/boot.bin       Releae 0054
  flash:/system.bin     Releae 0054
  Image                 Version
  flash:/b-boot.bin     --
  flash:/b-system.bin   --
Comware images that have been loaded.
Primary Comware images for the next startup.
Image name.
Version
Image version.
If an image is corrupted or deleted, this field displays two hyphens (--).
Backup Comware images for the next startup.
boot-loader file
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
H3C Comware Software, Version 9.0.001, Alpha 1029
Copyright (c) 2004-2020 New H3C Technologies Co., Ltd. All rights reserved.
H3C WX3510X uptime is 0 weeks, 6 days, 20 hours, 37 minutes
Last reboot reason : User soft reboot
Boot image: flash:/boot.bin
Boot image version: 9.0.001, Alpha 1029
  Compiled May 26 2020 14:00:00
System image: flash:/system.bin
System image version: 9.0.001, Alpha 1029
Last reboot reason
Reason for the last reboot:
·     User rebootThe reboot was manually initiated from a user interface, such as the CLI or SNMP.
·     Cold rebootThe reboot was caused by a power cycle.
·     Kernel abnormality rebootThe reboot was caused by kernel exceptions.
·     DeadLoop rebootThe reboot was caused by a kernel thread dead loop.
·     DEV HandShake rebootThe reboot was caused by a device management handshake failure.
·     Auto Update rebootThe reboot was caused by an automatic software upgrade.
·     Memory exhaust rebootThe reboot was caused by a card-memory-exhausted event.
·     Critical process abnormality rebootThe reboot was caused by critical process exceptions.
iot update file
Use iot update file to updrade the IoT software.
iot update file filename
filename: Specifies a .bin file in the filename.bin format. The file must be stored in the root directory of a file system on the device. The value string can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
# Updrade the IoT software.
<Sysname> iot update file iotware.bin
  • Become a Partner
  • Partner Resources
