01-EVPN commands | 421.54 KB |
address-family evpn (public instance view)
address-family evpn (VPN instance view)
address-family ipv4 (public instance view)
address-family ipv6 (public instance view)
arp forwarding-conversational-learning
display evpn m-lag synchronized-mac
display evpn ipv6 auto-discovery
display evpn route arp suppression
display evpn route { igmp-js | igmp-ls | smet }
display evpn route nd suppression
display l2vpn forwarding evpn split-horizon
evpn multihoming advertise disable
evpn multihoming timer df-delay
evpn route arp-mobility suppression
evpn route gateway-mac unmovable
ip forwarding-conversational-learning
ip-prefix-route generate disable
ipv6 forwarding-conversational-learning
ipv6 nd ra tunnel-broadcast enable
ipv6 nd ra tunnel-broadcast global enable
mac-address forwarding-conversational-learning
nexthop evpn-m-lag group-address
peer advertise evpn-route suppress
peer advertise vpn-reoriginate ibgp
peer default-gateway no-advertise
route-distinguisher (EVPN instance view)
route-distinguisher (public instance view)
EVPN commands
Use address-family evpn to enter public instance EVPN view.
Use undo address-family evpn to delete all settings in public instance EVPN view.
address-family evpn
Public instance view
You can configure EVPN settings such as route targets in public instance EVPN view.
# Enter public instance EVPN view.
[Sysname] ip public-instance
[Sysname-public-instance] address-family evpn
[Sysname-public-instance-evpn]
Use address-family evpn to enter VPN instance EVPN view.
Use undo address-family evpn to delete all settings in VPN instance EVPN view.
address-family evpn
VPN instance view
You can configure EVPN settings such as route targets and routing policies in VPN instance EVPN view.
# Enter EVPN view of VPN instance tenant.
[Sysname] ip vpn-instance tenant
[Sysname-vpn-instance-tenant] address-family evpn
[Sysname-vpn-evpn-tenant]
Use address-family ipv4 to enter public instance IPv4 address family view.
Use undo address-family ipv4 to delete all settings in public instance IPv4 address family view.
address-family ipv4
# Enter public instance IPv4 address family view.
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4]
Use address-family ipv6 to enter public instance IPv6 address family view.
Use undo address-family ipv6 to delete all settings in public instance IPv6 address family view.
address-family ipv6
# Enter public instance IPv6 address family view.
[Sysname-public-instance] address-family ipv6
[Sysname-public-instance-ipv6]
address-family l2vpn evpn
Use address-family l2vpn evpn to create the BGP EVPN address family and enter its view, or enter the view of the existing BGP EVPN address family.
Use undo address-family l2vpn evpn to delete the BGP EVPN address family and all settings in BGP EVPN address family view.
The BGP EVPN address family does not exist.
BGP instance view
Configuration made in BGP EVPN address family view takes effect only on routes and peers of the BGP EVPN address family that are on the public network.
# Create the BGP EVPN address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn]
advertise evpn route
Use advertise evpn route to enable BGP EVPN route advertisement for the BGP VPNv4 or VPNv6 address family.
Use undo advertise evpn route to disable BGP EVPN route advertisement for the BGP VPNv4 or VPNv6 address family.
advertise evpn route [ replace-rt ][ advertise-policy policy-name ]
BGP EVPN routes are not advertised through the BGP VPNv4 or VPNv6 address family.
BGP VPNv4 address family
BGP VPNv6 address family
replace-rt: Replaces the route targets of BGP EVPN routes with the route targets of BGP VPNv4 or VPNv6 routes. If you do not specify this keyword, route targets of BGP EVPN routes are not modified.
advertise-policy policy-name: Specifies a routing policy to filter the BGP EVPN routes to be advertised to BGP VPNv4 or VPNv6 peers. The policy-name argument specifies the routing policy name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, all BGP EVPN routes are advertised to BGP VPNv4 or VPNv6 peers.
To enable communication between data centers interconnected through an MPLS L3VPN network, you must configure the BGP EVPN address family and the BGP VPNv4 or VPNv6 address family to exchange routes on EDs.
After you execute this command, the device advertises IP prefix advertisement routes and MAC/IP advertisement routes that contain host route information through the BGP VPNv4 or VPNv6 address family.
# Enable BGP EVPN route advertisement for the BGP VPNv4 address family.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] advertise evpn route
advertise l2vpn evpn
Use advertise l2vpn evpn to enable BGP EVPN route advertisement to the local site.
Use undo advertise l2vpn evpn to disable BGP EVPN route advertisement to the local site.
BGP EVPN route advertisement to the local site is enabled.
BGP-VPN IPv4 unicast address family view
BGP-VPN IPv6 unicast address family view
This command enables the device to advertise BGP EVPN routes to the local site after the device adds the routes to the routing table of a VPN instance. The BGP EVPN routes here are IP prefix advertisement routes and MAC/IP advertisement routes that contain ARP or ND information.
# Enable BGP EVPN route advertisement to the local site for VPN instance vpn1.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] advertise l2vpn evpn
advertise l3vpn route
Use advertise l3vpn route to enable BGP VPNv4 or VPNv6 route advertisement for the BGP EVPN address family.
Use undo advertise l3vpn route to disable BGP VPNv4 or VPNv6 route advertisement for the BGP EVPN address family.
advertise l3vpn route [ replace-rt ][ advertise-policy policy-name ]
BGP VPNv4 or VPNv6 routes are not advertised through the BGP EVPN address family.
replace-rt: Replaces the route targets of BGP VPNv4 or VPNv6 routes with the route targets of BGP EVPN routes. If you do not specify this keyword, route targets of BGP VPNv4 or VPNv6 routes are not modified.
advertise-policy policy-name: Specifies a routing policy to filter the BGP VPNv4 or VPNv6 routes to be advertised to BGP EVPN peers. The policy-name argument specifies the routing policy name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, all BGP VPNv4 or VPNv6 routes are advertised to BGP EVPN peers.
After you execute this command, the device advertises BGP VPNv4 or VPNv6 routes as IP prefix advertisement routes through the BGP EVPN address family.
# Enable BGP VPNv4 or VPNv6 route advertisement for the BGP EVPN address family.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] advertise l3vpn route
advertise route-reoriginate
Use advertise route-reoriginate to enable reoriginating BGP routes for a VPN instance based on the BGP routes received from other VPN instances.
Use undo advertise route-reoriginate to restore the default.
advertise route-reoriginate [ route-policy route-policy-name ] [ replace-rt ]
A VPN instance does not reoriginate BGP unicast routes for the BGP routes of other VPN instances.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. BGP route reorigination is performed only for the routes that match this routing policy. If you do not specify a routing policy, BGP route reorigination is performed for BGP routes of any VPN instance.
replace-rt: Replaces the route targets of reoriginated BGP routes with those of the local VPN instance. If you do not specify this keyword, route targets of reoriginated BGP routes are the same as the original routes.
This command enables the device to reoriginate BGP routes based on received VPNv4, VPNv6, and EVPN routes that match the import route targets of a local VPN instance and advertise the reoriginated BGP routes to VPNv4, VPNv6, and EVPN peers.
# Enable reoriginating BGP routes for VPN instance vpn1 based on the BGP routes received from other VPN instances.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-vpn1] advertise route-reoriginate
Use arp forwarding-conversational-learning to enable conversational learning for remote ARP entries.
Use undo arp forwarding-conversational-learning to disable conversational learning for remote ARP entries.
arp forwarding-conversational-learning [ aging aging-time ]
Conversational learning is disabled for remote ARP entries.
aging aging-time: Specifies an aging timer in minutes for remote ARP entries, in the range of 60 to 1440. The default value is 60.
Use this command only on an EVPN network.
By default, the device issues a remote ARP entry to the hardware after the ARP information is advertised to the local site by BGP EVPN routes. This feature enables the device to issue a remote ARP entry to the hardware only when the entry is required for packet forwarding. This feature saves hardware resources on the device.
After you enable this feature, the device periodically examines whether the ARP entries are used for packet forwarding. An ARP entry is deleted if its aging timer expires.
When a large number of remote ARP entries exist, set an appropriate aging timer to avoid traffic interruption caused by the aging of ARP entries. As a best practice, set the aging timer value higher than or equal to the number of remote ARP entries divided by 200.
# Enable conversational learning for remote ARP entries and set the entry aging timer to 80 minutes.
[Sysname] arp forwarding-conversational-learning aging 80
arp mac-learning disable
Use arp mac-learning disable to disable an EVPN instance from learning MAC addresses from ARP information.
Use undo arp mac-learning disable to restore the default.
An EVPN instance learns MAC addresses from ARP information.
EVPN instance view
The MAC information and ARP information advertised by a remote VTEP overlap. To avoid duplication, use this command to disable the learning of MAC addresses from ARP information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
# Disable an EVPN instance from learning MAC addresses from ARP information.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan] arp mac-learning disable
arp-advertising disable
Use arp-advertising disable to disable ARP information advertisement for an EVPN instance.
Use undo arp-advertising disable to restore the default.
ARP information advertisement is enabled for an EVPN instance.
EVPN instance view
In an EVPN network with distributed gateways, you can disable ARP information advertisement for a VXLAN to save resources if all its user terminals use the same EVPN gateway device. The EVPN instance of the VXLAN will stop advertising ARP information through MAC/IP advertisement routes and withdraw advertised ARP information. When ARP information advertisement is disabled, user terminals in other VXLANs still can communicate with that VXLAN through IP prefix advertisement routes.
# Disable ARP information advertisement for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] arp-advertising disable
dci enable
Use dci enable to enable DCI on an interface.
Use undo dci enable to disable DCI on an interface.
dci enable
undo dci enable
DCI is disabled on an interface.
Interface view
For EDs to automatically establish VXLAN-DCI tunnels, you must enable DCI on the Layer 3 interfaces that interconnect the EDs.
Subinterfaces of a DCI-enabled interface inherit configuration of the interface.
# Enable DCI on VLAN-interface 10.
[Sysname-Vlan-interface10] dci enable
display bgp l2vpn evpn
Use display bgp l2vpn evpn to display BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ statistics ] | [ route-distinguisher route-distinguisher | route-type { auto-discovery | es | igmp-ls | igmp-js | imet | ip-prefix | mac-ip | s-pmsi | smet } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info | as-path | cluster-list | community | ext-community ] | ipv4-address | ipv6-address | mac-address ] | statistics ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] community-list { basic-community-list-number | adv-community-list-number | comm-list-name } [ whole-match ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] ext-community [ rt route-target | soo site-of-origin]&<1-32> [ whole-match ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP EVPN routes for the default BGP instance.
peer { ipv4-address | ipv6-address }: Specifies a peer by its IPv4 address or IPv6 address.
advertised-routes: Specifies the routes advertised to the specified peer.
received-routes: Specifies the routes received from the specified peer.
statistics: Displays BGP EVPN route statistics.
route-distinguisher route-distinguisher: Specifies a route distinguisher (RD), a string of 3 to 21 characters. The RD can use one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number. For example, 65536:1. The AS number must be equal to or greater than 65536.
route-type: Specifies a route type.
auto-discovery: Specifies Ethernet auto-discovery routes.
es: Specifies Ethernet segment (ES) routes.
igmp-ls: Specifies IGMP leave synch routes.
igmp-js: Specifies IGMP join synch routes.
imet: Specifies inclusive multicast Ethernet tag (IMET) routes.
ip-prefix: Specifies IP prefix advertisement routes.
mac-ip: Specifies MAC/IP advertisement routes.
s-pmsi: Specifies selective provider multicast service interface (S-PMSI) routes.
smet: Specifies selective multicast Ethernet tag (SMET) routes.
evpn-route: Specifies a BGP EVPN route, a case-insensitive string of 1 to 512 characters.
route-length: Specifies the route length in bits, in the range of 0 to 65535.
evpn-prefix: Specifies a BGP EVPN route in the format of evpn-route/route-length, a case-insensitive string of 1 to 512 characters.
advertise-info: Displays advertisement information for BGP EVPN routes.
as-path: Specifies the AS path attribute.
cluster-list: Specifies the cluster list attribute.
community: Specifies the community attribute.
ext-community: Specifies the extended community attribute.
ipv4-address: Specifies an IPv4 address.
ipv6-address: Specifies an IPv6 address.
mac-address: Specifies a MAC address to match MAC/IP advertisement routes. If you specify the route-type keyword, you can specify this argument only if you also specify the mac-ip keyword.
community-number&<1-32>: Specifies a community sequence number. The value range for the community-number argument is 1 to 4294967295. &<1-32> indicates that a maximum of 32 numbers can be specified.
aa:nn&<1-32>: Specifies a community number. Both aa and nn are in the range of 0 to 65535. &<1-32> indicates that a maximum of 32 numbers can be specified.
internet: Specifies the INTERNET community attribute. Routes with this attribute can be advertised to all BGP peers. By default, all routes have this attribute.
no-advertise: Specifies the NO_ADVERTISE community attribute. Routes with this attribute cannot be advertised to any BGP peers.
no-export: Specifies the NO_EXPORT community attribute. Routes with this attribute cannot be advertised outside the local AS or confederation, but can be advertised to other sub-ASs in the confederation.
no-export-subconfed: Specifies the NO_EXPORT_SUBCONFED community attribute. Routes with this attribute cannot be advertised outside the local AS or to other sub-ASs in the confederation.
whole-match: Displays BGP EVPN routes that exactly match the specified community list, community numbers, or extended community attribute. If you do not specify this keyword, the command displays BGP EVPN routes that include the specified community list, community numbers, or extended community attribute.
community-list: Specifies a community list to match BGP EVPN unicast routes.
basic-community-list-number: Specifies a basic community list by its number in the range of 1 to 99.
comm-list-name: Specifies a community list by its name, a case-sensitive string of 1 to 63 characters.
adv-community-list-number: Specifies an advanced community list by its number in the range of 100 to 199.
rt route-target: Specifies a route target, a string of 3 to 24 characters.
soo site-of-origin: Specifies the Site of Origin (SoO) extended community attribute, a string of 3 to 24 characters.
A route target or SoO attribute has the following forms:
· 16-bit AS number:32-bit self-defined number. For example, 101:3. The value range is 0 to 65535 for an AS number and 0 to 4294967295 for a self-defined number.
· 32-bit IP address:16-bit self-defined number. For example, 192.168.122.15:1. The value range is 0 to 65535 for a self-defined number.
· 32-bit AS number:16-bit self-defined number. For example, 70000:3. The value range is 65536 to 4294967295 for an AS number and 0 to 65535 for a self-defined number.
· 32-bit IP address/IPv4 address mask length:16-bit user-defined number. For example, 192.168.122.15/24:1.
· 32-bit AS number in dotted format:16-bit user-defined number. For example, 65535.65535:1.
&<1-32>: Specifies a maximum of 32 items.
If you do not specify any parameter, this command displays brief information about all BGP EVPN routes.
This command displays BGP EVPN routes that carry any community attribute and the whole-match keyword does not take effect if you do not specify the following parameters:
· community-number
· aa:nn
· internet
· no-advertise
· no-export
· no-export-subconfed
This command displays BGP EVPN routes that carry any extended community attribute and the whole-match keyword does not take effect if you do not specify the following parameters:
· rt
· soo
# Display brief information about all BGP EVPN routes.
<Sysname> display bgp l2vpn evpn
BGP local router ID is 8.8.8.8
a - additional-path
Total number of routes from all PEs: 3
Route distinguisher: 1:1
Total number of routes: 2
* >e Network : [2][0][48][0011-0022-0033][32][11.22.33.55]/136
NextHop : 1.1.1.2 LocPrf : 100
PrefVal : 0 OutLabel : NULL
MED : 0
Path/Ogn: 20i
Route distinguisher of public instance: 1:15
Total number of routes: 1
* >i Network : [2][0][48][7010-0000-0001][0][0.0.0.0]/104
NextHop : 1.1.1.4 LocPrf : 100
MED : 0
Path/Ogn: 20i
# Display all BGP EVPN routes that carry community attributes.
<Sysname> display bgp l2vpn evpn community
BGP local router ID is 1.1.1.9
a – additional-path
Total number of routes from all PEs: 6
Route distinguisher: 100:1
Total number of routes: 3
Network NextHop MED LocPrf PrefVal Path/Ogn Community
* > [2][0][48][00aa.00bb.00cc][4][0.0.0.0]/136
10.1.1.2 0 32768 ? <2:3>
* e 10.1.1.1 0 0 65410? <2:3>
* > [3][300][16][::ffff:1.1.1.1]/176
127.0.0.1 0 32768 ? <3:4>
# Display all BGP EVPN routes that carry extended community attributes.
<Sysname> display bgp l2vpn evpn ext-community
a – additional-path
Network NextHop MED LocPrf PrefVal Path/Ogn Ext-Community
10.1.1.2 0 32768 ? <RT 2:3>
* e 10.1.1.1 0 0 65410? <RT 2:3>
127.0.0.1 0 32768 ? <RT 3:4>
Status codes |
Route status codes: · * - valid—Valid route. · > - best—Optimal route. · d - dampened—Dampened route. · h - history—History route. · i - internal—Internal route. · e - external—External route. · s - suppressed—Suppressed route. · S - stale—Stale route. · a - additional-path—Add-Path optimal route. |
Origin |
Origin of the route: · i – IGP—Originated in the AS. The origin of routes advertised by using the network command is IGP. · e – EGP—Learned through EGP. · ? – incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is incomplete. |
Network |
BGP EVPN route/route length. For example, in the entry [2][0][48][1485-247c-0506][32][10.1.2.20]/136, [2][0][48][1485-247c-0506][32][10.1.2.20] is the route, and 136 is the route length in bytes. BGP EVPN routes are as follows: · [1][ESI][EthernetTagID] ¡ 1—Ethernet auto-discovery route. ¡ ESI—Ethernet segment identifier (ESI). ¡ EthernetTagID—Ethernet tag ID. · [2][EthernetTagID][MACLength][MAC][IPAddressLength][IPAddress] ¡ 2—MAC/IP advertisement route. ¡ EthernetTagID—Ethernet tag ID. ¡ MACLength—MAC address length. ¡ MAC—MAC address. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address. · [3][EthernetTagID][IPAddressLength][IPAddress] ¡ 3—IMET route. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address of the originating router. · [4][ESI][IPAddressLength][IPAddress] ¡ 4—ES route. ¡ ESI—ESI. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address of the originating router. · [5][EthernetTagID][IPAddressLength][IPAddress] ¡ 5—IP prefix advertisement route. ¡ EthernetTagID—Ethernet tag ID. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address of the originating router. · [6][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP] ¡ 6—Selective multicast Ethernet tag route. ¡ EthernetTagID—Ethernet tag ID. ¡ Source Len—Length of the multicast source address. This field displays 0 if the multicast source is any (*, G). ¡ Source IP—Source IP address of IGMP membership reports. This field is not displayed if the multicast source is any (*, G). ¡ Group Len—Length of the multicast group address. ¡ Group IP—Multicast group address of IGMP membership reports. ¡ Originator Len—Length of the originating router's IP address. ¡ Originator IP—IP address of the originating router. · [7][ESI][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP] ¡ 7—IGMP join synch route. ¡ ESI—ESI. ¡ EthernetTagID—Ethernet tag ID. ¡ Source Len—Length of the multicast source address. This field displays 0 if the multicast source is any (*, G). ¡ Source IP—Source IP address of IGMP membership reports. This field is not displayed if the multicast source is any (*, G). ¡ Group Len—Length of the multicast group address. ¡ Group IP—Multicast group address of IGMP membership reports. ¡ Originator Len—Length of the originating router's IP address. ¡ Originator IP—IP address of the originating router. · [8][ESI][EthernetTagID] [Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP][ [LeaveGroup Synchronization] ¡ 8—IGMP leave synch route. ¡ ESI—ESI. ¡ EthernetTagID—Ethernet tag ID. ¡ Source Len—Length of the multicast source address. This field displays 0 if the multicast source is any (*, G). ¡ Source IP—Source IP address of IGMP membership reports. This field is not displayed if the multicast source is any (*, G). ¡ Group Len—Length of the multicast group address. ¡ Group IP—Multicast group address of IGMP membership reports. ¡ Originator Len—Length of the originating router's IP address. ¡ Originator IP—IP address of the originating router. ¡ LeaveGroup Synchronization—Leave group synchronization sequence number. · [10]EthernetTagID][Source Len][Source IP][Group Len][Group IP]][Originator Len][Originator IP] ¡ 10—Selective provider multicast service interface route. ¡ EthernetTagID—Ethernet tag ID. ¡ Source Len—Length of the multicast source IP address. This field displays 0 if the multicast source is any (*, G). ¡ Source IP—Multicast source IP address. This field is not displayed if the multicast source is any (*, G). ¡ Group Len—Length of the multicast group IP address. ¡ Group IP—Multicast group IP address. ¡ Originator Len—Length of the originating router's IP address. ¡ Originator IP—IP address of the originating router. |
NextHop |
Next hop IP address. |
MED |
Multi-Exit Discriminator (MED) attribute. |
LocPrf |
Local precedence. |
OutLabel |
Outgoing label. |
PrefVal |
Preferred value. |
Path/Ogn |
AS_PATH and ORIGIN attributes of the route. |
Community |
Community attribute. |
Ext-Community |
Extended community attribute. |
# Display detailed information about BGP EVPN route [1][0001.0203.0405.0607.0809][5]/120 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [1][0001.0203.0405.0607.0809][5] 120
BGP local router ID: 172.16.250.133
Local AS number: 100
Route distinguisher: 1.1.1.1:100
Paths: 1 available, 1 best
BGP routing table information of [1][0001.0203.0405.0607.0809][5]/120:
Rely nexthop : 10.1.1.2
Original nexthop: 10.1.1.2
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN >, <ESI Label: Flag 0,
Label 1>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
State : valid, external, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Ethernet auto-discovery route
ESI : 0001.0203.0405.0607.0809
Ethernet tag ID : 5
MPLS label : 10
Paths |
Number of routes: · available—Number of valid routes. · best—Number of optimal routes. |
From |
IP address of the BGP peer that advertised the route. |
Rely nexthop |
Next hop after route recursion. If no next hop is found, this field displays not resolved. |
Original nexthop |
Original next hop of the route. If the route was obtained from a BGP update message, the original next hop is the next hop IP address in the message. |
OutLabel |
Outgoing label of the route. |
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · ESI Label. |
RxPathID |
Add-Path ID value of the received route. This field is not supported by the BGP EVPN address family. |
TxPathID |
Add-Path ID value of the sent route. This field is not supported by the BGP EVPN address family. |
AS-path |
AS_PATH attribute of the route. This attribute records the ASs the route has passed and avoids routing loops. |
Origin |
Origin of the route: · igp—Originated in the AS. The origin of routes advertised by using the network command is IGP. · egp—Learned through EGP. · incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is incomplete. |
Attribute value |
Attributes of the route: · MED—MED value for the destination network. · localpref—Local preference value. · pref-val—Preferred value. · pre—Route preference value. |
State |
Current state of the route: · valid. · internal. · external. · local. · synchronize. · best. · localredist—The route is redistributed from a local VPN instance or public instance. |
IP precedence |
IP precedence in the range of 0 to 7. N/A indicates that the IP precedence is invalid. |
QoS local ID |
QoS local ID in the range of 1 to 4095. N/A indicates that the QoS local ID is invalid. |
Traffic index |
Traffic index in the range of 1 to 64. N/A indicates that the traffic index is invalid. |
MPLS label |
MPLS label. The current software version does not support this field. |
# Display detailed information about BGP EVPN route [2][5][48][0001-0203-0405][32][4.5.5.5]/136 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [2][5][48][0001-0203-0405][32][5.5.5.5] 136
BGP routing table information of [2][5][48][0001-0203-0405][32][5.5.5.5]/136:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <RT: 1:3>, <RT: 1:4>, <RT: 1:5>, <RT: 1:6>, <RT: 1:7
>, <Encapsulation Type: VXLAN>, <Router's Mac: 0006-0708-0910
>, <MAC Mobility: Flag 0, SeqNum 2>, <Default GateWay>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : MAC/IP advertisement route
Ethernet tag ID : 5
MAC address : 0001-0203-0405
IP address : 5.5.5.5/32
MPLS label1 : 10
MPLS label2 : 100
Re-origination : Enable
Route distinguisher: 2.2.2.2:100
OutLabel : 0
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
State : valid, external, best, reoriginated, remoteredist
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Ethernet tag ID : 5
MPLS label1 : 200
MPLS label2 : 300
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · Router's Mac. · MAC Mobility—MAC mobility. ¡ Flag—Indicates whether the MAC address can move. A value of 1 indicates that the MAC address cannot move, and a value of 0 indicates that the MAC address can move. ¡ SeqNum—Identifies the most recent move of the MAC address. · Default GateWay—Route for the default gateway. |
State |
Current state of the route: · valid. · internal. · external. · local. · synchronize. · best. · reoriginated—Reoriginated route. · remoteredist—MAC/IP advertisement route generated based on a remote route. |
MPLS label1 |
VXLAN ID used for Layer 2 forwarding. |
MPLS label2 |
L3 VXLAN ID used for Layer 3 forwarding. |
Re-origination |
State of route reorigination: · Enable. · Disable. |
# Display detailed information about BGP EVPN route [3][0][32][5.5.5.5]/80 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [3][0][32][4.5.5.5] 80
BGP routing table information of [3][0][32][4.5.5.5]/80:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>
RxPathID : 0x0
TxPathID : 0x0
PMSI tunnel : Flag 0, TunnelType 6, Label 10, EndPointAddress 10.1.1.2
AS-path : 200
Origin : igp
Attribute value : MED 0,pref-val 0
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Inclusive multicast Ethernet tag route
Ethernet tag ID : 0
Origin address : 5.5.5.5/32
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Ethernet tag ID : 0
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. |
PMSI tunnel |
P-Multicast Service Interface (PMSI) tunnel information: · Flag—This field is fixed at 0 in the current software version. · TunnelType—This field is fixed at 6 in the current software version, which represents a head-end replication tunnel. · Label—VXLAN ID. · EndPointAddress—Tunnel destination address. |
State |
Route state: · valid—Valid route. · internal—Internal route. · external—External route. · local—Locally originated route. · synchronize—Synchronized route. · best—Optimal route. · reoriginated—Reoriginated route. · localredist—IMET route originated based on a local route. · remoteredist—IMET route originated based on a remote route. |
Origin address |
Re-origination |
Status of route reorigination: · Enable. · Disable. |
# Display detailed information about BGP EVPN route [4][0000.0000.0000.0000.000a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][0000.0000.0000.0000.000a][32][4.5.5.5] 128
BGP routing table information of [4][0000.0000.0000.0000.000a][32][4.5.5.5]/128:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, <ES-Import RT: 1:1>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Ethernet segment route
ESI : 0000.0000.0000.0000.000a
Origin address : 4.5.5.5/32
Table 5 Command output
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · ES-Import RT. |
Origin address |
# Display detailed information about BGP EVPN route [5][10][32][4.5.5.5]/80 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [5][10][32][4.5.5.5] 80
BGP routing table information of [5][10][32][4.5.5.5]/80:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, <Router's Mac:
0006-0708-0910>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : IP prefix advertisement route
Ethernet tag ID : 10
IP address : 4.5.5.5/32
Gateway address : 0.0.0.0
MPLS Label : 1
OutLabel : 0
0006-0708-0910>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
MPLS Label : 20
Table 6 Command output
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · Router's Mac. |
State |
Current state of the route: · valid. · internal. · external. · local. · synchronize. · best. · reoriginated—Reoriginated route. · localredist—IP prefix advertisement route generated based on a local route. · remoteredist—IP prefix advertisement route generated based on a remote route. |
IP address |
IP address and prefix length. |
MPLS Label |
Re-origination |
# Display detailed information about BGP EVPN route [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/160 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1] 160
BGP routing table information of [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/160:
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Selective multicast Ethernet tag route
Ethernet tag ID : 0
Source length : 32
Source address : 10.1.1.1
Group length : 32
Group address : 224.224.224.224
Origin address : 192.168.3.1
IGMP flags : v3, include
Table 7 Command output
Ext-Community |
Source length |
Length of the multicast source address. |
Source address |
Multicast source address. |
Group length |
Length of the multicast group address. |
Group address |
Multicast group address. |
Origin address |
# Display detailed information about BGP EVPN route [7][00:00:00:00:00:00:00:00:00][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/240 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [7][0000.0000.0000.0000.0000][0][32][10.1.1.1][16][224.224.224.224][32][192.168.3.1] 240
BGP routing table information of [7][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/240:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, < ESI-RT: 0:0>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : IGMP join synch route
ESI : 0000.0000.0000.0000.0000
Ethernet tag ID : 0
Source length : 32
Group length : 32
Table 8 Command output
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · EVI-RT—Route target associated with EVI. |
Source length |
Source address |
Group length |
Group address |
Origin address |
# Display detailed information about BGP EVPN route [8][ 00:00:00:00:00:00:00:00:00][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0]/272 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [8][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0] 272
BGP routing table information of [8][0000.0000.0000.0000.0000] [0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0]/272:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, < ESI-RT: 1:200>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : IGMP leave synch route
Ethernet tag ID : 0
Source length : 32
Group length : 32
Leave group sync: 0
Max ResponseTime: 2500ms
Max ResponseCode: 25
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · ESI-RT—Route target associated with the ESI. |
Source length |
Source address |
Group length |
Group address |
Origin address |
Leave group sync |
Leave group synchronization sequence number. |
Max ResponseTime |
Maximum response time in milliseconds. |
Max ResponseCode |
Maximum response time in the received packet, in deciseconds. |
# Display detailed information about BGP EVPN route [10][0][32][7.21.0.7][32][225.0.0.0][32][2.2.2.2]/160 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [10][0][32][7.21.0.7][32][225.0.0.0][32][2.2.2.2]/160
BGP local router ID: 2.2.2.2
Local AS number: 200
Route distinguisher: 1.1.1.1:100(vpna)
BGP routing table information of [10][0][32][7.21.0.7][32][225.0.0.0][32][2.2.2.2]/160:
Rely nexthop : 12.1.1.1
Original nexthop: 0.0.0.0
OutLabel : NULL
Ext-Community : <RT: 1:1>, <Encapsulation Type: VXLAN>
RxPathID : 0x0
TxPathID : 0x0
Org-validation : Valid
PMSI tunnel : Flag 0, TunnelType 3, Label 1000, Reserved 0, SenderAddr 2.2.2.2,
PGroupAddr 232.0.0.0
AS-path : (null)
Origin : igp
Attribute value : MED 0, localpref 100, pref-val 32768
State : valid, local, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : S-PMSI A-D route
Ethernet tag ID : 0
Source length : 32
Source address : 7.21.0.7
Group length : 32
Group address : 225.0.0.0
Origin address : 2.2.2.2
Table 10 Command output
Ext-Community |
EVPN route type |
S-PMSI (selective provider multicast service interface) route. |
Org-validation |
RPKI source AS check result: · Valid. · Not found. · Invalid. |
PMSI tunnel |
PMSI tunnel information: · Flag—Flag, which is fixed at 0 in the current software version. · TunnelType—Tunnel type, which is fixed at 6 (head-end replication tunnel) in the current software version. · Label—VXLAN ID. · Reserved—Reserved field. The value is fixed at 0 in the current software version. · SenderAddr—Sender address. · PgroupAddr—Multicast group address of the service provider. |
Source length |
Source address |
Group length |
Group address |
Origin address |
# Display community attribute information about BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 community
BGP local router ID: 1.1.1.9
BGP routing table information of [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128:
Community: no-export
# Display extended community attribute information about BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 ext-community
Ext-Community: <RT 1:1>
# Display the AS path attribute of BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 as-path
As-path: 80
# Display the cluster ID list attribute of BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 cluster-list
Cluster list: 80
Table 11 Command output
Paths |
Numbers of available routes and optimal routes. |
Community |
Ext-Community |
As-path |
AS path attribute. |
Cluster-list |
Cluster ID list attribute. |
# Display statistics about the BGP EVPN routes with community attributes.
<Sysname> display bgp l2vpn evpn statistics community
Total number of routes from all PEs: 1
Route distinguisher: 100:1(vpn1)
Total number of routes: 4
display evpn auto-discovery
Use display evpn auto-discovery to display information about IPv4 peers that are automatically discovered through BGP.
display evpn auto-discovery { imet [ peer ip-address] [ vsi vsi-name ] | mac-ip | macip-prefix [ nexthop next-hop ] [ count ] }
imet: Specifies IPv4 peers discovered through IMET routes.
peer ip-address: Specifies a peer by its IPv4 address. If you do not specify this option, the command displays information about all automatically discovered IPv4 peers.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv4 peer information for all VSIs.
mac-ip: Specifies IPv4 peers discovered through MAC/IP advertisement routes that do not carry L3 VXLAN IDs.
macip-prefix: Specifies IPv4 peers discovered through MAC/IP advertisement routes that carry L3 VXLAN IDs or IP prefix advertisement routes that carry L3 VXLAN IDs.
nexthop next-hop: Specifies a next hop. If you do not specify this option, the command displays IPv4 peer information for all next hops.
count: Displays the number of IPv4 peers. If you do not specify this keyword, the command displays detailed IPv4 peer information.
# Display information about IPv4 peers discovered through IMET routes.
<Sysname> display evpn auto-discovery imet
Total number of automatically discovered peers: 2
VSI name: vpna
RD PE_address Tunnel_address Tunnel mode VXLAN ID
1:10 2.2.2.2 2.2.2.2 VXLAN 10
2:100 3.3.3.3 3.3.3.3 VXLAN 10
Table 12 Command output
PE_address |
Identifier of the remote VTEP on the VSI. |
Tunnel_address |
Tunnel destination IP address. |
Tunnel mode |
Tunnel mode: · VXLAN. · VXLAN-DCI. |
# Display information about IPv4 peers discovered through MAC/IP advertisement routes that do not carry L3 VXLAN IDs.
<Sysname> display evpn auto-discovery mac-ip
Total number of automatically discovered peers: 1
VSI name: vpna
Destination IP Source IP VXLAN ID Tunnel mode Tunnel name
6.6.6.6 1.1.1.9 100 VXLAN Tunnel1
Table 13 Command output
Destination IP |
Source IP |
Tunnel source IP address. |
Tunnel mode |
Tunnel mode. VXLAN represents a VXLAN tunnel. |
# Display information about IPv4 peers discovered through MAC/IP advertisement routes that carry L3 VXLAN IDs or IP prefix advertisement routes that carry L3 VXLAN IDs.
<Sysname> display evpn auto-discovery macip-prefix
Destination IP Source IP L3VNI Tunnel mode Outgoing interface
1.1.1.1 3.3.3.3 200 VXLAN Vsi-interface3
2.2.2.2 3.3.3.3 200 VXLAN Vsi-interface3
# Display the total number of IPv4 peers discovered through MAC/IP advertisement routes that carry L3 VXLAN IDs or IP prefix advertisement routes that carry L3 VXLAN IDs.
<Sysname> display evpn auto-discovery macip-prefix count
Total number of entries: 2
Table 14 Command output
Destination IP |
Source IP |
L3VNI |
Tunnel mode |
Outgoing interface |
VSI interface associated with the L3 VXLAN ID. |
Use display evpn m-lag synchronized-mac to display M-LAG-synchronized MAC address entries.
display evpn m-lag synchronized-mac [ vsi vsi-name ] [ count ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address entries for all VSIs.
count: Displays the number of MAC address entries that match the command. If you do not specify this keyword, the command displays detailed information about MAC address entries.
To ensure VM reachability information consistency in an M-LAG system, M-LAG member devices synchronize MAC address entries and ARP packets with each other through a peer link. This command displays the synchronized MAC address entries from an M-LAG peer.
# Display all M-LAG-synchronized MAC address entries.
<Sysname> display evpn m-lag synchronized-mac
VSI name: bbb
MAC address Link ID Interface
0000-0000-000a 1 BAGG10
0000-0000-0009 0 Tunnel1
# Display the total number of M-LAG-synchronized MAC address entries.
<Sysname> display evpn m-lag synchronized-mac count
Table 15 Command output
Link ID |
AC's or VXLAN tunnel's link ID on a VSI. |
Outgoing interface name. |
display evpn es
Use display evpn es to display EVPN ES information.
display evpn es { local [ vsi vsi-name ] [ esi esi-id ] [ verbose ] | remote [ vsi vsi-name ] [ esi esi-id ] [ nexthop next-hop ] }
local: Specifies local ES information.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ES information about all VSIs.
esi esi-id: Specifies an ES by its ESI in XXXX.XXXX.XXXX.XXXX.XXXX format. Each X represents a hexadecimal digit. The ESI must begin with 00 and cannot be all zeros. If you do not specify this option, the command displays information about all ESs.
verbose: Displays detailed ES information. If you do not specify this keyword, the command displays brief ES information.
remote: Specifies remote ES information.
nexthop next-hop: Specifies a next hop. If you do not specify this option, the command displays ES information received from all next hops.
# Display brief information about local ESs of VSI vpna.
<Sysname> display evpn es local vsi vpna
Redundancy mode: A – All-active S – Single-active
VSI name : vpna
ESI Tag ID DF address Mode State
0001.0002.0002.0002.0002 - 1.1.1.1 A Up
0001.0002.0003.0004.0005 - 1.1.1.1 A Up
0003.0003.0003.0003.0003 2 2.2.2.2 A Up
# Display brief information about local ESs of all VSIs.
VSI name : v1
0003.0003.0003.0003.0003 1 1.1.1.1 A Up
0003.0003.0003.0003.0003 3 3.3.3.3 A Up
0003.0003.0003.0003.0003 10 2.2.2.2 A Up
VSI name : vpna
Table 16 Command output
Tag ID |
Ethernet tag ID. |
DF address |
Router ID of the VTEP elected as the DF. |
Mode |
Redundancy mode of the ES: · A—All-active mode. · S—Single-active mode. |
State |
State of the ES: · Up. · Down. |
# Display detailed information about local ESs of all VSIs.
<Sysname> display evpn es local verbose
VSI name : v1
ESI : 0003.0003.0003.0003.0003
Interface : Ten-GigabitEthernet1/0/1
Redundancy mode : All-active
State : Up
ACs :
Link ID Service instance ID Tag ID DF address
0 1 1 1.1.1.1
1 3 3 3.3.3.3
2 10 10 2.2.2.2
VSI name : vpna
ESI : 0001.0002.0002.0002.0002
Interface : Ten-GigabitEthernet1/0/2
State : Up
ACs :
1 - - 1.1.1.1
ESI : 0001.0002.0003.0004.0005
Interface : Ten-GigabitEthernet1/0/3
State : Up
ACs :
0 - - 1.1.1.1
Interface : Ten-GigabitEthernet1/0/4
State : Up
ACs :
2 2 2 2.2.2.2
Table 17 Command output
Redundancy mode |
Redundancy mode of the ES: · All-active. · Single-active. |
State |
State of the ES: · Up. · Down. If the ES is not manually assigned an ESI, a hyphen (-) is displayed. |
ACs |
The VSI's ACs on the ES. |
Link ID |
The AC's link ID on the VSI. |
Service instance ID |
Ethernet service instance ID. |
Tag ID |
Ethernet tag ID. |
DF address |
# Display information about remote ESs of all VSIs.
<Sysname> display evpn es remote
VSI name : v1
A-D per ES routes :
1.1.1.1
A-D per EVI routes :
Tag ID Peer IP
1 1.1.1.1
3 1.1.1.1
10 1.1.1.1
VSI name : vpna
ESI : 0001.0000.0000.0000.0001
Ethernet segment routes :
1.1.1.1
3.3.3.3
A-D per ES routes :
1.1.1.1
3.3.3.3
Tag ID Peer IP
- 1.1.1.1
- 3.3.3.3
1.1.1.1
A-D per ES routes :
1.1.1.1
Tag ID Peer IP
- 1.1.1.1
# Display remote ES information received from next hop 3.3.3.3 for VSI vpna.
<Sysname> display evpn es remote vsi vpna nexthop 3.3.3.3
VSI name : vpna
3.3.3.3
A-D per ES routes :
3.3.3.3
Tag ID Peer IP
- 3.3.3.3
Table 18 Command output
Redundancy mode |
Ethernet segment routes |
Ethernet segment routes for the ES. |
A-D per ES routes |
A-D per Ethernet segment routes for the ES. |
A-D per EVI routes |
A-D per EVI routes for the ES. |
Tag ID |
Ethernet tag ID. |
Peer IP |
IP address of the remote peer. |
Use display evpn ipv6 auto-discovery to display information about IPv6 peers that are automatically discovered through BGP.
display evpn ipv6 auto-discovery { imet [ peer ipv6-address ] [ vsi vsi-name ] | mac-ip | macip-prefix [ nexthop next-hop ] [ count ] }
imet: Specifies IPv6 peers discovered through IMET routes.
peer ipv6-address: Specifies a peer by its IPv6 address. If you do not specify this option, the command displays information about all automatically discovered IPv6 peers.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv6 peer information for all VSIs.
mac-ip: Specifies IPv6 peers discovered through MAC/IP advertisement routes that do not carry L3 VXLAN IDs.
macip-prefix: Specifies IPv6 peers discovered through MAC/IP advertisement routes that carry L3 VXLAN IDs or IP prefix advertisement routes that carry L3 VXLAN IDs.
nexthop next-hop: Specifies a next hop. If you do not specify this option, the command displays IPv6 peer information for all next hops.
count: Displays the number of IPv6 peers. If you do not specify this keyword, the command displays detailed IPv6 peer information.
# Display information about IPv6 peers discovered through IMET routes.
<Sysname> display evpn ipv6 auto-discovery imet
VSI name: vpna
RD : 1:10
PE address : 11::8
Tunnel address : 11::8
Tunnel mode : VXLAN
VXLAN ID : 10
RD : 2:100
PE address : 12::8
Tunnel address : 12::8
Tunnel mode : VXLAN
VXLAN ID : 10
Table 19 Command output
PE address |
Tunnel address |
Tunnel mode |
# Display information about IPv6 peers discovered through MAC/IP advertisement routes that do not carry L3 VXLAN IDs.
<Sysname> display evpn ipv6 auto-discovery mac-ip
VSI name: vpna
Destination IP : 6:6::6:8
Source IP : 1:1::1:7
VXLAN ID : 100
Tunnel mode : VXLAN
Tunnel name : Tunnel1
Table 20 Command output
Destination IP |
Source IP |
Tunnel mode |
# Display information about IPv6 peers discovered through MAC/IP advertisement routes that carry L3 VXLAN IDs or IP prefix advertisement routes that carry L3 VXLAN IDs.
<Sysname> display evpn ipv6 auto-discovery macip-prefix
L3VNI : 100
Tunnel mode : VXLAN
OutInterface : Vsi-interface3
# Display the total number of IPv6 peers discovered through MAC/IP advertisement routes that carry L3 VXLAN IDs or IP prefix advertisement routes that carry L3 VXLAN IDs.
<Sysname> display evpn ipv6 auto-discovery macip-prefix count
Total number of entries: 1
Table 21 Command output
Destination IP |
Source IP |
L3VNI |
Tunnel mode |
OutInterface |
display evpn ipv6 route mac
Use display evpn ipv6 route mac to display IPv6 EVPN MAC address entries.
display evpn ipv6 route mac [ local | remote ] [ vsi vsi-name ] [ count ]
local: Specifies local MAC address entries.
remote: Specifies remote MAC address entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays MAC address entries for all VSIs.
count: Displays the number of MAC address entries. If you do not specify this keyword, the command displays detailed information about MAC address entries.
If you do not specify the local or remote keyword, this command displays both local and remote IPv6 EVPN MAC address entries.
# Display all IPv6 EVPN MAC address entries.
<Sysname> display evpn ipv6 route mac
Flags: D - Dynamic B - BGP L - Local active
G - Gateway S - Static M - Mapping I - Invalid
VSI name: vpna
MAC address Link ID/Name Flags Nexthop
0000-0000-000a 1 DL -
0000-0000-0009 Tunnel1 B 1::2
0001-2000-4000 - BI 1::3
# Display the total number of IPv6 EVPN MAC address entries.
<Sysname> display evpn ipv6 route mac count
Total number of entries: 3
Table 22 Command output
Link ID/Name |
For a local MAC address, this field displays the AC's link ID on the VSI. For a remote MAC address, this field displays the tunnel interface name. |
Flags |
MAC address entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. · I—The entry is invalid. Possible reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. |
Nexthop |
IP address of the remote VTEP. If the MAC address entry is a local entry, a hyphen (-) is displayed. |
Use display evpn route arp to display EVPN ARP entries.
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ count ]
local: Specifies local ARP entries.
remote: Specifies remote ARP entries.
public-instance: Specifies the public instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
count: Displays the number of ARP entries. If you do not specify this keyword, the command displays detailed information about ARP entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ARP entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays EVPN ARP entries for the public instance and all VPN instances.
# Display all EVPN ARP entries.
<Sysname> display evpn route arp
VPN instance: vpn1 Interface: Vsi-interface1
IP address MAC address Router MAC VSI index Flags
10.1.1.1 0003-0003-0003 a0ce-7e40-0400 0 GL
10.1.1.11 0001-0001-0001 a0ce-7e40-0400 0 DL
10.1.1.12 0001-0001-0011 a0ce-7e41-0401 0 B
10.1.1.13 0001-0001-0021 a0ce-7e42-0402 0 B
10.1.1.101 0001-0011-0101 a0ce-7e40-0400 0 SL
10.1.1.102 0001-0011-0102 0011-9999-0000 0 BS
Public instance Interface: Vsi-interface2
11.1.1.1 0033-0033-0033 a0ce-7e40-0400 0 GL
11.1.1.11 0011-0011-0011 a0ce-7e40-0400 0 DL
# Display the total number of EVPN ARP entries.
<Sysname> display evpn route arp count
Total number of entries: 8
Table 23 Command output
VSI interface. |
Flags |
ARP entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. · I—The entry is invalid. Possible reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. |
Use display evpn route arp suppression to display EVPN ARP flood suppression entries.
display evpn route arp suppression [ local | remote ] [ vsi vsi-name ] [ count ]
local: Specifies local ARP flood suppression entries.
remote: Specifies remote ARP flood suppression entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ARP flood suppression entries for all VSIs.
count: Displays the number of ARP flood suppression entries. If you do not specify this keyword, the command displays detailed information about ARP flood suppression entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ARP flood suppression entries.
# Display all EVPN ARP flood suppression entries.
<Sysname> display evpn route arp suppression
VSI name: vpna
IP address MAC address Flags
10.1.1.12 0002-0002-0002 B
10.1.1.13 0002-0002-0002 BI
10.1.1.101 0001-0011-0101 BS
10.1.1.102 0001-0011-0102 DL
# Display the total number of ARP flood suppression entries.
<Sysname> display evpn route arp suppression count
Total number of entries: 4
Table 24 Command output
Flags |
ARP flood suppression entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. · I—The entry is invalid. Possible reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. |
Use display evpn route { igmp-js | igmp-ls | smet } to display EVPN multicast routes.
display evpn route { igmp-js | igmp-ls | smet } [ local | remote ] [ vsi vsi-name ] [ count ]
smet: Specifies SMET routes.
local: Specifies local multicast routes.
remote: Specifies remote multicast routes.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays multicast routes for all VSIs.
count: Displays the number of multicast routes. If you do not specify this keyword, the command displays detailed information about multicast routes.
If you do not specify the local or remote keyword, this command displays both local and remote multicast routes.
# Display all SMET routes.
<Sysname> display evpn route smet
VSI name: bbb
Source address : 192.164.1.1
Group address : 226.1.1.1
Local version : v3(I)
Peers :
Nexthop Tunnel name Link ID Remote version
1.1.1.1 Tunnel0 0x5000000 v3(E)
ACs :
AC Link ID Flags
XGE1/0/1 srv1 0 Sync
Table 25 Command output
Source address |
Multicast source IP address. |
Group address |
Multicast group IP address. |
Local version |
Local IGMP version. IGMPv3 includes the v3(I) and v3(E) subversions. |
Peers |
Remote peers in SMET routes. |
Nexthop |
Remote VTEP IP address. |
Tunnel name |
Remote tunnel interface name. |
Link ID |
Link ID of the VXLAN tunnel. |
Remote version |
Remote IGMP version. IGMPv3 includes the v3(I) and v3(E) subversions. |
ACs |
Local ACs. |
AC |
AC name. This field displays a Layer 3 interface name or a Layer 2 interface name and an Ethernet service instance name. |
Link ID |
The AC's link ID. |
Flags |
Flags: · Local—Local AC. · Sync—AC synchronized from another VTEP. |
# Display all local and remote IGMP join synch routes.
<Sysname> display evpn route igmp-js
VSI name: aaa
Group address : 227.1.1.1
Remote version : v3(I)
ESI : 0000.0002.0003.0004.0005
Ethernet tag ID : 20
AC : XGE1/0/1 srv2
Peers : 156.1.1.2, 156.1.1.3, 156.1.1.4
VSI name: bbb
Source address : 192.164.1.3
Group address : 227.1.1.2
Local version : v2
AC : XGE1/0/1 srv2
Table 26 Command output
Source address |
Group address |
Local version |
Remote version |
Remote VTEP IP addresses. |
# Display all local and remote IGMP leave synch routes.
<Sysname> display evpn route igmp-ls
VSI name: aaa
Group address : 228.1.1.1
Local version : -
ESI : 0000.0002.0003.0004.0003
AC : XGE1/0/1 srv3
Peers : 156.1.1.6, 156.1.1.3, 156.1.1.2
Table 27 Command output
Source address |
Group address |
Local version |
Remote version |
Peers |
# Display the total number of IGMP join synch routes.
<Sysname> display evpn route igmp-js count
display evpn route mac
Use display evpn route mac to display IPv4 EVPN MAC address entries.
display evpn route mac [ local | remote ] [ vsi vsi-name ] [ count ]
If you do not specify the local or remote keyword, this command displays both local and remote IPv4 EVPN MAC address entries.
# Display all IPv4 EVPN MAC address entries.
<Sysname> display evpn route mac
VSI name: bbb
MAC address Link ID/Name Flags Next hop
0000-0000-0009 Tunnel1 B 2.2.2.2
0001-2000-4000 - BI 3.3.3.3
# Display the total number of IPv4 EVPN MAC address entries.
<Sysname> display evpn route mac count
Table 28 Command output
Link ID/Name |
Flags |
Next hop |
display evpn route nd
Use display evpn route nd to display EVPN ND entries.
display evpn route nd [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ count ]
local: Specifies local ND entries.
remote: Specifies remote ND entries.
count: Displays the number of ND entries. If you do not specify this keyword, the command displays detailed information about ND entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ND entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays EVPN ND entries for the public instance and all VPN instances.
# Display all EVPN ND entries.
<Sysname> display evpn route nd
IPv6 address : AD80:0300:1000:0050:0200:0300:0100:0012
MAC address : 0001-0001-0001 Router MAC : a0ce-7e40-0400
VSI index : 0 Flags : GL
IPv6 address : AD10:0300:1000:0020:0200:0300:0100:0022
MAC address : 0001-0001-0002 Router MAC : a0ce-7e40-0411
Public instance Interface: Vsi-interface1
IPv6 address : BC80:0300:1000:0050:0200:0300:0100:0033
MAC address : 0002-0002-0001 Router MAC : a0ce-7e40-0422
IPv6 address : BC10:0300:1000:0020:0200:0300:0100:0034
MAC address : 0002-0002-0002 Router MAC : a0ce-7e40-0433
# Display the total number of EVPN ND entries.
<Sysname>display evpn route nd count
Table 29 Command output
VSI interface. |
Flags |
ND entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. |
display evpn route nd suppression
Use display evpn route nd suppression to display EVPN ND flood suppression entries.
display evpn route nd suppression [ local | remote ] [ vsi vsi-name ] [ count ]
local: Specifies local ND flood suppression entries.
remote: Specifies remote ND flood suppression entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ND flood suppression entries for all VSIs.
count: Displays the number of ND flood suppression entries. If you do not specify this keyword, the command displays detailed information about ND flood suppression entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ND flood suppression entries.
# Display all EVPN ND flood suppression entries.
<Sysname> display evpn route nd suppression
VSI name: vpna
IPv6 address MAC address Flags
11::8 72cb-ce9b-0a06 DL
11::9 0001-0001-0001 B
# Display the total number of ND flood suppression entries.
<Sysname> display evpn route nd suppression count
Table 30 Command output
Flags |
display evpn routing-table
Use display evpn routing-table to display the EVPN routing table for a VPN instance.
display evpn routing-table [ ipv6 ] { public-instance | vpn-instance vpn-instance-name } [ count ]
ipv6: Specifies IPv6 information. If you do not specify this keyword, the command displays IPv4 information.
count: Displays the number of entries in the routing table. If you do not specify this keyword, the command displays detailed information about the routing table.
# Display the EVPN IPv4 routing table for VPN instance vpn1.
<Sysname> display evpn routing-table vpn-instance vpn1
Flags: E - with valid ESI A – A-D ready L - Local ES exists
VPN instance name: vpn1 Local L3VNI: 7
IP address Nexthop Outgoing interface NibID Flags
10.1.1.11 1.1.1.1 Vsi-interface3 0x18000000 EAL
10.1.1.12 2.2.2.2 Vsi-interface3 0x18000001 EA
# Display the EVPN IPv4 routing table for the public instance.
<Sysname> display evpn routing-table public-instance
Public instance Local L3VNI: 3900
# Display the number of EVPN route entries in the IPv4 routing table for VPN instance vpn1.
<Sysname> display evpn routing-table vpn-instance vpn1 count
# Display the EVPN IPv6 routing table for VPN instance vpna.
<Sysname> display evpn routing-table ipv6 vpn-instance vpna
VPN instance: vpna Local L3VNI: 7
Next hop : 1.1.1.1
Outgoing interface : Vsi-interface3
NibID : 0x18000000
IPv6 address : BC10:0300:1000:0020:0200:0300:0100:0035
Next hop : 2.2.2.2
NibID : 0x18000001
Table 31 Command output
Local L3VNI |
L3 VXLAN ID associated with the VPN instance or the public instance. |
NibID |
Next hop ID. |
Flags |
Flags of the route: · E—The route carries a valid ESI. · A—All Ethernet auto-discovery routes are received. The ECMP routes for the next hop can be issued. · L—An active local ESI exists. Remote routes are not issued. · -—The MAC/IP advertisement route does not have a valid ESI. ECMP routes are not supported. |
display l2vpn forwarding evpn split-horizon
Use display l2vpn forwarding evpn split-horizon to display site-facing interfaces excluded from traffic forwarding by split horizon.
display l2vpn forwarding evpn split-horizon [ tunnel tunnel-number ] slot slot-number
tunnel tunnel-number: Specifies an existing VXLAN tunnel interface number. If you do not specify this option, the command displays all site-facing interfaces excluded from traffic forwarding by split horizon.
slot slot-number: Specifies an IRF member device by its member ID.
# Display site-facing interfaces excluded from traffic forwarding for Tunnel 0.
<Sysname> display l2vpn forwarding evpn split-horizon tunnel 0 slot 0
Tunnel name: 0
Total number of filtered interfaces: 2
Filtered interfaces:
XGE1/0/1
XGE1/0/2
Table 32 Command output
Tunnel name |
VXLAN tunnel interface name. |
Filtered interfaces |
Site-facing interfaces that do not forward the flood traffic received from the VXLAN tunnel. |
esi
Use esi to assign an ESI to an interface.
Use undo esi to restore the default.
esi esi-id
undo esi
No ESI is assigned to an interface.
Interface view
An ESI uniquely identifies an ES. The links on interfaces with the same ESI belong to the same ES. Traffic of the ES can be distributed among the links for load sharing.
You can assign ESIs to a main interface and its subinterfaces.
· If you assign an ESI to a subinterface, the subinterface-specific ESI takes precedence over that configured on the main interface.
· If you do not assign an ESI to a subinterface, it inherits the ESI of the main interface.
To modify the ESI of an interface, first use the undo esi command to delete the original ESI.
# Assign ESI 0000.0001.0002.0003.0004 to Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] esi 0000.0001.0002.0003.0004
evpn m-lag group
Use evpn m-lag group to specify the virtual VTEP address.
Use undo evpn m-lag group to restore the default.
evpn m-lag group virtual-vtep-ip
EVPN M-LAG is not configured.
virtual-vtep-ip: Specifies the virtual VTEP address.
EVPN M-LAG virtualizes two VTEPs or EVPN gateways into one M-LAG system to avoid single points of failure. The VTEPs or EVPN gateways use a virtual VTEP address to establish VXLAN tunnels to remote devices.
For the device to re-establish VXLAN tunnels, you must execute the address-family l2vpn evpn command in BGP instance view after you configure or remove the virtual VTEP address.
To modify the virtual VTEP address, you must first delete the original virtual VTEP address.
EVPN M-LAG is mutually exclusive with EVPN-DCI dual-homing. Do not use the evpn edge group and evpn m-lag group commands together.
# Specify the virtual VTEP address as 1.1.1.1.
[Sysname] evpn m-lag group 1.1.1.1
evpn edge group
evpn m-lag local
Use evpn m-lag local to specify the IP addresses of the VTEPs in an M-LAG system.
Use undo evpn m-lag local to restore the default.
evpn m-lag local local-ip remote remote-ip
The IP addresses of the VTEPs in an M-LAG system are not specified.
local local-ip: Specifies the IP address of the local VTEP.
remote remote-ip: Specifies the IP address of the peer VTEP.
An AC that is attached to only one of the VTEPs in an M-LAG system is called a single-armed AC. After you configure this command, each VTEP in an M-LAG system changes the next hop of the routes for single-armed ACs to its local VTEP IP address when advertising the routes. This ensures that the traffic of a single-armed AC is forwarded to its attached VTEP. When a VTEP receives BGP EVPN routes from the peer VTEP IP address specified by using this command, it does not set up a VXLAN tunnel to the peer VTEP.
You must execute this command if single-armed ACs are attached to an M-LAG system that uses an Ethernet aggregate link as the peer link. You do not need to execute this command on an M-LAG system that uses a VXLAN tunnel as the peer link. In such an M-LAG system, a VTEP uses the source IP address of the peer link as the next hop of routes for single-armed ACs to ensure correct traffic forwarding.
When you execute this command, make sure the IP address of the local VTEP belongs to a local interface. Make sure the local VTEP IP address and peer VTEP IP address are reversed on the VTEPs in an M-LAG system.
# Specify the IP addresses of the local and peer VTEPs in the M-LAG system as 2.2.2.2 and 3.3.3.3, respectively.
[Sysname] evpn m-lag local 2.2.2.2 remote 3.3.3.3
evpn edge group
Use evpn edge group to configure a virtual ED address.
Use undo evpn edge group to restore the default.
evpn edge group { group-ipv4 | group-ipv6 }
No virtual ED address is configured.
group-ipv4: Specifies the IPv4 virtual ED address.
group-ipv6: Specifies the IPv6 virtual ED address.
For high availability and load sharing, you can deploy two EDs at a data center. To virtualize the redundant EDs into one device, you must configure the same virtual ED address on them. The redundant EDs use the virtual ED address to establish tunnels with VTEPs and remote EDs.
Redundant EDs cannot provide access service for local VMs. They can act only as EDs. For correct communication, do not redistribute external routes on only one of the redundant EDs. However, you can redistribute the same external routes on both EDs.
On a redundant ED, the virtual ED address must be the IP address of a loopback interface, and it cannot be the BGP peer IP address of the ED.
EVPN-DCI dual-homing is mutually exclusive with EVPN M-LAG. Do not use the evpn edge group and evpn m-lag group commands together.
If you execute the undo bgp command to disable the BGP instance of the EVPN address family, the evpn edge group setting will also be deleted. Make sure you are fully aware of the impact of the undo bgp command when you use it on a live network.
# Configure 1.2.3.4 as the virtual ED address.
[Sysname] evpn edge group 1.2.3.4
evpn m-lag group
evpn encapsulation
Use evpn encapsulation to create an EVPN instance and enter its view, or enter the view of an existing EVPN instance.
Use undo evpn encapsulation to restore the default.
evpn encapsulation vxlan
No EVPN instance exists.
VSI view
vxlan: Specifies VXLAN encapsulation.
Before you can configure EVPN settings, you must create an EVPN instance.
# Create an EVPN instance and enter its view.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan]
evpn global-mac
Use evpn global-mac to configure the EVPN global MAC address.
Use undo evpn global-mac to restore the default.
evpn global-mac mac-address
No EVPN global MAC address is configured.
mac-address: Specifies a MAC address in H-H-H format. Do not specify a multicast MAC address, broadcast MAC address, or all-zeros MAC address.
The EVPN global MAC address is used only by VSI interfaces associated with an L3 VXLAN ID.
For a VSI interface associated with an L3 VXLAN ID, the MAC address assigned to it by using the mac-address command takes precedence over the EVPN global MAC address.
Do not use a reserved MAC address as the EVPN global MAC address.
# Configure the EVPN global MAC address as 0001-0001-0001.
[Sysname] evpn global-mac 1-1-1
evpn irb asymmetric
Use evpn irb asymmetric to enable asymmetric IRB for EVPN VXLAN.
Use undo evpn irb asymmetric to restore the default.
evpn irb asymmetric
Symmetric IRB is enabled for EVPN VXLAN.
Use this command to set the IRB mode for EVPN VXLAN.
# Enable asymmetric IRB for EVPN VXLAN.
[Sysname] evpn irb asymmetric
evpn multihoming advertise disable
Use evpn multihoming advertise disable to disable advertisement of EVPN multihoming routes and withdraw the EVPN multihoming routes that have been advertised to remote sites.
Use undo evpn multihoming advertise disable to restore the default.
The device advertises EVPN multihoming routes.
EVPN multihoming routes include Ethernet auto-discovery routes and Ethernet segment routes.
In a multihomed EVPN network, execute this command on a redundant VTEP before you reboot it. This operation allows other VTEPs to refresh their EVPN routing table to prevent traffic interruption caused by the reboot.
# Disable advertisement of EVPN multihoming routes and withdraw the EVPN multihoming routes that have been advertised to remote sites.
[Sysname] evpn multihoming advertise disable
evpn multihoming timer df-delay
Use evpn multihoming timer df-delay to set the DF election delay.
Use undo evpn multihoming timer df-delay to restore the default.
evpn multihoming timer df-delay delay-value
The DF election delay is 3 seconds.
delay-value: Specifies the DF election delay, in the range of 1 to 1200 seconds.
DF election delay defines the minimum interval allowed between two DF elections.
The DF election can be triggered by site-facing interface status changes, redundant VTEP membership changes, and interface ESI changes. To prevent frequent DF elections from degrading network performance, set the DF election delay.
To fast elect a DF and avoid traffic interruption upon DF failure, set the DF election delay to 0 seconds.
# Set the DF election delay to 5 seconds.
[Sysname] evpn multihoming timer df-delay 5
evpn route arp-mobility suppression
Use evpn route arp-mobility suppression to enable ARP mobility event suppression.
Use undo evpn route arp-mobility suppression to disable ARP mobility event suppression.
ARP mobility event suppression is disabled.
Misconfiguration of IP addresses might cause two sites attached to different distributed EVPN gateways to contain the same IP address. In this condition, the gateways constantly synchronize and update EVPN ARP entries and determine that ARP mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by ARP entry synchronization traffic. To eliminate loops and suppress those ARP mobility events, enable ARP mobility event suppression on distributed EVPN gateways. This feature allows an IP address to move at most four times between sites within 180 seconds. If an IP address moves more than four times within 180 seconds, distributed EVPN gateways suppress the excess ARP mobility events and do not advertise ARP information for the IP address.
# Enable ARP mobility event suppression.
[Sysname] evpn route arp-mobility suppression
evpn route gateway-mac unmovable
Use evpn route gateway-mac unmovable to set the MAC mobility extended community to unmovable in the MAC/IP advertisement routes used for advertising the MAC addresses of the centralized EVPN gateway interfaces.
Use undo evpn route gateway-mac unmovable to restore the default.
The MAC mobility extended community is set to movable in the MAC/IP advertisement routes used for advertising the MAC addresses of the centralized EVPN gateway interfaces.
If an endpoint uses a MAC address identical to that of a gateway interface on a centralized EVPN gateway, the VTEP attached to the endpoint will perform the following operations:
· Recognizes this event as a MAC address move.
· Creates a MAC address for the endpoint to overwrite the one for the gateway interface.
As a result, traffic forwarding errors occur.
To resolve this issue, execute the evpn route gateway-mac unmovable command on the centralized EVPN gateway. If an endpoint uses a MAC address identical to that of a centralized EVPN gateway interface, the VTEP attached to the endpoint will not create a MAC address for the endpoint.
# Set the MAC mobility extended community to unmovable in the MAC/IP advertisement routes used for advertising the MAC addresses of the centralized EVPN gateway interfaces.
[Sysname] evpn route gateway-mac unmovable
export route-policy
Use export route-policy to apply an export routing policy to EVPN on a VPN instance.
Use undo export route-policy to restore the default.
No export routing policy is applied to EVPN on a VPN instance.
VPN instance EVPN view
route-policy: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
You can specify an export routing policy to filter advertised routes or modify their route attributes for EVPN.
EVPN can use an export routing policy specified in VPN instance view or in VPN instance EVPN view. Export routing policy configuration in VPN instance EVPN view takes precedence over that in VPN instance view.
# Apply export routing policy poly-1 to EVPN on VPN instance vpn1.
[Sysname-vpn-instance-vpn1] address-family evpn
[Sysname-vpn-evpn-vpn1] export route-policy poly-1
route-policy (Layer 3—IP Routing Command Reference)
igp-metric inherit
Use igp-metric inherit to set the metric of a BGP EVPN route added to a VPN instance's routing table to the metric of the IGP route pointing to the next hop in the original BGP EVPN route.
Use undo igp-metric inherit to restore the default.
igp-metric inherit
The device sets the metric to 0 when adding BGP EVPN routes a VPN instance's routing table.
BGP EVPN address family view
After you execute this command, the device sets the metric of a BGP EVPN route added to a VPN instance's routing table to the metric of the IGP route pointing to the next hop in the original BGP EVPN route.
# Set the metric of a BGP EVPN route added to a VPN instance's routing table to the metric of the IGP route pointing to the next hop in the original BGP EVPN route.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn] igp-metric inherit
import evpn mac-ip
Use import evpn mac-ip to enable the device to redistribute received MAC/IP advertisement routes that contain ARP or ND information into a BGP unicast routing table.
Use undo import evpn mac-ip to disable the device from redistributing received MAC/IP advertisement routes that contain ARP or ND information into a BGP unicast routing table.
import evpn mac-ip
MAC/IP advertisement routes that contain ARP or ND information are not redistributed into any BGP unicast routing table.
BGP IPv4 unicast address family view
BGP IPv6 unicast address family view
BGP-VPN IPv4 unicast address family view
BGP-VPN IPv6 unicast address family view
This command enables the device to redistribute received MAC/IP advertisement routes that contain ARP or ND information into a BGP unicast routing table.
· If you use this command in BGP IPv4 or IPv6 unicast address family view, the device will redistribute the routes into the BGP IPv4 or IPv6 unicast routing table. In addition, the device will advertise the routes to the local site.
· If you use this command in BGP-VPN IPv4 or IPv6 unicast address family view, the device will redistribute the routes into the BGP-VPN IPv4 or IPv6 unicast routing table of the corresponding VPN instance. To advertise the routes to the local site, you must configure the advertise l2vpn evpn command.
# Redistribute received MAC/IP advertisement routes into the BGP-VPN IPv4 unicast routing table of VPN instance vpna.
[Sysname] bgp 100
[Sysname-bgp-default] ip vpn-instance vpna
[Sysname-bgp-default-vpna] address-family ipv4
[Sysname-bgp-default-ipv4-vpna] import evpn mac-ip
import route-policy
Use import route-policy to apply an import routing policy to EVPN on a VPN instance.
Use undo import route-policy to restore the default.
No import routing policy is applied to EVPN on a VPN instance. The VPN instance accepts a route when the export route targets of the route match local import route targets.
You can specify an import routing policy to filter received routes or modify their route attributes for EVPN.
EVPN can use an import routing policy specified in VPN instance view or in VPN instance EVPN view. Import routing policy configuration in VPN instance EVPN view takes precedence over that in VPN instance view.
# Apply import routing policy poly-1 to EVPN on VPN instance vpn1.
[Sysname-vpn-evpn-vpn1] import route-policy poly-1
ip forwarding-conversational-learning
Use ip forwarding-conversational-learning to enable conversational learning for host route FIB entries.
Use undo ip forwarding-conversational-learning to disable conversational learning for host route FIB entries.
ip forwarding-conversational-learning [ aging aging-time ]
Conversational learning is disabled for host route FIB entries.
aging aging-time: Specifies an aging timer in minutes for host route FIB entries, in the range of 60 to 1440. The default value is 60.
Use this command only on an EVPN network.
By default, the device issues a host route FIB entry to the hardware after the entry is generated. This feature enables the device to issue a host route FIB entry to the hardware only when the entry is required for packet forwarding. This feature saves hardware resources on the device.
Set an appropriate aging timer for host route FIB entries according to your network. A much longer or shorter aging timer will degrade the device performance.
· If the aging timer is too long, the device will save many outdated host route FIB entries and fail to accommodate the most recent network changes. These entries cannot be used for correct packet forwarding and exhaust FIB resources.
· If the aging timer is too short, the device will delete the valid host route FIB entries that can still be effective for packet forwarding. As a result, FIB entry flapping will occur, and the device performance will be affected.
# Enable conversational learning for host route FIB entries.
[Sysname] ip forwarding-conversational-learning
ip public-instance
Use ip public-instance to create the public instance and enter its view, or enter the view of the existing public instance.
Use undo ip public-instance to delete the public instance.
ip public-instance
The public instance does not exist.
A distributed EVPN gateway uses the public instance to perform Layer 3 forwarding for the public network and to enable communication between private and public networks. The public instance is similar to a VPN instance. A distributed EVPN gateway processes traffic of the public instance in the same way it does for a VPN instance.
# Create the public instance and enter its view.
[Sysname] ip public-instance
[Sysname-public-instance]
ip-prefix-route generate disable
Use ip-prefix-route generate disable to disable generation of IP prefix advertisement routes for the subnets of a VSI interface.
Use undo ip-prefix-route generate disable to enable generation of IP prefix advertisement routes for the subnets of a VSI interface.
The device only generates MAC/IP advertisement routes for a VSI interface that provides centralized VXLAN IP gateway service. The device generates IP prefix advertisement routes for the subnets of a VSI interface that provides distributed VXLAN IP gateway service.
VSI interface view
This command takes effect only on a VSI interface that provides distributed VXLAN IP gateway service (configured by using the distributed-gateway local command). It does not take effect on VSI interfaces that provide centralized VXLAN IP gateway service.
# Disable generation of IP prefix advertisement routes for the subnets of VSI-interface 1.
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] ip-prefix-route generate disable
ipv6 forwarding-conversational-learning
Use ipv6 forwarding-conversational-learning to enable conversational learning for IPv6 host route FIB entries.
Use undo ipv6 forwarding-conversational-learning to disable conversational learning for IPv6 host route FIB entries.
ipv6 forwarding-conversational-learning [ aging aging-time ]
Conversational learning is disabled for IPv6 host route FIB entries.
aging aging-time: Sets an aging timer in minutes for IPv6 host route FIB entries, in the range of 60 to 1440. The default value is 60.
By default, the device issues an IPv6 host route FIB entry to the hardware after the entry is generated. This feature enables the device to issue an IPv6 host route FIB entry to the hardware only when the entry is required for packet forwarding. This feature saves hardware resources on the device.
Set an appropriate aging timer for IPv6 host route FIB entries according to your network. A much longer or shorter aging timer will degrade the device performance.
· If the aging timer is too long, the device will save many outdated IPv6 host route FIB entries and fail to accommodate the most recent network changes. These entries cannot be used for correct packet forwarding and exhaust FIB resources.
· If the aging timer is too short, the device will delete the valid IPv6 host route FIB entries that can still be effective for packet forwarding. As a result, FIB entry flapping will occur, and the device performance will be affected.
# Enable conversational learning for IPv6 host route FIB entries and set the entry aging timer to 80 minutes.
[Sysname] ipv6 forwarding-conversational-learning aging 80
ipv6 nd ra tunnel-broadcast enable
Use ipv6 nd ra tunnel-broadcast enable to enable a VSI interface to send RA messages over VXLAN tunnels.
Use undo ipv6 nd ra tunnel-broadcast enable to disable a VSI interface from sending RA messages over VXLAN tunnels.
A VSI interface uses the global RA message tunneling configuration.
VSI interface view
By default, a distributed EVPN gateway drops the RS messages received from VXLAN tunnels and periodically advertises RA messages only to the local site. As a result, a distributed EVPN gateway does not send RA messages over VXLAN tunnels, and remote gateways cannot update information about the gateway based on RA messages. To resolve the issue, use this command to enable distributed EVPN gateways to reply to remote RS messages with RA messages and periodically advertise RA messages over VXLAN tunnels.
# Enable VSI-interface 100 to send RA messages over VXLAN tunnels.
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] ipv6 nd ra tunnel-broadcast enable
ipv6 nd ra interval
ipv6 nd ra tunnel-broadcast global enable
Use ipv6 nd ra tunnel-broadcast global enable to globally enable VSI interfaces to send RA messages over VXLAN tunnels.
Use undo ipv6 nd ra tunnel-broadcast global enable to globally disable VSI interfaces from sending RA messages over VXLAN tunnels.
VSI interfaces do not send RA messages over VXLAN tunnels.
You can configure RA message tunneling for VSI interfaces globally or on a per-VSI interface basis. The global configuration takes effect on all VSI interfaces. The interface-specific configuration takes precedence over the global configuration on a VSI interface.
# Globally enable VSI interfaces to send RA messages over VXLAN tunnels.
[Sysname] ipv6 nd ra tunnel-broadcast global enable
ipv6 nd ra interval
l2vpn m-lag peer-link tunnel
Use l2vpn m-lag peer-link tunnel to enable an M-LAG member device to automatically set up a VXLAN tunnel with the peer M-LAG member device.
Use undo l2vpn m-lag peer-link tunnel to disable an M-LAG member device from automatically setting up a VXLAN tunnel with the peer M-LAG member device.
l2vpn m-lag peer-link tunnel { source source-ipv4 destination destination-ipv4 | source source-ipv6 destination destination-ipv6 }
The M-LAG member devices in an M-LAG system do not set up a VXLAN tunnel between them.
source source-ipv4 destination destination-ipv4: Specifies source and destination IPv4 addresses for the automatically established VXLAN tunnel.
source source-ipv6 destination destination-ipv6: Specifies source and destination IPv6 addresses for the automatically established VXLAN tunnel.
This command applies to an M-LAG system that uses an Ethernet aggregate link as the peer link.
By default, the dynamic ACs created on the peer link use frame match criteria and VSI mappings identical to those of the site-facing ACs. If you configure the same frame match criterion for the site-facing ACs of different VSIs, the dynamic ACs created for the site-facing ACs will conflict with each other. To resolve this issue, use this command to enable the M-LAG member devices to automatically set up a VXLAN tunnel between them.
After you execute this command, the M-LAG member devices no longer create dynamic ACs on the IPL. Instead, they set up a VXLAN tunnel and assign it to all VXLANs. The VXLAN tunnel and the peer link transmit different types of traffic.
· The VXLAN tunnel is used to forward data traffic. When a site-facing AC on one M-LAG member device fails, the device forwards the remote packets destined for the AC to the other M-LAG member device over the VXLAN tunnel. The remote packets are encapsulated with the VXLAN ID of the failed site-facing AC. When the other M-LAG member device receives the packets, it decapsulates them and forwards them in the VXLAN where they belong.
· The peer link is used to exchange M-LAG protocol packets and synchronize MAC and ARP entries.
If you use this command on an M-LAG system that uses a VXLAN tunnel as the peer link, the M-LAG member devices do not assign the automatically established VXLAN tunnel to VXLANs and thus cannot use it to forward traffic.
To change the tunnel source and destination addresses, first execute the undo l2vpn m-lag peer-link tunnel command to delete the existing VXLAN tunnel.
# Enable the device to set up a VXLAN tunnel with its M-LAG peer. Specify the source and destination IPv4 addresses of the VXLAN tunnel as 1.1.1.1 and 2.2.2.2, respectively.
[Sysname] l2vpn m-lag peer-link tunnel source 1.1.1.1 destination 2.2.2.2
l3-vni
Use l3-vni to configure an L3 VXLAN ID for a VSI interface or for the public instance.
Use undo l3-vni to remove the L3 VXLAN ID for a VSI interface or for the public instance.
l3-vni vxlan-id
undo l3-vni
No L3 VXLAN ID is configured for a VSI interface or for the public instance.
VSI interface view
Public instance view
vxlan-id: Specifies a VXLAN ID. The value range for this argument is 0 to 16777215.
On distributed EVPN gateways, you must configure L3 VXLAN IDs for the gateways to differentiate traffic of different VPN instances.
To forward Layer 3 traffic of a VPN instance, you must assign an L3 VXLAN ID to the VSI interface of the VPN instance. To forward Layer 3 traffic of the public network, you must assign the same L3 VXLAN ID to the public instance and the VSI interface of the public instance.
To modify the L3 VXLAN ID for the public instance, you must first delete the original L3 VXLAN ID.
The L3 VXLAN ID specified by using this command cannot be the same as any VXLAN ID specified by using the mapping vni command.
# Configure the L3 VXLAN ID as 1000 for VSI-interface 100.
[Sysname-Vsi-interface100] l3-vni 1000
mac-address forwarding-conversational-learning
Use mac-address forwarding-conversational-learning to enable conversational learning for remote MAC address entries.
Use undo mac-address forwarding-conversational-learning to disable conversational learning for remote MAC address entries.
Conversational learning is disabled for remote MAC address entries.
By default, the device issues a remote MAC address entry to the hardware after the remote MAC address is advertised to the local site by BGP EVPN routes. This feature enables the device to issue a remote MAC address entry to the hardware only when the entry is required for packet forwarding. This feature saves hardware resources on the device.
With this feature enabled, the device generates a blackhole MAC address entry for an unknown MAC address if receiving 50 frames destined for that MAC address within the MAC aging time. Those blackhole MAC address entries age out when the MAC aging timer expires. After a blackhole MAC address entry ages out, the device can forward the traffic destined for the MAC address. For more information about the MAC aging time and blackhole MAC address entries, see MAC address table configuration in Layer 2—LAN Switching Configuration Guide.
# Enable conversational learning for remote MAC address entries.
[Sysname] mac-address forwarding-conversational-learning
mac-advertising disable
Use mac-advertising disable to disable MAC address advertisement and withdraw advertised MAC addresses.
Use undo mac-advertising disable to restore the default.
MAC address advertisement is enabled.
EVPN instance view
The MAC information and ARP information advertised by the VTEP overlap. To avoid duplication, use this command to disable MAC address advertisement and withdraw the MAC addresses advertised to remote VTEPs.
# Disable MAC address advertisement and withdraw advertised MAC addresses for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] mac-advertising disable
mapping vni
Use mapping vni to map a local VXLAN to a remote VXLAN.
Use undo mapping vni to restore the default.
mapping vni vxlan-id
undo mapping vni
A local VXLAN is not mapped to any remote VXLAN.
EVPN instance view
vxlan-id: Specifies a remote VXLAN ID. The value range for this argument is 0 to 16777215.
The VXLAN mapping feature provides Layer 2 connectivity for a tenant subnet that uses different VXLAN IDs in multiple data centers.
VXLAN mapping includes the following types:
· Non-intermediate VXLAN mapping—When two data centers use different VXLAN IDs for a subnet, map the local VXLAN to the remote VXLAN on the ED of one data center. For example, for VXLAN 10 of data center 1 to communicate with VXLAN 20 of data center 2, map VXLAN 10 to VXLAN 20 on the ED of data center 1.
· Intermediate VXLAN mapping—When multiple data centers use different VXLAN IDs for a subnet, map the VXLANs to an intermediate VXLAN on all EDs. For example, data center 1 uses VXLAN 10, data center 2 uses VXLAN 20, and data center 3 uses VXLAN 30. To provide connectivity for the VXLANs, map them to intermediate VXLAN 500 on EDs of the data centers. You must use intermediate VXLAN mapping if more than two data centers use different VXLAN IDs. The intermediate VXLAN can be used only for VXLAN mapping, and it cannot be used for common VXLAN services.
You must create mapped remote VXLANs on the device, create an EVPN instance for each remote VXLAN, and configure RD and route target settings for the EVPN instances.
The mapped remote VXLAN ID cannot be any L3 VXLAN ID specified by using the l3-vni command or the reserved VXLAN ID specified by using the reserved vxlan command.
# Map local VXLAN 100 to remote VXLAN 200.
[Sysname] vsi aaa
[Sysname-vsi-aaa] vxlan 100
[Sysname-vsi-aaa-vxlan-100] quit
[Sysname-vsi-aaa-evpn-vxlan] mapping vni 200
reserved vxlan (VXLAN Command Reference)
mapping-vni remove vpn-target
Use mapping-vni remove vpn-target to remove the route targets of VPN instances from BGP EVPN routes for mapped remote VXLANs.
Use undo mapping-vni remove vpn-target to restore the default.
The device does not remove the route targets of VPN instances from BGP EVPN routes for mapped remote VXLANs.
This command enables an EVPN-DCI ED to remove the route targets of the VPN instances with L3 VXLAN IDs associated from BGP EVPN routes when the ED performs VXLAN mapping. It prevents remote EDs from adding the BGP EVPN routes for mapped remote VXLANs to the routing tables of those VPN instances. If only Layer 2 connectivity is required between data centers, use this command on the EDs of the data centers to disable Layer 3 forwarding.
If the peer re-originated and mapping vni commands are used together on an ED, the ED advertises both original and reoriginated BGP EVPN routes that carry different VXLAN IDs. To avoid forwarding failure, use the mapping-vni remove vpn-target command to remove the route targets of VPN instances with L3 VXLAN IDs associated from the original BGP EVPN routes. This allows remote EDs to add only the reoriginated BGP EVPN routes to the routing tables of those VPN instances.
# Remove the route targets of VPN instances from BGP EVPN routes for mapped remote VXLANs.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] mapping-vni remove vpn-target
mapping vni
peer re-originated
nd mac-learning disable
Use nd mac-learning disable to disable an EVPN instance from learning MAC addresses from ND information.
Use undo nd mac-learning disable to restore the default.
An EVPN instance learns MAC addresses from ND information.
EVPN instance view
The MAC information and ND information advertised by a remote VTEP overlap. To avoid duplication, use this command to disable the learning of MAC addresses from ND information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
# Disable an EVPN instance from learning MAC addresses from ND information.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] nd mac-learning disable
nexthop evpn-m-lag group-address
Use nexthop evpn-m-lag group-address to enable the device to replace the next hop in advertised BGP EVPN routes with the virtual VTEP address.
Use nexthop evpn-m-lag group-address to restore the default.
undo nexthop evpn-m-lag group-address
When advertising BGP EVPN routes to an EBGP peer or peer group, the device replaces the next hop with the IP address of the source interface used to establish BGP sessions. When advertising EBGP routes to an IBGP peer or peer group, the device does not modify the next hop.
When you use M-LAG on EDs in an EVPN-DCI network, you must enable the EDs to replace the next hop in advertised BGP EVPN routes with the virtual VTEP address.
# Enable the device to replace the next hop in advertised BGP EVPN routes with the virtual VTEP address.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] nexthop evpn-m-lag group-address
peer advertise evpn-route suppress
Use peer advertise evpn-route suppress to suppress the advertisement of specific BGP EVPN routes to a peer or peer group.
Use undo peer advertise evpn-route suppress to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise evpn-route suppress { ip-prefix | mac-ip }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise evpn-route suppress { ip-prefix | mac-ip }
Advertisement of BGP EVPN routes is not suppressed.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must exist.
ipv4-address: Specifies a peer by its IPv4 address. The peer must exist.
mask-length: Specifies a mask length in the range of 0 to 32. To specify a subnet, you must specify both the ipv4-address and mask-length arguments.
ipv6-address: Specifies a peer by its IPv6 address. The peer must exist.
prefix-length: Specifies a prefix length in the range of 0 to 128. To specify a subnet, you must specify both the ipv6-address and prefix-length arguments.
ip-prefix: Suppresses IP prefix advertisement routes.
mac-ip: Suppresses MAC/IP advertisement routes.
To reduce the number of BGP EVPN routes on EDs of an EVPN-DCI network, suppress the advertisement of specific BGP EVPN routes on the EDs.
If two VSI interfaces on EVPN gateways of different data centers use the same IP address, do not suppress the advertisement of MAC/IP advertisement routes on the EDs of the data centers. If you suppress the advertisement of these routes, the EDs cannot communicate with each other.
# Suppress the IP prefix advertisement routes advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise evpn-route suppress ip-prefix
peer advertise original-route
Use peer advertise original-route to enable the device to advertise original BGP EVPN routes to a peer or peer group.
Use undo peer advertise original-route to disable the device from advertising original BGP EVPN routes to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise original-route
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise original-route
The device advertises only reoriginated BGP EVPN routes to peers and peer groups after the peer re-originated command is executed.
For this command to take effect on an ED, first execute the peer re-originated command.
In an EVPN-DCI network, an ED configured with the peer re-originated command advertises only reoriginated BGP EVPN routes. For the ED to advertise both original and reoriginated BGP EVPN routes to a peer or peer group, execute the peer advertise original-route command on the ED.
# Enable the device to advertise original BGP EVPN routes to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise original-route
peer re-originated
peer suppress re-originated
peer advertise vpn-reoriginate ibgp
Use peer advertise vpn-reoriginate ibgp to enable advertising the IP prefix advertisement routes reoriginated for a VPN instance to an IBGP peer or peer group.
Use undo peer advertise vpn-reoriginate ibgp to restore the default.
peer { group-name | ipv4-address [ mask-length ] } advertise vpn-reoriginate ibgp
undo { group-name | ipv4-address [ mask-length ] } peer advertise vpn-reoriginate ibgp
The device does not advertise the IP prefix advertisement routes reoriginated for a VPN instance to IBGP peers or peer groups.
For this command to take effect, you must also execute the advertise route-reoriginate command.
This command enables the device to advertise the IP prefix advertisement routes reoriginated for VPN instances to IBGP peers after the advertise route-reoriginate command is executed for the VPN instances.
# Enable advertising the IP prefix advertisement routes reoriginated for VPN instances to IBGP peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise vpn-reoriginate ibgp
peer default-gateway no-advertise
Use peer default-gateway no-advertise to remove the default-gateway extended community attribute from the EVPN gateway routes advertised to a peer or peer group.
Use undo peer default-gateway no-advertise to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-gateway no-advertise
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-gateway no-advertise
EVPN gateway routes advertised to peers and peer groups contain the default-gateway extended community attribute.
An EVPN gateway route is the route for the IP address of a VSI interface on an EVPN gateway. By default, the EVPN gateway routes advertised by an EVPN gateway contain the default-gateway extended community attribute. The EVPN gateway routes with that attribute cannot be used as ECMP routes. You can use this command to remove the default-gateway extended community attribute from EVPN gateway routes for the routes to be used for load sharing.
# Remove the default-gateway extended community attribute from the EVPN gateway routes advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 default-gateway no-advertise
peer next-hop-invariable
Use peer next-hop-invariable to configure the device to not change the next hop of routes advertised to an EBGP peer or peer group.
Use undo peer next-hop-invariable to configure the device to use its address as the next hop of routes advertised to an EBGP peer or peer group.
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } next-hop-invariable
The device uses its address as the next hop of routes advertised to EBGP peers or peer groups.
This command is exclusive with the peer next-hop-local command.
The next hop in BGP EVPN routes is the IP address of the originating VTEP. By default, the device replaces the next hop of IBGP routes with its address when advertising the routes to an EBGP peer. If the device is a transport network device, it will modify the next hop of BGP EVPN routes. For VTEPs to learn one another's IP address, you must configure the device to not change the next hop of routes advertised to EBGP peers.
# Configure the device to not change the next hop of routes advertised to EBGP peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 next-hop-invariable
peer next-hop-local (Layer 3—IP Routing Command Reference)
peer re-originated
Use peer re-originated to modify the information in received BGP EVPN routes.
Use undo peer re-originated to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ imet | ip-prefix | mac-ip ] [ replace-rt ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ imet | ip-prefix | mac-ip ]
The device does not modify the L3 VXLAN ID, RD, or route targets of the BGP EVPN routes that are received from peers or peer groups.
imet: Specifies IMET routes.
ip-prefix: Specifies IP prefix advertisement routes.
mac-ip: Specifies MAC/IP advertisement routes.
replace-rt: Replaces the L3 VXLAN ID, RD, and route targets of BGP EVPN routes with those of the matching local VPN instance. If you do not specify this keyword, only the L3 VXLAN ID and RD will be replaced.
In an EVPN-DCI network, use this command to hide the L3 VXLAN IDs of data centers or enable communication between data centers that use different L3 VXLAN IDs or route targets.
After you execute this command on an ED, the ED performs the following operations after receiving IP prefix advertisement routes:
1. Matches the route targets of the routes with the import route targets of local VPN instances.
2. Replaces the L3 VXLAN ID, RD, and route targets of the routes with those of the matching local VPN instance.
3. Advertises the routes to a VTEP or remote ED.
After you execute this command, an ED advertises only modified BGP EVPN routes. The original BGP EVPN routes are not advertised. To advertise the original BGP EVPN routes, use the peer advertise original-route command.
If the RD of a received BGP EVPN route is identical to the RD of the matching local VPN instance, an ED does not replace the L3 VXLAN ID and route targets of the route or regenerate the route. As a result, the ED does not advertise the route. As a best practice, assign unique RDs to VPN instances on different EVPN gateways and EDs if you use the peer re-originated command.
If you do not specify a route type, this command applies to IP prefix advertisement routes.
# Replace the L3 VXLAN ID and RD of IP prefix advertisement routes.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 re-originated
peer router-mac-local
Use peer router-mac-local to enable route router MAC replacement for a peer or peer group.
Use undo peer router-mac-local to cancel route router MAC replacement configuration for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } router-mac-local [ dci ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } router-mac-local [ dci ]
The device does not modify the router MAC address of routes before advertising the routes.
dci: Establishes VXLAN-DCI tunnels with the peer or peer group. If you do not specify this keyword, whether the device establishes VXLAN-DCI tunnels with the peer or peer group depends on the dci enable command configuration in interface view.
This command enables an ED to use its router MAC address to replace the router MAC address of routes received from and advertised to a peer or peer group in the local data center. The router MAC replacement process is as follows:
· For routes received from the peer or peer group, the ED performs router MAC replacement and advertises the routes to remote EDs.
· For routes received from a remote data center, the ED performs router MAC replacement and advertises the routes to the peer or peer group.
# In BGP EVPN address family view, enable route router MAC replacement for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 router-mac-local
Use peer suppress re-originated to suppress advertisement of reoriginated BGP EVPN routes to a peer or peer group.
Use undo peer suppress re-originated to disable suppression of reoriginated BGP EVPN route advertisement to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated { imet | ip-prefix | mac-ip }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated { imet | ip-prefix | mac-ip }
The device advertises reoriginated BGP EVPN routes to peers and peer groups after the peer re-originated command is executed.
An ED configured with the peer re-originated and peer advertise original-route commands advertises both original and reoriginated BGP EVPN routes. For the ED to advertise only original BGP EVPN routes to a peer or peer group, execute the peer suppress re-originated command on the ED.
# Suppress advertisement of reoriginated IP prefix advertisement routes to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 suppress re-originated ip-prefix
peer re-originated
policy vpn-target
Use policy vpn-target to enable route target filtering for BGP EVPN routes.
Use undo policy vpn-target to disable route target filtering for BGP EVPN routes.
policy vpn-target
Route target filtering is enabled for BGP EVPN routes.
When route target filtering is enabled for BGP EVPN routes, the EVPN routing table accepts only BGP EVPN routes of which the export route targets match the local import route targets. If the device must save all BGP EVPN routes, use the undo policy vpn-target command to disable route target filtering for BGP EVPN routes.
# Disable route target filtering for BGP EVPN routes.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] undo policy vpn-target
route-distinguisher (EVPN instance view)
Use route-distinguisher to configure an RD for an EVPN instance.
Use undo route-distinguisher to restore the default.
route-distinguisher { route-distinguisher | auto [ router-id ] }
No RD is configured for an EVPN instance.
EVPN instance view
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. The RD cannot be all zeros and can use one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number. For example, 65536:1. The AS number must be equal to or greater than 65536.
auto: Automatically generates an RD in the N:VXLAN ID format. The initial value of N is 1. If N:VXLAN ID is already in use, the system increases the value of N by 1 until the RD is available.
router-id: Automatically generates an RD based on the router ID in the Router ID:N format. The initial value of N is 1. If Router ID:N is already in use, the system increases the value of N by 1 until the RD is available. If you do not specify this keyword with the auto keyword, the system automatically generates an RD based on the VXLAN ID in the N:VXLAN ID format.
EVPN uses MP-BGP to advertise BGP EVPN routes for automatic VTEP discovery, MAC reachability information advertisement, and host route advertisement. MP-BGP uses the RD to differentiate BGP EVPN routes of different EVPN instances.
# Configure 22:1 as the RD of an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] route-distinguisher 22:1
route-distinguisher (public instance view)
Use route-distinguisher to configure an RD for the public instance.
No RD is configured for the public instance.
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. The RD can use one of the following formats:
To modify the RD of the public instance, first execute the undo route-distinguisher command to remove the original RD.
# Configure 22:1 as the RD of the public instance.
[Sysname-public-instance] route-distinguisher 22:1
rr-filter
Use rr-filter to create a route reflector (RR) reflection policy.
Use undo rr-filter to restore the default.
undo rr-filter
An RR does not filter reflected BGP EVPN routes.
ext-comm-list-number: Specifies an extended community attribute list by its number in the range of 1 to 199.
This command enables an RR to reflect only received BGP EVPN routes that match the attributes in the specified extended community attribute list.
If a cluster contains multiple RRs, you can configure different reflection policies on the RRs for load sharing among the RRs.
For more information about the extended community attribute list, see Layer 3—IP Routing Configuration Guide.
# Configure a reflection policy for the device to reflect BGP EVPN routes that match extended community attribute list 10.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] rr-filter 10
ip extcommunity-list (Layer 3—IP Routing Command Reference)
vpn-route cross multipath
Use vpn-route cross multipath to enable ECMP VPN route redistribution.
Use undo vpn-route cross multipath to disable ECMP VPN route redistribution.
ECMP VPN route redistribution is disabled. If multiple routes have the same prefix and RD, BGP only imports the optimal route into the EVPN routing table.
ECMP VPN route redistribution enables BGP to import all routes that have the same prefix and RD into the EVPN routing table.
# Enable ECMP VPN route redistribution.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] vpn-route cross multipath
vpn-target
Use vpn-target to configure route targets for EVPN.
Use undo vpn-target to delete route targets for EVPN.
In EVPN instance view:
vpn-target { vpn-target&<1-8> | auto } * [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { vpn-target&<1-8> | auto | all } [ both | export-extcommunity | import-extcommunity ]
VPN instance EVPN view, public instance view, public instance IPv4 address family view, public instance IPv6 address family view, or public instance EVPN view:
EVPN does not have route targets.
EVPN instance view
Public instance EVPN view
Public instance IPv4 address family view
Public instance IPv6 address family view
vpn-target&<1-8>: Specifies a space-separated list of up to eight route targets. Each route target is a string of 3 to 21 characters in one of the following formats:
auto: Automatically generates a route target in the format of BGP AS number:VXLAN ID.
both: Uses the specified route targets as both import and export targets. If you do not specify the both, export-extcommunity, or import-extcommunity keyword, the both keyword applies.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Specifies all route targets.
EVPN uses MP-BGP to advertise BGP EVPN routes for automatic VTEP discovery, MAC reachability information advertisement, and host route advertisement. MP-BGP uses route targets to control the advertisement and acceptance of BGP EVPN routes.
A VTEP sets the export targets for BGP EVPN routes before advertising the routes to remote VTEPs. The VTEP checks the export targets of BGP EVPN routes from remote VTEPs and imports only BGP EVPN routes of which the export targets match the local import targets.
If you execute this command multiple times, all configured route targets take effect.
# Configure import route targets 10:1, 100:1, and 1000:1 for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] vpn-target 10:1 100:1 1000:1 import-extcommunity
