- 03-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Bulk interface commands
- 03-Ethernet interface commands
- 04-Ethernet link aggregation commands
- 05-M-LAG commands
- 06-Port isolation commands
- 07-VLAN commands
- 08-MVRP commands
- 09-Loopback, null, and inloopback interface commands
- 10-VLAN mapping commands
- 11-Loop detection commands
- 12-Spanning tree commands
- 13-LLDP commands
- 14-Service loopback group commands
- 15-Layer 2 forwarding commands
06-Port isolation commands | 39.95 KB |
display port-isolate group
Use display port-isolate group to display port isolation group information.
# Display port isolation group information.
<Sysname> display port-isolate group
Port isolation group information:
Group ID: 1
Group members:
Ten-GigabitEthernet1/0/2
Group ID |
ID of the isolation group. |
Group members |
Isolated ports in the isolation group. No ports indicates that the isolation group does not contain isolated ports. |
port-isolate enable
port-isolate enable
Use port-isolate enable to assign a port to an isolation group.
Use undo port-isolate enable to remove a port from an isolation group.
port-isolate enable
The port is not assigned to an isolation group.
The configuration in Layer 2 Ethernet interface view applies only to the interface.
The configuration in Layer 2 aggregate interface view applies to the Layer 2 aggregate interface and its aggregation member ports. If the device fails to apply the configuration to the aggregate interface, it does not assign any aggregation member port to the isolation group. If the failure occurs on an aggregation member port, the device skips the port and continues to assign other aggregation member ports to the isolation group.
You cannot assign the member ports of a service loopback group to an isolation group, and vice versa.
This command assigns a port to the default isolation group (isolation group 1).
# Assign Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to the default isolation group.
[Sysname-Ten-GigabitEthernet1/0/1] port-isolate enable
[Sysname-Ten-GigabitEthernet1/0/2] port-isolate enable
# Assign Layer 2 aggregate interface Bridge-Aggregation 1 to the default isolation group.
[Sysname-Bridge-Aggregation1] quit
[Sysname-Ten-GigabitEthernet1/0/1] port link-aggregation group 1
[Sysname-Ten-GigabitEthernet1/0/2] port link-aggregation group 1
[Sysname-Ten-GigabitEthernet1/0/2] quit
[Sysname-Bridge-Aggregation1] port-isolate enable
