- 11-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-PTP configuration
- 05-SNMP configuration
- 06-RMON configuration
- 07-Event MIB configuration
- 08-NETCONF configuration
- 09-Ansible configuration
- 10-Puppet configuration
- 11-Chef configuration
- 12-CWMP configuration
- 13-EAA configuration
- 14-Process monitoring and maintenance configuration
- 15-Sampler configuration
- 16-Mirroring configuration
- 17-sFlow configuration
- 18-Information center configuration
- 19-GOLD configuration
- 20-Packet capture configuration
- 21-VCF fabric configuration
15-Sampler configuration | 55.21 KB |
Display and maintenance commands for a sampler
Samplers and IPv4 NetStream configuration examples
Example: Configuring samplers and IPv4 NetStream
About sampler
A sampler selects a packet from sequential packets and sends the packet to other service modules for processing. Sampling is useful when you want to limit the volume of traffic to be analyzed. The sampled data is statistically accurate and sampling decreases the impact on the forwarding capacity of the device.
The device supports random sampling mode.
Creating a sampler
1. Enter system view.
2. Create a sampler.
sampler sampler-name mode random packet-interval n-power rate
By default, no samplers exist.
Task |
Command |
Display configuration information about the sampler. |
display sampler [ sampler-name ] [ slot slot-number ] |
As shown in Figure 1, configure samplers and NetStream as follows:
· Configure IPv4 NetStream on the device to collect statistics on outgoing traffic.
· Send the NetStream data to port 5000 on the NetStream server.
· Configure random sampling in the outbound direction to select one packet randomly from 256 packets on Ten-GigabitEthernet 1/0/2.
Configuration procedure
IMPORTANT: By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface. |
# Create sampler 256 in random sampling mode, and set the sampling rate to 8. One packet from 256 packets is selected.
[Device] sampler 256 mode random packet-interval n-power 8
# Enable IPv4 NetStream to use sampler 256 to collect statistics about outgoing traffic on Ten-GigabitEthernet 1/0/2.
[Device] interface ten-gigabitethernet 1/0/2
[Device-Ten-GigabitEthernet1/0/2] ip netstream outbound
[Device-Ten-GigabitEthernet1/0/2] ip netstream outbound sampler 256
[Device-Ten-GigabitEthernet1/0/2] quit
# Configure the address and port number of the NetStream server as the destination for the NetStream data export. Use the default source interface for the NetStream data export.
[Device] ip netstream export host 12.110.2.2 5000
# Display configuration information for sampler 256.
[Device] display sampler 256
Sampler name: 256
Mode: Random; Packet-interval: 8; IsNpower: Y
