01-Hardware Information and Specifications | 2.79 MB |
1 Product models and technical specifications
Product models
H3C S9820-8C and S9820-8C-SAN switches are high-density intelligent 100G/400G switches developed for data centers, providing powerful hardware forwarding capacity and abundant data center features.
This document is applicable to the following switch models:
Product model |
Product code |
S9820-8C |
LS-9820-8C |
S9820-8C-SAN |
LS-9820-8C-SAN |
NOTE: · To obtain the purchase information, see the product data sheet at https://www.h3c.com/en/Products_and_Solutions/InterConnect/Switches/ and pay attention to the switch product lifecycle management announcement at https://www.h3c.com/en/Support/Policy_Dynamics/Management_Strategy/Products_End_of_Life_Announcement/Switches/. · For information about product and software compatibility, see the release notes. |
Technical specifications
Table1-1 Technical specifications
Item |
S9820-8C/S9820-8C-SAN |
Physical specifications |
Dimensions (H × W × D, without package) |
130.5 × 440 × 760 mm (5.14 × 17.32 × 29.92 in) |
Dimensions (H × W × D, with package) |
310 × 575 × 975 mm (12.20 × 22.64 × 38.39 in) |
Weight (fully configured with fan trays, power modules, and interface modules, excluding transceiver modules and cables) |
≤ 45 kg (99.21 lb) |
Technical specifications |
Processor |
· S9820-8C: 4 cores, 2.2 GHz · S9820-8C-SAN: 8 cores, 2.2 GHz |
DRAM memory |
8 GB |
NOR flash |
32 MB *2 (primary and backup) |
NAND flash |
8GB eMMC |
Interface types and quantity |
Console port |
· 1 × mini USB console port · 1 × serial console port |
Management Ethernet port |
· 1 × 10/100/1000BASE-T copper port · 1 × SFP port |
USB port |
1 |
IRF physical ports |
Not supported |
Fans, power modules, and interface modules |
Power module slot |
4 |
Interface module slot |
8 |
Fan tray slot |
5 |
Power module specifications |
Power input |
AC input and HVDC input |
Power specifications |
See "Power modules" |
Power consumption |
Typical power consumption (Fully configured with copper cables, at 50% load) |
· Configured with LSWM116H interface modules: 921 W · Configured with LSWM116HC interface modules: 1132 W · Configured with LSWM1M4CD interface modules: 820 W |
Maximum power consumption (Fully configured with transceiver modules, at 100% load) |
· Configured with LSWM116H interface modules: 1818 W · Configured with LSWM116HC interface modules: 2030 W · Configured with LSWM1M4CD interface modules: 1655 W |
Thermal consumption |
Typical thermal consumption |
· Configured with LSWM116H interface modules: 3143 BTU/hr · Configured with LSWM116HC interface modules: 3862 BTU/hr · Configured with LSWM1M4CD interface modules: 2798 BTU/hr |
Maximum thermal consumption |
· Configured with LSWM116H interface modules: 6203 BTU/hr · Configured with LSWM116HC interface modules: 6927 BTU/hr · Configured with LSWM1M4CD interface modules: 5647 BTU/hr |
Heat dissipation |
Heat dissipation method |
Air cooling |
Ventilation aisles |
Front-to-rear (from the port side to the power module side) |
Reliability and availability |
Power module redundancy |
2+1 or 2+2 redundancy |
Fan redundancy |
4+1 redundancy |
Hot swapping |
Power modules and fan trays support hot swapping Interface modules support hot swapping, but do not hot swap an interface module when the switch is starting up |
Mean time between failure (MTBF) (year) |
· S9820-8C: 38.8 · S9820-8C-SAN: 40.3 |
Mean time to repair (MTTR) (hour) |
· S9820-8C: 1 · S9820-8C-SAN: 0.5 |
Availability |
· S9820-8C: 99.999709% · S9820-8C-SAN: 99.999858% |
Environment specifications |
Sound pressure level at 27°C (80.6°F) |
65.6 dB(A) |
Altitude |
–60 m to +5000 m (–196.85 ft to +16404.20 ft) |
Operating temperature |
0°C to 45°C (32°F to 113°F) Note: The allowed maximum temperature decreases by 0.33 °C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 0 m (0 ft). If you use a QSFP-100G-ZR4-WDM1300 transceiver module, the operating temperature must be in the range of 0°C to 40°C (32°F to 104°F). |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Humidity |
5% RH to 95% RH, noncondensing |
Compliance |
Product compliance |
· Safety standards · EMC standards · Environmental and eco-friendly standards |
2 Chassis views
(1) Interface module 1 |
(2) Interface module 2 |
(3) Interface module 3 |
(4) Interface module 4 |
(5) Interface module 5 |
(6) Interface module 6 |
(7) Interface module 7 |
(8) Interface module 8 |
(1) Fiber management Ethernet port (numbered 1) |
(2) Grounding point |
(3) Copper management Ethernet port (numbered 0) |
(4) Serial console port |
(5) Mini USB console port |
(6) USB port |
(7) Serial label pull tab |
(8) Power module 1 |
(9) Power module 2 |
(10) Power module 3 |
(11) Power module 4 |
(12) Fan tray 5 |
(13) Fan tray 4 |
(14) Fan tray 3 |
(15) Fan tray 2 |
(16) Fan tray 1 |
(17) System status LED (SYS) |
(18) Copper management Ethernet port LED (LINK/ACT) |
(19) Fiber management Ethernet port LED (LINK/ACT) |
The ESN serial number and MAC address of the switch can be found on the serial label pull tab.
The switch came with power module slots PWR1 and PWR2 empty and power module slots PWR3 and PWR4 each installed with a filler panel. You can install two to four power modules for the switch as needed. In Figure2-2, PSR1600B-12A-B power modules are installed in the four power module slots.
The switch came with the five fan tray slots empty. You must install five fan trays of the same model for the switch. In Figure2-2, FAN-80B-1-B fan trays are installed in the five fan tray slots.
The switch came with the eight interface module slots each installed with a filler panel. You can install one to eight interface modules for the switch as needed. In Figure2-1, LSWM116H interface modules are installed in the eight interface module slots.
The switch supports shipping with fan trays and power modules installed. To purchase a switch preinstalled with fans trays and power modules, contact marketing staff.
3 FRUs
The switch uses modular design. Table3-1 describes the FRUs available for the switch.
Table3-1 FRUs available for the switch
FRUs |
Power modules |
PSR1600B-12A-B |
Yes |
Fan trays |
FAN-80B-1-B |
Yes |
Interface modules |
LSWM116H |
Yes |
LSWM116HC |
Yes, in Release 6635 and later versions |
LSWM1M4CD |
The switch can operate correctly with two power modules. You can install three power modules for 2+1 redundancy or four power modules for 2+2 redundancy.
To ensure heat dissipation, make sure all fan slots are installed with fan trays and install fan trays of the same model on the switch as a best practice.
Power modules
WARNING! When the switch has power modules in redundancy, you can replace a power module without powering off the switch. To avoid device damage and personal injury, make sure the power module is powered off before you replace it. |
The switch supports the PSR1600B-12A-B power module (1600 W AC power module).
Figure3-1 PSR1600B-12A-B power module
(1) Handle |
(2) AC power receptacle |
(3) Latch |
(4) Power module alarm LED |
For information about the power module alarm LED, see "Power module alarm LED."
Features
PSR1600B-12A-B is a power module with AC input and DC output. It can provide up to 1600 W of output. Table3-2 describes the features provided by the PSR1600B-12A-B power module.
Table3-2 Features provided by the PSR1600B-12A-B power module
Feature |
Protection function |
Protection for input overcurrent, input undervoltage, output overcurrent, output overvoltage, output shortcircuit, and overtemperature. |
Support for redundancy |
The power modules can work in N+1 or N+N redundant mode, and support load sharing. |
Support for hot swapping |
You can install or remove a power module when the switch is operating correctly. |
Table3-3 Technical specifications
Item |
Specification |
Dimensions (H × W × D) |
40.2 × 73.5 × 253.8 mm (1.58 × 2.89 × 9.99 in), including the handle |
Weight |
1.09 kg (2.40 lb) |
Rated AC input voltage range |
100 VAC to 240 VAC @ 50 or 60 Hz |
Max AC input voltage range |
90 VAC to 290 VAC @ 47 to 63 Hz |
Rated HVDC input voltage |
240 VDC |
Max HVDC input voltage range |
180 VDC to 320 VDC |
Rated input current |
10.5 A |
Rated output current |
131 A |
Rated output voltage |
12 V |
Rated output power |
1600 W |
Melting current of power module fuse |
10 A/ 250 V |
Fan trays
CAUTION: The switch has five fan tray slots. To ensure good ventilation of the switch, follow these guidelines to install and remove fan trays: · The switch comes with the fan tray slots empty. As a best practice to ensure adequate heat dissipation, install fan trays of the same model on the switch. Before powering on the switch, make sure the number of installed fan trays meets the minimum requirement. · Make sure all slots have a module or filler panel installed when the switch is operating. · If multiple fan trays fail on an operating switch, do not remove the fan trays at the same time. Replace the fan trays one after another and finish replacing each fan tray within 3 minutes. |
The switch supports the FAN-80B-1-B fan tray.
Figure3-2 FAN-80B-1-B fan tray
For information about the alarm LED, see "Fan tray alarm LED."
Features
The FAN-80B-1-B fan tray draws air from the port side to the power module side. The fan tray is small, hot swappable, and can automatically adjust the fan speed according to the device temperature.
Table3-4 FAN-80B-1-B fan tray specifications
Item |
Specification |
84 × 81 × 240 mm (3.31 × 3.19 × 9.45 in), including the handle |
Fans |
1 |
Weight |
0.9 kg (1.98 lb) |
Airflow direction |
Air exhausted from the fan tray faceplate |
Max fan speed |
12800 R.P.M |
Max airflow |
130 CFM (3.68 m3/min) |
Operating voltage |
12 V |
Max power consumption |
102 W |
Interface modules
The switch provides eight interface module slots. Table3-5 describes the interface modules available for the switch.
You can install an interface module in any interface module slot on the switch.
You can install or remove an interface module when the switch is operating correctly. Do not install or remove an interface module on a starting switch.
Table3-5 Available interface modules
Model |
Port type and number |
LSWM116H |
16-port QSFP28 Ethernet optical interface module |
16 × QSFP28 ports |
LSWM116HC |
16 × QSFP28 ports |
LSWM1M4CD |
4-port 400GBASE Ethernet optical interface module(QSFP-DD) |
4 × QSFP-DD ports |
LSWM116H
The LSWM116H interface module provides 16 QSFP28 ports.
Figure3-3 LSWM116H front panel
Ports and LEDs
For information about the QSFP28 port and modules and cables available for the port, see "QSFP28 port."
For information about the QSFP28 port LED, see "QSFP28 port LED."
Table3-6 Technical specifications
Item |
Specifications |
50 × 127.3 × 262.2 mm (1.97 × 5.01 × 10.32 in), including the connector but excluding the ejector lever |
Weight |
1.4 kg (3.09 lb) |
Power consumption (typical) |
52 W |
Power consumption (fully loaded) |
87 W |
LSWM116HC
The LSWM116HC interface module provides 16 QSFP28 ports.
Figure3-4 LSWM116HC front panel
Ports and LEDs
Table3-7 Technical specifications
Item |
Specifications |
Weight |
1.5 kg (3.31 lb) |
78 W |
113 W |
LSWM1M4CD
The LSWM1M4CD interface module provides 4 QSFP-DD ports.
Figure3-5 LSWM1M4CD front panel
Ports and LEDs
For information about the QSFP-DD port and modules and cables available for the port, see "QSFP-DD port."
For information about the QSFP-DD port LED, see "QSFP-DD port LED."
Table3-8 Technical specifications
Item |
Specifications |
Weight |
1.3 kg (2.87 lb) |
39 W |
87 W |
4 Ports
As a best practice, use H3C transceiver modules and cables for the switch. H3C transceiver modules and cables are subject to change over time. For the most up-to-date list of H3C transceiver modules and cables, contact H3C Support or marketing staff.
For information about the specifications of H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
The switch uses high-power ports in high density. Bringing up the ports simultaneously takes a comparatively long time. To reduce the time to bring up a port, the system does not turn off the laser transmitter on the transceiver module when shutting down the port.
Console port
The switch has a serial console port and a mini USB console port.
Table4-1 Console port specifications
Item |
Connector type |
RJ-45 |
USB mini-Type B |
Compliant standard |
EIA/TIA-232 |
USB 2.0 |
Operating mode |
Duplex Universal Asynchronous Receiver/Transmitter (duplex UART) |
Mini USB interface Universal Asynchronous Receiver/Transmitter (UART) |
Transmission baud rate |
9600 bps (default) to 115200 bps |
Services |
· Provides connection to an ASCII terminal. · Provides connection to the serial port of a local terminal (a PC for example) or remote terminal (through a pair of modems) running a terminal emulation program. |
· Provides connection to an ASCII terminal. · Provides connection to the USB port of a local terminal (a PC for example) running a terminal emulation program. |
A console port and a mini USB console port cannot be connected simultaneously. If both ports are connected, only the mini USB console port takes effect.
The switch has two management Ethernet ports: a copper management port and an SFP management port. You can connect the ports to a local PC for software loading and debugging or to a remote management station for remote management.
Table4-2 Management Ethernet port specifications
Item |
Specification |
Connector type |
· 10/100/1000BASE-T management port: RJ-45. · SFP management port: LC. |
· 10/100/1000BASE-T management port: IEEE802.3ab. · SFP management port: IEEE802.3z. |
Port transmission rate, duplex mode, and auto MDI/MDI-X |
· 10/100/1000BASE-T management port: ¡ 10/100 Mbps, half/full duplex, auto MDI/MDI-X. ¡ 1000 Mbps, full duplex, auto MDI/MDI-X. · SFP management port: 1000/100 Mbps, full duplex. |
Transmission medium and max transmission distance |
· 10/100/1000BASE-T management port: 100 m (328.08 ft) over category-5 UTP cable. · SFP management port: See FE SFP transceiver modules in Table4-3 and GE SFP transceiver modules in Table4-4. |
Functions and services |
Software upgrade and network management. |
Table4-3 FE SFP transceiver modules available for the SFP management port
FE SFP transceiver module |
Central wavelength (nm) |
Connector |
Fiber type and diameter (µm) |
Max transmission distance |
SFP-FE-SX-MM1310-A |
1310 |
LC |
Multi-mode, 50/125 |
2 km (1.24 miles) |
Multi-mode, 62.5/125 |
SFP-FE-LX-SM1310-A |
1310 |
LC |
Single-mode, 9/125 |
15 km (9.32 miles) |
Table4-4 GE SFP transceiver modules available for the SFP management port
GE SFP transceiver module |
Connector |
Cable/Fiber type and diameter (µm) |
Modal bandwidth (MHz × km) |
SFP-GE-T SFP-GE-T-D |
N/A |
RJ-45 |
Twisted pair cable |
N/A |
100 m (328.08 ft) |
SFP-GE-SX-MM850-A SFP-GE-SX-MM850-D |
850 |
LC |
500 |
550 m (1804.46 ft) |
400 |
500 m (1640.42 ft) |
200 |
275 m (902.23 ft) |
160 |
200 m (656.17 ft) |
SFP-GE-LX-SM1310-A |
1310 |
LC |
N/A |
10 km (6.21 miles) |
500 or 400 |
500 |
SFP-GE-LX-SM1310-D |
1310 |
LC |
N/A |
USB port
The switch has one OHCI-compliant USB 2.0 port that can upload and download data at a rate up to 480 Mbps. You can use this USB port to access the file system on the flash of the switch, for example, to upload or download application and configuration files.
The USB port supplies power as per USB 2.0 specifications. Use only USB 2.0-compliant USB devices for the USB port. The port might not identify USB devices that are not compliant with USB 2.0.
NOTE: USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices of all vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor. |
QSFP28 port
Table4-5 QSFP28 port specifications
Item |
Specification |
Interface name |
40 GE/100 GE QSFP28 Ethernet optical interface |
Product compatibility |
· LSWM116H interface module: 16 QSFP28 ports · LSWM116HC interface module: 16 QSFP28 ports |
Connector |
LC/MPO |
The 40 GE/100 GE QSFP28 Ethernet optical interfaces are mainly used for transmitting and receiving 40 GE/100 GE Ethernet optical interface services |
IEEE802.3ba |
Optical interface attribute |
Depends on transceiver modules and cables |
Operating mode |
Full duplex |
Transceiver modules and cables |
· 100G QSFP28 modules · 100G QSFP28 copper cables · 100G QSFP28 fiber cables (AOC) · 100G QSFP28 to 4*25G SFP28 copper cables · 40G QSFP+ modules · 40G QSFP+ copper cables · 40G QSFP+ fiber cables (AOC) · 40G QSFP+ to 4*10G SFP+ copper cables NOTE: For information about support for transceiver modules and cables of a QSFP28 port, see H3C S9820-64H & S9820-8C & S9820-8C-SAN Switch Series and Transceivers Compatibility Matrix. |
Support for interface splitting |
· LSWM116H: Interface splitting is not supported in the current software version. For the most recent support information, see the most up-to-date release notes (software feature changes). For more information, contact H3C Support or marketing staff. · LSWM116HC: Interface splitting is not supported. |
Other restrictions |
A 100G port on the device might fail to come up when a 100G DAC cable is used to connect the port to an Intel network card, for example, Intel (rainbow) Eth E810-CQDA2. As a best practice, use an AOC cable or transceiver module for connection to the Intel network card. |
QSFP-DD port
Table4-6 QSFP-DD port specifications
Item |
Specification |
Interface name |
400 GE QSFP-DD Ethernet optical interface |
LSWM1M4CD interface module: 4 QSFP-DD ports |
Connector |
LC/MPO |
The 400 GE QSFP-DD Ethernet optical interfaces are mainly used for transmitting and receiving 400 GE Ethernet optical interface services |
IEEE 802.3bs |
Operating mode |
Full duplex |
· 400G QSFP-DD modules · 400G QSFP-DD copper cables · 400G 1-to-2 cables (being developed) NOTE: For information about support for transceiver modules and cables of a QSFP-DD port, see H3C S9820-64H & S9820-8C & S9820-8C-SAN Switch Series and Transceivers Compatibility Matrix. |
Support for splitting |
A 400G QSFP-DD port can be split into two 200G ports. |
5 LEDs
System status LED
The system status LED shows the operating status of the switch.
Table5-1 System status LED description
LED mark |
Status |
SYS |
Steady green |
The switch is operating correctly. |
Flashing green |
The switch is performing power-on self-test (POST). |
Steady red |
The system has failed to pass POST or a fault has occurred. |
Flashing blue (3 Hz) |
Helps identifying the switch. To identify the switch location, execute the locator blink blink-time command. This LED will flash blue at 3 Hz. |
Off |
The switch is powered off or has failed to start up. |
QSFP28 port LED
Table5-2 QSFP28 port LED description
LED status |
Steady green |
A transceiver module or cable has been correctly installed in the port. The port has a link and is operating at 100 Gbps. |
Flashing green |
The port is sending or receiving data at 100 Gbps. |
Steady yellow |
A transceiver module or cable has been correctly installed in the port. The port has a link and is operating at 40 Gbps. |
Flashing yellow (3 Hz) |
The port is sending or receiving data at 40 Gbps. |
Off |
No transceiver module or cable has been installed in the port, or no link is present on the port. |
QSFP-DD port LED
Table5-3 QSFP-DD port LED description
LED status |
Steady green |
A transceiver module is installed in the port. The port is operating at its maximum speed of 400 Gbps, and a link is present on the port. |
Flashing green |
The port is sending or receiving data at its maximum speed of 400 Gbps. |
Steady yellow |
A transceiver module is installed in the port. The port is operating at a speed lower than the maximum speed. |
The port is sending or receiving data at a speed lower than the maximum speed. |
Off |
No transceiver module is installed in the port, or no link is present on the port. |
Management Ethernet port LEDs
The switch provides a LINK/ACT LED for each management Ethernet port to indicate their operating status.
Table5-4 Management Ethernet port LED description
LED mark |
Status |
LINK/ACT |
Off |
No link is present on the port. |
Steady green |
The port is operating at 1000 Mbps. |
Flashing green |
The port is receiving or sending data at 1000 Mbps. |
Steady yellow |
The port is operating at 100 Mbps. |
Flashing yellow |
The port is receiving or sending data at 100 Mbps. |
A PSR1600B-12A-B power module provides an alarm LED.
Table5-5 Description for the alarm LED on a PSR1600B-12A-B power module
Status |
Steady green |
The power module is operating correctly and in active state. |
Flashing green at 1 Hz |
The power module is operating correctly and in standby state. |
Flashing green at 2 Hz |
The power module software is being upgraded. |
Steady amber |
The power module is faulty or has entered self-protection mode. |
Flashing amber at 1 Hz |
An alarm has occurred on the power module when one of the following conditions exists on the power module but the power module does not enter protection state: · Output overvoltage. · Output undervoltage. · Output overcurrent. · Output power overload. · Overtemperature. |
Flashing amber at 2 Hz |
The power module does not have input power but the power modules working in parallel with it have input power. |
Off |
Neither this power module nor power modules working in parallel with it have input power. |
Fan tray alarm LED
A FAN-80B-1-B fan tray provides an alarm LED.
Table5-6 Description for the alarm LED on a FAN-80B-1-B fan tray
Status |
Steady green |
The fan tray is operating correctly. |
Steady red |
The fan tray is faulty. |
Off |
The fan tray is not installed securely or no power is present. |
6 Cooling system
CAUTION: The chassis and power modules use separate air aisles. Make sure the two aisles are not blocked when the switch is operating. |
The switch uses a highly efficient front-rear air aisle cooling system to ensure adequate heat dissipation and improve system reliability. Consider the ventilation design at the installation site when you plan the installation location for the switch.
Table6-1 Fan tray options for the switch
Available fan tray |
Airflow direction of the chassis |
FAN-80B-1-B |
From the port side to the power module side |
Figure6-1 Airflow from the port side to the power module side (with FAN-80B-1-B fan trays)
7 Cable routing recommendations
You can purchase one cable management frame for the switch and install it on the rack posts immediately above or below the switch as required. For more organized cabling, you can purchase two cable management frames so that the switch has a cable management frame installed both above and below it.
Route the signal cables along the left or right side of the cable management frame as required. Cable routing in Figure7-1 is for your reference.
