27-WLAN Command References(FAT AP)
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References(V7)-R6749-6W10027-WLAN Command References(FAT AP)
03-WLAN access commands
03-WLAN access commands 301.43 KB
WLAN access commands· 1
access-control acl 1
beacon ssid-advertise· 2
beacon ssid-hide· 2
client max-count 3
client smart-access enable· 3
client-mode access-retransmit 4
client-mode beacon-keepalive· 5
client-mode link-hold-rssi 6
client-mode min-record-rssi 6
client-mode probe-keepalive· 7
client-mode roam calibration-interval 8
client-mode roam scan-aging· 8
client-mode roam scan-interval 9
client-mode roam-enhance· 10
customlog format wlan· 11
description· 12
display interface wlan-radio· 12
display wlan ap all client-number 15
display wlan ap all radio client-number 15
display wlan blacklist 16
display wlan bss· 17
display wlan client 18
display wlan client ipv6· 24
display wlan client online-duration· 24
display wlan client status· 25
display wlan client-mode packet-statistics· 27
display wlan client-mode roam-enhance bss· 29
display wlan client-mode roaming-state· 30
display wlan service-template· 32
display wlan statistics client 37
display wlan statistics connect-history· 38
display wlan statistics service template· 39
display wlan whitelist 39
interface wlan-radio· 40
nas-id· 40
nas-port-type· 41
quick-association enable· 42
reset wlan client 42
reset wlan dynamic-blacklist 43
reset wlan statistics client 43
reset wlan statistics service-template· 44
service-template enable· 45
snmp-agent trap enable wlan client 45
snmp-agent trap enable wlan client-audit 46
ssid· 47
unknown-client 47
vip limit rate· 48
vlan· 49
wlan association optimization· 50
wlan broadcast-probe reply· 50
wlan client bss-load-ie enable· 51
wlan client idle-timeout 52
wlan client keep-alive· 52
wlan client keep-alive interval 53
wlan client reauthentication-period· 54
wlan dynamic-blacklist lifetime· 54
wlan link-test 55
wlan nas-port-id format 57
wlan service-template· 58
wlan static-blacklist mac-address· 58
wlan web-server api-path· 59
wlan web-server host 60
wlan web-server max-client-entry· 61
wlan whitelist mac-address· 61
For information about MSR routers that can function as fat APs, see "Compatibility of hardware and fat AP functionality."
The radio modes vary by device model. This chapter uses radio interface WLAN-Radio 0/0 as examples.
access-control acl
Use access-control acl to specify an ACL for ACL-based access control.
Use undo access-control acl to restore the default.
access-control acl acl-number
No ACL is specified.
Service template view
acl-number: Specifies the number of a Layer 2 ACL, in the range of 4000 to 4999.
This feature controls client access by using the specified ACL rules. When the device receives an association request, it performs the following actions:
·     Allows the client to access the WLAN if the MAC address of the client matches the MAC address attribute or MAC address OUI attribute in a rule and the rule action is permit. If multiple clients match the OUI attribute, all these clients are allowed to access the WLAN.
·     Denies the client's access to the WLAN if no match is found or the matched rule has a deny statement.
When you configure this feature, follow these restrictions and guidelines:
·     If the specified ACL contains a deny statement, configure a permit statement for the ACL to permit all clients. If you do not do so, no clients can come online.
·     ACL-based access control configuration takes precedence over whitelist and blacklist configuration.
·     You can specify only one ACL. If you execute this command multiple times, the most recent configuration takes effect.
# Create ACL 4000 and create ACL rules to permit the client with MAC address 000e-35b2-000e and clients with the specified OUI. Specify ACL 4000 for service template service1.
[Sysname] acl mac 4000
[Sysname-acl-mac-4000] rule 0 permit source-mac 000e-35b2-000e ffff-ffff-ffff
[Sysname-acl-mac-4000] rule 1 permit source-mac 000e-35b2-000f ffff-ff00-0000
[Sysname-acl-mac-4000] rule 2 deny
[Sysname-acl-mac-4000] quit
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] access-control acl 4000
Use beacon ssid-advertise to enable Service Set Identifier (SSID) broadcast in beacon frames.
Use undo beacon ssid-advertise to restore the default.
An AP hides SSIDs in beacon frames when the maximum number of associated clients is reached.
This feature enables new clients to discover APs even if the number of associated clients reaches the upper limit. However, these clients still cannot associate with the APs.
# Enable SSID broadcast in beacon frames.
[Sysname-wlan-st-s1] beacon ssid-advertise
client max-count
beacon ssid-hide
Use beacon ssid-hide to enable SSID hidden in beacon frames.
Use undo beacon ssid-hide to restore the default.
beacon ssid-hide
SSIDs are not hidden in beacon frames.
This command disables a radio from broadcasting SSIDs in the beacon frames and responding to probe requests after the specified service template is bound to the radio.
# Enable SSID hidden in beacon frames.
[Sysname-wlan-st-service1] beacon ssid-hide
client max-count
Use client max-count to set the maximum number of associated clients for a radio or a service template.
Use undo client max-count to restore the default.
client max-count max-number
The number of associated clients for a radio or a service template is not limited.
max-number: Specifies the maximum number of clients in the range of 1 to 512.
With this feature configured, new clients cannot access the WLAN and the SSID is hidden when the maximum number is reached.
# Set the maximum number of associated clients to 38 for service template service1.
[Sysname-wlan-st-service1] client max-count 38
beacon ssid-hide
Use client smart-access enable to enable smart client access.
Use undo client smart-access enable to restore the default.
Smart client access is disabled.
This feature enables H3C wireless clients to access the WLAN automatically when the AKM mode is set to PSK or when the radio is bound to an empty service template.
# Enable smart client access.
[Sysname-wlan-st-service1] client smart-access enable
Use client-mode access-retransmit to set the retransmission interval and maximum number of retransmission attempts for authentication and association requests.
Use undo client-mode access-retransmit to restore the default.
client-mode access-retransmit interval interval [ count count ]
The retransmission interval is 300 milliseconds and the AP does not retransmit authentication and association requests.
Radio interface view
interval: Specifies the retransmission interval in the range of 100 to 5000 milliseconds.
count: Specifies the maximum number of retransmission attempts, in the range of 1 to 10.
If the AP fails to receive any authentication or association response within the retransmission interval after the last retransmission, the AP tries to associate with another radio.
Make sure the client mode is enabled on the interface before you perform this task. Disabling the client mode removes the retransmission configuration.
# Set the retransmission interval to 500 ms and the maximum number of retransmission attempts to 3 for authentication and association requests.
[Sysname] interface wlan-radio 1/0/1
[Sysname-WLAN-Radio1/0/1] client-mode access-retransmit interval 500 count 3
client-mode enable
Use client-mode beacon-keepalive to enable beacon-based AP keepalive.
Use undo client-mode beacon-keepalive to disable beacon-based AP keepalive.
client-mode beacon-keepalive interval interval count count
Beacon-based AP keepalive is disabled.
interval: Specifies the keepalive interval, in the range of 100 to 8191 milliseconds.
count: Specifies the keepalive count in the range of 1 to 100.
This feature enables the AP to proactively connect to another radio if the AP fails to receive any beacon frame from the currently associated radio before the beacon keepalive timer expires.
The beacon keepalive time equals the keepalive interval multiplied by the keepalive count.
Make sure the client mode has been enabled on the interface before you perform this task. Disabling the client mode removes the keepalive configuration.
As a best practice, set the beacon-based AP keepalive interval to a value twice the beacon sending interval or higher.
# Enable beacon-based AP keepalive, set the keepalive interval to 100 milliseconds, and set the keepalive count to 5.
[Sysname-WLAN-Radio1/0/1] client-mode beacon-keepalive interval 100 count 5
client-mode enable
Use client-mode link-hold-rssi to set the link hold RSSI for the current link.
Use undo client-mode link-hold-rssi to restore the default.
client-mode link-hold-rssi rssi
The link hold RSSI for the current link is 0.
rssi: Specifies the link hold RSSI in the range of 0 to 100. Setting the interval to 0 disables the AP from proactively switching to another link because of low RSSI.
Perform this task to set the minimum RSSI for the current link to be retained. If the current link's RSSI drops below the link hold RSSI, the AP goes offline and then comes online from another radio.
# Set the link hold RSSI for the current link to 18.
[Sysname-WLAN-Radio1/0/1] client-mode link-hold-rssi 18
client-mode enable
Use client-mode min-record-rssi to set the minimum RSSI threshold for BSS recording.
Use undo client-mode min-record-rssi to restore the default.
The minimum RSSI threshold for BSS recording is 15.
rssi: Specifies the minimum RSSI threshold for BSS recording, in the range of 0 to 100.
Perform this task to set the minimum RSSI of a BSS that can be recorded. For a BSS that has been recorded, the AP determines that the BSS is not detected if the detected RSSI of the BSS does not reach the minimum threshold.
If roaming enhancement is disabled, you can set the threshold only on the radio enabled with the client mode. Disabling the client mode removes the threshold configuration.
If roaming enhancement is enabled, you can set the threshold only on the radio enabled with roaming enhancement. Disabling roaming enhancement removes the threshold configuration.
# Set the minimum RSSI threshold for BSS recording to 20.
[Sysname-WLAN-Radio1/0/1] client-mode min-record-rssi 20
client-mode enable
Use client-mode probe-keepalive to enable probe response-based AP keepalive.
Use undo client-mode probe-keepalive to disable probe response-based AP keepalive.
client-mode probe-keepalive [ interval interval retry retries ]
Probe response-based AP keepalive is enabled, the keepalive interval is 1000 milliseconds, and the maximum number of retransmission attempts is 5.
interval interval: Specifies the keepalive interval at which the AP sends probe requests, in the range of 100 to 60000 milliseconds. The default value is 1000.
retry retries: Specifies the maximum number of retransmission count, in the range of 1 to 100. The default value is 5.
This feature enables the AP to proactively connect to another radio if no probe response is received from the currently associated radio before the maximum number of probe request retransmission attempts is reached.
# Enable probe response-based AP keepalive, set the keepalive interval to 100 milliseconds, and set the maximum number of retransmission attempts to 5.
[Sysname-WLAN-Radio1/0/1] client-mode probe-keepalive interval 100 retry 5
client-mode enable
Use client-mode roam calibration-interval to set the roaming calibration interval.
Use undo client-mode roam calibration-interval to restore the default.
client-mode roam calibration-interval interval
The roaming calibration interval is 1000 milliseconds.
interval: Specifies the roaming calibration interval in the range of 1000 to 10000 milliseconds.
Perform this task to set the interval at which the AP triggers a roaming calibration. A short interval might result in frequent roaming, affecting network stability. A long interval might prevent the AP from switching to the optimal WLAN in time, affecting communication quality.
Make sure the client mode has been enabled on the interface before you perform this task. Disabling the client mode removes the interval configuration.
# Set the roaming calibration interval to 1000 milliseconds.
[Sysname-WLAN-Radio1/0/1] client-mode roam calibration-interval 1000
client-mode enable
Use client-mode roam scan-aging to set the scanning aging count for BSS entries.
Use undo client-mode roam scan-aging to restore the default.
client-mode roam scan-aging count
The scanning aging count for BSS entries is 5.
count: Specifies the aging count in the range of 1 to 10.
The AP generates an entry for each BSS detected through scanning. If the BSS cannot be detected again after the specified scanning intervals, the AP deletes the BSS entry. If the AP is associated with the deleted BSS, the AP goes offline from the BSS and then comes online from another BSS.
Make sure the client mode has been enabled on the interface before you perform this task. Disabling the client mode removes the aging count configuration.
# Set the scanning aging count for BSS entries to 5.
[Sysname-WLAN-Radio1/0/1] client-mode roam scan-aging 5
client-mode enable
Use client-mode roam scan-interval to set the roaming scanning interval.
Use undo client-mode roam scan-interval to restore the default.
client-mode roam scan-interval interval
The roaming scanning interval is 5000 milliseconds.
count: Specifies the scanning interval in the range of 100 to 10000 milliseconds.
Perform this task to set the interval at which the AP scans the network for beacon frames and probe responses. A short interval might result in frequent scanning, causing packet loss. A long interval might prevent the AP from discovering the optimal WLAN in time, affecting communication quality.
If roaming enhancement is disabled, you can set the interval only on the radio enabled with the client mode. Disabling the client mode removes the threshold configuration.
If roaming enhancement is enabled, you can set the interval only on the radio enabled with roaming enhancement. Disabling roaming enhancement removes the threshold configuration.
# Set the roaming scanning interval to 2000 milliseconds.
[Sysname] interface wlan-radio 1/0/2
[Sysname-WLAN-Radio1/0/2] client-mode roam scan-interval 2000
client-mode enable
Use client-mode roam-enhance to enable roaming enhancement on the fat AP.
Use undo client-mode roam-enhance to disable roaming enhancement on the fat AP.
client-mode roam-enhance { quick | slow }
Roaming enhancement is disabled on the fat AP.
quick: Specifies quick roaming. In this mode, the AP performs roaming when the RSSI gap between an optimal wireless service and the current wireless service exceeds the gap threshold.
slow: Specifies slow roaming. In this mode, the AP performs roaming when the following conditions are met:
·     The RSSI of the current wireless service is lower than the roaming RSSI threshold.
·     The RSSI gap between an optimal wireless service and the current wireless service has exceeded the gap threshold.
In an Automated Guided Vehicle (AGV) system, client-mode fat APs deployed on the vehicles provide wireless access to onboard devices not equipped with a wireless NIC. In this networking mode, each fat AP must scan the network for better links and transmit data at the same time, which might cause packet loss.
To resolve this issue, enable roaming enhancement on the fat AP to enable the 2.4G radio to scan the network and the 5G radio to transmit data.
·     Enable roaming enhancement on the 2.4G radio and enable client mode on the 5G radio. Make sure auto roaming has been disabled before you enable roaming enhancement.
·     Enable automatic channel selection on the 5G radio.
·     To ensure good performance, do not configure the 2.4G radio to provide wireless access services.
·     Enabling this feature triggers the fat AP to go offline and then come online again.
·     To use the client-mode disconnect command to disconnect the fat AP from the WLAN, you must first disable roaming enhancement on the AP.
# Enable roaming enhancement and set the roaming mode to quick.
[Sysname-WLAN-Radio1/0/2] client-mode roam-enhance quick
client-mode roam rssi-threshold
Use customlog format wlan to enable the device to generate client logs in the specified format.
Use undo customlog format wlan to restore the default.
customlog format wlan { normal | sangfor }
The device generates client logs only in H3C format.
normal: Specifies normal format.
sangfor: Specifies sangfor format.
By default, the device generates client logs only in H3C format that logs AP name, radio ID, client MAC address, SSID, BSSID, and client online status.
You can configure the device to generate client logs in one of the following formats:
·     Normal—Logs AP MAC address, AP name, client IP address, client MAC address, SSID, and BSSID.
·     Sangfor—Logs AP MAC address, client IP address, and client MAC address.
This feature does not affect the generation of client logs in H3C format.
# Enable the device to generate client logs in sangfor format.
[Sysname] customlog format wlan sangfor
description
Use description to configure a description for a service template.
No description is configured for a service template.
text: Specifies a description, a case-sensitive string of 1 to 64 characters.
# Configure a description for service template service1.
[Sysname-wlan-st-service1] description wlanst
Use display interface wlan-radio to display WLAN radio interface information.
display interface wlan-radio [ interface-number ] [ brief ]
interface-number: Specifies a WLAN radio interface by its number. If you do not specify this argument, the command displays information about all WLAN radio interfaces.
# Display detailed information about WLAN-Radio 0/0.
<Sysname> display interface wlan-radio 0/0
WLAN-Radio0/0
Current state: UP
Description: WLAN-Radio0/0 Interface
IP Packet Frame Type: PKTFMT_IEEE_802.11, Hardware Address: d461-fe59-4d20
current mode: 802.11ac, current channel: 36
Last link flapping: 0 hours 31 minutes 6 seconds
Current system time:2016-01-01 00:31:19
Last time when physical state changed to up:2016-01-01 00:00:13
Last time when physical state changed to down:2016-01-01 00:00:13
Input (total): 0 packets, 0 bytes
Input (normal): 0packets, 0bytes
                0 management, 0 control, 0 data
Input (error): 0 total, 0 CRC, 0 decrypt errors
               0 mic failures, 0 phy errors, 0 other errors
Output (normal): Q[0]:0, Q[1]:0, Q[2]:0, Q[3]:0 packets
                 Q[0]:0, Q[1]:0, Q[2]:0, Q[3]:0 bytes
Output (bcn&probe): 0 packets, 0 bytes
Output (error): 0 total, 0 discard, 0 buffer failures
                0 ack failures, 0 rts successed, 0 rts failures
Current state
Physical link state of the interface:
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface was shut down with the shutdown command. To bring up the interface, execute the undo shutdown command.
·     Stby—The interface is a backup interface.
This field displays PKTFMT_IEEE_802.11, which indicates that the frame is 802.11 encapsulated.
Hardware Address
Interface MAC address.
current mode
Current radio mode.
current channel
Current working channel.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Current system time
Current system time in the YYYY/MM/DD HH:MM:SS format. If a time zone is specified, this field displays the system time in the HH:MM:SS UTC±HH:MM:SS format.
Last time when the physical link state of the interface changed to up. This field displays - if the physical link state has never been changed.
Last time when the physical link state of the interface changed to down. This field displays - if the physical link state has never been changed.
Input(total): 0 packets, 0 bytes
Inbound packet statistics (in packets and bytes) for the interface. All inbound normal packets and abnormal packets were counted.
Input (normal): 0packets, 0bytes 0 management, 0 control, 0 data
Inbound normal packet statistics (in packets and bytes) for the interface. All normal inbound management, control, and data packets were counted.
Input (error)
Inbound error packet statistics for the interface.
Outbound packet statistics (in packets and bytes) for the interface. All outbound normal packets and abnormal packets were counted.
Output (normal): Q[0]:0, Q[1]:0, Q[2]:0, Q[3]:0 packets Q[0]:0, Q[1]:0, Q[2]:0, Q[3]:0 bytes 0 management, 0 control, 0 data
Outbound normal packet statistics (in packets and bytes) for the interface. All normal outbound management, control, and data packets were counted.
Q[n] represents an AC queue, where n represents the queue ID.
Output (bcn&probe)
Outbound beacon and probe frame statistics (in packets and bytes) for the interface.
Output (error)
Outbound error packet statistics for the interface.
# Display brief information about WLAN-Radio 0/0.
<Sysname> display interface wlan-radio 0/0 brief
Speed: (a) - auto
Interface            Link Speed     Duplex Type PVID Description
WLAN-Radio0/0        UP   --        --     --   --
Brief information about Layer 2 interfaces.
Link
·     ADM—The interface was shut down with the shutdown command. To restore the physical state of the interface, execute the undo shutdown command.
·     Stby—The interface is a backup interface. To display the primary interface, use the display interface-backup state command.
Speed
Speed of the interface, in Mbps.
This field displays the (a) flag next to the speed if the speed is automatically negotiated.
This field displays -- for WLAN radio interfaces.
Duplex
Duplex mode of the interface:
·     (a)/A—Autonegotiation.
·     H—Half duplex.
·     F—Full duplex.
Link type of the interface:
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
PVID
Use display wlan ap all client-number to display the number of online clients at the 2.4 GHz band and the 5 GHz band.
# Display the number of online clients at both the 2.4 GHz and 5 GHz bands.
<System> display wlan ap all client-number
AP name           Clients           2.4GHz            5GHz
fatap             2                 2                 0
Clients
Total number of online clients.
2.4GHz
Number of online clients at the 2.4 GHz band.
5GHz
Number of online clients at the 5 GHz band.
Use display wlan ap all radio client-number to display the number of online clients and channel information for each radio.
# Display the number of online clients and channel information for each radio.
<Sysname> display wlan ap all radio client-number
AP name                    RID     Channel     Clients
fatap                      1       44          12
fatap                      2       11          4
Use display wlan blacklist to display blacklist entries.
display wlan blacklist { dynamic | static }
dynamic: Specifies the dynamic blacklist.
static: Specifies the static blacklist.
# Display static blacklist entries.
<Sysname> display wlan blacklist static
Total number of clients: 3
 MAC addresses:
  000e-35b2-000e
  0019-5b8e-b709
  001c-f0bf-9c92
# Display dynamic blacklist entries.
<Sysname> display wlan blacklist dynamic
MAC address     APID   RID    Lifetime (s)  Duration (hh:mm:ss)
000f-e2cc-0001  1      1      300           00:02:11
000f-e2cc-0002  2      1      300           00:01:17
000f-e2cc-0003  3      1      300           00:02:08
MAC address
Client MAC address.
APID
ID of the AP that detects the rogue client.
RID
ID of the radio that detects the rogue client.
Lifetime (s)
Lifetime of the entry in seconds.
Duration (hh:mm:ss)
Duration for the entry since the entry was added to the dynamic blacklist.
display wlan bss
Use display wlan bss to display basic service set (BSS) information.
display wlan bss { all | bssid bssid } [ verbose ]
all: Displays all BSSs.
bssid bssid: Specifies a BSS by its ID. The value is a 48-bit hexadecimal number in the format of H-H-H.
verbose: Displays detailed client information. If you do not specify this keyword, the command displays brief client information.
# Display brief information about all BSSs.
<Sysname> display wlan bss all
Total number of BSSs: 4
AP name                   RID  SSID                            BSSID
fatap                     1    SSID1                           001c-f08f-f804
fatap                     2    SSID1                           001c-f08f-f806
# Display detailed information about the BSS with ID 001c-f08f-f804.
<Sysname> display wlan bss bssid 001c-f08f-f804 verbose
AP name                       : fatap
BSSID                         : 001c-f08f-f804
Radio ID                      : 1
Service template name         : servcie1
SSID                          : SSID1
VLAN ID                       : 1
AKM mode                      : Not configured
User authentication mode      : Bypass
Table 5 Command output
AKM mode
AKM mode:
·     802.1X.
·     PSK.
·     Not configured.
User authentication mode:
·     Bypass—No client authentication.
·     MAC.
·     802.1X.
·     OUI.
display wlan client
Use display wlan client to display client information.
display wlan client [ interface wlan-radio interface-number | mac-address mac-address | service-template service-template-name | vlan vlan-id ] [ verbose ]
interface wlan-radio interface-number: Displays information about clients that are connected to the specified radio interface.
mac-address mac-address: Specifies a client by its MAC address.
service-template service-template-name: Displays information about clients that are associated with the specified service template. The service template name is a case-insensitive string of 1 to 63 characters.
vlan vlan-id: Displays information about clients in the specified VLAN. The VLAN ID is in the range of 1 to 4094.
# Display brief information about all clients.
<Sysname> display wlan client
MAC address    Username             R IP address      VLAN
000f-e265-6400 N/A                  1 1.1.1.1         100
000f-e265-6401 user                 1 3.0.0.3         200
84db-ac14-dd08 N/A                  1 5.5.5.3         1
Table 6 Command output
MAC address
Client MAC address.
Username
Client username:
·     The field displays the client username if the client uses 802.1X or MAC authentication.
·     The field displays N/A if the client does not use 802.1X or MAC authentication.
If the client uses portal authentication, this field does not display the portal username of the client.
AP name
Name of the AP that the client is associated with.
R
ID of the radio that the client is associated with.
IP address
IPv4 address of the client.
VLAN ID
ID of the VLAN to which the client belongs.
# Display detailed information about the client with MAC address 000f-e265-6400.
<Sysname> display wlan client mac-address 000f-e265-6400 verbose
Total number of clients: 1
MAC address                        : 000f-e265-6400
IPv4 address                       : 10.1.1.114
IPv6 address                       : 2001::1234:5678:0102:0304
Username                           : N/A
AID                                : 1
Radio ID                           : 1
Channel                            : 36
SSID                               : office
BSSID                              : 0026-3e08-1150
VLAN ID                            : 3
Sleep count                        : 3
Wireless mode                      : 802.11gn
Channel bandwidth                  : 20MHz
SM power save                      : Enabled
Short GI for 20MHz                 : Supported
Short GI for 40MHz                 : Supported
Short GI for 80MHz                 : Supported
Short GI for 160/80+80MHz          : Not supported
STBC RX capability                 : Not supported
STBC TX capability                 : Not supported
LDPC RX capability                 : Not supported
SU beamformee capability           : Not supported
MU beamformee capability           : Not supported
Beamformee STS capability          : N/A
Block Ack                          : TID 0 In
Supported VHT-MCS set              : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
                                     NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
Supported HT MCS set               : 0, 1, 2, 3, 4, 5, 6, 7,
                                     8, 9, 10, 11, 12, 13, 14,
                                     15
Supported rates                    : 1, 2, 5.5, 6, 9, 11,
                                     12, 18, 24, 36, 48, 54 Mbps
QoS mode                           : WMM
Listen interval                    : 10
RSSI                               : 62
Rx/Tx rate                         : 130/195 Mbps
Speed                              : N/A
Authentication method              : Open system
Security mode                      : PRE-RSNA
Cipher suite                       : N/A
WPA3 status                        : Disabled
Authorization ACL ID               : 3001(Not effective)
Authorization user profile         : N/A
Authorization CAR                  :
  Average input rate               : 102400 bps
  Average output rate              : 102400 bps
Roam status                        : N/A
Key derivation                     : SHA1
PMF status                         : Enabled
Forwarding policy name             : Not configured
Online time                        : 0days 0hours 1minutes 13seconds
FT status                          : Inactive
Table 7 Command output
MAC address
Client MAC address.
IPv4 address
Client IPv4 address.
IPv6 address
Client IPv6 address.
Username
Client username:
AID
Association ID.
Radio ID
Channel
Channel with which the client is associated.
SSID
SSID with which the client is associated.
VLAN ID
Sleep count
Client sleep times.
Wireless mode
Wireless mode:
·     802.11a.
·     802.11b.
·     802.11g.
·     802.11gn.
·     802.11an.
·     802.11ac.
·     802.11gac.
Channel bandwidth
Channel bandwidth:
·     20 MHz.
·     40 MHz.
·     80 MHz.
·     160 MHz.
20/40 BSS Coexistence Management
Whether the client supports 20/40MHz channel bandwidth coexistence.
SM Power Save
SM Power Save status:
·     Enabled—Only one antenna of a client operates in active state, and others operate in sleep state to save power.
·     Disabled.
Short GI for 20MHz
Whether the client supports short GI when its channel bandwidth is 20 MHz:
·     Supported.
·     Not supported.
Short GI for 40MHz
Whether the client supports short GI when its channel bandwidth is 40 MHz:
·     Supported.
·     Not supported.
Short GI for 80MHz
Whether the client supports short GI when its channel bandwidth is 80 MHz:
·     Supported.
·     Not supported.
Whether the client supports short GI when its channel bandwidth is 160 MHz or 80 + 80 MHz:
·     Supported.
·     Not supported.
STBC Rx Capability
Client STBC receive capability;
·     Not supported.
·     Supported.
STBC Tx Capability
Client STBC transmission capability:
·     Not supported.
·     Supported.
LDPC Rx capability
Client LDPC receive capability;
·     Not supported.
·     Supported.
Client SU beamformee capability:
·     Not supported.
·     Supported.
Client MU beamformee capability:
·     Not supported.
·     Supported.
Supported spatial stream quantity if the client is a beamformee receiver, in the range of 0 to 7 (the maximum spatial stream quantity specified by the MIMO mode minus one). This field displays N/A if the client cannot act as a beamformee receiver.
Number of Sounding Dimensions
Supported spatial stream quantity if the client is a beamformee transmitter, in the range of 0 to 7 (the maximum spatial stream quantity specified by the MIMO mode minus one). This field displays N/A if the client cannot act as a beamformee transmitter.
Block Ack
Negotiation result of Block ACK with TID:
·     TID 0 In—Sends Block ACK for inbound traffic.
·     TID 0 Out—Sends Block ACK for outbound traffic.
·     TID 0 Both—Sends Block ACK for both inbound and outbound traffic.
·     N/A—Does not send Block ACK for both inbound and outbound traffic.
VHT-MCS supported by the client.
QoS mode
QoS mode:
·     N/A—WMM is not supported.
·     WMM—WMM is supported.
WMM information negotiation is carried out between an AP and a client that both support WMM.
Listen interval
Interval at which the client wakes up to listen for beacon frames. It is counted by beacon interval.
RSSI
Received signal strength indication. This value indicates the client signal strength detected by the AP.
Rx/Tx rate
Sending and receiving rates of data, management, and control frames.
Speed
Sending and receiving rates in the past 2 minutes in Kbps, rounded to three decimal places.
This field displays N/A if both the sending and receiving rates are 0.
Authentication method:
·     Open system.
·     Shared key.
·     SAE.
Security mode
Security mode:
·     RSN—Beacons and probe responses carry RSN IE.
·     WPA—Beacons and probe responses carry WPA IE.
·     PRE-RSNA—Beacons and probe responses do not carry RSN IE or WPA IE.
AKM mode
AKM mode:
·     802.1X.
·     PSK.
·     OWE.
·     Not configured.
Cipher suite
Cipher suite:
·     N/A.
·     WEP40.
·     WEP104.
·     WEP128.
·     CCMP.
·     TKIP.
·     MAC.
·     802.1X.
·     OUI.
WPA3 status
WPA3 status:
·     Disabled.
·     Enabled.
·     N/A.
Authorized ACL number:
·     This field displays the ACL number if the authorized ACL takes effect.
·     This field displays ACL number(Not effective) if the authorized ACL does not take effect.
·     This field displays N/A if the authentication server is configured without any authorized ACL.
Name of the authorized user profile:
·     This field displays the authorized user profile name if the authorized user profile takes effect.
·     This field displays authorized user profile name + Not effective if the authorized user profile does not take effect.
·     This field displays N/A if the authentication server is configured without any authorized user profile.
Authorization CAR
Authorization CAR:
·     Average input rate—Average uplink rate in bps.
·     Average output rate—Average downlink rate in bps.
·     N/A—This field displays N/A if the authentication server is not configured with authorization CAR for users.
Roam status
Roam status:
·     Roaming in progress.
·     Inter-AC roam.
·     Inter-MA roam.
·     Intra-AC roam.
·     Intra-MA roam.
·     This field displays N/A if the client stays in one BSS after coming online.
Key derivation
Key derivation type:
·     SHA1—Uses the HMAC-SHA1 hash algorithm.
·     SHA256—Uses the HMAC-SHA256 hash algorithm.
·     N/A—No key derivation algorithm is involved for the authentication type.
PMF status
PMF status:
·     Enabled—Management frame protection is enabled.
·     Disabled—Management frame protection is disabled.
·     N/A—Management frame protection is not involved.
WLAN forwarding policy name:
·     Not configured.
·     Policy-name.
Online time
Client online duration.
FT status
Fast BSS transition (FT):
·     Active—FT is enabled.
·     Inactive—FT is disabled.
Use display wlan client ipv6 to display information about client IPv6 addresses.
# Display brief status information about the specified client.
<Sysname> display wlan client ipv6
MAC address    AP name              IPv6 address                            VLAN
84db-ac14-dd08 fatap                 1    1::2:0:0:3                300
Table 8 Command output
MAC address
Client MAC address.
IPv6 address
VLAN
Client VLAN.
Use display wlan client online-duration to display client online duration.
display wlan client online-duration [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief information about client online duration.
<Sysname> display wlan client online-duration
Total number of online clients: 2
MAC address            IPv4 address    Online duration
a4c1-5b79-fa5b-1d62    192.168.11.123  0days 0hours 2minutes 23seconds
22d3-c5b7-a4b5-96fa    192.168.11.234  0days 0hours 5minutes 34seconds
Table 9 Command output
MAC address
Client MAC address.
IPv4 address
Online duration
Use display wlan client status to display client status information.
display wlan client status [ mac-address mac-address ] [ verbose ]
mac-address mac-address: Specifies a client by its MAC address in the format of H-H-H. If you do not specify this option, the command displays status information about all clients.
verbose: Displays detailed client status information. If you do not specify this keyword, the command displays brief client status information.
<Sysname> display wlan client status mac-address 001c-f08f-f804
MAC address     RSSI  Rx/Tx rate(bps)   Speed(bps)   Discard  AP name          RID
001c-f08f-f804  0     39/117Mbps   N/A          0.00     fatap            2
# Display brief status information about all clients.
Total number of clients: 2
000b-c002-9d09  65    39/117Mbps   N/A     0.00%    fatap            2
000f-e265-6401  62    130/195Mbps  N/A     0.00%    fatap            1
Table 10 Command output
MAC address
Client MAC address.
RSSI
RSSI of the client.
Rx/Tx rate(bps)
Rates at which the client receives and sends data, management packets, and control packets.
Speed(bps)
Rates at which the client receives and sends packets in the past 2 minutes, rounded to one decimal place.
If a rate is smaller than 1 Mbps, the value is displayed in Kbps. If a rate equals 1 Mbps or is larger than 1 Mbps, the value is displayed in Mbps.
Discard
Ratio of packets discarded by the client.
AP name
Name of the AP with which the client is associated.
RID
ID of the radio with which the client is associated.
# Display detailed status information about the specified client.
<Sysname> display wlan client status mac-address 001c-f08f-f804 verbose
MAC address                       : 001c-f08f-f804
Radio ID                          : 2
RSSI                              : 0
Rx/Tx rate                        : 39/117 Mbps
Speed                             : N/A
Received:
 Retransmitted packets            : 84
 Retransmitted packet ratio       : 64.12%
Sent:
 Retransmitted packets            : 0
 Retransmitted packet ratio       : 0.00%
Discarded:
 Discarded packets                : 0
 Discarded packet ratio           : 0.00%
Table 11 Command output
MAC address
Client MAC address.
AP name
Radio ID
RSSI
RSSI of the client.
Rx/Tx rate
Speed
Received
Statistics about packets received by the AP:
·     Retransmitted packets.
·     Retransmitted packet ratio.
Sent
Statistics about packets sent by the AP:
Discarded
Statistics about packets discarded by the client:
·     Discarded packets.
·     Discarded packet ratio.
Use display wlan client-mode packet-statistics to display statistics about received and transmitted packets in client mode.
display wlan client-mode packet-statistics radio radio-id
radio-id: Specifies a radio by its ID.
# Display statistics about received and transmitted packets in client mode.
<Sysname> display wlan client-mode packet-statistics radio 1
Packet statistics:
unknown                              : 0
recv beacon in scan                  : 65
recv beacon in run                   : 47164
recv probe response in fsm           : 49
recv probe response in run           : 0
recv probe response in scan          : 322
recv auth in fsm                     : 50
recv assoc response in fsm           : 50
recv deauth in fsm                   : 0
recv disassoc in fsm                 : 0
recv action in fsm                   : 5
recv other frame in fsm              : 5
recv other frame in scan             : 0
send auth success                    : 50
send auth failed                     : 0
send assoc success                   : 50
send assoc failed                    : 0
send deauth success                  : 49
send deauth failed                   : 0
send unicast probe success           : 50
send unicast probe failed            : 0
send broadcast probe(ssid) success   : 8
send broadcast probe(ssid) failed    : 0
send broadcast probe success         : 16
send broadcast probe failed          : 0
send null data success               : 0
send null data failed                : 0
Table 12 Command output
unknown
Number of received unknown frames.
recv beacon in scan
Number of received beacon frames at the scanning phase.
recv beacon in run
Number of received beacon frames after association.
Number of received probe responses at the association phase.
Number of received probe responses after association.
Number of received probe responses at the scanning phase.
recv auth in fsm
Number of received authentication frames at the association phase.
Number of received association responses at the association phase.
recv deauth in fsm
Number of received deauthentication frames at the association phase.
Number of received disassociation frames at the association phase.
recv action in fsm
Number of received action frames at the association phase.
Number of received other frames at the association phase.
Number of received other frames at the scanning phase.
send auth success
Number of authentication frames sent successfully.
send auth failed
Number of authentication frames failed to be sent.
send assoc success
Number of association frames sent successfully.
send assoc failed
Number of association frames failed to be sent.
send deauth success
Number of deauthentication frames sent successfully.
send deauth failed
Number of deauthentication frames failed to be sent.
Number of unicast probe requests sent successfully.
Number of unicast probe requests failed to be sent.
Number of broadcast probe requests (carrying an SSID) sent successfully.
Number of broadcast probe requests (carrying an SSID) failed to be sent.
Number of broadcast probe requests sent successfully.
Number of broadcast probe requests failed to be sent.
Number of null data packets sent successfully.
Number of null data packets failed to be sent.
client-mode enable
reset wlan client-mode packet-statistics
Use display wlan client-mode roam-enhance bss to display information about BSSs detected in client mode.
This command displays information about BSSs carried in beacon frames and probe responses detected in the most recent five scanning operations.
# Display information about BSSs detected in client mode.
<Sysname> display wlan client-mode roam-enhance bss
Total number of BSSs: 2
BSSID          Time      MSec  RSSI AVER CHL  AGE SSID
84d9-3100-4b00 16:51:09  0244  37   36   149  5   agv-work
               16:51:08  0834  37
               16:51:08  0732  36
               16:51:08  0642  37
               16:51:09  0253  36
50da-00df-33e0 16:51:08  0802  45   45   149  5   agv-work
               16:51:08  0699  44
               16:51:08  0597  46
               16:51:08  0261  46
               16:51:09  0251  45
Table 13 Command output
Time
Time at which the beacon frame or probe response was received.
MSec
Time at which the beacon frame or probe response was received, in milliseconds.
AVER
Average RSSI of the five most recently received frames that carry the BSSID.
CHL
Channel carried in the frame received most recently.
AGE
Aging count for the BSS entry.
Use display wlan client-mode roaming-state to display roaming state changes of the AP in client mode.
# Display roaming state changes of the AP in client mode.
<Sysname> display wlan client-mode roaming-state
Radio ID: 1           FSM changes: 9               SSID: agv
Index FSM  BSSID          RSSI Chl FsmChangeCause         Time
1     UnAu 50da-00df-33e0 55   36  Send prob(Bss)         Day 2 18:12:36 987
2     Auth 50da-00df-33e0 55   36  Auth direct(Bss)       Day 2 18:12:36 35
3     Asso 50da-00df-33e0 55   36  Send assoc             Day 2 18:12:36 37
4     Run  50da-00df-33e0 55   36  Rec assoc              Day 2 18:12:36 38
5     UnAu 50da-00df-33e0 55   36  Scan aging             Day 2 18:12:41 39
6     UnAu 50da-00df-33e0 47   149 Send prob(chlchg)      Day 4 8:49:5 41
7     Auth 50da-00df-33e0 47   149 Auth direct(Bss)       Day 4 8:49:5 42
8     Asso 50da-00df-33e0 47   149 Send assoc             Day 4 8:49:5 43 9
9     Run  50da-00df-33e0 47   149 Rec assoc              Day 4 8:49:5 46
Table 14 Command output
Radio ID
ID of the radio in client mode.
FSM changes
Number of state changes during the association process.
FSM
Device state. Options include:
·     Init—The device is in initialization state.
·     UnAu—The device has not been authenticated.
·     Auth—The device is being authenticated.
·     Asso—The device is attempting to associate with a WLAN.
·     Run—The device is in running state.
·     N/A—The device is in abnormal state.
Chl
Channel ID.
FsmChangeCause
State change reason. Options include:
·     Rec prob resp—The device received a probe response and sent an authentication frame.
·     Send assoc req—The device sent an association request.
·     Rec assoc resp—The device received an association response.
·     Rec deauth—The device received a deauthentication frame.
·     Rec disasso—The device received a disassociation frame.
·     Unauth timeout—The unauthentication state timed out and the AP sent an authentication frame.
·     Unauth timeout fail—The unauthentication state timed out and the AP sent an authentication failure frame.
·     Auth timeout—The authentication state timed out.
·     Asso timeout—The association state timed out.
·     Keepalive beacon timeout—The beacon-based keepalive timed out.
·     Rec action—The device received an action frame.
·     Init to unauth—The device state changed from initialization to unauthentication.
·     Disconnect(cfg)—Connection terminated because of manual configuration.
·     Undo SSID—The SSID configuration was removed.
·     Send prob req(chlchg)—The AP sent a probe request after a channel change.
·     Send prob req fail(chlchg)—The AP failed to send a probe request after a channel change.
·     Radio down—The associated radio became unavailable.
·     Prob resp fail—The AP failed to process a probe response.
·     Auth fail(open system)—The AP failed to process an open system authentication frame.
·     Auth fail(share key)—The AP failed to process a shared key authentication frame.
·     Asso resp fail—The AP failed to process an association response.
·     Chl Chg IE(beacon)—The channel changed in a received beacon frame.
·     Chl Chg IE(probe)—The channel changed in a received probe response.
·     Send prob req(unchlchg)—The AP sent a probe request and did not change its channel.
·     Connect BSS fail—The AP failed to access a BSS.
·     Share-key fail—Shared key authentication failed during association.
·     4H fail—Four-way handshake failed during association.
·     Select BSS by roam—The AP performed a BSS roaming.
·     Disconnect(dbm)—Disabling the client mode triggered AP reassociation.
·     Scan aging—The entry for the associated BSS expired.
·     Unauth timeout—The AP failed to receive probe responses in UnAuth state and stays in UnAuth state.
·     Auth direct—The AP did not receive any probe response and sent an authentication frame directly.
·     Active detect timeout—The probe request-based keepalive timed out.
·     Disconnect(RSSI)—The RSSI of the current link dropped below the link hold RSSI.
·     Roam enhance enabled—Roaming enhancement was enabled.
·     Unknown.
Time
Time at which the state change occurred.
client-mode enable
reset wlan client-mode roaming-state
Use display wlan service-template to display service template information.
display wlan service-template [ service-template-name ] [ verbose ]
service-template-name: Specifies a service template by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command displays information about all service templates.
verbose: Displays detailed service template information.
# Display brief information about all service templates.
[Sysname] display wlan service-template
Total number of service templates: 2
Service template name           SSID                                    Status
1                               2333                                    Enabled
2                               3222                                    Enabled
# Display detailed information about all service templates.
<Sysname> display wlan service-template verbose
Service template name                            : service1
Description                                      : Not configured
SSID                                             : wuxianfuwu
SSID-hide                                        : Disabled
User-isolation                                   : Disabled
Service template status                          : Disabled
Maximum clients per BSS                          : 64
Frame format                                     : Dot3
Seamless roam status                             : Disabled
Seamless roam RSSI threshold                     : 50
Seamless roam RSSI gap                           : 20
VLAN ID                                          : 1
AKM mode                                         : PSK
Security IE                                      : RSN
Cipher suite                                     : CCMP
WEP key ID                                       : 1
TKIP countermeasure time                         : 100 sec
PTK lifetime                                     : 43200 sec
PTK rekey                                        : Enabled
GTK rekey                                        : Enabled
GTK rekey method                                 : Time-based
GTK rekey time                                   : 86400 sec
GTK rekey client-offline                         : Enabled
PPSK                                             : Disabled
PPSK Fail Permit                                 : Disabled
Enhance-open status                              : Enabled
Enhanced-open transition-mode service-template   : N/A
Intrusion protection                             : Disabled
Intrusion protection mode                        : Temporary-block
Temporary block time                             : 180 sec
Temporary service stop time                      : 20 sec
Fail VLAN ID                                     : 1
802.1X handshake                                 : Enabled
802.1X handshake secure                          : Disabled
802.1X domain                                    : my-domain
MAC-auth domain                                  : Not configured
Max 802.1X users per BSS                         : 4096
Max MAC-auth users per BSS                       : 4096
802.1X re-authenticate                           : Enabled
Authorization fail mode                          : Online
Accounting fail mode                             : Online
Authorization                                    : Permitted
PMF status                                       : Optional
Hotspot policy number                            : Not configured
Forwarding policy status                         : Disabled
Forwarder                                        : AP
FT status                                        : Disabled
QoS trust                                        : Port
QoS priority                                     : 0
Table 15 Command output
SSID
SSID of the service template.
SSID-hide
Whether the SSID is hidden in beacons:
·     Disabled.
·     Enabled.
User-isolation
Use isolation:
·     Disabled.
·     Enabled.
Service template status:
·     Disabled.
·     Enabled.
Maximum number of clients that the BSS supports.
Frame format
Client data frame encapsulation format:
·     Dot3—802.3 format.
·     Dot11—802.11 format.
Seamless roaming status:
·     Disabled.
·     Enabled.
Seamless roaming RSSI threshold.
Seamless roaming RSSI gap.
VLAN ID
ID of the VLAN to which clients belong after they come online through the service template.
AKM mode
AKM mode:
·     802.1X.
·     PSK.
Security IE
Security IE:
·     RSN.
·     WPA.
Cipher suite
Cipher suite:
·     WEP40.
·     WEP104.
·     WEP128.
·     TKIP.
·     CCMP.
·     GCMP.
TKIP countermeasure time. The value 0 indicates no countermeasures are taken.
PTK rekey
Whether PTK rekey is enabled:
·     Enabled.
·     Disabled.
GTK rekey
Whether GTK rekey is enabled:
·     Enabled.
·     Disabled.
GTK rekey method
GTK rekey method:
·     Time-based.
·     Packet-based.
GTK rekey time
GTK rekey interval.
GTK rekey packets
Number of packets that can be transmitted before the GTK is refreshed.
Whether client-off GTK rekey is enabled:
·     Enabled.
·     Disabled.
WPA3 status
WPA3 security mode:
·     Disabled.
·     Mandatory.
·     Optional.
PPSK
Whether PPSK is enabled:
·     Disabled.
·     Enabled.
PPSK Fail Permit
Whether PPSK fail permit is enabled:
·     Disabled.
·     Enabled.
Enhance-open status
Whether enhanced open system authentication is enabled:
·     Disabled.
·     Enabled.
Recommended service template in transition mode. If no service template is specified, this field displays N/A.
Authentication mode:
·     Bypass—No authentication.
·     MAC.
·     MAC-or-802.1X—MAC authentication is performed first. If MAC authentication fails, 802.1X authentication is performed.
·     802.1X.
·     802.1X-or-MAC—802.1X authentication is performed first. If 802.1X authentication fails, MAC authentication is performed.
·     OUI-or-802.1X—OUI authentication is performed first. If OUI authentication fails, 802.1X authentication is performed.
Whether intrusion protection is enabled:
·     Enabled.
·     Disabled.
Intrusion protection mode:
·     Temporary-block—Temporarily adds intruders to the block list.
·     Service-stop—Stops all services provided by the BSS that receives illegal packets until it resets.
·     Temporary-service-stop—Temporarily stops the access service provided by the BSS that receives illegal packets.
Temporary block time in seconds.
Temporary service stop time in seconds.
Fail VLAN ID
ID of the VLAN to which clients are added if they cannot pass the authentication when the authentication server can be reached. This field displays Not configured if the fail VLAN ID is not configured.
Critical VLAN ID
ID of the VLAN to which clients are added if they cannot pass the authentication because the authentication server cannot be reached. This field displays Not configured if the critical VLAN ID is not configured.
802.1X handshake
Whether 802.1X handshake is enabled:
·     Enabled.
·     Disabled.
Whether secure 802.1X handshake is enabled:
·     Enabled.
·     Disabled.
802.1X domain
802.1X authentication domain. This field displays Not configured if the domain is not configured.
MAC-auth domain
MAC authentication domain. This field displays Not configured if the domain is not configured.
Maximum number of supported 802.1X users in a BSS.
Maximum number of supported users that pass the MAC authentication in a BSS.
Whether 802.1X reauthentication is enabled:
·     Enabled.
·     Disabled.
Authorization fail mode:
·     Offline—Clients are logged off when authorization fails.
·     Online—Clients are not logged off when authorization fails.
Accounting fail mode:
·     Offline—Clients are logged off when accounting fails.
·     Online—Clients are not logged off when accounting fails.
Authorization
Authorization information:
·     Permitted—Applies the authorization information issued by the RADIUS server or the local device.
·     Ignored—Ignores the authorization information issued by the RADIUS server or the local device.
Key derivation
·     SHA1-AND-SHA256—Uses the HMAC SHA1 and SHA256 hash algorithm.
PMF status
PMF status:
·     Optional—Management frame protection in optional mode is enabled.
·     Mandatory—Management frame protection in mandatory mode is enabled.
Hotspot 2.0 policy number.
WLAN forwarding policy status:
·     Disabled.
·     Enabled.
Forward policy name
·     Not configured—No WLAN forwarding policy is configured.
·     policy-name.
Forwarder
Client traffic forwarder:
·     AP.
FT status
FT status:
·     Disabled.
·     Enabled.
FT method
FT method:
·     over-the-air.
·     over-the-ds.
FT reassociation deadline
FT reassociation timeout timer in seconds.
QoS trust
QoS priority trust mode:
·     Port—Port priority trust mode.
·     Dot11e—802.11e priority trust mode.
QoS priority
Port priority in the range of 0 to 7.
Use display wlan statistics client to display client statistics.
display wlan statistics client [ mac-address mac-address ]
mac-address mac-address: Specifies a client by its MAC address. If you do not specify this option, the command displays statistics for all clients.
# Display statistics for all clients.
<Sysname> display wlan statistics client
MAC address                : 0014-6c8a-43ff
AP name                    : fatap
Radio ID                   : 1
SSID                       : office
BSSID                      : 000f-e2ff-7700
RSSI                       : 31
Sent frames:
  Back ground              : 0/0 (frames/bytes)
  Best effort              : 9/1230 (frames/bytes)
  Video                    : 0/0 (frames/bytes)
  Voice                    : 2/76 (frames/bytes)
Received frames:
  Best effort              : 18/2437 (frames/bytes)
  Voice                    : 7/468 (frames/bytes)
Discarded frames:
  Best effort              : 0/0 (frames/bytes)
  Voice                    : 5/389 (frames/bytes)
Table 16 Command output
SSID
MAC address
Client MAC address.
Back ground
AC-BK queue.
Best effort
AC-BE queue.
Video
AC-VI queue.
Voice
AC-VO queue.
Use display wlan statistics connect-history to display client connection history.
display wlan statistics connect-history service-template service-template-name
service-template service-template-name: Specifies a service template by its name.
# Display the connection history for service template 1.
<Sysname> display wlan statistics connect-history service-template 1
AP name                     : fatap
Radio ID                    : 1
Associations                : 132
Association failures        : 3
Reassociations              : 30
Rejections                  : 12
Abnormal disassociations    : 2
Current associations        : 57
Use display wlan statistics service-template to display service template statistics.
display wlan statistics service-template service-template-name
# Display statistics for service template 1.
<Sysname> display wlan statistics service-template 1
AP name                       : fatap
Radio ID                      : 1
Received:
  Frame count                 : 1713
  Frame bytes                 : 487061
  Data frame count            : 1683
  Data frame bytes            : 485761
  Association request count   : 2
Sent:
  Frame count                 : 62113
  Frame bytes                 : 25142076
  Data frame count            : 55978
  Data frame bytes            : 22626600
  Association response count  : 2
Use display wlan whitelist to display whitelist entries.
# Display whitelist entries.
<Sysname> display wlan whitelist
 MAC addresses:
  000e-35b2-000e
  0019-5b8e-b709
  001c-f0bf-9c92
Use interface wlan-radio to enter WLAN radio interface view.
interface-number: Specifies the WLAN radio interface ID.
# Enter interface view of WLAN-Radio 0/0.
[Sysname] interface wlan-radio 0/0
[Sysname-WLAN-Radio0/0]
nas-id
Use nas-id to set the network access server identifier (NAS ID).
nas-id nas-id
undo nas-id
No NAS ID is specified.
Global configuration view
nas-id: Specifies a NAS ID, a case-sensitive string of 1 to 63 characters.
After coming online, a client sends a RADIUS request that carries the NAS ID to the RADIUS server to indicate its network access server.
# Set the global NAS ID to abc123.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] nas-id abc123
nas-port-type
Use nas-port-type to set the NAS port type attribute in RADIUS requests.
Use the undo nas-port-type to restore the default.
nas-port-type value
undo nas-port-type
The NAS port type is Wireless-IEEE 802.11.
value: Specifies a NAS port type by its code value in the range of 0 to 255. Table 17 lists the most commonly used NAS port types and their code values.
Table 17 Common NAS port types and their code values
NAS port type
Code value
Async
0
Sync
1
ISDN Sync
2
ISDN Async V.120
3
ISDN Async V.110
4
Virtual
5
PIAFS
6
HDLC Clear Channel
7
X.25
8
X.75
9
G.3 Fax
10
SDSL
11
ADSL-CAP
12
ADSL-DMT
13
IDSL
14
Ethernet
15
xDSL
16
Cable
17
Wireless-Other
18
19
You can execute this command to set the NAS port type attribute in RADIUS requests for 802.11X and MAC-authenticated clients.
Make sure the service template is disabled before you execute this command.
# Set the NAS port type in RADIUS requests to 15 (Ethernet).
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] nas-port-type 15
Use quick-association to enable quick association.
Use undo quick-association to disable quick association.
undo quick-association enable
Quick association is disabled.
This command disables APs from performing load balancing or band navigation on clients associated with the specified service template.
# Enable quick association for service template service1.
[Sysname-wlan-st-service1]quick-association enable
reset wlan client
Use reset wlan client to log off a client or all clients.
reset wlan client { all | mac-address mac-address }
View
all: Specifies all clients.
# Log off all clients.
<Sysname> reset wlan client all
display wlan client
Use reset wlan dynamic-blacklist to remove the specified client or all clients from the dynamic blacklist.
reset wlan dynamic-blacklist [ mac-address mac-address ]
mac-address mac-address: Specifies a client by its MAC address. If you do not specify this option, the command removes all clients from the dynamic blacklist.
# Remove all clients from the dynamic blacklist.
<Sysname> reset wlan dynamic-blacklist
# Remove the specified client from the dynamic blacklist.
<Sysname> reset wlan dynamic-blacklist mac-address b8ca-32a2-df69
Use reset wlan statistics client to clear client statistics.
reset wlan statistics client { all | mac-address mac-address }
View
# Clear statistics about all clients.
<Sysname> reset wlan statistics client all
Use reset wlan statistics service-template to clear service template statistics.
reset wlan statistics service-template service-template-name
View
# Clear statistics about service template service1.
<Sysname> reset wlan statistics service-template service1
service-template
Use service-template to bind a service template to a radio interface.
Use undo service-template to unbind a service template from a radio interface.
undo service-template service-template-name
No service template is bound to a radio interface.
Before you bind a service template to a radio interface, you must create the service template.
# Bind service template service1 to interface WLAN-Radio 0/0.
[Sysname-WLAN-Radio0/0] service-template service1
Use service-template enable to enable a service template.
Use undo service-template enable to disable a service template.
A service template is disabled.
If the number of BSSs on a device exceeds the limit, you cannot enable a new service template.
# Enable service template service1.
[Sysname-wlan-st-service1] service-template enable
Use snmp-agent trap enable wlan client to enable SNMP notification for client access.
Use undo snmp-agent trap enable wlan client to disable SNMP notification for client access.
SNMP notification is disabled for client access.
When this feature is enabled, the device sends a client status change notification to an NMS every time the status of a client changes. For the notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable SNMP notification for client access.
[Sysname] snmp-agent trap enable wlan client
snmp-agent trap enable wlan client-audit
Use snmp-agent trap enable wlan client-audit to enable SNMP notification for client audit.
Use undo snmp-agent trap enable wlan client-audit to disable SNMP notification for client audit.
SNMP notification is disabled for client audit.
When this feature is enabled, the device sends a client status change notification to an NMS when a client comes online, goes offline, roams to another AP, or obtains an IP address. For the notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable SNMP notification for client audit.
[Sysname] snmp-agent trap enable wlan client-audit
ssid
Use ssid to set an SSID for a service template.
Use undo ssid to restore the default.
ssid ssid-name
undo ssid
No SSID is configured for a service template.
Service template view
ssid-name: Specifies an SSID name, a case-sensitive string of 1 to 32 characters.
Disable the service template before you execute this command.
# Set the SSID to lynn for service template service1.
[Sysname-wlan-st-service1] ssid lynn
unknown-client
Use unknown-client to set the way that an AP processes traffic from unknown clients.
Use undo unknown-client to restore the default.
unknown-client { deauthenticate | drop }
undo unknown-client
An AP drops packets from unknown clients and deauthenticates these clients.
deauthenticate: Drops packets from unknown clients and deauthenticates these clients.
drop: Drops packets from unknown clients.
# Configure APs that use service template example to drop packets from unknown clients but not deauthenticate these clients.
[Sysname] wlan service-template example
[Sysname-wlan-st-example] unknown-client drop
vip limit rate
Use vip limit rate to enable VIP client rate limit.
Use undo vip limit rate to disable VIP client rate limit.
vip limit rate level level { inbound | outbound } mode { dynamic [ min min-cir ] [ max max-cir ] | static } cir cir
undo vip limit rate level level { inbound | outbound }
VIP client rate limit is disabled.
VIP client group view
level level: Specifies the VIP client level. Only 2 is available.
inbound: Limits the rate of incoming traffic.
outbound: Limits the rate of outgoing traffic.
dynamic: Specifies the dynamic rate limit mode. In this mode, the limited rate for each client is the total CIR divided by the number of clients.
min min-cir: Specifies the minimum CIR for each client, in the range of 16 to 1700000 Kbps. If you do not specify this option, the command does not limit the minimum total CIR.
max max-cir: Specifies the maximum CIR for each client, in the range of 16 to 1700000 Kbps. The maximum CIR must be larger than the minimum CIR. If you do not specify this option, the command does not limit the maximum total CIR.
static: Specifies the static rate limit mode. In this mode, the limited rate for each client is a fixed value.
cir cir: Specifies the CIR in Kbps. The value range for the cir argument is 16 to 1700000 Kbps.
If a large number of VIP clients are online, you can perform this task to rate limit VIP clients to guarantee bandwidth for each client and ensure good user experience.
If you specify both the minimum and maximum CIRs for dynamic rate limit, the feature operates as follows:
·     If the specified CIR divided by the total number of clients is smaller than the minimum CIR, the minimum CIR takes effect for each client.
·     If the specified CIR divided by the total number of clients is larger than the maximum CIR, the maximum CIR takes effect for each client.
·     If the specified CIR divided by the total number of clients is between the minimum and maximum CIRs, the specified CIR divided by the total number of clients takes effect for each client.
You can execute this command multiple times to limit the rates of both the incoming and outgoing traffic.
If you configure both VIP client rate limit and radio-based client rate limit, the configuration that takes effect depends on the rate limit modes (static or dynamic):
·     If different rate limit modes are configured, VIP client rate limit takes effect.
·     If the static mode is configured, the smaller CIR takes effect.
·     If the dynamic mode is configured, VIP client rate limit takes effect.
# Configure static VIP client rate limit: set the CIR to 500 Kbps for incoming traffic and set the CIR to 100 Kbps for outgoing traffic.
[Sysname] wlan vip-client-group
[Sysname-vip-client-group] vip limit rate level 2 inbound mode static cir 500
[Sysname-vip-client-group] vip limit rate level 2 outbound mode static cir 100
client-rate-limit (radio view/AP group radio view)
vlan
Use vlan to assign clients coming online through a service template to the specified VLAN.
Use undo vlan to restore the default.
vlan vlan-id
undo vlan [ vlan-id ]
Clients are assigned to VLAN 1 after coming online through a service template.
vlan-id: Specifies a VLAN by its VLAN ID, in the range of 1 to 4094. If the specified VLAN does not exist, this command creates the VLAN when clients come online.
# Assign clients coming online through service template service1 to VLAN 2.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] vlan 2
wlan association optimization
Use wlan association optimization to set the index for optimizing client association ratios.
Use undo wlan association optimization to restore the default.
wlan association optimization value
The index is 0. The device does not optimize client association ratios.
value: Specifies the index for optimizing client association ratios, in the range of 900 to 1000. The smaller the index is, the smaller the calculated association success ratio will be and the larger the calculated congestion ratio and abnormal disassociation ratio will be.
This feature enables the device to recalculate the client association success ratio, association congestion ratio, and abnormal disassociation ratio by using the specified index to get smaller ratio values.
The client association success ratio is the number of successful client associations divided by the total number of client association attempts. The client association congestion ratio is the number of failed client associations caused by AP overloading divided by the total number of client association attempts. The client abnormal disassociation ratio is the number of abnormal disassociations divided by the sum of successful associations and online clients.
# Set the index for optimizing client association ratios to 950.
[Sysname] wlan association optimization 950
wlan broadcast-probe reply
Use wlan broadcast-probe reply to enable the AP to respond to broadcast probe requests.
Use undo wlan broadcast-probe reply to disable the AP from responding to broadcast probe requests.
wlan broadcast-probe reply [ rssi-threshold rssi-value ] [ frequency-band { 2.4 | 5 } ]
undo wlan broadcast-probe reply [ frequency-band { 2.4 | 5 } ]
The AP responds to broadcast probe requests from clients operating at any frequency band.
rssi-threshold rssi-value: Specifies an RSSI threshold in the range of 1 to 100. If you do not specify this option, the command enables the AP to respond to broadcast probe requests with any RSSIs.
frequency-band: Specifies a frequency band. If you do not specify this keyword, the command enables the AP to respond to broadcast probe requests received at both the 5 GHz and 2.4 GHz bands.
2.4: Specifies the 2.4 GHz band.
5: Specifies the 5 GHz band.
Broadcast probe requests do not carry any SSIDs. Upon receiving a broadcast probe request, the AP responds with a probe response that carries service information for the AP.
By default, the AP responds to all broadcast probe requests, which might threat network security and decrease AP performance. However, disabling responding to broadcast probe requests might forbid clients from roaming to the optimal AP in time, affecting client access.
You can perform this task to enable the AP to respond to broadcast requests from a specific frequency band with strong signal strength.
# Disable the AP from responding to broadcast probe requests from clients operating at all frequency bands.
[Sysname] undo wlan broadcast-probe reply
wlan client bss-load-ie enable
Use wlan client bss-load-ie enable to enable beacon frames and probe responses to carry the BSS load IE.
Use undo wlan client bss-load-ie enable to disable beacon frames and probe responses from carrying the BSS load IE.
wlan client bss-load-ie enable [ update-interval interval ]
Beacon frames and probe responses do not carry the BSS load IE.
update-interval interval: Specifies the update interval for BSS load IEs, in the range of 5 to 30 seconds. The default value is 15.
A BSS load IE contains information about the number of online clients in the BSS, channel usage, and remaining media time.
As a best practice, enable this feature in Hotspot 2.0 networks or networks configured with WLAN roaming to help clients identify the optimal WLAN.
# Enable beacon frames and probe responses to carry the BSS load IE.
[Sysname] wlan client bss-load-ie enable
wlan client idle-timeout
Use wlan client idle-timeout to set the client idle timeout timer.
Use undo wlan client idle-timeout to restore the default.
wlan client idle-timeout timeout
The client idle timeout timer is 3600 seconds.
timeout: Specifies the client idle timeout timer in the range of 60 to 86400 seconds.
If an online client does not send any frames to the associated AP before the client idle timeout timer expires, the AP logs off the client.
# Set the client idle timeout timer to 2000 seconds.
[Sysname] wlan client idle-timeout 2000
wlan client keep-alive
Use wlan client keep-alive enable to enable client keepalive.
Use undo wlan client keep-alive to disable client keepalive.
Client keepalive is disabled.
This feature enables the AP to send keepalive packets to clients at the specified intervals to determine whether the clients are online. If the AP does not receive any replies from a client within three keepalive intervals, it logs off the client.
# Enable client keepalive.
[Sysname] client keep-alive enable
wlan client keep-alive interval
Use wlan client keep-alive interval to set the client keepalive interval.
Use undo wlan client keep-alive interval to restore the default.
wlan client keep-alive interval interval
The client keepalive interval is 300 seconds.
interval: Specifies the client keepalive interval in the range of 3 to 1800 seconds.
Enable client keepalive on the fat AP before you execute this command.
This feature enables an AP to send keepalive packets to clients at the client keepalive interval to determine whether the clients are online. If the AP does not receive any replies from a client within three keepalive intervals, it logs off the client.
# Set the client keepalive interval to 1000 seconds.
[Sysname] wlan client keep-alive interval 1000
wlan client reauthentication-period
Use wlan client reauthentication-period to set the idle period before client reauthentication.
Use undo wlan client reauthentication-period to restore the default.
wlan client reauthentication-period [ period-value ]
The idle period is 10 seconds.
period-value: Specifies the idle period in the range of 1 to 3600 seconds.
When URL redirection for WLAN MAC authentication is enabled, an AP redirects clients whose information is not recorded on the RADIUS server to the specified URL for Web authentication. Clients passing Web authentication are logged off and must perform MAC reauthentication to come online. However, MAC reauthentication fails if the IP addresses assigned to the clients have not expired.
Perform this task to add these clients to the dynamic blacklist for the specified idle period after they pass Web authentication to reduce reauthentication failures.
# Set the idle period before client reauthentication to 100 seconds.
[Sysname] wlan client reauthentication-period 100
wlan dynamic-blacklist lifetime
Use wlan dynamic-blacklist lifetime to set the aging time for dynamic blacklist entries.
Use undo wlan dynamic-blacklist lifetime to restore the default.
wlan dynamic-blacklist lifetime lifetime
The aging time is 300 seconds for dynamic blacklist entries.
lifetime: Specifies the aging time in the range of 1 to 3600 seconds.
The configured aging time takes effect only on entries added to the dynamic blacklist after this command is executed.
The aging time for dynamic blacklist entries only applies to rogue client entries.
# Set the aging time for dynamic blacklist entries to 3600 seconds.
[Sysname] wlan dynamic-blacklist lifetime 3600
wlan link-test
Use wlan link-test to test wireless link quality.
wlan link-test mac-address
mac-address: Specifies the client MAC address in the H-H-H format.
Wireless link quality detection enables an AP to test the quality of the link to a wireless client. The AP sends empty data frames to the client at each supported rate. Then it calculates link quality information such as RSSI, packet retransmissions, and RTT based on the responses from the client.
The timeout timer for wireless link quality detection is 10 seconds. If wireless link detection is not completed within the timeout timer, test results cannot be obtained.
# Test the quality of the wireless link to the client with MAC address 60a4-4cda-eff0.
<Sysname> wlan link-test 60a4-4cda-eff0
Testing link to 60a4-4cda-eff0. Press CTRL + C to break.
                              Link Status
MAC address: 60a4-4cda-eff0
VHT-MCS  Rate(Mbps)  Tx packets  Rx packets  RSSI   Retries RTT(ms)
NSS = 1
 0       32.5        5           5           54     0       0
 1       65          5           5           51     0       0
 2       97.5        5           5           49     0       0
 3       130         5           5           47     0       0
 4       195         5           5           45     0       0
 5       260         5           5           45     0       0
 6       292.5       5           5           44     0       0
 7       325         5           5           44     0       0
 8       390         5           5           44     0       0
 9       433.3       5           5           43     0       0
NSS = 2
 0       65          5           5           44     0       0
 1       130         5           5           44     0       0
 2       195         5           5           44     0       0
 3       260         5           5           44     0       0
 4       390         5           5           44     0       0
 5       520         5           5           44     0       0
 6       585         5           5           43     0       0
 7       650         5           5           43     0       0
 8       780         5           5           43     0       0
 9       866.7       5           5           43     0       0
<Sysname> wlan link-test 784f-43b6-077c
Testing link to 784f-43b6-077c. Press CTRL + C to break.
                              Link Status
MAC address: 784f-43b6-077c
0       6.5         5           5           54     0        0
1       13          5           5           51     0        0
2       19.5        5           5           49     0        0
3       26          5           5           47     0        0
4       39          5           5           45     0        0
5       52          5           5           45     0        0
6       58.5        5           5           44     0        0
7       72.2        5           5           44     0        0
8       13          5           5           44     0        0
9       26          5           5           43     0        0
10       39         5           5           44     0        0
11       52         5           5           44     0        0
12       78         5           5           44     0        0
13       104        5           5           44     0        0
14       117        5           5           44     0        0
15       144.4      5           5           44     11       0
Table 18 Command output
No./MCS/VHT-MCS
·     No.—Rate number for link quality test on 802.11a, 802.11b, or 802.11g clients.
·     MCS—MCS index for link quality test on 802.11n clients.
·     VHT-MCS—VHT-MCS index for link quality test on 802.11ac clients.
Rate(Mbps)
Rate at which the AP sends wireless link quality detection frames.
Tx packets
Number of wireless link quality detection frames sent by the AP.
Rx packets
Number of responses received by the AP.
RSSI
RSSI of the client detected by the AP.
Retries
Number of wireless link quality retransmission frames sent by the AP.
RTT(ms)
Round trip time for link quality test frames from the AP to the client.
NSS
Number of spatial streams for link quality test on 802.11n or 802.11ac clients.
wlan nas-port-id format
Use wlan nas-port-id format to set the format of NAS port IDs for wireless clients.
Use undo wlan nas-port-id format to restore the default.
wlan nas-port-id format { 2 | 4 }
Clients use format 2 to generate NAS port IDs.
2: Specifies the SlotID00IfNOVlanID format.
·     SlotID—Slot ID for client access, a string of two characters.
·     IfNO—Interface number for client access, a string of three characters.
·     VlanID—VLAN ID for client access, a string of nine characters.
4: Specifies the slot=**;subslot=**;port=**;vlanid=**;vlanid2=** format. The vlanid2 field is available only for clients accessing the WLAN through an interface configured with VLAN termination.
802.1X and MAC-authenticated clients fill NAS port IDs in the specified format in RADIUS packets.
# Set the NAS port ID format to format 4.
[Sysname] wlan nas-port-id format 4
nas-port-id
Use wlan service-template to create a service template and enter its view, or enter the view of an existing service template.
Use undo wlan service-template to delete a service template.
wlan service-template service-template-name
undo wlan service-template service-template-name
No service template exists.
You cannot delete a service template that has been bound to a radio.
# Create service template service1 and enter its view.
wlan static-blacklist mac-address
Use wlan static-blacklist mac-address to add a client to the static blacklist.
Use undo wlan static-blacklist mac-address to remove a client from the static blacklist.
wlan static-blacklist mac-address mac-address
undo wlan static-blacklist [ mac-address mac-address ]
No clients exist in the static blacklist.
If you add an online client to the static blacklist, the command logs off the client.
You cannot add a client to both the whitelist and the static blacklist.
The undo form of the command removes all clients from the static blacklist if you do not specify the mac-address mac-address option.
Do not add multicast or broadcast MAC addresses to the static blacklist.
# Add MAC address 001c-f0bf-9c92 to the static blacklist.
[Sysname] wlan static-blacklist mac-address 001c-f0bf-9c92
wlan web-server api-path
Use wlan web-server api-path to specify the path of the Web server to which client information is reported.
Use undo wlan web-server api-path to restore the default.
wlan web-server api-path path
The path of the Web server is not specified.
path: Specifies a path, a case-sensitive string of 1 to 256 characters.
The Web server accepts client information only when the server's host name, port number, and path are specified.
# Specify the path of the Web server as /wlan/dev-cfg.
[Sysname] wlan web-server api-path /wlan/dev-cfg
wlan web-server host
wlan web-server max-client-entry
Use wlan web-server host to specify the host name and port number of the Web server to which client information is reported.
Use undo wlan web-server host to restore the default.
wlan web-server host host-name port port-number
The host name and port number of the Web server are not specified.
host host-name: Specifies a host name, a case-insensitive string of 3 to 127 characters that can contain letters, digits, hyphens (-), underscores (_), and dots (.).
port port-number: Specifies a port number in the range of 1 to 65534.
Client information changes are reported to the Web server in real time.
# Specify the host name and port number of the Web server as www.abc.com and 668, respectively.
[Sysname] wlan web-server host www.abc.com port 668
Use wlan web-server max-client-entry to set the maximum number of client entries that can be reported at a time.
Use undo wlan web-server max-client-entry to restore the default.
wlan web-server max-client-entry number
A maximum of ten client entries can be reported at a time.
number: Specifies a maximum number of client entries that can be reported at a time, in the range of 1 to 25.
# Set the maximum of client entries that can be reported at a time to 12.
[Sysname] wlan web-server max-client-entry 12
wlan whitelist mac-address
Use wlan whitelist mac-address to add a client to the whitelist.
Use undo wlan whitelist mac-address to remove a client from the whitelist.
wlan whitelist mac-address mac-address
undo wlan whitelist [ mac-address mac-address ]
No clients exist in the whitelist.
When you add the first client to the whitelist, the system asks you whether to disconnect all online clients. Enter Y at the prompt to configure the whitelist.
If you remove an online client from the whitelist, the command logs off the client. If you remove all clients from the whitelist, online clients will not be logged off.
The undo form of the command removes all clients from the whitelist if you do not specify the mac-address mac-address option.
Do not add multicast or broadcast MAC addresses to the whitelist.
# Add MAC address 001c-f0bf-9c92 to the whitelist.
[Sysname] wlan whitelist mac-address 001c-f0bf-9c92
This command will disconnect all clients. Continue? [Y/N]:
  • Become a Partner
  • Partner Resources
