- 26-WLAN Command References(AC)
- 01-Compatibility of hardware and AC functionality.htm
- 03-Radio management commands
- 05-WLAN security commands
- 07-WIPS commands
- 09-WLAN roaming commands
- 11-WLAN radio resource measurement commands
- 13-Band navigation commands
- 15-WLAN RRM commands
- 17-WLAN probe commands
00-Preface | 100.01 KB |
Preface
This command reference describes the commands of WLAN.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
