21-VXLAN Command References
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References(V7)-R6749-6W10021-VXLAN Command References
Table of Contents
Related Documents
01-VXLAN commands
01-VXLAN commands 284.42 KB
VXLAN commands
The following compatibility matrixes show the support of hardware platforms for VXLAN:
Hardware
VXLAN compatibility
MSR610
No
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
Yes
MSR810-LMS, MSR810-LUS
No
MSR810-SI, MSR810-LM-SI
No
MSR810-LMS-EA, MSR810-LME
Yes
MSR1004S-5G, MSR1004S-5G-CN
Yes
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN
Yes
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
Yes
MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
No
Yes
MSR3600-28-G-DP, MSR3600-51-G-DP
Yes
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
Yes
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
MSR3640-G
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
VXLAN compatibility
MSR810-W-WiNet, MSR810-LM-WiNet
Yes
MSR830-4LM-WiNet
Yes
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
Yes
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
Yes
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
VXLAN compatibility
MSR860-6EI-XS
Yes
MSR860-6HI-XS
Yes
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
VXLAN compatibility
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
Basic VXLAN commands
ac statistics enable
Use ac statistics enable to enable packet statistics for a Layer 3 interface that acts as an AC.
Use undo ac statistics enable to disable packet statistics for a Layer 3 interface that acts as an AC.
The packet statistics feature is disabled for a Layer 3 interface that acts as an AC.
For this command to take effect, you must map the Layer 3 interface to a VSI. If you modify the VSI mapping, packet statistics of the interface are cleared.
# Map GigabitEthernet 1/0/1 to VSI vsia and enable packet statistics on the interface.
[Sysname-GigabitEthernet1/0/1] xconnect vsi vsia
[Sysname-GigabitEthernet1/0/1] ac statistics enable
display l2vpn interface verbose
reset l2vpn statistics ac
arp suppression enable
Use arp suppression enable to enable ARP flood suppression.
Use undo arp suppression enable to disable ARP flood suppression.
ARP flood suppression is disabled.
VSI view
ARP flood suppression reduces ARP request broadcasts by enabling the VTEP to reply to ARP requests on behalf of VMs.
This feature snoops ARP packets to populate the ARP flood suppression table with local and remote MAC addresses. If an ARP request has a matching entry, the VTEP replies to the request on behalf of the VM. If no match is found, the VTEP floods the request to both local and remote sites.
# Enable ARP flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable
display arp suppression vsi
reset arp suppression vsi
description
Use description to configure a description for a VSI.
A VSI does not have a description.
VSI view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
display l2vpn vsi
Use display arp suppression vsi to display ARP flood suppression entries.
In standalone mode:
display arp suppression vsi [ name vsi-name ] [ count ]
In IRF mode:
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays entries for all VSIs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays entries on the master device. (In IRF mode.)
count: Displays the number of ARP flood suppression entries that match the command.
# Display ARP flood suppression entries.
<Sysname> display arp suppression vsi
IP address      MAC address    Vsi Name                        Link ID    Aging
1.1.1.2         000f-e201-0101 vsi1                            0x70000    14
1.1.1.3         000f-e201-0202 vsi1                            0x80000    18
1.1.1.4         000f-e201-0203 vsi2                            0x90000    10
# Display the number of ARP flood suppression entries.
<Sysname> display arp suppression vsi count
Total entries: 3
Link ID
Link ID that uniquely identifies an AC or a VXLAN tunnel on a VSI.
Aging
Remaining lifetime (in minutes) of the ARP flood suppression entry. When the timer expires, the entry is deleted.
Use display l2vpn interface to display L2VPN information for Layer 3 interfaces that are mapped to VSIs.
display l2vpn interface [ vsi vsi-name | interface-type interface-number ] [ verbose ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters.
verbose: Displays detailed information about Layer 3 interfaces. If you do not specify this keyword, the command displays brief information about Layer 3 interfaces.
If you do not specify any parameters, this command displays brief L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
# Display brief L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
<Sysname> display l2vpn interface
Total number of interfaces: 2, 1 up, 1 down
Interface                Owner                           Link ID   State    Type
GE1/0/1                  vxlan3                          1         Up       VSI
GE1/0/2                  vxlan4                          2         Down     VSI
Layer 3 interface name.
Owner
VSI name.
Link ID
The interface's link ID on the VSI.
Physical state of the interface:
·     Up—The interface is physically up.
·     Down—The interface is physically down.
L2VPN type of the interface. This field displays VSI for the VXLAN feature.
# Display detailed L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
<Sysname> display l2vpn interface verbose
Interface: GE1/0/1
    Owner           : vsi1
    Link ID         : 0
    State           : Up
    Type            : VSI
    E-Tree Mode     : root
    AC VNID         : -
    End.Dx2 SID     : -
    End.Dx2l SID    : -
    DF State        : DF
Interface: GE1/0/2
    Owner           : vsi2
    Link ID         : 0
    State           : Down
    Type            : VSI
    E-Tree Mode     : root
    AC VNID         : -
    End.Dx2 SID     : -
    End.Dx2l SID    : -
    DF State        : DF
Owner
VSI name.
Link ID
E-Tree Mode
Role of the AC in EVPN E-tree in the EVPN VPLS or EVPN VPLS over SRv6 network:
·     root.
·     leaf.
AC VNID
Virtual nexthop for the AC. This field is available only when AC bypass is configured for the AC.
End.Dx2 SID
End.DX2 SID assigned to the AC in the EVPN VPLS over SRv6 network.
This field displays a hyphen (-) if the AC is not assigned any End.DX2 SID.
End.Dx2l SID
End.Dx2l SID assigned to the AC in the EVPN VPLS over SRv6 network.
This field displays a hyphen (-) if the AC is not assigned any End.Dx2l SID.
DF State
Whether the device is the designated forwarder for the AC at a multihomed EVPN site:
·     BDF—The device is a backup designated forwarder.
·     DF—The device is the designated forwarder.
This field is not displayed if no Ethernet segment identifiers are configured on the interface.
display l2vpn mac-address
Use display l2vpn mac-address to display MAC address entries for VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address entries for all VSIs.
dynamic: Specifies dynamic MAC address entries learned in the data plane. If you do not specify this keyword, the command displays all MAC address entries, including:
·     Dynamic remote- and local-MAC entries.
·     Remote-MAC entries advertised through BGP EVPN.
·     Manually added static remote-MAC entries.
·     Remote-MAC entries issued through OpenFlow.
VXLAN does not support static local-MAC entries.
count: Displays the number of MAC address entries. If you do not specify this keyword, the command displays detailed information about MAC address entries.
# Display MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address
MAC Address      State    VSI Name                        Link ID/Name  Aging
0000-0000-000b   Static   vpn1                            Tunnel10      NotAging
0000-0000-000c   Dynamic  vpn1                            Tunnel60      Aging
0000-0000-000d   Dynamic  vpn1                            Tunnel99      Aging
--- 3 mac address(es) found  ---
# Display the total number of MAC address entries in all VSIs.
<Sysname> display l2vpn mac-address count
Entry state:
·     Dynamic—Local- or remote-MAC entry dynamically learned in the data plane.
·     Static—Static remote-MAC entry.
·     EVPN—Remote-MAC entry advertised through BGP EVPN.
·     OpenFlow—Remote-MAC entry issued by a remote controller through OpenFlow.
Link ID/Name
For a local MAC address, this field displays the AC's link ID on the VSI.
For a remote MAC address, this field displays the tunnel interface name.
Aging
Entry aging state:
·     Aging.
·     NotAging.
reset l2vpn mac-address
display l2vpn vsi
Use display l2vpn vsi to display information about VSIs.
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about all VSIs.
verbose: Displays detailed information about VSIs. If you do not specify this keyword, the command displays brief information about VSIs.
# Display brief information about all VSIs.
<Sysname> display l2vpn vsi
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpna                            0               1500   Up
Table 5 Command output
MTU
MTU on the VSI.
VSI state:
·     Up—The VSI is up.
·     Down—The VSI is down.
·     Admin down—The VSI has been manually shut down by using the shutdown command.
# Display detailed information about all VSIs.
<Sysname> display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : -
  Broadcast Restrain      :
  Multicast Restrain      :
  Unknown Unicast Restrain:
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            :
  PW Redundancy           : Slave
  Service Class           : -
  Statistics              : Enabled
  Input Statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Output Statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Gateway Interface       : VSI-interface 100
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State  Type      Flood Proxy  Split horizon
    Tunnel1              0x5000001  Up     Manual    Disabled     Enabled
    Tunnel2              0x5000002  Up     Manual    Disabled     Enabled
  ACs:
    AC                               Link ID    State
    GE1/0/1                          0          Up
Table 6 Command output
VSI Description
Description of the VSI. If the VSI does not have a description, the command does not display this field.
VSI State
VSI state:
·     Up—The VSI is up.
·     Administratively down—The VSI has been manually shut down by using the shutdown command.
MTU
MTU on the VSI.
Bandwidth
Maximum bandwidth (in kbps) for known unicast traffic on the VSI. This field displays a hyphen (-) if it is not available in the current software version.
Broadcast Restrain
Broadcast restraint bandwidth (in kbps). This field displays a hyphen (-) if it is not available in the current software version.
Multicast Restrain
Multicast restraint bandwidth (in kbps). This field displays a hyphen (-) if it is not available in the current software version.
Unknown unicast restraint bandwidth (in kbps). This field displays a hyphen (-) if it is not available in the current software version.
MAC Learning
State of the MAC learning feature.
MAC Table Limit
Maximum number of MAC address entries on the VSI. This field displays a hyphen (-) if it is not available in the current software version.
MAC Learning Rate
MAC address entry learning rate of the VSI.
Drop Unknown
Action on source MAC-unknown frames received after the maximum number of MAC entries is reached.
PW Redundancy
PW redundancy mode:
·     Slave—Master/slave mode and the local PE operates as the slave node.
·     Master—Master/slave mode and the local PE operates as the master node.
This field is not supported by a VXLAN network.
Flooding
State of the VSI's flooding feature:
·     Enabled—Flooding is enabled on the VSI. The VTEP floods unknown unicast frames to both local and remote sites.
·     Disabled—Flooding is disabled on the VSI. The VTEP floods unknown unicast frames only to local sites.
Service Class
Service class value of outgoing VXLAN packets.
Statistics
Packet statistics state:
·     Enabled—The packet statistics feature is enabled for the VSI.
·     Disabled—The packet statistics feature is disabled for the VSI.
Input Statistics
Incoming traffic statistics:
·     Octets—Number of incoming bytes.
·     Packets—Number of incoming packets.
·     Errors—Number of error packets.
·     Discards—Number of discarded packets.
Output Statistics
Outgoing traffic statistics:
·     Octets—Number of outgoing bytes.
·     Packets—Number of outgoing packets.
Gateway Interface
VSI interface name.
Tunnel state:
·     Up—The tunnel is operating correctly.
·     Blocked—The tunnel is a backup proxy tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary proxy tunnel is operating correctly. ‌
·     Defect—The tunnel interface is up, but BFD cannot detect the remote VTEP.
·     Down—The tunnel interface is down.
Tunnel assignment method:
·     Auto—The tunnel was automatically assigned to the VXLAN. For an EVPN network, VXLAN tunnels are automatically assigned to VXLANs.
·     Manual—The tunnel was manually assigned to the VXLAN.
Flood Proxy
Flood proxy state:
·     Enabled—Flood proxy is enabled. The VTEP sends broadcast, multicast, and unknown unicast traffic to a flood proxy server through the tunnel. The flood proxy server replicates and forwards flood traffic to remote VTEPs.
·     Disabled—Flood proxy is disabled.
Split horizon
State of split horizon:
·     Enabled—Split horizon is enabled on the VXLAN tunnel. The VXLAN tunnel does not forward the traffic that is received on other VXLAN tunnels.
·     Disabled—Split horizon is disabled on the VXLAN tunnel. The VXLAN tunnel forwards the traffic that is received on other VXLAN tunnels.
ACs
ACs that are bound to the VSI.
Link ID
AC state:
·     Up.
·     Down.
display vxlan tunnel
Use display vxlan tunnel to display VXLAN tunnel information for VXLANs.
display vxlan tunnel [ vxlan-id vxlan-id [ tunnel tunnel-number ] ]
vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215. If you do not specify a VXLAN, this command displays VXLAN tunnel information for all VXLANs.
tunnel tunnel-number: Specifies a VXLAN tunnel. The tunnel-number argument represents the tunnel interface number. The value range for the tunnel-number argument is 0 to 10239. If you do not specify a VXLAN tunnel, this command displays information about all VXLAN tunnels associated with the specified VXLAN.
# Display VXLAN tunnel information for all VXLANs.
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: vpna, Total tunnels: 3 (3 up, 0 down, 0 defect, 0 blocked)
Tunnel name          Link ID    State  Type         Flood proxy  Split horizon
# Display VXLAN tunnel information for VXLAN 10.
<Sysname> display vxlan tunnel vxlan-id 10
# Display information about VXLAN tunnel 0 for VXLAN 10.
<Sysname> display vxlan tunnel vxlan-id 10 tunnel 0
Interface: Tunnel0
  Link ID    : 0x5000000
  State      : Up
  Type       : Auto
  Flood Proxy: Disabled
    Input statistics:
      Octets : 994496
      Packets: 15539
    Output statistics:
      Octets : 0
      Packets: 0
Table 7 Command output
Link ID
Tunnel's link ID in the VXLAN.
Tunnel state:
·     Blocked—The tunnel is a backup proxy tunnel. Its tunnel interface is but the tunnel is blocked because the primary proxy tunnel is operating correctly.
·     Defect—The tunnel interface is up, but BFD cannot detect the remote VTEP. This type is not supported in the current software version.
Flood proxy
Flood proxy state:
Split horizon
Statistics
·     Enabled—The packet statistics feature is enabled for the VXLAN tunnel.
·     Disabled—The packet statistics feature is disabled for the VXLAN tunnel.
Input statistics
Output statistics
tunnel
vxlan
flooding disable
Use flooding disable to disable flooding for a VSI.
Use undo flooding disable to enable flooding for a VSI.
flooding disable
Flooding is enabled for a VSI.
VSI view
By default, the device floods unknown unicast frames received from the local site to the following interfaces in the frame's VXLAN:
·     All site-facing interfaces except for the incoming interface.
·     All VXLAN tunnel interfaces.
To confine unknown unicast traffic to the site-facing interfaces, use this command to disable flooding for the VSI bound to the VXLAN. The VSI will not flood unknown unicast frames to VXLAN tunnel interfaces.
# Disable flooding for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before you can configure L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
l2vpn rewrite inbound tag
Use l2vpn rewrite inbound tag to configure the VLAN tag processing rule for incoming traffic.
Use undo l2vpn rewrite inbound to restore the default.
l2vpn rewrite inbound tag { nest { c-vid vlan-id | s-vid vlan-id [ c-vid vlan-id ] } | remark 1-to-2 s-vid vlan-id c-vid vlan-id } [ symmetric ]
VLAN tags of incoming traffic are not processed.
nest: Adds VLAN tags.
c-vid: Specifies an inner VLAN tag.
s-vid: Specifies an outer VLAN tag.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
remark: Maps VLAN tags.
1-to-2: Performs one-to-two mapping to replace the VLAN tag of single tagged packets with the specified outer and inner VLAN tags.
symmetric: Applies the reverse VLAN tag processing rule to outgoing traffic. If you do not specify this keyword, VLAN tags of outgoing traffic are not processed.
To modify the VLAN tag processing rule for incoming traffic, first execute the undo l2vpn rewrite inbound command to remove the existing rule, and then execute the l2vpn rewrite inbound command.
When you use this command, follow these restrictions:
·     The l2vpn rewrite inbound tag nest s-vid vlan-id c-vid vlan-id command takes effect only on untagged packets.
·     The l2vpn rewrite inbound tag remark 1-to-2 command takes effect only on single tagged packets.
# Configure Layer 3 Ethernet interface GigabitEthernet 1/0/1 to add outer VLAN tag 100 to incoming frames and remove outer VLAN tag 100 from outgoing frames.
[Sysname-GigabitEthernet1/0/1] l2vpn rewrite inbound tag nest s-vid 100 symmetric
l2vpn statistics interval
Use l2vpn statistics interval to set the VXLAN statistics collection interval.
Use undo l2vpn statistics interval to restore the default.
l2vpn statistics interval interval
The VXLAN statistics collection interval is 15 minutes.
interval: Specifies an interval value in the range of 30 to 65535 seconds.
This command sets the interval for collecting VSI packet statistics, VXLAN tunnel packet statistics, and AC packet statistics.
# Set the VXLAN statistics collection interval to 30 seconds.
[Sysname] l2vpn statistics interval 30
mac-address static vsi
Use mac-address static vsi to add a static MAC address entry for a VXLAN VSI.
Use undo mac-address static vsi to remove static MAC address entries for a VXLAN VSI.
mac-address static mac-address interface tunnel tunnel-number vsi vsi-name
undo mac-address static [ mac-address ] [ interface tunnel tunnel-number ]  vsi vsi-name
VXLAN VSIs do not have static MAC address entries.
mac-address: Specifies a MAC address in H-H-H format. Do not specify a multicast MAC address or an all-zeros MAC address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
interface tunnel tunnel-number: Specifies a VXLAN tunnel interface by its tunnel interface number. The value range for the tunnel-number argument varies by device model. The tunnel interface must already exist.
A remote MAC address is the MAC address of a VM in a remote site. Remote MAC entries include manually added MAC entries, dynamically learned MAC entries, and MAC entries advertised through a protocol, for example, BGP EVPN.
When you add a remote MAC address entry, make sure the specified VSI's VXLAN has been assigned the specified VXLAN tunnel.
The undo mac-address static vsi vsi-name command removes all static MAC address entries for a VSI.
Do not configure static remote-MAC entries for tunnels that are automatically established by using EVPN.
·     EVPN re-establishes tunnels if the transport-facing interface goes down and then comes up. If you have configured static remote-MAC entries, the entries are deleted when the tunnels are re-established.
·     EVPN re-establishes tunnels if you perform configuration rollback. If the tunnel IDs change during tunnel re-establishment, configuration rollback fails, and static remote-MAC entries on the tunnels cannot be restored.
# Add MAC address 000f-e201-0101 to VSI vsi1. Specify Tunnel-interface 1 as the outgoing interface.
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
mtu
Use mtu to set the MTU for a VSI.
mtu size
undo mtu
The default MTU of a VSI is 1500 bytes.
VSI view
size: Specifies an MTU value. The value range for this argument is 300 to 65535 bytes.
The MTU set by using this command limits the maximum length of the packets that a VSI receives from ACs and forwards through VXLAN tunnels. The MTU does not limit the maximum length of other packets in the VXLAN VSI.
Fragmentation is disabled for a VSI that uses the default MTU. If you set a MTU for a VSI, the packets longer than the MTU are fragmented.
# Set the MTU to 1400 bytes for VSI vxlan1.
[Sysname] vsi vxlan1
[Sysname-vsi-vxlan1] mtu 1400
display l2vpn vsi
reserved vxlan
Use reserved vxlan to specify a reserved VXLAN.
Use undo reserved vxlan to restore the default.
reserved vxlan vxlan-id
undo reserved vxlan
No VXLAN has been reserved.
You can specify only one reserved VXLAN on the VTEP. The reserved VXLAN cannot be the VXLAN created on any VSI.
The reserved VXLAN ID cannot be the same as the remote VXLAN ID specified by using the mapping vni command.
# Specify VXLAN 10000 as the reserved VXLAN.
[Sysname] reserved vxlan 10000
mapping vni (EVPN Command Reference)
Use reset arp suppression vsi to clear ARP flood suppression entries on VSIs.
reset arp suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ARP flood suppression entries on all VSIs.
# Clear ARP flood suppression entries on all VSIs.
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
Use reset l2vpn mac-address to clear dynamic MAC address entries on VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears all dynamic MAC address entries on all VSIs.
Use this command when the number of dynamic MAC address entries reaches the limit or the device learns incorrect MAC addresses.
# Clear the dynamic MAC address entries on VSI vpn1.
<Sysname> reset l2vpn mac-address vsi vpn1
display l2vpn mac-address vsi
Use reset l2vpn statistics ac to clear packet statistics on ACs.
reset l2vpn statistics ac [ interface interface-type interface-number ]
If you do not specify any parameters, this command clears packet statistics on all ACs.
# Clear packet statistics for Layer 3 interface GigabitEthernet 1/0/1.
<Sysname> reset l2vpn statistics ac interface gigabitethernet 1/0/1
reset l2vpn statistics tunnel
Use reset l2vpn statistics tunnel to clear packet statistics on VXLAN tunnel interfaces.
reset l2vpn statistics tunnel [ vsi vsi-name ]
For hardware compatibility with this command, see the tunnel statistics enable command.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears packet statistics on VXLAN tunnel interfaces of all VSIs.
# Clear packet statistics on VXLAN tunnel interfaces of all VSIs.
<Sysname> reset l2vpn statistics tunnel
tunnel statistics enable (VSI view)
selective-flooding mac-address
Use selective-flooding mac-address to enable selective flood for a MAC address.
Use undo selective-flooding mac-address to disable selective flood for a MAC address.
selective-flooding mac-address mac-address
undo selective-flooding mac-address mac-address
Selective flood is disabled for all MAC addresses.
VSI view
mac-address: Specifies a MAC address. The MAC address cannot be all Fs.
This command excludes a remote MAC address from the flood suppression done by using the flooding disable command. The VTEP will flood the frames destined for the specified MAC address to remote sites when unknown-unicast floods are confined to the local site.
# Enable selective flood for 000f-e201-0101 on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
flooding disable
service-class
Use service-class to set a service class value for outgoing VXLAN packets.
Use undo service-class to restore the default.
service-class service-class-value
undo service-class
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware
Command compatibility
MSR610
No
Yes
No
No
Yes
Yes
Yes
Yes
MSR2600-10-X1
Yes
MSR 2630
No
No
No
Yes
Yes
Yes
Yes
Yes
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
Yes
MSR830-4LM-WiNet
Yes
Yes
Yes
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR860-6EI-XS
Yes
MSR860-6HI-XS
Yes
MSR2630-XS
Yes
MSR3600-28-XS
No
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
No service class value is set for outgoing VXLAN packets.
VSI view
service-class-value: Specifies a service class value. The value range for this argument is 0 to 15.
Class Based Tunnel Selection (CBTS) compares the service class value of VXLAN packets with the service class values of MPLS TE tunnels. CBTS uses the following rules to select a tunnel to forward the traffic:
·     If the packets match only one MPLS TE tunnel, CBTS uses this tunnel.
·     If the packets match multiple MPLS TE tunnels, CBTS randomly selects one tunnel from them.
·     If the packets do not match any MPLS TE tunnel, CBTS selects the MPLS TE tunnel that meets the following requirements:
¡     Its service class value is smaller than the service class value of the traffic.
¡     Its service class value is the nearest to the service class value of the traffic.
If multiple qualified tunnels exist, CBTS randomly selects one of them to forward the packets. If an MPLS TE tunnel is not configured with a service class value, this tunnel has the smallest service class value.
The service class value is used only when MPLS TE tunnels are used to forward the VXLAN packets. This value is meaningless if any other tunnel is used to forward the VXLAN packets.
To set the service class value for an MPLS TE tunnel, use the mpls te service-class command. For more information about this command, see MPLS TE commands in MPLS Command Reference.
If you execute the service-class command multiple times for a VSI, the most recent configuration takes effect.
# Set the service class value to 2 for outgoing VXLAN packets.
[Sysname] vsi vpna
[Sysname-vsi-vpna] service-class 2
display l2vpn vsi
shutdown
Use shutdown to shut down a VSI.
Use undo shutdown to bring up a VSI.
shutdown
VSIs are not manually shut down.
VSI view
Use this command to temporarily disable a VSI to provide Layer 2 switching services. The shutdown action does not change settings on the VSI. You can continue to configure the VSI. After you bring up the VSI again, the VSI provides services based on the latest settings.
# Shut down VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
display l2vpn vsi
tunnel
Use tunnel to assign a VXLAN tunnel to a VXLAN.
Use undo tunnel to remove a VXLAN tunnel from a VXLAN.
tunnel tunnel-number { flooding-proxy | no-split-horizon }
undo tunnel tunnel-number
A VXLAN does not contain VXLAN tunnels.
VXLAN view
tunnel-number: Specifies a tunnel interface number. The value range for this argument is 0 to 10239. The tunnel must be a VXLAN tunnel.
flooding-proxy: Enables flood proxy on the tunnel for the VTEP to send flood traffic to the flood proxy server. The flood proxy server replicates and forwards flood traffic to remote VTEPs. If you do not specify this keyword, flood proxy is disabled on the tunnel.
no-split-horizon: Disables split horizon on the tunnel. The tunnel can forward the traffic that is received on ACs and other VXLAN tunnels. If you do not specify this keyword, split horizon is enabled on the tunnel, and it does not forward the traffic that is received on other VXLAN tunnels.
This command assigns a VXLAN tunnel to a VXLAN to provide Layer 2 connectivity for the VXLAN between two sites. In unicast mode, the system floods unknown unicast, multicast, and broadcast traffic to each tunnel in the VXLAN.
You can assign multiple VXLAN tunnels to a VXLAN, and configure a VXLAN tunnel to trunk multiple VXLANs.
On a VSI, you can enable flood proxy on multiple VXLAN tunnels. The first tunnel that is enabled with flood proxy works as the primary proxy tunnel to forward broadcast, multicast, and unknown unicast traffic. Other proxy tunnels are backups that do not forward traffic when the primary proxy tunnel is operating correctly.
If you disable split horizon on a VXLAN tunnel, make sure the corresponding VXLAN does not have another VXLAN tunnel that is destined for the same remote VTEP.
To modify the flood proxy or split horizon setting on a VXLAN tunnel, you must first use the undo tunnel command to remove the tunnel.
# Assign VXLAN tunnels 1 and 2 to VXLAN 10000.
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
tunnel bfd enable
Use tunnel bfd enable to enable BFD on a VXLAN tunnel interface.
Use undo tunnel bfd enable to disable BFD on a VXLAN tunnel interface.
tunnel bfd enable destination-mac mac-address
BFD is disabled on a VXLAN tunnel interface.
VXLAN tunnel interface view
destination-mac mac-address: Specifies a destination MAC address in H-H-H format for BFD control packets. The MAC address can be a remote VTEP address or a multicast address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
Enable BFD on both ends of a VXLAN tunnel for quick link connectivity detection. The VTEPs periodically send BFD single-hop control packets to each other through the VXLAN tunnel. A VTEP sets the tunnel state to Defect if it has not received control packets from the remote end for 5 seconds. In this situation, the tunnel interface state is still Up. The tunnel state will change from Defect to Up if the VTEP can receive BFD control packets again.
# Enable BFD on VXLAN tunnel interface Tunnel 9, and specify 1-1-1 as the destination MAC address for BFD control packets.
[Sysname] interface tunnel 9 mode vxlan
[Sysname-Tunnel9] tunnel bfd enable destination-mac 1-1-1
tunnel global source-address
Use tunnel global source-address to specify a global source address for VXLAN tunnels.
Use undo tunnel global source-address to restore the default.
tunnel global source-address { ipv4-address | ipv6 ipv6-address }
undo tunnel global source-address [ ipv6 ]
No global source address is specified for VXLAN tunnels.
ipv4-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify the ipv6 keyword when executing the undo tunnel global source-address command, the command deletes the global source IPv4 address for VXLAN tunnels.
A VXLAN tunnel uses the global source address if you do not specify a source interface or source address for the tunnel.
The global source address takes effect only on VXLAN tunnels.
IPv4 VXLAN tunnels use the global source IPv4 address, and IPv6 VXLAN tunnels use the global source IPv6 addresses.
# Specify 1.1.1.1 as the global source address for VXLAN tunnels.
[Sysname] tunnel global source-address 1.1.1.1
Use tunnel statistics enable to enable packet statistics for all VXLAN tunnels associated with a VSI.
Use undo tunnel statistics enable to disable packet statistics for all VXLAN tunnels associated with a VSI.
Hardware
MSR610
No
Yes
No
No
Yes
Yes
Yes
Yes
MSR2600-10-X1
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
Yes
MSR830-4LM-WiNet
Yes
Yes
Yes
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR860-6EI-XS
Yes
MSR860-6HI-XS
Yes
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
The packet statistics feature is disabled for the VXLAN tunnels associated with a VSI.
VSI view
# Enable packet statistics for all VXLAN tunnels associated with VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna] tunnel statistics enable
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSIs exist.
A VSI acts as a virtual switch to provide Layer 2 switching services for a VXLAN on a VTEP. A VSI has all functions of a physical Ethernet switch, including source MAC address learning, MAC address aging, and flooding.
A VSI can provide services only for one VXLAN.
# Create VSI vxlan10 and enter VSI view.
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
display l2vpn vsi
vxlan
Use vxlan to create a VXLAN and enter its view, or enter the view of an existing VXLAN.
Use undo vxlan to restore the default.
vxlan vxlan-id
undo vxlan
No VXLANs exist.
VSI view
You can create only one VXLAN for a VSI. The VXLAN ID for each VSI must be unique.
# Create VXLAN 10000 for VSI vpna and enter VXLAN view.
[Sysname] vsi vpna
vsi
vxlan fast-forwarding enable
Use vxlan fast-forwarding enable to enable VXLAN fast forwarding.
Use undo vxlan fast-forwarding enable to disable VXLAN fast forwarding.
VXLAN fast forwarding is disabled.
VXLAN fast forwarding enables the device to bypass QoS and security services when the device forwards data traffic over VXLAN tunnels based on the software. As a best practice, enable this feature to improve forwarding speed only when QoS and security services are not configured on the following interfaces:
·     VSI interfaces.
·     Traffic outgoing interfaces for VXLAN tunnels.
When VXLAN fast forwarding is enabled, a VXLAN tunnel cannot use ECMP routes to load share traffic. Instead, it selects one route from the ECMP routes to forward VXLAN packets.
# Enable VXLAN fast forwarding.
<Sysname> system
[Sysname] vxlan fast-forwarding enable
vxlan invalid-udp-checksum discard
Use vxlan invalid-udp-checksum discard to enable the device to drop the VXLAN packets that fail UDP checksum check.
Use undo vxlan invalid-udp-checksum discard to restore the default.
The device does not check the UDP checksum of VXLAN packets.
This command enables the device to check the UDP checksum of VXLAN packets.
The device always sets the UDP checksum of VXLAN packets to 0. For compatibility with third-party devices, a VXLAN packet can pass the check if its UDP checksum is 0 or correct. If its UDP checksum is incorrect, the VXLAN packet fails the check and is dropped.
# Enable the device to drop the VXLAN packets that fail UDP checksum check.
[Sysname] vxlan invalid-udp-checksum discard
vxlan invalid-vlan-tag discard
vxlan local-mac report
Use vxlan local-mac report to enable local-MAC logging.
Use undo vxlan local-mac report to disable local-MAC logging.
Local-MAC logging is disabled.
When the local-MAC logging feature is enabled, the VXLAN module immediately sends a log message with its local MAC addresses to the information center. When a local MAC address is added or removed, a log message is also sent to the information center to notify the local-MAC change.
With the information center, you can set log message filtering and output rules, including output destinations. For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
# Enable local-MAC logging.
[Sysname] vxlan local-mac report
vxlan source udp-port five-tuple
Use vxlan source udp-port five-tuple to configure a VXLAN tunnel interface to generate the source UDP port number in the VXLAN encapsulation based on the IP five-tuple of the inner Ethernet frame.
Use undo vxlan source udp-port five-tuple to restore the default.
Hardware
MSR610
No
Yes
No
No
Yes
Yes
Yes
Yes
MSR2600-10-X1
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
Yes
MSR830-4LM-WiNet
Yes
Yes
Yes
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR860-6EI-XS
Yes
MSR860-6HI-XS
Yes
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
The source UDP port number in the VXLAN encapsulation is generated based on the source and destination MAC addresses of the inner Ethernet frame.
This command takes effect only on IPv4-based VXLAN. Only manually created VXLAN tunnel interfaces support this command.
# Configure VXLAN tunnel interface Tunnel 1 to generate the source UDP port number in the VXLAN encapsulation based on the IP five-tuple of the inner Ethernet frame.
[Sysname] interface tunnel 1 mode vxlan
[Sysname-Tunnel1] vxlan source udp-port five-tuple
vxlan source udp-port acl
Use vxlan tunnel mac-learning disable to disable remote-MAC address learning.
Use undo vxlan tunnel mac-learning disable to enable remote-MAC address learning.
Remote-MAC address learning is enabled.
When network attacks occur, use this command to prevent the device from learning incorrect remote MAC addresses in the data plane.
# Disable remote-MAC address learning.
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port
Use vxlan udp-port to set the destination UDP port number for VXLAN packets.
Use undo vxlan udp-port to restore the default.
vxlan udp-port port-number
undo vxlan udp-port
The destination UDP port number is 4789 for VXLAN packets.
port-number: Specifies a UDP port number in the range of 1 to 65535. As a best practice, specify a port number in the range of 1024 to 65535 to avoid conflict with well-known ports.
You must configure the same destination UDP port number on all VTEPs in a VXLAN.
# Set the destination UDP port number to 6666 for VXLAN packets.
[Sysname] vxlan udp-port 6666
xconnect vsi
Use xconnect vsi to map an AC to a VSI.
Use undo xconnect vsi to restore the default.
xconnect vsi vsi-name [ track track-entry-number&<1-3> ]
undo xconnect vsi
An AC is not mapped to any VSI.
Interface view
vsi-name: Specifies the VSI name, a case-sensitive string of 1 to 31 characters.
track track-entry-number&<1-3>: Specifies a space-separated list of up to three track entry numbers in the range of 1 to 1024. The AC is up only if a minimum of one associated track entry is in positive state.
For traffic that matches a Layer 3 interface, the system uses the VSI's MAC address table to make a forwarding decision.
# Map GigabitEthernet 1/0/1 to VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-GigabitEthernet1/0/1] xconnect vsi vpn1
display l2vpn service-instance
encapsulation
vsi
VXLAN IP gateway commands
arp distributed-gateway dynamic-entry synchronize
Use arp distributed-gateway dynamic-entry synchronize to enable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
Use undo arp distributed-gateway dynamic-entry synchronize to disable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
Dynamic ARP entry synchronization is disabled for distributed VXLAN IP gateways.
When local proxy ARP is enabled on distributed VXLAN IP gateways, each gateway learns ARP information independently. A gateway does not forward ARP packets destined for its local VSI interfaces to other gateways. For distributed VXLAN IP gateways to have the same ARP entries, you must enable dynamic ARP entry synchronization.
A controller or the EVPN feature can also synchronize ARP entries among distributed VXLAN IP gateways. When you use a controller or the EVPN feature, do not enable dynamic ARP entry synchronization.
# Enable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
[Sysname] arp distributed-gateway dynamic-entry synchronize
distributed-gateway local
local-proxy-arp enable (Layer 3—IP Services Command Reference)
bandwidth
Use bandwidth to set the expected bandwidth for a VSI interface or VSI subinterface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth (in kbps) equals the interface baudrate divided by 1000.
VSI interface view
bandwidth-value: Specifies the expected bandwidth, in the range of 1 to 400000000 kbps.
# Set the expected bandwidth to 10000 kbps for VSI-interface 100.
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] bandwidth 10000
default
Use default to restore the default settings for a VSI interface or VSI subinterface.
default
VSI interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions.
To resolve this problem:
1.     Use the display this command in interface view to identify these commands.
2.     Use their undo forms or follow the command reference to restore their default settings.
3.     If the restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for VSI-interface 100.
[Sysname-Vsi-interface100] default
This command will restore the default settings. Continue? [Y/N]:y
description
Use description to configure the description of a VSI interface or VSI subinterface.
The description of a VSI interface or VSI subinterface is interface-name plus Interface (for example, Vsi-interface100 Interface).
VSI interface view
# Configure the description as gateway for VXLAN 10 for VSI-interface 100.
[Sysname-Vsi-interface100] description gateway for VXLAN 10
display interface vsi-interface
Use display interface vsi-interface to display information about VSI interfaces
display interface [ vsi-interface [ vsi-interface-id ] [ brief [ description | down ] ]
vsi-interface [ vsi-interface-id]: Specifies a VSI interface by its number. Make sure the specified VSI interface has been created on the device. If you do not specify the vsi-interface [ vsi-interface-id ] option, this command displays information about all interfaces except for VA interfaces. If you specify only the vsi-interface keyword, this command displays information about all VSI interfaces. If you specify a VSI interface, this command displays information about the specified interface. For more information about VA interfaces, see PPPoE configuration in Layer 2—WAN Access Configuration Guide.
brief: Display brief interface information. If you do not specify this keyword, the command displays detailed interface information.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays interfaces that are physically down as well as the down reason. If you do not specify this keyword, the command does not filter output by physical interface state.
# Display information about VSI-interface 100.
<Sysname> display interface vsi-interface 100
Vsi-interface100
Current state: UP
Line protocol state: UP
Description: Vsi-interface100 Interface
Bandwidth: 1000000 kbps
IP packet frame type: Ethernet II, hardware address: 0011-2200-0102
IPv6 packet frame type: Ethernet II, hardware address: 0011-2200-0102
Table 8 Command output
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface:
·     UP(spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist.
Description of the interface.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-allocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     Cellular-allocated—IP address allocated through the modem manufacturer's proprietary protocol. For more information, see 3G/4G modem management in Layer 2WAN Access Configuration Guide.
·     MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide.
·     MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide.
IPv4 packet framing format.
hardware address
MAC address.
IPv6 packet framing format.
Physical
Physical type of the interface, which is fixed at Unknown.
baudrate
Interface baudrate in kbps.
Last time when the reset counters interface vsi-interface command was used to clear interface statistics.
This field displays Never if the reset counters interface vsi-interface command has never been used on the interface since the device startup.
Average input rate for the last 300 seconds.
Average output rate for the last 300 seconds.
Incoming traffic statistics on the interface:
·     Number of incoming packets.
·     Number of incoming bytes.
·     Number of dropped incoming packets.
Outgoing traffic statistics on the interface:
·     Number of outgoing packets.
·     Number of outgoing bytes.
·     Number of dropped outgoing packets.
# Display brief information about all VSI interfaces.
<Sysname> display interface vsi-interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Vsi100               DOWN DOWN     --
# Display brief information and complete description for VSI-interface 100.
<Sysname> display interface vsi-interface 100 brief description
Vsi100               UP    UP      1.1.1.1         VSI-interface100
# Displays interfaces that are physically down and the down reason.
Interface            Link   Cause
Vsi100               DOWN   Administratively
Vsi200               DOWN   Administratively
Table 9 Command output
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     UP (s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag.
·     DOWN—The data link layer protocol of the interface is down.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—The interface is not mapped to any VSI, or the mapped VSI does not have any AC or VXLAN tunnel.
Use distributed-gateway local to specify a VSI interface as a distributed gateway to provide services for the local site.
Use undo distributed-gateway local to restore the default.
A VSI interface is not a distributed gateway.
VSI interface view
If a VXLAN uses distributed gateway services, you must assign the same IP address to the VXLAN's VSI interfaces on different VTEPs. To avoid IP address conflicts, you must specify the VSI interface on each VTEP as a distributed gateway.
# Specify VSI-interface 100 as a distributed gateway.
[Sysname-Vsi-interface100] distributed-gateway local
gateway subnet
Use gateway subnet to assign a subnet to a VSI.
Use undo gateway subnet to remove a subnet from a VSI.
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
undo gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
No subnet is assigned to a VSI.
VSI view
ipv4-address: Specifies an IPv4 subnet address in dotted-decimal notation.
wildcard-mask: Specifies a wildcard mask in dotted decimal notation. In contrast to a network mask, the 0 bits in a wildcard mask represent "do care" bits, and the 1 bits represent "don't care" bits. If the "do care" bits in a packet's IP address are identical to the "do care" bits in the specified subnet address, the packet is assigned to the VSI. All "don't care" bits are ignored. The 0s and 1s in a wildcard mask can be noncontiguous. For example, 0.255.0.255 is a valid wildcard mask.
ipv6-address prefix-length: Specifies an IPv6 subnet address and the address prefix length in the range of 1 to 128.
You must configure this command on VSIs that share a gateway interface. This command enables the VSI interface to identify the VSI of a packet.
You can assign a maximum of eight IPv4 and IPv6 subnets to a VSI.
You must specify a gateway interface for a VSI before you can assign subnets to the VSI. If you remove the gateway interface from the VSI, the VSI's subnet settings are automatically deleted.
For VSIs that share a gateway interface, the subnets must be unique.
# Assign subnet 100.0.10.0/24 to VSI vxlan.
[Sysname] vsi vxlan
[Sysname-vsi-vxlan] gateway subnet 100.0.10.0 0.0.0.255
gateway vsi-interface
Use gateway vsi-interface to specify a gateway interface for a VSI.
Use undo gateway vsi-interface to restore the default.
gateway vsi-interface vsi-interface-id
No gateway interface is specified for a VSI.
VSI view
vsi-interface-id: Specifies a VSI interface by its number. Make sure the specified VSI interface has been created on the device.
A VSI can have only one gateway interface. Multiple VSIs can share a gateway interface.
# Specify VSI-interface 100 as the gateway interface for VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna] gateway vsi-interface 100
Use interface vsi-interface to create a VSI interface and enter its view, or enter the view of an existing VSI interface.
Use undo interface vsi-interface to delete a VSI interface.
interface vsi-interface vsi-interface-id
undo interface vsi-interface vsi-interface-id
No VSI interfaces exist.
vsi-interface-id: Specifies a VSI interface number. The value range for this argument is 0 to 8191. You can create a maximum of 256 VSI interfaces.
# Create VSI-interface 100 and enter VSI interface view.
mac-address
Use mac-address to assign a MAC address to a VSI interface or VSI subinterface.
Use undo mac-address to restore the default.
undo mac-address
VSI interfaces use the bridge MAC address.
VSI interface view
# Assign MAC address 0001-0001-0001 to VSI-interface 100.
[Sysname-Vsi-interface100] mac-address 1-1-1
mtu
Use mtu to set the MTU for a VSI interface.
mtu size
undo mtu
The default MTU of VSI interfaces is 1500 bytes.
VSI interface view
size: Specifies an MTU value in the range of 46 to 9600 bytes.
# Set the MTU to 1430 bytes for VSI-interface 100.
[Sysname-Vsi-interface100] mtu 1430
Use reset counters interface vsi-interface to clear packet statistics on VSI interfaces
reset counters interface [ vsi-interface [ vsi-interface-id ] ]
vsi-interface [ vsi-interface-id]: Specifies a VSI interface by its number. Make sure the specified VSI interface has been created on the device. If you do not specify the vsi-interface [ vsi-interface-id ] option, this command clears packet statistics on all interfaces except for VA interfaces. If you specify only the vsi-interface keyword, this command clears packet statistics on all VSI interfaces. If you specify a VSI interface, this command clears packet statistics on the specified interface.
Use this command to clear history statistics before you collect traffic statistics for a time period.
# Clear packet statistics on VSI-interface 100.
<Sysname> reset counters interface vsi-interface 100
shutdown
Use shutdown to shut down a VSI interface.
Use undo shutdown to bring up a VSI interface.
shutdown
A VSI interface or subinterface is not manually shut down.
VSI interface view
CAUTION
CAUTION:
If you shut down a VSI interface, the VXLAN network using this VSI interface as the gateway will be unable to communicate with other networks at Layer 3. Make sure you are fully aware of the impact of this command when you use it on a live network.
# Shut down VSI-interface 100.
[Sysname-Vsi-interface100] shutdown
vtep group member local
Use vtep group member local to assign the local VTEP to a VTEP group.
Use undo vtep group member local to remove the local VTEP from a VTEP group.
vtep group group-ip member local member-ip
undo vtep group group-ip member local
A VTEP is not assigned to any VTEP group.
group-ip: Specifies a VTEP group by its group IP address. The IP address must already exist on the local VTEP.
member-ip: Specifies the member VTEP IP address for the local VTEP. The IP address must already exist on the local VTEP.
Member VTEPs in a VTEP group cannot use the group IP address or share an IP address.
# Assign the local VTEP to VTEP group 1.1.1.1, and specify 2.2.2.2 as the member VTEP IP address of the local VTEP.
[Sysname] vtep group 1.1.1.1 member local 2.2.2.2
vtep group member remote
Use vtep group member remote to specify a VTEP group and its member VTEPs.
Use undo vtep group member remote to remove a VTEP group and its member VTEPs.
vtep group group-ip member remote member-ip&<1-8>
undo vtep group group-ip member remote
No VTEP group is specified.
member-ip&<1-8>: Specifies a space-separated list of up to eight member VTEP IP addresses.
# Specify VTEP group 1.1.1.1 and its member VTEPs at 2.2.2.2, 3.3.3.3, and 4.4.4.4.
[Sysname] vtep group 1.1.1.1 member remote 2.2.2.2 3.3.3.3 4.4.4.4
vxlan tunnel arp-learning disable
Use vxlan tunnel arp-learning disable to disable remote ARP learning for VXLANs.
Use undo vxlan tunnel arp-learning disable to enable remote ARP learning for VXLANs.
Remote ARP learning is enabled for VXLANs.
By default, the device learns ARP information of remote VMs from packets received on VXLAN tunnel interfaces. To save resources on VTEPs in an SDN transport network, you can temporarily disable remote ARP learning when the controller and VTEPs are synchronizing entries. After the entry synchronization is completed, use the undo vxlan tunnel arp-learning disable command to enable remote ARP learning.
As a best practice, disable remote ARP learning for VXLANs only when the controller and VTEPs are synchronizing entries.
# Disable remote ARP learning for VXLANs.
<Sysname> system
[Sysname] vxlan tunnel arp-learning disable
  • Become a Partner
  • Partner Resources
