19-LISP Command References
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References(V7)-R6749-6W10019-LISP Command References
Table of Contents
Related Documents
01-LISP commands
01-LISP commands 219.13 KB
LISP commands
IPv4 LISP VRF instances are not supported on the following routers:
·     MSR810.
·     MSR810-10-PoE.
·     MSR810-LM.
·     MSR810-LM-HK.
·     MSR810-W.
·     MSR810-W-DB.
·     MSR810-W-LM.
·     MSR810-W-LM-HK.
The following compatibility matrixes show the support of hardware platforms for LISP:
Hardware
LISP compatibility
MSR610
No
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
Yes
MSR810-LMS, MSR810-LUS
No
MSR810-SI, MSR810-LM-SI
No
MSR810-LMS-EA, MSR810-LME
Yes
MSR1004S-5G, MSR1004S-5G-CN
Yes
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN
Yes
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
No
MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
No
Yes
MSR3600-28-G-DP, MSR3600-51-G-DP
Yes
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
Yes
MSR3610, MSR3620, MSR3620-DP, MSR3640, MSR3660
Yes
MSR3610-G, MSR3620-G
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
LISP compatibility
MSR810-W-WiNet, MSR810-LM-WiNet
Yes
MSR830-4LM-WiNet
Yes
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
Yes
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
Yes
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
LISP compatibility
MSR860-6EI-XS
Yes
MSR860-6HI-XS
Yes
MSR2630-XS
No
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
LISP compatibility
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
Data Software licenses are required for some devices to support LISP. For more information about licensing, see license management in Fundamentals Configuration Guide.
allowed-locator
Use allowed-locator to configure an MS to permit only the specified RLOC address.
Use undo allowed-locator to remove the configuration.
allowed-locator rloc-address
undo allowed-locator rloc-address
An MS permits all RLOC addresses.
IPv4 LISP site view
rloc-address: Specifies an RLOC in dotted decimal notation.
For an ETR to successfully register with an MS, the RLOC addresses in the Map-Register messages sent by the ETR must be permitted by the MS.
This command applies only to MSs.
You can execute this command multiple times to specify a maximum of eight RLOC addresses.
# Configure the MS to permit the RLOC address 11.11.11.11.
[Sysname] lisp
[Sysname-lisp] site site-1
[Sysname-lisp-site-site-1] allowed-locator 11.11.11.11
authentication-mode
Use authentication-mode to set the authentication mode for an MS.
Use undo authentication-mode to restore the default.
authentication-mode sha-1 authentication-key { ciphertext | plaintext } string
authentication-mode none
No authentication mode is set for an MS and the MS does not accept Map-Register messages.
IPv4 LISP site view
sha-1: Configures the MS to use SHA-1 to authenticate Map-Register messages sent by the ETRs.
ciphertext: Specifies a key in encrypted form.
plaintext: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 33 to 73 characters.
none: Configures the MS to accept Map-Register messages without authentication.
For an ETR to successfully register with an MS, make sure the MS and the ETR have the same authentication settings.
# Configure the MS to use SHA-1 and the plaintext key abc to authenticate Map-Register messages from the ETRs.
[Sysname] lisp
[Sysname-lisp-site-site-1] authentication-mode sha-1 authentication-key plaintext abc
etr map-server
database-mapping (dynamic-EID view)
Use database-mapping to configure an EID-to-RLOC mapping.
Use undo database-mapping to delete an EID-to-RLOC mapping.
database-mapping eid-prefix prefix-length locator priority priority weight weight
undo database-mapping eid-prefix prefix-length locator
No EID-to-RLOC mapping is configured.
Dynamic-EID view
eid-prefix prefix-length: Specifies an EID prefix and its length. The eid-prefix argument represents the EID prefix in dotted decimal notation. The prefix-length argument represents the prefix length in the range of 0 to 32.
locator: Specifies an RLOC address. Typically, a loopback interface's address is used.
priority priority: Specifies the priority of the RLOC address, in the range of 0 to 255.
weight weight: Specifies the weight of the RLOC address, in the range of 0 to 100.
A host is permitted to roam in and out only if its IP prefix is in the dynamic EID space.
# Configure an EID-to-RLOC mapping by setting the dynamic EID prefix to 10.1.1.0/24, RLOC address to 11.11.11.11, priority to 1, and weight to 50.
[Sysname] lisp
[Sysname-lisp] dynamic-eid DE
[Sysname-lisp-dynamic-eid-DE] database-mapping 10.1.1.0 24 11.11.11.11 priority 1 weight 50
roaming-eid-prefix
database-mapping (LISP view/LISP-VRF view)
LISP view
LISP-VRF view
You can map a maximum of eight RLOC addresses to one EID prefix.
# Configure an EID-to-RLOC mapping by setting the EID prefix to 10.1.1.0/24, RLOC address to 11.11.11.11, priority to 1, and weight to 50.
[Sysname] lisp
[Sysname-lisp] database-mapping 10.1.1.0 24 11.11.11.11 priority 1 weight 50
eid-prefix
description
Use description to configure a description for an IPv4 LISP site.
The IPv4 LISP site does not have a description.
IPv4 LISP site view
# Configure the description as abc for the IPv4 LISP site.
[Sysname] lisp
[Sysname-lisp] site site1
[Sysname-lisp-site-site1] description abc
display lisp dynamic-eid
Use display lisp dynamic-eid to display information about the LISP dynamic EID detection policies and the detected dynamic EIDs.
display lisp dynamic-eid [ name dynamic-eid-name ] [ default | vrf vrf-name ] [ verbose ]
name dynamic-eid-name: Specifies a LISP dynamic EID detection policy by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a LISP dynamic EID detection policy, this command displays information about all LISP dynamic EID detection policies.
default: Displays information for the public LISP network.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
verbose: Displays detailed information about the LISP dynamic EID detection policies and the detected dynamic EIDs. If you do not specify this keyword, the command displays brief information about the LISP dynamic EID detection policies and the detected dynamic EIDs.
If you do not specify any parameters, this command displays information about the LISP dynamic EID detection policies and the detected dynamic EIDs for all IPv4 LISP VRF instances.
# Display brief information about all LISP dynamic EID detection policies and the detected dynamic EIDs.
<Sysname> display lisp dynamic-eid
LISP dynamic EID information for public VRF
* = Dyn-EID learned by site-based Map-Notify
Dyn-EID name   Dynamic EID      Uptime                Interface
a              1.1.1.2          00:01:05                 GigabitEthernet1/0/1
# Display detailed information about all LISP dynamic EID detection policies and the detected dynamic EIDs.
<Sysname> display lisp dynamic-eid verbose
Dynamic EID name: a
  Database-mapping EID-prefix: 1.1.1.0/24, instance-id: 0, LSBs: 0x00000001
    Locator: 10.10.10.4, Priority: 1, Weight: 1
             Uptime: 00:03:53, State: up, local
  Registering more-specific dynamic-EIDs
  Map servers: 10.10.10.3
  Site-based multicast Map-Notify group: 239.0.0.2
  Roaming dynamic EIDs allowed: 2.2.2.0/24
  Number of roaming dynamic EIDs discovered: 1
  Last dynamic EID discovered: 1.1.1.2, 00:03:54 ago
  Roaming dynamic EIDs:
         10.10.10.3, GigabitEthernet1/0/1, uptime: 00:03:54
                     discovered by: ip packet reception
         10.10.10.4, NULL0, uptime: 00:03:54
                     discovered by: EID-Notify
                     EID-Notify Locators:
                       172.16.0.2
Locator
RLOC address.
priority
Priority of the RLOC address.
weight
Weight of the RLOC address.
Uptime
Time elapsed since the RLOC address became reachable.
state
State of the RLOC address.
Map-Notify group
Multicast address for Map-Notify messages.
Dynamic EID prefix range in which the dynamic EIDs are permitted to roam in.
Number of detected dynamic EIDs.
The most recently detected dynamic EID and time when the dynamic EID was detected.
The detected dynamic EIDs.
Interface on which the dynamic EIDs were detected.
discovered by
How the roaming host was detected:
·     ip packet reception—Through IP packets.
·     arp packet reception—Through gratuitous ARP packets.
·     site-based Map-Notify—Through Map-Notify messages.
·     EID-Notify—Through EID-Notify messages.
EID-Notify Locators
RLOC addresses that are carried in the EID-Notify message.
reset lisp dynamic-eid
display lisp ipv4
Use display lisp ipv4 to display IPv4 LISP configuration information.
display lisp ipv4 [ default | vrf vrf-name ]
default: Displays the public LISP network configuration information.
If you do not specify any parameters, this command displays configuration information for all LISP VRF instances.
# Display the public LISP network configuration information.
<Sysname> display lisp ipv4 default
LISP IP Configuration Information for Public VRF (iid 0)
  Ingress Tunnel Router (ITR):    disabled
  Egress Tunnel Router (ETR):     disabled
  Proxy-ITR Router (PITR):        disabled
  Proxy-ETR Router (PETR):        disabled
  Locator VRF:                    default
  LISP-NAT Interworking:          disabled
  ITR send Map-Request:           disabled
  ITR send Data-Probe:            disabled
  LISP ALT-VRF:                   not configured
  ETR glean mapping:              disabled, verify disabled
  ETR accept mapping data:        disabled, verify disabled
  ETR Map-Cache TTL:              1440 minutes
  Shortest EID-prefix allowed:    /16
  Locator Reachability Algorithms:
    Echo-nonce algorithm:         disabled
    TCP-counts algorithm:         disabled
    RLOC-probe algorithm:         disabled
  Static mappings configured:     0
  Map-Cache limit:                0xFFFFFFFF
  Map-Cache size:                 0
  Map-Resolver (MR):              disabled
  Map-Server (MS):                disabled
LISP IP Configuration Information for Public VRF/LISP IP Configuration Information for VRF vrfname
Indicates that the configuration information is for the public LISP network/LISP VRF instance.
iid
Instance ID.
State of the ITR feature:
·     enabled
·     disabled
State of the ETR feature:
·     enabled
·     disabled
State of the PITR feature:
·     enabled
·     disabled
State of the PETR feature:
·     enabled
·     disabled
Locator VRF
Name of the LISP VRF instance that the RLOC address space belongs. If this filed displays default, the RLOC address space belongs to the public LISP network.
State of the NAT feature:
·     enabled
·     disabled
Whether the feature of ITR sending Map-Request messages is enabled:
·     enabled
·     disabled
ITR send Data-Probe
Whether the feature of ITR sending data-probe messages is enabled:
·     enabled
·     disabled
LISP ALT-VRF
State of the Alternative Topology (ALT) VRF feature:
·     vrfname—Name of the ALT VRF.
·     not configured—The ALT VRF feature is not configured.
ETR glean mapping
Whether the feature of ETR gleaning EID-to-RLOC mappings from LISP encapsulated data packets is enabled:
·     enabled
·     disabled
Whether the feature of ETR verifying the gleaned EID-to-RLOC mappings is enabled:
·     verify enabled
·     verify disabled
Whether the feature of ETR accepting the mapping information in Map-Request messages is enabled:
·     enabled
·     disabled
Whether the feature of ETR verifying the mapping information is enabled:
·     verify enabled
·     verify disabled
ETR Map-Cache TTL
TTL value in Map-Reply and Map-Register messages, in minutes.
The minimum prefix length permitted by an ITR for EIDs in Map-Reply messages.
Locator reachability detection algorithm:
·     Echo-nonce algorithm
·     TCP-counts algorithm
·     RLOC-probe algorithm
State of the Echo-nonce algorithm:
·     enabled
·     disabled
State of the TCP-counts algorithm:
·     enabled
·     disabled
State of the RLOC-probe algorithm:
·     enabled
·     disabled
Number of static mapping cache entries.
Map-Cache limit
Maximum number of mapping cache entries that can be created.
Map-Cache size
Number of existing mapping cache entries.
Map-Resolver (MR)
State of the MR feature:
·     enabled
·     disabled
Map-Server (MS)
State of the MS feature:
·     enabled
·     disabled
display lisp ipv4 database
Use display lisp ipv4 database to display IPv4 LISP local EID prefix information.
display lisp ipv4 database [ destination-eid-prefix [ prefix-length ] ] [ default | vrf vrf-name ]
destination-eid-prefix [ prefix-length ]: Specifies a local EID prefix in dotted decimal notation. The prefix-length argument specifies the prefix length in the range of 0 to 32. If you do not specify a local EID prefix, this command displays all IPv4 LISP local EID prefix information.
default: Displays information about the local EID prefixes for the public IPv4 LISP network.
This command applies only to ETRs.
If you do not specify any parameters, this command displays information about the local EID prefixes for all IPv4 LISP VRF instances.
# Display information about the local EID prefixes for the public IPv4 LISP network.
<Sysname> display lisp ipv4 database default
LISP ETR IP Mapping Database for Public VRF (iid 0), 1 entries
EID-prefix: 192.13.1.0/24, instance-id: 0, LSBs: 0x00000007, Sync Flags: 0x0001
  Locator: 1.1.1.1, priority: 1, weight: 10
           Uptime: 00:17:40, state: up, local
           Data in/out: 0/0
  Locator: 11.11.11.11, priority: 1, weight: 10
           Data in/out: 0/0
  Locator: 192.12.1.1, priority: 1, weight: 10
           Data in/out: 0/0
LISP ETR IP Mapping Database for Public VRF/LISP ETR IP Mapping Database for VRF vrfname
Indicates that the local EID prefix information is for the public LISP network/LISP VRF instance.
iid
Instance ID.
entries
Number of EID prefixes.
LSBs
The locator status bits.
Sync Flags
EID synchronization flag. 0x0001 means that the EIDs are synchronized to the kernel.
Locator
RLOC address for the EID.
priority
weight
Uptime
Time during which the RLOC address is reachable.
Downtime
Time during which the RLOC address is unreachable.
state
State of the RLOC address:
·     up
·     down
·     admin-down
·     local
Data in/out
Number of encapsulated/decapsulated data packets.
display lisp ipv4 data-cache
Use display lisp ipv4 data-cache to display IPv4 LISP data cache entries.
display lisp ipv4 data-cache [ destination-eid-prefix ] [ default | vrf vrf-name ]
destination-eid-prefix: Specifies a destination EID prefix in dotted decimal notation. If you do not specify a destination EID prefix, this command displays all IPv4 LISP data cache entries.
default: Displays data cache entries for the public LISP network.
This command applies only to ITRs.
If you do not specify any parameters, this command displays data cache entries for all IPv4 LISP VRF instances.
# Display data cache entries in the IPv4 LISP VRF instance red.
<Sysname> display lisp ipv4 data-cache vrf red
LISP IP Mapping Data Cache for VRF red (iid 13), 1 entries
192.23.1.3, uptime: 00:00:05, state: incomplete, nonce: 0x8a39f-0x12faf
LISP IP Mapping Data Cache for Public VRF/LISP IP Mapping Data Cache for VRF vrfname
Indicates that the data cache entries are for the public LISP network/LISP VRF instance.
iid
Instance ID.
entries
Number of data cache entries.
uptime
Time when the data cache entry was created.
state
State of the data cache entry:
·     Complete—The ITR received a Map-Reply message.
·     incomplete—The ITR did not receive a Map-Reply message.
reset lisp ipv4 data-cache
display lisp ipv4 map-cache
Use display lisp ipv4 map-cache to display IPv4 LISP mapping cache entries.
display lisp ipv4 map-cache [ destination-eid-prefix [ prefix-length ] ] [ default | vrf vrf-name ] [ verbose ]
destination-eid-prefix [ prefix-length ]: Specifies a destination EID prefix in dotted decimal notation. The prefix-length argument specifies the prefix length in the range of 0 to 32. If you do not specify a destination EID prefix, this command displays all IPv4 LISP mapping cache entries.
default: Displays mapping cache entries for the public LISP network.
verbose: Displays detailed information about IPv4 LISP mapping cache entries. If you do not specify this keyword, the command displays brief information about IPv4 LISP mapping cache entries.
If you do not specify any parameters, this command displays mapping cache entries for all IPv4 LISP VRF instances.
# Display mapping cache entries for the public LISP network.
<Sysname> display lisp ipv4 map-cache default verbose
LISP IP Mapping Cache for Public VRF (iid 0), 1 entries
192.23.1.0/24, uptime: 00:01:13, expires: 01:58:46, via map-reply
  Last activity: 00:00:39
  State: complete, last modified: 00:01:13, map-source: 192.22.1.3
  Locator      Uptime    State       Priority/  Data     Control
                                     Weight     in/out   in/out
  3.3.3.3      00:01:13  up          1/10       0/4      0/0
    Last up/down state change:           00:01:13, state change count: 1
    Last data packet in/out:             never/00:00:39
    Last control packet in/out:          never/never
    Last priority/weight change:         never/never
    Sync Flags:                          0x0003
    TnlID:                               0x1000000
  192.22.1.3   00:01:13  up          1/10       3/0      1/0
    Last data packet in/out:             00:00:39/never
    Last control packet in/out:          00:01:13/never
    Sync Flags:                          0x0003
    TnlID:                               0x2000001
Table 5 Command output
LISP IP Mapping Cache for Public VRF/LISP IP Mapping Cache for VRF vrfname
Indicates that the mapping cache entries are for the public LISP network/LISP VRF instance.
iid
Instance ID.
entries
Number of mapping cache entries.
uptime
Time elapsed since the mapping cache entry was created.
expires
Mapping cache entry aging time.
via
How the mapping cache entry was created:
·     static—Statically configured.
·     map-reply—Learned from a Map-Reply message.
·     map-request—Learned from a Map-Request message.
Last activity
Time period during which the mapping cache entry was used for traffic routing and forwarding (traffic input/output) for the most recent time.
State of the mapping cache entry:
·     complete—The mapping cache entry is validated.
·     tentative—The mapping cache entry is tentative.
last modified
Most recent mapping cache entry modification time.
map-source
Source IP address of the Map-Request or Map-Reply message that was used to create the mapping cache entry. This field displays local if the mapping cache entry was statically configured.
Locator
RLOC address.
Uptime
·     up
·     down
·     no-route
Priority/ Weight
Priority/Weight of the RLOC address.
Data in/out
Control in/out
Number of received/sent LISP control messages.
Time elapsed since the last time the RLOC address state changed.
Most recent data packet encapsulation/decapsulation time.
Most recent LISP control message receiving/sending time.
Most recent RLOC address priority/weight changing time.
Sync Flags
RLOC synchronization flag:
·     0x0001—The RLOC addresses are synchronized to RIB.
·     0x0002—The RLOC addresses are synchronized to the LINUX kernel.
TnlID
ID of the tunnel for the RLOC address.
reset lisp ipv4 map-cache
display lisp ipv4 statistics
Use display lisp ipv4 statistics to display IPv4 LISP statistics.
display lisp ipv4 statistics [ default | vrf vrf-name ]
default: Displays the public LISP network statistics.
If you do not specify any parameters, this command displays statistics about all IPv4 LISP VRF instances.
# Display the public IPv4 LISP network statistics.
<Sysname> display lisp ipv4 statistics default
LISP IP Statistics Information for Public VRF (iid 0) - last cleared: never
Control Packets:
  Map-Requests in/out:                  1/9
    Encapsulated Map-Requests in/out:   1/9
    RLOC-probe Map-Requests in/out:     0/0
    SMR-based Map-Requests in/out:      0/0
  Map-Replies in/out:                   1/1
    Authoritative in/out:               1/1
    Non-authoritative in/out:           0/0
    Negative Map-Replies in/out:        0/0
    RLOC-probe Map-Replies in/out:      0/0
  Map-Registers in/out:                 0/121
    Authentication failures:            0
  Map-Notifies in/out:                  0/0
  Map-Notify-Acks in/out:               0/0
Errors:
  Map-Request format errors:            0
  Map-Reply format errors:              0
  Map-Reply spoof alerts:               0
Table 6 Command output
LISP IP Statistics Information for Public VRF/LISP IP Statistics Information for  VRF vrfname
Indicates that the statistics are for the public LISP network/LISP VRF instance.
iid
Instance ID.
last cleared
Most recent statistics clearing time.
Control Packets
Map-Requests in/out
Number of received/sent Map-Request messages.
Number of received/sent encapsulated Map-Request messages.
Number of received/sent RLOC-probe Map-Request messages.
Number of received/sent SMR-based Map-Request messages.
Map-Replies in/out
Number of received/sent Map-Reply messages.
Number of received/sent authoritative Map-Reply messages.
Number of received/sent non-authoritative Map-Reply messages.
Number of received/sent negative Map-Reply messages.
Number of received/sent RLOC-probe Map-Reply messages.
Number of received/sent Map-Register messages.
Number of Map-Register message authentication failures.
Map-Notifies in/out
Number of received/sent Map-Notify messages.
Number of Map-Notify message authentication failures.
Number of received/sent Map-ACK messages.
Errors
Number of error data packets.
Number of Map-Request messages with incorrect format.
Number of Map-Reply messages with incorrect format.
Number of unsolicited Map-Reply messages.
reset lisp ipv4 statistics
display lisp site
Use display lisp site to display IPv4 LISP site information.
display lisp site [ destination-eid-prefix [ prefix-length ] | name site-name ] [ default | vrf vrf-name ] [ verbose ]
destination-eid-prefix [ prefix-length ]: Specifies a destination EID prefix in dotted decimal notation. The prefix-length argument specifies the prefix length in the range of 0 to 32. If you do not specify a destination EID prefix, this command displays all IPv4 LISP site information.
name site-name: Specifies an IPv4 LISP site by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a LISP site, this command displays all IPv4 LISP site information.
default: Displays information about LISP sites for the public LISP network.
verbose: Displays detailed information about IPv4 LISP sites. If you do not specify this keyword, the command displays brief information about IPv4 LISP sites.
If you do not specify any parameters, this command displays information about LISP sites in all IPv4 LISP VRF instances.
# Display brief information about IPv4 LISP sites for the public LISP network.
<Sysname> display lisp site default
LISP Site Registration Information for Public VRF
Site Name      Last       Actively   Who last        EID-prefix      Inst
               Registered Registered Registered                      ID
site1          never      no         --              192.13.1.0/24   0
               00:22:39   no         192.12.1.1      192.13.1.0/24-1 13
site2          never      no         --              192.23.1.0/24   0
               00:00:39   yes        192.22.1.3      192.23.1.0/24   13
Table 7 Command output
LISP Site Registration Information for Public VRF/LISP Site Registration Information for VRF vrfname
Indicates that the site information is for the public LISP network/LISP VRF instance.
Last registered
Most recent EID prefix registration time.
Actively Registered
Whether the EID prefix is registered:
·     yes
·     no
Who last registered
ETR that most recently registered the EID prefix.
EID-prefix
EID prefix configured for the LISP site. -cnt indicates the number of EID prefixes that are more specific than the configured EID prefix.
Inst ID
ID of the instance to which the EID prefix belongs.
# Display detailed information about the IPv4 LISP sites for the public network.
<Sysname> display lisp site default verbose
Site name:   site1
Description: none configured
Allowed configured locators: any
  Configured EID-prefix: 192.13.1.0/24, instance-id: 13
    Currently registered:      yes
    First registered:          02:47:44
    Last registered:           00:00:07
    Who last registered:       192.12.1.1
    Routing table tag:         0
    Proxy Replying:            no
    Wants Map-Notifications:   no
    Registered TTL:            120 minutes
    Registered locators:
      1.1.1.1 (LR), priority: 1, weight: 10
      11.11.11.11 (LR), priority: 1, weight: 10
      192.12.1.1 (LR), priority: 1, weight: 10
    Registration errors:
      Allowed locators mismatch: 0
  More-specific EID-prefix: 192.13.1.9/32, instance-id: 13
    First registered:          00:00:04
    Last registered:           00:00:04
    Who last registered:       192.168.10.1
    Proxy Replying:            no
    Registered TTL:            1440 minutes
      192.168.10.1 (LR), priority: 1, weight: 1
Table 8 Command output
Description of the LISP site. This field displays none configured if no description is configured for the LISP site.
RLOC addresses that are permitted to be registered. This field displays any if all RLOC addresses are permitted.
instance-id
·     yes
·     no
First registered
Time when the EID prefix was registered for the first time.
Proxy Replying
Whether the registrant accepts replies from an MS proxy:
·     yes
·     no
Whether the registrant requires Map-Notify messages:
·     yes
·     no
Registered TTL
TTL value for the registered EID mapping entry, in minutes.
Registered locators
Registered RLOC address for the EID prefix:
·     L—RLOC address of the registrant.
·     R—The RLOC address of the registrant is routable.
·     priority Locator—Priority of the RLOC address.
·     weight Locator—Weight of the RLOC address.
Registration errors
Number of registration errors.
Number of authentication failures.
Number of RLOCs that failed to match the permitted RLOC addresses.
More-specifics registered
Number of EID prefixes that are more specific than the configured EID prefix.
reset lisp lisp site
dynamic-eid
Use dynamic-eid to create a dynamic EID detection policy and enter its view, or enter the view of an existing dynamic EID detection policy.
Use undo dynamic-eid to delete a dynamic EID detection policy and all configuration in its view.
dynamic-eid dynamic-eid-name
undo dynamic-eid dynamic-eid-name
No dynamic EID detection policies exist.
LISP view
LISP-VRF view
dynamic-eid-name: Assigns a name to the dynamic EID detection policy, a case-sensitive string of 1 to 63 characters.
Only the hosts that match the specified dynamic EID detection policy are permitted to roam.
# Create the dynamic EID detection policy DE and enter its view.
[Sysname] lisp
eid-notify
On an FHR:
Use eid-notify to enable the FHR to send dynamic EID information and set the authentication mode.
Use undo eid-notify to disable the FHR from sending dynamic EID information.
On an xTR:
Use eid-notify to enable the xTR to accept dynamic EID information and set the authentication mode.
Use undo eid-notify to disable the xTR from accepting dynamic EID information.
On an FHR:
eid-notify xtr-address authentication-mode { none | sha-1 authentication-key { ciphertext | plaintext } string }
undo eid-notify xtr-address
On an xTR:
eid-notify authentication-mode { none | sha-1 authentication-key { ciphertext | plaintext } string }
undo eid-notify authentication-mode
An FHR does not send dynamic EID information, and an xTR does not accept dynamic EID information.
Dynamic-EID view
xtr-address: Specifies the IP address of an xTR in the LISP site.
authentication-mode none: Enables the FHR to send dynamic EID information or the xTR to receive EID information without authentication.
authentication-mode sha-1: Specifies the SHA-1 authentication mode.
authentication-key ciphertext: Specifies a key in encrypted form.
authentication-key plaintext: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
If you configure an FHR to send dynamic EID information, you must specify the xtr-address argument in this command. You can specify a maximum of four different xTR IP addresses. If you configure an xTR to accept dynamic EID information, you do not need to specify an xTR IP address in this command.
Make sure both the FHR and xTR have the same authentication settings. If the authentication settings are different, the FHR fails to send the dynamic EID information or the xTR fails to receive the dynamic EID information.
# Configure the FHR to notify the xTR (with the IP address 172.16.0.2) of dynamic EID information without authentication.
[Sysname] lisp
[Sysname-lisp-dynamic-eid-DE] eid-notify 172.16.0.2 authentication-mode none
eid-prefix
Use eid-prefix to configure an MS to permit an EID prefix for registration.
Use undo eid-prefix to remove a permitted EID prefix.
eid-prefix eid-prefix prefix-length [ instance-id id ] [ accept-more-specifics ]
undo eid-prefix eid-prefix prefix-length [ instance-id id ]
An MS does not permit any EID prefixes and does not process any Map-Register messages.
LISP site view
instance-id id: Specifies a LISP VRF instance by its ID in the range of 0 to 16777215. If you do not specify an instance ID, LISP VRF instance 0 is specified. The instance ID must be the same as that specified by using the xtr instance-id command.
accept-more-specifics: Configures the MS to permit EID prefixes that are longer than the configured EID prefix. Specify this keyword only if your device supports virtual machine mobility.
For an ETR to successfully register with an MS, you must configure the MS to permit the same EID prefixes configured on the ETR by using the database-mapping command.
# Configure the MS to permit the EID prefix 10.1.1.0/24.
[Sysname] lisp
[Sysname-lisp-site-site-1] eid-prefix 10.1.1.0 24
xtr instance-id
etr
Use etr to enable the IPv4 ETR feature.
Use undo etr to disable the IPv4 ETR feature.
etr
undo etr
The IPv4 ETR feature is disabled.
LISP view
LISP-VRF view
# Enable the IPv4 ETR feature.
[Sysname] lisp
[Sysname-lisp] etr
etr accept-map-request-mapping
Use etr accept-map-request-mapping to configure an ETR to accept the mapping information in Map-Request messages.
Use undo etr accept-map-request-mapping to restore the default.
etr accept-map-request-mapping [ verify ]
An ETR does not accept the mapping information in Map-Request messages.
LISP view
LISP-VRF view
verify: Enables the ETR to verify the mapping information in Map-Request messages. To verify the mapping information in a Map-Request message, the ETR sends its own Map-Request message to the sender of the Map-Request message. If you do not specify this keyword, the ETR directly use the mapping information for packet forwarding.
# Configure the ETR to accept and use the mapping information in Map-Request messages without verification.
[Sysname] lisp
[Sysname-lisp] etr accept-map-request-mapping
etr
etr map-cache-ttl
Use etr map-cache-ttl command to set the TTL value in Map-Reply messages sent by an ETR.
Use undo etr map-cache-ttl to restore the default.
etr map-cache-ttl ttl
The TTL value in Map-Reply messages is 1440 minutes (24 hours).
LISP view
LISP-VRF view
ttl: Specifies the TTL value in Map-Reply messages, in the range of 60 to 10080 minutes.
When an ETR responds to an ITR with Map-Reply messages, it sets a TTL value in the messages. The ITR sets the TTL value for the cache entries according to the TTL value in these messages.
# Set the TTL value in Map-Reply messages to 120 minutes.
[Sysname] lisp
[Sysname-lisp] etr map-cache-ttl 120
etr map-server
Use etr map-server to specify an MS address for an IPv4 ETR.
Use undo etr map-server to remove an MS address.
etr map-server map-server-address authentication-mode none [ proxy-reply ]
etr map-server map-server-address authentication-mode sha-1 authentication-key { ciphertext | plaintext } string [ proxy-reply ]
undo etr map-server map-server-address
No MS address is specified for an IPv4 ETR.
LISP view
LISP-VRF view
map-server-address: Specifies an MS address.
authentication-mode none: Configures the ETR to register with an MS without authentication.
authentication-mode sha-1: Configures the ETR to use SHA-1 to authenticate to an MS for registration.
proxy-reply: Configures the ETR to use the MS as a proxy to respond to the ITR.
An ETR periodically sends Map-Register messages to an MS if the following requirements are met:
·     The MS address is specified for the ETR by using this command.
·     The specified MS address is reachable.
You can specify a maximum of two MS addresses in LISP-VRF view.
# Specify the MS address 44.44.44.44 for the ETR, and configure the ETR to use SHA-1 and the plaintext key 12345 to authenticate to the MS.
[Sysname] lisp
[Sysname-lisp] etr map-server 44.44.44.44 authentication-mode sha-1 authentication-key plaintext 123456
etr
itr
Use itr to enable the IPv4 ITR feature.
Use undo itr to disable the IPv4 ITR feature.
itr
undo itr
The IPv4 ITR feature is disabled.
LISP view
LIPS VRF instance view
# Enable the IPv4 ITR feature.
[Sysname] lisp
[Sysname-lisp] itr
itr map-resolver
Use itr map-resolver to specify an MR address for an IPv4 ITR.
Use undo itr map-resolver to remove an MR address.
itr map-resolver map-resolver-address
undo itr map-resolver map-resolver-address
No MR address is specified for an IPv4 ITR.
LISP view
LISP-VRF view
map-resolver-address: Specifies an MR address.
You can specify a maximum of two MR addresses in LISP-VRF view.
After you specify an MR address, the ITR encapsulates Map-Request messages in ECM messages and sends them to the MR.
# Specify the MR address 44.44.44.44 for the ITR.
[Sysname] lisp
[Sysname-lisp] itr map-resolver 44.44.44.44
lig
Use lig to query the mapping information in the LISP mapping database.
lig { destination-eid | hostname | self } [ count count ] [ source source-eid ] [ to map-resolver ] [ timer timeout ] [ vrf vrf-name ]
destination-eid: Specifies the destination EID.
hostname: Specifies the name of the destination host, a case-insensitive string of 1 to 253 characters.
self: Checks whether the local EID prefix is registered in the LISP mapping database.
count count: Specifies the maximum number of Map-Request messages to be sent, in the range of 1 to 5. The default value is 3.
source source-eid: Specifies the source EID in Map-Request messages. By default, the EID in the first mapping cache entry of the database is used.
to map-resolver: Specifies an MR address as the destination address of Map-Request messages. By default, Map-Request messages are sent to the configured MR.
timer timeout: Specifies the interval for sending another Map-Request message when no Map-Reply message is returned, in the range of 1 to 5 seconds. The default interval is 2 seconds.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command queries mapping information in the database of the public LISP network.
If you specify the hostname argument, make sure DNS is configured on the local device. If DNS is not configured, the query will fail.
You can press Ctrl + C to terminate the query process.
# Query mapping information for the EID 1.1.1.1.
<Sysname> lig 1.1.1.1
Sending Map-Request to 10.1.1.5 for 1.1.1.1
Received Map-Reply from 10.1.1.1 with rtt 0.002709 sec
Map-cache entry for EID 1.1.1.1:
1.1.1.1/32; uptime: 00:00:01; expires: 23:59:58; via Map-Reply; auth
  Locator    Uptime             State       Priority/Weight   Data in/out     Control in/out
  10.1.1.1   00:00:01           up          1/2                  0/0              5/0
# Obtain mapping information for the EID 1.1.1.1 from the MR 10.1.1.2.
<Sysname> lig 1.1.1.1 to 10.1.1.2
Sending Map-Request to 10.1.1.2 for 1.1.1.1 ...
Received Map-Reply from 10.1.1.2 with rtt 0.002709 sec
# Check whether the EID prefix is registered in the LISP mapping database.
<Sysname> lig self
Sending loopback Map-Request to 192.168.10.2 for 10.10.10.0 ...
Received Map-Reply from 127.0.0.1 with rtt 0.003030 sec
Map-cache entry for EID 10.10.10.0:
10.10.10.0/24; uptime: 08:51:48; expires: 23:59:58; via Map-Reply; self
  192.168.10.1 08:51:48         up        1/2                    0/0               0/0
Table 9 Command output
uptime
Time elapsed since the EID prefix became up.
expires
Remaining EID prefix aging time.
Locator
RLOC address.
Uptime
Priority/Weight
Priority and weight of the RLOC address.
Data in/out
Number of received and sent data packets.
Control in/out
Number of received and sent LISP control messages.
lisp
Use lisp to enable LISP and enter its view.
Use undo lisp to disable LISP.
lisp
undo lisp
LISP is disabled.
# Enable LISP and enter its view.
[Sysname] lisp
[Sysname-lisp]
lisp extended-subnet-mode
Use lisp extended-subnet-mode to enable support for extended subnets on an interface.
Use undo lisp extended-subnet-mode to disable support for extended subnets on an interface.
Support for extended subnets is disabled on an interface.
Interface view
This command allows an interface to detect virtual machine mobility within the subnet that the interface is attached to.
# Configure GigabitEthernet 1/0/1 to support extended subnets.
[Sysname-GigabitEthernet1/0/1] lisp extended-subnet-mode
lisp mobility
Use lisp mobility to apply a dynamic EID detection policy to an interface.
Use undo lisp mobility to remove a dynamic EID detection policy from an interface.
lisp mobility dynamic-eid-name
undo lisp mobility dynamic-eid-name
No dynamic EID detection policy is applied to an interface.
Interface view
dynamic-eid-name: Specifies a dynamic EID detection policy by its name, a case-sensitive string of 1 to 63 characters.
An interface performs virtual machine mobility detection only if a dynamic EID detection policy is applied to it.
# Apply the dynamic EID detection policy DE to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lisp mobility DE
locator-down
Use locator-down to configure an RLOC address in the EID-to-RLOC mapping database as unreachable.
Use undo locator-down to remove the configuration.
locator-down eid-prefix prefix-length locator
undo locator-down eid-prefix prefix-length locator
No RLOC address in the EID-to-RLOC mapping database is configured as unreachable.
LISP view
LISP-VRF view
For the command to take effect, make sure the EID-to-RLOC mapping already exists in the database.
# Configure the RLOC address 11.11.11.11 as unreachable.
[Sysname] lisp
[Sysname-lisp]
[Sysname-lisp] locator-down 10.1.1.0 24 11.11.11.11
database-mapping
locator-vrf
Use locator-vrf to assign the RLOC address space to a VRF instance.
Use undo locator-vrf to restore the default.
locator-vrf { default | vrf vrf-name }
undo locator-vrf
The RLOC address space belongs to the LISP VRF instance.
LISP view
LISP-VRF view
default: Assign the RLOC address space to the public LISP network.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The MPLS L3VPN instance must already exist.
# Assign the RLOC address space to the public network.
[Sysname] lisp
[Sysname-lisp] locator-vrf default
map-cache
Use map-cache to create a static EID-to-RLOC mapping cache entry.
Use undo map-cache to delete a static EID-to-RLOC mapping cache entry.
map-cache destination-eid-prefix prefix-length { locator priority priority weight weight | drop | map-request | native-forward }
undo map-cache destination-eid-prefix prefix-length { locator | drop | map-request | native-forward }
No static EID-to-RLOC mapping cache entry is created.
LISP view
LISP-VRF view
priority priority: Specifies the priority for the RLOC address, in the range of 0 to 255. The smaller the priority value, the higher the priority. A value of 255 means that the priority is invalid.
weight weight: Specifies the weight for the RLOC address, in the range of 0 to 100.
drop: Drops packets that match the created static EID-to-RLOC mapping cache entry.
map-request: Sends Map-Request messages for packets that match the created static EID-to-RLOC mapping cache entry.
native-forward: Forwards packets that match the created static EID-to-RLOC mapping cache entry without LISP routing.
The EID-to-RLOC mapping cache entries consist of static mapping cache entries and dynamic mapping cache entries.
# Create a static mapping cache entry in LISP view.
[Sysname] lisp
[Sysname-lisp] map-cache 10.1.1.0 24 12.1.1.1 priority 1 weight 50
map-cache-limit
map-cache-limit
Use map-cache-limit to set the maximum number of EID-to-RLOC mapping cache entries.
Use undo map-cache-limit to restore the default.
map-cache-limit cache-limit
The maximum number of EID-to-RLOC mapping cache entries is not set.
LISP view
LISP-VRF view
cache-limit: Specifies the maximum number of EID-to-RLOC mapping cache entries, in the range of 1 to 4294967295.
Follow these restrictions and guidelines to create new mapping cache entries when the maximum number of mapping cache entries (both static and dynamic EID-to-RLOC mapping cache entries) is reached:
·     If the database contains both static and dynamic mapping cache entries, you can create only static mapping cache entries. The new static mapping cache entries overwrite the existing dynamic mapping cache entries.
·     If the database contains only static mapping cache entries, you cannot create new mapping cache entries.
You can use the reset lisp ipv4 map-cache command to manually clear the dynamic mapping entries or wait for the dynamic mapping entries to age out.
# Set the maximum number of EID-to-RLOC mapping cache entries to 2000.
[Sysname] lisp
[Sysname-lisp] map-cache-limit 2000
map-cache
map-notify-group
Use map-notify-group to specify a multicast address for Map-Notify messages.
Use undo map-notify-group to restore the default.
map-notify-group map-notify-group-address
No multicast address is specified for Map-Notify messages.
Dynamic-EID view
map-notify-group-address: Specifies a multicast address for Map-Notify messages.
When an xTR detects a roaming host, it sends Map-Notify messages to the specified multicast address to notify all the other xTRs in the LISP site.
# Specify the multicast address 239.0.0.2 for Map-Notify messages.
[Sysname] lisp
[Sysname-lisp-dynamic-eid-DE] map-notify-group 239.0.0.2
map-resolver
Use map-resolver to enable the IPv4 MR feature.
Use undo map-resolver to disable the IPv4 MR feature.
map-resolver
undo map-resolver
The IPv4 MR feature is disabled.
LISP view
LISP-VRF view
An MR processes and forwards Map-Request messages.
# Enable the IPv4 MR feature.
[Sysname] lisp
[Sysname-lisp] map-resolver
map-server (dynamic-EID view)
Use map-server to specify an MS address for the dynamic EID space and set the authentication mode.
Use undo map-server to remove an MS address.
undo map-server map-server-address
No MS address is specified for the dynamic EID space.
Dynamic-EID view
authentication-mode none: Configures an xTR to register with an MS without authentication.
authentication-mode sha-1: Configures an xTR to use SHA-1 to authenticate to an MS for registration.
proxy-reply: Specifies that the MS can return Map-Reply messages as a proxy.
When an xTR detects a roaming virtual machine, it registers the detected dynamic EID information with the MS specified by using this command.
If no MS address is specified for the dynamic EID space, the xTR registers the detected dynamic EID information with the MS in the LISP VRF instance.
You can specify a maximum of two MS addresses.
# Specify the MS address 44.44.44.44 for the dynamic EID space, configure the xTR to use SHA-1 and the plaintext key 123456 to authenticate to the MS.
[Sysname] lisp
[Sysname-lisp-dynamic-eid-DE] map-server 44.44.44.44 authentication-mode sha-1 authentication-key plaintext 123456
map-server (LISP view/LISP-VRF view)
Use map-server to enable the IPv4 MS feature.
Use undo map-server to disable the IPv4 MS feature.
map-server
undo map-server
The IPv4 MS feature is disabled.
LISP view
LISP-VRF view
# Enable the IPv4 MS feature.
[Sysname] lisp
[Sysname-lisp] map-server
native-forward-map-cache timeout
Use native-forward-map-cache timeout to set the aging time for the native-forward type mapping cache entries.
Use undo native-forward-map-cache timeout to restore the default.
native-forward-map-cache timeout time
The aging time of the native-forward type mapping cache entries depends on the configuration of the MS and the registration.
LISP view
LISP-VRF view
time: Specifies the aging time for the native-forward type mapping cache entries, in the range 1 to 60 seconds.
To speed up LISP communication during the system startup, you can use this command to set a shorter aging time.
# Set the aging time to 1 second for the native-forward type mapping cache entries.
[Sysname] lisp
[Sysname-lisp] native-forward-map-cache timeout 1
Use reset lisp dynamic-eid to clear the detected dynamic EID prefix information.
reset lisp dynamic-eid [ default | vrf vrf-name ] [ eid-prefix ]
default: Clears the detected dynamic EID prefix information for the public LISP network.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears the detected dynamic EID prefix information for the public LISP network and all LISP VRF instances.
eid-prefix: Specifies a dynamic EID prefix in dotted decimal notation. If you do not specify a dynamic EID prefix, this command clears all detected dynamic EID prefix information.
# Clear information for the detected dynamic EID prefix 1.1.1.1.
<Sysname> reset lisp dynamic-eid 1.1.1.1
Use reset lisp ipv4 data-cache to clear IPv4 LISP data cache entries.
reset lisp ipv4 data-cache [ default | vrf vrf-name ] [ destination-eid ]
default: Clears data cache entries for the public LISP network.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears data cache entries for all LISP VRF instances.
destination-eid: Specifies a destination EID in dotted decimal notation. If you do not specify a destination EID, this command clears all data cache entries.
# Clear data cache entries for all IPv4 LISP VRF instances.
<Sysname> reset lisp ipv4 data-cache
Use reset lisp ipv4 map-cache to clear IPv4 LISP dynamic mapping cache entries.
reset lisp ipv4 map-cache [ default | vrf vrf-name ] [ destination-eid-prefix [ prefix-length ] ]
default: Clears dynamic mapping cache entries for the public LISP network.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears dynamic mapping cache entries for all LISP VRF instances.
destination-eid [ prefix-length ]: Specifies a destination EID prefix in dotted decimal notation. The prefix-length argument specifies the prefix length in the range of 0 to 32. If you do not specify a destination EID prefix, this command clears all dynamic mapping cache entries.
# Clear dynamic mapping cache entries for all IPv4 LISP VRF instances.
<Sysname> reset lisp ipv4 map-cache
Use reset lisp ipv4 statistics to clear IPv4 LISP statistics.
reset lisp ipv4 statistics [ default | vrf vrf-name ]
default: Clears statistics for the public LISP network.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears statistics for all IPv4 LISP VRF instances.
# Clear statistics for all IPv4 LISP VRF instances.
<Sysname> reset lisp ipv4 statistics
reset lisp site
Use reset lisp site to clear LISP site registration information.
reset lisp site [ default | vrf vrf-name ] [ name site-name ]
default: Clears registration information for all LISP sites in the public LISP network.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears LISP site registration information for all IPv4 LISP VRF instances.
name site-name: Specifies a LISP site by its name. If you do not specify a LISP site, this command clears all LISP site registration information.
# Clear registration information for the LISP site site1.
<Sysname> reset lisp site name site1 default
display lisp site
roaming-eid-prefix
Use roaming-eid-prefix to specify the dynamic EID range for roaming in.
Use undo roaming-eid-prefix to restore the default.
roaming-eid-prefix eid-prefix prefix-length
The dynamic EID range is 0.0.0.0/0 for roaming in.
Dynamic-EID view
Use this command to specify the range of the host addresses permitted by the dynamic EID space to roam in.
By default, a host is permitted to roam in if its address is in the dynamic EID space specified by using the database-mapping command in dynamic-EID view. After you execute the roaming-eid-prefix command, the host address must also be in the dynamic EID range for the host to roam in.
# Specify the dynamic EID range as 1.1.1.1/32 for roaming in.
[Sysname] lisp
[Sysname-lisp-dynamic-eid-DE] roaming-eid-prefix 1.1.1.1 32
shortest-eid-prefix-length
Use shortest-eid-prefix-length to set the minimum permitted length for the EID prefixes in Map-Reply messages and Map-Request messages.
Use undo shortest-eid-prefix-length to restore the default.
shortest-eid-prefix-length prefix-length
The minimum permitted length for the EID prefixes in Map-Reply messages and Map-Request messages is 16.
LISP view
LISP-VRF view
prefix-length: Specifies the minimum EID prefix length in the range of 0 to 32.
# Set the minimum permitted length to 12 for the EID prefixes in Map-Reply messages and Map-Request messages.
[Sysname] lisp
[Sysname-lisp] shortest-eid-prefix-length 12
site
Use site to create an IPv4 LISP site and enter its view, or enter the view of an existing IPv4 LISP site.
Use undo site to delete a IPv4 LISP site and all configuration in its view.
site site-name
undo site site-name
No IPv4 LISP sites exist.
LISP view
LISP-VRF view
site-name: Assigns a name to the IPv4 LISP site, a case-sensitive string of 1 to 63 characters.
# Create the IPv4 LISP site site-1 and enter its view.
[Sysname] lisp
vrf
Use vrf to create an IPv4 LISP VRF instance and enter its view, or enter the view of an existing IPv4 LISP VRF instance.
Use undo vrf to remove an IPv4 LISP VRF instance and all configuration in its view.
vrf vrf-name
undo vrf vrf-name
No IPv4 LISP VRF instances exist.
LISP view
To configure an IPv4 LISP VRF instance, you need to configure an MPLS L3VPN instance in system view first.
# Create the IPv4 LISP VRF instance red and enter its view.
[Sysname] ip vpn-instance red
[Sysname-vpn-instance-red] quit
[Sysname] lisp
[Sysname-lisp] vrf red
[Sysname-lisp-vrf-red]
xtr instance-id
Use xtr instance-id to specify an instance ID for EID prefixes.
Use undo xtr instance-id to restore the default.
xtr instance-id instance-id
The instance ID for EID prefixes is 0.
LISP view
LISP-VRF view
instance-id: Specifies an instance ID in the range of 1 to 16777215.
# Specify the instance ID 123 for EID prefixes.
[Sysname] lisp
[Sysname-lisp] xtr instance-id 123
eid-prefix
  • Become a Partner
  • Partner Resources
