| 09-BFD commands | 356.13 KB |
bfd detect-interface first-fail-timer
bfd detect-interface source-ip
bfd detect-interface special-processing
bfd multi-hop authentication-mode
bfd multi-hop destination-port
bfd multi-hop detect-multiplier
bfd multi-hop min-echo-receive-interval
bfd multi-hop min-receive-interval
bfd multi-hop min-transmit-interval
BFD commands
Basic BFD commands
bfd authentication-mode
Use bfd authentication-mode to configure the BFD authentication mode for single-hop BFD control packets.
Use undo bfd authentication-mode to restore the default.
bfd authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
Single-hop BFD control packets are not authenticated.
Interface view
BFD template view
hmac-md5: Specifies the HMAC MD5 algorithm.
hmac-mmd5: Specifies the HMAC Meticulous MD5 algorithm.
hmac-msha1: Specifies the HMAC Meticulous SHA1 algorithm.
hmac-sha1: Specifies the HMAC SHA1 algorithm.
m-md5: Specifies the Meticulous MD5 algorithm.
m-sha1: Specifies the Meticulous SHA1 algorithm.
md5: Specifies the MD5 algorithm.
sha1: Specifies the SHA1 algorithm.
simple: Specifies the simple authentication mode.
key-id: Sets the authentication key ID in the range of 1 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 33 to 53 characters.
Use this command to enhance BFD session security.
A static BFD session supports this command only when it is in IPv4 or IPv6 control packet mode used for single-hop detection.
BFD version 0 does not support this command. The configuration does not take effect.
# Configure GigabitEthernet 1/0/1 to perform simple authentication for single-hop BFD control packets, setting the authentication key ID to 1 and plaintext key to 123456.
[Sysname-GigabitEthernet1/0/1] bfd authentication-mode simple 1 plain 123456
bfd static
bfd demand enable
Use bfd demand enable to enable the Demand BFD session mode.
Use undo bfd demand enable to restore the default.
bfd demand enable
The BFD session is in Asynchronous mode.
Interface view
In Demand mode, the device periodically sends BFD control packets. If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets. If the peer end is operating in Demand mode, both ends stop sending BFD control packets. As a best practice, configure the bfd echo enable command together with this command to detect connectivity by sending Echo packets. If the device does not receive any Echo packets from the peer end, it considers the session down.
In Asynchronous mode, the device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within a specific interval.
# Enable the Demand BFD session mode on GigabitEthernet 1/0/1
[Sysname-GigabitEthernet1/0/1] bfd demand enable
bfd echo enable
Use bfd detect-interface first-fail-timer to configure the timer that delays reporting the first BFD session establishment failure to the data link layer.
Use undo bfd detect-interface first-fail-timer to restore the default.
bfd detect-interface first-fail-timer seconds
The first BFD session establishment failure is not reported to the data link layer.
Interface view
seconds: Specifies the timeout time that reports the first BFD session establishment failure to the data link layer. The value range for this argument is 1 to 10000 seconds.
If the BFD session fails to be established when the timer expires, BFD reports the failure to the data link layer and sets the data link layer state of the interface to DOWN(BFD). This behavior rapidly identifies the interfaces for which BFD sessions fail to be established. In this case, the BFD session state is displayed as Down in the display bfd session command output. The line protocol state of the interface is displayed as DOWN(BFD) in the display interface command output.
If you execute the bfd detect-interface source-ip command on the local end, the BFD session for detecting the local interface state fails to be established when the following conditions exist:
· The bfd detect-interface source-ip command is not executed on the remote end.
· The local and remote ends have mismatching BFD authentication settings.
# Configure the timer that delays reporting the first BFD session establishment failure as 10 seconds for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd detect-interface first-fail-timer 10
display interface (Interface Command Reference)
Use bfd detect-interface source-ip to associate the interface state with BFD and specify the source IP address for BFD control packets.
Use undo bfd detect-interface to remove the association between the interface state and BFD.
bfd detect-interface source-ip ip-address [ discriminator local local-value remote remote-value ] [ template template-name ]
The interface state is not associated with BFD. BFD does not set the link layer protocol of the interface to DOWN(BFD) state when detecting a failure.
Interface view
ip-address: Specifies the source IP address for BFD control packets, in dotted decimal notation.
discriminator: Specifies BFD session discriminators. If you do not specify discriminators, the device obtains BFD session discriminators through autonegotiation.
local local-value: Specifies the local discriminator. The value range for the local-value argument is 1 to 32768.
remote remote-value: Specifies the remote discriminator in the range of 1 to 4294967295.
template template-name: Specifies a template by its name, a case-sensitive string of 1 to 63 characters. If you specify a nonexistent template or do not specify a template, the BFD session uses the BFD parameters configured in interface view. If you first specify a nonexistent template and then create the template, the BFD session uses the parameters configured in the template.
By creating a BFD session for single-hop detection through exchange of BFD control packets, this feature implements fast link detection. When BFD detects a link fault, it sets the link layer protocol state to DOWN(BFD). This behavior helps applications relying on the link layer protocol state achieve fast convergence.
The source IP address of control packets is specified manually, and the destination IP address is fixed at 224.0.0.184. As a best practice, specify the IP address of the interface as the source IP address. If the interface does not have an IP address, specify a unicast IP address other than 0.0.0.0 as the source IP address.
You can associate the state of the following interfaces with BFD:
· Layer 3 Ethernet interfaces and subinterfaces. For BFD detection to take effect, do not execute this command on both a Layer 3 Ethernet interface and its subinterface.
· Layer 3 aggregate interfaces, Layer 3 aggregate subinterfaces, and member ports (Layer 3 Ethernet interfaces only) in a Layer 3 aggregation group.
To configure this command on the preceding interfaces at the same time, you must manually specify the local and remote discriminators on each of the interfaces. As a best practice, do not configure this command on these interfaces at the same time.
· VLAN interfaces.
If the peer device does not support obtaining BFD session discriminators through autonegotiation, you must specify the discriminators on both the local and peer devices. Without the discriminators, the BFD session cannot come up.
The BFD session discriminators must match on the local and peer devices. For example, if you configure bfd detect-interface source-ip 20.1.1.1 discriminator local 513 remote 514 on the local device, you must configure bfd detect-interface source-ip 20.1.1.2 discriminator local 514 remote 513 on the peer device.
The local discriminators of BFD sessions for interfaces on the same device must be different.
To modify your configuration, remove it by using the undo form of the command and then execute the bfd detect-interface source-ip command again.
The echo function does not take effect on BFD sessions associated with interface states.
If you specify an existing template for this command, the bfd demand enable command cannot take effect.
# Associate GigabitEthernet 1/0/1 with BFD to detect the interface state, and specify the source IP address as 20.1.1.1.
[Sysname-GigabitEthernet1/0/1] bfd detect-interface source-ip 20.1.1.1
bfd demand enable
bfd echo enable
bfd template
Use bfd detect-interface special-processing to enable special processing for BFD sessions.
Use undo bfd detect-interface special-processing to disable special processing for BFD sessions.
bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
undo bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
All types of special processing for BFD sessions are disabled.
Interface view
admin-down: Notifies a session down event to the data link layer upon receipt of a BFD packet with the State field as AdminDown. This keyword helps rapidly discover interfaces on which BFD sessions are manually shut down. If you do not specify this keyword, the device sets the BFD session state to Down, but does not notify the session down event to the data link layer.
authentication-change: Immediately sets the session to down state upon a local authentication information change. This keyword helps rapidly discover interfaces with authentication information changes. If you do not specify this keyword, the device sets the session to down state if authentication information inconsistency still persists after a period of time.
session-up: Ignores authentication information inconsistency when the local session is up. If a large number of BFD sessions exist, examining authentication information consistency affects device performance. If you do not specify this keyword, the device examines authentication information in incoming BFD packets when the local session state is up. If the authentication information does not match on the two ends, the BFD session is declared down.
If you do not specify any parameters, this command enables or disables all types of special processing.
# Enable all types of special processing for BFD sessions on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd detect-interface special-processing admin-down authentication-change session-up
bfd detect-multiplier
Use bfd detect-multiplier to set the single-hop detection time multiplier for control packet mode and echo packet mode.
Use undo bfd detect-multiplier to restore the default.
bfd detect-multiplier value
The single-hop detection time multiplier is 3.
Interface view
BFD template view
value: Specifies a detection time multiplier. The value range for this argument is 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD packets (including control packets and echo packets) that can be discarded.
Table 1 Actual detection interval calculation method
Mode |
Actual detection interval of the sender |
Echo packet mode |
Detection time multiplier of the sender × actual packet sending interval of the sender |
Control packet mode BFD session in asynchronous mode |
Detection time multiplier of the receiver × MAX (minimum receiving interval supported by the sender, minimum sending interval supported by the receiver) |
Control packet mode BFD session in demand mode |
Detection time multiplier of the sender × MAX (minimum sending interval supported by the sender, minimum receiving interval supported by the receiver) |
# Set the single-hop detection time multiplier for control packet mode and the detection time multiplier for echo packet mode to 6 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd detect-multiplier 6
bfd echo enable
Use bfd echo enable to enable the echo function.
Use undo bfd echo enable to disable the echo function.
undo bfd echo [ receive | send ] enable
The echo function is disabled.
Interface view
receive: Specifies the echo packet receiving capability.
send: Specifies the echo packet sending capability.
If you enable the echo function for a BFD session in which control packets are sent and the session comes up, BFD performs the following operations:
· Periodically sends echo packets to detect link connectivity.
· Decreases the control packet receiving rate at the same time.
To enable only the echo packet receiving capability, use the bfd echo receive enable command.
To enable only the echo packet sending capability, use the bfd echo send enable command.
If you do not specify the receive or send keyword, the command enables both the echo packet receiving and sending capabilities.
The echo function does not take effect on BFD sessions in control packet mode that use IPv6 link-local addresses.
# Enable the echo function on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd echo enable
bfd static
bfd echo-source-ip
Use bfd echo-source-ip to configure the source IP address of BFD echo packets.
Use undo bfd echo-source-ip to remove the configured source IP address of BFD echo packets.
bfd echo-source-ip ip-address
No source IP address is configured for BFD echo packets.
ip-address: Specifies the source IP address of BFD echo packets. The source IP address must be a valid unicast IPv4 address in dotted decimal notation.
As a best practice, configure this command on the source end of an echo-packet-mode BFD session. In addition, make sure the source IP address is not in the same network segment as any interfaces on the device. This avoids the following situations:
· A large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
· With malformed packet attack detection and prevention enabled, the local end might filter echo packets sent from the peer as malformed packets, resulting in BFD session establishment failure. For more information about malformed packet attack detection and prevention, see attack detection and prevention in Security Configuration Guide.
# Configure the source IP address of BFD echo packets as 8.8.8.8.
[Sysname] bfd echo-source-ip 8.8.8.8
bfd echo-source-ipv6
Use bfd echo-source-ipv6 to configure the source IPv6 address of BFD echo packets.
Use undo bfd echo-source-ipv6 to remove the configured source IPv6 address of BFD echo packets.
No source IPv6 address is configured for BFD echo packets.
ipv6-address: Specifies the source IPv6 address for BFD echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
As a best practice, configure this command on the source end of an echo-packet-mode BFD session. In addition, make sure the source IPv6 address is not in the same network segment as any interfaces on the device. This avoids the following situations:
· A large number of ICMPv6 redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IPv6 address of BFD echo packets as 80::2.
[Sysname] bfd echo-source-ipv6 80::2
bfd init-fail timer
Use bfd init-fail-timer to set the delay timer for BFD to notify upper-layer protocols of session establishment failures.
Use undo bfd init-fail-timer to restore the default.
bfd init-fail-timer seconds
BFD does not notify upper-layer protocols of session establishment failures.
seconds: Specifies the delay time in the range of 5 to 600 seconds. After the delay time, BFD notifies the upper-layer protocol of session establishment failures.
CAUTION: For session establishment failures caused by configuration mismatches at the two ends, this command can cause the upper-layer protocol to act incorrectly. Therefore, use this command with caution. BFD status mismatch and BFD authentication configuration mismatch are examples of configuration mismatches. |
This command takes effect only for control packet mode.
In some cases, for an upper-layer protocol to act correctly, BFD must notify the upper-layer protocol of session establishment failures. For example, with this command configured, the link aggregation module can promptly set the state of a member port from Selected to Unselected in the case of a link failure.
# Set the delay timer to 10 seconds for BFD to notify upper-layer protocols of session establishment failures.
[Sysname] bfd init-fail-timer 10
bfd min-echo-receive-interval
Use bfd min-echo-receive-interval to set the minimum interval for receiving BFD echo packets.
Use undo bfd min-echo-receive-interval to restore the default.
Hardware |
Default |
MSR610 |
The minimum interval for receiving BFD echo packets is 1000 milliseconds. |
MSR810-LMS, MSR810-LUS |
MSR810-SI, MSR810-LM-SI |
MSR810-LMS-EA, MSR810-LME |
MSR1004S-5G, MSR1004S-5G-CN |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN |
MSR2600-10-X1 |
MSR2630 |
MSR3600-28, MSR3600-51 |
The minimum interval for receiving BFD echo packets is 100 milliseconds. |
MSR3610, MSR3620, MSR3620-DP, MSR3640, MSR3660 |
MSR3610-G, MSR3620-G |
MSR3640-G |
MSR3640-X1-HI |
Hardware |
Default |
MSR830-4LM-WiNet |
MSR2600-6-WiNet |
MSR2600-10-X1-WiNet |
MSR2630-WiNet |
MSR3600-28-WiNet |
MSR3610-X1-WiNet |
Hardware |
Default |
MSR860-6EI-XS |
MSR860-6HI-XS |
MSR2630-XS |
MSR3600-28-XS |
MSR3610-XS |
MSR3620-XS |
MSR3610-I-XS |
MSR3610-IE-XS |
MSR3620-X1-XS |
MSR3640-XS |
MSR3660-XS |
Hardware |
Default |
MSR810-LM-GL |
MSR810-W-LM-GL |
MSR830-6EI-GL |
MSR830-10EI-GL |
MSR830-6HI-GL |
MSR830-10HI-GL |
MSR1004S-5G-GL |
MSR2600-6-X1-GL |
MSR3600-28-SI-GL |
Interface view
BFD template view
interval: Specifies the minimum interval for receiving BFD echo packets, in milliseconds.
The following compatibility matrixes show the value ranges for the interval argument:
Hardware |
Value range |
MSR610 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
MSR2600-10-X1 |
0, 30 to 10000 |
MSR 2630 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 10 to 10000 |
0, 10 to 10000 |
0, 10 to 10000 |
0, 10 to 10000 |
MSR3640-G |
0, 10 to 10000 |
MSR3640-X1-HI |
0, 10 to 10000 |
Hardware |
Value range |
0, 30 to 10000 |
MSR830-4LM-WiNet |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
MSR2600-6-WiNet |
0, 30 to 10000 |
0, 30 to 10000 |
MSR2630-WiNet |
0, 30 to 10000 |
MSR3600-28-WiNet |
0, 30 to 10000 |
MSR3610-X1-WiNet |
0, 10 to 10000 |
0, 10 to 10000 |
Hardware |
Value range |
MSR860-6EI-XS |
0, 30 to 10000 |
MSR860-6HI-XS |
0, 30 to 10000 |
MSR2630-XS |
0, 30 to 10000 |
MSR3600-28-XS |
0, 30 to 10000 |
MSR3610-XS |
0, 10 to 10000 |
MSR3620-XS |
0, 10 to 10000 |
MSR3610-I-XS |
0, 10 to 10000 |
MSR3610-IE-XS |
0, 10 to 10000 |
MSR3620-X1-XS |
0, 10 to 10000 |
MSR3640-XS |
0, 10 to 10000 |
MSR3660-XS |
0, 10 to 10000 |
Hardware |
Value range |
MSR810-LM-GL |
0, 30 to 10000 |
MSR810-W-LM-GL |
0, 30 to 10000 |
MSR830-6EI-GL |
0, 30 to 10000 |
MSR830-10EI-GL |
0, 30 to 10000 |
MSR830-6HI-GL |
0, 30 to 10000 |
MSR830-10HI-GL |
0, 30 to 10000 |
MSR1004S-5G-GL |
0, 30 to 10000 |
MSR2600-6-X1-GL |
0, 30 to 10000 |
MSR3600-28-SI-GL |
0, 30 to 10000 |
This command sets the BFD echo packet receiving interval, which is the actual BFD echo packet sending interval.
The local end stops sending echo packets after autonegotiation with the remote end if the following conditions are met:
· The echo function is enabled on the local end.
· The minimum interval for receiving BFD echo packets is set to 0 milliseconds on the remote end.
# Set the minimum interval for receiving BFD echo packets to 500 milliseconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd min-echo-receive-interval 500
bfd static
bfd min-receive-interval
Use bfd min-receive-interval to set the minimum interval for receiving single-hop BFD control packets.
Use undo bfd min-receive-interval to restore the default.
Hardware |
Default |
MSR610 |
The minimum interval for receiving single-hop BFD control packets is 1000 milliseconds. |
MSR2600-10-X1 |
MSR 2630 |
The minimum interval for receiving single-hop BFD control packets is 100 milliseconds. |
MSR3640-G |
MSR3640-X1-HI |
Hardware |
Default |
MSR830-4LM-WiNet |
MSR2600-6-WiNet |
MSR2630-WiNet |
MSR3600-28-WiNet |
MSR3610-X1-WiNet |
Hardware |
Default |
MSR860-6EI-XS |
MSR860-6HI-XS |
MSR2630-XS |
MSR3600-28-XS |
MSR3610-XS |
MSR3620-XS |
MSR3610-I-XS |
MSR3610-IE-XS |
MSR3620-X1-XS |
MSR3640-XS |
MSR3660-XS |
Hardware |
Default |
MSR810-LM-GL |
MSR810-W-LM-GL |
MSR830-6EI-GL |
MSR830-10EI-GL |
MSR830-6HI-GL |
MSR830-10HI-GL |
MSR1004S-5G-GL |
MSR2600-6-X1-GL |
MSR3600-28-SI-GL |
Interface view
BFD template view
interval: Specifies the minimum interval for receiving single-hop BFD control packets, in milliseconds.
Hardware |
Value range |
MSR610 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
MSR2600-10-X1 |
30 to 10000 |
MSR2630 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
10 to 10000 |
10 to 10000 |
10 to 10000 |
10 to 10000 |
MSR3640-G |
10 to 10000 |
MSR3640-X1-HI |
10 to 10000 |
Hardware |
Value range |
30 to 10000 |
MSR830-4LM-WiNet |
30 to 10000 |
30 to 10000 |
30 to 10000 |
MSR2600-6-WiNet |
30 to 10000 |
30 to 10000 |
MSR2630-WiNet |
30 to 10000 |
MSR3600-28-WiNet |
30 to 10000 |
MSR3610-X1-WiNet |
10 to 10000 |
10 to 10000 |
Hardware |
Value range |
MSR860-6EI-XS |
30 to 10000 |
MSR860-6HI-XS |
30 to 10000 |
MSR2630-XS |
30 to 10000 |
MSR3600-28-XS |
30 to 10000 |
MSR3610-XS |
10 to 10000 |
MSR3620-XS |
10 to 10000 |
MSR3610-I-XS |
10 to 10000 |
MSR3610-IE-XS |
10 to 10000 |
MSR3620-X1-XS |
10 to 10000 |
MSR3640-XS |
10 to 10000 |
MSR3660-XS |
10 to 10000 |
Hardware |
Value range |
MSR810-LM-GL |
30 to 10000 |
MSR810-W-LM-GL |
30 to 10000 |
MSR830-6EI-GL |
30 to 10000 |
MSR830-10EI-GL |
30 to 10000 |
MSR830-6HI-GL |
30 to 10000 |
MSR830-10HI-GL |
30 to 10000 |
MSR1004S-5G-GL |
30 to 10000 |
MSR2600-6-X1-GL |
30 to 10000 |
MSR3600-28-SI-GL |
30 to 10000 |
Use this command to prevent the control packet sending rate of the peer end from exceeding the control packet receiving rate of the local end.
The actual control packet sending interval of the peer end takes the greater value between the following values:
· Minimum interval for transmitting BFD control packets on the peer end.
· Minimum interval for receiving BFD control packets on the local end.
# Set the minimum interval for receiving single-hop BFD control packets to 500 milliseconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd min-receive-interval 500
bfd static
bfd min-transmit-interval
Use bfd min-transmit-interval to set the minimum interval for transmitting single-hop BFD control packets.
Use undo bfd min-transmit-interval to restore the default.
Hardware |
Default |
MSR610 |
The minimum interval for transmitting single-hop BFD control packets is 1000 milliseconds. |
MSR2600-10-X1 |
MSR 2630 |
The minimum interval for transmitting single-hop BFD control packets is 100 milliseconds. |
MSR3640-G |
MSR3640-X1-HI |
Hardware |
Default |
MSR830-4LM-WiNet |
MSR2600-6-WiNet |
MSR2630-WiNet |
MSR3600-28-WiNet |
MSR3610-X1-WiNet |
Hardware |
Default |
MSR860-6EI-XS |
MSR860-6HI-XS |
MSR2630-XS |
MSR3600-28-XS |
MSR3610-XS |
MSR3620-XS |
MSR3610-I-XS |
MSR3610-IE-XS |
MSR3620-X1-XS |
MSR3640-XS |
MSR3660-XS |
Hardware |
Default |
MSR810-LM-GL |
MSR810-W-LM-GL |
MSR830-6EI-GL |
MSR830-10EI-GL |
MSR830-6HI-GL |
MSR830-10HI-GL |
MSR1004S-5G-GL |
MSR2600-6-X1-GL |
MSR3600-28-SI-GL |
Interface view
BFD template view
interval: Specifies the minimum interval for transmitting single-hop BFD control packets, in milliseconds.
Hardware |
Value range |
MSR610 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
MSR2600-10-X1 |
30 to 10000 |
MSR2630 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
10 to 10000 |
10 to 10000 |
10 to 10000 |
10 to 10000 |
MSR3640-G |
10 to 10000 |
MSR3640-X1-HI |
10 to 10000 |
Hardware |
Value range |
30 to 10000 |
MSR830-4LM-WiNet |
30 to 10000 |
30 to 10000 |
30 to 10000 |
MSR2600-6-WiNet |
30 to 10000 |
30 to 10000 |
MSR2630-WiNet |
30 to 10000 |
MSR3600-28-WiNet |
30 to 10000 |
MSR3610-X1-WiNet |
10 to 10000 |
10 to 10000 |
Hardware |
Value range |
MSR860-6EI-XS |
30 to 10000 |
MSR860-6HI-XS |
30 to 10000 |
MSR2630-XS |
30 to 10000 |
MSR3600-28-XS |
30 to 10000 |
MSR3610-XS |
10 to 10000 |
MSR3620-XS |
10 to 10000 |
MSR3610-I-XS |
10 to 10000 |
MSR3610-IE-XS |
10 to 10000 |
MSR3620-X1-XS |
10 to 10000 |
MSR3640-XS |
10 to 10000 |
MSR3660-XS |
10 to 10000 |
Hardware |
Value range |
MSR810-LM-GL |
30 to 10000 |
MSR810-W-LM-GL |
30 to 10000 |
MSR830-6EI-GL |
30 to 10000 |
MSR830-10EI-GL |
30 to 10000 |
MSR830-6HI-GL |
30 to 10000 |
MSR830-10HI-GL |
30 to 10000 |
MSR1004S-5G-GL |
30 to 10000 |
MSR2600-6-X1-GL |
30 to 10000 |
MSR3600-28-SI-GL |
30 to 10000 |
Use this command to prevent the BFD packet sending rate from exceeding the device capability.
The actual BFD control packet transmitting interval on the local end is the greater value between the following values:
· Minimum interval for transmitting BFD control packets on the local end.
· Minimum interval for receiving BFD control packets on the peer end.
# Set the minimum interval for transmitting single-hop BFD control packets to 500 milliseconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd min-transmit-interval 500
Use bfd multi-hop authentication-mode to configure the authentication mode for multihop BFD control packets.
Use undo bfd multi-hop authentication-mode to restore the default.
bfd multi-hop authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
No authentication is performed.
Static BFD session view
A static BFD session supports this command only when it is in IPv4 or IPv6 control packet mode used for multihop detection.
# Configure the simple authentication mode for multihop BFD control packets, setting the authentication key ID to 1 and key to 123456.
[Sysname] bfd multi-hop authentication-mode simple 1 plain 123456
Use bfd multi-hop destination-port to configure the destination port number for multihop BFD control packets.
Use undo bfd multi-hop destination-port to restore the default.
The destination port number for multihop BFD control packets is 4784.
port-number: Specifies the destination port number of multihop BFD control packets, 3784 or 4784.
IANA assigned port number 4784 to BFD for multihop BFD detection in control packet mode. By default, H3C devices use 4784 as the destination port number for multihop BFD control packets, while devices from other vendors might use 3784. To avoid BFD session establishment failures, make sure the devices on both ends of the BFD session use the same destination port number for multihop BFD control packets.
This command applies to only new multihop BFD sessions in control packet mode.
# Specify the destination port number for multihop BFD control packets as 3784.
[Sysname] bfd multi-hop destination-port 3784
Use bfd multi-hop detect-multiplier to set the multihop detection time multiplier for control packet mode and echo packet mode.
Use undo bfd multi-hop detect-multiplier to restore the default.
The multihop detection time multiplier is 3.
value: Specifies the multihop detection time multiplier in the range of 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD control packets that can be discarded.
Table 2 Actual detection interval calculation method
Mode |
Echo packet mode |
Only the following static BFD sessions support this command:
· Static BFD sessions in IPv4 control packet mode used for multihop detection.
· Static BFD sessions in IPv4 echo packet mode used for multihop detection.
· Static BFD sessions in IPv6 control packet mode used for multihop detection.
· Static BFD sessions in IPv6 echo packet mode used for multihop detection.
# Set the multihop detection time multiplier to 6.
[Sysname] bfd multi-hop detect-multiplier 6
Use bfd multi-hop min-echo-receive-interval to set the minimum interval for receiving multihop BFD echo packets.
Use undo bfd multi-hop min-echo-receive-interval to restore the default.
bfd multi-hop min-echo-receive-interval interval
Hardware |
Default |
MSR610 |
The minimum interval for receiving multihop BFD echo packets is 1000 milliseconds. |
MSR2600-10-X1 |
MSR 2630 |
The minimum interval for receiving multihop BFD echo packets is 100 milliseconds. |
MSR3640-G |
MSR3640-X1-HI |
Hardware |
Default |
MSR830-4LM-WiNet |
MSR2600-6-WiNet |
MSR2630-WiNet |
MSR3600-28-WiNet |
MSR3610-X1-WiNet |
Hardware |
Default |
MSR860-6EI-XS |
MSR860-6HI-XS |
MSR2630-XS |
MSR3600-28-XS |
MSR3610-XS |
MSR3620-XS |
MSR3610-I-XS |
MSR3610-IE-XS |
MSR3620-X1-XS |
MSR3640-XS |
MSR3660-XS |
Hardware |
Default |
MSR810-LM-GL |
MSR810-W-LM-GL |
MSR830-6EI-GL |
MSR830-10EI-GL |
MSR830-6HI-GL |
MSR830-10HI-GL |
MSR1004S-5G-GL |
MSR2600-6-X1-GL |
MSR3600-28-SI-GL |
interval: Specifies the minimum interval for receiving multihop BFD echo packets, in milliseconds.
Hardware |
Value range |
MSR610 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
MSR2600-10-X1 |
0, 30 to 10000 |
MSR2630 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
0, 10 to 10000 |
0, 10 to 10000 |
0, 10 to 10000 |
0, 10 to 10000 |
MSR3640-G |
0, 10 to 10000 |
MSR3640-X1-HI |
0, 10 to 10000 |
Hardware |
Value range |
0, 30 to 10000 |
MSR830-4LM-WiNet |
0, 30 to 10000 |
0, 30 to 10000 |
0, 30 to 10000 |
MSR2600-6-WiNet |
0, 30 to 10000 |
0, 30 to 10000 |
MSR2630-WiNet |
0, 30 to 10000 |
MSR3600-28-WiNet |
0, 30 to 10000 |
MSR3610-X1-WiNet |
0, 10 to 10000 |
0, 10 to 10000 |
Hardware |
Value range |
MSR860-6EI-XS |
0, 30 to 10000 |
MSR860-6HI-XS |
0, 30 to 10000 |
MSR2630-XS |
0, 30 to 10000 |
MSR3600-28-XS |
0, 30 to 10000 |
MSR3610-XS |
0, 10 to 10000 |
MSR3620-XS |
0, 10 to 10000 |
MSR3610-I-XS |
0, 10 to 10000 |
MSR3610-IE-XS |
0, 10 to 10000 |
MSR3620-X1-XS |
0, 10 to 10000 |
MSR3640-XS |
0, 10 to 10000 |
MSR3660-XS |
0, 10 to 10000 |
Hardware |
Value range |
MSR810-LM-GL |
0, 30 to 10000 |
MSR810-W-LM-GL |
0, 30 to 10000 |
MSR830-6EI-GL |
0, 30 to 10000 |
MSR830-10EI-GL |
0, 30 to 10000 |
MSR830-6HI-GL |
0, 30 to 10000 |
MSR830-10HI-GL |
0, 30 to 10000 |
MSR1004S-5G-GL |
0, 30 to 10000 |
MSR2600-6-X1-GL |
0, 30 to 10000 |
MSR3600-28-SI-GL |
0, 30 to 10000 |
The interval for receiving multihop BFD echo packets is also the interval for sending multihop BFD echo packets. By executing this command, you can control both the receiving interval and sending interval for multihop BFD echo packets.
This command takes effect only on static BFD sessions for multihop detection with echo packets.
# Set the minimum interval for receiving multihop BFD echo packets to 500 milliseconds.
[Sysname] bfd multi-hop min-echo-receive-interval 500
bfd static
Use bfd multi-hop min-receive-interval to set the minimum interval for receiving multihop BFD control packets.
Use undo bfd multi-hop min-receive-interval to restore the default.
Hardware |
Default |
MSR610 |
The minimum interval for receiving multihop BFD control packets is 1000 milliseconds. |
MSR2600-10-X1 |
MSR2630 |
The minimum interval for receiving multihop BFD control packets is 100 milliseconds. |
MSR3640-G |
MSR3640-X1-HI |
Hardware |
Default |
MSR830-4LM-WiNet |
MSR2600-6-WiNet |
MSR2630-WiNet |
MSR3600-28-WiNet |
MSR3610-X1-WiNet |
Hardware |
Default |
MSR860-6EI-XS |
MSR860-6HI-XS |
MSR2630-XS |
MSR3600-28-XS |
MSR3610-XS |
MSR3620-XS |
MSR3610-I-XS |
MSR3610-IE-XS |
MSR3620-X1-XS |
MSR3640-XS |
MSR3660-XS |
Hardware |
Default |
MSR810-LM-GL |
MSR810-W-LM-GL |
MSR830-6EI-GL |
MSR830-10EI-GL |
MSR830-6HI-GL |
MSR830-10HI-GL |
MSR1004S-5G-GL |
MSR2600-6-X1-GL |
MSR3600-28-SI-GL |
interval: Specifies the minimum interval for receiving multihop BFD control packets, in millis econds.
Hardware |
Value range |
MSR610 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
MSR2600-10-X1 |
30 to 10000 |
MSR2630 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
10 to 10000 |
10 to 10000 |
10 to 10000 |
10 to 10000 |
MSR3640-G |
10 to 10000 |
MSR3640-X1-HI |
10 to 10000 |
Hardware |
Value range |
30 to 10000 |
MSR830-4LM-WiNet |
30 to 10000 |
30 to 10000 |
30 to 10000 |
MSR2600-6-WiNet |
30 to 10000 |
30 to 10000 |
MSR2630-WiNet |
30 to 10000 |
MSR3600-28-WiNet |
30 to 10000 |
MSR3610-X1-WiNet |
10 to 10000 |
10 to 10000 |
Hardware |
Value range |
MSR860-6EI-XS |
30 to 10000 |
MSR860-6HI-XS |
30 to 10000 |
MSR2630-XS |
30 to 10000 |
MSR3600-28-XS |
30 to 10000 |
MSR3610-XS |
10 to 10000 |
MSR3620-XS |
10 to 10000 |
MSR3610-I-XS |
10 to 10000 |
MSR3610-IE-XS |
10 to 10000 |
MSR3620-X1-XS |
10 to 10000 |
MSR3640-XS |
10 to 10000 |
MSR3660-XS |
10 to 10000 |
Hardware |
Value range |
MSR810-LM-GL |
30 to 10000 |
MSR810-W-LM-GL |
30 to 10000 |
MSR830-6EI-GL |
30 to 10000 |
MSR830-10EI-GL |
30 to 10000 |
MSR830-6HI-GL |
30 to 10000 |
MSR830-10HI-GL |
30 to 10000 |
MSR1004S-5G-GL |
30 to 10000 |
MSR2600-6-X1-GL |
30 to 10000 |
MSR3600-28-SI-GL |
30 to 10000 |
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving capability (minimum control packet receiving interval) of the local end. If the receiving capability is exceeded, the peer end dynamically adjusts the BFD control packet sending interval to the minimum control packet receiving interval of the local end.
# Set the minimum interval for receiving multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-receive-interval 500
Use bfd multi-hop min-transmit-interval to set the minimum interval for transmitting multihop BFD control packets.
Use undo bfd multi-hop min-transmit-interval to restore the default.
Hardware |
Default |
MSR610 |
The minimum interval for transmitting multihop BFD control packets is 1000 milliseconds. |
MSR2600-10-X1 |
MSR 2630 |
The minimum interval for transmitting multihop BFD control packets is 100 milliseconds. |
MSR3640-G |
MSR3640-X1-HI |
Hardware |
Default |
MSR830-4LM-WiNet |
MSR2600-6-WiNet |
MSR2630-WiNet |
MSR3600-28-WiNet |
MSR3610-X1-WiNet |
Hardware |
Default |
MSR860-6EI-XS |
MSR860-6HI-XS |
MSR2630-XS |
MSR3600-28-XS |
MSR3610-XS |
MSR3620-XS |
MSR3610-I-XS |
MSR3610-IE-XS |
MSR3620-X1-XS |
MSR3640-XS |
MSR3660-XS |
Hardware |
Default |
MSR810-LM-GL |
MSR810-W-LM-GL |
MSR830-6EI-GL |
MSR830-10EI-GL |
MSR830-6HI-GL |
MSR830-10HI-GL |
MSR1004S-5G-GL |
MSR2600-6-X1-GL |
MSR3600-28-SI-GL |
interval: Specifies the minimum interval for transmitting multihop BFD control packets, in milliseconds.
Hardware |
Value range |
MSR610 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
MSR2600-10-X1 |
30 to 10000 |
MSR2630 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
10 to 10000 |
10 to 10000 |
10 to 10000 |
10 to 10000 |
MSR3640-G |
10 to 10000 |
MSR3640-X1-HI |
10 to 10000 |
Hardware |
Value range |
30 to 10000 |
MSR830-4LM-WiNet |
30 to 10000 |
30 to 10000 |
30 to 10000 |
MSR2600-6-WiNet |
30 to 10000 |
30 to 10000 |
MSR2630-WiNet |
30 to 10000 |
MSR3600-28-WiNet |
30 to 10000 |
MSR3610-X1-WiNet |
10 to 10000 |
10 to 10000 |
Hardware |
Value range |
MSR860-6EI-XS |
30 to 10000 |
MSR860-6HI-XS |
30 to 10000 |
MSR2630-XS |
30 to 10000 |
MSR3600-28-XS |
30 to 10000 |
MSR3610-XS |
10 to 10000 |
MSR3620-XS |
10 to 10000 |
MSR3610-I-XS |
10 to 10000 |
MSR3610-IE-XS |
10 to 10000 |
MSR3620-X1-XS |
10 to 10000 |
MSR3640-XS |
10 to 10000 |
MSR3660-XS |
10 to 10000 |
Hardware |
Value range |
MSR810-LM-GL |
30 to 10000 |
MSR810-W-LM-GL |
30 to 10000 |
MSR830-6EI-GL |
30 to 10000 |
MSR830-10EI-GL |
30 to 10000 |
MSR830-6HI-GL |
30 to 10000 |
MSR830-10HI-GL |
30 to 10000 |
MSR1004S-5G-GL |
30 to 10000 |
MSR2600-6-X1-GL |
30 to 10000 |
MSR3600-28-SI-GL |
30 to 10000 |
# Set the minimum interval for transmitting multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-transmit-interval 500
bfd session init-mode
Use bfd session init-mode to configure the mode for establishing a BFD session.
Use undo bfd session init-mode to restore the default.
BFD uses the active mode.
active: Specifies the active mode. In active mode, BFD actively transmits BFD control packets to the remote device, regardless of whether it receives a BFD control packet from the remote device.
passive: Specifies the passive mode. In passive mode, BFD does not actively transmit a BFD control packet to the remote end; it transmits a BFD control packet only after receiving a BFD control packet from the remote end.
A minimum of one end must operate in active mode for a BFD session to be established.
# Configure the session establishment mode as passive.
[Sysname] bfd session init-mode passive
bfd static
Use bfd static to create a static BFD session and enter its view, or enter the view of an existing static BFD session.
Use undo bfd static to delete a static BFD session and all its settings.
Static BFD session for single-hop detection with IPv4 control packets:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number source-ip ipv4-address discriminator local local-value remote remote-value ]
undo bfd static session-name
Static BFD session for multihop detection with IPv4 control packets:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] source-ip ipv4-address discriminator local local-value remote remote-value ]
Static BFD session for single-hop detection with IPv4 echo packets:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo discriminator { local local-value | auto } ]
Static BFD session for multihop detection with IPv4 echo packets:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo discriminator { local local-value | auto } ]
Static BFD session for single-hop detection with IPv6 control packets:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number source-ipv6 ipv6-address discriminator local local-value remote remote-value ]
Static BFD session for multihop detection with IPv6 control packets:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] source-ipv6 ipv6-address discriminator local local-value remote remote-value ]
Static BFD session for single-hop detection with IPv6 echo packets:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo discriminator { local local-value | auto } ]
Static BFD session for multihop detection with IPv6 echo packets:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo discriminator { local local-value | auto } ]
Static BFD session for single-hop detection with IPv4 control packets (the peer address is fixed at 224.0.0.184):
bfd static session-name [ peer-ip default-ip interface interface-type interface-number source-ip ip-address discriminator local discr-value remote discr-value ]
No static BFD sessions exist.
session-name: Specifies a static BFD session name, a case-sensitive string of 1 to 64 characters.
peer-ip ipv4-address: Specifies the peer IPv4 address in dotted decimal notation. It must be a valid unicast IPv4 address. For a static BFD session in control packet mode, the peer IPv4 address and the source IPv4 address determine the path to be detected. For a static BFD session in echo packet mode, the peer IPv4 address and the destination IPv4 address determine the path to be detected.
peer-ipv6 ipv6-address: Specifies the peer IPv6 address. For a static BFD session in control packet mode, the peer IPv6 address and the source IPv6 address determine the path to be detected. For a static BFD session in echo packet mode, the peer IPv6 address and the destination IPv6 address determine the path to be detected.
default-ip: Specifies the peer IPv4 address as 224.0.0.184.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the static BFD session belongs to the public network.
interface interface-type interface-number: Specifies an interface by its type and number. BFD uses the specified interface as the outgoing interface for outgoing packets.
destination-ip ipv4-address: Specifies the destination IPv4 address for echo packets, in dotted decimal notation. It must be a valid unicast IPv4 address of the local end.
destination-ipv6 ipv6-address: Specifies the destination IPv6 address for echo packets. It must be the IPv6 address of the local end.
source-ip ipv4-address: Specifies the source IPv4 address for BFD packets, in dotted decimal notation. It must be a valid unicast IPv4 address.
source-ipv6 ipv6-address: Specifies the source IPv6 address for BFD packets.
one-arm-echo: Specifies the static BFD session mode as echo packet mode.
local local-value: Specifies the local discriminator in the range of 1 to 32768.
auto: Enables the device to automatically assign local discriminator values to static BFD sessions.
By working with Track, a static BFD session can provide fast failure detection. For more information about Track association with BFD, see Track in High Availability Configuration Guide.
If a static BFD session in control packet mode is created on the peer device, you must use this command to create a static BFD session on the local device. The BFD session discriminators must match on the local and peer devices. For example, if you configure bfd static abc peer-ip 20.1.1.1 vpn-instance vpn1 source-ip 20.1.1.2 discriminator local 513 remote 514 on the local device, you must configure bfd static bcd peer-ip 20.1.1.2 vpn-instance vpn1 source-ip 20.1.1.1 discriminator local 514 remote 513 on the peer device.
When creating a static BFD session, you must specify a peer IP address. The system checks only the format of the IP address but not its correctness. If the peer IPv4 or IPv6 address is incorrect, the static BFD session cannot be established.
You need to create a static BFD session on only the local device if you use the echo packet mode to perform detection. As a best practice, specify the source IP address for echo packets when creating a static BFD session. Make sure the specified source IP address does not belong to the subnet where a local interface resides. Without a source IP address specified, the device uses the IP address specified in the bfd echo-source-ip or bfd echo-source-ipv6 command as the source IP address of echo packets.
Without the source-ip/source-ipv6 or bfd echo-source-ip/bfd echo-source-ipv6 keyword specified, the device uses the IPv4 or IPv6 address specified for the destination-ip/destination-ipv6 keyword as the source IPv4 or IPv6 address of echo packets.
To use a static BFD session in control packet for single-hop detection, you must perform the following configuration:
· Specify the IP address of the peer interface for the peer-ip/peer-ipv6 parameter.
· Specify the IP address of the local interface for the source-ip/source-ipv6 parameter.
The bfd static session-name command without any parameters specified can only be used to enter the view of an existing static BFD session.
To modify a static BFD session, delete it and then configure a new static BFD session.
If you do not specify a VPN instance or an interface, the device performs multihop detection in the public network.
To detect network layer connectivity, execute the following commands:
· bfd static session-name peer-ip ipv4-address interface interface-type interface-number source-ip ipv4-address discriminator local local-value remote remote-value
For the static BFD session to be successfully established, make sure the IPv4 addresses of the local and peer interfaces where the static BFD session resides are used as the source and peer IPv4 addresses, respectively.
· bfd static session-name peer-ipv6 ipv6-address interface interface-type interface-number source-ipv6 ipv6-address discriminator local local-value remote remote-value
For the static BFD session to be successfully established, make sure the IPv6 addresses of the local and peer interfaces where the static BFD session resides are used as the source and peer IPv6 addresses, respectively.
To detect data link layer connectivity, execute the following command:
· bfd static session-name peer-ip default-ip interface interface-type interface-number source-ip ip-address discriminator local discr-value remote discr-value
If the process-interface-status command is also executed, BFD sets the interface state to DOWN(BFD) when detecting a link failure. Specify the IP address of the interface as the source IP address. If the interface does not have an IP address, specify a unicast IP address other than 0.0.0.0 as the source IP address. An interface can use only one static BFD session to detect data link layer connectivity.
For a static BFD session in control packet mode, the source IP address of BFD packets is the IP address specified for the source-ip/source-ipv6 keyword, and the destination IP address is the IP address specified for the peer-ip/peer-ipv6 keyword.
For a static BFD session in echo packet mode, the source IP address of BFD packets is the IP address specified for the source-ip/source-ipv6 keyword, and the destination IP address is the IP address specified for the destination-ip/destination-ipv6 keyword. Without the source-ip/source-ipv6 or bfd echo-source-ip/bfd echo-source-ipv6 keyword specified, the device uses the IPv4 or IPv6 address specified for the destination-ip/destination-ipv6 keyword as the source IPv4 or IPv6 address of echo packets.
BFD supports detecting data link connectivity for the following interface types:
· Layer 3 aggregate interfaces, Layer 3 aggregate subinterfaces, and member ports in a Layer 3 aggregation group. For BFD detection to take effect, do not execute this command on any two of the interface types at the same time.
· VLAN interfaces.
· Serial interfaces, POS interfaces, serial interfaces created from E1, T1, MP-group interfaces, member interfaces of an MP-group interface, HDLC link bundle interfaces, and member interfaces of an HDLC link bundle interface. For BFD detection to take effect, do not execute this command on a member interface of an MP-group interface and a member interface of an HDLC link bundle interface at the same time.
Different static BFD sessions cannot have the same local discriminator.
# Create a static BFD session and enter its view. The static BFD session detects the path between 1.1.1.1 and 1.1.1.2 and uses GigabitEthernet 1/0/1 to send BFD packets with source IP address 1.1.1.1 and destination IP address is 1.1.1.2. The local discriminator is 1537, and the remote discriminator is 2048.
[Sysname] bfd static aaaa peer-ip 1.1.1.2 interface gigabitethernet 1/0/1 source-ip 1.1.1.1 discriminator local 1537 remote 2048
[Sysname-bfd-static-session-abc]
# Create a static BFD session and enter its view. The static BFD session detects the path between 1.1.1.1 and 1.1.1.2 and uses GigabitEthernet 1/0/1 to send BFD packets with source IP address 9.9.9.9 and destination IP address is 1.1.1.2.
[Sysname] bfd static abc peer-ip 1.1.1.1 interface gigabitethernet 1/0/1 destination-ip 1.1.1.2 source-ip 9.9.9.9 one-arm-echo discriminator auto
bfd echo-source-ip
bfd template
Use bfd template to create a BFD template and enter its view, or enter the view of an existing BFD template.
Use undo bfd template to delete the BFD template.
bfd template template-name
undo bfd template template-name
No BFD templates exist.
template-name: Specifies the template name, a case-sensitive string of 1 to 63 characters.
# Create BFD template bfd1 and enter BFD template view.
[Sysname] bfd template bfd1
[Sysname-bfd-template-bfd1]
display bfd session
Use display bfd session to display BFD session information.
display bfd session [ discriminator local local-value | static name session-name | verbose ]
display bfd session [ [ dynamic ] [ control | echo ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ lsp | te | pw ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ verbose ] ]
display bfd session [ [ static ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
display bfd session [ [ static ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
discriminator local local-value: Specifies a BFD session by its local discriminator in the range of 1 to 4294967295.
name session-name: Specifies a static BFD session by its name, a case-sensitive string of 1 to 64 characters.
dynamic: Specifies dynamic BFD sessions.
static: Specifies static BFD sessions.
control: Specifies BFD sessions in control mode.
echo: Specifies BFD sessions in echo mode.
ip: Specifies BFD sessions used to detect IPv4 links.
ipv6: Specifies BFD sessions used to detect IPv6 links.
lsp: Specifies BFD sessions used to detect MPLS LSPs.
te: Specifies BFD sessions used to detect MPLS TE tunnels.
pw: Specifies BFD sessions used to detect PWs.
state: Displays BFD sessions by session state.
down: Specifies BFD sessions in Down state.
admin-down: Specifies BFD sessions in AdminDown state.
init: Specifies BFD sessions in Init state.
up: Specifies BFD sessions in Up state.
discriminator remote remote-value: Specifies a BFD session by its remote discriminator in the range of 1 to 4294967295.
peer-ip ipv4-address: Specifies a BFD session by the peer IPv4 address in dotted decimal notation.
peer-ipv6 ipv6-address: Specifies a BFD session by the peer IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays information for the BFD sessions of the public network.
verbose: Displays detailed BFD session information.
If you do not specify the dynamic or static keyword, this command displays all dynamic and static BFD sessions.
# Display brief information about all BFD sessions.
<Sysname> display bfd session
Total sessions: 9 Up sessions: 9 Init mode: Active
LD/RD SourceIP DestinationIP State Holdtime Interface
513/513 1.1.1.1 1.1.1.2 Up 2297ms GE1/0/1
IPv6 session working in control packet mode:
Local discr: 513 Remote discr: 513
Source IP: FE80::20C:29FF:FED4:7171
Destination IP: FE80::20C:29FF:FE72:AC4D
Session state: Up Interface: GE1/0/1
Hold time: 2142ms
IPv4 static session working in control packet mode:
1017/7101 2.1.1.1 2.1.1.2 Up 4988ms GE1/0/1
IPv6 static session working in control packet mode:
Local discr: 1226 Remote discr: 6221
Source IP: 12::1
Destination IP: 12::2
Hold time: 4812ms
IPv4 static session working in echo mode:
LD SourceIP DestinationIP State Holdtime Interface
1226 192.168.51.1 192.168.51.5 Up 4238ms GE1/0/1
IPv6 static session working in echo mode:
Local discr: 2012
Source IP: 15::1
Destination IP: 15::5
Hold time: 4626ms
MPLS LSP session working in control packet mode:
32769/32769 2.2.2.9 127.0.0.1 Up 4990ms N/A
MPLS TE session working in echo mode:
32777 1.1.1.1 3.3.3.3 Up 4430ms Tun0
MPLS PW session working in control packet mode:
20481/20481 2.2.2.2 127.0.0.1 Up 2489ms N/A
Total sessions |
Total number of BFD sessions. |
Up sessions |
Total number of active BFD sessions. |
Init mode |
BFD operating mode: Active or Passive. |
XX session working in yy mode |
BFD session type and operating mode: · IPv4 session working in control packet mode. · IPv4 session working in echo mode. · IPv6 session working in control packet mode. · IPv6 session working in echo mode. · IPv4 static session working in echo mode. · IPv6 static session working in echo mode. · MPLS LSP session working in control packet mode—BFD session in control mode used to detect failures in an LSP. · MPLS LSP session working in echo mode—BFD session in echo mode used to detect failures in an LSP. · MPLS TE session working in control packet mode. · MPLS TE session working in echo mode. · MPLS PW session working in control packet mode. · IPv4 SDWAN session working in control packet mode. · IPv6 SDWAN session working in control packet mode. |
LD/RD |
Local discriminator/Remote discriminator of the session. |
Source IP |
Source IPv4 address of the session. |
Destination IP |
Destination IPv4 address of the session. |
State |
Session state: Down, Init, Adown, or Up. |
Holdtime |
Length of time before session detection timer expires. For a BFD session in Down state, this field displays 0ms. |
Name of the interface of the session. |
Local discr |
Local discriminator of the session. |
Remote discr |
Session state |
Session state: Down, Adown, Init, or Up. |
Hold time |
# Display detailed information about all BFD sessions.
<Sysname> display bfd session verbose
Local discr: 33793 Remote discr: 33793
Source IP: 23.1.1.2 Destination IP: 23.1.1.3
Destination port: 3784 Session state: Up
Min Tx interval: 1000ms Actual Tx interval: 1000ms
Min Rx interval: 1000ms Detection time: 5000ms
Rx count: 133 Tx count: 142
Connection type: Direct Up duration: 00:02:01
Hold time: 4571ms Auth mode: None
Detection mode: Async Slot: 0
Protocol: OSPF
Version: 1
Diag info: No Diagnostic
Local discr: 33794 Remote discr: 33794
Source IP: FE80::5457:A5FF:FE0F:306
Destination IP: FE80::5457:A1FF:FEB5:206
Rx count: 3262 Tx count: 3048
Connection type: Direct Up duration: 00:44:26
Hold time: 4409ms Auth mode: None
Protocol: OSPFv3
Version: 1
Session name: abc
Local discr: 1017 Remote discr: 7101
Source IP: 2.1.1.1 Destination IP: 2.1.1.2
Rx count: 1012 Tx count: 1064
Connection type: Direct Up duration: 00:14:41
Hold time: 4438ms Auth mode: None
Protocol: STATIC_IPv4
Version: 1
Session name: blue
Source IP: 12::1
Rx count: 225 Tx count: 266
Connection type: Direct Up duration: 00:03:13
Hold time: 4371ms Auth mode: None
Protocol: STATIC_IPv6
Version: 1
Session name: aa
Local discr: 1226
Source IP: 192.168.51.1 Destination IP: 192.168.51.5
Destination port: 3785 Session state: Up
Hold time: 4965ms Actual Tx interval: 1000ms
Rx count: 308 Tx count: 308
Connection type: Direct Up duration: 00:04:28
Version: 1
Session name: bb
Local discr: 2012
Source IP: 15::1 Destination IP: 15::5
Hold time: 4426ms Actual Tx interval: 1000ms
Rx count: 193 Tx count: 193
Connection type: Direct Up duration: 00:02:46
Version: 1
Local discr: 32769 Remote discr: 32769
Source IP: 3.3.3.9 Destination IP: 2.2.2.9
Destination port: 4784 Session state: Up
Interface: N/A
Rx count: 1778 Tx count: 1669
Connection type: Indirect Up duration: 00:24:14
Hold time: 4248ms Auth mode: None
Protocol: MPLS_LSPV
Version: 1
Local discr: 32777
Source IP: 1.1.1.1 Destination IP: 3.3.3.3
Interface: Tunnel0
Hold time: 4450ms Actual Tx interval: 1000ms
Rx count: 320 Tx count: 320
Connection type: Indirect Up duration: 00:04:35
Protocol: MPLS_LSPV
Version: 1
Local discr: 20481 Remote discr: 20481
Source IP: 2.2.2.2 Destination IP: 127.0.0.1
Interface: N/A
Min Tx interval: 500ms Actual Tx interval: 500ms
Min Rx interval: 500ms Detection time: 2500ms
Rx count: 72 Tx count: 73
Connection type: Indirect Up duration: 00:00:30
Hold time: 2489ms Auth mode: None
Protocol: MPLS_LSPV
Version: 1
Total sessions |
Up sessions |
Init mode |
Local discr |
Local ID of the session. |
Remote discr |
Remote ID of the session. |
Source IP |
Source IP address of the session. |
Destination IP |
Destination IP address of the session. |
Session state |
Session state: Down, Init, or Up. |
Min Tx interval |
Minimum transmit interval. |
Min Rx interval |
Minimum receive interval. |
Actual Tx interval |
Actual transmit interval. |
Detection time |
Actual session detection timer. |
Rx count |
Number of packets received. |
Tx count |
Number of packets sent. |
Connection type |
Connection type of the interface: Direct or indirect. |
Up duration |
Time period for which the session has been up. |
Hold time |
Length of time before session detection timer expires. For a BFD session in down state, this field displays 0ms. |
Auth mode |
Session authentication mode. |
Connect type |
Up duration |
Detection mode |
Detection mode: · Async—Asynchronous mode. · Demand—Demand mode. · Async/Echo—Asynchronous mode with echo function enabled. · Demand/Echo—Demand mode with echo function enabled. |
Slot |
(In standalone mode.) Slot number of the device. (In IRF mode.) Slot number of the card where the BFD session resides. |
Protocol |
Protocol associated with BFD: · OSPF. · ISIS_BR_L1—IS-IS with the network type as broadcast and the router type as Level 1. · ISIS_BR_L2—IS-IS with the network type as broadcast and the router type as Level 2. · ISIS_P2P—IS-IS with the network type as P2P. · ISIS6_BR_L1—IPv6 IS-IS with the network type as broadcast and the router type as Level 1. · ISIS6_BR_L2—IPv6 IS-IS with the network type as broadcast and the router type as Level 2. · ISIS6_P2P—IPv6 IS-IS with the network type as P2P. · BGP. · MPLS_RSVP. · STATIC4—IPv4 static routing. · TRACK—Track. · RIP. · IPFRR—FIB IP FRR. · MAD. · MPLS_LSPV. · OSPFv3. · BGP4+. · PIM. · PIM6—IPv6 PIM. · STATIC6—IPv6 static routing. · RIPNG—RIPng. · Interface—Interface state. · TUNNEL. · VTEP. · LAGG—Link aggregation. · STATIC_IPv4—IPv4 static BFD session. · STATIC_IPv6—IPv6 static BFD session. · STATIC_IPv4/SFC—Static BFD session for service chains. · SDWAN—BFD session for SDWAN tunnels.. |
Diag info |
Diagnostic information about the session: · No Diagnostic. · Control Detection Time Expired—A control-mode BFD session goes down because local detection times out. · Echo Function Failed—An echo-mode BFD session goes down, because local detection times out or the source IP address of echo packets is deleted. · Neighbor Signaled Session Down—The remote end notifies the local end of BFD session down. · Administratively Down—The local system prevents a BFD session from being established. |
reset bfd session statistics
Use reset bfd session statistics to clear the BFD session statistics.
# Clear the BFD session statistics.
<Sysname> reset bfd session statistics
snmp-agent trap enable bfd
Use snmp-agent trap enable bfd to enable SNMP notifications for BFD.
Use undo snmp-agent trap enable bfd to disable SNMP notifications for BFD.
All SNMP notifications are enabled for BFD.
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
# Disable SNMP notifications for BFD.
[Sysname] undo snmp-agent trap enable bfd
SBFD commands
Use bfd detect-multiplier to set the detection time multiplier in BFD template view.
The detection time multiplier is 3.
BFD template view
value: Specifies a detection time multiplier in the range of 3 to 50.
The detection time multiplier determines the maximum number of SBFD control packets that an initiator can discard continuously.
The detection time is the detection time multiplier of the initiator multiplied by the minimum SBFD packet sending interval of the initiator.
# In BFD template abc, set the detection time multiplier to 6.
[Sysname] bfd template abc
[Sysname-bfd-template-abc] bfd detect-multiplier 6
Use bfd min-transmit-interval to set the minimum interval for transmitting SBFD control packets in BFD template view.
Hardware |
Default |
MSR610 |
The minimum interval for transmitting SBFD control packets is 1000 milliseconds. |
MSR2600-10-X1 |
MSR2630 |
The minimum interval for transmitting SBFD control packets is 100 milliseconds. |
MSR3640-G |
MSR3640-X1-HI |
Hardware |
Default |
MSR830-4LM-WiNet |
MSR2600-6-WiNet |
MSR2630-WiNet |
MSR3600-28-WiNet |
MSR3610-X1-WiNet |
Hardware |
Default |
MSR860-6EI-XS |
MSR860-6HI-XS |
MSR2630-XS |
MSR3600-28-XS |
MSR3610-XS |
MSR3620-XS |
MSR3610-I-XS |
MSR3610-IE-XS |
MSR3620-X1-XS |
MSR3640-XS |
MSR3660-XS |
Hardware |
Default |
MSR810-LM-GL |
MSR810-W-LM-GL |
MSR830-6EI-GL |
MSR830-10EI-GL |
MSR830-6HI-GL |
MSR830-10HI-GL |
MSR1004S-5G-GL |
MSR2600-6-X1-GL |
MSR3600-28-SI-GL |
BFD template view
interval: Specifies the minimum interval for transmitting SBFD control packets, in milliseconds.
Hardware |
Value range |
MSR610 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
MSR2600-10-X1 |
30 to 10000 |
MSR2630 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
10 to 10000 |
10 to 10000 |
10 to 10000 |
10 to 10000 |
MSR3640-G |
10 to 10000 |
MSR3640-X1-HI |
10 to 10000 |
Hardware |
Value range |
30 to 10000 |
MSR830-4LM-WiNet |
30 to 10000 |
30 to 10000 |
30 to 10000 |
MSR2600-6-WiNet |
30 to 10000 |
30 to 10000 |
MSR2630-WiNet |
30 to 10000 |
MSR3600-28-WiNet |
30 to 10000 |
MSR3610-X1-WiNet |
10 to 10000 |
10 to 10000 |
Hardware |
Value range |
MSR860-6EI-XS |
30 to 10000 |
MSR860-6HI-XS |
30 to 10000 |
MSR2630-XS |
30 to 10000 |
MSR3600-28-XS |
30 to 10000 |
MSR3610-XS |
10 to 10000 |
MSR3620-XS |
10 to 10000 |
MSR3610-I-XS |
10 to 10000 |
MSR3610-IE-XS |
10 to 10000 |
MSR3620-X1-XS |
10 to 10000 |
MSR3640-XS |
10 to 10000 |
MSR3660-XS |
10 to 10000 |
Hardware |
Value range |
MSR810-LM-GL |
30 to 10000 |
MSR810-W-LM-GL |
30 to 10000 |
MSR830-6EI-GL |
30 to 10000 |
MSR830-10EI-GL |
30 to 10000 |
MSR830-6HI-GL |
30 to 10000 |
MSR830-10HI-GL |
30 to 10000 |
MSR1004S-5G-GL |
30 to 10000 |
MSR2600-6-X1-GL |
30 to 10000 |
MSR3600-28-SI-GL |
30 to 10000 |
Use this command to prevent the SBFD control packet sending rate from exceeding the device capability.
The actual SBFD control packet transmitting interval is the set minimum interval.
# In BFD template abc, set the minimum interval for transmitting SBFD control packets to 500 milliseconds.
[Sysname-bfd-template-abc] bfd min-transmit-interval 500
Use bfd multi-hop detect-multiplier to set the detection time multiplier in system view.
The detection time multiplier is 5.
# Set the detection time multiplier to 6.
Use bfd multi-hop min-transmit-interval to set the minimum interval for transmitting SBFD control packets in system view.
Hardware |
Default |
MSR610 |
The minimum interval for transmitting SBFD control packets is 1000 millisecons. |
MSR2600-10-X1 |
MSR 2630 |
The minimum interval for transmitting SBFD control packets is 100 millisecons. |
MSR3640-G |
MSR3640-X1-HI |
Hardware |
Default |
MSR830-4LM-WiNet |
MSR2600-6-WiNet |
MSR2630-WiNet |
MSR3600-28-WiNet |
MSR3610-X1-WiNet |
Hardware |
Default |
MSR860-6EI-XS |
MSR860-6HI-XS |
MSR2630-XS |
MSR3600-28-XS |
MSR3610-XS |
MSR3620-XS |
MSR3610-I-XS |
MSR3610-IE-XS |
MSR3620-X1-XS |
MSR3640-XS |
MSR3660-XS |
Hardware |
Default |
MSR810-LM-GL |
MSR810-W-LM-GL |
MSR830-6EI-GL |
MSR830-10EI-GL |
MSR830-6HI-GL |
MSR830-10HI-GL |
MSR1004S-5G-GL |
MSR2600-6-X1-GL |
MSR3600-28-SI-GL |
Hardware |
Value range |
MSR610 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
MSR2600-10-X1 |
30 to 10000 |
MSR2630 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
30 to 10000 |
10 to 10000 |
10 to 10000 |
10 to 10000 |
10 to 10000 |
MSR3640-G |
10 to 10000 |
MSR3640-X1-HI |
10 to 10000 |
Hardware |
Value range |
30 to 10000 |
MSR830-4LM-WiNet |
30 to 10000 |
30 to 10000 |
30 to 10000 |
MSR2600-6-WiNet |
30 to 10000 |
30 to 10000 |
MSR2630-WiNet |
30 to 10000 |
MSR3600-28-WiNet |
30 to 10000 |
MSR3610-X1-WiNet |
10 to 10000 |
10 to 10000 |
Hardware |
Value range |
MSR860-6EI-XS |
30 to 10000 |
MSR860-6HI-XS |
30 to 10000 |
MSR2630-XS |
30 to 10000 |
MSR3600-28-XS |
30 to 10000 |
MSR3610-XS |
10 to 10000 |
MSR3620-XS |
10 to 10000 |
MSR3610-I-XS |
10 to 10000 |
MSR3610-IE-XS |
10 to 10000 |
MSR3620-X1-XS |
10 to 10000 |
MSR3640-XS |
10 to 10000 |
MSR3660-XS |
10 to 10000 |
Hardware |
Value range |
MSR810-LM-GL |
30 to 10000 |
MSR810-W-LM-GL |
30 to 10000 |
MSR830-6EI-GL |
30 to 10000 |
MSR830-10EI-GL |
30 to 10000 |
MSR830-6HI-GL |
30 to 10000 |
MSR830-10HI-GL |
30 to 10000 |
MSR1004S-5G-GL |
30 to 10000 |
MSR2600-6-X1-GL |
30 to 10000 |
MSR3600-28-SI-GL |
30 to 10000 |
# Set the minimum interval for transmitting SBFD control packets to 500 milliseconds.
bfd template
display sbfd session
Use display sbfd session to display SBFD session information.
display sbfd session { initiator | reflector } [ discriminator value | verbose ]
initiator: Displays SBFD session information for the initiator.
reflector: Displays SBFD session information for the reflector.
discriminator value: Specifies a local discriminator in the range of 1 to 4294967295.
verbose: Displays detailed information about all SBFD sessions.
If you do not specify the discriminator or verbose keyword, this command displays brief information about all SBFD sessions.
# Display brief information about all SBFD sessions for the initiator.
<Sysname> display sbfd session initiator
Total sessions: 1 Up sessions: 1
SBFD session (SRV6 PLY):
Local discr: 33794 Remote discr: 16777001
Source IP: 1::1
Destination IP: 4::4
Session state: Up
Hold time: 2235ms
Table 5 Command output
Total sessions |
Total number of SBFD sessions. |
Up sessions |
Number of active SBFD sessions. |
SBFD session (SRV6 PLY) |
SBFD sessions created for an SRv6-TE policy. |
Local discr |
Remote discr |
Source IP |
Destination IP |
Session state |
Session state: Down or Up. |
Hold time |
Length of time before the session detection timer expires, in milliseconds. For an SBFD session in Down state, this field displays 0ms. |
# Display detailed information about the SBFD session with local discriminator 33794 for the initiator.
<Sysname> display sbfd session initiator discriminator 33794
Source IP: 1::1 Destination IP: 4::4
Session state: Up Hold time: 2061ms
Color: 20 NID: 2149580802
Detection time: 2500ms Up duration: 00:15:36
Rx count: 2137 Tx count: 2142
Slot: 2
Protocol: SRV6PLY
Template name: 2
Table 6 Command output
Local discr |
Remote discr |
Source IP |
Destination IP |
Session state |
Hold time |
Color |
Color attribute of the SRv6-TE policy. |
NID |
NHLFE entry index for an SID list. |
Min Tx interval |
Minimum SBFD packet transmission interval in milliseconds. |
Actual SBFD packet transmission interval in milliseconds. |
Detection time |
Actual session detection timer in milliseconds. |
Up duration |
Rx count |
Tx count |
Slot |
(Standalone mode.) Slot number of the device. (IRF mode.) Slot number of the card where the BFD session resides. |
Diag info |
Diagnostic information about the session: · No Diagnostic. · Control Detection Time Expired—The SBFD session goes down because local detection times out. · Neighbor Signaled Session Down—The remote end notifies the local end of SBFD session down. |
Template name |
Template associated with the session. If no template is associated, this field is not displayed. |
# Display detailed information about all SBFD sessions for the initiator.
<Sysname> display sbfd session initiator verbose
Slot: 2
Protocol: SRV6PLY
Template name: 2
Table 7 Command output
Total sessions |
Up sessions |
Local discr |
Remote discr |
Source IP |
Destination IP |
Session state |
Hold time |
Color |
NID |
Min Tx interval |
Minimum SBFD packet transmission interval. |
Actual SBFD packet transmission interval. |
Detection time |
Up duration |
Rx count |
Tx count |
Slot |
Diag info |
Template name |
# Display brief information about all SBFD sessions for the reflector.
<Sysname> display sbfd session reflector
Local discriminator 1000001 on slot 0
Configured mode: Explicit Value
Total sessions: 1
Local discr: 1000001 Remote discr: 32770
Source IP: 3.2.1.2
Destination IP: 1.1.1.1
Hold time: 29296ms
VRF name: -
Table 8 Command output
Configured mode |
Discriminator type: · IP Address—IPv4 address. · Explicit Value—Integer. |
Total sessions |
Local discr |
Remote discr |
Source IP |
Destination IP |
Destination port |
Destination port number in BFD packets defined in Comware: · The destination port number in single-hop BFD control packets is 3784. · The destination port number in single-hop or multihop BFD echo packets is 3785. · The destination port number in multihop BFD control packets is 4784. · The destination port number in BFD control packets for association between link aggregation and BFD is 6784. For an indirect BFD session whose packets are forwarded through IP routes, upon receiving a packet, the local end uses its destination port number for sending packets if it is different from the local port number. |
Hold time |
VRF name |
VPN instance bound to the interface where the packets of the SBFD session are received. If no VPN instance is bound to the interface, this field displays a hyphen (-). |
# Display detailed information about the SBFD session with local discriminator 1000001 for the reflector.
<Sysname> display sbfd session reflector discriminator 1000001
Configured mode: IP Address
Total sessions: 1
Source IP: 3.2.1.2 Destination IP: 1.1.1.1
Min Tx interval: 1000ms Min Rx interval: 10ms
Detect multi: 5 Up duration: 00:16:51
Rx count: 967 Tx count: 967
Max Rx period: 3008ms Max Tx period: 1000us
Hold time: 29374ms
VRF name: -
Table 9 Command output
Configured mode |
Total sessions |
Local discr |
Remote discr |
Source IP |
Destination IP |
Min Tx interval |
Minimum transmission interval of incoming SBFD packets. |
Min Rx interval |
Minimum SBFD packet receiving interval. |
Detect multi |
Session detection time multiplier carried in incoming SBFD packets. |
Up duration |
Rx count |
Tx count |
Max Rx period |
Maximum SBFD packet receiving interval in milliseconds. |
Max Tx period |
Maximum response packet transmission interval, in microseconds. |
Hold time |
VRF name |
sbfd local-discriminator
Use sbfd local-discriminator to set the local discriminator for the reflector.
Use undo sbfd local-discriminator to remove the local discriminator setting for the reflector.
sbfd local-discriminator { ipv4-address | integer-value }
undo sbfd local-discriminator { ipv4-address | integer-value }
No local discriminator is set for the reflector.
ipv4-address: Specifies a valid unicast IPv4 address as the local discriminator.
integer-value: Specifies an integer as the local discriminator. The value range for this argument is 1000001 to 4294967295.
In a BFD session, both ends periodically send BFD packets to detect bidirectional forwarding path failures. SBFD is a unidirectional failure detection mechanism that provides shorter detection time than BFD. SBFD is used in scenarios where only one end of a link requires failure detection.
An SBFD session involves the following roles:
· Initiator—Periodically sends SBFD control packets to detect connectivity to remote entities. An initiator initiates SBFD sessions and maintains SBFD session state.
· Reflector—Listens for incoming SBFD control packets on local entities and replies with response SBFD control packets.
The remote discriminator in SBFD control packets sent by the initiator must be specified in the sbfd local-discriminator command. Otherwise, the reflector does not reply with response SBFD control packets.
You can execute this command multiple times to configure multiple local discriminators.
A node can act as the initiator of one session and the reflector of another session at the same time.
# Specify 1.1.1.1 as the local discriminator for the reflector.
[Sysname] sbfd local-discriminator 1.1.1.1
# Specify 1000001 as the local discriminator for the reflector.
[Sysname] sbfd local-discriminator 1000001
sbfd source-ipv6
Use sbfd source-ipv6 to specify the source IPv6 address used by the initiator to send SBFD control packets.
Use undo sbfd source-ipv6 to restore the default.
sbfd source-ipv6 ipv6-address
No source IPv6 address is specified for SBFD control packets.
ipv6-address: Specifies a unicast IPv6 address.
To use SBFD to detect the connectivity of forwarding paths in an SRv6-TE policy, you must execute this command on the initiator. In addition, a route to the specified IPv6 address must exist on the reflector.
# Specify 80::2 as the source IPv6 address for SBFD control packets.
[Sysname] sbfd source-ipv6 80::2
