- 10-MPLS Command References
- 01-Basic MPLS commands
- 02-Static LSP commands
- 03-LDP commands
- 04-MPLS TE commands
- 05-Static CRLSP commands
- 06-RSVP commands
- 07-Tunnel policy commands
- 08-MPLS L3VPN commands
- 09-MPLS L2VPN commands
- 10-VPLS commands
- 11-L2VPN access to L3VPN or IP backbone commands
- 12-MPLS OAM commands
- 13-MPLS protection switching commands
- 14-MCE commands
11-L2VPN access to L3VPN or IP backbone commands | 115.09 KB |
reset counters interface ve-l2vpn
reset counters interface ve-l3vpn
The following compatibility matrixes show the support of hardware platforms for L2VPN access to L3VPN or IP backbone:
Hardware |
Compatibility with L2VPN access to L3VPN or IP backbone |
MSR610 |
No |
Yes |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR1004S-5G, MSR1004S-5G-CN |
Yes |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth for an interface is 100000 kbps.
L2VE interface view
L2VE subinterface view
L3VE interface view
L3VE subinterface view
The expected bandwidth for an interface affects the CBQ bandwidth and the link costs in OSPF, OSPFv3, and IS-IS. For more information, see ACL and QoS Configuration Guide and Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth for VE-L2VPN 100 to 10000 kbps.
[Sysname] interface ve-l2vpn 100
[Sysname-VE-L2VPN100] bandwidth 10000
# Set the expected bandwidth for VE-L3VPN 100 to 10000 kbps.
[Sysname] interface ve-l3vpn 100
[Sysname-VE-L3VPN100] bandwidth 10000
default
Use default to restore the default settings for an interface.
default
L2VE interface view
L3VE interface view
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for VE-L2VPN 100.
[Sysname-VE-L2VPN100] default
This command will restore the default settings. Continue? [Y/N]:y
# Restore the default settings for VE-L3VPN 100.
[Sysname-VE-L3VPN100] default
description
The description of an interface is VE-L2VPNnumber Interface, for example, VE-L2VPN100 Interface.
L2VE interface view
L3VE interface view
Configure descriptions for different interfaces for identification and management purposes.
You can use the display interface command to display the configured interface description.
# Configure a description of L2VPN-Terminate for VE-L2VPN 100.
[Sysname-VE-L2VPN100] description L2VPN-Terminate
# Configure a description of L3VPN-Access for VE-L3VPN 100.
[Sysname-VE-L3VPN100] description L3VPN-Access
display interface ve-l2vpn
Use display interface ve-l2vpn to display L2VE interface information.
display interface [ ve-l2vpn [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
ve-l2vpn [ interface-number | interface-number.subnumber ]: Displays information about L2VE interfaces or L2VE subinterfaces. The interface-number argument represents the number of an existing L2VE interface. The subnumber argument represents the number of a subinterface created on the interface. If you do not specify the ve-l2vpn keyword, this command displays information about all interfaces on the device. If you specify the ve-l2vpn keyword but do not specify the interface-number or interface-number.subnumber argument, this command displays information about all L2VE interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in the physical state of DOWN and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display information about VE-L2VPN 100.
<Sysname> display interface ve-l2vpn 100
VE-L2VPN100
Current state: UP
Line protocol state: UP
Description: VE-L2VPN100 Interface
Bandwidth: 100000kbps
IP Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 0011-2200-0202
IPv6 Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 0011-2200-0202
Link service is PWE3 ethernet mode
Physical: L2VE, baudrate: 100000000 bps
VE-L2VPN100 |
Information about interface VE-L2VPN 100. |
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer. · UP—The data link layer protocol is up. · UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces. · DOWN—The data link layer protocol is down. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface, in kbps. |
Maximum transmission unit |
MTU of the interface. |
Internet protocol processing: Disabled |
The interface cannot process IP packets. |
Internet Address |
IP address of the interface. The primary attribute indicates that the address is the primary IP address. |
Link service |
Link service mode: · VPLS mode—This mode is available when the interface is bound with a VPLS instance. For more information about VPLS instances, see "Configuring VPLS." · PWE3 ethernet mode—This mode is available when the interface is associated with a PW whose encapsulation type is Ethernet. For more information about PWs, see "Configuring MPLS L2VPN." · PWE3 vlan mode—This mode is available when the interface is associated with a PW whose encapsulation type is VLAN. For more information about PWs, see "Configuring MPLS L2VPN." |
Physical: L2VE |
Physical type of the interface: L2VE interface for terminating an MPLS L2VPN. |
Last clearing of counters |
Last time the counters were cleared by using the reset counters interface command. If the reset counters interface command has never been executed since the device started up, this field displays Never. |
Last 300 seconds input rate |
Average input rate in the last 300 seconds. |
Last 300 seconds output rate |
Average output rate in the last 300 seconds. |
# Display brief information about all L2VE interfaces.
<Sysname> display interface ve-l2vpn brief
Protocol: (s) - spoofing
L2VE1 DOWN DOWN --
# Display brief information about VE-L2VPN 2, including the entire interface description.
<Sysname> display interface ve-l2vpn 2 brief description
L2VE1 DOWN DOWN --
# Display information about interfaces in the physical state of DOWN and the causes.
L2VE1 ADM Administratively
L2VE2 DOWN Not connected
Brief information on interfaces in route mode: |
Brief information about Layer 3 interfaces. |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been administratively shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Not connected—The tunnel is not established. |
display interface ve-l3vpn
Use display interface ve-l3vpn to display L3VE interface information.
display interface [ ve-l3vpn [ interface-number | interface-number.subnumber ] [ brief [ description | down ] ]
ve-l3vpn [ interface-number | interface-number.subnumber ]: Displays information about L3VE interfaces or L3VE subinterfaces. The interface-number argument represents the number of an existing L3VE interface. The subnumber argument represents the number of a subinterface created on the interface. If you do not specify the ve-l3vpn keyword, this command displays information about all interfaces on the device. If you specify the ve-l3vpn keyword but do not specify the interface-number or interface-number.subnumber argument, this command displays information about all L3VE interfaces.
# Display information about interface VE-L3VPN 100.
<Sysname> display interface ve-l3vpn 100
VE-L3VPN100
Current state: UP
Description: VE-L3VPN100 Interface
Internet address: 2.2.2.2/24 (primary)
Physical: L3VE, baudrate: 100000000 bps
VE-L3VPN100 |
Information about interface VE-L3VPN 100. |
Current state |
Bandwidth |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · BOOTP-allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3—IP Services Configuration Guide. · PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2—WAN Access Configuration Guide. · Unnumbered—IP address borrowed from another interface. · Cellular-allocated—IP address allocated through the modem-manufacturer's proprietary protocol. For more information, see 3G/4G modem management in Layer 2—WAN Access Configuration Guide. · MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide. · MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide. |
Internet protocol processing |
The interface is not assigned an IP address and cannot process IP packets. The primary attribute indicates that the address is the primary IP address. |
Link service |
Physical: L3VE |
Physical type of the interface: L3VE interface for accessing an MPLS L3VPN or IP backbone. |
Input: 0 packets, 0 bytes, 0 drops |
Total input packet statistics, including the number of input packets, input bytes, and dropped input packets. |
Output: 0 packets, 0 bytes, 0 drops |
Total output packet statistics, including the number of output packets, output bytes, and dropped output packets. |
# Display brief information about all L3VE interfaces.
<Sysname> display interface ve-l3vpn brief
L3VE1 DOWN DOWN --
# Display brief information about interface VE-L3VPN 2, including the entire interface description.
<Sysname> display interface ve-l3vpn 2 brief description
L3VE1 DOWN DOWN --
L3VE1 ADM Administratively
L3VE2 DOWN Not connected
Link |
Protocol |
Primary IP |
Cause |
interface ve-l2vpn
Use interface ve-l2vpn to create an L2VE interface or L2VE subinterface and enter its view, or enter the view of an existing L2VE interface or L2VE subinterface.
Use undo interface ve-l2vpn to delete an L2VE interface or L2VE subinterface.
interface ve-l2vpn { interface-number | interface-number.subnumber }
undo interface ve-l2vpn { interface-number | interface-number.subnumber }
No L2VE interfaces or L2VE subinterfaces exist.
interface-number: Specifies the L2VE interface number, in the range of 1 to 8192.
interface-number.subnumber: Specifies the L2VE subinterface number. The interface-number argument represents the main interface number, in the range of 1 to 8192. The subnumber argument represents the subinterface number, in the range of 1 to 4094.
A VE-L2VPN interface (an L2VE interface) or an L2VE subinterface terminates MPLS L2VPN packets. The L2VE interface performs the following operations:
· Removes the MPLS label from an MPLS L2VPN packet.
· Sends the original Layer 2 packet to an L3VE interface or L3VE subinterface that has the same interface number as the L2VE interface.
An L2VE subinterface sends original Layer 2 packets only to the L3VE interface that has the same interface number as the L2VE subinterface.
If an L2VE subinterface receives packets that carry VLAN tags, you must configure the L2VE subinterface to terminate the VLAN tags. For more information about VLAN termination, see Layer 2—LAN Switching Configuration Guide.
Deleting an L2VE interface also deletes all subinterfaces on the interface.
Before you create an L2VE subinterface, the main L2VE interface of the subinterface must already exist.
The VPLS access to L3VPN or IP backbone model does not support creating L2VE subinterfaces.
# Create L2VE interface VE-L2VPN 100, and enter L2VE interface view.
# Create L2VE subinterface VE-L2VPN 100.10, and enter L2VE subinterface view.
[Sysname] interface ve-l2vpn 100.10
[Sysname-VE-L2VPN100.10]
interface ve-l3vpn
Use interface ve-l3vpn to create an L3VE interface or L3VE subinterface and enter its view, or enter the view of an existing L3VE interface or L3VE subinterface.
Use undo interface ve-l3vpn to delete an L3VE interface or L3VE subinterface.
interface ve-l3vpn { interface-number | interface-number.subnumber }
undo interface ve-l3vpn { interface-number | interface-number.subnumber }
No L3VE interfaces or L3VE subinterfaces exist.
interface-number: Specifies the L3VE interface number, in the range of 1 to 8192.
interface-number.subnumber: Specifies the L3VE subinterface number. The interface-number argument represents the main interface number, in the range of 1 to 8192. The subnumber argument represents the subinterface number, in the range of 1 to 4094.
A VE-L3VPN interface (an L3VE interface) provides access to an MPLS L3VPN or IP backbone for packets. The L3VE interface forwards packets received from the backbone to an L2VE interface that has the same interface number as the L3VE interface.
If packets entering an MPLS L3VPN or IP backbone carry VLAN tags, you must create an L3VE subinterface on the L3VE interface to terminate the VLAN tags. For more information about VLAN termination, see Layer 2—LAN Switching Configuration Guide.
Deleting an L3VE interface also deletes all subinterfaces on the interface.
Before you create an L3VE subinterface, the main L3VE interface of the subinterface must already exist.
# Create L3VE interface VE-L3VPN 100, and enter L3VE interface view.
[Sysname-VE-L3VPN100] quit
# Create L3VE subinterface VE-L3VPN 100.10, and enter L3VE subinterface view.
[Sysname] interface ve-l3vpn 100.10
[Sysname-VE-L3VPN100.10]
mtu
Use mtu to set the MTU for an interface.
mtu size
undo mtu
The MTU on an interface is 1500 bytes.
L2VE interface view
L3VE interface view
mtu-size: Specifies the MTU in bytes, in the range of 46 to 1560.
# Set the MTU for VE-L2VPN 100 to 1430 bytes.
[Sysname-VE-L2VPN100] mtu 1430
# Set the MTU for VE-L3VPN 100 to 1430 bytes.
[Sysname-VE-L3VPN100] mtu 1430
Use reset counters interface ve-l2vpn to clear L2VE interface statistics.
reset counters interface [ ve-l2vpn [ interface-number | interface-number.subnumber ] ]
ve-l2vpn [ interface-number | interface-number.subnumber ]: Clears statistics for L2VE interfaces or L2VE subinterfaces. The interface-number argument represents the number of an existing L2VE interface. The subnumber argument represents the number of a subinterface created on the interface. If you do not specify the ve-l2vpn keyword, this command clears statistics for all interfaces on the device. If you specify the ve-l2vpn keyword but do not specify the interface-number or interface-number.subnumber argument, this command clears statistics for all L2VE interfaces.
Use this command to clear old statistics so you can observe new traffic statistics on an interface.
# Clear statistics for VE-L2VPN 100.
<Sysname> reset counters interface ve-l2vpn 100
Use reset counters interface ve-l3vpn to clear L3VE interface statistics.
reset counters interface [ ve-l3vpn [ interface-number | interface-number.subnumber ] ]
ve-l3vpn [ interface-number | interface-number.subnumber ]: Clears statistics for L3VE interfaces or L3VE subinterfaces. The interface-number argument represents the number of an existing L3VE interface. The subnumber argument represents the number of a subinterface created on the interface. If you do not specify the ve-l3vpn keyword, this command clears statistics for all interfaces on the device. If you specify the ve-l3vpn keyword but do not specify the interface-number or interface-number.subnumber argument, this command clears statistics for all L3VE interfaces.
# Clear statistics for interface VE-L3VPN 100.
<Sysname> reset counters interface ve-l3vpn 100
shutdown
Use shutdown to shut down an interface.
Use undo shutdown to bring up an interface.
shutdown
L2VE interfaces, L2VE subinterfaces, L3VE interfaces, and L3VE subinterfaces are up.
L2VE interface view
L3VE interface view
CAUTION: Executing this command on an interface will interrupt the link established on the interface. Please be cautious. |
# Shut down VE-L2VPN 100.
[Sysname-VE-L2VPN100] shutdown
# Shut down VE-L3VPN 100.
[Sysname-VE-L3VPN100] shutdown
