01--HH3C-OFP-MIB | 60.95 KB |
HH3C-OFP-MIB
About this MIB
OpenFlow is the communications interface defined between the control and forwarding layers of a Software-Defined Networking architecture. With OpenFlow, you can perform centralized data forwarding management for physical and virtual devices through controllers.
MIB file name
hh3c-ofp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cOfp(167)
Scalar objects
hh3cOfpTrapDisconnectReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cOfpTrapDisconnectReason (1.3.6.1.4.1.25506.2.167.2.1.1) |
accessible-for-notify |
Integer32 |
0..10 |
Reason why an OpenFlow instance was disconnected from a controller. |
As per the MIB. |
Tabular objects
hh3cOfpInstanceControllerTable
About this table
This table contains controller information for an OpenFlow instance.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cOfpInstanceID and hh3cOfpInstanceControllerID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
h3cOFPInstanceID (1.3.6.1.4.1.25506.2.167.1.1.1.1) |
not-accessible |
Integer32 |
1..4094 |
ID of an OpenFlow instance. |
As per the MIB. |
h3cOFPInstanceControllerID (1.3.6.1.4.1.25506.2.167.1.1.1.2) |
not-accessible |
Integer32 |
0..63 |
Index of an OpenFlow controller. |
As per the MIB. |
h3cOFPInstanceControllerRole (1.3.6.1.4.1.25506.2.167.1.1.1.3) |
read-only |
INTEGER |
equal(1), master(2), slave(3) |
Role of the OpenFlow controller. |
As per the MIB. |
hh3cOfpInstanceCtrConnectType (1.3.6.1.4.1.25506.2.167.1.1.1.4) |
read-only |
INTEGER |
tcp(1), ssl(2) |
Type of the connection between the OpenFlow instance and the controller. |
As per the MIB. |
hh3cOfpInstanceCtrConnectState (1.3.6.1.4.1.25506.2.167.1.1.1.5) |
read-only |
INTEGER |
idle(0), established(1) |
State of the connection between the OpenFlow instance and the controller. |
As per the MIB. |
hh3cOfpInstanceCtrSSLPolicy (1.3.6.1.4.1.25506.2.167.1.1.1.6) |
read-only |
DisplayString |
OCTET STRING (SIZE(0..31)) |
Name of the SSL client policy used for SSL connections. |
As per the MIB. |
hh3cOfpInstanceCtrVRFName (1.3.6.1.4.1.25506.2.167.1.1.1.7) |
read-only |
DisplayString |
Name of the VRF to which the controller belongs. |
As per the MIB. |
hh3cOfpInstanceCtrIPType (1.3.6.1.4.1.25506.2.167.1.1.1.8) |
read-only |
InetAddressType |
Standard MIB values. |
Type of the OpenFlow controller's IP address. |
As per the MIB. |
hh3cOfpInstanceCtrIPaddress (1.3.6.1.4.1.25506.2.167.1.1.1.9) |
read-only |
InetAddress |
OCTET STRING (SIZE (0..255)) |
IP address of the OpenFlow controller. |
As per the MIB. |
hh3cOfpInstanceCtrPort (1.3.6.1.4.1.25506.2.167.1.1.1.10) |
read-only |
Integer32 |
1..65535 |
Port number of the OpenFlow controller. |
As per the MIB. |
hh3cOfpInstanceFlowTableTable
About this table
This table contains flow table information for an OpenFlow instance.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cOfpFlowTableInstanceID and hh3cOfpInstanceTableID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cOfpFlowTableInstanceID (1.3.6.1.4.1.25506.2.167.1.2.1.1) |
not-accessible |
Integer32 |
1..4094 |
As per the MIB. |
hh3cOfpInstanceTableID (1.3.6.1.4.1.25506.2.167.1.2.1.2) |
not-accessible |
Integer32 |
0..254 |
ID of a flow table. |
As per the MIB. |
hh3cOfpInstanceFlowEntryNumCtrl (1.3.6.1.4.1.25506.2.167.1.2.1.3) |
read-only |
Unsigned32 |
Number of flow entries deployed by the controller. |
As per the MIB. |
hh3cOfpInstanceFlowEntryTotalNum (1.3.6.1.4.1.25506.2.167.1.2.1.4) |
read-only |
Unsigned32 |
Total number of flow entries in the table. |
As per the MIB. |
hh3cOfpInstanceFlowEntryLimit (1.3.6.1.4.1.25506.2.167.1.2.1.5) |
read-only |
Unsigned32 |
Maximum number of flow entries supported by the flow table. |
As per the MIB. |
Notifications
This section contains the HH3C-OFP-MIB notifications.
hh3cOfpControllerDisconnect
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.167.2.2.0.1 |
Disconnection of the connection between an OpenFlow instance and the controller. |
Error notification |
Major |
1.3.6.1.4.1.25506.2.167.2.2.0.2(hh3cOfpControllerConnect) |
ON |
This notification is generated when the connection between an OpenFlow instance and the controller is disconnected.
Status control
ON
CLI: Use the snmp-agent trap enable command.
OFF
CLI: Use the undo snmp-agent trap enable command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.167.1.1.1.1 (hh3cOfpInstanceID) |
ID of an OpenFlow instance |
Yes |
Integer32 |
1.3.6.1.4.1.25506.2.167.1.1.1.2 (hh3cOfpInstanceControllerID) |
ID of the OpenFlow controller |
Yes |
Integer32 |
1.3.6.1.4.1.25506.2.167.2.1.1 (hh3cOfpTrapDisconnectReason) |
Reason why the OpenFlow instance was disconnected from a controller. |
No |
Integer32 |
Recommended action
To resolve the issue:
1. Check whether OpenFlow connection backup is disabled. You can ignore this notification if the generation of this notification is triggered by an active/standby switchover.
2. Check the link between the device and the controller.
3. If the issue persists, contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.167.2.2.0.2 |
Establishment of connection between an OpenFlow instance and the controller. |
N/A |
N/A |
ON |
This notification is generated when the connection is established between an OpenFlow instance and the controller.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
Integer32 |
ID of the OpenFlow controller. |
Yes |
Integer32 |
Recommended action
No action is required.
