01-HH3C-VXLAN-MIB | 58.81 KB |
HH3C-VXLAN-MIB
About this MIB
Use this table to manage VXLAN configuration.
MIB file name
hh3c-vxlan.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cVxlan(150)
Tabular objects
hh3cVxlanScalarGroup
About this table
Use this table to configure global VXLAN settings.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
This table does not has an index.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVxlanLocalMacNotify (1.3.6.1.4.1.25506.2.150.1.1.1) |
read-write |
TruthValue |
true(1) false(2) |
Status of local-MAC logging. |
As per the MIB. |
hh3cVxlanRemoteMacLearn (1.3.6.1.4.1.25506.2.150.1.1.2) |
read-write |
TruthValue |
true(1) false(2) |
Status of remote MAC address learning. |
As per the MIB. |
hh3cVxlanNextVxlanID (1.3.6.1.4.1.25506.2.150.1.1.3) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
Next available VNI. |
As per the MIB. |
hh3cVxlanConfigured (1.3.6.1.4.1.25506.2.150.1.1.4) |
read-only |
Unsigned32 |
Total number of VXLANs configured on the device. |
As per the MIB. |
hh3cVxlanTable
About this table
Use this table to configure VXLANs.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cVxlanID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVxlanID (1.3.6.1.4.1.25506.2.150.1.2.1.1) |
not-accessible |
Unsigned32 |
VNI. |
As per the MIB. |
hh3cVxlanAddrType (1.3.6.1.4.1.25506.2.150.1.2.1.2) |
read-create |
InetAddressType· |
unknown(0) ipv4(1) ipv6(2) ipv4z(3) ipv6z(4) dns(16) |
Address type. |
Supports only ipv4(1). |
hh3cVxlanGroupAddr (1.3.6.1.4.1.25506.2.150.1.2.1.3) |
read-create |
InetAddress |
OCTET STRING (0..255) |
Destination address. |
As per the MIB. |
hh3cVxlanSourceAddr (1.3.6.1.4.1.25506.2.150.1.2.1.4) |
read-create |
InetAddress |
Source address. |
As per the MIB. |
hh3cVxlanVsiIndex (1.3.6.1.4.1.25506.2.150.1.2.1.5) |
read-create |
Unsigned32 |
VSI index. |
hh3cVxlanRemoteMacCount (1.3.6.1.4.1.25506.2.150.1.2.1.6) |
read-only |
Unsigned32 |
Remote MAC address count. |
As per the MIB. |
hh3cVxlanRowStatus (1.3.6.1.4.1.25506.2.150.1.2.1.7) |
read-create |
RowStatus |
active(1) notInService(2) notReady(3) createAndGo(4) createAndWait(5) destroy(6) |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). You can use active(1) to modify only the hh3cVxlanGroupAddr and hh3cVxlanSourceAddr objects. |
hh3cVxlanTunnelTable
About this table
Use this table to configure tunnels for VXLANs.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cVxlanID and hh3cVxlanTunnelID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVxlanTunnelID (1.3.6.1.4.1.25506.2.150.1.3.1.1) |
not-accessible |
Unsigned32 |
Tunnel ID. |
As per the MIB. |
hh3cVxlanTunnelRowStatus (1.3.6.1.4.1.25506.2.150.1.3.1.2) |
read-create |
RowStatus |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
hh3cVxlanTunnelOctets (1.3.6.1.4.1.25506.2.150.1.3.1.3) |
read-only |
Counter64 |
Counter64 (0..18446744073709551615) |
Byte count on the VXLAN tunnel. |
Not supported |
hh3cVxlanTunnelPackets (1.3.6.1.4.1.25506.2.150.1.3.1.4) |
read-only |
Counter64 |
Packet count on the VXLAN tunnel. |
Not supported |
hh3cVxlanTunnelInputOctets (1.3.6.1.4.1.25506.2.150.1.3.1.5) |
read-only |
Counter64 |
Incoming byte count on the VXLAN tunnel. |
Not supported |
hh3cVxlanTunnelOutputOctets (1.3.6.1.4.1.25506.2.150.1.3.1.6) |
read-only |
Counter64 |
Outgoing byte count on the VXLAN tunnel. |
Not supported |
hh3cVxlanTunnelInputPackets (1.3.6.1.4.1.25506.2.150.1.3.1.7) |
read-only |
Counter64 |
Incoming packet count on the VXLAN tunnel. |
Not supported |
hh3cVxlanTunnelOutputPackets (1.3.6.1.4.1.25506.2.150.1.3.1.8) |
read-only |
Counter64 |
Outgoing packet count on the VXLAN tunnel. |
Not supported |
hh3cVxlanTunnelInputDiscards (1.3.6.1.4.1.25506.2.150.1.3.1.9) |
read-only |
Counter64 |
Dropped incoming packet count on the VXLAN tunnel. |
Not supported |
hh3cVxlanTunnelOutputDiscards (1.3.6.1.4.1.25506.2.150.1.3.1.10) |
read-only |
Counter64 |
Dropped outgoing packet count on the VXLAN tunnel. |
Not supported |
hh3cVxlanTunnelBoundTable
About this table
Use this table to display the number of VXLANs bound to a VXLAN tunnel.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cVxlanTunnelID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVxlanTunnelBoundVxlanNum (1.3.6.1.4.1.25506.2.150.1.4.1.1) |
read-only |
Unsigned32 |
The number of VXLANs bound to a VXLAN tunnel. |
As per the MIB. |
hh3cVxlanMacTable
About this table
Use this table to display remote MAC address information about VXLANs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cVxlanVsiIndex and hh3cVxlanMacAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVxlanMacAddr (1.3.6.1.4.1.25506.2.150.1.5.1.1) |
not-accessible |
MacAddress |
OCTET STRING (6) |
MAC address. |
As per the MIB. |
hh3cVxlanTunnelID (1.3.6.1.4.1.25506.2.150.1.5.1.2) |
read-only |
Unsigned32 |
VXLAN tunnel ID. |
As per the MIB. |
hh3cVxlanMacType (1.3.6.1.4.1.25506.2.150.1.5.1.3) |
read-only |
unknown (0) selfLearned (1) staticConfigured (2) protocolLearned (3) openflow (4) ovsdb (5) |
MAC address type. |
As per the MIB. |
hh3cVxlanStaticMacTable
About this table
Use this table to display static remote MAC address information about VXLANs.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cVxlanVsiIndex and hh3cVxlanStaticMacAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVxlanStaticMacAddr (1.3.6.1.4.1.25506.2.150.1.6.1.1) |
not-accessible |
MacAddress |
OCTET STRING (6) |
MAC address. |
As per the MIB. |
hh3cVxlanStaticMacTunnelID (1.3.6.1.4.1.25506.2.150.1.6.1.2) |
read-create |
Unsigned32 |
VXLAN tunnel ID. |
Does not support modification after object creation. |
hh3cVxlanStaticMacRowStatus (1.3.6.1.4.1.25506.2.150.1.6.1.3) |
read-create |
RowStatus |
Row status. |
