02-HH3C-IPRAN-DCN-MIB | 76.71 KB |
HH3C-IPRAN-DCN-MIB (IPRAN)
About this MIB
This MIB describes how OSPF supports IPRAN DCN so that the gateway can manage and control remote devices, monitor running states of the devices, and obtain notifications when the devices come online or go offline.
MIB file name
hh3c-ipran-dcn.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpRanDcn(152)
Tabular objects
hh3cIpRanDcnInfoObject
About this table
This table contains network element information about the current device.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
hh3cIpRanDcnNeId (1.3.6.1.4.1.25506.2.152.1.1.1) |
read-only |
Hh3cIpRanNeId |
OCTET STRING (4) |
ID that uniquely identifies the local network element. |
hh3cIpRanDcnNeIpType (1.3.6.1.4.1.25506.2.152.1.1.2) |
read-only |
InetAddressType |
ipv4(1) |
IP address type of the local network element. |
hh3cIpRanDcnNeIp (1.3.6.1.4.1.25506.2.152.1.1.3) |
read-only |
InetAddress |
OCTET STRING (0..255) |
IP address of the local network element. |
hh3cIpRanDcnMask (1.3.6.1.4.1.25506.2.152.1.1.4) |
read-only |
InetAddress |
Subnet mask of the IP address of the local network element. |
hh3cIpRanDcnMAC (1.3.6.1.4.1.25506.2.152.1.1.5) |
read-only |
MacAddress |
OCTET STRING (6) |
Bridge MAC of the local network element. |
hh3cIpRanDcnVendor (1.3.6.1.4.1.25506.2.152.1.1.6) |
read-only |
DisplayString |
SIZE (0..255) |
Vendor of the local network element. |
hh3cIpRanDcnNeInfoTable
About this table
This table contains information about all network elements in the network.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
hh3cIpRanDcnNeInfoNeId (1.3.6.1.4.1.25506.2.152.1.1.2.1.1) |
read-only |
Hh3cIpRanNeId |
OCTET STRING (4) |
ID that uniquely identifies the network element. |
hh3cIpRanDcnNeInfoNeIpType (1.3.6.1.4.1.25506.2.152.1.1.2.1.2) |
read-only |
InetAddressType |
ipv4(1) |
IP address type of the network element. |
hh3cIpRanDcnNeInfoNeIp (1.3.6.1.4.1.25506.2.152.1.1.2.1.3) |
read-only |
InetAddress |
IP address of the network element. |
hh3cIpRanDcnNeInfoMetric (1.3.6.1.4.1.25506.2.152.1.1.2.1.4) |
read-only |
Integer32 |
Standard MIB values. |
Distance from the local network element to the remote node. |
hh3cIpRanDcnNeInfoDeviceType (1.3.6.1.4.1.25506.2.152.1.1.2.1.5) |
read-only |
DisplayString |
Device type of the network element. |
hh3cIpRanDcnNeInfoMAC (1.3.6.1.4.1.25506.2.152.1.1.2.1.6) |
read-only |
MacAddress |
OCTET STRING (6) |
Bridge MAC of the network element. |
hh3cIpRanDcnNeInfoVendor (1.3.6.1.4.1.25506.2.152.1.1.2.1.7) |
read-only |
DisplayString |
Vendor of the network element. |
hh3cIpRanDcnTrapObjects
About this table
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
hh3cIpRanDcnNeNumber (1.3.6.1.4.1.25506.2.152.1.2.1) |
read-only |
Integer32 |
Total number of online network elements. |
hh3cIpRanDcnNeChangeMode (1.3.6.1.4.1.25506.2.152.1.2.2) |
read-only |
INTEGER |
online (1), offline (2) |
Network element state in the most recent notification. |
hh3cIpRanDcnCompanyName (1.3.6.1.4.1.25506.2.152.1.2.3) |
read-only |
DisplayString |
Device vendor name. |
hh3cIpRanDcnDeviceType (1.3.6.1.4.1.25506.2.152.1.2.4) |
read-only |
DisplayString |
Device type. |
hh3cIpRanDcnDeviceMac (1.3.6.1.4.1.25506.2.152.1.2.5) |
read-only |
MacAddress |
OCTET STRING(6) |
Bridge MAC of the device. |
Notifications
hh3cIpRanDcnNeOnline
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.1 |
A network element comes online. |
Informational |
OFF |
A notification sent when a network element comes online.
Status control
ON
CLI: Use the auto-report command.
OFF
CLI: Use the undo auto-report command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.152.1.1.2.1.1 (hh3cIpRanDcnNeInfoNeId) |
Network element ID. |
No |
Hh3cIpRanNeId |
OCTET STRING (4) |
1.3.6.1.4.1.25506.2.152.1.1.2.1.2 (hh3cIpRanDcnNeInfoNeIpType) |
No |
InetAddressType |
ipv4(1) |
1.3.6.1.4.1.25506.2.152.1.1.2.1.3 (hh3cIpRanDcnNeInfoNeIp) |
No |
InetAddress |
1.3.6.1.4.1.25506.2.152.1.2.3 (hh3cIpRanDcnCompanyName) |
No |
DisplayString |
1.3.6.1.4.1.25506.2.152.1.2.4 (hh3cIpRanDcnDeviceType) |
Device type. |
No |
DisplayString |
1.3.6.1.4.1.25506.2.152.1.2.5 (hh3cIpRanDcnDeviceMac) |
No |
MacAddress |
OCTET STRING (6) |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cIpRanDcnNeOffline
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.2 |
A network element goes offline. |
Informational |
OFF |
A notification sent when a network element goes offline.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
No |
Hh3cIpRanNeId |
OCTET STRING (4) |
No |
InetAddressType |
ipv4(1) |
No |
InetAddress |
Recommended action
