01-HH3C-IF-EXT-MIB | 241.96 KB |
hh3cIfMonInputErrorAlarmRising
hh3cIfMonInputErrorAlarmResume
hh3cIfMonOutputErrorAlarmRising
HH3C-IF-EXT-MIB
About this MIB
Use this MIB to manage and describe interfaces.
MIB file name
hh3c-if-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIfExt(40)
Scalar objects
hh3cIfShutDownInterval
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfShutDownInterval (1.3.6.1.4.1.25506.2.40.1.2) |
read-write |
Integer32 |
Integer32(1..2147483647) |
Port status detection timer. |
0..300 |
Tabular objects
hh3cIfFlowStatTable
About this table
Use this table to obtain the interface traffic information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfStatFlowInterval.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfStatFlowInterval (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.1) |
read-write |
Integer32 |
Integer32(1..300) |
Traffic statistics polling interval. |
Implementation varies by product. |
hh3cIfStatFlowInBits (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.2) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
Incoming traffic in bits. |
As per the MIB. |
hh3cIfStatFlowOutBits (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.3) |
read-only |
Unsigned32 |
Outgoing traffic in bits. |
As per the MIB. |
hh3cIfStatFlowInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.4) |
read-only |
Unsigned32 |
Incoming traffic in packets. |
As per the MIB. |
hh3cIfStatFlowOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.5) |
read-only |
Unsigned32 |
Outgoing traffic in packets. |
As per the MIB. |
hh3cIfStatFlowInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.6) |
read-only |
Unsigned32 |
Incoming traffic in bytes. |
As per the MIB. |
hh3cIfStatFlowOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.7) |
read-only |
Unsigned32 |
Outgoing traffic in bytes. |
As per the MIB. |
hh3cIfSpeedStatTable
About this table
Use this table to obtain the interface traffic speed statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfSpeedStatInterval.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfSpeedStatInterval (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.1) |
read-write |
Integer32 |
Integer32(1..300) |
Interface traffic speed statistics polling interval. 0 indicates the interface traffic speed statistics collection feature is disabled. |
hh3cIfSpeedStatInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.2) |
read-only |
Unsigned32 |
Average incoming traffic speed (in pps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval. |
As per the MIB. |
hh3cIfSpeedStatOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.3) |
read-only |
Unsigned32 |
Average outgoing traffic speed (in pps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval. |
As per the MIB. |
hh3cIfSpeedStatInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.4) |
read-only |
Unsigned32 |
Average incoming traffic speed (in Bps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval. |
As per the MIB. |
hh3cIfSpeedStatOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.5) |
read-only |
Unsigned32 |
Average outgoing traffic speed (in Bps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval. |
As per the MIB. |
hh3cIfHCFlowStatTable
About this table
Use this table to obtain the 64-bit traffic information of interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfStatFlowHCInBits.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfStatFlowHCInBits (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.1) |
read-only |
CounterBasedGauge64 |
Counter64 (0..18446744073709551615) |
Incoming traffic in bits (64-bit version). |
As per the MIB. |
hh3cIfStatFlowHCOutBits (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.2) |
read-only |
Outgoing traffic in bits (64-bit version). |
As per the MIB. |
hh3cIfStatFlowHCInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.3) |
read-only |
Incoming traffic in packets (64-bit version). |
As per the MIB. |
hh3cIfStatFlowHCOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.4) |
read-only |
Outgoing traffic in packets (64-bit version). |
As per the MIB. |
hh3cIfStatFlowHCInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.5) |
read-only |
Incoming traffic in bytes (64-bit version). |
As per the MIB. |
hh3cIfStatFlowHCOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.6) |
read-only |
Outgoing traffic in bytes (64-bit version). |
As per the MIB. |
hh3cRTParentIfTable
About this table
Use this table to obtain main interface information of subinterfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cRTParentIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRTParentIfIndex (1.3.6.1.4.1.25506.2.40.2.2.1.1.1) |
not-accessible |
Integer32 |
Main interface index. Index of the interface for which you can create subinterfaces. |
As per the MIB. |
hh3cRTMinSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.1.1.2) |
read-only |
Integer32 |
Minimum number of the subinterface that can be created. |
As per the MIB. |
hh3cRTMaxSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.1.1.3) |
read-only |
Integer32 |
Maximum number of the subinterface that can be created. |
As per the MIB. |
hh3cRTSubIfTable
About this table
Use this table to obtain information about subinterface information of main interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cRTSubIfParentIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRTSubIfParentIfIndex (1.3.6.1.4.1.25506.2.40.2.2.2.1.1) |
not-accessible |
Integer32 |
Main interface index. |
As per the MIB. |
hh3cRTSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.2.1.2) |
not-accessible |
Integer32 |
Subinterface number. |
As per the MIB. |
hh3cRTSubIfSubIfIndex (1.3.6.1.4.1.25506.2.40.2.2.2.1.3) |
read-only |
Integer32 |
Subinterface index. |
As per the MIB. |
hh3cRTSubIfSubIfDesc (1.3.6.1.4.1.25506.2.40.2.2.2.1.4) |
read-only |
DisplayString |
OCTET STRING(0..255) |
Subinterface description. |
As per the MIB. |
hh3cRTSubIfRowStatus (1.3.6.1.4.1.25506.2.40.2.2.2.1.5) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Subinterface state. |
Available values are active(1), createAndGo(4), and destroy(6). |
hh3cIfLinkModeTable
About this table
Use this table to obtain the interface link mode.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfLinkModeIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfLinkModeIndex (1.3.6.1.4.1.25506.2.40.2.2.3.1.1) |
not-accessible |
Integer32 |
1..2147483647 |
Link mode index. |
As per the MIB. |
hh3cIfLinkMode (1.3.6.1.4.1.25506.2.40.2.2.3.1.2) |
read-write |
INTEGER |
bridgeMode(1), routeMode(2) |
Current link mode of the interface. |
As per the MIB. |
hh3cIfLinkModeSwitchSupport (1.3.6.1.4.1.25506.2.40.2.2.3.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Whether the link mode of the interface can be switched. |
As per the MIB. |
hh3cIfPortTypeTable
About this table
Use this table to obtain the port type of an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfPortTypeIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfPortTypeIndex (1.3.6.1.4.1.25506.2.40.2.2.4.1.1) |
not-accessible |
Integer32 |
Interface index, which is the same as ifIndex in ifTable. |
As per the MIB. |
hh3cIfPortType (1.3.6.1.4.1.25506.2.40.2.2.4.1.2) |
read-write |
INTEGER |
other(1),ethernet(2),fc(3)
Ethernet/ FC mode of an interface. |
As per the MIB. |
hh3cIfTable
About this table
Use this table to obtain interface-related information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfUpDownTimes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfUpDownTimes (1.3.6.1.4.1.25506.2.40.2.3.2.1.1) |
read-only |
Integer32 |
Number of interface up/down events. |
As per the MIB. |
hh3cIfMtu (1.3.6.1.4.1.25506.2.40.2.3.2.1.2) |
read-write |
Integer32 |
Interface MTU. |
As per the MIB. |
hh3cIfBandwidthRate (1.3.6.1.4.1.25506.2.40.2.3.2.1.3) |
accessible-for-notify |
Integer32 |
Interface bandwidth. |
Not supported |
hh3cIfDiscardPktRate (1.3.6.1.4.1.25506.2.40.2.3.2.1.4) |
Integer32 |
Packet loss rate of an interface. |
Not supported |
hh3cIfStatusKeepTime (1.3.6.1.4.1.25506.2.40.2.3.2.1.5) |
read-only |
TimeTicks |
TimeTicks (0..4294967295) |
Duration of the current interface state. |
As per the MIB. |
hh3cIfInNUcastPkts (1.3.6.1.4.1.25506.2.40.2.3.2.1.6) |
read-only |
Integer32 |
Number of incoming non-unicast packets. |
Not supported |
hh3cIfOutNUcastPkts (1.3.6.1.4.1.25506.2.40.2.3.2.1.7) |
read-only |
Integer32 |
Number of outgoing non-unicast packets. |
Not supported |
hh3cIfIsPoe (1.3.6.1.4.1.25506.2.40.2.3.2.1.8) |
read-only |
TruthValue |
true(1), false(2) |
Support for PoE on an interface. |
Not supported |
hh3cIfOperStatus (1.3.6.1.4.1.25506.2.40.2.3.2.1.9) |
read-only |
INTEGER |
up(1), down(2), testing(3), admindown(4) |
Operational state of an interface. |
Not supported |
hh3cIfDownTimes (1.3.6.1.4.1.25506.2.40.2.3.2.1.10) |
read-only |
Integer32 |
Number of link-down events. |
Not supported |
hh3cIfPfcStatus (1.3.6.1.4.1.25506.2.40.2.3.2.1.11) |
read-write |
INTEGER |
enable(1), disable(2), auto(3)
PFC mode of an interface. |
hh3cIfPfcDot1pNoDrop (1.3.6.1.4.1.25506.2.40.2.3.2.1.12) |
read-write |
BITS |
pri0(0), pri1(1), pri2(2), pri3(3), pri4(4), pri5(5), pri6(6), pri7(7) |
802.1p priority list for PFC on an interface. |
hh3cIfDescription (1.3.6.1.4.1.25506.2.40.2.3.2.1.13) |
read-write |
DisplayString |
Description of an interface. |
As per the MIB. |
hh3cIfFwdErrDiscards (1.3.6.1.4.1.25506.2.40.2.3.2.1.14) |
read-only |
Unsigned32 |
Number of packets dropped because of forwarding entry errors on an interface. |
As per the MIB. |
hh3cIfUsingTable
About this table
Use this table to obtain information about breakout interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfUsingIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfUsingIndex (1.3.6.1.4.1.25506.2.40.2.3.4.1) |
not-accessible |
Integer32 |
Index of an interface that can be split or combined. |
As per the MIB. |
hh3cIfUsingSupportType (1.3.6.1.4.1.25506.2.40.2.3.4.2) |
read-only |
Integer32 |
Interface type that an interface can be split or combined into. |
As per the MIB. |
hh3cIfUsingType (1.3.6.1.4.1.25506.2.40.2.3.4.3) |
read-write |
INTEGER |
noUsing(0), using10GE(1), using20GE(2), using40GE(3), using100GE(4), using25GE(5), using50GE(6) using200GE(7) using400GE(8) |
Interface type that an interface will be split or combined into. |
As per the MIB. |
hh3cIfUsingStatus (1.3.6.1.4.1.25506.2.40.2.3.4.4) |
read-only |
INTEGER |
noUsing(0), needReboot(1) |
State of the splitting or combining operation. |
As per the MIB. |
hh3cIfQueBufferTable
About this table
Use this table to obtain the interface buffer information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfQueId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQueId (1.3.6.1.4.1.25506.2.40.2.2.6.1.1) |
read-only |
INTEGER |
que0(1), que1(2), que2(3), que3(4), que4(5), que5(6), que6(7), que7(8) |
ID of an interface buffer queue. |
As per the MIB. |
hh3cIfQueOutUcastTotal (1.3.6.1.4.1.25506.2.40.2.2.6.1.2) |
read-only |
Unsigned32 |
Total buffer of an outbound unicast queue. |
As per the MIB. |
hh3cIfQueOutUcastFree (1.3.6.1.4.1.25506.2.40.2.2.6.1.3) |
read-only |
Unsigned32 |
Available buffer of an outbound unicast queue. |
As per the MIB. |
hh3cIfQueOutUcastUsedRatio (1.3.6.1.4.1.25506.2.40.2.2.6.1.4) |
read-only |
Unsigned32 |
Buffer usage of an outbound unicast queue. |
As per the MIB. |
hh3cIfQueOutUcastUsedPeak (1.3.6.1.4.1.25506.2.40.2.2.6.1.5) |
read-only |
Unsigned32 |
Peak buffer usage of an outbound unicast queue. |
As per the MIB. |
hh3cIfQueOutUcastThreshold (1.3.6.1.4.1.25506.2.40.2.2.6.1.6) |
read-only |
Unsigned32 |
Buffer alarm threshold of an outbound unicast queue. |
As per the MIB. |
hh3cIfQueOutUcastOverThres (1.3.6.1.4.1.25506.2.40.2.2.6.1.7) |
read-only |
Unsigned32 |
Number of buffer usage alarms of an outbound unicast queue. |
As per the MIB. |
hh3cIfQueInTotal (1.3.6.1.4.1.25506.2.40.2.2.6.1.8) |
read-only |
Unsigned32 |
Total buffer of an inbound unicast queue. |
As per the MIB. |
hh3cIfQueInFree (1.3.6.1.4.1.25506.2.40.2.2.6.1.9) |
read-only |
Unsigned32 |
Available buffer of an inbound unicast queue. |
As per the MIB. |
hh3cIfQueInUsedRatio (1.3.6.1.4.1.25506.2.40.2.2.6.1.10) |
read-only |
Unsigned32 |
Buffer usage of an inbound unicast queue. |
As per the MIB. |
hh3cIfQueInUsedPeak (1.3.6.1.4.1.25506.2.40.2.2.6.1.11) |
read-only |
Unsigned32 |
Peak buffer usage of an inbound unicast queue. |
As per the MIB. |
hh3cIfQueInThreshold (1.3.6.1.4.1.25506.2.40.2.2.6.1.12) |
read-only |
Unsigned32 |
Buffer alarm threshold of an inbound unicast queue. |
As per the MIB. |
hh3cIfQueInOverThres (1.3.6.1.4.1.25506.2.40.2.2.6.1.13) |
read-only |
Unsigned32 |
Number of buffer usage alarms of an inbound unicast queue. |
As per the MIB. |
hh3cIfQueInHeadRoomTotal (1.3.6.1.4.1.25506.2.40.2.2.6.1.14) |
read-only |
Unsigned32 |
Total headroom of an inbound queue. |
As per the MIB. |
hh3cIfQueInHeadRoomFree (1.3.6.1.4.1.25506.2.40.2.2.6.1.15) |
read-only |
Unsigned32 |
Available headroom of an inbound queue. |
As per the MIB. |
hh3cIfQueInHeadRoomUsedRatio (1.3.6.1.4.1.25506.2.40.2.2.6.1.16) |
read-only |
Unsigned32 |
Headroom usage of an inbound queue. |
As per the MIB. |
hh3cIfQueInHeadRoomUsedPeak (1.3.6.1.4.1.25506.2.40.2.2.6.1.17) |
read-only |
Unsigned32 |
Peak headroom usage of an inbound unicast queue. |
As per the MIB. |
hh3cIfHCSpeedStatTable
About this table
Use this table to obtain the 64-bit packet statistics of an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfSpeedStatHCInPkts.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfSpeedStatHCInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.1) |
read-only |
Average incoming traffic speed (in packets) of the interface within the specified interval before the latest sampling point. |
As per the MIB. |
hh3cIfSpeedStatHCOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.2) |
read-only |
Average outgoing traffic speed (in packets) of the interface within the specified interval before the latest sampling point. |
As per the MIB. |
hh3cIfSpeedStatHCInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.3) |
read-only |
Average incoming traffic speed (in bytes) of the interface within the specified interval before the latest sampling point. |
As per the MIB. |
hh3cIfSpeedStatHCOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.4) |
read-only |
Average outgoing traffic speed (in bytes) of the interface within the specified interval before the latest sampling point. |
As per the MIB. |
hh3cIfExtTrapCfgTable
About this table
Use this table to obtain information about the interface bandwidth and packet loss rate.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfBandwidthUpperLimit.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfBandwidthUpperLimit (1.3.6.1.4.1.25506.2.40.3.1.1.1.1) |
read-write |
Integer32 |
Upper limit of the interface bandwidth. |
Not supported |
hh3cIfDiscardPktRateUpperLimit (1.3.6.1.4.1.25506.2.40.3.1.1.1.2) |
read-write |
Integer32 |
Upper limit of the interface packet loss rate. |
Not supported |
Notifications
The following information describes the notifications included in the HH3C-IF-EXT-MIB module.
hh3cIfPortUp
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.5 |
Link-up alarm |
Informational |
ON |
The notification is generated when physical state of the interface changes to up.
Status control
ON
CLI: snmp-agent trap enable standard linkup
OFF
CLI: undo snmp-agent trap enable standard linkup
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Interface index. |
Yes |
Integer32 |
Standard MIB values. |
1.3.6.1.2.1.2.2.1.1 (ifDescr) |
Interface description. |
No |
OCTET STRING |
Unsigned32 (0..255) |
Recommended action
No action is required.
hh3cIfPortDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.6 |
Link-down alarm. |
Informational |
Warning |
ON |
The notification is generated when physical state of the interface changes to down.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
Recommended action
hh3cIfMonInputUsageRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.1 |
Inbound bandwidth usage rising alarm. |
Informational |
Warning |
ON |
The notification is generated when the inbound bandwidth usage exceeds the upper threshold.
Status control
ON
CLI: snmp-agent trap enable ifmonitor input-usage
OFF
CLI: undo snmp-agent trap enable ifmonitor input-usage
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.1(hh3cIfMonInputUsageLowThres) |
Lower threshold for the inbound bandwidth usage. |
No |
Unsigned32 |
0-100 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.2(hh3cIfMonInputUsageHighThres) |
Upper threshold for the inbound bandwidth usage. |
No |
Unsigned32 |
0-100 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.1(hh3cIfMonInputUsageStatistics) |
Inbound bandwidth usage statistics. |
No |
Counter64 |
Recommended action
To resolve the issue:
1. Verify that the upper threshold is set reasonably.
2. If the issue persists, contact H3C Support.
hh3cIfMonInputUsageResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.2 |
Inbound bandwidth usage recovery alarm |
Informational |
ON |
The notification is generated when the inbound bandwidth usage drops from above the upper threshold to below the lower threshold.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
No |
Unsigned32 |
0-100 |
No |
Unsigned32 |
0-100 |
No |
Counter64 |
Recommended action
hh3cIfMonOutputUsageRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.3 |
Outbound bandwidth usage rising alarm |
Informational |
Warning |
ON |
The notification is generated when the outbound bandwidth usage exceeds the upper threshold.
Status control
ON
CLI: snmp-agent trap enable ifmonitor output-usage
OFF
CLI: undo snmp-agent trap enable ifmonitor output-usage
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.3(hh3cIfMonOutputUsageLowThres) |
Lower threshold for the outbound bandwidth usage. |
No |
Unsigned32 |
0-100 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.4(hh3cIfMonOutputUsageHighThres) |
Upper threshold for the outbound bandwidth usage. |
No |
Unsigned32 |
0-100 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.2(hh3cIfMonOutputUsageStatistics) |
Outbound bandwidth usage statistics. |
No |
Counter64 |
Recommended action
hh3cIfMonOutputUsageResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.4 |
Outbound bandwidth usage recovery alarm |
Informational |
ON |
The notification is generated when the outbound bandwidth usage drops from above the upper threshold to below the lower threshold.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
No |
Unsigned32 |
1-4294967295 |
No |
Unsigned32 |
1-4294967295 |
No |
Counter64 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.5 |
Inbound error packet rising alarm |
Informational |
Warning |
ON |
The notification is generated when the number of inbound error packets exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor input-error
OFF
CLI: undo snmp-agent trap enable ifmonitor input-error
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.6(hh3cIfMonInputErrorAlarmHighThres) |
Upper threshold for the number of inbound error packets. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.5(hh3cIfMonInputErrorAlarmLowThres) |
Lower threshold for the number of inbound error packets. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.3(hh3cIfMonInputErrorAlarmStatistics) |
Inbound error alarm statistics. |
No |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.7(hh3cIfMonInputErrorAlarmInterval) |
Inbound error alarm statistics collection interval. |
No |
Unsigned32 |
0-65535 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.6 |
Inbound error packet recovery alarm |
Informational |
ON |
The notification is generated when the number of inbound error packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
CLI: undo snmp-agent trap enable ifmonitor input -error
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
No |
Unsigned32 |
1-4294967295 |
No |
Unsigned32 |
1-4294967295 |
No |
Counter64 |
1-4294967295 |
No |
Unsigned32 |
0-65535 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.7 |
Outbound error packet rising alarm |
Informational |
Warning |
ON |
The notification is generated when the number of outbound error packets exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor output-error
OFF
CLI: undo snmp-agent trap enable ifmonitor output-error
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.9(hh3cIfMonOutputErrorAlarmHighThres) |
Upper threshold for the number of outbound error packets. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.8(hh3cIfMonOutputErrorAlarmLowThres) |
Lower threshold for the number of outbound error packets. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.4(hh3cIfMonOutputErrorAlarmStatistics) |
Outbound error alarm statistics. |
No |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.10(hh3cIfMonOutputErrorAlarmInterval) |
Outbound error alarm statistics collection interval. |
No |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonOutputErrorAlarmResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.8 |
Outbound error packet recovery alarm |
Informational |
ON |
The notification is generated when the number of outbound error packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
No |
Unsigned32 |
1-4294967295 |
No |
Unsigned32 |
1-4294967295 |
No |
Counter64 |
1-4294967295 |
No |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonSdhErrorRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.9 |
SDH error packet rising alarm |
Informational |
ON |
The notification is generated when the number of SDH error packets exceeds the upper threshold within the specified interval.
Status control
ON
Syntax: snmp-agent trap enable ifmonitor sdh-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-error
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.11(hh3cIfMonSdhErrorLowThres) |
Lower threshold for the number of SDH error packets. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.12(hh3cIfMonSdhErrorHighThres) |
Upper threshold for the number of SDH error packets. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.5(hh3cIfMonSdhErrorStatistics) |
SDH error statistics. |
No |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.13(hh3cIfMonSdhErrorInterval) |
SDH error statistics collection interval. |
No |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonSdhErrorResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.10 |
SDH error packet recovery alarm |
Informational |
ON |
The notification is generated when the number of SDH error packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-error
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
No |
Unsigned32 |
1-4294967295 |
No |
Unsigned32 |
1-4294967295 |
No |
Counter64 |
1-4294967295 |
No |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonSdhB1ErrorRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.11 |
SDH B1 error packet rising alarm |
Informational |
ON |
The notification is generated when the number of SDH B1 error packets exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-b1-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-b1-error
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.14(hh3cIfMonSdhB1ErrorLowThres) |
Lower threshold for the number of SDH B1 error packets. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.15(hh3cIfMonSdhB1ErrorHighThres) |
Upper threshold for the number of SDH B1 error packets. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.6(hh3cIfMonSdhB1ErrorStatistics) |
SDH B1 error packet statistics. |
No |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.16(hh3cIfMonSdhB1ErrorInterval) |
SDH B1 error statistics collection interval. |
No |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonSdhB1ErrorResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.12 |
SDH B1 error packet recovery alarm |
Informational |
ON |
The notification is generated when the number of SDH B1 error packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
No |
Unsigned32 |
1-4294967295 |
No |
Unsigned32 |
1-4294967295 |
No |
Counter64 |
1-4294967295 |
No |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonSdhB2ErrorRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.13 |
SDH B2 error packet rising alarm |
Informational |
ON |
The notification is generated when the number of SDH B2 error packets exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-b2-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-b2-error
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.17(hh3cIfMonSdhB2ErrorLowThres) |
Lower threshold for the number of SDH B2 error packets. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.18(hh3cIfMonSdhB2ErrorHighThres) |
Upper threshold for the number of SDH B2 error packets. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.7(hh3cIfMonSdhB2ErrorStatistics) |
SDH B2 error packet statistics. |
No |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.19(hh3cIfMonSdhB2ErrorInterval) |
SDH B2 error statistics collection interval. |
No |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonSdhB2ErrorResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.14 |
Informational |
ON |
The notification is generated when the number of SDH B2 error packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
No |
Unsigned32 |
1-4294967295 |
No |
Unsigned32 |
1-4294967295 |
SDH B2 error statistics. |
No |
Counter64 |
1-4294967295 |
No |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonCRCErrorRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.15 |
CRC error packet rising alarm |
Informational |
Minor |
ON |
The notification is generated when the number of CRC error packets exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor crc-error
OFF
CLI: undo snmp-agent trap enable ifmonitor crc-error
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.21(hh3cIfMonCRCErrorHighThres) |
Upper threshold for the number of CRC error packets. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.20(hh3cIfMonCRCErrorLowThres) |
Lower threshold for the number of CRC error packets. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.8(hh3cIfMonCRCErrorStatistics) |
CRC error statistics. |
No |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.22(hh3cIfMonCRCErrorInterval) |
CRC error statistics collection interval. |
No |
Unsigned32 |
0-65535 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.23(hh3cIfMonCRCErrType) |
No |
INTEGER |
1-2 |
Recommended action
hh3cIfMonCRCErrorResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.16 |
CRC error packet recovery alarm |
Informational |
ON |
The notification is generated when the number of CRC error packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
No |
Unsigned32 |
1-4294967295 |
No |
Unsigned32 |
1-4294967295 |
No |
Counter64 |
1-4294967295 |
No |
Unsigned32 |
0-65535 |
No |
INTEGER |
1-2 |
Recommended action
hh3cIfMonRxPauseFrameRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.17 |
Received pause frame rising alarm |
Informational |
ON |
The notification is generated when the number of received pause frames exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor rx-pause
OFF
CLI: undo snmp-agent trap enable ifmonitor rx-pause
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.25(hh3cIfMonRxPauseFrameHighThres) |
Upper threshold for received pause frames. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.24(hh3cIfMonRxPauseFrameLowThres) |
Lower threshold for received pause frames. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.9(hh3cIfMonRxPauseFrameStatistics) |
Received pause frame statistics. |
No |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.26(hh3cIfMonRxPauseFrameInterval) |
Received pause frame statistics collection interval. |
No |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonRxPauseFrameResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.18 |
Received pause frame recovery alarm |
Informational |
ON |
The notification is generated when the number of received pause frames drops from above the upper threshold to below the lower-threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
No |
Unsigned32 |
1-4294967295 |
No |
Unsigned32 |
1-4294967295 |
No |
Counter64 |
1-4294967295 |
No |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonTxPauseFrameRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.19 |
Transmitted pause frame rising alarm |
Informational |
ON |
The notification is generated when the number of transmitted pause frames exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor tx-pause
OFF
CLI: undo snmp-agent trap enable ifmonitor tx-pause
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.28(hh3cIfMonTxPauseFrameHighThres) |
Upper threshold for transmitted pause frames. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.27(hh3cIfMonTxPauseFrameLowThres) |
Lower threshold for transmitted pause frames. |
No |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.10(hh3cIfMonTxPauseFrameStatistics) |
Transmitted pause frame statistics. |
No |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.29(hh3cIfMonTxPauseFrameInterval) |
Transmitted pause frame statistics collection interval. |
No |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonTxPauseFrameResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.20 |
Transmitted pause frame recovery alarm |
Informational |
ON |
The notification is generated when the number of transmitted pause frames drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
Integer32 |
No |
OCTET STRING |
No |
Unsigned32 |
1-4294967295 |
No |
Unsigned32 |
1-4294967295 |
No |
Counter64 |
1-4294967295 |
No |
Unsigned32 |
0-65535 |
Recommended action
1.
