01-HH3C-LICENSE-MIB | 116.65 KB |
HH3C-LICENSE-MIB
About this MIB
Use this MIB to manage the feature licenses on the device.
MIB file name
hh3c-license.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cLicense(145)
Scalar objects
hh3cLicenseNotifyEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLicenseNotifyEnable (1.3.6.1.4.1.25506.2.145.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Enables or disables all license module notifications. |
As per the MIB. |
hh3cLicenseOpEntryMaxNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLicenseOpEntryMaxNum (1.3.6.1.4.1.25506.2.145.1.2) |
read-write |
Unsigned32 |
Unsigned32 (1..20) |
Maximum number of entries can be recorded in hh3cLicenseOpTable. |
As per the MIB. |
hh3cLicenseNextFreeOpIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLicenseNextFreeOpIndex (1.3.6.1.4.1.25506.2.145.1.3) |
read-only |
Unsigned32 |
Standard MIB values. |
The hh3cLicenseOpIndex appropriate value used for creating an entry in hh3cLicenseOpTable. |
As per the MIB. |
hh3cLicenseBindValidityPeriodRemaining
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLicenseBindValidityPeriodRemaining (1.3.6.1.4.1.25506.2.145.3.1.1) |
accessible-for-notify |
Unsigned32 |
Remaining days before a license expires. |
As per the MIB. |
Tabular objects
hh3cLicenseDevInfoTable
About this table
This table displays the device SN and DID information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cLicensePhysicalIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLicensePhysicalIndex (1.3.6.1.4.1.25506.2.145.2.1.1.1) |
PhysicalIndex |
Index of hh3cLicenseDevInfoTable, depending on entPhysicalIndex in the ENTITY-MIB module. |
As per the MIB. |
hh3cLicenseSN (1.3.6.1.4.1.25506.2.145.2.1.1.2) |
read-only |
SnmpAdminString |
OCTET STRING(0..255) |
Device serial number. |
As per the MIB. |
hh3cLicenseDeviceIDType (1.3.6.1.4.1.25506.2.145.2.1.1.3) |
read-only |
INTEGER |
INTEGER{ invalid(1), keyString(2), file(3) } |
Type of device ID. |
As per the MIB. |
hh3cLicenseDeviceID (1.3.6.1.4.1.25506.2.145.2.1.1.4) |
read-only |
SnmpAdminString |
Device ID. |
As per the MIB. |
hh3cLicenseHardwareInfo (1.3.6.1.4.1.25506.2.145.2.1.1.5) |
read-only |
SnmpAdminString |
Device hardware information. |
As per the MIB. |
hh3cLicenseMaxNum (1.3.6.1.4.1.25506.2.145.2.1.1.6) |
read-only |
Unsigned32 |
Maximum number of licenses that can be installed on the device. |
As per the MIB. |
hh3cLicenseUsedNum (1.3.6.1.4.1.25506.2.145.2.1.1.7) |
read-only |
Unsigned32 |
Number of installed licenses. |
As per the MIB. |
hh3cLicenseRecyclableNum (1.3.6.1.4.1.25506.2.145.2.1.1.8) |
read-only |
Unsigned32 |
Number of recyclable storage for licenses. |
As per the MIB. |
hh3cLicenseInstallType (1.3.6.1.4.1.25506.2.145.2.1.1.9) |
read-only |
INTEGER |
invalid(1), installInChassis(2), installInSlot(3), installInCPU(4) |
Type of license installation. |
As per the MIB. |
hh3cLicenseFileStoragePath (1.3.6.1.4.1.25506.2.145.2.1.1.10) |
read-only |
SnmpAdminString |
Storage path of license files. |
As per the MIB. |
hh3cLicenseGeneralTable
About this table
This table displays the general license information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cLicenseIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLicenseIndex (1.3.6.1.4.1.25506.2.145.2.2.1.1) |
Unsigned32 |
License ID. |
As per the MIB. |
hh3cLicenseFeature (1.3.6.1.4.1.25506.2.145.2.2.1.2) |
read-only |
SnmpAdminString |
OCTET STRING(0..1024) |
Name of a licensed feature. |
As per the MIB. |
hh3cLicenseProductDescr (1.3.6.1.4.1.25506.2.145.2.2.1.3) |
read-only |
OCTET STRING |
Product description in the license. |
As per the MIB. |
hh3cLicenseFileDescr (1.3.6.1.4.1.25506.2.145.2.2.1.4) |
read-only |
SnmpAdminString |
Description of a license file. |
As per the MIB. |
hh3cLicenseState (1.3.6.1.4.1.25506.2.145.2.2.1.5) |
read-only |
INTEGER |
invalid(1), inuse(2), usable(3), expired(4), uninstalled (5), unusable(6) |
State of an installed license. |
As per the MIB. |
hh3cLicenseActivationFile (1.3.6.1.4.1.25506.2.145.2.2.1.6) |
read-only |
SnmpAdminString |
Name of an installed activation file. |
As per the MIB. |
hh3cLicenseActivationKey (1.3.6.1.4.1.25506.2.145.2.2.1.7) |
read-only |
SnmpAdminString |
Installed activation key. |
As per the MIB. |
hh3cLicenseLicenseKey (1.3.6.1.4.1.25506.2.145.2.2.1.8) |
read-only |
SnmpAdminString |
Installed license key. |
As per the MIB. |
hh3cLicenseUninstActivationFile (1.3.6.1.4.1.25506.2.145.2.2.1.9) |
read-only |
SnmpAdminString |
Uninstall file. |
As per the MIB. |
hh3cLicenseUninstActivationKey (1.3.6.1.4.1.25506.2.145.2.2.1.10) |
read-only |
SnmpAdminString |
Uninstall key. |
As per the MIB. |
hh3cLicenseType (1.3.6.1.4.1.25506.2.145.2.2.1.11) |
read-only |
INTEGER |
unknown(1), permanent(2), daysRestricted(3), trialDaysRestricted(4), dateRestricted(5), trialDateRestricted(6), countRestricted(7), trialCountRestricted(8) |
License type by validity period. |
As per the MIB. |
hh3cLicenseInstalledTime (1.3.6.1.4.1.25506.2.145.2.2.1.12) |
read-only |
DateAndTime |
Time when a license was installed. |
As per the MIB. |
hh3cLicenseUninstalledTime (1.3.6.1.4.1.25506.2.145.2.2.1.13) |
read-only |
DateAndTime |
Time when a license was uninstalled. |
As per the MIB. |
hh3cLicenseDaysLeft (1.3.6.1.4.1.25506.2.145.2.2.1.14) |
read-only |
Unsigned32 |
Remaining days of a license. |
As per the MIB. |
hh3cLicenseValidityStart (1.3.6.1.4.1.25506.2.145.2.2.1.15) |
read-only |
DateAndTime |
Start date for a date-restricted license. |
As per the MIB. |
hh3cLicenseValidityEnd (1.3.6.1.4.1.25506.2.145.2.2.1.16) |
read-only |
DateAndTime |
End date for a date-restricted license. |
As per the MIB. |
hh3cLicenseExpiredDays (1.3.6.1.4.1.25506.2.145.2.2.1.17) |
read-only |
Unsigned32 |
Expiration date for a date-restricted license. |
As per the MIB. |
hh3cLicenseCount (1.3.6.1.4.1.25506.2.145.2.2.1.18) |
read-only |
Unsigned32 |
Effective number of a quantity-based license. |
As per the MIB. |
hh3cLicenseFeatureTable
About this table
This table displays summary information about feature licenses.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cLicensePhysicalIndex and IMPLIED hh3cLicenseFeatureName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLicenseFeatureName (1.3.6.1.4.1.25506.2.145.2.3.1.1) |
read-only |
SnmpAdminString |
OCTET STRING(1..31) |
As per the MIB. |
hh3cLicenseFeatureState (1.3.6.1.4.1.25506.2.145.2.3.1.2) |
read-only |
INTEGER |
notLicensed(1), trialLicense(2), formalLicense(3), serverLicense(4), preLicense(5) |
Licensing state of the feature. |
As per the MIB. |
hh3cLicenseOpTable
About this table
This table is used to install or uninstall licenses.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cLicenseOpIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLicenseOpIndex (1.3.6.1.4.1.25506.2.145.2.4.1.1) |
Unsigned32 |
Operation ID. |
As per the MIB. |
hh3cLicenseOpPhysicalIndex (1.3.6.1.4.1.25506.2.145.2.4.1.2) |
read-create |
PhysicalIndexOrZero |
Integer32 |
Entity index of an MPU or CPU for an operation, depending on entPhysicalIndex in the ENTITY-MIB module. |
As per the MIB. |
hh3cLicenseOpType (1.3.6.1.4.1.25506.2.145.2.4.1.3) |
read-create |
INTEGER |
compress(1), delete(2), installActivationFile(3), installActivationKey(4), installLicenseKey(5), uninstallActivationFile(6), uninstallActivationKey(7), uninstallLicenseKey(8) |
Operation type. |
As per the MIB. |
hh3cLicenseOpString (1.3.6.1.4.1.25506.2.145.2.4.1.4) |
read-create |
SnmpAdminString |
OCTET STRING (0..255) |
License key, activation key, or activation file that was installed or uninstalled. |
As per the MIB. |
hh3cLicenseOpNotifyEnable (1.3.6.1.4.1.25506.2.145.2.4.1.5) |
read-create |
TruthValue |
true(1), false(2) |
Enables or disables hh3cLicenseOpCompletion. |
As per the MIB. |
hh3cLicenseOpRowStatus (1.3.6.1.4.1.25506.2.145.2.4.1.6) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
hh3cLicenseOpState (1.3.6.1.4.1.25506.2.145.2.4.1.7) |
read-only |
INTEGER |
opInProgress(1), opSuccessful(2), opFailed(3) |
Operation status. |
As per the MIB. |
hh3cLicenseOpFailedReason (1.3.6.1.4.1.25506.2.145.2.4.1.8) |
read-only |
SnmpAdminString |
Detailed cause of an operation failure. |
As per the MIB. |
hh3cLicenseOpEndTime (1.3.6.1.4.1.25506.2.145.2.4.1.9) |
read-only |
TimeTicks |
OCTET STRING |
System time when an operation was executed. |
As per the MIB. |
Notifications
The following information describes the notifications included in the HH3C-LICENSE-MIB module.
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.145.3.0.1 |
Notification of license operation completion. |
Informational |
ON |
This notification is generated when a license operation was completed according to the requirements of the network management system (NMS).
The parameters in the notification are related to the executed operation. As a best practice, see NMS online help system for parameter descriptions.
Status control
ON
MIB: Set hh3cLicenseOpNotifyEnable to true(1)
OFF
MIB: Set hh3cLicenseOpNotifyEnable to false(2)
Objects
OID (object) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.145.2.4.1.1 (hh3cLicenseOpIndex) |
Operation ID. |
Yes |
Unsigned32 |
1.3.6.1.4.1.25506.2.145.2.4.1.2 (hh3cLicenseOpPhysicalIndex) |
No |
Integer32 (0..2147483647) |
1.3.6.1.4.1.25506.2.145.2.4.1.3 (hh3cLicenseOpType) |
Operation type. |
No |
INTEGER |
compress(1) delete(2) installActivationFile(3) installActivationKey(4) installLicenseKey(5) uninstallActivationFile(6) uninstallActivationKey(7) uninstallLicenseKey(8) |
1.3.6.1.4.1.25506.2.145.2.4.1.4 (hh3cLicenseOpString) |
No |
SnmpAdminString |
OCTET STRING (SIZE (0..255)) |
1.3.6.1.4.1.25506.2.145.2.4.1.7 (hh3cLicenseOpState) |
Operation status. |
No |
INTEGER |
opInProgress(1) opSuccessful(2) opFailed(3) |
1.3.6.1.4.1.25506.2.145.2.4.1.8 (hh3cLicenseOpFailedReason) |
No |
SnmpAdminString |
Recommended action
To resolve the issue:
1. Verify the license operation result.
2. If the issue persists, contact H3C Support.
hh3cLicenseActivationFileLost
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.145.3.0.2 |
Notification of activation file loss. |
Fault Alarms |
Major |
1.3.6.1.4.1.25506.2.145.3.0.3(hh3cLicenseActivationFileRestored) |
ON |
This notification is generated when an activation file was lost or damaged and will be issued continuously until the fault is solved.
Status control
ON
OFF
Objects
OID (object) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.145.2.1.1.1 (hh3cLicensePhysicalIndex) |
Yes |
PhysicalIndex |
Integer32 (1..2147483647) |
1.3.6.1.4.1.25506.2.145.2.2.1.6 (hh3cLicenseActivationFile) |
No |
SnmpAdminString |
Recommended action
1. Copy the backup activation file to the flash:/license directory to recover the license. If the backup activation file is lost or no activation file is backed up, contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.145.3.0.3 |
Notification of successful activation file recovery. |
Notification of recovery. |
ON |
This notification is generated when an activation file was recovered successfully.
Status control
ON
OFF
Objects
OID (object) |
Index |
Type |
Value range |
Yes |
PhysicalIndex |
No |
SnmpAdminString |
Recommended action
No action is required.
hh3cLicenseExpired
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.145.3.0.4 |
Notification of license expiration. |
Informational |
Major |
ON |
This notification is generated when a license expired.
Status control
ON
OFF
Objects
OID (object) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.145.2.3.1.1 (hh3cLicenseFeatureName) |
No |
SnmpAdminString |
OCTET STRING (SIZE (1..31)) |
1.3.6.1.4.1.25506.2.145.2.3.1.2 (hh3cLicenseFeatureState) |
No |
INTEGER |
notLicensed(1) trialLicense(2) formalLicense(3) |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
1. Install a new license. If you need to purchase a new license, contact H3C Support.
hh3cLicenseExpireWarning
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.145.3.0.5 |
A license is about to expire. |
Informational |
Warning |
ON |
This notification is generated when a license is about to expire. The notification will be issued continuously until the notification condition is cleared.
Status control
ON
OFF
Objects
OID (object) |
Index |
Type |
Value range |
No |
SnmpAdminString |
No |
INTEGER |
1.3.6.1.4.1.25506.2.145.3.1.1 (hh3cLicenseBindValidityPeriodRemaining) |
Remaining days before the license expires. |
No |
Unsigned32 |
Recommended action
1. Install a new license before the license expires. If you need to purchase a new license, contact H3C Support.
