01-OpenFlow configuration | 316.21 KB |
Configuring OpenFlow instances
Configuring the OpenFlow instance mode
Enabling the TTP mode for an OpenFlow instance
Configuring inband management VLANs
Configuring flow tables and flow entries for an OpenFlow instance
Setting the controller connection mode
Preventing an OpenFlow instance from reporting the specified types of ports to controllers
Enabling the OpenFlow data plane forwarding feature
Activating or reactivating an OpenFlow instance
Configuring OpenFlow instance attributes
Configuring controllers for an OpenFlow switch
Configuring an OpenFlow instance to act as an SSL server to listen to controllers
Refreshing all Layer 3 flow entries in the MAC-IP flow tables for an OpenFlow instance
Enabling packet loss prevention for OpenFlow forwarding
Ignoring the permit flag added by OpenFlow
Reserving ACL resources for extensibility flow tables
Shutting down an interface by OpenFlow
Enabling SNMP notifications for OpenFlow
Display and maintenance commands for OpenFlow
OpenFlow configuration examples
Example: Configuring OpenFlow in VLAN mode
Restrictions for merging the action list into the action set
Packet-out messages restrictions
Packet-in messages restrictions
Flow table modification messages restrictions
Capabilities supported by the MAC-IP flow table
MAC-IP flow table restrictions
Table-miss flow entry of MAC-IP flow tables
MAC-IP flow table cooperating with extensibility flow table
Capabilities supported by the VLAN tagging flow table
Capabilities supported by the VLAN untagging flow table
Capabilities supported by ingress MPLS flow entries
Capabilities supported by transit MPLS flow entries
Capabilities supported by egress MPLS flow entries
Multi-level table-based TTP pipeline
Table-miss flow entry of TTP flow tables
Capabilities supported by the TTP-ingress-port flow table
Capabilities supported by the TTP-VLAN flow table
Capabilities supported by the TTP-termination-MAC flow table
Capabilities supported by the TTP-unicast-routing flow table
Capabilities supported by the TTP-bridging flow table
Capabilities supported by the TTP-ingress-ACL flow table
Capabilities supported by the TTP-egress-ACL flow table
Capabilities supported by the TTP-L2-interface-group flow table
Capabilities supported by the TTP-L3-unicast-group flow table
Capabilities supported by the TTP-L3-ECMP-group table
About OpenFlow
OpenFlow is the communications interface defined between the control and forwarding layers of a Software-Defined Networking architecture. With OpenFlow, you can perform centralized data forwarding management for physical and virtual devices through controllers.
OpenFlow network components
OpenFlow separates the data forwarding and routing decision functions. It keeps the flow-based forwarding function and employs a separate controller to make routing decisions. An OpenFlow switch communicates with the controller through an OpenFlow channel. An OpenFlow channel can be encrypted by using TLS or run directly over TCP. An OpenFlow switch exchanges control messages with the controller through an OpenFlow channel to perform the following operations:
· Receive flow table entries or data from the controller.
· Report information to the controller.
Unless otherwise stated, a switch refers to an OpenFlow switch throughout this document.
Figure 1 OpenFlow network diagram
OpenFlow switch
OpenFlow switches include the following types:
· OpenFlow-only—Supports only OpenFlow operation.
· OpenFlow-hybrid—Supports both OpenFlow operation and traditional Ethernet switching operation.
OpenFlow port
OpenFlow supports the following types of ports:
· Physical port—Corresponds to a hardware interface, such as an Ethernet interface. A physical port can be either an ingress port or an output port.
· Logical port—Does not correspond to a hardware interface and might be defined by non-OpenFlow methods. For example, aggregate interfaces are logical ports. A logical port can be either an ingress port or an output port.
· Reserved port—Defined by OpenFlow to specify forwarding actions. Reserved ports include the following types:
¡ All—All ports that can be used to forward a packet.
¡ Controller—OpenFlow controller.
¡ Local—Local CPU.
¡ Normal—Normal forwarding process.
¡ Flood—Flooding.
Only the Controller and Local types can be used as ingress ports.
OpenFlow instance
Unless otherwise stated, an OpenFlow switch refers to an OpenFlow instance throughout this document.
You can configure one or more OpenFlow instances on the same device. A controller considers each OpenFlow instance as a separate OpenFlow switch and deploys forwarding instructions to it.
An OpenFlow instance operates in one of the following modes:
· Global mode—When the global mode is enabled for an OpenFlow instance, the flow entries take effect on packets within the network. All service interfaces on the device belong to the OpenFlow instance.
· VLAN mode—When the VLAN mode is enabled for an OpenFlow instance, the flow entries take effect only on packets within VLANs associated with the OpenFlow instance. You must associate the OpenFlow instance with VLANs. All interfaces in the associated VLANs belong to the OpenFlow instance.
Activation and reactivation
The configurations for an OpenFlow instance take effect only after the OpenFlow instance is activated.
The controller can deploy flow entries to an OpenFlow instance only after the OpenFlow instance reports the following device information to the controller:
· Capabilities supported by OpenFlow.
· Information about ports that belong to the OpenFlow instance.
An activated OpenFlow instance must be reactivated when any of the OpenFlow instance configurations are changed.
After reactivation, the OpenFlow instance is disconnected from all controllers and then reconnected to them.
OpenFlow instance port
An OpenFlow switch sends information about the following ports to the controller:
· Physical ports.
· Logical ports.
· Reserved ports of the Local type.
In loosen mode, a port belongs to the OpenFlow instance when VLANs associated with the OpenFlow instance overlap with the port's allowed VLANs. Otherwise, a port belongs to an OpenFlow instance only when VLANs associated with the OpenFlow instance are within the port's allowed VLAN list.
OpenFlow flow table
An OpenFlow switch matches packets with one or more flow tables. A flow table contains flow entries, and packets are matched based on the matching precedence of flow entries.
Flow table types
OpenFlow flow tables include the following types:
· MAC-IP—Combines the MAC address table and FIB table.
A MAC-IP flow table provides the following match fields:
¡ Destination MAC address.
¡ VLAN.
¡ Destination IP address.
A MAC-IP flow table provides the following actions:
¡ Modifying the destination MAC address.
¡ Modifying the source MAC address.
¡ Modifying the VLAN.
¡ Specifying the output port.
For more information, see "Appendix B MAC-IP flow table."
· Extensibility—Uses ACLs to match packets.
· VLAN tagging—Tags all incoming packets matching the table.
· VLAN untagging—Untags all outgoing packets matching the table.
· MPLS—Uses static LSPs.
An MPLS flow table provides the following match fields:
¡ Ethernet type.
¡ MPLS label.
An MPLS flow table provides the following actions:
¡ Modifying the MPLS label.
¡ Adding an MPLS label.
¡ Popping the top MPLS label.
¡ Specifying the next hop of the route.
For more information, see "Appendix D MPLS flow table."
· Table Type Pattern (TTP)—TTP is a generic multi-level flow table pattern defined by OpenFlow, which simplifies the OpenFlow pipeline processing. TTP flow entries are typically used on VXLAN data center networks. The TTP mode allows an OpenFlow switch to interoperate with third-party TTP-based controllers.
TTP flow tables include multiple types of flow entries. For more information about TTP flow entries, see "Appendix E TTP flow table."
Flow entry
A flow entry contains the following fields:
· Match fields—Matching rules of the flow entry. These contain the ingress port, packet headers, and metadata specified by the previous table.
· Priority—Matching precedence of the flow entry. When a packet is matched with the flow table, only the highest priority flow entry that matches the packet is selected.
· Counters—Counts of the packets and bytes that match the flow entry.
· Instructions—Used to modify the action set or pipeline processing. Instructions include the following types:
¡ Meter—Directs the packets to the specified meter to rate limit the packets.
¡ Apply-Actions—Applies the specified actions in the action list immediately.
¡ Clear-Actions—Clears all actions in the action set immediately.
¡ Write-Actions—Modifies all actions in the action set immediately.
¡ Goto-Table—Indicates the next flow table in the processing pipeline.
Actions are executed in one of the following ways:
¡ Action Set—When the instruction set of a flow entry does not contain a Goto-Table instruction, pipeline processing stops. Then, the actions in the action set are executed in the order specified by the instruction list. An action set contains a maximum of one action of each type.
¡ Action List—The actions in the action list are executed immediately in the order specified by the action list. The effect of those actions is cumulative.
Actions include the following types:
¡ (Required.) Output—The Output action forwards a packet to the specified OpenFlow port. OpenFlow switches must support forwarding packets to physical ports, logical ports, and reserved ports.
¡ (Required.) Drop—No explicit action exists to represent drops. Packets whose action sets have no output actions are dropped. Typically, packets are dropped due to empty instruction sets, empty action sets, or the executing a Clear-Actions instruction.
¡ (Required.) Group—Process the packet through the specified group. The exact interpretation depends on group type.
¡ (Optional.) Set-Queue—The Set-Queue action sets the queue ID for a packet. When the packet is forwarded to a port by the output action, the packet is assigned to the queue attached to this port for scheduling and forwarding. The forwarding behavior is dictated by the configuration of the queue and provides basic QoS support.
¡ (Optional.) Set-Field—The Set-Field actions are identified by their field type and modify the values of corresponding header fields in the packet. Set-Field actions are always applied to the outermost header. For example, a Set VLAN ID action always sets the ID of the outermost VLAN tag.
· Timeouts—Maximum amount of idle time or hard time for the flow entry.
¡ idle time—The flow entry is removed if it has matched no packets within the idle time.
¡ hard time—The flow entry is removed when the hard time timeout is exceeded, regardless of whether or not it has matched packets.
· Cookie—Custom data specified by the controller. The data is not used for processing packets, and might be used by the controller for matching flow entries.
· Flags—Flag for modifying the flow entry management method. For example, the OFPFF_SEND_FLOW_REM flag triggers the switch to send Flow-Removed messages for the flow entry to the controller.
Figure 2 Flow entry components
OpenFlow pipeline
The OpenFlow pipeline processing defines how packets interact with flow tables contained by a switch.
The flow tables of an OpenFlow switch are sequentially numbered, starting at 0. The packet is first matched with flow entries of the first flow table, which is flow table 0. A flow entry can only direct a packet to a flow table number that is greater than its own flow table number.
When a packet matches a flow entry, the OpenFlow switch updates the action set for the packet and passes the packet to the next flow table. In the last flow table, the OpenFlow switch executes all actions to modify packet contents and specify the output port for packet forwarding. If the instruction set of a flow table contains an action list, the OpenFlow switch immediately executes the actions for a copy of the packet in this table.
Figure 3 OpenFlow forwarding workflow
Every flow table must support a table-miss flow entry to process table misses. The table-miss flow entry specifies how to process packets that were not matched by other flow entries in the flow table.
The table-miss flow entry wildcards all match fields (all fields omitted) and has the lowest priority 0.
The table-miss flow entry behaves in most ways like any other flow entry.
Group table
The ability for a flow entry to point to a group enables OpenFlow to represent additional methods of forwarding. A group table contains group entries.
Figure 4 Group entry components
A group entry contains the following fields:
· Group Identifier—A 32 bit unsigned integer uniquely identifying the group.
· Group Type—Type of the group. All means executing all buckets in the group. This group is used for multicast or broadcast forwarding.
· Counters—Updated when packets are processed by a group.
· Action Buckets—An ordered list of action buckets, where each action bucket contains a set of actions to execute and associated parameters. Table 1 shows the actions supported by action buckets.
Table 1 Actions supported by action buckets
Action |
Type |
Output |
Required |
Forwards a packet to a specific OpenFlow port, for example, physical port, logical port, and reserved port. |
Set-Field |
Optional |
The Set-Field actions are identified by their field type and modify the values of corresponding header fields in the packet. Support for the Set-Field actions depends on the device model. Header fields supported by the Set-Field actions vary by device model. The Set-Field actions support the following header fields: · OFPXMT_OFB_IN_PORT—Switch input port. · OFPXMT_OFB_IN_PHY_PORT—Switch physical input port. · OFPXMT_OFB_ETH_DST—Ethernet destination address. · OFPXMT_OFB_ETH_SRC—Ethernet source address. · OFPXMT_OFB_VLAN_VID—VLAN ID. · OFPXMT_OFB_VLAN_PCP—VLAN priority. · OFPXMT_OFB_IP_DSCP—IP DSCP (6 bits in ToS field). · OFPXMT_OFB_IP_ECN—IP ECN (2 bits in ToS field). · OFPXMT_OFB_IP_PROTO—IP protocol. · OFPXMT_OFB_IPV4_SRC—IPv4 source address. · OFPXMT_OFB_IPV4_DST—IPv4 destination address. · OFPXMT_OFB_TCP_SRC—TCP source port. · OFPXMT_OFB_TCP_DST—TCP destination port. · OFPXMT_OFB_UDP_SRC—UDP source port. · OFPXMT_OFB_UDP_DST—UDP destination port. · OFPXMT_OFB_SCTP_SRC—SCTP source port. · OFPXMT_OFB_SCTP_DST—SCTP destination port. · OFPXMT_OFB_IPV6_SRC—IPv6 source address. · OFPXMT_OFB_IPV6_DST—IPv6 destination address. · OFPXMT_OFB_IPV6_ND_TARGET—Target address for ND. · OFPXMT_OFB_IPV6_ND_SLL—Source link-layer for ND. · OFPXMT_OFB_IPV6_ND_TLL—Target link-layer for ND. |
Meter table
Meters enable OpenFlow to implement various simple QoS operations, such as rate-limiting. A meter table contains meter entries.
A meter entry contains the following fields:
· Meter Identifier—A 32 bit unsigned integer uniquely identifying the meter.
· Meter Bands—Each meter can have one meter band, which specifies the rate at which the band applies and the way packets should be processed. If the current rate of packets exceeds the rate of the band, packets are processed according to the method defined in the band.
· Counters—Updated when packets are processed by a meter.
Figure 5 Meter entry components
A meter band contains the following fields:
· Band Type—(Optional.) Packet processing methods. Options are:
¡ Drop—Discards the packet when the rate of the packet exceeds the band rate.
¡ DSCP Remark—Remarks the DSCP field in the IP header of the packet.
· Rate—Defines the lowest rate at which the band can apply.
· Counters—Updated when packets are processed by a band.
· Type Specific Arguments—Some band types have specific arguments.
Figure 6 Band components
OpenFlow channel
The OpenFlow channel is the interface that connects each OpenFlow switch to a controller. The controller uses the OpenFlow channel to exchange control messages with the switch to perform the following operations:
· Configure and manage the switch.
· Receive events from the switch.
· Send packets out the switch.
The OpenFlow channel is usually encrypted by using TLS. Also, an OpenFlow channel can be run directly over TCP.
The OpenFlow protocol supports the following message types: controller-to-switch, asynchronous, and symmetric. Each message type has its own subtypes.
Controller-to-switch messages
Controller-to-switch messages are initiated by the controller and used to directly manage or inspect the state of the switch. Controller-to-switch messages might or might not require a response from the switch.
The controller-to-switch messages include the following subtypes:
· Features—The controller requests the basic capabilities of a switch by sending a features request. The switch must respond with a features reply that specifies the basic capabilities of the switch.
· Configuration—The controller sets and queries configuration parameters in the switch. The switch only responds to a query from the controller.
· Modify-State—The controller sends Modify-State messages to manage state on the switches. Their primary purpose is to add, delete, and modify flow or group entries in the OpenFlow tables and to set switch port properties.
· Read-State—The controller sends Read-State messages to collect various information from the switch, such as current configuration and statistics.
· Packet-out—These are used by the controller to send packets out of the specified port on the switch, or to forward packets received through packet-in messages. Packet-out messages must contain a full packet or a buffer ID representing a packet stored in the switch. The message must also contain a list of actions to be applied in the order they are specified. An empty action list drops the packet.
· Barrier—Barrier messages are used to confirm the completion of the previous operations. The controller send s Barrier request. The switch must send a Barrier reply when all the previous operations are complete.
· Role-Request—Role-Request messages are used by the controller to set the role of its OpenFlow channel, or query that role. It is typically used when the switch connects to multiple controllers.
· Asynchronous-Configuration—These are used by the controller to set an additional filter on the asynchronous messages that it wants to receive, or to query that filter. It is typically used when the switch connects to multiple controllers.
Asynchronous messages
Switches send asynchronous messages to controllers to inform a packet arrival or switch state change. For example, when a flow entry is removed due to timeout, the switch sends a flow-removed message to inform the controller.
The asynchronous messages include the following subtypes:
· Packet-In—Transfer the control of a packet to the controller. For all packets forwarded to the Controller reserved port using a flow entry or the table-miss flow entry, a packet-in event is always sent to controllers. Other processing, such as TTL checking, can also generate packet-in events to send packets to the controller. The packet-in events can include the full packet or can be configured to buffer packets in the switch. If the packet-in event is configured to buffer packets, the packet-in events contain only some fraction of the packet header and a buffer ID. The controller processes the full packet or the combination of the packet header and the buffer ID. Then, the controller sends a packet-out message to direct the switch to process the packet.
· Flow-Removed—Inform the controller about the removal of a flow entry from a flow table. These are generated due to a controller flow delete request or the switch flow expiry process when one of the flow timeouts is exceeded.
· Port-status—Inform the controller of a state or setting change on a port.
· Error—Inform the controller of a problem or error.
Symmetric messages
Symmetric messages are sent without solicitation, in either direction.
The symmetric messages contain the following subtypes:
· Hello—Hello messages are exchanged between the switch and controller upon connection startup.
· Echo—Echo request or reply messages can be sent from either the switch or the controller, and must return an echo reply. They are mainly used to verify the liveness of a controller-switch connection, and might also be used to measure its latency or bandwidth.
· Experimenter—This is a staging area for features meant for future OpenFlow revisions.
OpenFlow timers
An OpenFlow switch supports the following timers:
· Connection detection interval—Interval at which the OpenFlow switch sends an Echo Request message to a controller. When the OpenFlow switch receives no Echo Reply message within three intervals, the OpenFlow switch is disconnected from the controller.
· Reconnection interval—Interval for the OpenFlow switch to wait before it attempts to reconnect to a controller.
OpenFlow controller
Controller roles
A switch can establish connections with multiple controllers. When OpenFlow operation is initiated, a switch is simultaneously connected to multiple controllers in Equal state. A controller can request its role to be changed at any time. The controller role contains the following types:
· Equal—In this role, the controller has full access to the switch and is equal to other controllers in the same role. By default, the controller receives all switch asynchronous messages such as packet-in and flow-removed messages. The controller can send controller-to-switch messages to modify the state of the switch.
· Master—This role is similar to the Equal role and has full access to the switch. The difference is that up to one controller in this role is allowed for a switch.
· Slave—In this role, the controller has read-only access to the switch.
The controller cannot send controller-to-switch messages to perform the following operations:
¡ Deploy flow entries, group entries, and meter entries.
¡ Modify the port and switch configurations.
¡ Send packet-out messages.
By default, the controller does not receive switch asynchronous messages except Port-status messages. The controller can send Asynchronous-Configuration messages to set the asynchronous message types it wants to receive.
Controller connection modes
An OpenFlow instance can connect to one or more controllers, depending on the controller connection mode the OpenFlow instance uses:
· Single—The OpenFlow instance connects to only one controller at a time. When communication with the current controller fails, the OpenFlow instance uses another controller.
· Multiple—The OpenFlow instance can simultaneously connect to multiple controllers. When communication with any controller fails, the OpenFlow instance attempts to reconnect to the controller after a reconnection interval.
Main and auxiliary connections
The OpenFlow channel can have one main connection and multiple auxiliary connections.
· Main connection—Processes control messages to complete operations such as deploying entries, obtaining data, and sending information. The main connection must be a reliable TCP or SSL connection.
· Auxiliary connection—Improves the communication performance between the controller and OpenFlow switches. An auxiliary connection can have the different destination IP address and port number than the main connection.
Connection interruption mode
When an OpenFlow switch is disconnected from all controllers, the OpenFlow switch is set to either of the following modes:
· Secure—The OpenFlow switch forwards traffic based on flow tables and does not remove unexpired flow entries. If the output action in a matching flow entry is to forward traffic to a controller, the traffic is discarded. This is the default forwarding mode.
· Smart—The OpenFlow switch forwards traffic based on flow tables and does not remove unexpired flow entries. If the output action in a matching flow entry is to forward traffic to a controller, the traffic is forwarded in normal process.
· Standalone—The OpenFlow switch uses the normal forwarding process.
The OpenFlow switch forwards traffic based on flow tables when it reconnects to a controller successfully.
Protocols and standards
OpenFlow Switch Specification Version 1.3.3
OpenFlow tasks at a glance
To configure OpenFlow, perform the following tasks:
1. Configuring OpenFlow instances
a. Creating an OpenFlow instance
b. Configuring the OpenFlow instance mode
c. Enabling the TTP mode for an OpenFlow instance
This task is applicable if the OpenFlow instance uses TTP flow tables.
d. (Optional.) Configuring inband management VLANs
e. (Optional.) Configuring flow tables and flow entries for an OpenFlow instance
This task is applicable if the OpenFlow instance does not use TTP flow tables.
f. (Optional.) Setting the controller connection mode
g. (Optional.) Preventing an OpenFlow instance from reporting the specified types of ports to controllers
h. Activating or reactivating an OpenFlow instance
i. (Optional.) Configuring OpenFlow instance attributes
2. Configuring controllers for an OpenFlow switch
3. (Optional.) Excluding the specified VLANs from the VLANs in which traffic is forwarded in the OpenFlow forwarding process
4. (Optional.) Configuring an OpenFlow instance to act as an SSL server to listen to controllers
5. (Optional.) Refreshing all Layer 3 flow entries in the MAC-IP flow tables for an OpenFlow instance
6. (Optional.) Enabling packet loss prevention for OpenFlow forwarding
7. (Optional.) Ignoring the permit flag added by OpenFlow
8. (Optional.) Reserving ACL resources for extensibility flow tables
9. (Optional.) Shutting down an interface by OpenFlow
10. (Optional.) Enabling SNMP notifications for OpenFlow
1. Enter system view.
2. Create an OpenFlow instance and enter its view.
openflow instance instance-id
3. (Optional) Set the datapath ID.
datapath-id id
By default, the datapath ID of an OpenFlow instance contains the instance ID and the bridge MAC address of the device. The upper 16 bits are the instance ID and the lower 48 bits are the bridge MAC address of the device.
The datapath ID uniquely identifies an OpenFlow switch (OpenFlow instance). Do not set the same datapath ID for different OpenFlow switches.
4. Set a DSCP value for OpenFlow packets.
tcp dscp dscp-value
By default, no DSCP value is set for OpenFlow packets.
When you associate an OpenFlow instance with VLANs, follow these guidelines:
· For VLAN traffic to be processed correctly, associate different OpenFlow instances with different VLANs.
· When you activate an OpenFlow instance that is associated with nonexistent VLANs, the system automatically creates the VLANs.
· Do not associate VLANs permitted on a port with different OpenFlow instances. Otherwise, port modification messages of different OpenFlow instances deployed from different controllers overwrite each other.
· Do not configure BFD MAD on the VLAN interface for a VLAN that is associated with an OpenFlow instance. For more information about BFD MAD, see Virtual Technologies Configuration Guide.
Enabling the global mode for an OpenFlow instance
2. Enter OpenFlow instance view.
3. Enable the global mode for the OpenFlow instance.
Classification global
By default, the OpenFlow instance mode is not configured.
Enabling the VLAN mode for an OpenFlow instance
3. Configure the OpenFlow instance mode.
classification vlan vlan-id [ mask vlan-mask ] [ loosen ]
You can enable the TTP mode only for an inactivated OpenFlow instance in global mode. To configure an OpenFlow instance to operate in global mode, use the classification global command.
An OpenFlow instance enabled with the TTP mode supports only TTP flow entries. This feature is exclusive with commands related to other types of flow entries (such as the flow-table command).
You can enable the TTP mode for the OpenFlow instance only when all OpenFlow instances are not activated.
The device supports enabling the TTP mode for only one OpenFlow instance.
3. Enable the TTP mode for the OpenFlow instance.
ttp enable
By default, the TTP mode is disabled for an OpenFlow instance.
Traffic in the inband management VLANs are forwarded in the normal forwarding process instead of the OpenFlow forwarding process. Inband management VLANs are used by an OpenFlow instance to establish OpenFlow channels to controllers.
The ports that are assigned only to inband management VLANs are not OpenFlow ports.
Inband management VLANs configured for an OpenFlow instance in VLAN mode must be within the list of the VLANs associated with the OpenFlow instance.
If an OpenFlow instance in global or VLAN mode connects to a controller through a non-management Ethernet interface, configure the VLAN to which the interface belongs as an inband management VLAN.
3. Configure inband management VLANs for the OpenFlow instance.
in-band management vlan vlan-id-list
By default, no inband management VLANs are configured for an OpenFlow instance.
You can configure one MAC-IP flow table, one MPLS flow table, and two extensibility flow tables for an OpenFlow instance.
If you specify the ingress-vlan ingress-table-id option, make sure the VLAN tagging flow table has the smallest ID among all flow tables. If you specify the egress-vlan egress-table-id option, make sure the VLAN untagging flow table has the largest ID among all flow tables.
The VLAN tagging and untagging flow tables take effect when the device meets the following requirements:
· The device operates in standalone mode.
· The device is enabled to perform QinQ tagging for double-tagged packets passing an extensibility flow table.
The extensibility flow table ID must be greater than the MAC-IP flow table ID or the MPLS flow table ID.
3. Configure flow tables for the OpenFlow instance.
flow-table { ingress-vlan ingress-table-id | mac-ip mac-ip-table-id | mpls mpls-table-id | extensibility extensibility-table-id&<1-n> | egress-vlan egress-table-id }*
By default, an OpenFlow instance contains one extensibility flow table with an ID of 0.
4. Enable the OpenFlow instance to perform QinQ tagging for double-tagged packets passing an extensibility flow table.
qinq-network enable
By default, a double-tagged packet becomes single-tagged after it passes an extensibility flow table.
To use the following flow tables for an OpenFlow instance, make sure the OpenFlow instance is configured with the qinq-network enable command:
¡ One or both types of the VLAN tagging and untagging flow tables.
¡ Extensibility flow tables.
5. Set the maximum number of flow entries that each extensibility flow table supports.
flow-entry max-limit limit-value
The default setting is 65535.
When the maximum number is reached, the OpenFlow instance does not accept new flow entries for that table and sends a deployment failure notification to the controller.
When multiple extensibility flow tables exist, the limit applies to each extensibility flow table separately.
6. Configure the OpenFlow instance to allow dynamic ARP entries to overwrite OpenFlow ARP entries.
precedence dynamic arp
By default, an OpenFlow instance does not allow dynamic ARP entries to overwrite OpenFlow ARP entries.
Only MAC-IP flow tables support this feature.
7. Allow the deployed flow tables to include link aggregation member ports.
permit-port-type member-port
By default, the deployed flow tables cannot include link aggregation member ports.
8. Configure the OpenFlow instance to drop slow protocol packets.
protocol-packet filter slow
By default, an OpenFlow instance does not drop slow protocol packets.
The slow protocols include LACP and OAM.
9. Configure the default action of table-miss flow entries to forward packets to the normal pipeline.
default table-miss permit
By default, the default action of table-miss flow entries is to drop packets.
3. Set the controller connection mode.
By default, the multiple mode is used.
Perform this task to prevent an OpenFlow instance from reporting controllers information about the following types of interfaces that belong to the OpenFlow instance:
· Layer 3 Ethernet interface.
· Layer 3 aggregate interface.
· VLAN interface.
· Virtual switch instance (VSI) interface.
3. Prevent an OpenFlow instance from reporting the specified types of ports to controllers.
forbidden port { l3-physical-interface | vlan-interface | vsi-interface } *
By default, no port types are prevented from being reported to the controllers. All ports that belong to an OpenFlow instance are reported to the controllers.
In a forwarding-control separated network, you must enable this feature to deliver the following mappings to the controller:
· Site-facing interface (where an Ethernet service instance is created) to VXLAN mappings.
· VXLAN-DCI tunnel to VXLAN mappings.
Based on these mappings, the controller generates flow entries and then deploys the flow entries to the switch.
3. Enable the OpenFlow data plane forwarding feature.
data-plane enable
By default, the OpenFlow data plane forwarding feature is disabled.
3. Activate or reactivate the OpenFlow instance.
active instance
By default, an OpenFlow instance is not activated.
The OpenFlow instance attribute configurations of an OpenFlow instance can take effect without activation for the OpenFlow instance.
3. Configure a description for the OpenFlow instance.
By default, an OpenFlow instance does not have a description.
4. Set OpenFlow timers.
¡ Set the connection detection interval.
controller echo-request interval interval
The default setting is 5 seconds.
¡ Set the reconnection interval.
controller connect interval interval
The default setting is 60 seconds.
5. Configure MAC address-related features.
¡ Forbid MAC address learning for VLANs associated with the OpenFlow instance.
mac-learning forbidden
By default, MAC address learning is allowed for VLANs associated with an OpenFlow instance.
The configuration does not take effect on inband management VLANs.
¡ Configure the OpenFlow instance to support matching the dynamic MAC addresses in the query and deletion flow entry instructions sent from controllers.
mac-ip dynamic-mac aware
By default, an OpenFlow instance ignores dynamic MAC addresses in the query and deletion flow entry instructions sent from controllers.
6. Prevent the OpenFlow instance from reporting ARP packets to the specified controllers.
forbidden packet-in arp controller controller-id-list
By default, no controllers to which ARP packets are forbidden to be reported are configured.
This feature forbids an OpenFlow instance to report ARP packets to the specified controllers to prevent the controllers from being affected by a large number of packets.
7. Disable logging for successful flow table modifications.
flow-log disable
By default, logging for successful flow table modifications is enabled.
8. Enable loop guard for the OpenFlow instance.
loop-protection enable
By default, loop guard is disabled for an OpenFlow instance.
After an OpenFlow instance is deactivated, you can enable loop guard for the OpenFlow instance to avoid loops. This feature enables the deactivated OpenFlow instance to create a flow entry for dropping all traffic in these VLANs.
Make sure the configuration of an auxiliary connection does not conflict with the configuration of the main connection. Otherwise, the auxiliary connection cannot be established.
For an OpenFlow instance in TTP mode, you can configure the controller to use an SSL client policy used to authenticate the instance during main connection establishment.
· To use a specific SSL client policy for main connection establishment, specify the ssl ssl-policy-name option in the controller address command.
· To use the global SSL client policy for main connection establishment, specify the global-ssl keyword in the controller address command.
2. Specify the global SSL client policy for TTP controllers.
openflow ttp-controller [ ttp-controller-id ] global-ssl ssl-policy-name
By default, no global SSL client policy is specified for TTP controllers.
To specify the global SSL client policy for a TTP controller, specify the ttp-controller-id argument. To specify the global SSL client policy for all TTP controllers, do not specify the ttp-controller-id argument.
3. Enter OpenFlow instance view.
4. Specify a controller and configure the main connection to the controller.
controller controller-id address { ip ipv4-address | ipv6 ipv6-address } [ port port-number ] [ local address { ip local-ipv4-address | ipv6 local-ipv6-address } [ port local-port- number ] ] [ global-ssl | ssl ssl-policy-name [ access-control-policy acp-policy-name ] ] [ vrf vrf-name ]
By default, an OpenFlow instance does not have a main connection to a controller.
The source IP address must be the IP address of a port belonging to an OpenFlow instance. Otherwise, the OpenFlow switch might fail to establish a connection with the controller.
5. (Optional) Specify a controller and configure an auxiliary connection to the controller.
controller id auxiliary auxiliary-id transport { tcp | udp | ssl ssl-policy-name } [ address { ip ipv4-address | ipv6 ipv6-address } ] [ port port-number ]
By default, an OpenFlow instance does not have auxiliary connections to a controller.
If no destination IP address and port number are specified, the auxiliary connection uses the destination IP address and port number configured for the main connection.
6. (Optional) Set the connection interruption mode.
fail-open mode { secure | smart| standalone }
By default, the secure mode is used.
7. (Optional) Enable OpenFlow connection backup.
tcp-connection backup
By default, OpenFlow connection backup is enabled.
This feature prevents connection interruption when an active/standby switchover occurs.
This feature is available only on an IRF fabric with two member devices.
This feature is available for only OpenFlow connections established over TCP.
The VLANs to be associated with an OpenFlow instance are calculated by a bitwise AND operation on the VLAN ID and mask. Use this feature to exclude the VLANs in which traffic is required to be forwarded in the normal forwarding process from the calculated VLANs. Traffic in the excluded VLANs is forwarded in the normal forwarding process instead of the OpenFlow forwarding process.
2. Exclude the specified VLANs from the VLANs in which traffic is forwarded in the OpenFlow forwarding process.
openflow normal-forward vlan { vlan-id [ to vlan-id ] } &<1-10>
By default, no VLANs are excluded from the VLANs in which traffic is forwarded in the OpenFlow forwarding process.
Typically, an OpenFlow instance actively connects to the controller acting as a TCP/SSL client. After the SSL server is enabled for an OpenFlow instance, the controller acts as the SSL client and actively connects to the OpenFlow instance. For more information about SSL, see Security Configuration Guide.
This feature can take effect without activation for an OpenFlow instance.
To re-configure the SSL server, first execute the undo form of the command to delete the existing SSL server configuration.
3. Configure an OpenFlow instance to act as an SSL server to listen to controllers.
listening port port-number ssl ssl-policy-name
By default, an OpenFlow instance is not configured to acts as an SSL server listen to controllers.
Perform this task to obtain all Layer 3 flow entries in the MAC-IP flow tables from the controller again if the Layer 3 flow entries have been overwritten.
3. Refresh all Layer 3 flow entries in the MAC-IP flow tables.
refresh ip-flow
Packet loss prevention ensures successful OpenFlow forwarding without packet loss. In an OpenFlow network, packet loss might occur on the switch during the flow entry deployment process. Packet loss then causes OpenFlow forwarding errors. For example, traffic is mistakenly sent to controllers and the controllers deploy faulty flow entries.
When this feature is enabled, the OpenFlow matching ability is decreased. For example, packets cannot be matched by IPv6 address.
Feature and hardware compatibility
This feature is not supported on the S6860 switch series.
To avoid a decrease in the forwarding efficiency and matching ability, do not enable this feature in a non-OpenFlow network.
After you enable or disable packet loss prevention on a switch, save the configuration and restart the switch to make the configuration take effect.
2. Enable packet loss prevention for OpenFlow forwarding.
openflow lossless enable
By default, packet loss prevention for OpenFlow forwarding is disabled.
Packets matching an OpenFlow flow entry with the output action as Normal are permitted to pass through and marked with a permit flag. Packets with a permit flag are not dropped by a discard action in a QoS policy (for example, a CAR discard action).
This feature allows the device to drop packets with a permit flag by using a discard action in a QoS policy.
2. Ignore the permit flag added by OpenFlow.
openflow permit-flag ignore
By default, the permit flag added by OpenFlow is not ignored.
To ensure packet forwarding, you can use this feature to reserve the specified number of ACL resources for extensibility flow tables.
After you configure this feature, save the configuration and restart the switch to make the configuration take effect.
To form an IRF fabric, make sure all member devices in the IRF fabric use the same ACL resource reservation value.
2. Reserve ACL resources for extensibility flow tables.
openflow flow-entry reserve-acl-resource reserved-value
By default, no ACL resources are reserved for extensibility flow tables.
After an interface is shut down by OpenFlow, the Current state field displays OFP DOWN in the display interface command output.
You can use the undo openflow shutdown command to bring up an interface shut down by OpenFlow. The interface can also be brought up by port modification messages from controllers.
2. Enter interface view.
3. Shut down an interface by OpenFlow.
openflow shutdown
By default, an interface is not shut down by OpenFlow.
This feature enables OpenFlow to generate SNMP notifications for important OpenFlow events. For the notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see SNMP configuration in Network Management and Monitoring Configuration Guide.
2. Enable SNMP notifications for OpenFlow.
snmp-agent trap enable openflow [ connect-state ]
By default, SNMP notifications are enabled for OpenFlow.
Task |
Command |
Display the detailed information for an OpenFlow instance. |
display openflow instance [ instance-id ] |
Display controller information for an OpenFlow instance. |
display openflow instance instance-id { controller [ controller-id ] | listened } |
Display auxiliary connection information. |
display openflow instance instance-id auxiliary [ controller-id [ auxiliary auxiliary-id ] ] |
Display flow table entries for an OpenFlow instance. |
display openflow instance instance-id flow-table [ table-id ] |
Display group table information for an OpenFlow instance. |
display openflow instance instance-id group [ group-id ] |
Display meter table information for an OpenFlow instance. |
display openflow instance instance-id meter [ meter-id ] |
Display summary OpenFlow instance information. |
display openflow summary |
Clear statistics on packets that a controller sends and receives for an OpenFlow instance. |
reset openflow instance instance-id { controller [ controller-id ] | listened } statistics |
As shown in Figure 7, an OpenFlow switch communicates with the controller. Perform the following tasks on the OpenFlow switch:
· Create OpenFlow instance 1, associate VLANs 4092 and 4094 with the OpenFlow instance, and activate the OpenFlow instance.
· Configure the IP address for controller 1 to have the controller manage the OpenFlow switch.
# Create VLANs 4092 and 4094.
<Switch> system-view
[Switch] vlan 4092
[Switch-vlan4092] quit
[Switch] vlan 4094
[Switch-vlan4094] quit
# Create OpenFlow instance 1 and associate VLANs with it.
[Switch] openflow instance 1
[Switch-of-inst-1] classification vlan 4092 mask 4093
# Specify controller 1 for OpenFlow instance 1 and activate the instance.
[Switch-of-inst-1] controller 1 address ip 192.168.49.49
[Switch-of-inst-1] active instance
[Switch-of-inst-1] quit
# View detailed information about the OpenFlow instance.
[Switch] display openflow instance 1
Instance 1 information:
Configuration information:
Description : --
Active status : Active
Inactive configuration:
None
Active configuration:
Classification VLAN, total VLANs(2)
4092, 4094
Port information:
Ten-GigabitEthernet1/0/3
Active channel information:
Controller 1 IP address: 192.168.49.49 port: 6633
Flow entry restrictions
Matching restrictions
VLAN matching
Table 2 describes the VLAN matching restrictions when an OpenFlow instance is associated with VLANs.
VLAN |
Mask |
Matching packets |
All packets in the VLANs that are associated with the OpenFlow instance. |
0 |
Packets without a VLAN tag. The PVID of the ingress port must be associated with the OpenFlow instance. |
0 |
Value |
Unsupported. |
Valid VLAN |
-/value |
Unsupported. |
0x1000 |
-/value (except 0x1000) |
Unsupported. |
0x1000 |
0x1000 |
Packets with a VLAN tag. The VLAN ID of the VLAN tag must be associated with the OpenFlow instance. |
Valid VLAN | 0x1000 |
-/value |
Matching packets by the combination of the VLAN ID and VLAN mask. The VLANs obtained through the combination of the VLAN ID and VLAN mask must be associated with the OpenFlow instance. |
Other |
Other |
Unsupported. |
Protocol packet matching
If protocols are enabled, protocol packets (except LLDP frames) are processed by the corresponding protocols instead of the OpenFlow protocol.
For more information about LLDP frame matching, see "LLDP frame matching."
Metadata matching
Metadata passes matching information between flow tables. The controller deploys metadata matching entries only to non-first flow tables. If the controller deploys a metadata matching entry to the first flow table, the switch returns an unsupported flow error.
Instruction restrictions
Table 3 Instruction restrictions
Instruction type |
Restrictions |
Clear-Actions |
The Clear-Actions instruction has the following restrictions: · For the single flow table, the flow entries of the table cannot include this instruction and other instructions at the same time. · For multiple flow tables of the pipeline, only the flow entries of the first flow table can include this instruction and other instructions at the same time. |
Apply-Actions |
The action list of the Apply-Actions instruction cannot include multiple Output actions. When the action list includes only one Output action, the switch processes the action list as described in "Restrictions for merging the action list into the action set." |
Write-Metadata/mask |
The flow entries of the last table of the pipeline cannot include this instruction. Otherwise, the switch returns an unsupported flow error. |
Goto-Table |
The switch follows the following restrictions to merge the action list into the action set.
Non-output actions
When the action set and the action list do not contain the Output or Group action, the following rules apply:
· If actions in the action set do not conflict with actions in the action list, the switch merges the action list into the action set.
· If actions in the action set conflict with actions in the action list, actions in the action list are replaced with actions in the action set.
Output actions
When the action set and the action list contain the Output action or the Group action, the following rules apply:
· If both the action list and the action set contain an Output action, the Output action in the action list takes precedence. The Output action in the action list does not modify the packet. The Output action in the action set is executed at the last step of the pipeline processing to modify the packet.
· If either the action list or the action set contains an Output action, the port specified by the Output action is treated as the output port. The actions are executed in the order defined by the action set rules.
· If the action list contains an Output action and the action set contains a Group action, the following rules apply:
¡ The Output action does not modify the packet.
¡ The Group action is executed.
Ingress port
The ingress port must be a physical or logical port when one of the following reserved ports is the output port in a packet-out message:
· Normal.
· Local.
· In Port.
· Controller.
Buffer ID co-existing with packet
If a packet-out message contains both the packet and the buffer ID representing the packet stored in the switch, the switch processes only the buffered packet. The switch ignores the packet in the message.
If the packet contained in a packet-out message has no VLAN tag, the switch performs the following operations:
· Tags the packet with the PVID of the ingress port.
· Forwards the packet within the VLAN.
The switch processes the packet as follows when the ingress port is a reserved port:
· If the output port is a physical or logical port, the switch tags the packet with the PVID of the output port and forwards the packet within the VLAN.
· If the output port is the Flood or All reserved port, the switch processes the packet as described in "Output port."
Output port
If the output port in a packet-out message is the Flood or All reserved port, the switch processes the packet contained in the packet-out message as follows:
· When the output port is the Flood reserved port:
¡ If the packet has a VLAN tag, the switch broadcasts the packet within the VLAN.
¡ If the packet has no VLAN tag and the ingress port is a physical or logical port, the switch tags the packet with the PVID of the ingress port. The switch then forwards the packet within the VLAN.
¡ If the packet has no VLAN tag and the ingress port is the Controller reserved port, the switch forwards the packet out all OpenFlow ports.
· When the output port is the All reserved port:
¡ If the packet has no VLAN tag, the switch forwards the packet out of all OpenFlow ports regardless of the ingress port type.
Processing VLAN tags
When sending a packet-in message to the controller, the switch processes the VLAN tag of the packet contained in the packet-out message as follows:
· If the VLAN tag of the packet is the same as the PVID of the ingress port, the switch removes the VLAN tag.
· If the VLAN tag of the packet is different from the PVID of the ingress port, the switch does not remove the VLAN tag.
Packet buffer
If a packet-in message is sent to controller due to no matching flow entry, the switch supports buffering the packet contained in the packet-in message. The buffer size is 1K packets.
If a packet-in message is sent to controller for other reasons, the switch does not support buffering the packet contained in the packet-in message. The switch must send the full packet to the controller, and the cookie field of the packet is set to 0xFFFFFFFFFFFFFFFF.
LLDP frame matching
LLDP is used to perform topology discovery in an OpenFlow network. LLDP must be enabled globally on a device. A switch sends a LLDP frame to the controller through the packet-in message when the following conditions exist:
· The port that receives the LLDP frame from the controller belongs to OpenFlow instances.
· The flow tables in the OpenFlow instance have a flow entry that matches the LLDP frame (the output port is the Controller reserved port).
The flow table modification messages have the following restrictions for the table-miss flow entry and common flow entries.
The controller deploys the table-miss flow entry (the action is Drop) to an OpenFlow instance after the OpenFlow instance is activated.
The controller cannot query the table-miss flow entry through Multipart messages.
The controller cannot modify the table-miss flow entry through the Modify request. The controller can only modify the table-miss flow entry through the Add request.
The controller can modify or delete the table-miss flow entry only through the strict version of the Modify or Delete request. The controller cannot modify or remove the table-miss flow entry through the non-strict version of the Modify or Delete request despite that the match fields are wildcarded.
The controller deploys a table-miss flow entry (the action is Drop) to an OpenFlow instance after the current table-miss flow entry is deleted.
Common flow entries
The controller cannot modify or remove all common flow entries through the non-strict version of the Modify or Delete request despite that the match fields are wildcarded.
The controller must include the required match fields and actions and can include the optional match fields and actions in the flow entries deployed to the MAC-IP flow table. If the controller does not include the optional match fields and actions in the flow entries, the switch adds them to the flow entries by default.
The Layer 2 flow entries are implemented by using MAC address entries. Table 4 describes the capabilities supported by Layer 2 flow entries.
Table 4 Capabilities supported by Layer 2 flow entries
Item |
Capabilities |
Required match fields |
The MAC-IP flow table must support the following match fields: · VLAN ID. · Unicast destination MAC address. |
Optional match fields |
N/A |
Required actions |
Specifying the output port. |
Optional actions |
The MAC-IP flow table can optionally support the following instructions: · Goto-Table—When the switch has multiple tables, the switch adds this instruction by default if the controller does not deploy it. · Write-Metadata—When the switch has multiple tables, the switch adds this instruction by default if the controller does not deploy it. |
The Layer 3 flow entries are implemented by using routing entries. Table 5 describes the capabilities supported by Layer 3 flow entries.
Table 5 Capabilities supported by Layer 3 flow entries
Item |
Capabilities |
The MAC-IP flow table must support the following match fields: · VLAN ID. · Unicast destination IP address. · Unicast destination MAC address, which must be the MAC address of the VLAN interface for the VLAN that is matched. |
N/A |
Required actions |
Optional actions |
The MAC-IP flow table can optionally support the following actions: · Modify source MAC address—The switch modifies the source MAC address to the MAC address of the VLAN interface for the VLAN to which the output port belongs. · Decrement TTL by one. · Goto-Table—When the switch has multiple tables, the switch adds this instruction by default if the controller does not deploy it. · Write-Metadata—When the switch has multiple tables, the switch adds this instruction by default if the controller does not deploy it. |
Controller must follow the restrictions in the following tables to deploy flow entries for MAC-IP flow table. Otherwise, forwarding failure might occur.
Table 6 Restrictions for deploying Layer 2 flow entries for the MAC-IP flow table
Item |
Restrictions |
Match fields |
The destination MAC address cannot be the MAC address of the switch to which the flow entry is deployed. |
Actions |
The output port must belong to the VLAN that is matched. |
Table 7 Restrictions for deploying Layer 3 flow entries for the MAC-IP flow table
Item |
Restrictions |
Match fields |
The VLAN interface of the VLAN that is matched is in up state. The destination MAC address is the MAC address of the VLAN interface for the VLAN that is matched. The destination IP address cannot be the IP address of the switch to which the flow entry is deployed. |
Actions |
The specified output port must belong to the destination VLAN. The destination MAC address cannot be the MAC address of the switch to which the flow entry is deployed. If the switch modifies the source MAC address, the source MAC address must be the MAC address of the VLAN interface for the VLAN to which the output port belongs. |
To deploy a Layer 3 flow entry, make sure the following requirements are met:
· The VLAN interface of the matched VLAN is in up state.
· The switch sends the controller a packet that indicates the VLAN interface acts as an OpenFlow port. The link state and the MAC address of the VLAN interface are also included in the packet.
The switch reports the VLAN interface deletion to the controller and the controller removes the corresponding Layer 3 flow entry.
The controller ensures the correctness of Layer 3 flow entries. The switch does not check for the restrictions for Lay 3 flow entries.
The table-miss flow entry of a MAC-IP flow table supports the following output actions:
· Goto-Table—Direct the packet to the next table.
· Drop—Drop the packet.
· Controller—Send the packet to the controller.
· Normal—Forward the packet to the normal pipeline.
Dynamic aware
On an OpenFlow switch that supports MAC-IP flow tables, you can configure OpenFlow to support querying and deleting dynamic MAC address flow entries.
The controller can query and delete dynamic MAC address flow entries by specifying a VLAN, a MAC address, or the combination of a MAC address and a VLAN.
Metadata/mask
The MAC-IP flow table supports the Write Metadata/mask instruction and the extensibility flow table supports metadata/mask matching. The MAC-IP flow table can cooperate with an extensibility flow table to perform the pipeline process of multiple tables by using metadata/mask.
Each metadata mask bit has a different meaning. The corresponding metadata bit being set indicates that the metadata mask bit is matched. When the corresponding metadata bit is not set, the metadata mask bit is wildcarded.
Table 8 Metadata mask meanings
Metadata mask bit |
Meaning |
Metadata |
Bit 0 |
Destination MAC address |
· 1—Set. Matches the destination MAC address. · 0—Not set. Does not match the destination MAC address. |
Bit 1 |
Source MAC address |
· 1—Set. Matches the source MAC address. · 0—Not set. Does not match the source MAC address. |
Bit 2 |
Destination IP address |
· 1—Set. Matches the destination IP address. · 0—Not set. Does not match the destination IP address. |
Others |
Reserved |
Reserved. |
When the output action in an extensibility flow table is not Normal, the following rules apply:
· The MAC-IP flow table does not take effect.
· All actions are executed according to the extensibility flow table.
When the output action in an extensibility flow table is Normal, the following rules apply:
· The output action is executed according to the MAC-IP flow table.
· The other actions are executed according to the extensibility flow table.
The controller must include the required match fields and actions and can include the optional match fields and actions in the flow entries deployed to the VLAN tagging flow table. If the controller does not include the optional match fields and actions in the flow entries, the switch adds them to the flow entries by default.
Table 9 describes the capabilities supported by the flow entries in the VLAN tagging flow table.
Table 9 Capabilities supported by flow entries in the VLAN tagging flow table
Item |
Capabilities |
The VLAN tagging flow table must support the following match fields: · input-port. · vlan. |
N/A |
Required actions |
The following actions in the action list of the Apply-Actions instruction must be applied immediately: · Push-Tag. · Set-Field (VLAN). |
Optional actions |
The VLAN tagging flow table can optionally support the following actions: · Output (normal). · Goto-Table. |
The Push-Tag and Set-Field (VLAN) actions must be in the action list of the Apply-Actions instruction. The Push-Tag and Set-Field (VLAN) actions can be used as follows:
· Push-Tag + Set-Field (value1)—Adds a VLAN tag value1.
· Set-Field (value1) + Push-Tag + Set-Field (value2)—Modifies the VLAN tag of the packet to value1 and adds a VLAN tag value2.
· Push-Tag + Set-Field (value1) + Push-Tag + Set-Field (value2)—Adds inner VLAN tag value2 and outer VLAN tag value1.
The Goto-Table instruction is optional and does not take effect. The flow table specified by this instruction can only be the next of the VLAN tagging flow table.
Table 10 Capabilities supported by flow entries in the VLAN untagging flow table
Item |
Capabilities |
The VLAN untagging flow table must support the following match fields: · egress port—Matches the egress port of packets. · vlan—Matches the outer VLAN tag of packets. |
The VLAN untagging flow table can optionally support the inner vlan match field that matches the inner VLAN tag of double-tagged packets. |
Required actions |
The following actions in the action list of the Apply-Actions instruction must be applied immediately: · Pop-Tag. · Set-Field (VLAN). |
Optional actions |
The VLAN untagging flow table can optionally support the Output (normal) action. |
The VLAN untagging flow table applies only to double-tagged packets.
The egress port and inner vlan are extended match fields that use the Experimenter ID H3C (0xFE2) and take the private match field values 47 and 48, respectively. To deploy flow entries that contain the extended match fields, make sure the controllers are developed to be compatible with the Experimenter ID and the extended match fields.
The Pop-Tag and Set-Field (VLAN) actions must be in the action list of the Apply-Actions instruction. The Pop-Tag and Set-Field (VLAN) actions can be used as follows:
· Pop-Tag—Removes the outer VLAN tag.
· Pop-Tag + Pop-Tag—Removes the inner and outer VLAN tags.
· Pop-Tag + Set-Field (value)—Removes the outer VLAN tag and modifies the inner VLAN tag to value.
The MPLS flow table includes ingress, transit, and egress MPLS flow entries.
Capabilities supported by ingress MPLS flow entries
An ingress MPLS flow entry is used only to add an MPLS label to packets.
Table 11 describes the capabilities supported by ingress MPLS flow entries.
Table 11 Capabilities supported by ingress MPLS flow entries
Item |
Capabilities |
An ingress MPLS flow entry must support the following match fields: · Ethernet type. · Unicast destination IP address. |
N/A |
Required actions |
An ingress MPLS flow entry must support the following actions: · Push-MPLS. · Set-Field (MPLS-Label). · Nexthop (experimenter field). |
Optional actions |
N/A |
The Push-MPLS, Set-Field (MPLS-Label), and Nexthop (experimenter field) actions can be used as follows:
· Set-Field (MPLS-Label)—Modifies the MPLS label of packets.
· Push-MPLS + Set-Field (MPLS-Label)—Adds an MPLS label to packets.
· Nexthop (experimenter field)—Specifies the next hop of the route.
Capabilities supported by transit MPLS flow entries
A transit MPLS flow entry is used only to modify the MPLS label of packets.
Table 12 describes the capabilities supported by transit MPLS flow entries.
Table 12 Capabilities supported by transit MPLS flow entries
Item |
Capabilities |
A transit MPLS flow entry must support the following match fields: · Ethernet type. This field is used to match MPLS-labeled packets with the field value 0x8847. · MPLS-Label. |
N/A |
Required actions |
A transit MPLS flow entry must support the following actions: · Set-Field (MPLS-Label). · Nexthop (experimenter field). |
Optional actions |
N/A |
The Set-Field (MPLS-Label) and Nexthop (experimenter field) actions can be used as follows:
Capabilities supported by egress MPLS flow entries
An egress MPLS flow entry is used only to pop the MPLS label of packets.
Table 13 describes the capabilities supported by egress MPLS flow entries.
Table 13 Capabilities supported by egress MPLS flow entries
Item |
Capabilities |
An egress MPLS flow entry must support the following match fields: · Ethernet type. This field is used to match MPLS-labeled packets with the field value 0x8847. · MPLS-Label. |
N/A |
Required actions |
An egress MPLS flow entry must support the following actions:: · Output (normal). · Pop-MPLS. |
Optional actions |
N/A |
The Pop-MPLS action is used to pop the MPLS label of packets.
Multi-level table-based TTP pipeline
A TTP pipeline can include multiple types of flow tables and the tables can be cascaded. Figure 8 shows the forwarding workflow of a TTP pipeline.
Figure 8 Multi-level table-based TTP pipeline
Table-miss flow entry of TTP flow tables
The table-miss flow entry of a TTP flow table supports the following output actions:
· Goto-table-50—Direct the packet to table 50 (the TTP-Bridging flow table).
Table 14 describes the instruction supported by the table-miss flow entry of different types in TTP flow tables. The instruction in the table-miss entry of TTP flow tables 0 through 50 cannot be modified.
Table 14 Instruction supported by the table-miss flow entry of TTP flow tables
Table ID |
TTP flow table |
Instruction in the table-miss entry |
0 |
TTP-ingress-port |
Normal |
10 |
TTP-VLAN |
Normal |
20 |
TTP-termination-MAC |
Goto-table-50 |
30 |
TTP-unicast-routing |
Normal |
50 |
TTP-bridging |
Controller |
60 |
TTP-ingress-ACL |
N/A |
61 |
TTP-egress-ACL |
N/A |
Capabilities supported by the TTP-ingress-port flow table
A TTP-ingress-port flow entry is used to identify the type of the input port for a packet and direct the packet to another table.
· Packets arriving at a physical interface are directed to the TTP-VLAN flow table.
· Packets arriving at a VXLAN tunnel interface are directed to a TTP-Bridging flow table and added the VXLAN ID information in metadata.
Table 15 Capabilities supported by TTP-ingress-port flow entries (for packets arriving at physical interfaces)
Item |
Capabilities |
N/A |
In-Port—Type of the input port (physical interface). |
Required actions |
Goto-table-10—Directs the packet to table 10 (TTP-VLAN flow table). |
Optional actions |
N/A |
Item |
Capabilities |
N/A |
· In-Port—Type of the input port (VXLAN tunnel interface). · Tunnel ID—VNI. |
Required actions |
· Write-metadata—Writes VNI and VRF information. · Goto-table-50—Directs the packet to table 50 (TTP-bridging flow table). |
Optional actions |
N/A |
· In-Port—Matches the type of the input port. It contains 4 bytes, where the former 2 bytes indicates the interface type. The following interface types are supported:
¡ 0x0000—Physical interface at the user side.
¡ 0x0001—VLAN tunnel interface on an overlay network.
· Metadata—Transmits the VNI and VRF index information in a pipeline. This field contains 64 bytes, where the lower-order 32 bytes indicate a VNI and the higher-order 32 bytes indicate a VRF index.
Capabilities supported by the TTP-VLAN flow table
A TTP-VLAN flow entry is used to match untagged or tagged packets arriving at a physical interface, direct the packets to the TTP-termination-MAC flow table, and transmit VXLAN ID information.
Table 17 Capabilities supported by TTP-VLAN flow entries (for untagged packets)
Item |
Capabilities |
N/A |
Required actions |
· Write-metadata—Writes the VNI information. · Goto-table-20—Directs the packet to table 20 (TTP-termination-MAC flow table). |
Optional actions |
N/A |
Table 18 Capabilities supported by TTP-VLAN flow entries (for tagged packets)
Item |
Capabilities |
N/A |
· In-Port—Type of the input port (physical interface). · VLAN ID—VLAN ID. |
Required actions |
Optional actions |
N/A |
Capabilities supported by the TTP-termination-MAC flow table
A TTP-termination-MAC flow entry is used to select Layer 2 or 3 forwarding based on the destination MAC address of a packet, direct the packet to a flow table, and transmit the VRF information.
Table 19 Capabilities supported by TTP-termination-MAC flow entries
Item |
Capabilities |
N/A |
· ETH_TYPE—Ethernet type. Value 0x800 indicates Ethernet. · Metadata—VNI. · ETH_DST—Destination MAC address (the MAC address of the local gateway). |
Required actions |
· Write-metadata—Writes VRF index information. Value 0 indicates the public network. · Goto-table—Directs the packet to a table. ¡ If the packet matches the value of the ETH_DST field, the switch directs the packet to table 30 (TTP-unicast-routing flow table) for Layer 3 forwarding. ¡ If the packet does not match the value of the ETH_DST field, the switch directs the packet to table 50 (TTP-bridging flow table) for Layer 2 forwarding. |
Optional actions |
N/A |
Capabilities supported by the TTP-unicast-routing flow table
A TTP-unicast-routing flow entry is used to forward Layer 3 packets.
Table 20 Capabilities supported by TTP-unicast-routing flow entries (for normal IPv4 unicast packets)
Item |
Capabilities |
N/A |
· ETH_TYPE—Ethernet type. Value 0x800 indicates Ethernet. · Metadata—VNI. · IP_DST—Destination IP address. |
Required actions |
The TTP-unicast-routing flow table must support the following actions: · Write-actions—Writes actions in to the action set. ¡ Set L3_Unicast_Group_ID—Specifies actions in a Layer 3 unicast group entry ID. For more information about Layer 3 unicast group entries, see "Capabilities supported by the TTP-L3-unicast-group flow table." ¡ Set L3_ECMP_Group_ID—Specifies actions in a Layer 3 ECMP group entry ID. For more information about Layer 3 ECMP group entries, see "Capabilities supported by the TTP-L3-ECMP-group table." · Set TTL—Decreases the TTL by 1. · Goto-table-60—Directs the packet to table 60 (TTP-ingress-ACL flow table). |
Optional actions |
N/A |
Table 21 Capabilities supported by TTP-unicast-routing flow entries (for IPv4 unicast packets with special destination IP addresses)
Item |
Capabilities |
N/A |
· ETH_TYPE—Ethernet type. Value 0x800 indicates Ethernet. · Metadata—VNI. · IP_DST—Destination IP address (a subnet or an IP address of the switch). |
Required actions |
Controller—Sends the packet to the controller. |
Optional actions |
N/A |
Capabilities supported by the TTP-bridging flow table
A TTP-bridging flow entry is used to forward a Layer 2 packet, determine the type of the output port based on the destination MAC address of the packet, and perform one of the following actions:
· If the output port is a local physical interface, the switch tags or untags the packet before forwarding.
· If the output port is a VXLAN tunnel interface, the switch sets the VNI for the packet and untags the packet before forwarding.
Table 22 Capabilities supported by TTP-bridging flow entries
Item |
Capabilities |
N/A |
· ETH_DST—Destination MAC address. · Metadata—VNI. |
Required actions |
· Write-actions—Writes actions in to the action set by using the Set L2_Interface_Group_ID field. For more information about the action set, see "Capabilities supported by the TTP-L2-interface-group flow table." · Goto-table-60—Directs the packet to table 60 (TTP-ingress-ACL flow table). |
Optional actions |
N/A |
Capabilities supported by the TTP-ingress-ACL flow table
The TTP-ingress-ACL flow entry is used to rate limit, redirect, mirror, or discard matching packets in the inbound direction or send the packets to the controller.
The TTP-ingress-ACL flow table does not contain a table-miss entry and executes all actions in the action set on a packet that does not match any flow entry.
Table 23 Capabilities supported by TTP-ingress-ACL flow entries (for LLDP and ARP packets)
Item |
Capabilities |
N/A |
ETH_TYPE—Ethernet type. |
Required actions |
Optional actions |
N/A |
Table 24 Capabilities supported by TTP-ingress-ACL flow entries (for DHCP packets)
Item |
Capabilities |
N/A |
· ETH_TYPE—Ethernet type. · IP_PROTO—IP protocol type. · UDP_SRC—Source UDP port number. · UDP_DST—Destination UDP port number. |
Required actions |
Optional actions |
N/A |
Table 25 Capabilities supported by TTP-ingress-ACL flow entries (for all packets)
Item |
Capabilities |
N/A |
· In-Port—Input port. · Metadata—VNI or VRF. · IPv4SRC—Source IPv4 address. · IPv4DST—Destination IPv4 address. · IP_PROTO—IP protocol type. · TCP_SRC/UDP_SRC—Source TCP or UDP port number. · TCP_DST/UDP_DST—Destination TCP or UDP port number. |
Required actions |
A TTP-ingress-ACL flow entry must contain one of the following actions: · Write meter-ID—Sets a meter entry for rate limit. · Clear-actions + Output port number—Clears the action set and specifies an output port for packet redirection. · Output port number—Specifies an output port to mirror the packet. · Clear-actions—Clears the action set to discard the packet. |
Optional actions |
N/A |
Capabilities supported by the TTP-egress-ACL flow table
A TTP-egress-ACL flow entry is used to rate limit, mirror, or discard matching packets in the outbound direction.
The TTP-egress-ACL flow table does not contain a table-miss entry and uses the normal forwarding process to forward a packet that does not match any flow entry.
All packets processed by the TTP-ingress-ACL flow table will be directed to the TTP-egress-ACL flow table for processing by default.
Table 26 Capabilities supported by TTP-egress-ACL flow entries
Item |
Capabilities |
N/A |
· Metadata—VNI. · IPv4SRC—Source IPv4 address. · IPv4DST—Destination IPv4 address. · IP_PROTO—IP protocol type. · TCP_SRC/UDP_SRC—Source TCP or UDP port number. · TCP_DST/UDP_DST—Destination TCP or UDP port number. |
Required actions |
A TTP-egress-ACL flow entry must contain one of the following actions: · Write meter-ID—Sets a meter table for rate limit. · Output port number—Specifies an output port to mirror the packet. · Clear-actions—Clears the action set to discard the packet. |
Optional actions |
N/A |
A TTP-L2-interface-group flow entry is used to tag or untag a packet and set the VXLAN ID of the packet.
For a TTP-L2-interface-group flow entry, the group type is indirect and the group entry contains only one action bucket.
Table 27 Capabilities supported by TTP-L2-interface-group flow entries (for VXLAN interfaces)
Item |
Capabilities |
Required actions |
· Set Tunnel_ID—Sets the VNI. · POP VLAN—Untags the packet. Do not execute this action on an untagged packet. · Output-port-number—Sets the output port to the VXLAN tunnel interface. |
Optional actions |
N/A |
Table 28 Capabilities supported by TTP-L2-interface-group flow entries (for untagging physical interfaces)
Item |
Capabilities |
Required actions |
· POP VLAN—Untags the packet. Do not execute this action on an untagged packet. · Output-port-number—Sets the output port. |
Optional actions |
N/A |
Table 29 Capabilities supported by TTP-L2-interface-group flow entries (for tagging physical interfaces)
Item |
Capabilities |
Required actions |
· PUSH VLAN—Tags the packet with a VLAN ID. · POP VLAN—Untags the packet. Do not execute this action on an untagged packet. · Output-port-number—Sets the output port. |
Optional actions |
N/A |
A TTP-L3-unicast-group flow table is used to perform the following actions on a packet:
· Set the destination MAC address and source MAC address.
· Specify a TTP-L2-interface-group entry.
In a TTP-L3-unicast-group flow entry, the group type is indirect and the group entry contains only one action bucket.
Table 30 Capabilities supported by TTP-L3-unicast-group flow entries
Item |
Capabilities |
Required actions |
· Set ETH_DST—Sets the destination MAC address. · Set ETH_SRC—Sets the source MAC address. · Set L2_Interface_Group_ID—Specifies a TTP-L2-interface-group flow table. |
Optional actions |
N/A |
A TTP-L3-ECMP-group table is used to direct a packet to multiple TTP-L3-unicast-group entries for processing.
For a TTP-L3-ECMP-group entry, the group type is select, and the group entry contains multiple action buckets.
Table 31 Capabilities supported by TTP-L3-ECMP-group flow entries
Item |
Capabilities |
Required actions |
· Bucket 1:{Set L3_Unicast_Group_ID} · Bucket 2:{Set L3_Unicast_Group_ID} · … · Bucket n:{Set L3_Unicast_Group_ID} |
Optional actions |
N/A |
