- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-GIR configuration
- 10-Emergency shell configuration
- 11-Automatic configuration
- 12-Preprovisioning feature configuration
- 13-Device management configuration
- 14-Tcl configuration
- 15-Python configuration
- 16-License management
15-Python configuration | 97.08 KB |
Importing and using the extended Python API
Importing the entire extended API and using the API
Importing an extended API function and using the function
Example: Using a Python script for device configuration
Using Python
About Python
Comware 7 provides a built-in Python interpreter. You can use Python to perform the following tasks:
· Execute Python scripts to implement automatic device configuration.
· Enter Python shell to configure the device by using the following items:
¡ Python 2.7 commands.
¡ Python 2.7 standard API.
¡ Extended API. For more information about the extended API, see "Comware 7 extended Python API."
Executing a Python script
To execute a Python script, use the following command in user view:
python filename
Entering the Python shell
To enter the Python shell from user view, execute the following command:
python
To use the extended Python API, you must first import the API to Python.
1. Enter the Python shell from user view.
python
2. Import the entire extended API.
import platformtools
3. Execute an extended API function.
platformtools.api
Example
# Use extended API function Transfer to download the test.cfg file from TFTP server 192.168.1.26.
<Sysname> python
Python 2.7.18 (default)
[GCC 4.4.1] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> platformtools.Transfer('tftp', '192.168.1.26', 'test.cfg', 'flash:/test.cfg', user='', password='')
<platformtools.Transfer object at 0xb7eab0e0>
python
2. Import an extended API function.
from platformtools import api-name
api-function
Example
<Sysname> python
>>> from platformtools import Transfer
<platformtools.Transfer object at 0xb7e5e0e0>
Exiting the Python shell
To exit the Python shell, execute the following command in the Python shell.
exit()
Python usage examples
Use a Python script to perform the following tasks:
· Download configuration files main.cfg and backup.cfg to the device.
· Configure the files as the main and backup configuration files for the next startup.
Figure 1 Network diagram
# Use a text editor on the PC to configure Python script test.py as follows:
#!usr/bin/python
platformtools.Transfer('tftp', '192.168.1.26', 'main.cfg', 'flash:/main.cfg')
platformtools.Transfer('tftp', '192.168.1.26', 'backup.cfg', 'flash:/backup.cfg')
platformtools.CLI('startup saved-configuration flash:/main.cfg main ;startup saved-configuration flash:/backup.cfg backup')
# Use TFTP to download the script to the device.
<Sysname> tftp 192.168.1.26 get test.py
# Execute the script.
<Sysname> python flash:/test.py
<Sysname>startup saved-configuration flash:/main.cfg main
Please wait...... Done.
<Sysname>startup saved-configuration flash:/backup.cfg backup
# Display startup configuration files.
<Sysname> display startup
Current startup saved-configuration file: flash:/startup.cfg
Next main startup saved-configuration file: flash:/main.cfg
Next backup startup saved-configuration file: flash:/backup.cfg
The Comware 7 extended Python API is compatible with the Python syntax.
channel
Use channel to execute Comware 7 CLI commands and create channel objects.
channel(command=‘’)
command: Specifies the commands to be executed. To enter multiple commands, use a space and a semicolon (;) as the delimiter. To enter a command in a view other than user view, you must first enter the commands used to enter the view. For example, you must enter ’system-view ;display interface brief | include UP’ to execute the display interface brief | include UP command.
This API function supports only Comware 7 commands. It does not support Linux, Python, or Tcl commands.
The API function is used for automated testing.
The list objects returned by the channel function might contain hexadecimal hidden characters such as 0x08. To hide the hexadecimal hidden characters, you can use the CLI function instead, or use the for loop to output the execution result of the channel function, for example:
<Sysname> python
>>> c = platformtools.channel('display vlan')
>>> for value in c:
... print value
display vlan
Total VLANs: 13
The VLANs include:
1(default), 2-3, 10, 20, 30, 40, 100-101, 200-202, 300
<Sysname>
Returns
Output from the executed commands, in the format of a list object.
# Display the VLAN inforamtion.
<Sysname> python
Sample output
['display vlan', ' Total VLANs: 13', ' The VLANs include:', ' 1(default), 2-3, 10, 2
0, 30, 40, 100-101, 200-202, 300, \x08\x08 ', '<Sysname>']
CLI
Use CLI to execute Comware 7 CLI commands and create CLI objects.
CLI(command=‘’, do_print=True)
command: Specifies the commands to be executed. To enter multiple commands, use a space and a semicolon (;) as the delimiter. To enter a command in a view other than user view, you must first enter the commands used to enter the view. For example, you must enter ’system-view ;local-user test class manage’ to execute the local-user test class manage command.
do_print: Specifies whether to output the execution result:
· True—Outputs the execution result. This value is the default.
· False—Does not output the execution result.
Returns
CLI objects
# Add a local user named test.
<Sysname> python
>>> platformtools.CLI('system-view ;local-user test class manage')
Sample output
New local user added.
<platformtools.CLI object at 0xb7f680a0>
get_error
Use get_error to get the error information from the download operation.
Transfer.get_error()
Returns
Error information (if there is no error information, the return is null)
# Download file test.cfg from TFTP server 1.1.1.1 and get the error information from the operation.
<Sysname> python
>>> c = platformtools.Transfer('tftp', '1.1.1.1', 'test.cfg', 'flash:/test.cfg', user='', password='')
>>> c.get_error()
Sample output
'Timeout was reached'
get_output
Use get_output to get the output from executed commands.
CLI.get_output()
Returns
Output from executed commands
# Add a local user and get the output from the command.
<Sysname> python
>>> c = platformtools.CLI('system-view ;local-user test class manage', False)
>>> c.get_output()
Sample output
['<Sysname>system-view', 'System View: return to User View with Ctrl+Z.', '[Sysname]local-user test class manage', 'New local user added.']
get_self_slot
Use get_self_slot to get the member ID of the master device.
get_self_slot()
Returns
A list object in the format of [-1,slot-number]. The slot-number indicates the member ID of the master device.
# Get the member ID of the master device.
<Sysname> python
>>> platformtools.get_self_slot()
Sample output
[-1,0]
get_slot_info
Use get_slot_info to get information about a member device.
get_slot_info()
Returns
A dictionary object in the format of {'Slot': slot-number, 'Status': 'status', 'Chassis': chassis-number, 'Role': 'role', 'Cpu': CPU-number }. The slot-number argument indicates the member ID of the device. The status argument indicates the status of the member device. The chassis-number and CPU-number arguments are fixed at 0. The role argument indicates the role of the member device.
# Get information about the device, a card, or a member device.
<Sysname> python
>>> platformtools.get_slot_info(1)
Sample output
{'Slot': 1, 'Status': 'Normal', 'Chassis': 0, 'Role': 'Master', 'Cpu': 0}
get_slot_range
Use get_slot_range to get the supported IRF member ID range.
get_slot_range()
Returns
A dictionary object in the format of {'MaxSlot': max-slot-number, 'MinSlot': min-slot-number }. The max-slot-number argument indicates the maximum member ID. The min-slot-number argument indicates the minimum member ID.
# Get the supported IRF member ID range.
<Sysname> python
>>> platformtools.get_slot_range()
Sample output
{'MaxSlot': 129, 'MinSlot': 1}
get_standby_slot
Use get_standby_slot to get the member IDs of the subordinate devices.
get_standby_slot()
Returns
A list object in one of the following formats:
· [ ]—The IRF fabric does not have a subordinate device.
· [[-1,slot-number]]—The IRF fabric has only one subordinate device.
· [[-1,slot-number1],[-1,slot-number2],...]—The IRF fabric has multiple subordinate devices.
The slot-number arguments indicate the member IDs of the subordinate devices.
# Get the member IDs of the subordinate devices.
<Sysname> python
>>> platformtools.get_standby_slot()
Sample output
[[-1, 1], [-1, 2]]
Transfer
Use Transfer to download a file from a server.
Transfer(protocol=‘’, host=‘’, source=‘’, dest=‘’, vrf=‘’,login_timeout=10, user=‘’, password=‘’)
protocol: Specifies the protocol used to download a file:
· ftp—Uses FTP.
· tftp—Uses TFTP.
· http—Uses HTTP.
host: Specifies the IP address of the remote server.
source: Specifies the name of the file to be downloaded from the remote server.
dest: Specifies a name for the downloaded file.
vrf: Specifies the VPN instance to which the remote server belongs. This argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the server belongs to the public network, do not specify this argument.
login_timeout: Specifies the timeout for the operation, in seconds. The default is 10.
user: Specifies the username for logging in to the server.
password: Specifies the login password.
Returns
Transfer object
If the IP address of the server is an IPv6 address, enclose the IP address with brackets ([]). For example:
Transfer("ftp","[2200::22]","0729.cfg","flash:/0729.cfg",user="abc",password="123456")
# Download file test.cfg from TFTP server 192.168.1.26.
<Sysname> python
Sample output
<platformtools.Transfer object at 0xb7f700e0>
send
Use send to generate and send a log message.
SYSLOG.send(digest=‘’, info=‘’, priority=‘’)
digest: Specifies a mnemonic for the log message. The mnemonic is a case-sensitive string of 1 to 32 characters.
info: Specifies the contents for the log message, a case-sensitive string of 1 to 1024 characters.
priority: Specifies a priority for the log message, in the range of 0 to 4294967295.
You must use the SYSLOG function to create a syslog object before you can generate and send a log message for the object.
For more information about the log message format, see information center configuration in Network Management and Monitoring Configuration Guide.
To enable the current terminal to display the generated log messages, first execute the terminal monitor command in user view.
Returns
None.
# Enable the current terminal to display log messages, and then generate and send a log message for SNMP. Set the mnemonic to Test, the contents to Try to send one message., and the priority to 1000.
<Sysname> terminal monitor
<Sysname> python
>>> a = platformtools.SYSLOG('snmp')
>>> a.send('Test','Try to send one message.',1000)
Sample output
>>> %Jan 1 06:24:17:908 2019 Sysname SNMP/0/Test: Try to send one message.
SYSLOG
Use SYSLOG to create a syslog object.
SYSLOG(module=‘’)
module: Specifies a name for the syslog object. The name is a case-insensitive string of 1 to 8 characters.
You must create a syslog object before you can send a log message for the object.
Returns
None.
# Create a syslog object named SNMP and assign the object to variable a.
<Sysname> python
>>> a
Sample output
<platformtools.SYSLOG object at 0xb7e180e0>
