03-Data buffer configuration | 48.21 KB |
Configuring data buffers
Enabling the Burst feature
The Burst feature enables the device to automatically allocate cell and packet resources. It is well suited to the following scenarios:
· Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
· Traffic comes in and goes out in one of the following ways:
¡ Enters a device from a high-speed interface and goes out of a low-speed interface.
¡ Enters from multiple same-rate interfaces at the same time and goes out of an interface with the same rate.
1. Enter system view.
2. Enable the Burst feature.
burst-mode enable
By default, the Burst feature is disabled.
Display and maintenance commands for data buffers
Task |
Command |
Display data buffer usage. |
display buffer usage [ slot slot-number ] |
