06-IP Multicast Command Reference
HomeSupportResource CenterSwitchesS5170 SeriesS5170-EI SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C S5170-EI Command References-R11xx-6W10106-IP Multicast Command Reference
06-IPv6 multicast VLAN commands
06-IPv6 multicast VLAN commands 84.48 KB
display ipv6 multicast-vlan
Use display ipv6 multicast-vlan to display information about IPv6 multicast VLANs.
display ipv6 multicast-vlan [ vlan-id ]
vlan-id: Specifies an IPv6 multicast VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify an IPv6 multicast VLAN, this command displays information about all IPv6 multicast VLANs.
# Display information about all IPv6 multicast VLANs.
<Sysname> display ipv6 multicast-vlan
Total 2 IPv6 multicast VLANs.
IPv6 multicast VLAN 100:
  Sub-VLAN list(3 in total):
    2-3, 6
  Port list(3 in total):
    GE1/0/1
    GE1/0/2
    GE1/0/3
IPv6 multicast VLAN 200:
  Sub-VLAN list(0 in total):
  Port list(0 in total):
Total number of IPv6 multicast VLANs.
Sub-VLAN list of the IPv6 multicast VLAN, and the total number of the sub-VLANs.
Port list of the IPv6 multicast VLAN, and the total number of the ports.
display ipv6 multicast-vlan forwarding-table
Use display ipv6 multicast-vlan forwarding-table to display IPv6 multicast VLAN forwarding entries.
display ipv6 multicast-vlan forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | slot slot-number | subvlan vlan-id | vlan vlan-id ] *
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command displays IPv6 multicast VLAN forwarding entries for all IPv6 multicast sources.
prefix-length: Specifies a prefix length of the IPv6 multicast source address. The value range is 0 to 128 and the default value is 128.
ipv6-group-address: Specifies an IPv6 multicast group address. The value range for this argument is FFxy::/16, where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays IPv6 multicast VLAN forwarding entries for all IPv6 multicast groups.
prefix-length: Specifies a prefix length of the IPv6 multicast group address. The value range is 8 to 128 and the default value is 128.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 multicast VLAN forwarding entries for the master device.
subvlan vlan-id: Specifies a sub-VLAN by its VLAN ID. If you do not specify a sub-VLAN, this command displays IPv6 multicast VLAN forwarding entries for all sub-VLANs.
vlan vlan-id: Specifies an IPv6 multicast VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify an IPv6 multicast VLAN, this command displays IPv6 multicast VLAN forwarding entries for all VLANs.
# Display all IPv6 multicast VLAN forwarding entries.
<Sysname> display ipv6 multicast-vlan forwarding-table
IPv6 multicast VLAN 100 Forwarding Table
Total 1 entries, 1 matched
00001. (1::1, FF0E::1)
     Flags: 0x10000
     IPv6 multicast VLAN: 100
     List of sub-VLANs (3 in total):
       1: VLAN 10
       2: VLAN 20
       3: VLAN 30
The multicast forwarding table for IPv6 multicast VLAN 100.
Total number of (S, G) entries, and the number of matching entries.
00001
Sequence number of the (S, G) entry.
(1::1, FF0E::1)
(S, G) entry, where a double colon (::) in the S position means all IPv6 multicast sources.
Flags
Entry flag.
This field displays one flag or the sum of multiple flags. In this example, the value 0x10000 means that the entry has only one flag 0x10000.
The following flags are available for an entry:
·     0x1—The entry is in inactive state.
·     0x4—The entry fails to update.
·     0x8—The sub-VLAN information fails to update for the entry.
·     0x200—The entry is in GR state.
·     0x10000—The entry is an IPv6 multicast VLAN forwarding entry.
display ipv6 multicast-vlan group
Use display ipv6 multicast-vlan group to display information about IPv6 multicast groups in IPv6 multicast VLANs.
display ipv6 multicast-vlan group [ ipv6-source-address | ipv6-group-address | slot slot-number | verbose | vlan vlan-id ] *
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command displays information about IPv6 multicast groups for all IPv6 multicast sources in IPv6 multicast VLANs.
ipv6-group-address: Specifies an IPv6 multicast group address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays information about all IPv6 multicast groups in IPv6 multicast VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about IPv6 multicast groups in IPv6 multicast VLANs for the master device.
verbose: Displays detailed information. If you do not specify the keyword, this command displays brief information.
vlan vlan-id: Specifies an IPv6 multicast VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify an IPv6 multicast VLAN, this command displays information about IPv6 multicast groups for all IPv6 multicast VLANs.
# Display detailed information about all IPv6 multicast groups in IPv6 multicast VLANs.
<Sysname> display ipv6 multicast-vlan group verbose
Total 6 entries.
IPv6 multicast VLAN 10: Total 3 entries.
  (2::2, FF0E::2)
    Flags: 0x70000020
    Sub-VLANs (1 in total):
      VLAN 40
  (22::22, FF0E::4)
    Flags: 0x70000030
      VLAN 40
  (::, FF0E::10)
    Flags: 0x10000030
      VLAN 40
IPv6 multicast VLAN 20: Total 3 entries.
  (2::2, FF0E::2)
    Flags: 0x70000010
    Sub-VLANs (0 in total):
  (22::22, FF0E::4)
    Flags: 0x70000010
  (::, FF0E::10)
    Flags: 0x50000010
Total 6 entries
Total number of (S, G) entries.
Total number of (S, G) entries in IPv6 multicast VLAN 10.
(::, FF0E::10)
Flags
Entry flag.
This field displays one flag or the sum of multiple flags. For example, the value 0x70000020 means that the entry has flags 0x20, 0x10000000, 0x20000000, and 0x40000000.
·     0x10—The entry is created by the IPv6 multicast VLAN.
·     0x20—The entry is created by the sub-VLAN of the IPv6 multicast VLAN.
·     0x40—The entry is to be deleted.
·     0x10000000—This value represents one of the following situations:
¡     The entry is newly created.
¡     The device receives an MLD query within an MLD general query interval.
·     0x20000000—The device does not receive MLDv1 or MLDv2 reports that match the entry within an MLD general query interval.
·     0x40000000—The device does not receive MLDv2 IS_EX (NULL) reports that match the entry within an MLD general query interval.
reset ipv6 multicast-vlan group
ipv6 multicast-vlan
Use ipv6 multicast-vlan to configure an IPv6 multicast VLAN and enter its view, or enter the view of an existing IPv6 multicast VLAN.
Use undo ipv6 multicast-vlan to remove the configuration of IPv6 multicast VLANs.
ipv6 multicast-vlan vlan-id
undo ipv6 multicast-vlan { all | vlan-id }
No IPv6 multicast VLANs exist.
vlan-id: Specifies an existing VLAN ID in the range of 1 to 4094.
all: Specifies all IPv6 multicast VLANs.
The total number of IPv6 multicast VLANs on a device cannot exceed the system upper limit.
You must enable MLD snooping for the VLAN to be configured as an IPv6 multicast VLAN.
As a best practice, do not configure an IPv6 multicast VLAN on a device that is enabled with IPv6 multicast routing.
# Enable MLD snooping for VLAN 100. Configure VLAN 100 as an IPv6 multicast VLAN and enter its view.
[Sysname] mld-snooping
[Sysname-mld-snooping] quit
[Sysname] vlan 100
[Sysname-vlan100] mld-snooping enable
[Sysname-vlan100] quit
[Sysname] ipv6 multicast-vlan 100
[Sysname-ipv6-mvlan-100]
ipv6 multicast routing
mld-snooping enable
ipv6 multicast-vlan entry-limit
Use ipv6 multicast-vlan entry-limit to set the maximum number of IPv6 multicast VLAN forwarding entries.
Use undo ipv6 multicast-vlan entry-limit to restore the default.
ipv6 multicast-vlan entry-limit limit
The maximum number of IPv6 multicast VLAN forwarding entries is 120.
limit: Specifies the maximum number of IPv6 multicast VLAN forwarding entries. The value range for this argument is 0 to 120.
If the configured value is smaller than the current number of IPv6 multicast VLAN forwarding entries, the device cannot create new entries until some entries age out or are manually removed. To allow new entries to be created immediately, use the reset ipv6 multicast-vlan group command to remove IPv6 multicast VLAN forwarding entries.
# Set the maximum number of IPv6 multicast VLAN forwarding entries to 120.
[Sysname] ipv6 multicast-vlan entry-limit 120
entry-limit (MLD-snooping view)
ipv6 port multicast-vlan
Use ipv6 port multicast-vlan to assign a user port to an IPv6 multicast VLAN.
Use undo ipv6 port multicast-vlan to restore the default.
ipv6 port multicast-vlan vlan-id
A port does not belong to an IPv6 multicast VLAN.
You can assign a port to only one IPv6 multicast VLAN.
For the port to be assigned to an IPv6 multicast VLAN, you must enable MLD snooping for the VLAN to which the port belongs.
# Assign GigabitEthernet 1/0/1 to IPv6 multicast VLAN 100.
[Sysname-GigabitEthernet1/0/1] ipv6 port multicast-vlan 100
port (IPv6 multicast VLAN view)
Use port to assign user ports to an IPv6 multicast VLAN.
Use undo port to delete user ports from an IPv6 multicast VLAN.
port interface-list
undo port { all | interface-list }
An IPv6 multicast VLAN does not have user ports.
interface-list: Specifies a port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number to interface-type interface-number.
all: Specifies all user ports in the current IPv6 multicast VLAN.
You can assign only Layer 2 Ethernet interfaces or Layer 2 aggregate interfaces as user ports to an IPv6 multicast VLAN. Additionally, you can assign a port to only one IPv6 multicast VLAN.
For ports to be assigned to an IPv6 multicast VLAN, you must enable MLD snooping for the VLANs to which the ports belong.
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/5 as user ports to IPv6 multicast VLAN 100.
[Sysname-ipv6-mvlan-100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/5
Use reset ipv6 multicast-vlan group to clear IPv6 multicast group entries in IPv6 multicast VLANs.
reset ipv6 multicast-vlan group [ ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] | vlan vlan-id ] *
ipv6-group-address: Specifies an IPv6 multicast group address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command clears all IPv6 multicast group entries in IPv6 multicast VLANs.
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command clears IPv6 multicast group entries for all IPv6 multicast sources in IPv6 multicast VLANs.
vlan vlan-id: Specifies an IPv6 multicast VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify an IPv6 multicast VLAN, this command clears IPv6 multicast group entries for all IPv6 multicast VLANs.
# Clear all IPv6 multicast group entries for all IPv6 multicast VLANs.
<Sysname> reset ipv6 multicast-vlan group
subvlan (IPv6 multicast VLAN view)
Use subvlan to assign VLANs as sub-VLANs to an IPv6 multicast VLAN.
Use undo subvlan to delete sub-VLANs from an IPv6 multicast VLAN.
subvlan vlan-list
undo subvlan { all | vlan-list }
An IPv6 multicast VLAN does not have sub-VLANs.
vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The value range for the VLAN ID is 1 to 4094. The specified VLANs must exist and cannot be multicast VLANs or sub-VLANs of other IPv6 multicast VLANs.
all: Specifies all sub-VLANs of the current IPv6 multicast VLAN.
You must enable MLD snooping for VLANs to be configured as sub-VLANs of an IPv6 multicast VLAN.
# Assign VLAN 10 through VLAN 15 as sub-VLANs to multicast VLAN 100.
[Sysname-ipv6-mvlan-100] subvlan 10 to 15
  • Become a Partner
  • Partner Resources
