00-Preface | 26.34 KB |
Preface
This installation guide describes the procedures for installing, accessing, registering, and upgrading a super controller.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with H3C super controllers.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
