- 03-Layer 2-LAN Switching Configuration Guide
- 01-Ethernet interface configuration
- 02-Loopback, null, and inloopback interface configuration
- 03-Bulk interface configuration
- 04-MAC address table configuration
- 05-Ethernet link aggregation configuration
- 06-Port isolation configuration
- 07-Spanning tree configuration
- 08-Loop detection configuration
- 09-VLAN configuration
- 10-MVRP configuration
- 11-VLAN mapping configuration
- 12-LLDP configuration
- 13-Service loopback group configuration
- 14-Cut-through forwarding configuration
- 15-DRNI configuration
14-Cut-through forwarding configuration | 34.06 KB |
Configuring cut-through forwarding
About cut-through forwarding
A cut-through forwarding-enabled device uses only the chip register to store frames to be forwarded when congestion occurs on frame forwarding. This feature increases the forwarding rate and reduces the delay.
Feature and hardware compatibility
This feature is available only on the S12500X-AF H card series.
1. Enter system view.
2. Enable cut-through forwarding.
cut-through enable
By default, cut-through forwarding is disabled.
