11-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S12500X-AF & S12500-X & S9800 Switch Series Command References(R27xx)-6W10511-Network Management and Monitoring Command Reference
17-GOLD commands
17-GOLD commands 123.64 KB
GOLD commands
diagnostic bootup enable test
Use diagnostic bootup enable test to enable the device to execute a boot-up diagnostic test at the next startup.
Use undo diagnostic bootup enable test to disable a boot-up diagnostic test.
In standalone mode:
diagnostic bootup enable slot slot-number-list test test-name [ para parameters ]
undo diagnostic bootup enable slot slot-number-list test test-name [ para parameters ]
In IRF mode:
diagnostic bootup enable chassis chassis-number slot slot-number-list test test-name [ para parameters ]
undo diagnostic bootup enable chassis chassis-number slot slot-number-list test test-name [ para parameters ]
The system does not run boot-up diagnostic tests during startup.
chassis chassis-number: Specifies an IRF member device by its member ID. (In IRF mode.)
slot slot-number-list: Specifies a space-separated list of up to seven slot number items. An item specifies a card by its slot number or specifies a range of cards in the form of start-slot-number to end-slot-number. The end slot number must be equal to or greater than the start slot number.
test test-name: Specifies a test by its name, a case-sensitive character string. You can use the test ? command to verify the value range of the test name.
para parameters: Specifies a diagnostic test execution parameter, a case-insensitive string of 1 to 511 characters. The value, input method, and default of the parameter vary by test.
This command takes effect at the next startup.
# (In standalone mode.) Enable the device to run test OnlyBootUp configured on the specified slot at the next startup and specify 123 as the parameter.
[Sysname] diagnostic bootup enable slot 1 test OnlyBootUp para 123
display diagnostic bootup
diagnostic event-log size
Use diagnostic event-log size to configure the maximum number of GOLD log entries.
Use undo diagnostic event-log size to restore the default.
diagnostic event-log size number
GOLD can save up to 512 log entries.
number: Specifies the maximum number of log entries, in the range of 0 to 1024.
If you specify a number smaller than the number of existing log entries, the system automatically deletes the oldest excess entries.
When the number of GOLD log entries exceeds the configured log buffer size, the system automatically deletes the oldest excess entries.
# Set the maximum number of log entries to 600.
[Sysname] diagnostic event-log size 600
diagnostic monitor enable
Use diagnostic monitor enable to enable monitoring diagnostics.
Use undo diagnostic monitor enable to disable monitoring diagnostics.
In standalone mode:
diagnostic monitor enable slot slot-number-list [ test test-name ]
undo diagnostic monitor enable slot slot-number-list [ test test-name ]
In IRF mode:
diagnostic monitor enable chassis chassis-number slot slot-number-list [ test test-name ]
undo diagnostic monitor enable chassis chassis-number slot slot-number-list [ test test-name ]
Monitoring diagnostics are enabled.
test test-name: Specifies a test by its name, a case-sensitive character string. You can use the test ? command to verify the value range of the test name. If you do not specify this option, the command enables all monitoring diagnostic tests.
Monitoring diagnostics enable the system to periodically run diagnostic tests to detect hardware faults and record test results. Monitoring diagnostics execute only non-disruptive tests.
Disruptive diagnostic tests that are being executed affect device operation or even disable certain functions, but non-disruptive diagnostic tests do not.
The system automatically executes enabled monitoring diagnostic tests after the device starts. Use the diagnostic monitor enable command to enable diagnostic tests that are disabled by default.
# (In standalone mode.) Enable test BoardStatusMonitor on the specified slot.
[Sysname] diagnostic monitor enable slot 1 test BoardStatusMonitor
diagnostic monitor interval
Use diagnostic monitor interval to configure an execution interval for monitoring diagnostic tests.
Use undo diagnostic monitor interval to restore the default.
In standalone mode:
diagnostic monitor interval slot slot-number-list [ test test-name ] time interval
undo diagnostic monitor interval slot slot-number-list [ test test-name ]
In IRF mode:
diagnostic monitor interval chassis chassis-number slot slot-number-list [ test test-name ] time interval
undo diagnostic monitor interval chassis chassis-number slot slot-number-list [ test test-name ]
The execution interval varies by monitoring diagnostic test. To display the execution interval of a monitoring diagnostic test, execut the display diagnostic content command.
test test-name: Specifies a test by its name, a case-sensitive character string. You can use the test ? command to verify the value range of the test name. If you do not specify this option, the command applies to all monitoring diagnostic tests.
interval: Sets an execution interval in the form of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is both 0 to 59. If you specify only the hh argument, you can omit the mm and ss segments. If you specify only the hh and mm arguments, you can omit the ss segment. For example, to specify 01:00:00, you can enter 1.
Use this command to configure the interval at which the system automatically executes enabled monitoring diagnostic tests.
The configured interval cannot be smaller than the minimum execution interval of the tests. Use the display diagnostic content verbose command to view the minimum execution interval of the tests.
# (In standalone mode.) Set the execution interval to 1 minute for test BoardStatusMonitor on the specified slot.
<Sysname> system-view.
[Sysname] diagnostic monitor interval slot 1 test BoardStatusMonitor time 00:01:00
diagnostic ondemand failure
Use diagnostic ondemand failure to set the maximum number of failed on-demand diagnostic tests.
Use undo diagnostic ondemand failure to restore the default.
diagnostic ondemand failure failure-number
The maximum number of failed on-demand diagnostic tests is not specified.
failure-number: Specifies the maximum number of failed tests, in the range of 1 to 999.
After you use the diagnostic ondemand start command to enable on-demand diagnostics, you can stop the diagnostic tests by using any of the following commands:
·     Use the diagnostic ondemand stop command to immediately stop the tests.
·     Use the diagnostic ondemand repeating command to configure the number of executions for the tests. The system stops executing the tests when the threshold is reached.
·     Use the diagnostic ondemand failure command to configure the maximum number of failed tests. The system stops a test when the number of failures reaches the configured threshold and the test is not executed as many times as specified.
Use this command to configure the maximum number of failed tests for diagnostic tests to be enabled. This command does not survive a device reboot.
# Set the maximum number of failed tests to 5 for all on-demand diagnostic tests.
<Sysname> diagnostic ondemand failure 5
display diagnostic ondemand configuration
Use diagnostic ondemand repeating to configure the number of executions for on-demand diagnostic tests.
Use undo diagnostic ondemand repeating to restore the default.
diagnostic ondemand repeating repeating-number
The default number of executions is 1.
repeating-number: Specifies the number of executions for on-demand diagnostic tests, in the range of 1 to 999.
Use this command to configure the number of executions for diagnostic tests to be enabled. This command does not survive a device reboot.
Do not specify a number smaller than the number of failed tests configured by using the diagnostic ondemand failure command.
# Set the number of executions to 2 for all on-demand diagnostic tests.
<Sysname> diagnostic ondemand repeating 2
display diagnostic configuration
Use diagnostic ondemand start to enable on-demand diagnostics.
In standalone mode:
diagnostic ondemand start slot slot-number-list test { test-name | non-disruptive } [ para parameters ]
In IRF mode:
diagnostic ondemand start chassis chassis-number slot slot-number-list test { test-name | non-disruptive } [ para parameters ]
All on-demand diagnostic tests need to be manually enabled.
non-disruptive: Executes all non-disruptive diagnostic tests.
para parameters: Specifies an extended parameter. The current software version does not support this option.
On-demand diagnostics allow you to manually execute certain diagnostic tests. These tests are known as on-demand diagnostic tests.
You can configure the number of executions and the maximum number of failed tests for on-demand diagnostic tests at the CLI. When either threshold is reached, the system immediately stops executing the tests.
# (In standalone mode.) Start disruptive diagnostic test PRBS on the specified slot.
<Sysname> diagnostic ondemand start slot 1 test PRBS
Running test PRBS on slot 1 may disrupt system operation. Continue? [Y/N]:y
# (In standalone mode.) Start all non-disruptive diagnostic tests on the specified slot.
<Sysname> diagnostic ondemand start slot 1 test non-disruptive
Use diagnostic ondemand stop to stop on-demand diagnostic tests.
In standalone mode:
diagnostic ondemand stop slot slot-number-list test { test-name | non-disruptive }
In IRF mode:
diagnostic ondemand stop chassis chassis-number slot slot-number-list test { test-name | non-disruptive }
non-disruptive: Stops all non-disruptive diagnostic tests.
You can configure the number of executions and the maximum number of failed tests for on-demand diagnostic tests at the CLI. When either threshold is reached, the system immediately stops executing the tests. You can also use this command to manually stop on-demand diagnostic tests.
# (In standalone mode.) Stop all non-disruptive diagnostic tests on the specified slot.
<Sysname> diagnostic ondemand stop slot 1 test non-disruptive
diagnostic simulation
Use diagnostic simulation to simulate diagnostic tests.
Use undo diagnostic simulation to restore the default.
In standalone mode:
diagnostic simulation slot slot-number-list test test-name { failure | random-failure | success }
undo diagnostic simulation slot slot-number-list test test-name
In IRF mode:
diagnostic simulation chassis chassis-number slot slot-number-list test test-name { failure | random-failure | success }
undo diagnostic simulation chassis chassis-number slot slot-number-list test test-name
All diagnostic tests are executed instead of simulated.
failure: Configures the system to generate failure results.
random-failure: Configures the system to randomly generate results.
success: Configures the system to generate success results.
Test simulation is used to verify GOLD frame functionality. After you execute this command, the system simulates the specified test if the execution requirements for the test are met. The test is not actually executed and does not trigger hardware correcting actions.
This command only applies to monitoring diagnostic tests and on-demand diagnostic tests.
# (In standalone mode.) Simulate test BoardStatusMonitor as failed on the specified slot.
<Sysname> diagnostic simulation slot 1 test BoardStatusMonitor failure
display diagnostic simulation
diagnostic start test
Use diagnostic start test to start script-bound diagnostics.
diagnostic start test test-name
test-name: Specifies a script-bound test by its name, a case-insensitive string of 1 to 31 characters. You can use the diagnostic start test ? command to verify available test names.
The device is configured with tests that are bound with scripts before the device is shipped. The system supports TCL scripts, such as scripts for verifying chip and port basic information after the device is powered on. After you use this command to start a test, the system automatically runs the scripts and displays the results at the CLI.
# Start script-bound test EquipSelfCheck.
<Sysname> diagnostic start test EquipSelfCheck
This command requires null configuration and reboot device afterwards. Continue?
[Y/N]:y
  ===============display clock===================
10:55:19.115 UTC Fri 06/27/2017
  ===============system-view=====================
  ===============undo stp enable=====================
  ===============probe-view=====================
  ===========undo monitor inner-channel=================
Use display diagnostic bootup to display boot-up diagnostic test information.
In standalone mode:
display diagnostic bootup [ slot slot-number [ test test-name ] ]
In IRF mode:
display diagnostic bootup [ chassis chassis-number [ slot slot-number [ test test-name ] ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command applies to all cards. (In standalone mode.)
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command applies to all member devices. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command applies to all cards. (In IRF mode.)
test test-name: Specifies a test by its name, a case-sensitive character string. You can use the test ? command to verify the value range of the test name. If you do not specify this option, the command displays information for all tests.
# (In standalone mode.) Display information about test OnlyBootUp on the specified slot.
<Sysname> display diagnostic bootup slot 1
slot 0:
  Test name                : OnlyBootUp
  ExtPara                  : 123
  State                    : Enabled
Use display diagnostic content to display information about diagnostic tests.
In standalone mode:
display diagnostic content [ slot slot-number ] [ verbose ]
In IRF mode:
display diagnostic content [ chassis chassis-number [ slot slot-number ] ] [ verbose ]
verbose: Displays detailed information about diagnostic tests. If you do not specify this keyword, the command displays brief information about the diagnostic tests.
# (In standalone mode.) Display brief information about all diagnostic tests on the specified slot.
<Sysname> display diagnostic content slot 1
Diagnostic test suite attributes:
#B/*: Bootup test/NA
#O/*: Ondemand test/NA
#M/*: Monitoring test/NA
#D/*: Disruptive test/Non-disruptive test
#P/*: Per port test/NA
#A/I/*: Monitoring test is active/Monitoring test is inactive/NA
Slot 1:
Name                            Attributes             Interval
IPCMonitor                      **M*PA                 00:01:00
BoardStatusMonitor              **M*PA                 01:00:00
TaskMonitor                     **M*PA                 00:00:10
PortMonitor                     **M*PA                 00:00:10
ComponentMonitor                **M*PA                 00:00:30
# (In standalone mode.) Display detailed information about all diagnostic tests on the specified slot.
<Sysname> display diagnostic content slot 1 verbose
Slot 1:
Test name        : IPCMonitor
Test attributes  : **M*PA
Test interval    : 00:01:00
Min interval     : 00:01:00
Correct-action   : -NA-
Description      : A Real-time test, enabled by default that checks ipc between
switch units.
Exec             : -NA-
Test name        : BoardStatusMonitor
Test interval    : 01:00:00
Min interval     : 00:00:06
Description      : A Real-time test, enabled by default that checks board status
 between local master and other local boards.
Exec             : -NA-
Test name        : TaskMonitor
Test interval    : 00:00:10
Min interval     : 00:00:10
Description      : A Real-time test, enabled by default that checks the important
tasks.
Exec             : -NA-
Test name        : PortMonitor
Description      : A Real-time test, enabled by default that checks port status
for each inner port.
Exec             : -NA-
Test name        : ComponentMonitor
Test interval    : 00:00:30
Description      : A Real-time test, enabled by default that checks component status.
Exec             : -NA-
B/*
Boot-up/Not boot-up.
O/*
On-demand/Not on-demand.
M/*
Monitoring/Not monitoring.
D/*
Disruptive/Non-disruptive.
P/*
Port-related/Not port-related.
A/I/*
Active and monitoring/Inactive and monitoring/Not monitoring.
Test name
Name of the diagnostic test.
Test attributes
Attributes of the diagnostic test. The characters from left to right indicate whether or not the test is boot-up, on-demand, monitoring, disruptive, port-related, or active. The asterisks (*) indicate that the test does not have the corresponding attributes.
Test interval
Execution interval for the test. If the execution interval for the test is not set, –NA–is displayed.
Min interval
Minimum execution interval for the test. If the test does not have a minimum execution interval, –NA–is displayed.
Correct-action
Correcting action triggered by failure of the test.
Description for the test.
display diagnostic event-log
Use display diagnostic event-log to display GOLD log entries.
display diagnostic event-log [ error | info ]
error: Displays all error log entries.
info: Displays all log entries except error log entries.
If you do not specify the error and info keywords, the command displays all GOLD log entries.
The system records information about test execution in the form of logs. A log entry contains test name, execution time, test result, and failure cause. Log entries are generated for every execution. To reduce the burden of the information center, GOLD logs are not sent to the information center.
(In standalone mode.) GOLD logs are cleared when the device restarts or when an active/standby MPU switchover occurs.
(In IRF mode.) GOLD logs are cleared when the device restarts or when a global active/standby MPU switchover occurs.
# (In standalone mode.) Display all GOLD log entries.
<Sysname> display diagnostic event-log
Event: E_INFO, Wed Jan  7 11:39:53:314 2014, -Slot=1 TestName->IPCMonitor, Event_INFO: Result->Success.
Use display diagnostic ondemand configuration to display configurations of on-demand diagnostic tests.
# Display the number of executions and the number of failed tests configured for on-demand diagnostic tests.
<Sysname> display diagnostic ondemand configuration
Maximum test-repeating times: 4
Maximum test-failure times: 1
display diagnostic result
Use display diagnostic result to display test results.
In standalone mode:
display diagnostic result [ slot slot-number [ test test-name ] ] [ verbose ]
In IRF mode:
display diagnostic result [ chassis chassis-number [ slot slot-number [ test test-name ] ] ] [ verbose ]
test test-name: Specifies a test by its name, a case-sensitive character string. You can use the test ? command to verify the value range of the test name. If you do not specify this option, the command applies to all diagnostic tests.
verbose: Displays detailed test results for diagnostic tests that are enabled or executed. (Statistics are not included.) If you do not specify this parameter, the command displays brief test results for the diagnostic tests.
# (In standalone mode.) Display brief test results for all diagnostic tests on the specified slot.
<Sysname> display diagnostic result slot 1
Slot 1:
  Name                            Run count    Failure count    Last result
  IPCMonitor                      51           0                Success
  BoardStatusMonitor              386          0                Success
  TaskMonitor                     310          0                Success
  PortMonitor                     310          0                Success
  ComponentMonitor                103          0                Success
# (In standalone mode.) Display detailed test results for all diagnostic tests.
<Sysname> display diagnostic result verbose
Slot 1:
  Total run count          : 52
  Total failure count      : 0
  Consecutive failure count: 0
  Last execution time      : Fri Nov 21 23:13:25 2014
  First failure time       : -NA-
  Last failure time        : -NA-
  Last pass time           : Fri Nov 21 23:13:25 2014
  Last execution result    : Success
  Last failure reason      : -NA-
  Next execution time      : Fri Nov 21 23:14:25 2014
  ipc link status : Normal
  Total run count          : 386
  Last execution time      : Fri Nov 21 23:00:01 2014
  Last pass time           : Fri Nov 21 23:00:01 2014
  Next execution time      : Sat Nov 22 00:00:07 2014
  Slot  check status : Normal
  Total run count          : 313
  Last execution time      : Fri Nov 21 23:13:35 2014
  Last pass time           : Fri Nov 21 23:13:35 2014
  Next execution time      : Fri Nov 21 23:13:45 2014
  Task check status : Normal
  test result: pass
  Total run count          : 104
  Next execution time      : Fri Nov 21 23:13:55 2014
  test result: pass
Test name
Name of the test.
Total run count
Total number of executions.
Total failure count
Total number of failed tests.
Number of consecutive failed tests.
Last execution time
Most recent execution time.
First failure time
First failed test time. If no failure occurs, –NA– is displayed.
Last failure time
Most recent failed test time. If no failure occurs, –NA– is displayed.
Last pass time
Most recent success test time. If no success occurs, –NA– is displayed.
Most recent test result.
Last failure reason
Cause for the most recent failed test. If the failed test is simulated, Simulated Test is displayed. If no failure occurs, –NA– is displayed.
Next execution time
Time for the next execution. If the test is a monitoring diagnostic test, its next execution time is the most recent execution time plus the execution interval. If the test is an on-demand or boot-up diagnostic test, –NA– is displayed.
display diagnostic result statistics
Use display diagnostic result statistics to display statistics for packet-related diagnostic tests.
In standalone mode:
display diagnostic result [ slot slot-number [ test test-name ] ] statistics
In IRF mode:
display diagnostic result [ chassis chassis-number [ slot slot-number [ test test-name ] ] ] statistics
test test-name: Specifies a test by its name, a case-sensitive character string. You can use the test ? command to verify the value range of the test name. If you do not specify this option, the command applies to all packet-related diagnostic tests.
# (In standalone mode.) Display statistics for test PortMonitor on the specified slot.
<Sysname> display diagnostic result slot 1 test PortMonitor statistics
Slot 1:
  Test name: PortMonitor
  Port    Packets sent    Packets received   Packets lost
  1       0               0                  0
  2       0               0                  0
  3       0               0                  0
  4       4               4                  0
  5       4               4                  0
  6       4               4                  0
  7       4               4                  0
  8       0               0                  0
Test name
Name of the test.
Port
Port number.
Packets sent
Number of packets that the device sends.
Packets received
Number of packets that the device receives.
Packets lost
Number of lost packets.
Use display diagnostic simulation to display configurations for simulated diagnostic tests.
In standalone mode:
display diagnostic simulation [ slot slot-number ]
In IRF mode:
display diagnostic simulation [ chassis chassis-number [ slot slot-number ] ]
# (In standalone mode.) Display configurations for all simulated diagnostic tests on the specified slot.
<Sysname> display diagnostic simulation slot 1
Slot 1:
  Name                            Mode
reset diagnostic event-log
Use reset diagnostic event-log to clear GOLD logs.
# Clear GOLD logs.
<Sysname> reset diagnostic event-log
reset diagnostic result
Use reset diagnostic result to clear test results.
In standalone mode:
reset diagnostic result [ slot slot-number [ test test-name ] ]
In IRF mode:
reset diagnostic result [ chassis chassis-number [ slot slot-number [ test test-name ] ] ]
This command does not clear the next execution time.
# (In standalone mode.) Clear test results for test BoardStatusMonitor on the specified slot.
<Sysname> reset diagnostic result slot 1 test BoardStatusMonitor
  • Become a Partner
  • Partner Resources
