- 01-AAA configuration
- 02-Password control configuration
- 03-Keychain configuration
- 04-Public key management
- 05-PKI configuration
- 06-IPsec configuration
- 07-SSH configuration
- 08-SSL configuration
- 09-Object group configuration
- 10-Attack detection and prevention configuration
- 11-TCP attack prevention configuration
- 12-IP source guard configuration
- 13-ARP attack protection configuration
- 14-ND attack defense configuration
- 15-uRPF configuration
- 16-FIPS configuration
- 17-Crypto engine configuration
00-Preface | 100.70 KB |
Preface
This configuration guide describes the security fundamentals and configuration procedures. It covers identity authentication features such as AAA and PKI, data security features such as public key management, SSH, and IPsec, and security defense features such as IP source guard and ARP attack protection.
· Audience
Audience
· Network planners.
· Network administrators working with the S6890 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
