11-Network Management and Monitoring Command Reference
HomeSupportSwitchesS6890 SeriesReference GuidesCommand ReferencesH3C S6890 Switch Series Command References(R27xx)-6W10511-Network Management and Monitoring Command Reference
11-Sampler commands
11-Sampler commands 47.50 KB
Sampler commands
display sampler
Use display sampler to display configuration information for a sampler.
display sampler [ sampler-name ] [ slot slot-number ]
sampler-name: Specifies a sampler by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a sampler, this command displays configuration information for all samplers.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays sampler configuration information for the master device.
# Display the configuration information about sampler 256.
<Sysname> display sampler 256
 Sampler name: 256
  Mode: Random;  Packet-interval: 8; IsNpower: Y
Sampler name
Name of the sampler.
Mode
Sampling mode.
Packet-interval
Sampling rate.
IsNpower
Whether the sampling rate is 2 to the nth power:
·     Y—Yes.
·     N—No.
sampler
Use sampler to create a sampler.
Use undo sampler to delete a sampler.
sampler sampler-name mode random packet-interval n-power rate
undo sampler sampler-name
No samplers exist.
random: Specifies the random sampling mode. A sampler in this mode randomly selects a packet out of a group of packets. Which packet is selected for each sampling varies.
n-power: Specifies the sampling rate as 2 to the nth power.
rate: Specifies the sampling rate. The sampling rate is 2 to the nth power, where n is the value of the rate argument. For example, if the rate argument is set to 8, one packet is selected from 256 (2 to the 8th power) packets in each sampling. The value range for the rate argument is 0 to 15.
# Create sampler abc in random sampling mode. Set the sampling rate to 8 to select one packet form 256 (2 to the 8th power) in each sampling.
[Sysname] sampler abc mode random packet-interval  n-power 8
  • Become a Partner
  • Partner Resources
